TX1 PCIe 4X bandwidth bottleneck ?
We use the PCIe bridge card to extend 4x USB3; the PCIe 4X switch to 4 chanel PCIe 1X, then PCIe 1X to USB 3.0 ; and test it used Intel real-sense SR300;
1Ch 1080p RGBD@30,it could preview the video data as 30 fps, RGBD total bandwidth is 1.6Gbps;
If 2 SR300, setting 30 fps , actually it run 19 fps : RGBD total bandwidth is 2 Gbps;
the Camera video data should be read by Memory Controller Client Interface (MCCIF) , what’s the bandwidth of MCCIF ?
I can’t answer the MCCIF question, but you could post info from this to see about the PCIe part of what’s going on:
sudo lspci -vvv
The dedicated RAW to YUV processing engines process up to 1400Mpix/s on TX1, that is the bottleneck of preview?
sudo lspci -vvv
[sudo] password for ubuntu:
00:01.0 PCI bridge: NVIDIA Corporation Device 0fae (rev a1) (prog-if 00 [Normal decode])
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- SERR- <PERR- INTx-
Latency: 0, Cache Line Size: 64 bytes
Interrupt: pin A routed to IRQ 130
Bus: primary=00, secondary=01, subordinate=06, sec-latency=0
I/O behind bridge: 0000f000-00000fff
Memory behind bridge: 13000000-134fffff
Prefetchable memory behind bridge: 00000000fff00000-00000000000fffff
Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort+ <SERR- <PERR-
BridgeCtl: Parity+ SERR- NoISA- VGA- MAbort- >Reset- FastB2B-
PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
Capabilities: [40] Subsystem: NVIDIA Corporation Device 0000
Capabilities: [48] Power Management version 3
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1+,D2+,D3hot+,D3cold+)
Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [50] MSI: Enable- Count=1/2 Maskable- 64bit+
Address: 0000000000000000 Data: 0000
Capabilities: [60] HyperTransport: MSI Mapping Enable- Fixed-
Mapping Address Base: 00000000fee00000
Capabilities: [80] Express (v2) Root Port (Slot+), MSI 00
DevCap: MaxPayload 128 bytes, PhantFunc 0
ExtTag+ RBE+
DevCtl: Report errors: Correctable+ Non-Fatal+ Fatal+ Unsupported+
RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+
MaxPayload 128 bytes, MaxReadReq 512 bytes
DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend-
LnkCap: Port #0, Speed 5GT/s, Width x4, ASPM L0s L1, Exit Latency L0s <512ns, L1 <4us
ClockPM- Surprise- LLActRep+ BwNot+ ASPMOptComp-
LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk-
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 5GT/s, Width x4, TrErr- Train- SlotClk+ DLActive+ BWMgmt+ ABWMgmt+
SltCap: AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug- Surprise-
Slot #0, PowerLimit 0.000W; Interlock- NoCompl-
SltCtl: Enable: AttnBtn- PwrFlt- MRL- PresDet- CmdCplt- HPIrq- LinkChg-
Control: AttnInd Off, PwrInd On, Power- Interlock-
SltSta: Status: AttnBtn- PowerFlt- MRL- CmdCplt- PresDet+ Interlock-
Changed: MRL- PresDet+ LinkState+
RootCtl: ErrCorrectable- ErrNon-Fatal- ErrFatal- PMEIntEna+ CRSVisible-
RootCap: CRSVisible-
RootSta: PME ReqID 0000, PMEStatus- PMEPending-
DevCap2: Completion Timeout: Range AB, TimeoutDis+, LTR+, OBFF Not Supported ARIFwd-
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR+, OBFF Disabled ARIFwd-
LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis-
Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
Compliance De-emphasis: -6dB
LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete-, EqualizationPhase1-
EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
Capabilities: [100 v1] Advanced Error Reporting
UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UESvrt: DLP+ SDES- TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
AERCap: First Error Pointer: 00, GenCap+ CGenEn- ChkCap+ ChkEn-
Capabilities: [140 v1] L1 PM Substates
L1SubCap: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2+ ASPM_L1.1+ L1_PM_Substates+
PortCommonModeRestoreTime=30us PortTPowerOnTime=70us
Kernel driver in use: pcieport
01:00.0 PCI bridge: PLX Technology, Inc. PEX 8608 8-lane, 8-Port PCI Express Gen 2 (5.0 GT/s) Switch (rev ba) (prog-if 00 [Normal decode])
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx+
Interrupt: pin A routed to IRQ 547
Region 0: Memory at 13400000 (32-bit, non-prefetchable)
Bus: primary=01, secondary=02, subordinate=06, sec-latency=0
Memory behind bridge: 13000000-133fffff
Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
Capabilities: [40] Power Management version 3
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [48] MSI: Enable+ Count=1/4 Maskable+ 64bit+
Address: 000000017c9b4000 Data: 0000
Masking: 00000001 Pending: 00000000
Capabilities: [68] Express (v2) Upstream Port, MSI 00
DevCap: MaxPayload 512 bytes, PhantFunc 0
ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ SlotPowerLimit 0.000W
DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
RlxdOrd- ExtTag- PhantFunc- AuxPwr- NoSnoop-
MaxPayload 128 bytes, MaxReadReq 128 bytes
LnkCap: Port #0, Speed 5GT/s, Width x4, ASPM L0s L1, Exit Latency L0s <1us, L1 <2us
ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp-
LnkCtl: ASPM Disabled; Disabled- CommClk-
LnkSta: Speed 5GT/s, Width x4, TrErr- Train- SlotClk- DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Not Supported, TimeoutDis-, LTR-, OBFF Not Supported
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled
Capabilities: [a4] Subsystem: PLX Technology, Inc. PEX 8608 8-lane, 8-Port PCI Express Gen 2 (5.0 GT/s) Switch
Capabilities: [100 v1] Device Serial Number ba-86-01-10-b5-df-0e-00
Capabilities: [fb4 v1] Advanced Error Reporting
UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
AERCap: First Error Pointer: 1f, GenCap+ CGenEn- ChkCap+ ChkEn-
Capabilities: [138 v1] Power Budgeting <?> Capabilities: [148 v1] Virtual Channel Caps: LPEVC=1 RefClk=100ns PATEntryBits=4 Arb: Fixed+ WRR32- WRR64- WRR128- Ctrl: ArbSelect=Fixed Status: InProgress- VC0: Caps: PATOffset=06 MaxTimeSlots=1 RejSnoopTrans- Arb: Fixed- WRR32+ WRR64- WRR128- TWRR128- WRR256- Ctrl: Enable+ ID=0 ArbSelect=WRR32 TC/VC=ff Status: NegoPending- InProgress- Port Arbitration Table <?>
VC1: Caps: PATOffset=00 MaxTimeSlots=1 RejSnoopTrans-
Arb: Fixed+ WRR32- WRR64- WRR128- TWRR128- WRR256-
Ctrl: Enable- ID=1 ArbSelect=Fixed TC/VC=00
Status: NegoPending+ InProgress-
Capabilities: [448 v1] Vendor Specific Information: ID=0000 Rev=0 Len=0cc <?> Capabilities: [950 v1] Vendor Specific Information: ID=0001 Rev=0 Len=010 <?>
02:01.0 PCI bridge: PLX Technology, Inc. PEX 8608 8-lane, 8-Port PCI Express Gen 2 (5.0 GT/s) Switch (rev ba) (prog-if 00 [Normal decode])
Interrupt: pin A routed to IRQ 548
Bus: primary=02, secondary=03, subordinate=03, sec-latency=0
Memory behind bridge: 13000000-130fffff
Address: 000000017c9b4000 Data: 0001
Capabilities: [68] Express (v2) Downstream Port (Slot+), MSI 00
ExtTag- RBE+
LnkCap: Port #1, Speed 5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <1us, L1 <2us
ClockPM- Surprise+ LLActRep+ BwNot+ ASPMOptComp-
LnkSta: Speed 5GT/s, Width x1, TrErr- Train- SlotClk- DLActive+ BWMgmt+ ABWMgmt-
Slot #113, PowerLimit 25.000W; Interlock- NoCompl-
Control: AttnInd Off, PwrInd Off, Power- Interlock-
DevCap2: Completion Timeout: Not Supported, TimeoutDis-, LTR-, OBFF Not Supported ARIFwd+
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled ARIFwd-
LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis-, Selectable De-emphasis: -6dB
Caps: LPEVC=1 RefClk=100ns PATEntryBits=1
Status: InProgress-
VC0: Caps: PATOffset=00 MaxTimeSlots=1 RejSnoopTrans-
Ctrl: Enable+ ID=0 ArbSelect=Fixed TC/VC=ff
Capabilities: [520 v1] Access Control Services
ACSCap: SrcValid+ TransBlk+ ReqRedir+ CmpltRedir+ UpstreamFwd+ EgressCtrl+ DirectTrans+
ACSCtl: SrcValid- TransBlk- ReqRedir- CmpltRedir- UpstreamFwd- EgressCtrl- DirectTrans-
02:05.0 PCI bridge: PLX Technology, Inc. PEX 8608 8-lane, 8-Port PCI Express Gen 2 (5.0 GT/s) Switch (rev ba) (prog-if 00 [Normal decode])
Interrupt: pin A routed to IRQ 549
Bus: primary=02, secondary=04, subordinate=04, sec-latency=0
Memory behind bridge: 13100000-131fffff
Address: 000000017c9b4000 Data: 0002
ExtTag- RBE+
LnkCap: Port #5, Speed 5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <1us, L1 <2us
Slot #117, PowerLimit 25.000W; Interlock- NoCompl-
Status: InProgress-
02:07.0 PCI bridge: PLX Technology, Inc. PEX 8608 8-lane, 8-Port PCI Express Gen 2 (5.0 GT/s) Switch (rev ba) (prog-if 00 [Normal decode])
Interrupt: pin A routed to IRQ 550
Bus: primary=02, secondary=05, subordinate=05, sec-latency=0
Memory behind bridge: 13200000-132fffff
Address: 000000017c9b4000 Data: 0003
ExtTag- RBE+
LnkCap: Port #7, Speed 5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <1us, L1 <2us
Slot #119, PowerLimit 25.000W; Interlock- NoCompl-
Status: InProgress-
02:09.0 PCI bridge: PLX Technology, Inc. PEX 8608 8-lane, 8-Port PCI Express Gen 2 (5.0 GT/s) Switch (rev ba) (prog-if 00 [Normal decode])
Interrupt: pin A routed to IRQ 551
Bus: primary=02, secondary=06, subordinate=06, sec-latency=0
Memory behind bridge: 13300000-133fffff
Address: 000000017c9b4000 Data: 0004
ExtTag- RBE+
LnkCap: Port #9, Speed 5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <1us, L1 <2us
Slot #121, PowerLimit 25.000W; Interlock- NoCompl-
Status: InProgress-
03:00.0 USB controller: Fresco Logic FL1100 USB 3.0 Host Controller (rev 10) (prog-if 30 [XHCI])
Subsystem: Fresco Logic FL1100 USB 3.0 Host Controller
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx+
Region 0: Memory at 13000000 (64-bit, non-prefetchable)
Region 2: Memory at 13010000 (64-bit, non-prefetchable)
Region 4: Memory at 13011000 (64-bit, non-prefetchable)
Flags: PMEClk- DSI- D1+ D2- AuxCurrent=0mA PME(D0+,D1+,D2-,D3hot+,D3cold-)
Capabilities: [50] MSI: Enable- Count=1/8 Maskable- 64bit+
Capabilities: [70] Express (v2) Endpoint, MSI 00
DevCap: MaxPayload 512 bytes, PhantFunc 0, Latency L0s <64ns, L1 <1us
ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset-
LnkCap: Port #0, Speed 5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s unlimited, L1 unlimited
LnkSta: Speed 5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Not Supported, TimeoutDis+, LTR-, OBFF Not Supported
Capabilities: [b0] MSI-X: Enable+ Count=8 Masked-
Vector table: BAR=2 offset=00000000
PBA: BAR=4 offset=00000000
Kernel driver in use: xhci_hcd
04:00.0 USB controller: Fresco Logic FL1100 USB 3.0 Host Controller (rev 10) (prog-if 30 [XHCI])
Region 0: Memory at 13100000 (64-bit, non-prefetchable)
Region 2: Memory at 13110000 (64-bit, non-prefetchable)
Region 4: Memory at 13111000 (64-bit, non-prefetchable)
05:00.0 USB controller: Fresco Logic FL1100 USB 3.0 Host Controller (rev 10) (prog-if 30 [XHCI])
Region 0: Memory at 13200000 (64-bit, non-prefetchable)
Region 2: Memory at 13210000 (64-bit, non-prefetchable)
Region 4: Memory at 13211000 (64-bit, non-prefetchable)
06:00.0 USB controller: Fresco Logic FL1100 USB 3.0 Host Controller (rev 10) (prog-if 30 [XHCI])
Region 0: Memory at 13300000 (64-bit, non-prefetchable)
Region 2: Memory at 13310000 (64-bit, non-prefetchable)
Region 4: Memory at 13311000 (64-bit, non-prefetchable)
e]0;ubuntu@tegra-ubuntu: ~ae[01;32mubuntu@tegra-ubuntue[00m:e[01;34m~e[00m$
e[Ke]0;ubuntu@tegra-ubuntu: ~ae[01;32mubuntu@tegra-ubuntue[00m:e[01;34m~e[00m$ exit
exit
Script done on Fri 19 May 2017 06:38:32 AM UTC
@linuxdev the log , we test with 2 USB3 Realsense camera by PCI X4 bridge;
@Trumany
RealSense SR300 | Data BW | Pix BW
1Ch 1080p RGBD@30 | 1.6Gbps | 71.5MPix/s
2Ch 1080p RGBD@19 | 2Gbps | 90.5MPix/s
4Ch 1080p RGBD@7 | 1Gbps | 42.5MPix/s
4Ch 720p RGBD@12 | 1.3Gbps | 22.0MPix/s
Just FYI, you can make the lspci output format nicely on the forum if you edit your post with the lspci info via the “pencil” icon in the upper right (hover the mouse over the quote in upper right and other icons will pop up), and when editing highlight the whole lspci output and then click on the “block quote” icon in upper right (looks like “</>”). The indentation will be preserved.
On the PCIe side: The bridges at 00:01.0 and 01:00.0 are running at 5GT/s, so with four lanes these PCIe bridges will not be a limit of bandwidth.
For bridges at: 02:01.0, 02:05.0, 02:07.0, 02:09.0: These bridges are also running 5GT/s, but use only one lane…this would be a limitation on bandwidth for any of the higher bandwidth devices, but not for any single device (these show as an 8-lane 8-port bridge, but only one lane is used per port). I’m not positive, but I think what you have there is essentially a splitter where the host side has many lanes available, but only a single lane is ever dedicated to data passing through it to any particular PCIe end point. One lane is certainly fast enough to not limit any individual device, but if two devices are put on a single lane you could hit bandwidth limitations. It might be of interest to see layout via:
sudo lspci -t
The USB3 controllers at 03:00.0, 04:00.0, 05:00.0, and 06:00.0 run at the full 5GT/s of PCIe V2, but each uses only a single PCIe lane. This means the PCIe side has roughly a peak throughput of (5Gbit/s * 8bit/10bit) = 4Gbit/s available regardless of peak USB3 speed. USB3 is listed as 5Gbit/s (overhead means actual data transferred is less than 5Gbit/s, but all of the overhead must pass through the PCIe lane). If a single USB3 device is connected to the single lane PCIe at PCIe V2, then that device cannot quite reach its raw throughput of 5Gbit/s (though it can come close for your purposes). Do you connect more than one device to any USB3 port? If so, what is the combined bandwidth required for all of the devices on that port (e.g., through a USB3 HUB)? You should probably be ok on bandwidth if only a single high-usage USB device is on a given port…you will run into limitations fast if more than one high bandwidth device is connected via HUB to a single port.
I’m not positive about any individual camera bandwidth, it looks like you would not have problems if each USB3 port has its own PCIe V2 lane, and if only one device is connected per USB3 port. A tree of USB topology (“lsusb -t”) and PCIe topology (“lspci -t”) might show if best use of PCIe and USB3 are arranged to make best use of bandwidth.
