Boot stuck at pcie enumeration with NVMe
I have 1TB NVMe (Vendor ID1344: Device ID 6001) is connected to PCIe C5 via PFX 48X switch. The boot stuck at Enumeration of C5 PCIe controller. This happens particularly with the 1TB NVMe only. If I use 480GB NVMe, the device successfully boots and lspci shows the device properly. The same 1TB NVMe works well with Jetpack 4.6 (Tegra 4.9.253) but not with Jetpack 5.0.2. Can anyone please help me understand what can be wrong and what can be probable solution? The list of PCIe driver changes is big.
Please note that PCIe switch firmware and configuration are same for Jetpack 4.6 and Jetpack 5.0.2
I am attaching dmesg log for stuck boot.
[    4.530509] tegra194-pcie 14160000.pcie: Adding to iommu group 6
[    4.540532] tegra194-pcie 14160000.pcie: host bridge /pcie@14160000 ranges:
[    4.542424] tegra194-pcie 14160000.pcie:       IO 0x0036100000..0x00361fffff -> 0x0036100000
[    4.551289] tegra194-pcie 14160000.pcie:      MEM 0x1400000000..0x173fffffff -> 0x1400000000
[    4.559451] tegra194-pcie 14160000.pcie:      MEM 0x1740000000..0x17ffffffff -> 0x0040000000
[    4.676412] tegra194-pcie 14160000.pcie: Link up
[    4.677197] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[    4.677421] pci_bus 0004:00: root bus resource [bus 00-ff]
[    4.677552] pci_bus 0004:00: root bus resource [io  0x0000-0xfffff] (bus address [0x36100000-0x361fffff])
[    4.677760] pci_bus 0004:00: root bus resource [mem 0x1400000000-0x173fffffff pref]
[    4.678067] pci_bus 0004:00: root bus resource [mem 0x1740000000-0x17ffffffff] (bus address [0x40000000-0xffffffff])
[    4.678471] pci 0004:00:00.0: [10de:1ad1] type 01 class 0x060400
[    4.678942] pci 0004:00:00.0: PME# supported from D0 D3hot D3cold
[    4.692796] pci 0004:01:00.0: [1344:6001] type 00 class 0x010802
[    4.693316] pci 0004:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[    4.695300] pci 0004:01:00.0: 7.876 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x1 link at 0004:00:00.0 (capable of 31.504 Gb/s with 8.0 GT/s PCIe x4 link)
[    4.705900] pci 0004:00:00.0: BAR 14: assigned [mem 0x1740000000-0x17400fffff]
[    4.706234] pci 0004:01:00.0: BAR 0: assigned [mem 0x1740000000-0x1740003fff 64bit]
[    4.706612] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[    4.706885] pci 0004:00:00.0:   bridge window [mem 0x1740000000-0x17400fffff]
[    4.707171] pci 0004:00:00.0: Max Payload Size set to  128/ 256 (was  256), Max Read Rq  512
[    4.707558] pci 0004:01:00.0: Max Payload Size set to  128/ 128 (was  128), Max Read Rq  512
[    4.716707] pcieport 0004:00:00.0: Adding to iommu group 6
[    4.721292] pcieport 0004:00:00.0: PME: Signaling with IRQ 24
[    4.727215] pcieport 0004:00:00.0: AER: enabled with IRQ 24
[    4.733061] nvme 0004:01:00.0: Adding to iommu group 6
[    4.738368] nvme nvme0: pci function 0004:01:00.0
[    4.741919] nvme 0004:01:00.0: enabling device (0000 -> 0002)
[    4.743402] tegra194-pcie 141a0000.pcie: Adding to iommu group 7
[    4.759330] tegra194-pcie 141a0000.pcie: host bridge /pcie@141a0000 ranges:
[    4.760163] tegra194-pcie 141a0000.pcie:       IO 0x003a100000..0x003a1fffff -> 0x003a100000
[    4.768934] tegra194-pcie 141a0000.pcie:      MEM 0x1c00000000..0x1f3fffffff -> 0x1c00000000
[    4.777390] tegra194-pcie 141a0000.pcie:      MEM 0x1f40000000..0x1fffffffff -> 0x0040000000
[    4.807415] nvme nvme0: allocated 64 MiB host memory buffer.
[    4.823144] nvme nvme0: 6/0/0 default/read/poll queues
[    4.892548] tegra194-pcie 141a0000.pcie: Link up
[    4.895367] tegra194-pcie 141a0000.pcie: PCI host bridge to bus 0005:00
[    4.895647] pci_bus 0005:00: root bus resource [bus 00-ff]
[    4.895832] pci_bus 0005:00: root bus resource [io  0x100000-0x1fffff] (bus address [0x3a100000-0x3a1fffff])
[    4.896050] pci_bus 0005:00: root bus resource [mem 0x1c00000000-0x1f3fffffff pref]
[    4.896262] pci_bus 0005:00: root bus resource [mem 0x1f40000000-0x1fffffffff] (bus address [0x40000000-0xffffffff])
[    4.896724] pci 0005:00:00.0: [10de:1ad0] type 01 class 0x060400
[    4.897181] pci 0005:00:00.0: PME# supported from D0 D3hot D3cold
[    4.910028] pci 0005:01:00.0: [11f8:8573] type 01 class 0x060400
[    4.911587] pci 0005:01:00.0: enabling Extended Tags
[    4.914339] pci 0005:01:00.0: PME# supported from D0 D3hot D3cold
[    4.916932] pci 0005:01:00.1: [11f8:8573] type 00 class 0x068000
[    4.917775] pci 0005:01:00.1: reg 0x10: [mem 0x00000000-0x003fffff]
[    4.918773] pci 0005:01:00.1: reg 0x18: [mem 0x00000000-0x0fffffff 64bit pref]
[    4.919361] pci 0005:01:00.1: reg 0x20: [mem 0x00000000-0x01ffffff]
[    4.919912] pci 0005:01:00.1: reg 0x24: [mem 0x00000000-0x007fffff]
[    4.920470] pci 0005:01:00.1: enabling Extended Tags
[    4.922349] pci 0005:01:00.1: PME# supported from D0 D3hot D3cold
[    4.934264] pci 0005:01:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    4.937112] pci 0005:02:00.0: [11f8:8573] type 01 class 0x060400
[    4.938509] pci 0005:02:00.0: enabling Extended Tags
[    4.941072] pci 0005:02:00.0: PME# supported from D0 D3hot D3cold
[    4.947427] pci 0005:02:01.0: [11f8:8573] type 01 class 0x060400
[    4.951257] pci 0005:02:01.0: enabling Extended Tags
[    4.957764] pci 0005:02:01.0: PME# supported from D0 D3hot D3cold
[    4.964202] pci 0005:02:02.0: [11f8:8573] type 01 class 0x060400
[    4.968131] pci 0005:02:02.0: enabling Extended Tags
[    4.974650] pci 0005:02:02.0: PME# supported from D0 D3hot D3cold
[    4.991152] pci 0005:02:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    4.991819] pci 0005:02:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    4.994930] pci 0005:02:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    5.004901] pci 0005:03:00.0: [1344:6001] type 00 class 0x010802
[    5.009143] pci 0005:03:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
Could you share the lspci -vv result when it is on jp4.6?
Also, attach us the full log from jp5.
This is the output of lspci -vv for Jetpack 4.6 on the device.
$ lspci -vv
0004:00:00.0 PCI bridge: NVIDIA Corporation Device 1ad1 (rev a1) (prog-if 00 [Normal decode])
        Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
        Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
        Latency: 0
        Interrupt: pin A routed to IRQ 33
        Bus: primary=00, secondary=01, subordinate=ff, sec-latency=0
        Memory behind bridge: 40000000-400fffff
        Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
        BridgeCtl: Parity- SERR- NoISA- VGA- MAbort- >Reset- FastB2B-
                PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
        Capabilities: <access denied>
        Kernel driver in use: pcieport
0004:01:00.0 Non-Volatile memory controller: Micron Technology Inc Device 6001 (rev 03) (prog-if 02 [NVM Express])
        Subsystem: Micron Technology Inc Device 0400
        Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
        Latency: 0
        Region 0: Memory at 1740000000 (64-bit, non-prefetchable) [size=16K]
        Kernel driver in use: nvme
0005:00:00.0 PCI bridge: NVIDIA Corporation Device 1ad0 (rev a1) (prog-if 00 [Normal decode])
        Latency: 0
        Interrupt: pin A routed to IRQ 35
        I/O behind bridge: 00000000-00002fff
        Memory behind bridge: 40000000-43ffffff
        Prefetchable memory behind bridge: 0000001c00000000-0000001c1fffffff
        Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort+ <SERR- <PERR-
0005:01:00.0 PCI bridge: PMC-Sierra Inc. Device 8573 (prog-if 00 [Normal decode])
        Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx+
        Latency: 0
        Interrupt: pin ? routed to IRQ 811
        Bus: primary=01, secondary=02, subordinate=05, sec-latency=0
        I/O behind bridge: 3a100000-3a102fff
        Memory behind bridge: 42c00000-431fffff
        Prefetchable memory behind bridge: 0000001c10000000-0000001c105fffff
0005:01:00.1 Bridge: PMC-Sierra Inc. Device 8573
        Subsystem: Dolphin Interconnect Solutions AS Device 0222
        Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
        Latency: 0
        Region 0: Memory at 1f42800000 (32-bit, non-prefetchable) [size=4M]
        Region 2: Memory at 1c00000000 (64-bit, prefetchable) [size=256M]
        Region 4: Memory at 1f40000000 (32-bit, non-prefetchable) [size=32M]
        Region 5: Memory at 1f42000000 (32-bit, non-prefetchable) [size=8M]
0005:02:00.0 PCI bridge: PMC-Sierra Inc. Device 8573 (prog-if 00 [Normal decode])
        Latency: 0
        Interrupt: pin ? routed to IRQ 812
        Bus: primary=02, secondary=03, subordinate=03, sec-latency=0
        I/O behind bridge: 3a100000-3a100fff
        Memory behind bridge: 42c00000-42dfffff
        Prefetchable memory behind bridge: 0000001c10000000-0000001c101fffff
0005:02:01.0 PCI bridge: PMC-Sierra Inc. Device 8573 (prog-if 00 [Normal decode])
        Latency: 0
        Interrupt: pin ? routed to IRQ 813
        Bus: primary=02, secondary=04, subordinate=04, sec-latency=0
        I/O behind bridge: 3a101000-3a101fff
        Memory behind bridge: 42e00000-42ffffff
        Prefetchable memory behind bridge: 0000001c10200000-0000001c103fffff
0005:02:02.0 PCI bridge: PMC-Sierra Inc. Device 8573 (prog-if 00 [Normal decode])
        Latency: 0
        Interrupt: pin ? routed to IRQ 814
        Bus: primary=02, secondary=05, subordinate=05, sec-latency=0
        I/O behind bridge: 3a102000-3a102fff
        Memory behind bridge: 43000000-431fffff
        Prefetchable memory behind bridge: 0000001c10400000-0000001c105fffff
0005:03:00.0 Non-Volatile memory controller: Micron Technology Inc Device 6001 (rev 03) (prog-if 02 [NVM Express])
        Subsystem: Micron Technology Inc Device 2100
        Latency: 0
        Region 0: Memory at 1f42c00000 (64-bit, non-prefetchable) [size=16K]
Here is the full log of JP 5.0.2.
dmesg_xavier_JP5.0.2.txt (58.1 KB)
Can anyone please help me with this matter?
@WayneWWW Any idea what can be wrong in JP 5.0.2 and not in JP 4.6?
Jetpack 4.6, full capabilities
xavier@nx1:~$ sudo lspci -vv
        Latency: 0
        Capabilities: [40] Power Management version 3
                Flags: PMEClk- DSI- D1- D2- AuxCurrent=375mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
                Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
        Capabilities: [50] MSI: Enable- Count=1/1 Maskable+ 64bit+
                Address: 0000000000000000  Data: 0000
                Masking: 00000000  Pending: 00000000
        Capabilities: [70] Express (v2) Root Port (Slot-), MSI 00
                DevCap: MaxPayload 256 bytes, PhantFunc 0
                        ExtTag- RBE+
                DevCtl: Report errors: Correctable+ Non-Fatal+ Fatal+ Unsupported+
                        RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+
                        MaxPayload 128 bytes, MaxReadReq 512 bytes
                DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr+ TransPend-
                LnkCap: Port #0, Speed 8GT/s, Width x1, ASPM not supported, Exit Latency L0s <1us, L1 <64us
                        ClockPM- Surprise+ LLActRep+ BwNot+ ASPMOptComp+
                LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk+
                        ExtSynch- ClockPM- AutWidDis- BWInt+ AutBWInt-
                LnkSta: Speed 8GT/s, Width x1, TrErr- Train- SlotClk+ DLActive+ BWMgmt+ ABWMgmt+
                RootCtl: ErrCorrectable- ErrNon-Fatal- ErrFatal- PMEIntEna+ CRSVisible+
                RootCap: CRSVisible+
                RootSta: PME ReqID 0000, PMEStatus- PMEPending-
                DevCap2: Completion Timeout: Range ABCD, TimeoutDis+, LTR+, OBFF Not Supported ARIFwd-
                DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR+, OBFF Disabled ARIFwd-
                LnkCtl2: Target Link Speed: 8GT/s, EnterCompliance- SpeedDis-
                         Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
                         Compliance De-emphasis: -6dB
                LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete+, EqualizationPhase1+
                         EqualizationPhase2+, EqualizationPhase3+, LinkEqualizationRequest-
        Capabilities: [b0] MSI-X: Enable- Count=8 Masked-
                Vector table: BAR=2 offset=00000000
                PBA: BAR=2 offset=00010000
        Capabilities: [100 v2] Advanced Error Reporting
                UESta:  DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
                UEMsk:  DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
                UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
                CESta:  RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
                CEMsk:  RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
                AERCap: First Error Pointer: 00, GenCap+ CGenEn- ChkCap+ ChkEn-
        Capabilities: [148 v1] #19
        Capabilities: [168 v1] #26
        Capabilities: [18c v1] #27
        Capabilities: [1ac v1] L1 PM Substates
                L1SubCap: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2- ASPM_L1.1- L1_PM_Substates+
                          PortCommonModeRestoreTime=60us PortTPowerOnTime=40us
                L1SubCtl1: PCI-PM_L1.2- PCI-PM_L1.1- ASPM_L1.2- ASPM_L1.1-
                           T_CommonMode=60us
                L1SubCtl2: T_PwrOn=40us
        Capabilities: [1bc v1] Vendor Specific Information: ID=0002 Rev=4 Len=100 <?>
        Capabilities: [2bc v1] Vendor Specific Information: ID=0001 Rev=1 Len=038 <?>
        Capabilities: [2f4 v1] #25
        Capabilities: [300 v1] Precision Time Measurement
                PTMCap: Requester:+ Responder:+ Root:+
                PTMClockGranularity: 16ns
                PTMControl: Enabled:- RootSelected:-
                PTMEffectiveGranularity: Unknown
        Capabilities: [30c v1] Vendor Specific Information: ID=0004 Rev=1 Len=054 <?>
        Latency: 0
                Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
                Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME-
        Capabilities: [50] MSI: Enable- Count=1/8 Maskable+ 64bit+
        Capabilities: [70] Express (v2) Endpoint, MSI 00
                DevCap: MaxPayload 128 bytes, PhantFunc 0, Latency L0s unlimited, L1 unlimited
                        ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset+ SlotPowerLimit 0.000W
                        RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop- FLReset-
                LnkCap: Port #0, Speed 8GT/s, Width x4, ASPM L1, Exit Latency L0s <1us, L1 <8us
                        ClockPM+ Surprise- LLActRep- BwNot- ASPMOptComp+
                        ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
                LnkSta: Speed 8GT/s, Width x1, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
        Capabilities: [b0] MSI-X: Enable+ Count=16 Masked-
                Vector table: BAR=0 offset=00002000
                PBA: BAR=0 offset=00002100
        Capabilities: [158 v1] #19
        Capabilities: [178 v1] Latency Tolerance Reporting
                Max snoop latency: 0ns
                Max no snoop latency: 0ns
        Capabilities: [180 v1] L1 PM Substates
                L1SubCap: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2+ ASPM_L1.1+ L1_PM_Substates+
                          PortCommonModeRestoreTime=10us PortTPowerOnTime=10us
                           T_CommonMode=0us LTR1.2_Threshold=0ns
        Latency: 0
                        ExtTag- RBE+
                LnkCap: Port #0, Speed 16GT/s, Width x8, ASPM not supported, Exit Latency L0s <1us, L1 <64us
                LnkSta: Speed 8GT/s, Width x4, TrErr- Train- SlotClk+ DLActive+ BWMgmt+ ABWMgmt+
                LnkCtl2: Target Link Speed: 16GT/s, EnterCompliance- SpeedDis-
        Capabilities: [190 v1] #27
        Capabilities: [1c0 v1] L1 PM Substates
                           T_CommonMode=60us
        Capabilities: [1d0 v1] Vendor Specific Information: ID=0002 Rev=4 Len=100 <?>
        Capabilities: [2d0 v1] Vendor Specific Information: ID=0001 Rev=1 Len=038 <?>
        Capabilities: [308 v1] #25
        Capabilities: [314 v1] Precision Time Measurement
        Capabilities: [320 v1] Vendor Specific Information: ID=0004 Rev=1 Len=054 <?>
        Latency: 0
        Capabilities: [40] Express (v2) Upstream Port, MSI 00
                DevCap: MaxPayload 512 bytes, PhantFunc 0
                        ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ SlotPowerLimit 0.000W
                DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
                        RlxdOrd- ExtTag- PhantFunc- AuxPwr- NoSnoop-
                        MaxPayload 128 bytes, MaxReadReq 128 bytes
                DevSta: CorrErr+ UncorrErr- FatalErr- UnsuppReq+ AuxPwr- TransPend-
                LnkCap: Port #24, Speed 8GT/s, Width x4, ASPM L1, Exit Latency L0s <64ns, L1 <1us
                        ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp+
                LnkCtl: ASPM Disabled; Disabled- CommClk+
                LnkSta: Speed 8GT/s, Width x4, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
                DevCap2: Completion Timeout: Not Supported, TimeoutDis-, LTR+, OBFF Via message
                DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled
        Capabilities: [7c] MSI: Enable+ Count=1/8 Maskable- 64bit+
                Address: 0000000092001000  Data: 0000
        Capabilities: [8c] Power Management version 3
                Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
        Capabilities: [94] Subsystem: Dolphin Interconnect Solutions AS Device 0222
        Capabilities: [100 v1] Advanced Error Reporting
                CESta:  RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
        Capabilities: [138 v1] Power Budgeting <?>
        Capabilities: [148 v1] #12
        Capabilities: [178 v1] #19
        Capabilities: [1a4 v1] Device Serial Number 00-00-43-43-00-00-00-01
        Capabilities: [1b0 v1] Latency Tolerance Reporting
        Capabilities: [7f8 v1] Vendor Specific Information: ID=ffff Rev=1 Len=808 <?>
        Latency: 0
        Capabilities: [40] MSI: Enable- Count=1/4 Maskable- 64bit+
        Capabilities: [50] MSI-X: Enable- Count=4 Masked-
                Vector table: BAR=0 offset=00076000
                PBA: BAR=0 offset=00077000
        Capabilities: [5c] Power Management version 3
        Capabilities: [64] Express (v2) Endpoint, MSI 00
                DevCap: MaxPayload 512 bytes, PhantFunc 0, Latency L0s <64ns, L1 <1us
                        ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset+ SlotPowerLimit 0.000W
                        RlxdOrd- ExtTag- PhantFunc- AuxPwr- NoSnoop- FLReset-
                LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete-, EqualizationPhase1-
                         EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
        Capabilities: [138 v1] #12
        Capabilities: [168 v1] Device Serial Number 00-00-43-43-00-00-00-01
        Latency: 0
        Capabilities: [40] Express (v2) Downstream Port (Slot+), MSI 00
                        ExtTag+ RBE+
                DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend-
                LnkCap: Port #12, Speed 8GT/s, Width x4, ASPM L1, Exit Latency L0s <64ns, L1 <1us
                LnkCtl: ASPM L1 Enabled; Disabled- CommClk+
                LnkSta: Speed 8GT/s, Width x4, TrErr- Train- SlotClk+ DLActive+ BWMgmt+ ABWMgmt-
                SltCap: AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise-
                        Slot #1, PowerLimit 0.000W; Interlock- NoCompl+
                SltCtl: Enable: AttnBtn- PwrFlt- MRL- PresDet- CmdCplt- HPIrq- LinkChg-
                        Control: AttnInd Off, PwrInd Off, Power- Interlock-
                SltSta: Status: AttnBtn- PowerFlt- MRL- CmdCplt- PresDet+ Interlock-
                        Changed: MRL- PresDet+ LinkState+
                DevCap2: Completion Timeout: Not Supported, TimeoutDis-, LTR+, OBFF Via message ARIFwd+
                DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled ARIFwd-
                LnkCtl2: Target Link Speed: 8GT/s, EnterCompliance- SpeedDis-, Selectable De-emphasis: -6dB
                Address: 0000000092001000  Data: 0001
        Capabilities: [1b0 v1] Downstream Port Containment
                DpcCap: INT Msg #0, RPExt- PoisonedTLP+ SwTrigger+ RP PIO Log 0, DL_ActiveErr+
                DpcCtl: Trigger:0 Cmpl- INT- ErrCor- PoisonedTLP- SwTrigger- DL_ActiveErr-
                DpcSta: Trigger- Reason:00 INT- RPBusy- TriggerExt:00 RP PIO ErrPtr:00
                Source: 0000
        Capabilities: [1bc v1] Access Control Services
                ACSCap: SrcValid+ TransBlk+ ReqRedir+ CmpltRedir+ UpstreamFwd+ EgressCtrl+ DirectTrans+
                ACSCtl: SrcValid- TransBlk- ReqRedir- CmpltRedir- UpstreamFwd- EgressCtrl- DirectTrans-
        Latency: 0
                        ExtTag+ RBE+
                LnkCap: Port #10, Speed 8GT/s, Width x2, ASPM L1, Exit Latency L0s <64ns, L1 <1us
                LnkCtl: ASPM Disabled; Disabled- CommClk-
                LnkSta: Speed 2.5GT/s, Width x0, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
                        Slot #2, PowerLimit 0.000W; Interlock- NoCompl+
                SltSta: Status: AttnBtn- PowerFlt- MRL- CmdCplt- PresDet- Interlock-
                        Changed: MRL- PresDet- LinkState-
                Address: 0000000092001000  Data: 0002
                Source: 0000
        Latency: 0
                        ExtTag+ RBE+
                LnkCap: Port #11, Speed 8GT/s, Width x2, ASPM L1, Exit Latency L0s <64ns, L1 <1us
                        Slot #3, PowerLimit 0.000W; Interlock- NoCompl+
                Address: 0000000092001000  Data: 0003
                Source: 0000
        Latency: 0
                LnkCtl: ASPM L1 Enabled; RCB 64 bytes Disabled- CommClk+
                        ExtSynch- ClockPM+ AutWidDis- BWInt- AutBWInt-
                L1SubCtl2: T_PwrOn=10us
Can anyone please help me with this issue?
Are you able to test this without using the pcie switch? For example, put this nvme to devkit to test.
The same nvme works on devkit, but when there is a pcie switch, it doesn’t like.
