Question about the PCIe adapter speed
We want to use PCIe ethernet adapters to send camera pictures from a xavier to another one. Now we have connected two xaviers through Mellanox connectx-5 adapters. The adapter is PCIex16 with 100Gb/s speed, and the xavier has PCIex16 slot with PCIex8 bandwidth we think. So ideally, we are supposed to get close to 50Gb/s. But now, we can only achieve to about 19Gb by the tool ‘iperf’. We have made several tries on different configurations, but none of them can make significant improvements. Attached pictures are some detailed information about our setups. Suggestions on how to improve the speed are welcome!
wps9
Jetson xavier kernel version
wps10
Mellanox driver configure
wps11
wps12
Could you please attach the output of ‘sudo lspci -vvvv’ ?
The output of command “lspci -vvvv” is as below
0000:00:00.0 PCI bridge: NVIDIA Corporation Device 1ad0 (rev a1) (prog-if 00 [Normal decode])
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- SERR- <PERR- INTx-
Latency: 0
Interrupt: pin A routed to IRQ 33
Bus: primary=00, secondary=01, subordinate=ff, sec-latency=0
I/O behind bridge: 0000f000-00000fff
Memory behind bridge: 40000000-400fffff
Prefetchable memory behind bridge: 00000000fff00000-00000000000fffff
Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- Reset- FastB2B-
PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
Capabilities:
Kernel driver in use: pcieport
0000:01:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller SM981/PM981 (prog-if 02 [NVM Express])
Subsystem: Samsung Electronics Co Ltd Device a801
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Latency: 0
Region 0: Memory at 1b40000000 (64-bit, non-prefetchable) [size=16K]
Capabilities:
Kernel driver in use: nvme
0001:00:00.0 PCI bridge: NVIDIA Corporation Device 1ad2 (rev a1) (prog-if 00 [Normal decode])
Latency: 0
Interrupt: pin A routed to IRQ 35
I/O behind bridge: 00000000-00000fff
Capabilities:
0001:01:00.0 SATA controller: Marvell Technology Group Ltd. Device 9171 (rev 13) (prog-if 01 [AHCI 1.0])
Subsystem: Marvell Technology Group Ltd. Device 9171
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Latency: 0
Interrupt: pin A routed to IRQ 820
Region 0: I/O ports at 100010 [size=8]
Region 1: I/O ports at 100020 [size=4]
Region 2: I/O ports at 100018 [size=8]
Region 3: I/O ports at 100024 [size=4]
Region 4: I/O ports at 100000 [size=16]
Region 5: Memory at 1230010000 (32-bit, non-prefetchable) [size=512]
Expansion ROM at 1230000000 [disabled] [size=64K]
Capabilities:
Kernel driver in use: ahci
0005:00:00.0 PCI bridge: NVIDIA Corporation Device 1ad0 (rev a1) (prog-if 00 [Normal decode])
Latency: 0
Interrupt: pin A routed to IRQ 39
Memory behind bridge: 40000000-401fffff
Prefetchable memory behind bridge: 0000001c00000000-0000001c03ffffff
Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort+ <SERR- Reset- FastB2B-
Capabilities:
0005:01:00.0 Ethernet controller: Mellanox Technologies MT28800 Family [ConnectX-5 Ex]
Subsystem: Mellanox Technologies MT28800 Family [ConnectX-5 Ex]
Latency: 0
Region 0: Memory at 1c00000000 (64-bit, prefetchable) [size=32M]
[virtual] Expansion ROM at 1f40000000 [disabled] [size=1M]
Capabilities:
Kernel driver in use: mlx5_core
Kernel modules: mlx5_core
0005:01:00.1 Ethernet controller: Mellanox Technologies MT28800 Family [ConnectX-5 Ex]
Latency: 0
Interrupt: pin B routed to IRQ 39
Region 0: Memory at 1c02000000 (64-bit, prefetchable) [size=32M]
[virtual] Expansion ROM at 1f40100000 [disabled] [size=1M]
Capabilities:
This is not the actual output of “sudo lspci -vvv” (a fourth “-v” doesn’t actually do anything). This lacks a lot of information as is. Make sure you use “sudo” for the more verbose lspci since only root can actually query in that much detail. Once you get that there will be lines in the log with transfer speeds (search for “GT/s”). Some of those lines are capabilities, other of those lines are actual speeds.
thanks for your reply . I have runned the command “sudo lspci -vvvv” as you said. the output is as below . all the information about “GT/S” are bolded.
jetson@jetson-desktop:~$ sudo lspci -vvv
[sudo] password for jetson:
Latency: 0
Capabilities: [40] Power Management version 3
Flags: PMEClk- DSI- D1- D2- AuxCurrent=375mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [50] MSI: Enable- Count=1/1 Maskable+ 64bit+
Address: 0000000000000000 Data: 0000
Masking: 00000000 Pending: 00000000
Capabilities: [70] Express (v2) Root Port (Slot-), MSI 00
DevCap: MaxPayload 256 bytes, PhantFunc 0
ExtTag- RBE+
DevCtl: Report errors: Correctable+ Non-Fatal+ Fatal+ Unsupported+
RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+
MaxPayload 256 bytes, MaxReadReq 512 bytes
DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr+ TransPend-
LnkCap: Port #0, Speed 16GT/s, Width x8, ASPM not supported, Exit Latency L0s <1us, L1 <64us
ClockPM- Surprise+ LLActRep+ BwNot+ ASPMOptComp+
LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk+
ExtSynch- ClockPM- AutWidDis- BWInt+ AutBWInt-
LnkSta: Speed 8GT/s, Width x4, TrErr- Train- SlotClk+ DLActive+ BWMgmt+ ABWMgmt+
RootCtl: ErrCorrectable- ErrNon-Fatal- ErrFatal- PMEIntEna+ CRSVisible+
RootCap: CRSVisible+
RootSta: PME ReqID 0000, PMEStatus- PMEPending-
DevCap2: Completion Timeout: Range ABCD, TimeoutDis+, LTR+, OBFF Not Supported ARIFwd-
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR+, OBFF Disabled ARIFwd-
LnkCtl2: Target Link Speed: 16GT/s, EnterCompliance- SpeedDis-
Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
Compliance De-emphasis: -6dB
LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete+, EqualizationPhase1+
EqualizationPhase2+, EqualizationPhase3+, LinkEqualizationRequest-
Capabilities: [b0] MSI-X: Enable- Count=8 Masked-
Vector table: BAR=2 offset=00000000
PBA: BAR=2 offset=00010000
Capabilities: [100 v2] Advanced Error Reporting
UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
AERCap: First Error Pointer: 00, GenCap+ CGenEn- ChkCap+ ChkEn-
Capabilities: [148 v1] #19
Capabilities: [168 v1] #26
Capabilities: [190 v1] #27
Capabilities: [1c0 v1] L1 PM Substates
L1SubCap: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2- ASPM_L1.1- L1_PM_Substates+
PortCommonModeRestoreTime=60us PortTPowerOnTime=40us
L1SubCtl1: PCI-PM_L1.2- PCI-PM_L1.1- ASPM_L1.2- ASPM_L1.1-
T_CommonMode=60us
L1SubCtl2: T_PwrOn=40us
Capabilities: [1d0 v1] Vendor Specific Information: ID=0002 Rev=4 Len=100 <?> Capabilities: [2d0 v1] Vendor Specific Information: ID=0001 Rev=1 Len=038 <?>
Capabilities: [308 v1] #25
Capabilities: [314 v1] Precision Time Measurement
PTMCap: Requester:+ Responder:+ Root:+
PTMClockGranularity: 16ns
PTMControl: Enabled:- RootSelected:-
PTMEffectiveGranularity: Unknown
Capabilities: [320 v1] Vendor Specific Information: ID=0004 Rev=1 Len=054 <?>
Latency: 0
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
Capabilities: [50] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [70] Express (v2) Endpoint, MSI 00
DevCap: MaxPayload 256 bytes, PhantFunc 0, Latency L0s unlimited, L1 unlimited
ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset+ SlotPowerLimit 0.000W
RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+ FLReset-
DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend-
LnkCap: Port #0, Speed 8GT/s, Width x4, ASPM L1, Exit Latency L0s unlimited, L1 <64us
ClockPM+ Surprise- LLActRep- BwNot- ASPMOptComp+
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 8GT/s, Width x4, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
LnkCtl2: Target Link Speed: 8GT/s, EnterCompliance- SpeedDis-
Capabilities: [b0] MSI-X: Enable+ Count=33 Masked-
Vector table: BAR=0 offset=00003000
PBA: BAR=0 offset=00002000
Capabilities: [148 v1] Device Serial Number 00-00-00-00-00-00-00-00
Capabilities: [158 v1] Power Budgeting <?>
Capabilities: [168 v1] #19
Capabilities: [188 v1] Latency Tolerance Reporting
Max snoop latency: 0ns
Max no snoop latency: 0ns
Capabilities: [190 v1] L1 PM Substates
L1SubCap: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2+ ASPM_L1.1+ L1_PM_Substates+
PortCommonModeRestoreTime=10us PortTPowerOnTime=10us
T_CommonMode=0us LTR1.2_Threshold=0ns
Latency: 0
ExtTag- RBE+
LnkCap: Port #0, Speed 5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <1us, L1 <64us
LnkCtl: ASPM L0s L1 Enabled; RCB 64 bytes Disabled- CommClk+
LnkSta: Speed 5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive+ BWMgmt+ ABWMgmt+
LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis-
LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete-, EqualizationPhase1-
EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
Capabilities: [b0] MSI-X: Enable- Count=1 Masked-
Vector table: BAR=0 offset=00000000
PBA: BAR=0 offset=00000000
Capabilities: [158 v1] #26
Capabilities: [17c v1] #27
T_CommonMode=60us
Capabilities: [1a0 v1] Vendor Specific Information: ID=0002 Rev=4 Len=100 <?> Capabilities: [2a0 v1] Vendor Specific Information: ID=0001 Rev=1 Len=038 <?>
Capabilities: [2d8 v1] #25
Capabilities: [2e4 v1] Precision Time Measurement
PTMCap: Requester:- Responder:+ Root:+
Capabilities: [2f0 v1] Vendor Specific Information: ID=0004 Rev=1 Len=054 <?>
Latency: 0
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot+,D3cold-)
Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [50] MSI: Enable+ Count=1/1 Maskable- 64bit-
Address: fffff000 Data: 0000
Capabilities: [70] Express (v2) Legacy Endpoint, MSI 00
DevCap: MaxPayload 512 bytes, PhantFunc 0, Latency L0s <1us, L1 <64us
ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset-
DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop-
LnkCap: Port #0, Speed 5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <512ns, L1 <64us
ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp-
LnkSta: Speed 5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Not Supported, TimeoutDis+, LTR-, OBFF Not Supported
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled
Capabilities: [100 v1] Advanced Error Reporting
AERCap: First Error Pointer: 00, GenCap- CGenEn- ChkCap- ChkEn-
Latency: 0
ExtTag- RBE+
LnkSta: Speed 16GT/s, Width x8, TrErr- Train- SlotClk+ DLActive+ BWMgmt+ ABWMgmt+
T_CommonMode=60us
Latency: 0
Capabilities: [60] Express (v2) Endpoint, MSI 00
DevCap: MaxPayload 512 bytes, PhantFunc 0, Latency L0s unlimited, L1 unlimited
ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset+ SlotPowerLimit 0.000W
RlxdOrd+ ExtTag+ PhantFunc- AuxPwr- NoSnoop+ FLReset-
DevSta: CorrErr+ UncorrErr- FatalErr- UnsuppReq+ AuxPwr- TransPend-
LnkCap: Port #0, Speed 16GT/s, Width x16, ASPM not supported, Exit Latency L0s unlimited, L1 <4us
ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp+
LnkSta: Speed 16GT/s, Width x8, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Range ABC, TimeoutDis+, LTR-, OBFF Not Supported
Capabilities: [48] Vital Product Data
Product Name: CX516A - ConnectX-5 QSFP28
Read-only fields:
[PN] Part number: MCX516A-CDAT
[EC] Engineering changes: B1
[V2] Vendor specific: MCX516A-CDAT
[SN] Serial number: MT2037X23692
[V3] Vendor specific: fca65aefaaf8ea118000043f72c3cfa8
[VA] Vendor specific: MLX:MODL=CX516A:MN=MLNX:CSKU=V2:UUID=V3:PCI=V0
[V0] Vendor specific: PCIeGen4 x16
[RV] Reserved: checksum good, 2 byte(s) reserved
End
Capabilities: [9c] MSI-X: Enable+ Count=64 Masked-
Vector table: BAR=0 offset=00002000
PBA: BAR=0 offset=00003000
Capabilities: [c0] Vendor Specific Information: Len=18 <?>
Flags: PMEClk- DSI- D1- D2- AuxCurrent=375mA PME(D0-,D1-,D2-,D3hot-,D3cold+)
UESvrt: DLP+ SDES- TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
AERCap: First Error Pointer: 04, GenCap+ CGenEn- ChkCap+ ChkEn-
Capabilities: [150 v1] Alternative Routing-ID Interpretation (ARI)
ARICap: MFVC- ACS-, Next Function: 1
ARICtl: MFVC- ACS-, Function Group: 0
Capabilities: [1c0 v1] #19
Capabilities: [230 v1] Access Control Services
ACSCap: SrcValid- TransBlk- ReqRedir- CmpltRedir- UpstreamFwd- EgressCtrl- DirectTrans-
ACSCtl: SrcValid- TransBlk- ReqRedir- CmpltRedir- UpstreamFwd- EgressCtrl- DirectTrans-
Capabilities: [320 v1] #27
Capabilities: [370 v1] #26
Capabilities: [420 v1] #25
Latency: 0
Read-only fields:
End
ARICap: MFVC- ACS-, Next Function: 0
You can edit your post (pencil icon at the lower right of an existing post) and put a line above and a line below the lspci log which is entirely three back quote (unshifted tilde key) characters, and it’ll add scrollbars and preserve formatting. Example line:
Note that the “LinkCap” is what speed the link is capable of, and is rated in “GT/s”. The “LinkSta” is the actual current speed status. If “LinkCap” is the same GT/s as “LinkSta”, then things are not only operating correctly, but are at their best speed. If the “LinkCap” is higher than “LinkSta”, then either something upstream does not support that high of a capability and it has reverted to a lower speed, or else the signal quality is suffering and there was no choice but slowing down. Sometimes things slow so much that no communications speed is possible.
Anything “8GT/s” is PCIe gen. 3. “5GT/s” is PCIe gen. 2. “2.5GT/s” is PCIe gen. 1.
Not all devices have advanced error reporting, but if you see “AERCap”, this is part of advanced error reporting. If the “First Error Pointer” is NULL (“00”) then there are no reported errors. Note that you have some devices with a non-NULL error pointer, “04”. This is a sign that something is in such a bad error state that correction is required, but it doesn’t say if correction is possible. It is rare to see a non-NULL first error pointer, so this is a serious problem even if AER is able to correct.
Some abbreviations are listed in the “Capabilities: [100 v1] Advanced Error Reporting”, but mostly this would require research to have any meaning. Typically the “+” or “-” has a meaning there possibly related to whether or not that classification of error was found (but like I said, you’d have to research to know its meaning, and this is rarely useful for any solution since it is often an electrical issue).
About the only kind of user solvable AER problem might be if the hardware in question requires firmware uploaded into the device, and the wrong firmware version is present, or else missing. Not many devices (aside from WiFi devices licensed to some part of the world) use extra firmware. Some specialty devices might have an error if they need time to boot and were tested before boot is complete.
I see that the PCIe link with Mellanox device has come up in Gen-4 (16GT/s) speed and x8 link width from the Link Status (LnkSta) registers.
So, This is a good enough configuration to get 100 Gb/s PCIe bandwidth.
But, I’m wondering what is the kind of Ethernet interface through which the Mellanox device is sending/receiving the data out/in.
If that interface is limiting the bandwidth (say at 25 Gb/s or 50 Gb/s for whatever reason), then, obviously we don’t see a higher value (i.e. 100 Gb/s)
