PCIE driver issue with L4T R24.2.1
I am using the MAGEWELL’s PCIE video capture cards on TX1.
They are working well with L4T R24.1 64bit. And the single channle cards(without PCIE switch) are also working well with R24.2.1. But there are DMA problem on multi channel card(with PCIE switch PEX8608) with R24.2.1.
[ 1557.965717] smmu_dump_pagetable(): fault_address=0x00000000fdd40000 pa=0xffffffffffffffff bytes=ffffffffffffffff #pte=0 in L2
[ 1557.965722] mc-err: (0) csw_afiw: EMEM decode error on PDE or PTE entry
[ 1557.965725] mc-err:   status = 0x60010031; addr = 0xfdd40000
[ 1557.965728] mc-err:   secure: no, access-type: write, SMMU fault: nr-nw-s
lspci output:
00:01.0 PCI bridge: NVIDIA Corporation Device 0fae (rev a1)
01:00.0 PCI bridge: PLX Technology, Inc. PEX 8608 8-lane, 8-Port PCI Express Gen 2 (5.0 GT/s) Switch (rev ba)
02:01.0 PCI bridge: PLX Technology, Inc. PEX 8608 8-lane, 8-Port PCI Express Gen 2 (5.0 GT/s) Switch (rev ba)
02:05.0 PCI bridge: PLX Technology, Inc. PEX 8608 8-lane, 8-Port PCI Express Gen 2 (5.0 GT/s) Switch (rev ba)
02:07.0 PCI bridge: PLX Technology, Inc. PEX 8608 8-lane, 8-Port PCI Express Gen 2 (5.0 GT/s) Switch (rev ba)
02:09.0 PCI bridge: PLX Technology, Inc. PEX 8608 8-lane, 8-Port PCI Express Gen 2 (5.0 GT/s) Switch (rev ba)
03:00.0 Multimedia video controller: Device 1cd7:0007 (rev 01)
05:00.0 Multimedia video controller: Device 1cd7:0007 (rev 01)
details:
ubuntu@tegra-ubuntu:~$ sudo lspci -vv
00:01.0 PCI bridge: NVIDIA Corporation Device 0fae (rev a1) (prog-if 00 [Normal decode])
        Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx-
        Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
        Latency: 0, Cache Line Size: 64 bytes
        Interrupt: pin A routed to IRQ 130
        Bus: primary=00, secondary=01, subordinate=06, sec-latency=0
        Memory behind bridge: 13000000-132fffff
        Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort+ <SERR- <PERR-
        BridgeCtl: Parity+ SERR- NoISA- VGA- MAbort- >Reset- FastB2B-
                PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
        Capabilities: [40] Subsystem: NVIDIA Corporation Device 0000
        Capabilities: [48] Power Management version 3
                Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1+,D2+,D3hot+,D3cold+)
                Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME-
        Capabilities: [50] MSI: Enable- Count=1/2 Maskable- 64bit+
                Address: 0000000000000000  Data: 0000
        Capabilities: [60] HyperTransport: MSI Mapping Enable- Fixed-
                Mapping Address Base: 00000000fee00000
        Capabilities: [80] Express (v2) Root Port (Slot+), MSI 00
                DevCap: MaxPayload 128 bytes, PhantFunc 0
                        ExtTag+ RBE+
                DevCtl: Report errors: Correctable+ Non-Fatal+ Fatal+ Unsupported+
                        RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+
                        MaxPayload 128 bytes, MaxReadReq 512 bytes
                DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend-
                LnkCap: Port #0, Speed 5GT/s, Width x4, ASPM L0s L1, Exit Latency L0s <512ns, L1 <4us
                        ClockPM- Surprise- LLActRep+ BwNot+ ASPMOptComp-
                LnkCtl: ASPM L1 Enabled; RCB 64 bytes Disabled- CommClk-
                        ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
                LnkSta: Speed 5GT/s, Width x4, TrErr- Train- SlotClk+ DLActive+ BWMgmt+ ABWMgmt+
                SltCap: AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug- Surprise-
                        Slot #0, PowerLimit 0.000W; Interlock- NoCompl-
                SltCtl: Enable: AttnBtn- PwrFlt- MRL- PresDet- CmdCplt- HPIrq- LinkChg-
                        Control: AttnInd Off, PwrInd On, Power- Interlock-
                SltSta: Status: AttnBtn- PowerFlt- MRL- CmdCplt- PresDet+ Interlock-
                        Changed: MRL- PresDet+ LinkState+
                RootCtl: ErrCorrectable- ErrNon-Fatal- ErrFatal- PMEIntEna+ CRSVisible-
                RootCap: CRSVisible-
                RootSta: PME ReqID 0000, PMEStatus- PMEPending-
                DevCap2: Completion Timeout: Range AB, TimeoutDis+, LTR+, OBFF Not Supported ARIFwd-
                DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR+, OBFF Disabled ARIFwd-
                LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis-
                         Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
                         Compliance De-emphasis: -6dB
                LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete-, EqualizationPhase1-
                         EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
        Capabilities: [100 v1] Advanced Error Reporting
                UESta:  DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
                UEMsk:  DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
                UESvrt: DLP+ SDES- TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
                CESta:  RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
                CEMsk:  RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
                AERCap: First Error Pointer: 00, GenCap+ CGenEn- ChkCap+ ChkEn-
        Capabilities: [140 v1] L1 PM Substates
                L1SubCap: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2+ ASPM_L1.1+ L1_PM_Substates+
                          PortCommonModeRestoreTime=30us PortTPowerOnTime=70us
        Kernel driver in use: pcieport
01:00.0 PCI bridge: PLX Technology, Inc. PEX 8608 8-lane, 8-Port PCI Express Gen 2 (5.0 GT/s) Switch (rev ba) (prog-if 00 [Normal decode])
        Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx+
        Interrupt: pin A routed to IRQ 547
        Region 0: Memory at 13200000 (32-bit, non-prefetchable)
        Bus: primary=01, secondary=02, subordinate=06, sec-latency=0
        Memory behind bridge: 13000000-131fffff
        Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
        Capabilities: [40] Power Management version 3
                Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
                Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
        Capabilities: [48] MSI: Enable+ Count=1/4 Maskable+ 64bit+
                Address: 000000017c91b000  Data: 0000
                Masking: 00000001  Pending: 00000000
        Capabilities: [68] Express (v2) Upstream Port, MSI 00
                DevCap: MaxPayload 512 bytes, PhantFunc 0
                        ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ SlotPowerLimit 0.000W
                DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
                        RlxdOrd- ExtTag- PhantFunc- AuxPwr- NoSnoop-
                        MaxPayload 128 bytes, MaxReadReq 128 bytes
                LnkCap: Port #0, Speed 5GT/s, Width x4, ASPM L0s L1, Exit Latency L0s <1us, L1 <2us
                        ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp-
                LnkCtl: ASPM L1 Enabled; Disabled- CommClk-
                LnkSta: Speed 5GT/s, Width x4, TrErr- Train- SlotClk- DLActive- BWMgmt- ABWMgmt-
                DevCap2: Completion Timeout: Not Supported, TimeoutDis-, LTR-, OBFF Not Supported
                DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled
        Capabilities: [a4] Subsystem: PLX Technology, Inc. PEX 8608 8-lane, 8-Port PCI Express Gen 2 (5.0 GT/s) Switch
        Capabilities: [100 v1] Device Serial Number ba-86-01-10-b5-df-0e-00
        Capabilities: [fb4 v1] Advanced Error Reporting
                UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
                CESta:  RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
                AERCap: First Error Pointer: 1f, GenCap+ CGenEn- ChkCap+ ChkEn-
        Capabilities: [138 v1] Power Budgeting <?>
        Capabilities: [148 v1] Virtual Channel
                Caps:   LPEVC=1 RefClk=100ns PATEntryBits=4
                Arb:    Fixed+ WRR32- WRR64- WRR128-
                Ctrl:   ArbSelect=Fixed
                Status: InProgress-
                VC0:    Caps:   PATOffset=06 MaxTimeSlots=1 RejSnoopTrans-
                        Arb:    Fixed- WRR32+ WRR64- WRR128- TWRR128- WRR256-
                        Ctrl:   Enable+ ID=0 ArbSelect=WRR32 TC/VC=ff
                        Status: NegoPending- InProgress-
                        Port Arbitration Table <?>
                VC1:    Caps:   PATOffset=00 MaxTimeSlots=1 RejSnoopTrans-
                        Arb:    Fixed+ WRR32- WRR64- WRR128- TWRR128- WRR256-
                        Ctrl:   Enable- ID=1 ArbSelect=Fixed TC/VC=00
                        Status: NegoPending+ InProgress-
        Capabilities: [448 v1] Vendor Specific Information: ID=0000 Rev=0 Len=0cc <?>
        Capabilities: [950 v1] Vendor Specific Information: ID=0001 Rev=0 Len=010 <?>
02:01.0 PCI bridge: PLX Technology, Inc. PEX 8608 8-lane, 8-Port PCI Express Gen 2 (5.0 GT/s) Switch (rev ba) (prog-if 00 [Normal decode])
        Interrupt: pin A routed to IRQ 548
        Bus: primary=02, secondary=03, subordinate=03, sec-latency=0
        Memory behind bridge: 13000000-130fffff
                Address: 000000017c91b000  Data: 0001
        Capabilities: [68] Express (v2) Downstream Port (Slot+), MSI 00
                        ExtTag- RBE+
                LnkCap: Port #1, Speed 5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <1us, L1 <2us
                        ClockPM- Surprise+ LLActRep+ BwNot+ ASPMOptComp-
                LnkCtl: ASPM Disabled; Disabled- CommClk-
                LnkSta: Speed 5GT/s, Width x1, TrErr- Train- SlotClk- DLActive+ BWMgmt+ ABWMgmt-
                        Slot #113, PowerLimit 25.000W; Interlock- NoCompl-
                        Control: AttnInd Off, PwrInd Off, Power- Interlock-
                DevCap2: Completion Timeout: Not Supported, TimeoutDis-, LTR-, OBFF Not Supported ARIFwd+
                DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled ARIFwd-
                LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis-, Selectable De-emphasis: -6dB
                Caps:   LPEVC=1 RefClk=100ns PATEntryBits=1
                Status: InProgress-
                VC0:    Caps:   PATOffset=00 MaxTimeSlots=1 RejSnoopTrans-
                        Ctrl:   Enable+ ID=0 ArbSelect=Fixed TC/VC=ff
        Capabilities: [520 v1] Access Control Services
                ACSCap: SrcValid+ TransBlk+ ReqRedir+ CmpltRedir+ UpstreamFwd+ EgressCtrl+ DirectTrans+
                ACSCtl: SrcValid- TransBlk- ReqRedir- CmpltRedir- UpstreamFwd- EgressCtrl- DirectTrans-
02:05.0 PCI bridge: PLX Technology, Inc. PEX 8608 8-lane, 8-Port PCI Express Gen 2 (5.0 GT/s) Switch (rev ba) (prog-if 00 [Normal decode])
        Interrupt: pin A routed to IRQ 549
        Bus: primary=02, secondary=04, subordinate=04, sec-latency=0
                Address: 000000017c91b000  Data: 0002
                        ExtTag- RBE+
                LnkCap: Port #5, Speed 5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <2us, L1 <4us
                LnkSta: Speed 2.5GT/s, Width x0, TrErr- Train- SlotClk- DLActive- BWMgmt- ABWMgmt-
                        Slot #117, PowerLimit 25.000W; Interlock- NoCompl-
                        Changed: MRL- PresDet+ LinkState-
                Status: InProgress-
02:07.0 PCI bridge: PLX Technology, Inc. PEX 8608 8-lane, 8-Port PCI Express Gen 2 (5.0 GT/s) Switch (rev ba) (prog-if 00 [Normal decode])
        Interrupt: pin A routed to IRQ 550
        Bus: primary=02, secondary=05, subordinate=05, sec-latency=0
        Memory behind bridge: 13100000-131fffff
                Address: 000000017c91b000  Data: 0003
                        ExtTag- RBE+
                LnkCap: Port #7, Speed 5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <1us, L1 <2us
                        Slot #119, PowerLimit 25.000W; Interlock- NoCompl-
                Status: InProgress-
02:09.0 PCI bridge: PLX Technology, Inc. PEX 8608 8-lane, 8-Port PCI Express Gen 2 (5.0 GT/s) Switch (rev ba) (prog-if 00 [Normal decode])
        Interrupt: pin A routed to IRQ 551
        Bus: primary=02, secondary=06, subordinate=06, sec-latency=0
                Address: 000000017c91b000  Data: 0004
                        ExtTag- RBE+
                LnkCap: Port #9, Speed 5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <2us, L1 <4us
                        Slot #121, PowerLimit 25.000W; Interlock- NoCompl-
                Status: InProgress-
        Subsystem: SafeNet (wrong ID) Device 0010
        Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx-
        Region 0: Memory at 13000000 (32-bit, non-prefetchable) [disabled]
                Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1+,D2+,D3hot+,D3cold-)
        Capabilities: [48] MSI: Enable- Count=1/1 Maskable- 64bit+
        Capabilities: [60] Express (v2) Endpoint, MSI 00
                DevCap: MaxPayload 256 bytes, PhantFunc 0, Latency L0s <64ns, L1 unlimited
                        ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset-
                DevSta: CorrErr+ UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend-
                LnkCap: Port #0, Speed 5GT/s, Width x2, ASPM L0s, Exit Latency L0s unlimited, L1 unlimited
                LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk-
                LnkSta: Speed 5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
                DevCap2: Completion Timeout: Range B, TimeoutDis-, LTR-, OBFF Not Supported
        Capabilities: [100 v1] Device Serial Number 00-00-00-00-00-00-00-00
        Subsystem: SafeNet (wrong ID) Device 0011
        Region 0: Memory at 13100000 (32-bit, non-prefetchable) [disabled]
I found the similar threads: https://devtalk.nvidia.com/default/topic/973598/network-issues-related-to-page-faults-intel-82574l-pcie-nic/?offset=1andhttps://devtalk.nvidia.com/default/topic/972169/pcie-drivers-jetpack-l4t-2-2-jetpack-l4t-2-3-diff/?offset=3#4999245. But it’s not resolved.
OK
I found the answer: [url]https://devtalk.nvidia.com/default/topic/967515/l4t-r24-2-pcie-iommu-not-working-when-switches-bridges-are-present/[/url] two month ago.
