JetPack-5.0 PCIe Switch Does Not Transmit MSI Interrupts
Hello everyone,
We are using a PCIe switch (Diodes PI7C9X2G608GP) with Gigabit Ethernet IC (Microchip lan7430) to have multiple Gigabit Ethernet on AGX Xavier.
We are using them without any errors on JetPack-4.6.x versions. However, this system does not work on JetPack-5.0.2. We can see the devices on lspci output. However, after debugging in detail we understood that the MSI interrupts are not correctly transmitted when there is a switch.
On AGX Xavier Dev. Kit, we confirmed the Ethernet IC (lan7430) is working (without this PCIe switch). So we are suspicious that in the new kernel version there is a change that effects functionalty of PCIe switch.
If you can help us to fix this issue, we will be very happy.
could you tell us how you found out below issue?
Please also share below info from both jetpack4 and jetpack5 with switch + device connected (which you can reproduce error).
  1. sudo lspci -vvv
  2. sudo lspci -tv
  3. uart logs/dmesg
  4. cat /proc/interrupts
Thanks @WayneWWW
We added kernel prints to the lan7430 driver source that’s how we confirmed that interrupts are not received correctly.
JetPack-4.6.3 device-tree :
jp463.dts (357.1 KB)
JetPack-4.6.3 dmesg:
jp463_dmesg.txt (71.8 KB)
sudo lspci -vvv
nvidia@nvidia-desktop:~$ sudo lspci -vvv
[sudo] password for nvidia:
0001:00:00.0 PCI bridge: NVIDIA Corporation Device 1ad2 (rev a1) (prog-if 00 [Normal decode])
	Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
	Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Latency: 0
	Interrupt: pin A routed to IRQ 35
	Bus: primary=00, secondary=01, subordinate=ff, sec-latency=0
	I/O behind bridge: 0000f000-00000fff
	Memory behind bridge: 40000000-400fffff
	Prefetchable memory behind bridge: 00000000fff00000-00000000000fffff
	Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
	BridgeCtl: Parity- SERR- NoISA- VGA- MAbort- >Reset- FastB2B-
		PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
	Capabilities: [40] Power Management version 3
		Flags: PMEClk- DSI- D1- D2- AuxCurrent=375mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
		Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
	Capabilities: [50] MSI: Enable- Count=1/1 Maskable- 64bit+
		Address: 0000000000000000  Data: 0000
	Capabilities: [70] Express (v2) Root Port (Slot-), MSI 00
		DevCap:	MaxPayload 256 bytes, PhantFunc 0
			ExtTag- RBE+
		DevCtl:	Report errors: Correctable+ Non-Fatal+ Fatal+ Unsupported+
			RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+
			MaxPayload 256 bytes, MaxReadReq 512 bytes
		DevSta:	CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr+ TransPend-
		LnkCap:	Port #0, Speed 5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <1us, L1 <64us
			ClockPM- Surprise+ LLActRep+ BwNot+ ASPMOptComp+
		LnkCtl:	ASPM L0s Enabled; RCB 64 bytes Disabled- CommClk-
			ExtSynch- ClockPM- AutWidDis- BWInt+ AutBWInt-
		LnkSta:	Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive+ BWMgmt+ ABWMgmt-
		RootCtl: ErrCorrectable- ErrNon-Fatal- ErrFatal- PMEIntEna+ CRSVisible+
		RootCap: CRSVisible+
		RootSta: PME ReqID 0000, PMEStatus- PMEPending-
		DevCap2: Completion Timeout: Range ABCD, TimeoutDis+, LTR+, OBFF Not Supported ARIFwd-
		DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR+, OBFF Disabled ARIFwd-
		LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis-
			 Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
			 Compliance De-emphasis: -6dB
		LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete-, EqualizationPhase1-
			 EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
	Capabilities: [b0] MSI-X: Enable- Count=1 Masked-
		Vector table: BAR=0 offset=00000000
		PBA: BAR=0 offset=00000000
	Capabilities: [100 v2] Advanced Error Reporting
		UESta:	DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
		UEMsk:	DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
		UESvrt:	DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
		CESta:	RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
		CEMsk:	RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
		AERCap:	First Error Pointer: 00, GenCap+ CGenEn- ChkCap+ ChkEn-
	Capabilities: [148 v1] #19
	Capabilities: [158 v1] #26
	Capabilities: [17c v1] #27
	Capabilities: [190 v1] L1 PM Substates
		L1SubCap: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2- ASPM_L1.1- L1_PM_Substates+
			  PortCommonModeRestoreTime=60us PortTPowerOnTime=40us
		L1SubCtl1: PCI-PM_L1.2- PCI-PM_L1.1- ASPM_L1.2- ASPM_L1.1-
			   T_CommonMode=60us
		L1SubCtl2: T_PwrOn=40us
	Capabilities: [1a0 v1] Vendor Specific Information: ID=0002 Rev=4 Len=100 <?>
	Capabilities: [2a0 v1] Vendor Specific Information: ID=0001 Rev=1 Len=038 <?>
	Capabilities: [2d8 v1] #25
	Capabilities: [2e4 v1] Precision Time Measurement
		PTMCap: Requester:- Responder:+ Root:+
		PTMClockGranularity: 16ns
		PTMControl: Enabled:- RootSelected:-
		PTMEffectiveGranularity: Unknown
	Capabilities: [2f0 v1] Vendor Specific Information: ID=0004 Rev=1 Len=054 <?>
	Kernel driver in use: pcieport
0001:01:00.0 Serial controller: Exar Corp. Device 0358 (rev 03) (prog-if 02 [16550])
	Control: I/O- Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
	Region 0: Memory at 1230000000 (32-bit, non-prefetchable) [size=16K]
	Capabilities: [78] Power Management version 3
		Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold-)
	Capabilities: [80] Express (v2) Endpoint, MSI 01
		DevCap:	MaxPayload 256 bytes, PhantFunc 0, Latency L0s <64ns, L1 <1us
			ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset- SlotPowerLimit 0.000W
		DevCtl:	Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
		DevSta:	CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend-
		LnkCap:	Port #1, Speed 2.5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <64ns, L1 <1us
			ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp-
		LnkCtl:	ASPM Disabled; RCB 64 bytes Disabled- CommClk-
			ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
		LnkSta:	Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk- DLActive- BWMgmt- ABWMgmt-
		DevCap2: Completion Timeout: Not Supported, TimeoutDis-, LTR-, OBFF Not Supported
		DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled
		LnkCtl2: Target Link Speed: 2.5GT/s, EnterCompliance- SpeedDis-
	Capabilities: [100 v1] Virtual Channel
		Caps:	LPEVC=0 RefClk=100ns PATEntryBits=1
		Arb:	Fixed- WRR32- WRR64- WRR128-
		Ctrl:	ArbSelect=Fixed
		Status:	InProgress-
		VC0:	Caps:	PATOffset=00 MaxTimeSlots=1 RejSnoopTrans-
			Arb:	Fixed- WRR32- WRR64- WRR128- TWRR128- WRR256-
			Ctrl:	Enable+ ID=0 ArbSelect=Fixed TC/VC=ff
			Status:	NegoPending- InProgress-
	Kernel driver in use: xrserial
0005:00:00.0 PCI bridge: NVIDIA Corporation Device 1ad0 (rev a1) (prog-if 00 [Normal decode])
	Latency: 0
	Interrupt: pin A routed to IRQ 39
	I/O behind bridge: 00000000-00003fff
	Memory behind bridge: 40000000-407fffff
	Prefetchable memory behind bridge: 0000001c00000000-0000001c007fffff
	Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort+ <SERR- <PERR-
	Capabilities: [50] MSI: Enable- Count=1/1 Maskable+ 64bit+
		Masking: 00000000  Pending: 00000000
			ExtTag- RBE+
			MaxPayload 128 bytes, MaxReadReq 512 bytes
		LnkCap:	Port #0, Speed 5GT/s, Width x8, ASPM not supported, Exit Latency L0s <1us, L1 <64us
		LnkCtl:	ASPM Disabled; RCB 64 bytes Disabled- CommClk+
		LnkSta:	Speed 5GT/s, Width x4, TrErr- Train- SlotClk+ DLActive+ BWMgmt+ ABWMgmt+
		LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete-, EqualizationPhase1-
	Capabilities: [b0] MSI-X: Enable- Count=8 Masked-
		Vector table: BAR=2 offset=00000000
		PBA: BAR=2 offset=00010000
	Capabilities: [168 v1] #26
	Capabilities: [190 v1] #27
	Capabilities: [1c0 v1] L1 PM Substates
			   T_CommonMode=60us
	Capabilities: [1d0 v1] Vendor Specific Information: ID=0002 Rev=4 Len=100 <?>
	Capabilities: [2d0 v1] Vendor Specific Information: ID=0001 Rev=1 Len=038 <?>
	Capabilities: [308 v1] #25
	Capabilities: [314 v1] Precision Time Measurement
		PTMCap: Requester:+ Responder:+ Root:+
	Capabilities: [320 v1] Vendor Specific Information: ID=0004 Rev=1 Len=054 <?>
0005:01:00.0 PCI bridge: Pericom Semiconductor PI7C9X2G608GP PCIe2 6-Port/8-Lane Packet Switch (prog-if 00 [Normal decode])
	Latency: 0
	Bus: primary=01, secondary=02, subordinate=06, sec-latency=0
	I/O behind bridge: 3a100000-3a103fff
		Flags: PMEClk- DSI- D1+ D2+ AuxCurrent=375mA PME(D0+,D1+,D2+,D3hot+,D3cold+)
	Capabilities: [5c] Vital Product Data
[   70.388797] pcieport 0005:01:00.0: invalid large VPD tag 7f at offset 0
pcilib: sysfs_read_vpd: read failed: Input/output error
		Not readable
	Capabilities: [64] Vendor Specific Information: Len=34 <?>
	Capabilities: [b0] Subsystem: Device 0000:0000
	Capabilities: [c0] Express (v2) Upstream Port, MSI 00
			ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ SlotPowerLimit 0.000W
			RlxdOrd- ExtTag- PhantFunc- AuxPwr- NoSnoop-
			MaxPayload 128 bytes, MaxReadReq 128 bytes
		DevSta:	CorrErr+ UncorrErr- FatalErr- UnsuppReq+ AuxPwr+ TransPend-
		LnkCap:	Port #0, Speed 5GT/s, Width x4, ASPM not supported, Exit Latency L0s <512ns, L1 <1us
			ClockPM+ Surprise- LLActRep- BwNot- ASPMOptComp-
		LnkCtl:	ASPM Disabled; Disabled- CommClk+
		LnkSta:	Speed 5GT/s, Width x4, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
		DevCap2: Completion Timeout: Not Supported, TimeoutDis-, LTR+, OBFF Not Supported
	Capabilities: [100 v1] Advanced Error Reporting
		UESvrt:	DLP+ SDES- TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
		CESta:	RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
	Capabilities: [140 v1] Virtual Channel
		Caps:	LPEVC=0 RefClk=100ns PATEntryBits=4
		Status:	InProgress-
		VC0:	Caps:	PATOffset=04 MaxTimeSlots=64 RejSnoopTrans-
			Arb:	Fixed+ WRR32- WRR64- WRR128+ TWRR128- WRR256-
			Port Arbitration Table <?>
	Capabilities: [20c v1] Power Budgeting <?>
	Capabilities: [230 v1] Latency Tolerance Reporting
		Max snoop latency: 0ns
		Max no snoop latency: 0ns
	Capabilities: [240 v1] L1 PM Substates
		L1SubCap: PCI-PM_L1.2- PCI-PM_L1.1+ ASPM_L1.2- ASPM_L1.1- L1_PM_Substates+
		L1SubCtl2:
0005:02:01.0 PCI bridge: Pericom Semiconductor PI7C9X2G608GP PCIe2 6-Port/8-Lane Packet Switch (prog-if 00 [Normal decode])
	Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx+
	Latency: 0
	Interrupt: pin A routed to IRQ 819
	Bus: primary=02, secondary=03, subordinate=03, sec-latency=0
	I/O behind bridge: 3a100000-3a100fff
	Memory behind bridge: 40000000-401fffff
	Prefetchable memory behind bridge: 0000001c00000000-0000001c001fffff
	Capabilities: [4c] MSI: Enable+ Count=1/1 Maskable- 64bit+
		Address: 00000000fffff000  Data: 0000
	Capabilities: [c0] Express (v2) Downstream Port (Slot+), MSI 00
			ExtTag- RBE+
		LnkCap:	Port #1, Speed 5GT/s, Width x1, ASPM not supported, Exit Latency L0s <512ns, L1 <1us
			ClockPM- Surprise- LLActRep+ BwNot+ ASPMOptComp-
		SltCap:	AttnBtn+ PwrCtrl+ MRL+ AttnInd+ PwrInd+ HotPlug+ Surprise-
			Slot #0, PowerLimit 25.000W; Interlock- NoCompl-
		SltCtl:	Enable: AttnBtn- PwrFlt- MRL- PresDet- CmdCplt- HPIrq- LinkChg-
			Control: AttnInd Off, PwrInd On, Power- Interlock-
		SltSta:	Status: AttnBtn- PowerFlt- MRL- CmdCplt+ PresDet+ Interlock-
			Changed: MRL- PresDet- LinkState+
		DevCap2: Completion Timeout: Not Supported, TimeoutDis-, LTR+, OBFF Not Supported ARIFwd-
		DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled ARIFwd-
		LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis-, Selectable De-emphasis: -3.5dB
		Status:	InProgress-
	Capabilities: [220 v1] Access Control Services
		ACSCap:	SrcValid+ TransBlk+ ReqRedir+ CmpltRedir+ UpstreamFwd+ EgressCtrl+ DirectTrans+
		ACSCtl:	SrcValid- TransBlk- ReqRedir- CmpltRedir- UpstreamFwd- EgressCtrl- DirectTrans-
		L1SubCtl2:
0005:02:02.0 PCI bridge: Pericom Semiconductor PI7C9X2G608GP PCIe2 6-Port/8-Lane Packet Switch (prog-if 00 [Normal decode])
	Latency: 0
	Interrupt: pin A routed to IRQ 820
	Bus: primary=02, secondary=04, subordinate=04, sec-latency=0
	I/O behind bridge: 3a101000-3a101fff
	Memory behind bridge: 40200000-403fffff
	Prefetchable memory behind bridge: 0000001c00200000-0000001c003fffff
		Address: 00000000fffff000  Data: 0001
			ExtTag- RBE+
		LnkCap:	Port #2, Speed 5GT/s, Width x1, ASPM not supported, Exit Latency L0s <512ns, L1 <1us
		Status:	InProgress-
		L1SubCtl2:
0005:02:03.0 PCI bridge: Pericom Semiconductor PI7C9X2G608GP PCIe2 6-Port/8-Lane Packet Switch (prog-if 00 [Normal decode])
	Latency: 0
	Interrupt: pin A routed to IRQ 821
	Bus: primary=02, secondary=05, subordinate=05, sec-latency=0
	I/O behind bridge: 3a102000-3a102fff
	Memory behind bridge: 40400000-405fffff
	Prefetchable memory behind bridge: 0000001c00400000-0000001c005fffff
		Address: 00000000fffff000  Data: 0002
			ExtTag- RBE+
		LnkCap:	Port #3, Speed 5GT/s, Width x1, ASPM not supported, Exit Latency L0s <512ns, L1 <1us
		Status:	InProgress-
		L1SubCtl2:
0005:02:04.0 PCI bridge: Pericom Semiconductor PI7C9X2G608GP PCIe2 6-Port/8-Lane Packet Switch (prog-if 00 [Normal decode])
	Latency: 0
	Interrupt: pin A routed to IRQ 822
	Bus: primary=02, secondary=06, subordinate=06, sec-latency=0
	I/O behind bridge: 3a103000-3a103fff
	Memory behind bridge: 40600000-407fffff
	Prefetchable memory behind bridge: 0000001c00600000-0000001c007fffff
		Address: 00000000fffff000  Data: 0003
			ExtTag- RBE+
		LnkCap:	Port #4, Speed 5GT/s, Width x1, ASPM not supported, Exit Latency L0s <512ns, L1 <1us
		Status:	InProgress-
		L1SubCtl2:
0005:03:00.0 Ethernet controller: Microchip Technology / SMSC Device 7430 (rev 11)
	Subsystem: Microchip Technology / SMSC Device 7430
	Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
	Latency: 0
	Region 0: Memory at 1f40000000 (64-bit, non-prefetchable) [size=8K]
	Region 2: Memory at 1f40002000 (64-bit, non-prefetchable) [size=256]
	Region 4: Memory at 1f40002100 (64-bit, non-prefetchable) [size=256]
		Flags: PMEClk- DSI+ D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold-)
	Capabilities: [50] MSI: Enable- Count=1/8 Maskable+ 64bit+
	Capabilities: [70] Express (v2) Endpoint, MSI 00
		DevCap:	MaxPayload 512 bytes, PhantFunc 0, Latency L0s <512ns, L1 <32us
			ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset+ SlotPowerLimit 25.000W
			RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop- FLReset-
		LnkCap:	Port #0, Speed 2.5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <1us, L1 <8us
			ClockPM+ Surprise- LLActRep- BwNot- ASPMOptComp+
			ExtSynch- ClockPM+ AutWidDis- BWInt- AutBWInt-
		LnkSta:	Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
		DevCap2: Completion Timeout: Range ABCD, TimeoutDis+, LTR+, OBFF Via message/WAKE#
	Capabilities: [b0] MSI-X: Enable+ Count=8 Masked-
		PBA: BAR=4 offset=00000000
	Capabilities: [148 v1] Device Serial Number 00-00-00-00-00-00-00-00
	Capabilities: [158 v1] Latency Tolerance Reporting
	Capabilities: [160 v1] L1 PM Substates
		L1SubCap: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2+ ASPM_L1.1+ L1_PM_Substates+
			  PortCommonModeRestoreTime=10us PortTPowerOnTime=10us
			   T_CommonMode=0us LTR1.2_Threshold=0ns
		L1SubCtl2: T_PwrOn=10us
	Capabilities: [170 v1] Vendor Specific Information: ID=0002 Rev=4 Len=100 <?>
	Kernel driver in use: lan743x
0005:04:00.0 Ethernet controller: Microchip Technology / SMSC Device 7430 (rev 11)
	Latency: 0
	Region 0: Memory at 1f40200000 (64-bit, non-prefetchable) [size=8K]
	Region 2: Memory at 1f40202000 (64-bit, non-prefetchable) [size=256]
	Region 4: Memory at 1f40202100 (64-bit, non-prefetchable) [size=256]
0005:05:00.0 Ethernet controller: Microchip Technology / SMSC Device 7430 (rev 11)
	Latency: 0
	Region 0: Memory at 1f40400000 (64-bit, non-prefetchable) [size=8K]
	Region 2: Memory at 1f40402000 (64-bit, non-prefetchable) [size=256]
	Region 4: Memory at 1f40402100 (64-bit, non-prefetchable) [size=256]
0005:06:00.0 Ethernet controller: Microchip Technology / SMSC Device 7430 (rev 11)
	Latency: 0
	Region 0: Memory at 1f40600000 (64-bit, non-prefetchable) [size=8K]
	Region 2: Memory at 1f40602000 (64-bit, non-prefetchable) [size=256]
	Region 4: Memory at 1f40602100 (64-bit, non-prefetchable) [size=256]
sudo lspci -tv
nvidia@nvidia-desktop:~$ sudo lspci -tv
-+-[0005:00]---00.0-[01-ff]----00.0-[02-06]--+-01.0-[03]----00.0  Microchip Technology / SMSC Device 7430
 |                                           +-02.0-[04]----00.0  Microchip Technology / SMSC Device 7430
 |                                           +-03.0-[05]----00.0  Microchip Technology / SMSC Device 7430
 |                                           \-04.0-[06]----00.0  Microchip Technology / SMSC Device 7430
 +-[0001:00]---00.0-[01-ff]----00.0  Exar Corp. Device 0358
 \-[0000:00]-
nvidia@nvidia-desktop:~$ cat /proc/interrupts
            CPU0       CPU1       CPU2       CPU3
   2:          0          0          0          0     GICv2   29 Level     trusty
   3:      17952      14656      16196      14756     GICv2   30 Level     arch_timer
   6:      16469          0          0          0     GICv2  208 Level     hsp
   7:          0          0          0          0     GICv2  202 Level     arm-smmu global fault
   8:          0          0          0          0     GICv2  203 Level     arm-smmu global fault
   9:          0          0          0          0     GICv2  264 Level     arm-smmu global fault
  10:          0          0          0          0     GICv2  265 Level     arm-smmu global fault
  11:          0          0          0          0     GICv2  272 Level     arm-smmu global fault
  12:          0          0          0          0     GICv2  273 Level     arm-smmu global fault
  13:          0          0          0          0     GICv2  368 Level     tegra-p2u-intr
  14:          0          0          0          0     GICv2  369 Level     tegra-p2u-intr
  15:          0          0          0          0     GICv2  370 Level     tegra-p2u-intr
  16:          0          0          0          0     GICv2  371 Level     tegra-p2u-intr
  17:          0          0          0          0     GICv2  372 Level     tegra-p2u-intr
  18:          0          0          0          0     GICv2  373 Level     tegra-p2u-intr
  19:          0          0          0          0     GICv2  374 Level     tegra-p2u-intr
  20:          0          0          0          0     GICv2  375 Level     tegra-p2u-intr
  21:          0          0          0          0     GICv2  376 Level     tegra-p2u-intr
  22:          0          0          0          0     GICv2  377 Level     tegra-p2u-intr
  23:          0          0          0          0     GICv2  253 Level     tegra-p2u-intr
  24:          0          0          0          0     GICv2  254 Level     tegra-p2u-intr
  25:          0          0          0          0     GICv2  378 Level     tegra-p2u-intr
  26:          0          0          0          0     GICv2  379 Level     tegra-p2u-intr
  27:          0          0          0          0     GICv2  380 Level     tegra-p2u-intr
  28:          0          0          0          0     GICv2  381 Level     tegra-p2u-intr
  29:          0          0          0          0     GICv2  382 Level     tegra-p2u-intr
  30:          0          0          0          0     GICv2  383 Level     tegra-p2u-intr
  31:          0          0          0          0     GICv2  235 Level     tegra-p2u-intr
  32:          0          0          0          0     GICv2  252 Level     tegra-p2u-intr
  33:          0          0          0          0     GICv2  104 Level     tegra-pcie-intr
  34:          0          0          0          0     GICv2  105 Level     tegra-pcie-msi
  35:          1          0          0          0     GICv2   77 Level     tegra-pcie-intr, PCIe PME, aerdrv
  36:          0          0          0          0     GICv2   78 Level     tegra-pcie-msi
  37:          0          0          0          0     GICv2   81 Level     tegra-pcie-intr
  38:          0          0          0          0     GICv2   82 Level     tegra-pcie-msi
  39:          1          0          0          0     GICv2   85 Level     tegra-pcie-intr, PCIe PME, aerdrv
  40:          4          0          0          0     GICv2   86 Level     tegra-pcie-msi
  41:          2          0          0          0     GICv2  226 Level     ether_qos.common_irq
  43:          0          0          0          0     GICv2  222 Level     2490000.ether_qos.rx0
  44:          0          0          0          0     GICv2  218 Level     2490000.ether_qos.tx0
  51:         17          0          0          0     GICv2  144 Level     3100000.serial
  54:         61          0          0          0     GICv2  152 Level     combined_uart rx
  55:      18289          0          0          0     GICv2   97 Level     mmc0
  56:          0          0          0          0     GICv2   94 Level     mmc1
  57:          0          0          0          0     GICv2   76 Level     ufshcd
  58:          0          0          0          0     GICv2   68 Level     3210000.spi
  59:          0          0          0          0     GICv2   69 Level     c260000.spi
  60:         17          0          0          0     GICv2   57 Level     3160000.i2c
  61:          8          0          0          0     GICv2   58 Level     c240000.i2c
  62:          0          0          0          0     GICv2   59 Level     3180000.i2c
  63:          0          0          0          0     GICv2   60 Level     3190000.i2c
  64:          0          0          0          0     GICv2   62 Level     31b0000.i2c
  65:          0          0          0          0     GICv2   63 Level     31c0000.i2c
  66:          0          0          0          0     GICv2   64 Level     c250000.i2c
  67:          0          0          0          0     GICv2   65 Level     31e0000.i2c
  70:        360          0          0          0     GICv2  193 Level     snd_hda_tegra
  71:          0          0          0          0     GICv2   51 Level     bc00000.rtcpu
  72:        113          0          0          0     GICv2  242 Level     d230000.actmon
  73:       4505          0          0          0     GICv2  297 Level     host_syncpt
  74:          2          0          0          0     GICv2  295 Level     host_status
  75:          0          0          0          0     GICv2  238 Level     vic
  76:          0          0          0          0     GICv2  268 Level     nvdla0
  77:          0          0          0          0     GICv2  269 Level     nvdla1
  78:          0          0          0          0     GICv2  185 Level     15200000.nvdisplay
  83:          0          0          0          0     GICv2  194 Level     cec_irq
  85:          0          0          0          0     GICv2  266 Level     pva-isr
  86:          0          0          0          0     GICv2  267 Level     pva-isr
  95:          0          0          0          0     GICv2  397 Level     carmel-pmu
  96:          0          0          0          0     GICv2  169 Level     tegra-oc-event
  97:          0          0          0          0     GICv2  270 Level     noc_nonsecure_irq
  98:          0          0          0          0     GICv2  271 Level     noc_secure_irq
  99:          0          0          0          0        PM   42 Level     tegra_rtc
 100:          0          0          0          0     GICv2  255 Level     mc_status
 102:          0          0          0          0     GICv2  165 Level     c150000.tegra-hsp
 113:         29          0          0          0     GICv2  214 Level     b950000.tegra-hsp, b950000.tegra-hsp, b950000.tegra-hsp
 117:          0          0          0          0     GICv2  315 Level     3ad0000.se_elp
 119:          0          0          0          0     GICv2  108 Level     gpcdma.0
 120:          0          0          0          0     GICv2  109 Level     gpcdma.1
 121:          0          0          0          0     GICv2  110 Level     gpcdma.2
 122:          0          0          0          0     GICv2  111 Level     gpcdma.3
 123:          0          0          0          0     GICv2  112 Level     gpcdma.4
 124:          0          0          0          0     GICv2  113 Level     gpcdma.5
 125:          0          0          0          0     GICv2  114 Level     gpcdma.6
 126:          0          0          0          0     GICv2  115 Level     gpcdma.7
 127:          0          0          0          0     GICv2  116 Level     gpcdma.8
 128:          0          0          0          0     GICv2  117 Level     gpcdma.9
 129:          0          0          0          0     GICv2  118 Level     gpcdma.10
 130:          0          0          0          0     GICv2  119 Level     gpcdma.11
 131:          0          0          0          0     GICv2  120 Level     gpcdma.12
 132:          0          0          0          0     GICv2  121 Level     gpcdma.13
 133:          0          0          0          0     GICv2  122 Level     gpcdma.14
 134:          0          0          0          0     GICv2  123 Level     gpcdma.15
 135:          0          0          0          0     GICv2  124 Level     gpcdma.16
 136:          0          0          0          0     GICv2  125 Level     gpcdma.17
 137:          0          0          0          0     GICv2  126 Level     gpcdma.18
 138:          0          0          0          0     GICv2  127 Level     gpcdma.19
 139:          0          0          0          0     GICv2  128 Level     gpcdma.20
 140:          0          0          0          0     GICv2  129 Level     gpcdma.21
 141:          0          0          0          0     GICv2  130 Level     gpcdma.22
 142:          0          0          0          0     GICv2  131 Level     gpcdma.23
 143:          0          0          0          0     GICv2  132 Level     gpcdma.24
 144:          0          0          0          0     GICv2  133 Level     gpcdma.25
 145:          0          0          0          0     GICv2  134 Level     gpcdma.26
 146:          0          0          0          0     GICv2  135 Level     gpcdma.27
 147:          0          0          0          0     GICv2  136 Level     gpcdma.28
 148:          0          0          0          0     GICv2  137 Level     gpcdma.29
 149:          0          0          0          0     GICv2  138 Level     gpcdma.30
 247:          0          0          0          0  tegra-gpio   48 Edge      force-recovery
 251:          0          0          0          0  tegra-gpio   52 Level     phy_interrupt
 254:          0          0          0          0  tegra-gpio   55 Edge      3400000.sdhci cd
 257:          0          0          0          0  tegra-gpio   58 Level     tmp451
 297:          0          0          0          0  tegra-gpio   98 Edge      15200000.nvdisplay
 391:          0          0          0          0  tegra-gpio  192 Edge      bluetooth hostwake
 459:          0          0          0          0  tegra-gpio-aon   32 Edge      ufs_cd_gpio
 463:          0          0          0          0  tegra-gpio-aon   36 Edge      power-key
 467:          7          0          0          0     GICv2   39 Level     30c0000.watchdog
 472:          0          0          0          0        PM  195 Level     xhci-hcd:usb1
 473:          1          0          0          0        PM  196 Level     3610000.xhci
 474:          0          0          0          0        PM  199 Level     3610000.xhci
 475:        288          0          0          0     GICv2  102 Level     gk20a_stall
 476:          0          0          0          0     GICv2  103 Level     gk20a_nonstall
 477:          0          0          0          0     GICv2  424 Level     ras-fhi
 478:          0          0          0          0     GICv2  425 Level     ras-fhi
 479:          0          0          0          0     GICv2  426 Level     ras-fhi
 480:          0          0          0          0     GICv2  427 Level     ras-fhi
 481:          0          0          0          0     GICv2  428 Level     ras-fhi
 482:          0          0          0          0     GICv2  429 Level     ras-fhi
 483:          0          0          0          0     GICv2  430 Level     ras-fhi
 484:          0          0          0          0     GICv2  431 Level     ras-fhi
 485:          0          0          0          0     GICv2  262 Level     noc_nonsecure_irq
 486:          0          0          0          0     GICv2  263 Level     noc_secure_irq
 487:          0          0          0          0     GICv2  292 Level     noc_nonsecure_irq
 488:          0          0          0          0     GICv2  204 Level     noc_secure_irq
 489:          0          0          0          0     GICv2  294 Level     noc_nonsecure_irq
 490:          0          0          0          0     GICv2  206 Level     noc_secure_irq
 491:          0          0          0          0     GICv2  291 Level     noc_nonsecure_irq
 492:          0          0          0          0     GICv2  207 Level     noc_secure_irq
 493:          0          0          0          0     GICv2  293 Level     noc_nonsecure_irq
 494:          0          0          0          0     GICv2  205 Level     noc_secure_irq
 496:          0          0          0          0        PM  241 Edge      max77620-top
 500:          0          0          0          0  max77620-top    3 Edge      max77620-gpio
 501:          0          0          0          0  max77620-top    4 Edge      max77686-rtc
 505:          0          0          0          0  max77620-top    8 Edge      max77620-thermal
 506:          0          0          0          0  max77620-top    9 Edge      max77620-thermal
 561:          0          0          0          0  max77686-rtc    1 Edge      rtc-alarm1
 823:          1          0          0          0   PCI-MSI    4 Edge      lan743x
 824:          0          0          0          0   PCI-MSI    5 Edge      lan743x
 825:          0          0          0          0   PCI-MSI    6 Edge      lan743x
 826:          0          0          0          0   PCI-MSI    7 Edge      lan743x
 827:          0          0          0          0   PCI-MSI    8 Edge      lan743x
 828:          0          0          0          0   PCI-MSI    9 Edge      lan743x
 829:          1          0          0          0   PCI-MSI   10 Edge      lan743x
 830:          0          0          0          0   PCI-MSI   11 Edge      lan743x
 831:          0          0          0          0   PCI-MSI   12 Edge      lan743x
 832:          0          0          0          0   PCI-MSI   13 Edge      lan743x
 833:          0          0          0          0   PCI-MSI   14 Edge      lan743x
 834:          0          0          0          0   PCI-MSI   15 Edge      lan743x
 835:          1          0          0          0   PCI-MSI   16 Edge      lan743x
 836:          0          0          0          0   PCI-MSI   17 Edge      lan743x
 837:          0          0          0          0   PCI-MSI   18 Edge      lan743x
 838:          0          0          0          0   PCI-MSI   19 Edge      lan743x
 839:          0          0          0          0   PCI-MSI   20 Edge      lan743x
 840:          0          0          0          0   PCI-MSI   21 Edge      lan743x
 841:          1          0          0          0   PCI-MSI   22 Edge      lan743x
 842:          0          0          0          0   PCI-MSI   23 Edge      lan743x
 843:          0          0          0          0   PCI-MSI   24 Edge      lan743x
 844:          0          0          0          0   PCI-MSI   25 Edge      lan743x
 845:          0          0          0          0   PCI-MSI   26 Edge      lan743x
 846:          0          0          0          0   PCI-MSI   27 Edge      lan743x
1075:          0          0          0          0        PM  211 Level     sw-wake
IPI0:      15290      25905      16797      22841       Rescheduling interrupts
IPI1:       1819       2167       8153       5818       Function call interrupts
IPI2:          0          0          0          0       CPU stop interrupts
IPI3:          0          0          0          0       Timer broadcast interrupts
IPI4:       1365        811        442        500       IRQ work interrupts
IPI5:          0          0          0          0       CPU wake-up interrupts
 Err:          0
extra ("cat /etc/nv_tegra_release ", “ifconfig” and “ifconfig -a”)
nvidia@nvidia-desktop:~$ cat /etc/nv_tegra_release
# R32 (release), REVISION: 7.3, GCID: 31982016, BOARD: t186ref, EABI: aarch64, DATE: Tue Nov 22 17:32:54 UTC 2022
nvidia@nvidia-desktop:~$ ifconfig
docker0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        inet 172.17.0.1  netmask 255.255.0.0  broadcast 172.17.255.255
        ether 02:42:c8:ea:13:ac  txqueuelen 0  (Ethernet)
        RX packets 0  bytes 0 (0.0 B)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 0  bytes 0 (0.0 B)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
eth0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        ether 00:04:4b:cb:ed:9b  txqueuelen 1000  (Ethernet)
        device interrupt 41
eth1: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        ether 86:61:b6:b0:7c:f1  txqueuelen 1000  (Ethernet)
eth2: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        ether 8e:82:75:68:d7:7a  txqueuelen 1000  (Ethernet)
eth3: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        ether 0a:b6:d4:e7:c8:47  txqueuelen 1000  (Ethernet)
eth4: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        ether fa:a6:6d:0e:6d:b0  txqueuelen 1000  (Ethernet)
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1  (Local Loopback)
        RX packets 1044  bytes 66032 (66.0 KB)
        TX packets 1044  bytes 66032 (66.0 KB)
nvidia@nvidia-desktop:~$ ifconfig -a
dummy0: flags=130<BROADCAST,NOARP>  mtu 1500
        ether f6:c5:96:29:cb:c9  txqueuelen 1000  (Ethernet)
        device interrupt 41
        RX packets 1124  bytes 70904 (70.9 KB)
        TX packets 1124  bytes 70904 (70.9 KB)
JetPack-5.0.2 device-tree:
502.dts (372.1 KB)
JetPack-5.0.2 dmesg:
jp502_dmesg.txt (72.8 KB)
sudo lspci -vvv
	Latency: 0
	Interrupt: pin A routed to IRQ 26
	I/O behind bridge: 0000f000-00000fff [disabled]
	Memory behind bridge: 40000000-400fffff [size=1M]
	Prefetchable memory behind bridge: 00000000fff00000-00000000000fffff [disabled]
	BridgeCtl: Parity- SERR+ NoISA- VGA- VGA16- MAbort- >Reset- FastB2B-
			ExtTag- RBE+
		DevCtl:	CorrErr+ NonFatalErr+ FatalErr+ UnsupReq+
		DevSta:	CorrErr- NonFatalErr- FatalErr- UnsupReq- AuxPwr+ TransPend-
		LnkCap:	Port #0, Speed 16GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <1us, L1 <64us
		LnkSta:	Speed 2.5GT/s (downgraded), Width x1 (ok)
			TrErr- Train- SlotClk+ DLActive+ BWMgmt- ABWMgmt-
		DevCap2: Completion Timeout: Range ABCD, TimeoutDis+, NROPrPrP+, LTR+
			 10BitTagComp+, 10BitTagReq-, OBFF Not Supported, ExtFmt-, EETLPPrefix-
			 EmergencyPowerReduction Not Supported, EmergencyPowerReductionInit-
			 FRS-, LN System CLS Not Supported, TPHComp-, ExtTPHComp-, ARIFwd-
			 AtomicOpsCap: Routing- 32bit- 64bit- 128bitCAS-
			 AtomicOpsCtl: ReqEn- EgressBlck-
		LnkCtl2: Target Link Speed: 16GT/s, EnterCompliance- SpeedDis-
		CESta:	RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr-
		CEMsk:	RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr+
		AERCap:	First Error Pointer: 00, ECRCGenCap+ ECRCGenEn- ECRCChkCap+ ECRCChkEn-
			MultHdrRecCap+ MultHdrRecEn- TLPPfxPres- HdrLogCap-
		HeaderLog: 00000000 00000000 00000000 00000000
		RootCmd: CERptEn+ NFERptEn+ FERptEn+
		RootSta: CERcvd- MultCERcvd- UERcvd- MultUERcvd-
			 FirstFatal- NonFatalMsg- FatalMsg- IntMsg 0
		ErrorSrc: ERR_COR: 0000 ERR_FATAL/NONFATAL: 0000
	Capabilities: [148 v1] Secondary PCI Express
		LnkCtl3: LnkEquIntrruptEn-, PerformEqu-
		LaneErrStat: 0
	Capabilities: [158 v1] Physical Layer 16.0 GT/s <?>
	Capabilities: [17c v1] Lane Margining at the Receiver <?>
			   T_CommonMode=10us
	Capabilities: [2d8 v1] Data Link Feature <?>
		DevCtl:	CorrErr- NonFatalErr- FatalErr- UnsupReq-
		DevSta:	CorrErr- NonFatalErr- FatalErr- UnsupReq- AuxPwr- TransPend-
		LnkSta:	Speed 2.5GT/s (ok), Width x1 (ok)
		DevCap2: Completion Timeout: Not Supported, TimeoutDis-, NROPrPrP-, LTR-
			 10BitTagComp-, 10BitTagReq-, OBFF Not Supported, ExtFmt-, EETLPPrefix-
			 FRS-, TPHComp-, ExtTPHComp-
			 AtomicOpsCap: 32bit- 64bit- 128bitCAS-
		Status:	InProgress-
	Latency: 0
	Interrupt: pin A routed to IRQ 30
	I/O behind bridge: 00000000-00003fff [size=16K]
	Memory behind bridge: 40000000-407fffff [size=8M]
	Prefetchable memory behind bridge: 0000001c00000000-0000001c007fffff [size=8M]
			ExtTag- RBE+
		LnkCap:	Port #0, Speed 16GT/s, Width x8, ASPM not supported
		LnkSta:	Speed 5GT/s (downgraded), Width x4 (downgraded)
			TrErr- Train- SlotClk+ DLActive+ BWMgmt- ABWMgmt+
		LaneErrStat: 0
	Capabilities: [168 v1] Physical Layer 16.0 GT/s <?>
	Capabilities: [190 v1] Lane Margining at the Receiver <?>
			   T_CommonMode=10us
	Capabilities: [308 v1] Data Link Feature <?>
	Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
	Latency: 0
	I/O behind bridge: 3a100000-3a103fff [size=16K]
[  464.120326] pci 0005:01:00.0: invalid large VPD tag 7f at offset 0
		Not readable
		DevSta:	CorrErr+ NonFatalErr- FatalErr- UnsupReq+ AuxPwr+ TransPend-
		LnkCtl:	ASPM Disabled; Disabled- CommClk-
		LnkSta:	Speed 5GT/s (ok), Width x4 (ok)
		DevCap2: Completion Timeout: Not Supported, TimeoutDis-, NROPrPrP-, LTR+
			 FRS-
			 AtomicOpsCtl: EgressBlck-
		CESta:	RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr+
			MultHdrRecCap- MultHdrRecEn- TLPPfxPres- HdrLogCap-
		Status:	InProgress-
		L1SubCtl2:
	Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
	Latency: 0
	Interrupt: pin A routed to IRQ 270
	I/O behind bridge: 3a100000-3a100fff [size=4K]
	Memory behind bridge: 40000000-401fffff [size=2M]
	Prefetchable memory behind bridge: 0000001c00000000-0000001c001fffff [size=2M]
		Address: 00000000fffff1c8  Data: 0000
			ExtTag- RBE+
			 FRS-, ARIFwd-
		Status:	InProgress-
		ACSCtl:	SrcValid+ TransBlk- ReqRedir+ CmpltRedir+ UpstreamFwd+ EgressCtrl- DirectTrans-
		L1SubCtl2:
	Latency: 0
	Interrupt: pin A routed to IRQ 271
	I/O behind bridge: 3a101000-3a101fff [size=4K]
	Memory behind bridge: 40200000-403fffff [size=2M]
	Prefetchable memory behind bridge: 0000001c00200000-0000001c003fffff [size=2M]
		Address: 00000000fffff1c8  Data: 0001
			ExtTag- RBE+
			 FRS-, ARIFwd-
		Status:	InProgress-
		L1SubCtl2:
	Latency: 0
	Interrupt: pin A routed to IRQ 272
	I/O behind bridge: 3a102000-3a102fff [size=4K]
	Memory behind bridge: 40400000-405fffff [size=2M]
	Prefetchable memory behind bridge: 0000001c00400000-0000001c005fffff [size=2M]
		Address: 00000000fffff1c8  Data: 0002
			ExtTag- RBE+
			 FRS-, ARIFwd-
		Status:	InProgress-
		L1SubCtl2:
	Latency: 0
	Interrupt: pin A routed to IRQ 273
	I/O behind bridge: 3a103000-3a103fff [size=4K]
	Memory behind bridge: 40600000-407fffff [size=2M]
	Prefetchable memory behind bridge: 0000001c00600000-0000001c007fffff [size=2M]
		Address: 00000000fffff1c8  Data: 0003
			ExtTag- RBE+
			 FRS-, ARIFwd-
		Status:	InProgress-
		L1SubCtl2:
	Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
	Latency: 0
		DevCap2: Completion Timeout: Range ABCD, TimeoutDis+, NROPrPrP-, LTR+
			 10BitTagComp-, 10BitTagReq-, OBFF Via message/WAKE#, ExtFmt-, EETLPPrefix-
			 FRS+, TPHComp-, ExtTPHComp-
	Kernel modules: lan743x
	Latency: 0
	Latency: 0
	Latency: 0
sudo lspci -tv
 \-[0000:00]-
           CPU0       CPU1       CPU2       CPU3
  9:          0          0          0          0     GICv2  25 Level     vgic
 11:          0          0          0          0     GICv2  30 Level     kvm guest ptimer
 12:          0          0          0          0     GICv2  27 Level     kvm guest vtimer
 13:      14914      15440      21412      24516     GICv2  26 Level     arch_timer
 14:          0          0          0          0     GICv2 262 Level     2300000.cbb-noc
 15:          0          0          0          0     GICv2 263 Level     2300000.cbb-noc
 16:          0          0          0          0     GICv2 292 Level     c600000.aon-noc
 17:          0          0          0          0     GICv2 204 Level     c600000.aon-noc
 18:          0          0          0          0     GICv2 294 Level     d600000.bpmp-noc
 19:          0          0          0          0     GICv2 206 Level     d600000.bpmp-noc
 20:          0          0          0          0     GICv2 291 Level     be00000.rce-noc
 21:          0          0          0          0     GICv2 207 Level     be00000.rce-noc
 22:          0          0          0          0     GICv2 293 Level     b600000.sce-noc
 23:          0          0          0          0     GICv2 205 Level     b600000.sce-noc
 24:          0          0          0          0     GICv2 104 Level     tegra-pcie-intr
 26:          1          0          0          0     GICv2  77 Level     tegra-pcie-intr, PCIe PME, aerdrv
 28:          0          0          0          0     GICv2  81 Level     tegra-pcie-intr
 30:          0          0          0          0     GICv2  85 Level     tegra-pcie-intr, PCIe PME, aerdrv
 32:          0          0          0          0     GICv2 226 Level     eth0.common_irq
 33:          0          0          0          0     GICv2 218 Level     eth0.tx0
 34:          0          0          0          0     GICv2 222 Level     eth0.rx0
 35:          6          0          0          0     GICv2 144 Level     3100000.serial
 38:         47          0          0          0     GICv2 152 Level     3c00000.tegra-hsp
 39:      12205          0          0          0     GICv2  97 Level     mmc0
 40:          0          0          0          0     GICv2  94 Level     mmc1
 41:          0          0          0          0     GICv2  68 Level     3210000.spi
 42:         34          0          0          0     GICv2  57 Level     3160000.i2c
 43:         93          0          0          0     GICv2  58 Level     c240000.i2c
 44:          0          0          0          0     GICv2  59 Level     3180000.i2c
 45:          0          0          0          0     GICv2  60 Level     3190000.i2c
 46:          0          0          0          0     GICv2  62 Level     31b0000.i2c
 47:          0          0          0          0     GICv2  63 Level     31c0000.i2c
 48:          0          0          0          0     GICv2  64 Level     c250000.i2c
 49:          0          0          0          0     GICv2  65 Level     31e0000.i2c
 52:       4101          0          0          0     GICv2 193 Level     snd_hda_tegra
 53:          0          0          0          0     GICv2  51 Level     bc00000.rtcpu
 54:        114          0          0          0     GICv2 242 Level     d230000.actmon
 55:        707          0          0          0     GICv2 297 Level     host_syncpt
 56:          1          0          0          0     GICv2 295 Level     host_status
 57:          0          0          0          0     GICv2 238 Level     vic
 58:          0          0          0          0     GICv2 268 Level     nvdla0
 59:          0          0          0          0     GICv2 269 Level     nvdla1
 60:          0          0          0          0     GICv2 185 Level     15200000.display
 61:          0          0          0          0     GICv2 275 Level     15200000.display
 66:          0          0          0          0     GICv2 194 Level     cec_irq
 67:          0          0          0          0     GICv2 266 Level     pva-isr
 68:          0          0          0          0     GICv2 267 Level     pva-isr
 69:          0          0          0          0     GICv2 416 Level     arm-pmu
 70:          0          0          0          0     GICv2 417 Level     arm-pmu
 71:          0          0          0          0     GICv2 418 Level     arm-pmu
 72:          0          0          0          0     GICv2 419 Level     arm-pmu
 73:          0          0          0          0     GICv2 420 Level     arm-pmu
 74:          0          0          0          0     GICv2 421 Level     arm-pmu
 75:          0          0          0          0     GICv2 422 Level     arm-pmu
 76:          0          0          0          0     GICv2 423 Level     arm-pmu
 78:          0          0          0          0     GICv2 255 Level     mc_status
 80:          0          0          0          0     GICv2 272 Level     arm-smmu global fault, arm-smmu-context-fault, arm-smmu-context-fault
 81:          0          0          0          0     GICv2 202 Level     arm-smmu global fault, arm-smmu-context-fault, arm-smmu-context-fault, arm-smmu-context-fault, arm-smmu-context-fault, arm-smmu-context-fault, arm-smmu-context-fault, arm-smmu-context-fault, arm-smmu-context-fault, arm-smmu-context-fault, arm-smmu-context-fault, arm-smmu-context-fault, arm-smmu-context-fault, arm-smmu-context-fault, arm-smmu-context-fault, arm-smmu-context-fault, arm-smmu-context-fault, arm-smmu-context-fault, arm-smmu-context-fault, arm-smmu-context-fault, arm-smmu-context-fault, arm-smmu-context-fault, arm-smmu-context-fault, arm-smmu-context-fault, arm-smmu-context-fault, arm-smmu-context-fault, arm-smmu-context-fault, arm-smmu-context-fault, arm-smmu-context-fault, arm-smmu-context-fault, arm-smmu-context-fault, arm-smmu-context-fault, arm-smmu-context-fault, arm-smmu-context-fault, arm-smmu-context-fault
 82:          0          0          0          0     GICv2 264 Level     arm-smmu global fault, arm-smmu-context-fault
 85:       8915          0          0          0     GICv2 165 Level     c150000.tegra-hsp
 89:      21405          0          0          0     GICv2 208 Level     3c00000.tegra-hsp
 97:         79          0          0          0     GICv2 214 Level     b950000.tegra-hsp
102:          0          0          0          0     GICv2 315 Level     3ad0000.se_elp
104:          0          0          0          0     GICv2 108 Level     gpcdma.0
105:          0          0          0          0     GICv2 109 Level     gpcdma.1
106:          0          0          0          0     GICv2 110 Level     gpcdma.2
107:          0          0          0          0     GICv2 111 Level     gpcdma.3
108:          0          0          0          0     GICv2 112 Level     gpcdma.4
109:          0          0          0          0     GICv2 113 Level     gpcdma.5
110:          0          0          0          0     GICv2 114 Level     gpcdma.6
111:          0          0          0          0     GICv2 115 Level     gpcdma.7
112:          0          0          0          0     GICv2 116 Level     gpcdma.8
113:          0          0          0          0     GICv2 117 Level     gpcdma.9
114:          0          0          0          0     GICv2 118 Level     gpcdma.10
115:          0          0          0          0     GICv2 119 Level     gpcdma.11
116:          0          0          0          0     GICv2 120 Level     gpcdma.12
117:          0          0          0          0     GICv2 121 Level     gpcdma.13
118:          0          0          0          0     GICv2 122 Level     gpcdma.14
119:          0          0          0          0     GICv2 123 Level     gpcdma.15
120:          0          0          0          0     GICv2 124 Level     gpcdma.16
121:          0          0          0          0     GICv2 125 Level     gpcdma.17
122:          1          0          0          0     GICv2 126 Level     gpcdma.18
123:          0          0          0          0     GICv2 127 Level     gpcdma.19
188:          0          0          0          0     GICv2  45 Level     c1e0000.gte
189:         19          0          0          0     GICv2  39 Level     30c0000.watchdog
193:          0          0          0          0     GICv2 198 Level     3550000.xudc
194:          0          0          0          0     GICv2 195 Level     xhci-hcd:usb1
195:          1          0          0          0     GICv2 196 Level     3610000.xhci
196:        133          0          0          0     GICv2 102 Level     gk20a_stall
197:          0          0          0          0     GICv2 103 Level     gk20a_nonstall
213:          0          0          0          0  c360000.pmc  82 Level     3610000.xhci
214:          0          0          0          0  c360000.pmc  73 Level     tegra_rtc
215:          0          0          0          0     GICv2 241 Level     max77620-top
216:          0          0          0          0  max77620-top   3 Edge      max77620-gpio
217:          0          0          0          0  max77620-top   4 Edge      max77686-rtc
218:          0          0          0          0  max77686-rtc   1 Edge      rtc-alarm1
220:          0          0          0          0  max77620-top   8 Edge      max77620-thermal
221:          0          0          0          0  max77620-top   9 Edge      max77620-thermal
223:          3          0          0          0  agic-controller  73 Edge
224:          2          0          0          0  agic-controller  64 Edge
226:          1          0          0          0  agic-controller  94 Edge
268:          0          0          0          0      gpio  43 Edge      3400000.sdhci cd
269:          0          0          0          0      gpio  77 Edge      15200000.display
274:          0          0          0          0  c360000.pmc  83 Edge      sw-wake
275:          0          0          0          0      gpio  36 Edge      force-recovery
276:          0          0          0          0      gpio  27 Edge      power-key
277:          0          0          0          0      gpio 149 Edge      bluetooth hostwake
278:          0          0          0          0      gpio  46 Level     tmp451
280:          0          0          0          0      gpio  40 Level     2490000.ethernet:00
IPI0:      3502      11370       4052       3980       Rescheduling interrupts
IPI1:      7032       6546      15224      10092       Function call interrupts
IPI3:         0          0          0          0       CPU stop (for crash dump) interrupts
IPI4:         0          0          0          0       Timer broadcast interrupts
IPI5:       342        172        260        244       IRQ work interrupts
IPI6:         0          0          0          0       CPU wake-up interrupts
Err:          0
# R35 (release), REVISION: 1.0, GCID: 31250864, BOARD: t186ref, EABI: aarch64, DATE: Thu Aug 11 03:40:29 UTC 2022
        ether 48:b0:2d:18:4f:7a  txqueuelen 1000  (Ethernet)
        loop  txqueuelen 1000  (Local Loopback)
        RX packets 2870  bytes 178214 (178.2 KB)
        TX packets 2870  bytes 178214 (178.2 KB)
rndis0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        ether 1a:43:cd:c8:1e:85  txqueuelen 1000  (Ethernet)
usb0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        ether 1a:43:cd:c8:1e:87  txqueuelen 1000  (Ethernet)
        ether 86:eb:44:27:cd:14  txqueuelen 1000  (Ethernet)
eth1: flags=4098<BROADCAST,MULTICAST>  mtu 1500
        ether c6:81:3c:f1:4e:09  txqueuelen 1000  (Ethernet)
eth2: flags=4098<BROADCAST,MULTICAST>  mtu 1500
        ether 06:13:6f:23:3a:e7  txqueuelen 1000  (Ethernet)
eth3: flags=4098<BROADCAST,MULTICAST>  mtu 1500
        ether aa:00:b0:67:6b:a2  txqueuelen 1000  (Ethernet)
eth4: flags=4098<BROADCAST,MULTICAST>  mtu 1500
        ether 56:6c:3e:91:0c:50  txqueuelen 1000  (Ethernet)
l4tbr0: flags=4098<BROADCAST,MULTICAST>  mtu 1500
sorry for late reply.
It looks like MSI interrupt allocation didn’t happen.
please add prints in PCIe MSI alloc API(Ex: pci_alloc_irq_vectors()).
Also, get the logs with below patch.
diff --git a/drivers/pci/controller/dwc/pcie-designware-host.c b/drivers/pci/controller/dwc/pcie-designware-host.c
index 08b4fdca68e1..ab26164abba4 100644
--- a/drivers/pci/controller/dwc/pcie-designware-host.c
+++ b/drivers/pci/controller/dwc/pcie-designware-host.c
@@ -196,11 +196,14 @@ static int dw_pcie_irq_domain_alloc(struct irq_domain *domain,
        bit = bitmap_find_free_region(pp->msi_irq_in_use, pp->num_vectors,
                                      order_base_2(nr_irqs));
+       pr_err("-----> %s nr_irq: %d num_vec: %d\n", __func__, nr_irqs, pp->num_vectors);
        raw_spin_unlock_irqrestore(&pp->lock, flags);
-       if (bit < 0)
+       if (bit < 0) {
+               pr_err("-----> %s -ENOSPC nr_irq: %d\n", __func__, nr_irqs);
                return -ENOSPC;
        for (i = 0; i < nr_irqs; i++)
                irq_domain_set_info(domain, virq + i, bit + i,
@@ -363,6 +366,7 @@ int dw_pcie_host_init(struct pcie_port *pp)
        if (pci->link_gen < 1)
                pci->link_gen = of_pci_get_max_link_speed(np);
+       dev_err(pci->dev, "%s: msi_enabled: %d\n", __func__, pci_msi_enabled());
        if (pci_msi_enabled()) {
                 * If a specific SoC driver needs to change the
@@ -383,6 +387,7 @@ int dw_pcie_host_init(struct pcie_port *pp)
                if (!pp->ops->msi_host_init) {
+                       dev_err(pci->dev, "%s !msi_host_init\n", __func__);
                        pp->msi_irq_chip = &dw_pci_msi_bottom_irq_chip;
                        ret = dw_pcie_allocate_domains(pp);
@@ -412,6 +417,7 @@ int dw_pcie_host_init(struct pcie_port *pp)
                                goto err_free_msi;
                } else {
+                       dev_err(pci->dev, "####%s msi_host_init\n", __func__);
                        ret = pp->ops->msi_host_init(pp);
                        if (ret < 0)
                                return ret;
diff --git a/drivers/pci/controller/dwc/pcie-tegra194.c b/drivers/pci/controller/dwc/pcie-tegra194.c
index e26ed0710868..8413ab4b26eb 100644
--- a/drivers/pci/controller/dwc/pcie-tegra194.c
+++ b/drivers/pci/controller/dwc/pcie-tegra194.c
@@ -2629,6 +2629,7 @@ static int tegra_pcie_dw_link_up(struct dw_pcie *pci)
static void tegra_pcie_set_msi_vec_num(struct pcie_port *pp)
        pp->num_vectors = MAX_MSI_IRQS;
+       pr_err("------->%s vec: %d\n", __func__, pp->num_vectors);
static int tegra_pcie_dw_start_link(struct dw_pcie *pci)
Hi Wayne,
Thanks for your help. We solved the issue internally with adding some commands to pcie_quirks file.
Could we know what was added by you and which device requires that quirk?
