I use pcie_aspm=off, exactly.
The complet boot log after a failure.
$ dmesg
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.140-tegra (buildbrain@mobile-u64-911) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Tue Jul 16 17:04:49 PDT 2019
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 7ee00000
[ 0.000000] OF: fdt: - 100000000 , 7f200000
[ 0.000000] Found tegra_fbmem: 00800000@92cb7000
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb0_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node iram-carveout, compatible id nvidia,iram-carveout
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fac00000
[ 0.000000] On node 0 totalpages: 1039872
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 519168 pages, LIFO batch:31
[ 0.000000] Normal zone: 8136 pages used for memmap
[ 0.000000] Normal zone: 520704 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 25 pages/cpu @ffffffc0fefb3000 s61592 r8192 d32616 u102400
[ 0.000000] pcpu-alloc: s61592 r8192 d32616 u102400 alloc=25*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] CPU features: enabling workaround for ARM erratum 832075
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1023544
[ 0.000000] Kernel command line: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,2 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 tegra_fbmem=0x800000@0x92cb7000 is_hdmi_initialised=1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 pci=nomsi pcie_aspm=off quiet
[ 0.000000] PCIe ASPM is disabled
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 98304 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 131072 bytes
[ 0.000000] early log buf free: 29328(89%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Memory: 3562168K/4159488K available (15230K kernel code, 2914K rwdata, 6628K rodata, 8576K init, 609K bss, 122184K reserved, 475136K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f60000 ( 15232 KB)
[ 0.000000] .rodata : 0xffffff8008f60000 - 0xffffff80095e0000 ( 6656 KB)
[ 0.000000] .init : 0xffffff80095e0000 - 0xffffff8009e40000 ( 8576 KB)
[ 0.000000] .data : 0xffffff8009e40000 - 0xffffff800a118808 ( 2915 KB)
[ 0.000000] .bss : 0xffffff800a118808 - 0xffffff800a1b0dbc ( 610 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf03fc8000 ( 63 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc0ff200000 ( 4082 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /interrupt-controller
[ 0.000000] t210 clock and reset probe
[ 0.000000] tegra-pmc: get_secure_pmc_setting: done secure_pmc=1
[ 0.000000] clk_cbus_recalc_rate: no gbus parent
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000006] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.001791] Console: colour dummy device 80x25
[ 0.001812] console [tty0] enabled
[ 0.001828] kmemleak: Kernel memory leak detector disabled
[ 0.001848] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=76800)
[ 0.001862] pid_max: default: 32768 minimum: 301
[ 0.002319] Security Framework initialized
[ 0.002543] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.002553] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.003715] ftrace: allocating 46935 entries in 184 pages
[ 0.177413] sched-energy: CPU device node has no sched-energy-costs
[ 0.177448] ASID allocator initialised with 65536 entries
[ 0.216275] tegra-id: chipid=22117.
[ 0.216289] tegra-id: opt_subrevision=0.
[ 0.216307] Tegra Speedo/IDDQ fuse revision 4
[ 0.216312] Tegra: CPU Speedo ID 9, SoC Speedo ID 0, GPU Speedo ID 2
[ 0.216316] Tegra: CPU Process ID 0, SoC Process ID 1, GPU Process ID 0
[ 0.216324] Tegra: CPU Speedo Value 2072, SoC Speedo Value 1965, GPU Speedo Value 2064
[ 0.216328] Tegra: CPU IDDQ Value 2016, SoC IDDQ Value 2200, GPU IDDQ Value 2645
[ 0.216348] Tegra Revision: A02 SKU: 0x8f CPU Process: 0 SoC Process: 1
[ 0.216364] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-b00.dts
[ 0.216371] DTB Build time: Jul 16 2019 17:09:35
[ 0.265058] CPU1: Booted secondary processor [411fd071]
[ 0.297004] CPU2: Booted secondary processor [411fd071]
[ 0.328971] CPU3: Booted secondary processor [411fd071]
[ 0.329064] Brought up 4 CPUs
[ 0.329069] SMP: Total of 4 processors activated.
[ 0.329077] CPU features: detected feature: 32-bit EL0 Support
[ 0.329341] CPU: All CPU(s) started at EL2
[ 0.329359] alternatives: patching kernel code
[ 0.337732] devtmpfs: initialized
[ 0.376046] Initilizing CustomIPI irq domain
[ 0.376442] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.376465] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.388014] pinctrl core: initialized pinctrl subsystem
[ 0.388716] OS set in device tree is not L4T.
[ 0.389166] regulator-dummy: no parameters
[ 0.389452] Initializing plugin-manager
[ 0.389574] Plugin module not found
[ 0.389802] node /plugin-manager/fragement@0 match with board >=3448-0000-100
[ 0.390384] node /plugin-manager/fragment@1 match with board >=3448-0000-101
[ 0.391226] node /plugin-manager/fragment@5 match with board 3449-0000-200
[ 0.391640] node /plugin-manager/fragement@6 match with odm-data enable-tegra-wdt
[ 0.392047] node /plugin-manager/fragement@8 match with odm-data enable-tegra-wdt
[ 0.392443] node /plugin-manager/fragement@9 match with board <3448-0000-300
[ 0.397119] NET: Registered protocol family 16
[ 0.398593] pstore: using zlib compression
[ 0.398627] console [pstore-1] enabled
[ 0.398632] pstore: Registered ramoops as persistent store backend
[ 0.398637] ramoops: attached 0x200000@0xb0000000, ecc: 0/0
[ 0.413074] cpuidle: using governor menu
[ 0.417487] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[ 0.419242] vdso: 2 pages (1 code @ ffffff8008f67000, 1 data @ ffffff8009e44000)
[ 0.419264] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.421678] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.424292] tegra_powergate_init: DONE
[ 0.424307] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-b00.dts
[ 0.424315] DTB Build time: Jul 16 2019 17:09:35
[ 0.426131] Tegra reboot handler registered.
[ 0.430691] iommu: Adding device tegra-carveouts to group 0
[ 0.430831] platform tegra-carveouts: domain=ffffffc0f9ba23d8 allocates as[0]=ffffffc0f940c0a8
[ 0.431200] iommu: Adding device smmu_test to group 1
[ 0.431242] platform smmu_test: domain=ffffffc0f9ba2618 allocates as[0]=ffffffc0f940c110
[ 0.432079] mc: mapped MMIO address: 0xffffff800802e000 -> 0x70019000
[ 0.432140] mc: mapped MMIO address: 0xffffff8008065000 -> 0x7001c000
[ 0.432197] mc: mapped MMIO address: 0xffffff8008079000 -> 0x7001d000
[ 0.432208] nv-tegra-mc 70019000.mc: No mssnvlink node
[ 0.432231] mc-err: mcerr ops are set to t21x
[ 0.441924] iommu: Adding device 70090000.xusb to group 2
[ 0.442243] iommu: Adding device 70006000.serial to group 3
[ 0.442306] platform 70006000.serial: domain=ffffffc0f941acd8 allocates as[0]=ffffffc0f940c178
[ 0.442741] iommu: Adding device 70006040.serial to group 4
[ 0.442996] iommu: Adding device 70006200.serial to group 5
[ 0.443182] iommu: Adding device sound to group 6
[ 0.443237] platform sound: domain=ffffffc0f94a8258 allocates as[0]=ffffffc0f940c1e0
[ 0.443813] iommu: Adding device 7000d400.spi to group 7
[ 0.444075] iommu: Adding device 7000d600.spi to group 8
[ 0.444381] iommu: Adding device 70410000.spi to group 9
[ 0.444691] iommu: Adding device 50000000.host1x to group 10
[ 0.444970] iommu: Adding device 54080000.vi to group 11
[ 0.445402] iommu: Adding device 54600000.isp to group 12
[ 0.445662] iommu: Adding device 54680000.isp to group 13
[ 0.445936] iommu: Adding device tegradc.0 to group 14
[ 0.445988] platform tegradc.0: domain=ffffffc0f94b4198 allocates as[0]=ffffffc0f940c248
[ 0.450165] platform tegradc.0: IOVA linear map 0x0000000092cb7000(800000)
[ 0.450556] platform tegradc.0: IOVA linear map 0x00000000d7000000(19000000)
[ 0.450915] iommu: Adding device tegradc.1 to group 15
[ 0.450965] platform tegradc.1: domain=ffffffc0f94b43d8 allocates as[0]=ffffffc0f940c2b0
[ 0.455111] platform tegradc.1: IOVA linear map 0x0000000092cb7000(800000)
[ 0.455502] platform tegradc.1: IOVA linear map 0x00000000d7000000(19000000)
[ 0.455784] iommu: Adding device 54340000.vic to group 16
[ 0.455988] iommu: Adding device 544c0000.nvenc to group 17
[ 0.456188] iommu: Adding device 54500000.tsec to group 18
[ 0.456382] iommu: Adding device 54100000.tsecb to group 19
[ 0.456589] iommu: Adding device 54480000.nvdec to group 20
[ 0.456781] iommu: Adding device 54380000.nvjpg to group 21
[ 0.457847] iommu: Adding device 546c0000.i2c to group 22
[ 0.458179] iommu: Adding device 57000000.gpu to group 23
[ 0.458230] platform 57000000.gpu: domain=ffffffc0f94c33d8 allocates as[0]=ffffffc0f940c318
[ 0.458288] platform 57000000.gpu: domain=ffffffc0f94c33d8 allocates as[1]=ffffffc0f940c380
[ 0.458328] platform 57000000.gpu: domain=ffffffc0f94c33d8 allocates as[2]=ffffffc0f940c3e8
[ 0.458360] platform 57000000.gpu: domain=ffffffc0f94c33d8 allocates as[3]=ffffffc0f940c450
[ 0.459244] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency thermal reset disabled.
[ 0.459256] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
[ 0.459268] tegra-pmc: ### PMC reset source: TEGRA_SOFTWARE_RESET
[ 0.459272] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_WARM
[ 0.459277] tegra-pmc: ### PMC reset status reg: 0x3
[ 0.509258] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.509267] tegra-pmc: Clear bootloader IO dpd settings
[ 0.509286] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
[ 0.509350] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset commands
[ 0.509633] iommu: Adding device 70012000.se to group 24
[ 0.510404] iommu: Adding device 7000c000.i2c to group 25
[ 0.510659] iommu: Adding device 7000c400.i2c to group 26
[ 0.510907] iommu: Adding device 7000c500.i2c to group 27
[ 0.511161] iommu: Adding device 7000c700.i2c to group 28
[ 0.511430] iommu: Adding device 7000d000.i2c to group 29
[ 0.511676] iommu: Adding device 7000d100.i2c to group 30
[ 0.511980] iommu: Adding device sdhci-tegra.0 to group 31
[ 0.512044] platform sdhci-tegra.0: domain=ffffffc0f955b558 allocates as[0]=ffffffc0f940c4b8
[ 0.512898] iommu: Adding device 700d0000.xudc to group 32
[ 0.516321] vdd-ac-bat: 5000 mV
[ 0.516681] vdd-5v0-sys: 5000 mV
[ 0.517644] vdd-5v0-hdmi: supplied by vdd-5v0-sys
[ 0.517688] vdd-5v0-hdmi: 5000 mV
[ 0.518100] vdd-1v8-sys: 1800 mV
[ 0.518531] vdd-fan: supplied by vdd-5v0-sys
[ 0.518571] vdd-fan: 5000 mV
[ 0.518948] vdd-usb-vbus: supplied by vdd-5v0-sys
[ 0.518986] vdd-usb-vbus: 5000 mV
[ 0.519509] vdd-usb-vbus2: 5000 mV
[ 0.549870] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.552349] gpio gpiochip0: gpio-line-names specifies 240 line names but there are 256 lines on the chip
[ 0.553750] GPIO line 151 (camera-control-output-low) hogged as output/low
[ 0.553771] GPIO line 152 (camera-control-output-low) hogged as output/low
[ 0.554142] gpiochip_setup_dev: registered GPIOs 0 to 255 on device: gpiochip0 (tegra-gpio)
[ 0.562252] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.562604] SCSI subsystem initialized
[ 0.562836] libata version 3.00 loaded.
[ 0.563116] usbcore: registered new interface driver usbfs
[ 0.563169] usbcore: registered new interface driver hub
[ 0.563245] usbcore: registered new device driver usb
[ 0.566961] max77620 4-003c: PMIC Version OTP:0x35 and ES:0x8
[ 0.572331] vdd-core: 600 <--> 1162 mV at 1075 mV
[ 0.572946] random: fast init done
[ 0.573186] vdd-ddr-1v1: Bringing 1125000uV into 1150000-1150000uV
[ 0.577022] vdd-ddr-1v1: 1150 mV
[ 0.581021] vdd-pre-reg-1v35: 1350 mV
[ 0.585030] vdd-1v8: 1800 mV
[ 0.589022] avdd-sys-1v2: 1200 mV
[ 0.593021] vdd-pex-1v0: 1050 mV
[ 0.593575] vddio-sdmmc-ap: 1800 <--> 3300 mV at 3300 mV
[ 0.594064] max77620-ldo3: at 3100 mV
[ 0.597022] vdd-rtc: 850 <--> 1100 mV at 1000 mV
[ 0.597544] max77620-ldo5: at 3100 mV
[ 0.598028] max77620-ldo6: at 2800 mV
[ 0.601021] avdd-1v05-pll: 1050 mV
[ 0.605024] avdd-io-hdmi-dp: 1050 mV
[ 0.606069] GPIO line 505 (spmic-default-output-high) hogged as output/high
[ 0.606342] gpiochip_setup_dev: registered GPIOs 504 to 511 on device: gpiochip1 (max77620-gpio)
[ 0.607679] max77620 4-003c: max77620 probe successful
[ 0.610462] media: Linux media interface: v0.10
[ 0.610524] Linux video capture interface: v2.00
[ 0.611530] pps_core: LinuxPPS API ver. 1 registered
[ 0.611536] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.611565] PTP clock support registered
[ 0.615459] tegra_fiq_debugger_init: found FIQ source (IRQ 98)
[ 0.621874] tegra210-emc 7001b000.external-memory-controller: validated EMC DFS table
[ 0.622783] Advanced Linux Sound Architecture Driver Initialized.
[ 0.623446] Bluetooth: Core ver 2.22
[ 0.623494] NET: Registered protocol family 31
[ 0.623497] Bluetooth: HCI device and connection manager initialized
[ 0.623513] Bluetooth: HCI socket layer initialized
[ 0.623522] Bluetooth: L2CAP socket layer initialized
[ 0.623547] Bluetooth: SCO socket layer initialized
[ 0.625304] tegra210_dvfs: no clock found for sdmmc2_ddr
[ 0.625321] tegra210_dvfs: no clock found for sdmmc4_ddr
[ 0.625366] tegra210_dvfs: no clock found for sdmmc1_ddr
[ 0.625379] tegra210_dvfs: no clock found for sdmmc3_ddr
[ 0.628669] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering probe
[ 0.629819] vdd-3v3-sys: supplied by vdd-5v0-sys
[ 0.629888] vdd-3v3-sys: 3300 mV
[ 0.630147] vdd-1v8-sys: supplied by vdd-3v3-sys
[ 0.633098] vdd-usb-vbus2: supplied by vdd-3v3-sys
[ 0.633565] vdd-3v3-sd: supplied by vdd-3v3-sys
[ 0.633602] vdd-3v3-sd: 3300 mV
[ 0.634346] avdd-io-edp-1v05: supplied by avdd-1v05-pll
[ 0.634388] avdd-io-edp-1v05: 1050 mV
[ 0.634868] vdd-usb-hub-en: supplied by vdd-1v8-sys
[ 0.634901] vdd-usb-hub-en: 5000 mV
[ 0.636303] camchar: rtcpu character device driver loaded
[ 0.637122] extcon-gpio-states extcon:extcon@1: Cable state:0, cable id:0
[ 0.638558] clocksource: Switched to clocksource arch_sys_counter
[ 0.679755] VFS: Disk quotas dquot_6.6.0
[ 0.679882] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.680386] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.680828] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000d7000000, size=0x19000000
[ 0.680845] dma-vpr: heap size is not multiple of cma_chunk_size heap_info->num_chunks (13) rem_chunk_size(0x1000000)
[ 0.681056] cma: enabled page replacement for spfn=d7000, epfn=f0000
[ 0.681062] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[ 0.681073] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 0.681097] tegra-carveouts tegra-carveouts: iram :dma coherent mem declare 0x0000000040001000,258048
[ 0.681103] tegra-carveouts tegra-carveouts: assigned reserved memory node iram-carveout
[ 0.681114] nvmap: nvmap_select_cache_ops() nvmap cache ops set to set/ways
[ 0.681123] nvmap_page_pool_init: Total RAM pages: 1009326
[ 0.681128] nvmap_page_pool_init: nvmap page pool size: 126165 pages (492 MB)
[ 0.681216] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.681687] misc nvmap: created heap iram base 0x0000000040001000 size (252KiB)
[ 0.682810] misc nvmap: created heap vpr base 0x00000000d7000000 size (409600KiB)
[ 0.691302] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[ 0.691730] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[ 0.691979] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.692187] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.692378] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 0.692663] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[ 0.692666] pre_t19x_iso_plat_init(): max_iso_bw=33280000KB
[ 0.693118] NET: Registered protocol family 2
[ 0.694205] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.694416] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.695004] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.695173] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.695257] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.695690] NET: Registered protocol family 1
[ 0.696471] RPC: Registered named UNIX socket transport module.
[ 0.696476] RPC: Registered udp transport module.
[ 0.696480] RPC: Registered tcp transport module.
[ 0.696485] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.696498] PCI: CLS 0 bytes, default 64
[ 0.696716] Trying to unpack rootfs image as initramfs...
[ 0.932731] Freeing initrd memory: 5432K
[ 0.942934] host1x 50000000.host1x: initialized
[ 0.944894] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.948299] audit: initializing netlink subsys (disabled)
[ 0.948390] audit: type=2000 audit(0.795:1): initialized
[ 0.949121] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 0.959327] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.960809] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.961611] 9p: Installing v9fs 9p2000 file system support
[ 0.964962] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 0.965108] io scheduler noop registered
[ 0.965396] io scheduler cfq registered (default)
[ 0.968163] gic 702f9000.agic: GIC IRQ controller registered
[ 0.971140] iommu: Adding device 702ef000.adsp to group 33
[ 0.977218] iommu: Adding device aconnect@702c0000:adsp_audio to group 34
[ 0.977362] tegra-aconnect aconnect@702c0000: Tegra ACONNECT bus registered
[ 0.977965] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_SKU_CALIB_0 = 0x59e640e
[ 0.977973] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_USB_CALIB_EXT_0 = 0x4
[ 0.980085] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.0, lane = usb2-0, function = xusb
[ 0.980184] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.1, lane = usb2-1, function = xusb
[ 0.980279] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane = usb2-2, function = xusb
[ 0.980461] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane = pcie-0, function = pcie-x1
[ 0.980572] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane = pcie-1, function = pcie-x4
[ 0.980659] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane = pcie-2, function = pcie-x4
[ 0.980751] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane = pcie-3, function = pcie-x4
[ 0.980839] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane = pcie-4, function = pcie-x4
[ 0.980935] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane = pcie-5, function = xusb
[ 0.981023] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane = pcie-6, function = xusb
[ 0.986360] tegra-pwm 7000a000.pwm: PWM clk cannot sleep in ops
[ 0.988208] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[ 0.990106] tegra-pcie 1003000.pcie: 4x1, 1x1 configuration
[ 0.991453] tegra-pcie 1003000.pcie: PCIE: Enable power rails
[ 0.991817] tegra-pcie 1003000.pcie: probing port 0, using 4 lanes
[ 0.993021] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.993261] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=750000, max_bw=1500000
[ 0.993505] Adding domain tsec-pd to PM domain host1x-pd
[ 0.995946] tegra-pcie 1003000.pcie: probing port 1, using 1 lanes
[ 0.996865] tsec 54500000.tsec: initialized
[ 0.998490] tsec 54100000.tsecb: initialized
[ 0.999207] Adding domain nvdec-pd to PM domain host1x-pd
[ 1.002836] nvdec 54480000.nvdec: initialized
[ 1.003950] Adding domain vic03-pd to PM domain host1x-pd
[ 1.004136] Adding domain msenc-pd to PM domain host1x-pd
[ 1.004305] Adding domain nvjpg-pd to PM domain host1x-pd
[ 1.008679] falcon 54340000.vic: initialized
[ 1.009952] falcon 544c0000.nvenc: initialized
[ 1.011376] falcon 54380000.nvjpg: initialized
[ 1.016095] tegradc tegradc.0: disp0 connected to head0->/host1x/sor1
[ 1.016229] display board info: id 0x0, fab 0x0
[ 1.016295] generic_infoframe_type: 0x87
[ 1.016435] tegradc tegradc.0: DT parsed successfully
[ 1.016477] tegradc tegradc.0: Display dc.ffffff800ab40000 registered with id=0
[ 1.017004] tegradc tegradc.0: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350781
[ 1.020254] tegradc tegradc.0: probed
[ 1.024861] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
[ 1.029289] tegra-adma 702e2000.adma: Tegra210 ADMA driver registered 10 channels
[ 1.030117] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initialized
[ 1.030448] kfuse 7000fc00.kfuse: initialized
[ 1.032056] tegra-pmc-iopower pmc-iopower: Regulator supply iopower-dbg-supply not available
[ 1.033164] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 1.034691] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[ 1.034710] vdd-cpu: 708 <--> 1322 mV at 708 mV
[ 1.035210] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator registration passed
[ 1.036554] vdd-gpu: applied init 1000000uV constraint
[ 1.036562] vdd-gpu: 708 <--> 1323 mV at 997 mV
[ 1.036955] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator registration passed
[ 1.040570] tegra-pcie 1003000.pcie: PCI host bridge to bus 0000:00
[ 1.040579] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 1.040585] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
[ 1.040591] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pref]
[ 1.040596] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.040624] pci 0000:00:01.0: [10de:0fae] type 01 class 0x060400
[ 1.040693] pci 0000:00:01.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 1.040875] pci 0000:00:02.0: [10de:0faf] type 01 class 0x060400
[ 1.040934] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 1.041096] pci 0000:00:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 1.041105] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 1.041246] pci 0000:01:00.0: [144d:a808] type 00 class 0x010802
[ 1.041288] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[ 1.041638] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 1.041754] pci 0000:02:00.0: [10ec:8168] type 00 class 0x020000
[ 1.041776] pci 0000:02:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 1.041803] pci 0000:02:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[ 1.041821] pci 0000:02:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[ 1.041936] pci 0000:02:00.0: supports D1 D2
[ 1.041940] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 1.042117] pci_bus 0000:02: busn_res: [bus 02-ff] end is updated to 02
[ 1.042158] pci 0000:00:01.0: BAR 14: assigned [mem 0x13000000-0x130fffff]
[ 1.042164] pci 0000:00:02.0: BAR 14: assigned [mem 0x13100000-0x131fffff]
[ 1.042170] pci 0000:00:02.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 1.042179] pci 0000:01:00.0: BAR 0: assigned [mem 0x13000000-0x13003fff 64bit]
[ 1.042195] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 1.042202] pci 0000:00:01.0: bridge window [mem 0x13000000-0x130fffff]
[ 1.042213] pci 0000:02:00.0: BAR 4: assigned [mem 0x13100000-0x13103fff 64bit]
[ 1.042230] pci 0000:02:00.0: BAR 2: assigned [mem 0x13104000-0x13104fff 64bit]
[ 1.042246] pci 0000:02:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 1.042254] pci 0000:00:02.0: PCI bridge to [bus 02]
[ 1.042259] pci 0000:00:02.0: bridge window [io 0x1000-0x1fff]
[ 1.042266] pci 0000:00:02.0: bridge window [mem 0x13100000-0x131fffff]
[ 1.042273] PCIE: ASPM not enabled
[ 1.042456] pcieport 0000:00:01.0: Signaling PME through PCIe PME interrupt
[ 1.042461] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 1.042467] pcie_pme 0000:00:01.0:pcie001: service driver pcie_pme loaded
[ 1.042690] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
[ 1.042694] pci 0000:02:00.0: Signaling PME through PCIe PME interrupt
[ 1.042701] pcie_pme 0000:00:02.0:pcie001: service driver pcie_pme loaded
[ 1.044687] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.044754] No Device Node present for smmu client: serial8250 !!
[ 1.044761] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 1.044790] iommu: Adding device serial8250 to group 35
[ 1.046338] console [ttyS0] disabled
[ 1.046617] Console: switching to colour frame buffer device 240x67
[ 1.046735] tegradc tegradc.0: fb registered
[ 1.046764] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 63, base_baud = 25500000) is a Tegra
[ 1.046799] console [ttyS0] enabled
[ 1.047680] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 64, base_baud = 0) is a TEGRA_UART
[ 1.047917] serial-tegra 70006200.serial: RX in PIO mode
[ 1.048009] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 65, base_baud = 0) is a TEGRA_UART
[ 1.048909] [drm] Initialized
[ 1.054741] tegradc tegradc.0: DC initialized, skipping tegra_dc_program_mode.
[ 1.054769] tegradc tegradc.0: hdmi: tmds rate:148351K prod-setting:prod_c_hdmi_75m_150m
[ 1.055121] tegradc tegradc.0: hdmi: get RGB quant from REG programmed by BL.
[ 1.055130] tegradc tegradc.0: hdmi: get YCC quant from REG programmed by BL.
[ 1.057012] brd: module loaded
[ 1.061056] loop: module loaded
[ 1.061127] tegra_profiler: version: 1.134, samples/io: 47/26
[ 1.061219] tegra_profiler: auth: init
[ 1.061783] THERMAL EST: found 2 subdevs
[ 1.061788] THERMAL EST num_resources: 0
[ 1.061793] [THERMAL EST subdev 0]
[ 1.061798] [THERMAL EST subdev 1]
[ 1.062128] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[ 1.062131] THERMAL EST: thz register success.
[ 1.062230] THERMAL EST: end of probe, return err: 0
[ 1.063023] hisi_sas: driver version v1.6
[ 1.063669] nvme nvme0: pci function 0000:01:00.0
[ 1.063714] nvme 0000:01:00.0: enabling device (0000 -> 0002)
[ 1.066202] tegra-qspi 70410000.spi: Prod settings list not found
[ 1.067101] qspi_mtd spi32766.0: MX25U3235F (4096 Kbytes)
[ 1.067109] qspi_mtd spi32766.0: mtd .name = spi32766.0, .size = 0x400000 (4MiB) .erasesize = 0x00001000 (4KiB) .numeraseregions = 0
[ 1.069224] libphy: Fixed MDIO Bus: probed
[ 1.069840] tun: Universal TUN/TAP device driver, 1.6
[ 1.069843] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.070486] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 1.070489] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.070534] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 1.070536] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 1.070605] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 1.070608] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 1.070652] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 1.070655] Copyright(c) 1999 - 2017 Intel Corporation.
[ 1.071206] r8168 0000:02:00.0: enabling device (0000 -> 0003)
[ 1.071224] r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded
[ 1.071283] r8168 0000:02:00.0: no MSI. Back to INTx.
[ 1.080702] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 1.080706] Extcon AUX1(HDMI) enable
[ 1.081276] tegradc tegradc.1: disp1 connected to head1->/host1x/sor
[ 1.081330] tegradc tegradc.1: No lt-data, using default setting
[ 1.081349] tegradc tegradc.1: No hpd-gpio in DT
[ 1.081376] tegradc tegradc.1: DT parsed successfully
[ 1.081408] tegradc tegradc.1: Display dc.ffffff800d4c0000 registered with id=1
[ 1.082275] tegradc tegradc.1: dpd enable lookup fail:-19
[ 1.085426] r8168 0000:02:00.0 (unnamed net_device) (uninitialized): Invalid ethernet address 00:00:00:00:00:00, trying device tree node
[ 1.085498] r8168 0000:02:00.0 (unnamed net_device) (uninitialized): Found valid ethernet address 00:04:4b:e6:b6:cd from device tree
[ 1.085928] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[ 1.085961] r8168 Copyright (C) 2017 Realtek NIC software team <nicfae@realtek.com>
This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
[ 1.086397] PPP generic driver version 2.4.2
[ 1.091336] PPP BSD Compression module registered
[ 1.091339] PPP Deflate Compression module registered
[ 1.091355] PPP MPPE Compression module registered
[ 1.091359] NET: Registered protocol family 24
[ 1.091406] usbcore: registered new interface driver r8152
[ 1.091446] usbcore: registered new interface driver asix
[ 1.091485] usbcore: registered new interface driver ax88179_178a
[ 1.091514] usbcore: registered new interface driver cdc_ether
[ 1.091545] usbcore: registered new interface driver net1080
[ 1.091574] usbcore: registered new interface driver cdc_subset
[ 1.091602] usbcore: registered new interface driver zaurus
[ 1.091645] usbcore: registered new interface driver cdc_ncm
[ 1.091816] tegradc tegradc.1: probed
[ 1.108851] tegradc tegradc.0: nominal-pclk:148351648 parent:148350781 div:1.0 pclk:148350781 146868084~161703244
[ 1.110668] tegradc tegradc.1: fb registered
[ 1.110672] VFIO - User Level meta-driver version: 0.3
[ 1.112242] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.112255] ehci-pci: EHCI PCI platform driver
[ 1.112304] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.112314] ohci-pci: OHCI PCI platform driver
[ 1.112357] ohci-platform: OHCI generic platform driver
[ 1.113838] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 1.113843] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 1.113851] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 1.113861] tegradc tegradc.1: blank - powerdown
[ 1.113874] extcon-disp-state extcon:disp-state: cable 44 state 0 already set.
[ 1.113877] Extcon DP: HPD disabled
[ 1.113880] hpd: hpd_switch 0
[ 1.113884] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 1.113906] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 1.113913] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 1.114448] tegra-xusb 70090000.xusb: USB2 port 0 has OTG_CAP
[ 1.115005] tegra-xusb-padctl 7009f000.xusb_padctl: enabled OTG on UTMI pad 0
[ 1.116044] tegra-xusb 70090000.xusb: extcon 0: ffffffc0f9140000 id
[ 1.117536] usbcore: registered new interface driver uas
[ 1.117635] usbcore: registered new interface driver usb-storage
[ 1.117717] usbcore: registered new interface driver usbserial
[ 1.118476] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-05-08 09:42:10 UTC, Version: 50.22 release
[ 1.118511] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 1.118528] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 1
[ 1.119403] tegra-xusb 70090000.xusb: hcc params 0x0184f525 hci version 0x100 quirks 0x00050010
[ 1.119440] tegra-xusb 70090000.xusb: irq 61, io mem 0x70090000
[ 1.119587] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.119594] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.119599] usb usb1: Product: xHCI Host Controller
[ 1.119603] usb usb1: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 1.119608] usb usb1: SerialNumber: 70090000.xusb
[ 1.120028] hub 1-0:1.0: USB hub found
[ 1.120065] hub 1-0:1.0: 5 ports detected
[ 1.120551] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 1.120560] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 2
[ 1.120631] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.120721] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.120727] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.120732] usb usb2: Product: xHCI Host Controller
[ 1.120736] usb usb2: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 1.120740] usb usb2: SerialNumber: 70090000.xusb
[ 1.121096] hub 2-0:1.0: USB hub found
[ 1.121129] hub 2-0:1.0: 4 ports detected
[ 1.123206] tegra-xudc-new 700d0000.xudc: device count: 1
[ 1.124116] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[ 1.124125] tegra-xudc-new 700d0000.xudc: vbus state: 0
[ 1.124147] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 1.124369] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 1.124815] mousedev: PS/2 mouse device common for all mice
[ 1.124874] usbcore: registered new interface driver xpad
[ 1.213973] tegradc tegradc.0: blank - powerdown
[ 1.231923] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 1.247421] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 1.248607] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 1.248610] Extcon AUX1(HDMI) disable
[ 1.249716] rtc rtc1: alarm rtc device
[ 1.249729] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc1
[ 1.249746] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[ 1.250111] i2c /dev entries driver
[ 1.251766] imx219 6-0010: tegracam sensor driver:imx219_v2.0.6
[ 1.275029] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[ 1.275088] imx219 6-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.275115] imx219 6-0010: board setup failed
[ 1.275178] imx219: probe of 6-0010 failed with error -121
[ 1.275985] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 1.277902] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[ 1.277907] tegra_soctherm 700e2000.soctherm: pllx_offset tz:2 max:8, min:4
[ 1.278197] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.278210] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[ 1.278216] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
[ 1.278336] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.278344] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[ 1.278350] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
[ 1.278483] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.278491] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[ 1.278495] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
[ 1.278687] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[ 1.279246] tegra_aotag tegra-aotag: Registering sensor 0
[ 1.279289] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.279309] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.279324] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[ 1.279332] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[ 1.280079] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.280093] tegra_dfll_action dfll-cdev-cap: Tegra DFLL 'cap cooling device' registered
[ 1.280231] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.280253] tegra_dfll_action dfll-cdev-floor: Tegra DFLL 'floor cooling device' registered
[ 1.280591] parse_throttle_dt_data: Num cap clks = 6
[ 1.280595] parse_throttle_dt_data: clk=cclk_g type=2
[ 1.280602] parse_throttle_dt_data: clk=gpu type=4
[ 1.280619] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[ 1.280638] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[ 1.280657] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[ 1.280660] parse_throttle_dt_data: clk=emc type=3
[ 1.281042] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.281131] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.281239] tegra_throttle_probe: probe successful. #cdevs=4
[ 1.281823] FAN dev name: pwm-fan
[ 1.281853] FAN:gpio request success.
[ 1.281899] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 1.282132] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 1.282246] pwm_fan_driver pwm-fan: fan tach request irq success
[ 1.282252] pwm_fan_driver pwm-fan: tach period: 1000
[ 1.282320] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 1.282324] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 1.282328] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 1.282332] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 1.282336] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 1.282340] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 1.282344] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 1.282348] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 1.282352] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 1.282356] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 1.282848] tegra-wdt 60005100.watchdog: Tegra WDT enabled on probe. Timeout = 120 seconds.
[ 1.283082] tegra-wdt 60005100.watchdog: initialized (timeout = 120 sec, nowayout = 1)
[ 1.283773] device-mapper: uevent: version 1.0.3
[ 1.284242] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 1.286946] tegra210-cpufreq cpufreq: probe()...completed
[ 1.287668] sdhci: Secure Digital Host Controller Interface driver
[ 1.287669] sdhci: Copyright(c) Pierre Ossman
[ 1.287671] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.288156] sdhci-tegra sdhci-tegra.0: Got CD GPIO
[ 1.288515] sdhci-tegra sdhci-tegra.0: Client registration for eMC Successful
[ 1.288637] sdhci-tegra sdhci-tegra.0: wakeup init done, cdirq 300
[ 1.291422] tegradc tegradc.0: unblank
[ 1.292903] tegra-se 70012000.se: tegra_se_probe: complete
[ 1.293552] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.294869] usbcore: registered new interface driver usbhid
[ 1.294870] usbhid: USB HID core driver
[ 1.297244] tegra21x_actmon 6000c800.actmon: in actmon_register()...
[ 1.297571] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
[ 1.299666] nvpmodel: initialized successfully
[ 1.300782] usbcore: registered new interface driver snd-usb-audio
[ 1.300846] No Device Node present for smmu client: snd-soc-dummy !!
[ 1.300851] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 1.300868] iommu: Adding device snd-soc-dummy to group 36
[ 1.312507] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/card0/input0
[ 1.319615] OPE platform probe
[ 1.319702] OPE platform probe successful
[ 1.320062] OPE platform probe
[ 1.320148] OPE platform probe successful
[ 1.330324] tegradc tegradc.0: nominal-pclk:154000000 parent:153999375 div:1.0 pclk:153999375 152460000~167860000
[ 1.330382] tegradc tegradc.0: hdmi: tmds rate:154000K prod-setting:prod_c_hdmi_150m_300m
[ 1.331354] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 1.331361] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 1.334692] mmc0: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADMA 64-bit with 64 bit addr
[ 1.346383] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 1.346503] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 1.346646] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 1.346770] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 1.346885] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 1.347005] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 1.347138] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 1.347255] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 1.347371] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 1.347483] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 1.359876] u32 classifier
[ 1.359877] Actions configured
[ 1.359946] Initializing XFRM netlink socket
[ 1.360693] NET: Registered protocol family 10
[ 1.361490] NET: Registered protocol family 17
[ 1.361503] NET: Registered protocol family 15
[ 1.361579] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 1.361685] Bluetooth: RFCOMM socket layer initialized
[ 1.361695] Bluetooth: RFCOMM ver 1.11
[ 1.361699] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.361703] Bluetooth: HIDP socket layer initialized
[ 1.361720] 9pnet: Installing 9P2000 support
[ 1.361755] Key type dns_resolver registered
[ 1.362205] Registered cp15_barrier emulation handler
[ 1.362211] Registered setend emulation handler
[ 1.366020] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 1.366023] Extcon AUX1(HDMI) enable
[ 1.366387] tegradc tegradc.0: sync windows ret = 250
[ 1.367299] registered taskstats version 1
[ 1.367912] Adding domain ve2-pd to PM domain host1x-pd
[ 1.368155] Adding domain ve-pd to PM domain host1x-pd
[ 1.370271] isp 54600000.isp: initialized
[ 1.371239] isp 54680000.isp: initialized
[ 1.381591] last reset is due to software reset
[ 1.381594] KERNEL: PMC reset status reg: 0x3
[ 1.381671] BL: PMC reset status reg: 0x3
[ 1.381672] BL: PMIC poweroff Event Recorder: 0x0
[ 1.383401] clk_cbus_recalc_rate: no gbus parent
[ 1.383405] clk_cbus_round_rate: no gbus parent
[ 1.383407] clk_cbus_round_rate: no gbus parent
[ 1.383415] clk_cbus_recalc_rate: no gbus parent
[ 1.383520] clk_cbus_recalc_rate: no gbus parent
[ 1.383523] clk_cbus_round_rate: no gbus parent
[ 1.383524] clk_cbus_round_rate: no gbus parent
[ 1.383528] clk_cbus_recalc_rate: no gbus parent
[ 1.384219] tegra_dvfs: GPU-cap: registered
[ 1.384274] tegra dvfs: vdd-cpu: nominal 1168mV, offset 708000uV, step 19200uV, scaling enabled
[ 1.384276] tegra dvfs: vdd-core: nominal 1075mV, offset 600000uV, step 12500uV, scaling enabled
[ 1.384278] tegra dvfs: vdd-gpu: nominal 1058mV, offset 708000uV, step 10000uV, scaling enabled
[ 1.385636] tegra_dvfs: vdd-gpu-vts: registered
[ 1.386330] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS 'floor cooling device' registered
[ 1.386958] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS 'cap cooling device' registered
[ 1.387462] input: gpio-keys as /devices/gpio-keys/input/input1
[ 1.387464] extcon-disp-state extcon:disp-state: cable 40 state 1
[ 1.387466] Extcon HDMI: HPD enabled
[ 1.387482] tegradc tegradc.0: hdmi: plugged
[ 1.419749] tegra_rtc 7000e000.rtc: setting system clock to 2019-11-25 07:34:27 UTC (1574667267)
[ 1.420782] vi 54080000.vi: vi_probe: ++
[ 1.423444] vi 54080000.vi: initialized
[ 1.425417] vi 54080000.vi: subdev nvcsi--1 bound
[ 1.427010] Disable partitions left on by BL
[ 1.427015] disb
[ 1.427062] bwmgr: missing cdev-type property
[ 1.427168] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.427175] DRAM derating cdev registered.
[ 1.428210] vdd-fan: disabling
[ 1.428213] vdd-usb-vbus: disabling
[ 1.428216] vdd-usb-vbus2: disabling
[ 1.428226] avdd-io-edp-1v05: disabling
[ 1.428321] ALSA device list:
[ 1.428324] #0: tegra-hda at 0x70038000 irq 83
[ 1.428326] #1: tegra-snd-t210ref-mobile-rt565x
[ 1.431470] Freeing unused kernel memory: 8576K
[ 1.450219] L4T-INITRD Build DATE: Mon Nov 25 07:34:27 UTC 2019
[ 1.454624] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 1.454675] Root device found: mmcblk0p1
[ 1.490567] usb 1-2: New USB device found, idVendor=0bda, idProduct=5411
[ 1.490572] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.490576] usb 1-2: Product: 4-Port USB 2.1 Hub
[ 1.490579] usb 1-2: Manufacturer: Generic
[ 1.492118] hub 1-2:1.0: USB hub found
[ 1.493158] hub 1-2:1.0: 4 ports detected
[ 1.537632] mmc0: hw tuning done ...
[ 1.537664] mmc0: new ultra high speed SDR104 SDHC card at address aaaa
[ 1.538088] mmcblk0: mmc0:aaaa SP32G 29.7 GiB
[ 1.541907] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12
[ 1.618628] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 1.638624] usb 1-2: usb_suspend_both: status 0
[ 1.638698] usb usb1: usb_suspend_both: status 0
[ 1.659545] Found dev node: /dev/mmcblk0p1
[ 1.691296] EXT4-fs (mmcblk0p1): warning: mounting fs with errors, running e2fsck is recommended
[ 1.693001] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 1.693759] Rootfs mounted over mmcblk0p1
[ 1.715647] Switching from initrd to actual rootfs
[ 1.948164] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.960460] cgroup: cgroup2: unknown option "nsdelegate"
[ 1.985924] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 1.986713] systemd[1]: Detected architecture arm64.
[ 2.014296] systemd[1]: Set hostname to <bmjetson-desktop>.
[ 2.073887] systemd-fstab-generator[1874]: Mount point <3f8579ee-4572-47ab-9763-2d3518828378> is not a valid path, ignoring.
[ 2.131169] systemd[1]: File /lib/systemd/system/systemd-journald.service:35 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 2.131180] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 2.306755] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.308803] systemd[1]: Created slice System Slice.
[ 2.309149] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.309253] systemd[1]: Listening on Journal Audit Socket.
[ 2.309283] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.310175] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 2.310333] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 2.312393] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 2.439000] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 2.497987] nvgpu: 57000000.gpu gm20b_init_clk_setup_sw:1268 [INFO] GPCPLL initial settings: NA mode, M=1, N=34, P=3 (id = 1)
[ 2.607180] systemd-journald[1971]: Received request to flush runtime journal from PID 1
[ 3.679844] random: crng init done
[ 3.683282] random: 7 urandom warning(s) missed due to ratelimiting
[ 3.961749] using random self ethernet address
[ 3.977754] using random host ethernet address
[ 4.220728] Mass Storage Function, version: 2009/09/11
[ 4.220734] LUN: removable file: (no medium)
[ 4.229547] using random self ethernet address
[ 4.234486] using random host ethernet address
[ 4.519501] rndis0: HOST MAC aa:9e:02:cf:42:44
[ 4.519969] rndis0: MAC aa:9e:02:cf:42:45
[ 4.523279] usb0: HOST MAC aa:9e:02:cf:42:46
[ 4.523317] usb0: MAC aa:9e:02:cf:42:47
[ 4.523339] tegra-xudc-new 700d0000.xudc: exiting ELPG
[ 4.528455] tegra-xudc-new 700d0000.xudc: exiting ELPG done
[ 4.528475] tegra-xudc-new 700d0000.xudc: ep 0 (type: 0, dir: out) enabled
[ 4.528506] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 4.528788] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 4.528802] tegra-xudc-new 700d0000.xudc: exiting ELPG
[ 4.533421] tegra-xudc-new 700d0000.xudc: exiting ELPG done
[ 4.533446] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 4.533697] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 4.548774] l4tbr0: port 1(rndis0) entered blocking state
[ 4.548780] l4tbr0: port 1(rndis0) entered disabled state
[ 4.549403] device rndis0 entered promiscuous mode
[ 4.570232] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 4.604105] l4tbr0: port 2(usb0) entered blocking state
[ 4.604110] l4tbr0: port 2(usb0) entered disabled state
[ 4.604681] device usb0 entered promiscuous mode
[ 4.629429] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 5.268669] zram: Added device: zram0
[ 5.281754] zram: Added device: zram1
[ 5.283053] zram: Added device: zram2
[ 5.293232] tegra-xusb 70090000.xusb: Upgrade port 0 to USB3.0
[ 5.293239] tegra-xusb 70090000.xusb: Upgrade port 1 to USB3.0
[ 5.296897] zram: Added device: zram3
[ 5.324443] zram0: detected capacity change from 0 to 518569984
[ 5.432433] Adding 506412k swap on /dev/zram0. Priority:5 extents:1 across:506412k SS
[ 5.444689] zram1: detected capacity change from 0 to 518569984
[ 5.479843] Adding 506412k swap on /dev/zram1. Priority:5 extents:1 across:506412k SS
[ 5.485031] zram2: detected capacity change from 0 to 518569984
[ 5.502474] Adding 506412k swap on /dev/zram2. Priority:5 extents:1 across:506412k SS
[ 5.508116] zram3: detected capacity change from 0 to 518569984
[ 5.555086] Adding 506412k swap on /dev/zram3. Priority:5 extents:1 across:506412k SS
[ 5.563996] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 5.565134] eth0: 0xffffff800a39e000, 00:04:4b:e6:b6:cd, IRQ 84
[ 5.607668] usb 2-1: new SuperSpeed USB device number 2 using tegra-xusb
[ 5.623093] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 5.642702] usb 2-1: New USB device found, idVendor=0bda, idProduct=0411
[ 5.642709] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5.642713] usb 2-1: Product: 4-Port USB 3.1 Hub
[ 5.642716] usb 2-1: Manufacturer: Generic
[ 5.647220] hub 2-1:1.0: USB hub found
[ 5.649832] hub 2-1:1.0: 4 ports detected
[ 5.814666] usb 2-1: usb_suspend_both: status 0
[ 5.822792] usb usb2: usb_suspend_both: status 0
[ 7.285943] tegradc tegradc.0: blank - powerdown
[ 7.336610] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 7.336612] Extcon AUX1(HDMI) disable
[ 7.357300] tegradc tegradc.0: unblank
[ 7.370755] tegradc tegradc.0: nominal-pclk:154000000 parent:153999375 div:1.0 pclk:153999375 152460000~167860000
[ 7.370911] tegradc tegradc.0: hdmi: tmds rate:154000K prod-setting:prod_c_hdmi_150m_300m
[ 7.372005] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 7.372012] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 7.406812] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 7.406816] Extcon AUX1(HDMI) enable
[ 7.413602] tegradc tegradc.0: unblank
[ 7.413612] tegradc tegradc.1: blank - powerdown
[ 8.054601] tegra-xusb 70090000.xusb: entering ELPG
[ 8.055834] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 1, speed 3
[ 8.056025] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 2, speed 0
[ 8.057600] tegra-xusb 70090000.xusb: entering ELPG done
[ 9.718648] r8168: eth0: link up
[ 9.718765] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 10.786067] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 10.786225] Bluetooth: BNEP socket layer initialized
[ 11.265768] fuse init (API version 7.26)
[ 12.211354] tegradc tegradc.0: unblank
[ 12.211364] tegradc tegradc.1: blank - powerdown
[ 62.349016] nvme nvme0: I/O 22 QID 0 timeout, disable controller
[ 62.355928] nvme nvme0: Identify Controller failed (-4)
[ 62.361309] nvme nvme0: Removing after probe failure status: -5
and the Output of the lspci :
$ sudo lspci -vvv
01:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller SM981/PM981 (prog-if 02 [NVM Express])
Subsystem: Samsung Electronics Co Ltd Device a801
Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Interrupt: pin A routed to IRQ 84
Region 0: Memory at 13000000 (64-bit, non-prefetchable) [disabled]
Capabilities: [40] Power Management version 3
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [50] MSI: Enable- Count=1/1 Maskable- 64bit+
Address: 0000000000000000 Data: 0000
Capabilities: [70] Express (v2) Endpoint, MSI 00
DevCap: MaxPayload 256 bytes, PhantFunc 0, Latency L0s unlimited, L1 unlimited
ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset+ SlotPowerLimit 0.000W
DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+ FLReset-
MaxPayload 128 bytes, MaxReadReq 512 bytes
DevSta: CorrErr+ UncorrErr- FatalErr- UnsuppReq+ AuxPwr- TransPend-
LnkCap: Port #0, Speed 8GT/s, Width x4, ASPM L1, Exit Latency L0s unlimited, L1 <64us
ClockPM+ Surprise- LLActRep- BwNot- ASPMOptComp+
LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk-
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Range ABCD, TimeoutDis+, LTR+, OBFF Not Supported
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled
LnkCtl2: Target Link Speed: 8GT/s, EnterCompliance- SpeedDis-
Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
Compliance De-emphasis: -6dB
LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete-, EqualizationPhase1-
EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
Capabilities: [b0] MSI-X: Enable- Count=33 Masked-
Vector table: BAR=0 offset=00003000
PBA: BAR=0 offset=00002000
Capabilities: [100 v2] Advanced Error Reporting
UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
CESta: RxErr- BadTLP- BadDLLP- Rollover+ Timeout+ NonFatalErr+
CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
AERCap: First Error Pointer: 00, GenCap+ CGenEn- ChkCap+ ChkEn-
Capabilities: [148 v1] Device Serial Number 00-00-00-00-00-00-00-00
Capabilities: [158 v1] Power Budgeting <?>
Capabilities: [168 v1] #19
Capabilities: [188 v1] Latency Tolerance Reporting
Max snoop latency: 0ns
Max no snoop latency: 0ns
Capabilities: [190 v1] L1 PM Substates
L1SubCap: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2+ ASPM_L1.1+ L1_PM_Substates+
PortCommonModeRestoreTime=10us PortTPowerOnTime=10us
L1SubCtl1: PCI-PM_L1.2- PCI-PM_L1.1- ASPM_L1.2- ASPM_L1.1-
T_CommonMode=0us LTR1.2_Threshold=0ns
L1SubCtl2: T_PwrOn=10us
