Greetings,
I have been using the TX2 such that our frame grabber PCIe boards work with the Jetson TX2. e.g.
https://www.activesilicon.com/products/firebird-camera-link-frame-grabber-1xCLD-2PE4L/
The most significant problem we have relates to the fact that we are getting less than half the specified data rate for PCIe 2.0 with 4x lanes. Looking I see discussions on previous forum posts in regards to PCIe bandwidth:
https://devtalk.nvidia.com/default/topic/1026623/jetson-tx2/pcie-x4-only-658mb-s/
Following the discussions of the other two forum posts I tested the bandwidth both first with the SMMU enabled and then again with the SMMU disabled. The actual TX2 bandwidth rate as in comparison to a similar x86_64 PCIe 2.0 is rather significant. i.e. Giving only a quater of the expected theortical rate. That is with our hardware:
- On a x86_64 system we get a rate of ~1.5Gb/s
- On the TX2, with SMMU enabled, we get a rate of 376.6Mb/s
- On the TX2, with SMMU disabled, we get a rate of 501.8Mb/s
One common factor seems to be that we are all using ‘TX2 <-> FPGA’ across PCIe setups. That is like the other two forum posts on PCIe bandwidth; we are using the PCIe bus to communicate with a Xilinx FPGA chip.
The details of the test enviroment
- Using JetPack 3.2, with L4T 28.2
- Both the ./jetson_clocks.sh script and "nvpmodel -m 0" were run.
Bandwidth testing is done by our own tool phx_rate that essentially tries to push as much data across the PCIe bus. In addition we used a Teledyne LeCroy PCIe analyzer to measure the bandwidth in conjunction with the phx_rate tool on the TX2. Thus ensuring that the rate given by the phx_rate tool is accurate.
With the SMMU enabled I got a rate of 376.6Mb/s.
The output from the test
nvidia@tegra-ubuntu:~/Development/phoenix_ts/install$ ./phx_rate
*** Active Silicon SDK Example phx_rate ***
Using Board Number   = 1
      Channel Number = 1
      Config File    = <None>
ERROR REPORTED by PHX Default Error Handler :
FBD_FirmwareRevisionCheck:  Failed with error code 0x00000000.
"Board Contains Firmware [2.18.2] - DLL Contains Firmware [2.17.1]
Please Update Board Firmware with FbdProg"
(Phoenix Library v8.21.00)
Hardware Rev =    21802
Software Rev =    82100
Please wait for 10 seconds
Acquiring for 10 seconds..++++++++++
Acquired 12853 buffers in 10 seconds [376.6 MBytes/sec]
In addition the output from running “lspci -vvvv” is
nvidia@tegra-ubuntu:~$ sudo lspci -vvvv
[sudo] password for nvidia:
00:01.0 PCI bridge: NVIDIA Corporation Device 10e5 (rev a1) (prog-if 00 [Normal decode])
        Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
        Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
        Latency: 0
        Interrupt: pin A routed to IRQ 388
        Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
        I/O behind bridge: 0000f000-00000fff
        Memory behind bridge: 51000000-51ffffff
        Prefetchable memory behind bridge: 00000000fff00000-00000000000fffff
        Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
        BridgeCtl: Parity- SERR- NoISA- VGA- MAbort- >Reset- FastB2B-
                PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
        Capabilities: [40] Subsystem: NVIDIA Corporation Device 0000
        Capabilities: [48] Power Management version 3
                Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1+,D2+,D3hot+,D3cold+)
                Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME-
        Capabilities: [50] MSI: Enable- Count=1/2 Maskable- 64bit+
                Address: 0000000000000000  Data: 0000
        Capabilities: [60] HyperTransport: MSI Mapping Enable- Fixed-
                Mapping Address Base: 00000000fee00000
        Capabilities: [80] Express (v2) Root Port (Slot+), MSI 00
                DevCap: MaxPayload 128 bytes, PhantFunc 0
                        ExtTag+ RBE+
                DevCtl: Report errors: Correctable+ Non-Fatal+ Fatal+ Unsupported+
                        RlxdOrd+ ExtTag+ PhantFunc- AuxPwr- NoSnoop+
                        MaxPayload 128 bytes, MaxReadReq 512 bytes
                DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend-
                LnkCap: Port #0, Speed 5GT/s, Width x4, ASPM L0s L1, Exit Latency L0s <512ns, L1 <4us
                        ClockPM- Surprise- LLActRep+ BwNot+ ASPMOptComp-
                LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk-
                        ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
                LnkSta: Speed 5GT/s, Width x4, TrErr- Train- SlotClk+ DLActive+ BWMgmt+ ABWMgmt-
                SltCap: AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug- Surprise-
                        Slot #0, PowerLimit 0.000W; Interlock- NoCompl-
                SltCtl: Enable: AttnBtn- PwrFlt- MRL- PresDet- CmdCplt- HPIrq- LinkChg-
                        Control: AttnInd Off, PwrInd On, Power- Interlock-
                SltSta: Status: AttnBtn- PowerFlt- MRL- CmdCplt- PresDet+ Interlock-
                        Changed: MRL- PresDet+ LinkState+
                RootCtl: ErrCorrectable- ErrNon-Fatal- ErrFatal- PMEIntEna+ CRSVisible-
                RootCap: CRSVisible-
                RootSta: PME ReqID 0000, PMEStatus- PMEPending-
                DevCap2: Completion Timeout: Range AB, TimeoutDis+, LTR+, OBFF Not Supported ARIFwd-
                DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR+, OBFF Disabled ARIFwd-
                LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis-
                         Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
                         Compliance De-emphasis: -6dB
                LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete-, EqualizationPhase1-
                         EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
        Capabilities: [100 v1] Advanced Error Reporting
                UESta:  DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
                UEMsk:  DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
                UESvrt: DLP+ SDES- TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
                CESta:  RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
                CEMsk:  RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
                AERCap: First Error Pointer: 00, GenCap+ CGenEn- ChkCap+ ChkEn-
        Kernel driver in use: pcieport
01:00.0 Multimedia video controller: Xilinx Corporation Device 7024
        Subsystem: Device 4153:fb10
        Latency: 0
        Region 0: Memory at 51000000 (32-bit, non-prefetchable)
        Capabilities: [40] Power Management version 3
                Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
                Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
        Capabilities: [60] Express (v2) Endpoint, MSI 00
                DevCap: MaxPayload 512 bytes, PhantFunc 0, Latency L0s <64ns, L1 unlimited
                        ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset-
                DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
                        RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+
                LnkCap: Port #0, Speed 5GT/s, Width x4, ASPM L0s, Exit Latency L0s unlimited, L1 unlimited
                        ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp-
                LnkSta: Speed 5GT/s, Width x4, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
                DevCap2: Completion Timeout: Range B, TimeoutDis-, LTR-, OBFF Not Supported
                DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled
                LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete-, EqualizationPhase1-
        Kernel driver in use: aslenum
        Kernel modules: aslenum
With the SMMU disabled we get a slightly faster rate of 501.8Mb/s.
      Channel Number = 1
Acquired 17128 buffers in 10 seconds [501.8 MBytes/sec]
In addition the output from running “lspci -vvvv” with SMMU disabled is
nvidia@tegra-ubuntu:~/Development/phoenix_ts/install$ sudo lspci -vvvv
        Latency: 0
        Interrupt: pin A routed to IRQ 422
                        ExtTag+ RBE+
        Latency: 0
