Hi DaneLLL,
I modified the source follow you.
diff --git a/drivers/usb/host/xhci-tegra.c b/drivers/usb/host/xhci-tegra.c
index 3b78b50..5eb8240 100644
--- a/drivers/usb/host/xhci-tegra.c
+++ b/drivers/usb/host/xhci-tegra.c
@@ -235,6 +235,8 @@ static struct usb_device_id max_burst_quirk_list[] = {
{ USB_DEVICE_SS(0x0bc2, 0xab26) },
/* Seagate Expansion Portable Drive 1TB */
{ USB_DEVICE_SS(0x0bc2, 0x231a) },
+ { USB_DEVICE_SS(0x152d, 0x0567) },
{ } /* terminating entry must be last */
But it seems not working.
[ 0.000000] Booting Linux on physical CPU 0x100
[ 0.000000] Linux version 4.9.140+ (lyp@lyp-Desktop) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #10 SMP PREEMPT Tue May 19 15:24:24 CST 2020
[ 0.000000] Boot CPU: AArch64 Processor [411fd073]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 80,
[ 0.000000] OF: fdt: - 80000000 , 70000000
[ 0.000000] OF: fdt: - f0200000 , 185600000
[ 0.000000] OF: fdt: - 275e00000 , 200000
[ 0.000000] OF: fdt: - 276600000 , 200000
[ 0.000000] OF: fdt: - 277000000 , 200000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000003100000 (options '')
[ 0.000000] bootconsole [uart8250] enabled
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb0_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb2_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fc000000
[ 0.000000] On node 0 totalpages: 2055168
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 523776 pages, LIFO batch:31
[ 0.000000] Normal zone: 24008 pages used for memmap
[ 0.000000] Normal zone: 1531392 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 25 pages/cpu @ffffffc1f701c000 s61592 r8192 d32616 u102400
[ 0.000000] pcpu-alloc: s61592 r8192 d32616 u102400 alloc=25*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 2022968
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x3100000 nvdumper_reserved=0x2772e0000 gpt usbcore.old_scheme_first=1 tegraid=18.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.2031647.1 bl_prof_dataptr=0x10000@0x275840000 sdhci_tegra.en_boot_part_access=1
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 163840 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 262144 bytes
[ 0.000000] early log buf free: 29448(89%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Memory: 7974800K/8220672K available (15486K kernel code, 2972K rwdata, 6700K rodata, 8640K init, 636K bss, 180336K reserved, 65536K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008200000 - 0xffffff8009120000 ( 15488 KB)
[ 0.000000] .rodata : 0xffffff8009120000 - 0xffffff80097b0000 ( 6720 KB)
[ 0.000000] .init : 0xffffff80097b0000 - 0xffffff800a020000 ( 8640 KB)
[ 0.000000] .data : 0xffffff800a020000 - 0xffffff800a307008 ( 2973 KB)
[ 0.000000] .bss : 0xffffff800a307008 - 0xffffff800a3a611c ( 637 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf07dc8000 ( 125 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc1f7200000 ( 8050 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000003] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.009500] Console: colour dummy device 80x25
[ 0.014161] console [tty0] enabled
[ 0.017718] bootconsole [uart8250] disabled
[ 0.022095] kmemleak: Kernel memory leak detector disabled
[ 0.022111] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.022127] pid_max: default: 32768 minimum: 301
[ 0.022443] Security Framework initialized
[ 0.022606] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.022617] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.023213] ftrace: allocating 47668 entries in 187 pages
[ 0.149940] sched-energy: Sched-energy-costs installed from DT
[ 0.149960] ASID allocator initialised with 65536 entries
[ 0.186130] tegra-id: chipid=21817.
[ 0.186145] tegra-id: opt_subrevision=1.
[ 0.186167] Tegra Revision: A02p SKU: 0xdc CPU Process: 0 SoC Process: 0
[ 0.186182] DTS File Name: arch/arm64/boot/dts/../../../../tegra/hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[ 0.186197] DTB Build time: Apr 14 2020 14:38:59
[ 0.233959] CPU1: Booted secondary processor [4e0f0030]
[ 0.265594] CPU2: Booted secondary processor [4e0f0030]
[ 0.297411] CPU3: Booted secondary processor [411fd073]
[ 0.329376] CPU4: Booted secondary processor [411fd073]
[ 0.361367] CPU5: Booted secondary processor [411fd073]
[ 0.361419] Brought up 6 CPUs
[ 0.361461] SMP: Total of 6 processors activated.
[ 0.361474] CPU features: detected feature: 32-bit EL0 Support
[ 0.362251] CPU: All CPU(s) started at EL2
[ 0.362313] alternatives: patching kernel code
[ 0.371784] devtmpfs: initialized
[ 0.398935] Initilizing CustomIPI irq domain
[ 0.399142] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.399168] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.400021] pinctrl core: initialized pinctrl subsystem
[ 0.400229] OS set in device tree is not L4T.
[ 0.400398] regulator-dummy: no parameters
[ 0.400546] Initializing plugin-manager
[ 0.400605] Plugin module not found
[ 0.400648] Plugin-manager status disabled
[ 0.401967] NET: Registered protocol family 16
[ 0.402733] pstore: using zlib compression
[ 0.403144] console [pstore-1] enabled
[ 0.403156] pstore: Registered ramoops as persistent store backend
[ 0.403169] ramoops: attached 0x200000@0x275880000, ecc: 0/0
[ 0.416986] cpuidle: using governor menu
[ 0.418099] bpmp: waiting for handshake
[ 0.418115] bpmp: handshake completed
[ 0.418139] bpmp: synchronizing channels
[ 0.418154] bpmp: channels synchronized
[ 0.418166] bpmp: mail init ok
[ 0.419878] arm-smmu 12000000.iommu: probing hardware configuration...
[ 0.419896] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.419909] arm-smmu 12000000.iommu: stage 1 translation
[ 0.419922] arm-smmu 12000000.iommu: stage 2 translation
[ 0.419935] arm-smmu 12000000.iommu: nested translation
[ 0.419951] arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.419970] arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.419990] arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.420005] arm-smmu 12000000.iommu: Stage-1: 39-bit VA -> 48-bit IPA
[ 0.420018] arm-smmu 12000000.iommu: Stage-2: 39-bit IPA -> 48-bit PA
[ 0.421801] vdso: 2 pages (1 code @ ffffff8009127000, 1 data @ ffffff800a024000)
[ 0.421829] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.424528] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.425674] Registering BPMP clocks...
[ 0.425770] tegra_bpmp_clk_init: clock init ok (638 clks)
[ 0.427583] tegra_powergate_init: DONE
[ 0.427602] DTS File Name: arch/arm64/boot/dts/../../../../tegra/hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[ 0.427625] DTB Build time: Apr 14 2020 14:38:59
[ 0.429019] Tegra reboot handler registered.
[ 0.430361] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.430440] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[ 0.430463] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ 0.430477] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L0
[ 0.430488] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.430689] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.430717] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.431031] iommu: Adding device 3460000.sdhci to group 0
[ 0.431684] iommu: Adding device 3400000.sdhci to group 1
[ 0.432719] iommu: Adding device 3507000.ahci-sata to group 2
[ 0.432745] arm-smmu: forcing sodev map for 3507000.ahci-sata
[ 0.433208] iommu: Adding device 3160000.i2c to group 3
[ 0.433639] iommu: Adding device c240000.i2c to group 4
[ 0.433979] iommu: Adding device 3180000.i2c to group 5
[ 0.434305] iommu: Adding device 3190000.i2c to group 6
[ 0.434729] iommu: Adding device 31b0000.i2c to group 7
[ 0.435053] iommu: Adding device 31c0000.i2c to group 8
[ 0.435374] iommu: Adding device c250000.i2c to group 9
[ 0.435693] iommu: Adding device 31e0000.i2c to group 10
[ 0.437232] iommu: Adding device 3210000.spi to group 11
[ 0.437559] iommu: Adding device c260000.spi to group 12
[ 0.437879] iommu: Adding device 3240000.spi to group 13
[ 0.438568] iommu: Adding device 3100000.serial to group 14
[ 0.438892] iommu: Adding device 3110000.serial to group 15
[ 0.439214] iommu: Adding device c280000.serial to group 16
[ 0.439535] iommu: Adding device 3130000.serial to group 17
[ 0.440788] iommu: Adding device 2490000.ether_qos to group 18
[ 0.440812] arm-smmu: forcing sodev map for 2490000.ether_qos
[ 0.441500] iommu: Adding device b000000.rtcpu to group 19
[ 0.443531] iommu: Adding device 13e10000.host1x to group 20
[ 0.443844] iommu: Adding device 13e10000.host1x:ctx0 to group 21
[ 0.444156] iommu: Adding device 13e10000.host1x:ctx1 to group 22
[ 0.444474] iommu: Adding device 13e10000.host1x:ctx2 to group 23
[ 0.444783] iommu: Adding device 13e10000.host1x:ctx3 to group 24
[ 0.445121] iommu: Adding device 13e10000.host1x:ctx4 to group 25
[ 0.445433] iommu: Adding device 13e10000.host1x:ctx5 to group 26
[ 0.445752] iommu: Adding device 13e10000.host1x:ctx6 to group 27
[ 0.446063] iommu: Adding device 13e10000.host1x:ctx7 to group 28
[ 0.446513] iommu: Adding device 150c0000.nvcsi to group 29
[ 0.447141] iommu: Adding device 15700000.vi to group 30
[ 0.447488] iommu: Adding device 15600000.isp to group 31
[ 0.447940] iommu: Adding device 15210000.nvdisplay to group 32
[ 0.448510] iommu: Adding device 15340000.vic to group 33
[ 0.448730] iommu: Adding device 154c0000.nvenc to group 34
[ 0.448950] iommu: Adding device 15480000.nvdec to group 35
[ 0.449320] iommu: Adding device 15380000.nvjpg to group 36
[ 0.449557] iommu: Adding device 15500000.tsec to group 37
[ 0.449777] iommu: Adding device 15100000.tsecb to group 38
[ 0.450442] iommu: Adding device 15810000.se to group 39
[ 0.450663] iommu: Adding device 15820000.se to group 40
[ 0.450875] iommu: Adding device 15830000.se to group 41
[ 0.451099] iommu: Adding device 15840000.se to group 42
[ 0.451944] iommu: Adding device smmu_test to group 43
[ 0.452550] mc: mapped MMIO address: 0xffffff800a710000 -> 0x2c10000
[ 0.452574] mc: mapped MMIO address: 0xffffff800a730000 -> 0x2c20000
[ 0.452594] mc: mapped MMIO address: 0xffffff800a750000 -> 0x2c30000
[ 0.452616] mc: mapped MMIO address: 0xffffff800a770000 -> 0x2c40000
[ 0.452635] mc: mapped MMIO address: 0xffffff800a790000 -> 0x2c50000
[ 0.452654] nv-tegra-mc 2c10000.mc: No mssnvlink node
[ 0.452674] mc-err: mcerr ops are set to t18x
[ 0.452817] dram-ecc: DRAM ECC disabled-MC_ECC_CONTROL:0x0000000c
[ 0.453915] iommu: Adding device 3530000.xhci to group 44
[ 0.453940] arm-smmu: forcing sodev map for 3530000.xhci
[ 0.454374] iommu: Adding device 3550000.xudc to group 45
[ 0.454396] arm-smmu: forcing sodev map for 3550000.xudc
[ 0.455113] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.455132] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[ 0.455691] iommu: Adding device 17000000.gp10b to group 46
[ 0.456695] tegra-reset 5000000.clock: registered 193 resets.
[ 0.458829] iommu: Adding device d000000.bpmp to group 47
[ 0.459050] bpmp: ping status is 0
[ 0.459154] bpmp d000000.bpmp: firmware tag is 4208eb5c85fe47a2235fbc0b8eb87dca
[ 0.461245] bpmp d000000.bpmp: probe ok
[ 0.464170] iommu: Adding device 2600000.dma to group 48
[ 0.465396] GPIO line 424 (wifi-enable) hogged as output/high
[ 0.465438] GPIO line 445 (sdmmc-wake-support-input) hogged as input
[ 0.465474] GPIO line 446 (sdmmc-wake-support-output) hogged as output/low
[ 0.465702] gpiochip_setup_dev: registered GPIOs 320 to 511 on device: gpiochip0 (tegra-gpio)
[ 0.469542] GPIO line 315 (wifi-wake-ap) hogged as input
[ 0.469723] gpiochip_setup_dev: registered GPIOs 256 to 319 on device: gpiochip1 (tegra-gpio-aon)
[ 0.471108] iommu: Adding device sound to group 49
[ 0.471476] iommu: Adding device 3510000.hda to group 50
[ 0.479065] iommu: Adding device c1a0000.aon to group 51
[ 0.479523] vdd-ac-bat: 5000 mV
[ 0.481332] vdd-1v8-ap: 1800 mV
[ 0.518777] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.521604] random: fast init done
[ 0.525089] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.525642] SCSI subsystem initialized
[ 0.525878] libata version 3.00 loaded.
[ 0.526238] usbcore: registered new interface driver usbfs
[ 0.526317] usbcore: registered new interface driver hub
[ 0.526460] usbcore: registered new device driver usb
[ 0.532934] gpiochip_setup_dev: registered GPIOs 240 to 255 on device: gpiochip2 (tca9539)
[ 0.543800] max77620 4-003c: PMIC Version OTP:0x45 and ES:0x8
[ 0.550164] vddio-ddr: at 1125 mV
[ 0.553988] avdd_dsi_csi: 1200 mV
[ 0.557995] vdd-1v8: 1800 mV
[ 0.561625] vdd-3v3-sys: 3300 mV
[ 0.562978] spmic-ldo0: at 1800 mV
[ 0.563870] spmic-ldo1: at 800 mV
[ 0.565646] vddio-3v3: 3300 mV
[ 0.566560] vddio-sdmmc1: 1800 <--> 3300 mV at 3300 mV
[ 0.569626] vdd-rtc: at 800 mV
[ 0.570571] avdd-ts-hv: 1800 <--> 3300 mV at 1800 mV
[ 0.573627] spmic-ldo6: at 1500 mV
[ 0.577625] vdd-pex-1v00: 1000 mV
[ 0.578425] dvdd-pex: 1000 mV
[ 0.581064] GPIO line 237 (spmic_gpio_input) hogged as input
[ 0.581270] GPIO line 238 (spmic_gpio_input) hogged as input
[ 0.581544] gpiochip_setup_dev: registered GPIOs 232 to 239 on device: gpiochip3 (max77620-gpio)
[ 0.581875] max77620 4-003c: max77620 probe successful
[ 0.582416] media: Linux media interface: v0.10
[ 0.582489] Linux video capture interface: v2.00
[ 0.586758] pps_core: LinuxPPS API ver. 1 registered
[ 0.586808] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.586879] PTP clock support registered
[ 0.587557] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.587624] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.590702] tegra_fiq_debugger_init: found FIQ source (IRQ 384)
[ 0.596016] trusty trusty: trusty version: Built: 22:43:54 Dec 9 2019
[ 0.596097] trusty trusty: selected api version: 3 (requested 3)
[ 0.597636] Advanced Linux Sound Architecture Driver Initialized.
[ 0.598170] Bluetooth: Core ver 2.22
[ 0.598252] NET: Registered protocol family 31
[ 0.598283] Bluetooth: HCI device and connection manager initialized
[ 0.598323] Bluetooth: HCI socket layer initialized
[ 0.598357] Bluetooth: L2CAP socket layer initialized
[ 0.598409] Bluetooth: SCO socket layer initialized
[ 0.599428] en-vdd-sd: 3300 mV
[ 0.599989] vdd-usb0-5v: 5000 mV
[ 0.600376] vdd-usb1-5v: 5000 mV
[ 0.601045] vdd-3v3: 3300 mV
[ 0.601400] en-vdd-vcm-2v8: 2800 mV
[ 0.601880] vdd-sys-bl: 3300 mV
[ 0.604819] camchar: rtcpu character device driver loaded
[ 0.605450] gpio tegra-gpio wake53 for gpio=159(X:7)
[ 0.607457] extcon-gpio-states external-connection:extcon@1: Cable state:1, cable id:1
[ 0.608820] clocksource: Switched to clocksource arch_sys_counter
[ 0.650304] VFS: Disk quotas dquot_6.6.0
[ 0.650584] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.651257] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.652137] nvmap: nvmap_select_cache_ops() nvmap cache ops set to roc
[ 0.652178] nvmap_page_pool_init: Total RAM pages: 2010084
[ 0.652210] nvmap_page_pool_init: nvmap page pool size: 251260 pages (981 MB)
[ 0.652405] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.656212] tegra-gpcdma 2600000.dma: GPC DMA driver register 32 channels
[ 0.668135] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type BCPU-therm
[ 0.668365] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type MCPU-therm
[ 0.668781] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.668959] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.669131] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tboard_tegra
[ 0.669298] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tdiode_tegra
[ 0.669543] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type PMIC-Die
[ 0.669838] la/ptsa driver initialized.
[ 0.669874] pre_t19x_iso_plat_init(): iso emc max clk=1866000KHz
[ 0.669905] pre_t19x_iso_plat_init(): max_iso_bw=26870400KB
[ 0.671096] NET: Registered protocol family 2
[ 0.673181] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.673872] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.674709] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.674826] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.675062] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.675909] NET: Registered protocol family 1
[ 0.677108] RPC: Registered named UNIX socket transport module.
[ 0.677144] RPC: Registered udp transport module.
[ 0.677173] RPC: Registered tcp transport module.
[ 0.677200] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.677244] PCI: CLS 0 bytes, default 64
[ 0.677539] Trying to unpack rootfs image as initramfs...
[ 0.698699] host1x 13e10000.host1x: initialized
[ 0.700742] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.705579] audit: initializing netlink subsys (disabled)
[ 0.705661] audit: type=2000 audit(0.584:1): initialized
[ 0.706387] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 0.718658] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.721447] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.723101] 9p: Installing v9fs 9p2000 file system support
[ 0.729144] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 0.729336] io scheduler noop registered
[ 0.730008] io scheduler cfq registered (default)
[ 0.735337] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 0.860033] iommu: Adding device aconnect@2a41000:adsp_audio to group 52
[ 0.901150] iommu: Adding device 2993000.adsp to group 53
[ 0.902317] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 0.905435] tegra-xusb-padctl 3520000.xusb_padctl: VBUS over-current detection enabled
[ 0.909278] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 0.910508] tegra-pwm 3290000.pwm: PWM clk can sleep in ops
[ 0.911595] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 0.912669] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 0.916555] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.916787] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1000000, vi_iso_bw=4500000, max_bw=4500000
[ 0.920195] tsec 15500000.tsec: initialized
[ 0.921719] tsec 15100000.tsecb: initialized
[ 0.925355] nvdec 15480000.nvdec: initialized
[ 0.931393] falcon 15340000.vic: initialized
[ 0.933041] falcon 154c0000.nvenc: initialized
[ 0.934614] falcon 15380000.nvjpg: initialized
[ 0.937913] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 0.939612] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 0.941302] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 0.943043] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 0.944732] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 0.946413] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 0.948121] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 0.949916] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 0.952929] tegradccommon 15200000.dc_common: host1x channel mapped
[ 0.952978] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[ 0.953041] tegradccommon 15200000.dc_common: dma mapping done
[ 0.954499] tegra_cec 3960000.tegra_cec: dt=1 start=0x03960000 end=0x03960FFF irq=388
[ 0.954797] tegradc 15210000.nvdisplay: disp0 connected to head1->/host1x/sor1
[ 0.954879] generic_infoframe_type: 0x87
[ 0.954977] tegradc 15210000.nvdisplay: DT parsed successfully
[ 0.955029] tegradc 15210000.nvdisplay: Display dc.ffffff800abe0000 registered with id=0
[ 0.955230] tegra_cec 3960000.tegra_cec: Unpowergate DISP: 0.
[ 0.957038] tegra_cec 3960000.tegra_cec: Enable clock result: 0.
[ 0.957124] tegra_cec 3960000.tegra_cec: tegra_cec_init started
[ 0.957365] tegra_cec 3960000.tegra_cec: cec_add_sysfs ret=0
[ 0.957407] tegra_cec 3960000.tegra_cec: probed
[ 0.960206] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 16727000 KB/s
[ 0.960228] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 665600000 Hz
[ 0.960246] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 357620000 Hz
[ 0.960442] tegradc 15210000.nvdisplay: vblank syncpt # 8 for dc 1
[ 0.960463] tegradc 15210000.nvdisplay: vpulse3 syncpt # 9 for dc 1
[ 0.961545] tegradc 15210000.nvdisplay: dc_hdmi_hotplug_init: couldn't get regulator vdd_hdmi_5v0, -517
[ 0.966774] tegradc 15210000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
[ 0.966826] tegradc 15210000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[ 0.970820] tegradc 15210000.nvdisplay: probed
[ 0.972113] Console: switching to colour frame buffer device 80x30
[ 0.972174] tegradc 15210000.nvdisplay: fb registered
[ 0.972449] gpio tegra-gpio wake21 for gpio=121(P:1)
[ 0.972767] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 32 channels
[ 0.973454] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 0.974039] kfuse 3830000.kfuse: initialized
[ 0.975607] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 0.979863] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.982794] console [ttyS0] disabled
[ 0.982897] 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 36, base_baud = 25500000) is a Tegra
[ 1.976846] tegra_cec 3960000.tegra_cec: Can't find physical addresse.
[ 1.976849] tegra_cec 3960000.tegra_cec: tegra_cec_init Done.
[ 3.219466] console [ttyS0] enabled
[ 3.224923] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 37, base_baud = 0) is a TEGRA_UART
[ 3.234894] c280000.serial: ttyTHS2 at MMIO 0xc280000 (irq = 38, base_baud = 0) is a TEGRA_UART
[ 3.243939] serial-tegra 3130000.serial: RX in PIO mode
[ 3.250165] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 39, base_baud = 0) is a TEGRA_UART
[ 3.260018] [drm] Initialized
[ 3.272633] brd: module loaded
[ 3.280395] loop: module loaded
[ 3.283708] tegra_profiler: version: 1.139, samples/io: 47/27
[ 3.289627] tegra_profiler: auth: init
[ 3.293922] nct1008_nct72 7-004c: starting parse dt
[ 3.294158] THERMAL EST: found 3 subdevs
[ 3.294163] THERMAL EST num_resources: 0
[ 3.294167] [THERMAL EST subdev 0]
[ 3.294173] [THERMAL EST subdev 1]
[ 3.294176] [THERMAL EST subdev 2]
[ 3.294616] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
[ 3.294619] THERMAL EST: thz register success.
[ 3.303018] THERMAL EST: end of probe, return err: 0
[ 3.304140] hisi_sas: driver version v1.6
[ 3.308935] tegra-ahci 3507000.ahci-sata: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl platform mode
[ 3.308947] tegra-ahci 3507000.ahci-sata: flags: 64bit ncq sntf pm led pmp pio slum part deso sadm apst
[ 3.313866] scsi host0: tegra_ahci
[ 3.314904] scsi host1: tegra_ahci
[ 3.315093] ata1: SATA max UDMA/133 mmio [mem 0x03507000-0x03508fff] port 0x100 irq 24
[ 3.315098] ata2: DUMMY
[ 3.320626] libphy: Fixed MDIO Bus: probed
[ 3.321096] tun: Universal TUN/TAP device driver, 1.6
[ 3.321100] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 3.326271] vcan: Virtual CAN interface driver
[ 3.326276] slcan: serial line CAN interface driver
[ 3.326280] slcan: 10 dynamic interface channels.
[ 3.326285] CAN device driver interface
[ 3.326361] cc770: CAN netdevice driver
[ 3.326481] sja1000 CAN netdevice driver
[ 3.328534] Message RAM Configuration
| base addr |0x0c312000|
| sidfc_flssa |0x00000000|
| xidfc_flesa |0x00000040|
| rxf0c_f0sa |0x000000c0|
| rxf1c_f1sa |0x000009c0|
| rxbc_rbsa |0x000009c0|
| txefc_efsa |0x000009c0|
| txbc_tbsa |0x00000a40|
| tmc_tmsa |0x00000ec0|
[ 3.328735] Release 3.2.0 from 19.12.2014
[ 3.329128] net can0: mttcan device registered (regs=ffffff800a54c000, irq=385)
[ 3.330884] Message RAM Configuration
| base addr |0x0c322000|
[ 3.331086] Release 3.2.0 from 19.12.2014
[ 3.331408] net can1: mttcan device registered (regs=ffffff800a62c000, irq=386)
[ 3.332000] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 3.332003] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 3.332059] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 3.332062] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 3.332100] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 3.332103] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 3.332140] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 3.332144] Copyright(c) 1999 - 2017 Intel Corporation.
[ 3.340965] eqos 2490000.ether_qos: can't get pllrefe_vcoout clk (-2)
[ 3.344867] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b a5 b cf
[ 3.344993] libphy: dwc_phy: probed
[ 3.345379] bcm54xx_low_power_mode(): put phy in iddq-lp mode
[ 3.347493] PPP generic driver version 2.4.2
[ 3.347641] PPP BSD Compression module registered
[ 3.347645] PPP Deflate Compression module registered
[ 3.347688] PPP MPPE Compression module registered
[ 3.347692] NET: Registered protocol family 24
[ 3.347742] usbcore: registered new interface driver r8152
[ 3.347780] usbcore: registered new interface driver asix
[ 3.347813] usbcore: registered new interface driver ax88179_178a
[ 3.347854] usbcore: registered new interface driver cdc_ether
[ 3.347879] usbcore: registered new interface driver net1080
[ 3.347904] usbcore: registered new interface driver cdc_subset
[ 3.347929] usbcore: registered new interface driver zaurus
[ 3.347964] usbcore: registered new interface driver cdc_ncm
[ 3.349249] VFIO - User Level meta-driver version: 0.3
[ 3.354878] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 3.354892] ehci-pci: EHCI PCI platform driver
[ 3.354931] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 3.354939] ohci-pci: OHCI PCI platform driver
[ 3.354972] ohci-platform: OHCI generic platform driver
[ 3.360032] tegra-xusb 3530000.xhci: USB2 port 0 has OTG_CAP
[ 3.361998] tegra-xusb 3530000.xhci: extcon 0: ffffffc1eac22800 id
[ 3.362125] tegra-xusb 3530000.xhci: Direct firmware load for tegra18x_xusb_firmware failed with error -2
[ 3.362130] tegra-xusb 3530000.xhci: Falling back to user helper
[ 3.362545] usbcore: registered new interface driver cdc_acm
[ 3.362548] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 3.362595] usbcore: registered new interface driver usblp
[ 3.362627] usbcore: registered new interface driver cdc_wdm
[ 3.362659] usbcore: registered new interface driver uas
[ 3.362780] usbcore: registered new interface driver usb-storage
[ 3.362824] usbcore: registered new interface driver ums-realtek
[ 3.362904] usbcore: registered new interface driver usbserial
[ 3.362945] usbcore: registered new interface driver ch341
[ 3.362981] usbserial: USB Serial support registered for ch341-uart
[ 3.363109] usbcore: registered new interface driver cp210x
[ 3.363139] usbserial: USB Serial support registered for cp210x
[ 3.363181] usbcore: registered new interface driver cypress_m8
[ 3.363202] usbserial: USB Serial support registered for DeLorme Earthmate USB
[ 3.363221] usbserial: USB Serial support registered for HID->COM RS232 Adapter
[ 3.363250] usbserial: USB Serial support registered for Nokia CA-42 V2 Adapter
[ 3.363279] usbcore: registered new interface driver ftdi_sio
[ 3.363310] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 3.363334] usbcore: registered new interface driver garmin_gps
[ 3.363353] usbserial: USB Serial support registered for Garmin GPS usb/tty
[ 3.363391] usbcore: registered new interface driver ipw
[ 3.363411] usbserial: USB Serial support registered for IPWireless converter
[ 3.363450] usbcore: registered new interface driver option
[ 3.363478] usbserial: USB Serial support registered for GSM modem (1-port)
[ 3.363509] usbcore: registered new interface driver pl2303
[ 3.363534] usbserial: USB Serial support registered for pl2303
[ 3.363566] usbcore: registered new interface driver usb_serial_simple
[ 3.363596] usbserial: USB Serial support registered for carelink
[ 3.363621] usbserial: USB Serial support registered for zio
[ 3.363640] usbserial: USB Serial support registered for funsoft
[ 3.363658] usbserial: USB Serial support registered for flashloader
[ 3.363676] usbserial: USB Serial support registered for google
[ 3.363695] usbserial: USB Serial support registered for libtransistor
[ 3.363727] usbserial: USB Serial support registered for vivopay
[ 3.363757] usbserial: USB Serial support registered for moto_modem
[ 3.363776] usbserial: USB Serial support registered for motorola_tetra
[ 3.363803] usbserial: USB Serial support registered for novatel_gps
[ 3.363846] usbserial: USB Serial support registered for hp4x
[ 3.363872] usbserial: USB Serial support registered for suunto
[ 3.363890] usbserial: USB Serial support registered for siemens_mpi
[ 3.367505] tegra-xudc-new 3550000.xudc: device count: 1
[ 3.368705] tegra-xudc-new 3550000.xudc: vbus state: 1
[ 3.441201] tegra-usb-cd usb_cd: notification status (0x0, 0x1)
[ 3.441207] tegra-usb-cd usb_cd: connected to SDP
[ 3.441220] tegra-xudc-new 3550000.xudc: device mode on: 0
[ 3.441425] tegra-xudc-new 3550000.xudc: active: 0 => 1
[ 3.442309] mousedev: PS/2 mouse device common for all mice
[ 3.442423] usbcore: registered new interface driver xpad
[ 3.574670] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 3.576032] Wake73 for irq=42
[ 3.577356] rtc rtc1: alarm rtc device
[ 3.577371] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 3.577393] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 3.577603] i2c /dev entries driver
[ 3.579458] pca954x 2-0070: vcc-pullup regulator not found
[ 3.579471] pca954x 2-0070: pca954x_probe: forcing device bus number, start 30.
[ 3.579476] pca954x 2-0070: device detect skipped.
[ 3.579937] i2c i2c-2: Added multiplexed i2c bus 30
[ 3.580891] i2c i2c-2: Added multiplexed i2c bus 31
[ 3.581310] i2c i2c-2: Added multiplexed i2c bus 32
[ 3.581712] i2c i2c-2: Added multiplexed i2c bus 33
[ 3.582009] i2c i2c-2: Added multiplexed i2c bus 34
[ 3.582281] i2c i2c-2: Added multiplexed i2c bus 35
[ 3.582669] i2c i2c-2: Added multiplexed i2c bus 36
[ 3.583662] i2c i2c-2: Added multiplexed i2c bus 37
[ 3.583669] pca954x 2-0070: registered 8 multiplexed busses for I2C switch pca9548
[ 3.585175] cax02_5 30-0030: probing v4l2 sensor.
[ 3.585238] cax02_5 30-0030: Failed to create debugfs directory
[ 3.630138] ata1: SATA link down (SStatus 0 SControl 300)
[ 3.793333] cax02_5 30-0030: tegracam sensor driver:cax02_v2.0.6
[ 4.125878] nct1008_nct72 7-004c: !!!Found deprecated property!!!
[ 4.131998] nct1008_nct72 7-004c: success parsing dt
[ 4.137090] nct1008_nct72 7-004c: success in enabling tmp451 VDD rail
[ 4.176041] nct1008_nct72 7-004c: LOC shutdown limit 107
[ 4.181964] nct1008_nct72 7-004c: EXT shutdown limit 107
[ 4.220173] nct1008_nct72 7-004c: initial LOC temp: 34000
[ 4.226043] nct1008_nct72 7-004c: initial EXT temp: 46000
[ 4.232248] nct1008_nct72 7-004c: hi_b:-11, lo_b:0
[ 4.237567] gpio tegra-gpio-aon wake35 for gpio=16(V:0)
[ 4.243068] nct1008_nct72 7-004c: nct1008_probe: initialized
[ 4.281234] tegra-i2c 3180000.i2c: no acknowledge from address 0x40
[ 4.288172] cax02_5 30-0030: Could not detect cax05 pdaq5 camera
[ 4.294380] cax02_5 31-0030: probing v4l2 sensor.
[ 4.299212] cax02_5 31-0030: Failed to create debugfs directory
[ 4.513274] cax02_5 31-0030: tegracam sensor driver:cax02_v2.0.6
[ 5.536970] cax02_5 31-0030: channel[0] ov490 read resolution 1280x720
[ 5.544043] cax02_5 32-0030: probing v4l2 sensor.
[ 5.548887] cax02_5 32-0030: Failed to create debugfs directory
[ 5.761220] cax02_5 32-0030: tegracam sensor driver:cax02_v2.0.6
[ 6.233218] tegra-i2c 3180000.i2c: no acknowledge from address 0x40
[ 6.240125] cax02_5 32-0030: Could not detect cax05 pdaq5 camera
[ 6.246288] cax02_5 33-0030: probing v4l2 sensor.
[ 6.251143] cax02_5 33-0030: Failed to create debugfs directory
[ 6.465237] cax02_5 33-0030: tegracam sensor driver:cax02_v2.0.6
[ 6.937220] tegra-i2c 3180000.i2c: no acknowledge from address 0x40
[ 6.944126] cax02_5 33-0030: Could not detect cax05 pdaq5 camera
[ 6.950301] cax02_5 36-0030: probing v4l2 sensor.
[ 6.955118] cax02_5 36-0030: Failed to create debugfs directory
[ 7.169216] cax02_5 36-0030: tegracam sensor driver:cax02_v2.0.6
[ 7.641216] tegra-i2c 3180000.i2c: no acknowledge from address 0x40
[ 7.648110] cax02_5 36-0030: Could not detect cax05 pdaq5 camera
[ 7.654266] cax02_5 37-0030: probing v4l2 sensor.
[ 7.659078] cax02_5 37-0030: Failed to create debugfs directory
[ 7.873253] cax02_5 37-0030: tegracam sensor driver:cax02_v2.0.6
[ 8.345216] tegra-i2c 3180000.i2c: no acknowledge from address 0x40
[ 8.352107] cax02_5 37-0030: Could not detect cax05 pdaq5 camera
[ 8.359193] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 8.371566] parse_throttle_dt_data: Num cap clks = 4
[ 8.376584] parse_throttle_dt_data: clk=mcpu type=1
[ 8.381489] parse_throttle_dt_data: clk=bcpu type=2
[ 8.386400] parse_throttle_dt_data: clk=gpu type=4
[ 8.391217] parse_throttle_dt_data: clk=emc type=3
[ 8.397045] tegra_throttle_probe: probe successful. #cdevs=4
[ 8.403249] FAN: coudln't get the regulator
[ 8.409167] device-mapper: uevent: version 1.0.3
[ 8.414681] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 8.423497] CPU EMC frequency mapping table: default setting
[ 8.436104] cpufreq: platform driver Initialization: pass
[ 8.442086] cpuidle: Initializing cpuidle driver init for Denver cluster
[ 8.448975] cpuidle: Initializing cpuidle driver init for A57 cluster
[ 8.456270] sdhci: Secure Digital Host Controller Interface driver
[ 8.462481] sdhci: Copyright(c) Pierre Ossman
[ 8.466861] sdhci-pltfm: SDHCI platform and OF driver helper
[ 8.474160] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 8.483349] CMDQ: cmdq_platfm_init successful
[ 8.488951] CQE: CMD_TIMING bit set for R1B DCMD
[ 8.488998] sdhci-tegra 3440000.sdhci: Client registration for eMC Successful
[ 8.494217] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 8.494266] sdhci-tegra 3400000.sdhci: Got WP GPIO
[ 8.496132] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 8.498034] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 257
[ 8.503228] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 8.504263] tegra-se-nvhost 15810000.se: initialized
[ 8.505386] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 8.506182] tegra-se-nvhost 15820000.se: initialized
[ 8.509966] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 8.510542] tegra-se-nvhost 15830000.se: initialized
[ 8.511380] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 8.511906] tegra-se-nvhost 15840000.se: initialized
[ 8.512978] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 8.513258] hidraw: raw HID events driver (C) Jiri Kosina
[ 8.518515] usbcore: registered new interface driver usbhid
[ 8.518516] usbhid: USB HID core driver
[ 8.522527] tegra186-cam-rtcpu b000000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 8.524601] tegra-ivc ivc-b000000.rtcpu: region 0: iova=0xbfef0000-0xbfefdb7f size=56192
[ 8.524830] tegra-ivc ivc-b000000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 8.524970] tegra-ivc ivc-b000000.rtcpu:i2c@480: i2c: ver=0 grp=1 RX[8x128]=0x1900-0x1d80 TX[8x128]=0x1d80-0x2200
[ 8.525178] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: vinotify: ver=0 grp=1 RX[64x128]=0x2200-0x4280 TX[64x128]=0x4280-0x6300
[ 8.525981] tegra-ivc ivc-b000000.rtcpu:mods@32c0: mods: ver=0 grp=1 RX[1x64]=0x6300-0x63c0 TX[1x64]=0x63c0-0x6480
[ 8.526050] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivccontrol: ver=0 grp=1 RX[16x320]=0x6480-0x7900 TX[16x320]=0x7900-0x8d80
[ 8.526096] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivccapture: ver=0 grp=1 RX[16x64]=0x8d80-0x9200 TX[16x64]=0x9200-0x9680
[ 8.526140] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: dbg: ver=0 grp=1 RX[1x384]=0x9680-0x9880 TX[1x384]=0x9880-0x9a80
[ 8.526228] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: dbg: ver=0 grp=1 RX[1x8192]=0x9a80-0xbb00 TX[1x8192]=0xbb00-0xdb80
[ 8.526518] tegra186-cam-rtcpu b000000.rtcpu: using cam RTCPU IRQ (51)
[ 8.526520] tegra186-cam-rtcpu b000000.rtcpu: tegra_camrtc_mon_create is successful
[ 8.526995] tegra186-cam-rtcpu b000000.rtcpu: firmware version cpu=sce cmd=5 sha1=3ecb1dca25fa98771f988f238c025334776c9a96
[ 8.528517] tegra_aon c1a0000.aon: tegra aon driver probe OK
[ 8.529420] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 8.529729] register_ari_mca_banks: Registered MCA ROC:IOB
[ 8.529802] register_ari_mca_banks: Registered MCA ROC:CCE
[ 8.530431] tegra18-bridge 2390000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 8.530435] tegra18-bridge 2390000.axi2apb: enabled timeout = 11155000
[ 8.530437] tegra18-bridge 2390000.axi2apb: bridge probed OK
[ 8.530495] tegra18-bridge 23a0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 8.530498] tegra18-bridge 23a0000.axi2apb: enabled timeout = 11155000
[ 8.530500] tegra18-bridge 23a0000.axi2apb: bridge probed OK
[ 8.530556] tegra18-bridge 23b0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 8.530560] tegra18-bridge 23b0000.axi2apb: enabled timeout = 11155000
[ 8.530562] tegra18-bridge 23b0000.axi2apb: bridge probed OK
[ 8.530616] tegra18-bridge 23c0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 8.530619] tegra18-bridge 23c0000.axi2apb: enabled timeout = 11155000
[ 8.530621] tegra18-bridge 23c0000.axi2apb: bridge probed OK
[ 8.530677] tegra18-bridge 23d0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 8.530680] tegra18-bridge 23d0000.axi2apb: enabled timeout = 11155000
[ 8.530682] tegra18-bridge 23d0000.axi2apb: bridge probed OK
[ 8.530739] tegra18-bridge 2100000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 8.530744] tegra18-bridge 2100000.axip2p: enabled timeout = 11155000
[ 8.530747] tegra18-bridge 2100000.axip2p: bridge probed OK
[ 8.530809] tegra18-bridge 2110000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 8.530814] tegra18-bridge 2110000.axip2p: enabled timeout = 11155000
[ 8.530816] tegra18-bridge 2110000.axip2p: bridge probed OK
[ 8.530867] tegra18-bridge 2120000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 8.530872] tegra18-bridge 2120000.axip2p: enabled timeout = 11155000
[ 8.530875] tegra18-bridge 2120000.axip2p: bridge probed OK
[ 8.530925] tegra18-bridge 2130000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 8.530930] tegra18-bridge 2130000.axip2p: enabled timeout = 11155000
[ 8.530933] tegra18-bridge 2130000.axip2p: bridge probed OK
[ 8.530983] tegra18-bridge 2140000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 8.530986] tegra18-bridge 2140000.axip2p: enabled timeout = 11155000
[ 8.530988] tegra18-bridge 2140000.axip2p: bridge probed OK
[ 8.531038] tegra18-bridge 2150000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 8.531044] tegra18-bridge 2150000.axip2p: enabled timeout = 11155000
[ 8.531047] tegra18-bridge 2150000.axip2p: bridge probed OK
[ 8.531096] tegra18-bridge 2160000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 8.531102] tegra18-bridge 2160000.axip2p: enabled timeout = 11155000
[ 8.531104] tegra18-bridge 2160000.axip2p: bridge probed OK
[ 8.531154] tegra18-bridge 2170000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 8.531160] tegra18-bridge 2170000.axip2p: enabled timeout = 11155000
[ 8.531162] tegra18-bridge 2170000.axip2p: bridge probed OK
[ 8.531216] tegra18-bridge 2180000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 8.531222] tegra18-bridge 2180000.axip2p: enabled timeout = 11155000
[ 8.531224] tegra18-bridge 2180000.axip2p: bridge probed OK
[ 8.531275] tegra18-bridge 2190000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 8.531280] tegra18-bridge 2190000.axip2p: enabled timeout = 11155000
[ 8.531283] tegra18-bridge 2190000.axip2p: bridge probed OK
[ 8.531343] tegra18_a57_serr_init: on CPU 1 a Denver Core
[ 8.531402] tegra18x_actmon d230000.actmon: in actmon_register()...
[ 8.531989] tegra18x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 8.532426] hw perfevents: enabled with denver15_uncore_pmu PMU driver, 3 counters available
[ 8.532532] denver_knobs_init:MTS_VERSION:47926945
[ 8.535517] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit with 64 bit addr
[ 8.540469] nvpmodel: initialized successfully
[ 8.544654] trusty-virtio trusty:virtio: initializing
[ 8.544907] gpio tegra-gpio wake71 for gpio=125(P:5)
[ 8.544958] mmc2: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 8.546247] trusty_ipc virtio0: vring0: va(pa) ffffffc1e9f4a000(0) qsz 32 notifyid 1
[ 8.546256] trusty_ipc virtio0: vring1: va(pa) ffffffc1e9f54000(0) qsz 32 notifyid 2
[ 8.546439] trusty-virtio trusty:virtio: initializing done
[ 8.546565] trusty_ipc virtio0: is online
[ 8.548066] usbcore: registered new interface driver snd-usb-audio
[ 8.556179] input: tegra-hda HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[ 8.556340] input: tegra-hda HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[ 8.636075] OPE platform probe
[ 8.636140] OPE platform probe successful
[ 8.714723] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 8.714794] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 8.714863] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 8.714930] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 8.714996] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 8.715062] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 8.715125] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 8.715194] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 8.715256] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 8.715325] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 8.715394] tegra-asoc: sound: ADMAIF11 <-> ADMAIF11 mapping ok
[ 8.715457] tegra-asoc: sound: ADMAIF12 <-> ADMAIF12 mapping ok
[ 8.715526] tegra-asoc: sound: ADMAIF13 <-> ADMAIF13 mapping ok
[ 8.715592] tegra-asoc: sound: ADMAIF14 <-> ADMAIF14 mapping ok
[ 8.715656] tegra-asoc: sound: ADMAIF15 <-> ADMAIF15 mapping ok
[ 8.715722] tegra-asoc: sound: ADMAIF16 <-> ADMAIF16 mapping ok
[ 8.715786] tegra-asoc: sound: ADMAIF17 <-> ADMAIF17 mapping ok
[ 8.715849] tegra-asoc: sound: ADMAIF18 <-> ADMAIF18 mapping ok
[ 8.715919] tegra-asoc: sound: ADMAIF19 <-> ADMAIF19 mapping ok
[ 8.715984] tegra-asoc: sound: ADMAIF20 <-> ADMAIF20 mapping ok
[ 8.734962] u32 classifier
[ 8.734963] Actions configured
[ 8.735020] Initializing XFRM netlink socket
[ 8.735566] NET: Registered protocol family 10
[ 8.736115] NET: Registered protocol family 17
[ 8.736125] NET: Registered protocol family 15
[ 8.736182] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 8.736183] can: controller area network core (rev 20120528 abi 9)
[ 8.736248] NET: Registered protocol family 29
[ 8.736260] can: raw protocol (rev 20120528)
[ 8.736261] can: broadcast manager protocol (rev 20161123 t)
[ 8.736264] can: netlink gateway (rev 20130117) max_hops=1
[ 8.736399] Bluetooth: RFCOMM socket layer initialized
[ 8.736406] Bluetooth: RFCOMM ver 1.11
[ 8.736409] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 8.736415] Bluetooth: HIDP socket layer initialized
[ 8.736430] 9pnet: Installing 9P2000 support
[ 8.736460] Key type dns_resolver registered
[ 8.740495] Registered cp15_barrier emulation handler
[ 8.741035] Registered setend emulation handler
[ 8.741865] registered taskstats version 1
[ 8.744739] isp 15600000.isp: initialized
[ 8.748596] nvcsi 150c0000.nvcsi: initialized
[ 8.753939] tegra-vi4 15700000.vi: initialized
[ 8.754643] gpio tegra-gpio-aon wake29 for gpio=56(FF:0)
[ 8.754715] gpio tegra-gpio-aon wake67 for gpio=57(FF:1)
[ 8.754779] gpio tegra-gpio-aon wake68 for gpio=58(FF:2)
[ 8.754819] tegra-vi4 15700000.vi: subdev 150c0000.nvcsi--6 bound
[ 8.754891] tegra-vi4 15700000.vi: subdev 150c0000.nvcsi--5 bound
[ 8.754895] tegra-vi4 15700000.vi: subdev cax02_5 31-0030 bound
[ 8.754896] input: gpio-keys as /devices/gpio-keys/input/input2
[ 8.755489] tegra-vi4 15700000.vi: subdev 150c0000.nvcsi--4 bound
[ 8.755556] tegra-vi4 15700000.vi: subdev 150c0000.nvcsi--3 bound
[ 8.755624] tegra-vi4 15700000.vi: subdev 150c0000.nvcsi--2 bound
[ 8.755692] tegra-vi4 15700000.vi: subdev 150c0000.nvcsi--1 bound
[ 8.791299] tegra_rtc c2a0000.rtc: setting system clock to 2020-05-19 07:35:07 UTC (1589873707)
[ 8.800161] mmc1: hw tuning done ...
[ 8.807125] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[ 8.821117] bpmp: mounted debugfs mirror
[ 8.822039] bwmgr: missing cdev-type property
[ 8.828043] spmic-ldo0: disabling
[ 8.828208] spmic-ldo1: disabling
[ 8.828350] en-vdd-sd: disabling
[ 8.828351] vdd-usb0-5v: disabling
[ 8.828353] vdd-usb1-5v: disabling
[ 8.828354] vdd-3v3: disabling
[ 8.828356] en-vdd-vcm-2v8: disabling
[ 8.828358] vdd-sys-bl: disabling
[ 8.828359] ALSA device list:
[ 8.828361] #0: tegra-hda at 0x3518000 irq 381
[ 8.828362] #1: tegra-snd-t186ref-mobile-rt565x
[ 9.538733] Waiting for root device /dev/mmcblk0p1...
[ 9.580872] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 9.654473] mmc0: mmc_decode_ext_csd: CMDQ supported: depth: 31, cmdq_support: 1
[ 9.675834] mmc0: periodic cache flush enabled
[ 9.680301] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 9.687153] mmcblk0: mmc0:0001 032G34 29.1 GiB
[ 9.691934] mmcblk0boot0: mmc0:0001 032G34 partition 1 4.00 MiB
[ 9.698133] mmcblk0boot1: mmc0:0001 032G34 partition 2 4.00 MiB
[ 9.708397] mmcblk0rpmb: mmc0:0001 032G34 partition 3 4.00 MiB
[ 9.718614] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 p26 p27 p28 p29 p30 p31 p32 p33
[ 9.841265] EXT4-fs (mmcblk0p1): 10 orphan inodes deleted
[ 9.846702] EXT4-fs (mmcblk0p1): recovery complete
[ 9.856194] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 9.864347] VFS: Mounted root (ext4 filesystem) on device 179:1.
[ 9.875798] devtmpfs: mounted
[ 9.880734] Freeing unused kernel memory: 8640K
[ 10.063286] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 10.114089] cgroup: cgroup2: unknown option "nsdelegate"
[ 10.145611] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 10.170378] systemd[1]: Detected architecture arm64.
[ 10.272707] systemd[1]: Set hostname to <calmcar-pdaq>.
[ 10.400384] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 10.417604] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 10.620657] random: systemd: uninitialized urandom read (16 bytes read)
[ 10.630823] systemd[1]: Created slice System Slice.
[ 10.636627] random: systemd: uninitialized urandom read (16 bytes read)
[ 10.643691] systemd[1]: Listening on udev Control Socket.
[ 10.649417] random: systemd: uninitialized urandom read (16 bytes read)
[ 10.656518] systemd[1]: Listening on Journal Socket.
[ 10.666549] systemd[1]: Starting calmcar pdaq rtmp service...
[ 10.667400] systemd[2257]: calmcar-rtmp.service: Failed to execute command: No such file or directory
[ 10.682347] systemd[1]: Listening on Syslog Socket.
[ 10.712151] gpio tegra-gpio-aon wake30 for gpio=60(FF:4)
[ 10.749699] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 10.819525] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 11.210396] systemd-journald[2416]: Received request to flush runtime journal from PID 1
[ 11.817715] random: crng init done
[ 11.821122] random: 7 urandom warning(s) missed due to ratelimiting
[ 11.880639] tegra-xusb 3530000.xhci: cannot find firmware....retry after 1 second
[ 12.509791] gpio tegra-gpio wake18 for gpio=101(M:5)
[ 12.512527] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 12.806244] dhd_module_init in
[ 12.806325] found wifi platform device bcmdhd_wlan
[ 12.807528] wifi_platform_get_country_code_map: could not get country_code_map
[ 12.807532] wifi_plat_dev_drv_probe:platform country code map is not available
[ 12.807552] Power-up adapter 'DHD generic adapter'
[ 12.807559] wifi_platform_set_power = 1
[ 12.892368] tegra-xusb 3530000.xhci: Firmware timestamp: 2019-07-08 19:32:42 UTC, Version: 55.15 release
[ 12.920908] tegra-xusb 3530000.xhci: xHCI Host Controller
[ 12.920935] tegra-xusb 3530000.xhci: new USB bus registered, assigned bus number 1
[ 12.921834] tegra-xusb 3530000.xhci: hcc params 0x0184fd25 hci version 0x100 quirks 0x00050810
[ 12.921875] tegra-xusb 3530000.xhci: irq 70, io mem 0x03530000
[ 12.922148] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 12.922153] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 12.922157] usb usb1: Product: xHCI Host Controller
[ 12.922161] usb usb1: Manufacturer: Linux 4.9.140+ xhci-hcd
[ 12.922164] usb usb1: SerialNumber: 3530000.xhci
[ 12.922599] hub 1-0:1.0: USB hub found
[ 12.922663] hub 1-0:1.0: 4 ports detected
[ 12.923016] tegra-xusb 3530000.xhci: xHCI Host Controller
[ 12.923027] tegra-xusb 3530000.xhci: new USB bus registered, assigned bus number 2
[ 12.926332] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 12.926340] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 12.926344] usb usb2: Product: xHCI Host Controller
[ 12.926347] usb usb2: Manufacturer: Linux 4.9.140+ xhci-hcd
[ 12.926351] usb usb2: SerialNumber: 3530000.xhci
[ 12.926717] hub 2-0:1.0: USB hub found
[ 12.926767] hub 2-0:1.0: 3 ports detected
[ 13.017496] wifi_platform_bus_enumerate device present 1
[ 13.046280] wifi_platform_bus_enumerate device present 0
[ 13.046800] F1 signature read @0x18000000=0x17214354
[ 13.051280] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 13.052065] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 13.052156] wifi_platform_get_mac_addr
[ 13.055320] ids dhd_log_netlink_init
[ 13.055675] wl_create_event_handler(): thread:wl_event_handler:1626 started
[ 13.055677] wl_event_handler :
[ 13.055679] tsk Enter, tsk = 0xffffffc1e2681a90
[ 13.057375] dhd_attach(): thread:dhd_watchdog_thread:1628 started
[ 13.057438] dhd_attach(): thread:dhd_dpc:1629 started
[ 13.057504] dhd_attach(): thread:dhd_rxf:162a started
[ 13.057510] dhd_deferred_work_init: work queue initialized
[ 13.058691]
Dongle Host Driver, version 1.201.82 (r)
Compiled from
[ 13.059185] Register interface [wlan0] MAC: 00:04:4b:a5:0b:cd
[ 13.059189] dhd_prot_ioctl : bus is down. we have nothing to do
[ 13.059310] sdhci-tegra 3440000.sdhci: Tuning done, restoring the best tap value : 61
[ 13.060352] wifi_platform_set_power = 0
[ 13.252876] usb 1-3: new high-speed USB device number 2 using tegra-xusb
[ 13.288653] usb 1-3: New USB device found, idVendor=19d2, idProduct=1476
[ 13.288662] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 13.288666] usb 1-3: Product: Android
[ 13.288669] usb 1-3: Manufacturer: Android
[ 13.288673] usb 1-3: SerialNumber: e5d317eb
[ 13.291146] option 1-3:1.0: GSM modem (1-port) converter detected
[ 13.291423] usb 1-3: GSM modem (1-port) converter now attached to ttyUSB0
[ 13.291691] option 1-3:1.1: GSM modem (1-port) converter detected
[ 13.292977] usb 1-3: GSM modem (1-port) converter now attached to ttyUSB1
[ 13.303493] option 1-3:1.2: GSM modem (1-port) converter detected
[ 13.303721] usb 1-3: GSM modem (1-port) converter now attached to ttyUSB2
[ 13.309514] cdc_ether 1-3:1.3 usb0: register 'cdc_ether' at usb-3530000.xhci-3, ZTE CDC Ethernet Device, fa:82:1b:88:f1:96
[ 13.670092] zram: Added device: zram0
[ 13.670591] zram: Added device: zram1
[ 13.672617] zram: Added device: zram2
[ 13.674063] zram: Added device: zram3
[ 13.675550] zram: Added device: zram4
[ 13.680961] zram: Added device: zram5
[ 13.713224] zram0: detected capacity change from 0 to 686845952
[ 13.721194]
Compiled from
[ 13.721205] wl_android_wifi_on in
[ 13.721210] wifi_platform_set_power = 1
[ 13.772071] Adding 670744k swap on /dev/zram0. Priority:5 extents:1 across:670744k SS
[ 13.775120] zram1: detected capacity change from 0 to 686845952
[ 13.794900] Adding 670744k swap on /dev/zram1. Priority:5 extents:1 across:670744k SS
[ 13.803134] zram2: detected capacity change from 0 to 686845952
[ 13.819308] Adding 670744k swap on /dev/zram2. Priority:5 extents:1 across:670744k SS
[ 13.829160] zram3: detected capacity change from 0 to 686845952
[ 13.846543] Adding 670744k swap on /dev/zram3. Priority:5 extents:1 across:670744k SS
[ 13.855744] zram4: detected capacity change from 0 to 686845952
[ 13.872411] Adding 670744k swap on /dev/zram4. Priority:5 extents:1 across:670744k SS
[ 13.875290] zram5: detected capacity change from 0 to 686845952
[ 13.894290] Adding 670744k swap on /dev/zram5. Priority:5 extents:1 across:670744k SS
[ 13.937938] vdd-1v8: voltage operation not allowed
[ 13.942847] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 13.972995] vdd-1v8: voltage operation not allowed
[ 13.977849] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 14.005825] vdd-1v8: voltage operation not allowed
[ 14.010705] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 14.021004] vdd-1v8: voltage operation not allowed
[ 14.025865] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 14.141344] vdd-1v8: voltage operation not allowed
[ 14.146285] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 14.155647] vdd-1v8: voltage operation not allowed
[ 14.160478] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 14.168788] vdd-1v8: voltage operation not allowed
[ 14.173640] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 14.180339] sdhci-tegra 3440000.sdhci: Tuning done, restoring the best tap value : 61
[ 14.180881] F1 signature read @0x18000000=0x17214354
[ 14.188991] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 14.190160] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 14.284255] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
[ 14.326276] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
[ 14.326526] gpio tegra-gpio-aon wake69 for gpio=59(FF:3)
[ 14.326580] gpio tegra-gpio-aon wake69 for gpio=59(FF:3)
[ 14.326582] Enabling wake69
[ 14.327301] wifi_platform_get_mac_addr
[ 14.329233] Firmware up: op_mode=0x0005, MAC=00:04:4b:a5:0b:cd
[ 14.333353] clm path from default:/lib/firmware/brcm/bcmdhd.clm_blob
[ 14.333382] Skipping the clm download. len:0 memblk: (null)
[ 14.335605] dhd_preinit_ioctls pspretend_threshold for HostAPD failed -23
[ 14.340511] Firmware version = wl0: May 17 2019 16:59:40 version 7.35.349.79 (r714996 CY) FWID 01-e527e2ad
[ 14.342808] dhd_interworking_enable: failed to set WNM info, ret=-23
[ 14.375119] wl_cfg80211_del_station :
[ 14.375124] Disconnect STA : ff:ff:ff:ff:ff:ff scb_val.val 3
[ 14.376040] dhd_ndo_add_ip: ndo ip addr add failed, ret = -23
[ 14.376049] dhd_inet6_work_handler: Adding host ip for NDO failed -23
[ 14.383973] check_dev_role_integrity :
[ 14.383976] device role select failed
[ 14.423438] wl_cfg80211_del_station :
[ 14.423444] Disconnect STA : ff:ff:ff:ff:ff:ff scb_val.val 3
[ 14.441351] check_dev_role_integrity :
[ 14.441358] device role select failed
[ 14.496940] wl_android_wifi_off in
[ 14.498180] dhd_wlfc_deinit():3472, maintain HOST RXRERODER flag in tvl
[ 14.498849] dhdsdio_isr : bus is down. we have nothing to do
[ 14.498932] gpio tegra-gpio-aon wake69 for gpio=59(FF:3)
[ 14.498938] Disabling wake69
[ 14.499078] sdhci-tegra 3440000.sdhci: Tuning done, restoring the best tap value : 61
[ 14.500140] wifi_platform_set_power = 0
[ 14.981132] tegradc 15210000.nvdisplay: blank - powerdown
[ 15.419191] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 15.419805] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 16.048127] Wake76 for irq=199
[ 16.048133] Wake77 for irq=199
[ 16.048136] Wake78 for irq=199
[ 16.048138] Wake79 for irq=199
[ 16.048140] Wake80 for irq=199
[ 16.048143] Wake81 for irq=199
[ 16.048145] Wake82 for irq=199
[ 16.048179] tegra-xusb 3530000.xhci: Upgrade port 0 to USB3.0
[ 16.048184] tegra-xusb 3530000.xhci: Upgrade port 1 to USB3.0
[ 16.149124] usb usb2: usb_suspend_both: status 0
[ 19.847616] fuse init (API version 7.26)
[ 19.942215]
Compiled from
[ 19.942230] wl_android_wifi_on in
[ 19.942240] wifi_platform_set_power = 1
[ 19.954722] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 19.954733] Bluetooth: BNEP socket layer initialized
[ 20.152603] vdd-1v8: voltage operation not allowed
[ 20.157687] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 20.184998] vdd-1v8: voltage operation not allowed
[ 20.189973] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 20.213870] vdd-1v8: voltage operation not allowed
[ 20.218759] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 20.228014] vdd-1v8: voltage operation not allowed
[ 20.232891] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 20.348934] vdd-1v8: voltage operation not allowed
[ 20.354032] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 20.361741] vdd-1v8: voltage operation not allowed
[ 20.366930] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 20.375510] vdd-1v8: voltage operation not allowed
[ 20.380400] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 20.387190] sdhci-tegra 3440000.sdhci: Tuning done, restoring the best tap value : 61
[ 20.388419] F1 signature read @0x18000000=0x17214354
[ 20.395202] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 20.396640] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 20.524288] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
[ 20.566577] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
[ 20.566900] gpio tegra-gpio-aon wake69 for gpio=59(FF:3)
[ 20.566920] gpio tegra-gpio-aon wake69 for gpio=59(FF:3)
[ 20.566922] Enabling wake69
[ 20.567650] wifi_platform_get_mac_addr
[ 20.569367] Firmware up: op_mode=0x0002, MAC=00:04:4b:a5:0b:cd
[ 20.581790] clm path from default:/lib/firmware/brcm/bcmdhd.clm_blob
[ 20.581816] Skipping the clm download. len:0 memblk: (null)
[ 20.597178] dhd_preinit_ioctls pspretend_threshold for HostAPD failed -23
[ 20.603141] Firmware version = wl0: May 17 2019 16:59:40 version 7.35.349.79 (r714996 CY) FWID 01-e527e2ad
[ 20.607038] dhd_interworking_enable: failed to set WNM info, ret=-23
[ 20.650783] wl_cfg80211_del_station :
[ 20.650811] Disconnect STA : ff:ff:ff:ff:ff:ff scb_val.val 3
[ 20.651545] dhd_ndo_add_ip: ndo ip addr add failed, ret = -23
[ 20.651560] dhd_inet6_work_handler: Adding host ip for NDO failed -23
[ 20.696561] wl_cfg80211_set_channel :
[ 20.696569] netdev_ifidx(6), chan_type(1) target channel(10)
[ 20.708381] wl_cfg80211_parse_ies :
[ 20.708385] No WPSIE in beacon
[ 20.708388] wl_cfg80211_parse_ies :
[ 20.708389] No WPSIE in beacon
[ 20.724745] _dhd_wlfc_mac_entry_update():1736, entry(32)
[ 38.362166] usb 2-1: new SuperSpeed USB device number 2 using tegra-xusb
[ 38.385779] usb 2-1: New USB device found, idVendor=152d, idProduct=0567
[ 38.385821] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 38.385840] usb 2-1: Product: USB 3.0 Device
[ 38.385864] usb 2-1: Manufacturer: USB 3.0 Device
[ 38.385878] usb 2-1: SerialNumber: 00000000C1F5
[ 38.402293] scsi host2: uas
[ 38.404315] scsi 2:0:0:0: Direct-Access Samsung SSD 860 PRO 1TB 0117 PQ: 0 ANSI: 6
[ 70.757422] scsi 2:0:0:0: tag#0 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD IN
[ 70.757588] scsi 2:0:0:0: tag#0 CDB: opcode=0x12 12 01 00 00 ff 00
[ 71.765432] scsi host2: uas_eh_bus_reset_handler FAILED to get lock err -16
[ 71.773199] scsi 2:0:0:0: Device offlined - not ready after error recovery
[ 71.777448] sd 2:0:0:0: [sda] Attached SCSI disk
[ 71.780000] sd 2:0:0:0: rejecting I/O to offline device
[ 71.780016] sd 2:0:0:0: rejecting I/O to offline device
[ 71.780021] sd 2:0:0:0: rejecting I/O to offline device
[ 71.781315] tegra-xusb 3530000.xhci: ERROR Transfer event for disabled endpoint or incorrect stream ring
[ 71.781319] tegra-xusb 3530000.xhci: @00000000ffedc5d0 00000000 00000000 04000000 02078001
[ 71.781342] usb 2-1: cmd cmplt err -71
[ 93.033480] scsi 2:0:0:1: tag#0 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD IN
[ 93.033504] scsi 2:0:0:1: tag#0 CDB: opcode=0x12 12 00 00 00 24 00
[ 94.045602] scsi host2: uas_eh_bus_reset_handler FAILED to get lock err -16
[ 94.053311] scsi 2:0:0:1: Device offlined - not ready after error recovery
But if I plug it in and reboot TX2, it will automatically mount and read/write normally.
nvidia@calmcar-pdaq:~$ df -h
Filesystem Size Used Avail Use% Mounted on
/dev/root 14G 12G 1.2G 92% /
devtmpfs 3.9G 0 3.9G 0% /dev
tmpfs 3.9G 4.0K 3.9G 1% /dev/shm
tmpfs 3.9G 21M 3.9G 1% /run
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 3.9G 0 3.9G 0% /sys/fs/cgroup
tmpfs 787M 120K 786M 1% /run/user/1001
/dev/sda1 954G 35G 920G 4% /media/nvidia/C14D581BDA18EBFA
Regards
