Auvidea
November 29, 2018, 1:20pm
1
We have interfaced a Pericom PI7C9X2G1616PR 16 lane PCIe bridge to the TX2. 4 Lanes are connected upstream to the TX2. Downstream 4 lanes are connected to an M.2 NVME slot and 8 lanes are connected to 8 PCIe x1 slots. Two of these are populated with i210 GbE modules.
The problem is that these 3 devices are not always initialised correctly after boot up. Below is a non working case: eth0 and eth1 are only available after remove and rescan. The SSD is not available at all. We suspect that uBoot does not scan the busses after the bridge correctly in all cases. This seems to be random. uBoot should scan those buses to find out all PCI/PCIe device and do enumeration (assign I/O, Memory and IRQ resources for all PCI/PCIe devices). How can we ensure that?
Non working case (ok after remove & rescan)
ubuntu@tegra-ubuntu:~$ lspci
00:01.0 PCI bridge: NVIDIA Corporation Device 0fae (rev a1)
01:00.0 PCI bridge: Pericom Semiconductor Device 8619
01:00.1 System peripheral: Pericom Semiconductor Device 8619
02:01.0 PCI bridge: Pericom Semiconductor Device 8619
02:02.0 PCI bridge: Pericom Semiconductor Device 8619
02:03.0 PCI bridge: Pericom Semiconductor Device 8619
02:0a.0 PCI bridge: Pericom Semiconductor Device 8619
02:0b.0 PCI bridge: Pericom Semiconductor Device 8619
02:0c.0 PCI bridge: Pericom Semiconductor Device 8619
02:0d.0 PCI bridge: Pericom Semiconductor Device 8619
02:0e.0 PCI bridge: Pericom Semiconductor Device 8619
02:0f.0 PCI bridge: Pericom Semiconductor Device 8619
06:00.0 Ethernet controller: Intel Corporation I210 Gigabit Network Connection (rev 03)
0a:00.0 Ethernet controller: Intel Corporation I210 Gigabit Network Connection (rev 03)
ubuntu@tegra-ubuntu:~$ ifconfig
enx00044b7aba6d Link encap:Ethernet HWaddr 00:04:4b:7a:ba:6d
inet addr:192.168.0.27 Bcast:192.168.0.255 Mask:255.255.255.0
inet6 addr: fe80::204:4bff:fe7a:ba6d/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:847 errors:0 dropped:0 overruns:0 frame:0
TX packets:1797 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:143386 (143.3 KB) TX bytes:1471106 (1.4 MB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:903 errors:0 dropped:0 overruns:0 frame:0
TX packets:903 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:110001 (110.0 KB) TX bytes:110001 (110.0 KB)
wlan0 Link encap:Ethernet HWaddr 00:04:4b:7a:ba:6b
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
ubuntu@tegra-ubuntu:~$ echo 1 > /sys/bus/pci/devices/0000\:06\:00.0/remove
ubuntu@tegra-ubuntu:~$ echo 1 > /sys/bus/pci/devices/0000\:0a\:00.0/remove
ubuntu@tegra-ubuntu:~$ echo 1 > /sys/bus/pci/rescan
RX packets:2093 errors:0 dropped:0 overruns:0 frame:0
TX packets:6195 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:392946 (392.9 KB) TX bytes:5706533 (5.7 MB)
eth0 Link encap:Ethernet HWaddr 00:a0:c9:00:00:01
Memory:13000000-13100000
eth1 Link encap:Ethernet HWaddr 00:a0:c9:00:00:00
Memory:13200000-13300000
RX packets:1137 errors:0 dropped:0 overruns:0 frame:0
TX packets:1137 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:127207 (127.2 KB) TX bytes:127207 (127.2 KB)
Here is a working case: eth0, eth1 and the SSD straight away after boot of the system (without taking any special action)
03:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd Device a804
RX packets:4453 errors:0 dropped:0 overruns:0 frame:0
TX packets:8151 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:513691 (513.6 KB) TX bytes:5790657 (5.7 MB)
eth1 Link encap:Ethernet HWaddr 00:a0:c9:00:00:01
Memory:13100000-13200000
eth2 Link encap:Ethernet HWaddr 00:a0:c9:00:00:00
Memory:13300000-13400000
RX packets:1164 errors:0 dropped:0 overruns:0 frame:0
TX packets:1164 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:128738 (128.7 KB) TX bytes:128738 (128.7 KB)
ubuntu@tegra-ubuntu:~$ df
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/mmcblk0p1 14318640 12904004 664252 96% /
none 2033572 0 2033572 0% /dev
tmpfs 2045372 592 2044780 1% /dev/shm
tmpfs 2045372 17744 2027628 1% /run
tmpfs 5120 4 5116 1% /run/lock
tmpfs 2045372 0 2045372 0% /sys/fs/cgroup
tmpfs 409076 64 409012 1% /run/user/1000
/dev/nvme0n1 240234168 60564 227947292 1% /media/ubuntu/CorsairSSD
vidyas
November 30, 2018, 4:40am
2
Can you please confirm that there is no issue in terms of PCIe devices getting enumerated? I mean, in both working and non-working cases, you do get all PCIe devices enumerated as per the expectations right?
vidyas
November 30, 2018, 4:42am
3
Also, can you please share full logs in both working and non-working cases?
kayccc
December 6, 2018, 3:14am
4
Hi Auvidea,
Please help to provide further information to help to move this issue forward.
Or you have clarified the cause and resolved the problem?
Auvidea
December 14, 2018, 3:55pm
5
The Pericom bridge is still not working. Today we have tested it with a new carrier board - the J220. Here debugging is easier, as it has a standard HDMI port. Previously we tested this on a J94, which is a headless carrier board with no HDMI monitor.
But the results are still the same. The system works very badly, if booted at warm or hot temperature. If it is called down to -20°C while booting, it at least detect all PCIe devices connected: 8x i210 Ethernet controller and 1x M.2 NVME SSD card.
Here are the errors the igb driver puts out:
ubuntu@tegra-ubuntu:~$ journalctl -k | grep igb
Feb 11 17:28:00 tegra-ubuntu kernel: igb: Intel(R) Gigabit Ethernet Network Driver - version 5.0.3-k
Feb 11 17:28:00 tegra-ubuntu kernel: igb: Copyright (c) 2007-2013 Intel Corporation.
Feb 11 17:28:00 tegra-ubuntu kernel: igb 0000:04:00.0: Refused to change power state, currently in D3
Feb 11 17:28:00 tegra-ubuntu kernel: igb 0000:04:00.0: PHY reset is blocked due to SOL/IDER session.
Feb 11 17:28:00 tegra-ubuntu kernel: igb 0000:04:00.0: Invalid MAC Address
Feb 11 17:28:00 tegra-ubuntu kernel: igb: probe of 0000:04:00.0 failed with error -5
Feb 11 17:28:00 tegra-ubuntu kernel: igb 0000:05:00.0: PHY reset is blocked due to SOL/IDER session.
Feb 11 17:28:00 tegra-ubuntu kernel: igb 0000:05:00.0: Invalid MAC Address
Feb 11 17:28:00 tegra-ubuntu kernel: igb: probe of 0000:05:00.0 failed with error -5
Feb 11 17:28:00 tegra-ubuntu kernel: igb 0000:06:00.0: PHY reset is blocked due to SOL/IDER session.
Feb 11 17:28:00 tegra-ubuntu kernel: igb 0000:06:00.0: Invalid MAC Address
Feb 11 17:28:00 tegra-ubuntu kernel: igb: probe of 0000:06:00.0 failed with error -5
Feb 11 17:28:00 tegra-ubuntu kernel: igb 0000:07:00.0: PHY reset is blocked due to SOL/IDER session.
Feb 11 17:28:00 tegra-ubuntu kernel: igb 0000:07:00.0: Invalid MAC Address
Feb 11 17:28:00 tegra-ubuntu kernel: igb: probe of 0000:07:00.0 failed with error -5
Feb 11 17:28:00 tegra-ubuntu kernel: igb 0000:08:00.0: PHY reset is blocked due to SOL/IDER session.
Feb 11 17:28:00 tegra-ubuntu kernel: igb 0000:08:00.0: Invalid MAC Address
Feb 11 17:28:00 tegra-ubuntu kernel: igb: probe of 0000:08:00.0 failed with error -5
Feb 11 17:28:00 tegra-ubuntu kernel: igb 0000:09:00.0: PHY reset is blocked due to SOL/IDER session.
Feb 11 17:28:00 tegra-ubuntu kernel: igb 0000:09:00.0: Invalid MAC Address
Feb 11 17:28:00 tegra-ubuntu kernel: igb: probe of 0000:09:00.0 failed with error -5
Feb 11 17:28:00 tegra-ubuntu kernel: igb 0000:0a:00.0: PHY reset is blocked due to SOL/IDER session.
Feb 11 17:28:00 tegra-ubuntu kernel: igb 0000:0a:00.0: Invalid MAC Address
Feb 11 17:28:00 tegra-ubuntu kernel: igb: probe of 0000:0a:00.0 failed with error -5
Feb 11 17:28:00 tegra-ubuntu kernel: igb 0000:0b:00.0: PHY reset is blocked due to SOL/IDER session.
Feb 11 17:28:00 tegra-ubuntu kernel: igb 0000:0b:00.0: Invalid MAC Address
Feb 11 17:28:00 tegra-ubuntu kernel: igb: probe of 0000:0b:00.0 failed with error -5
Here is the complete list produced by “journalctl -k” because dmesg ran out of buffer space.
errors.txt (2.37 KB)
Auvidea
December 14, 2018, 3:56pm
6
I have tried to put the complete log into a code box, but the log was too large. So I have attached it as a file.
The tests above were performed on the TX1. We also tried a TX2. Here the error messages and the logs are different.
nvidia@tegra-ubuntu:~$ lspci
00:01.0 PCI bridge: NVIDIA Corporation Device 10e5 (rev a1)
04:00.0 Ethernet controller: Intel Corporation I210 Gigabit Network Connection (rev 03)
05:00.0 Ethernet controller: Intel Corporation I210 Gigabit Network Connection (rev 03)
07:00.0 Ethernet controller: Intel Corporation I210 Gigabit Network Connection (rev 03)
08:00.0 Ethernet controller: Intel Corporation I210 Gigabit Network Connection (rev 03)
09:00.0 Ethernet controller: Intel Corporation I210 Gigabit Network Connection (rev 03)
0b:00.0 Ethernet controller: Intel Corporation I210 Gigabit Network Connection (rev 03)
nvidia@tegra-ubuntu:~$ ifconfig
eth0 Link encap:Ethernet HWaddr 00:04:4b:8c:9a:de
inet addr:192.168.0.43 Bcast:192.168.0.255 Mask:255.255.255.0
inet6 addr: fe80::6641:1ea2:f2bd:9557/64 Scope:Link
inet6 addr: fd00::9ed:3595:8b81:8258/64 Scope:Global
inet6 addr: fd00::8da9:e815:f3c0:b570/64 Scope:Global
inet6 addr: 2001:a61:344e:d700:9ed:3595:8b81:8258/64 Scope:Global
inet6 addr: 2001:a61:344e:d700:1f75:15ef:50f9:2259/64 Scope:Global
RX packets:202 errors:0 dropped:0 overruns:0 frame:0
TX packets:132 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:35111 (35.1 KB) TX bytes:22969 (22.9 KB)
Interrupt:43
Memory:50200000-502fffff
eth2 Link encap:Ethernet HWaddr 00:a0:c9:00:00:02
Memory:50500000-505fffff
eth3 Link encap:Ethernet HWaddr 00:a0:c9:00:00:01
Memory:50800000-508fffff
eth4 Link encap:Ethernet HWaddr 00:a0:c9:00:00:06
Memory:50b00000-50bfffff
eth5 Link encap:Ethernet HWaddr 00:a0:c9:00:00:05
Memory:50e00000-50efffff
eth6 Link encap:Ethernet HWaddr 00:a0:c9:00:00:07
Memory:51100000-511fffff
eth7 Link encap:Ethernet HWaddr 00:a0:c9:00:00:03
Memory:51400000-514fffff
eth8 Link encap:Ethernet HWaddr 00:a0:c9:00:00:04
Memory:51700000-517fffff
l4tbr0 Link encap:Ethernet HWaddr 02:da:45:2a:a9:98
inet addr:192.168.55.1 Bcast:192.168.55.255 Mask:255.255.255.0
inet6 addr: fe80::505d:a8ff:fefd:6a52/64 Scope:Link
TX packets:8 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:704 (704.0 B)
RX packets:234 errors:0 dropped:0 overruns:0 frame:0
TX packets:234 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:17606 (17.6 KB) TX bytes:17606 (17.6 KB)
usb0 Link encap:Ethernet HWaddr 02:da:45:2a:a9:98
usb1 Link encap:Ethernet HWaddr 4e:9a:50:ca:13:78
wlan0 Link encap:Ethernet HWaddr 00:04:4b:8c:9a:dc
nvidia@tegra-ubuntu:~$ dmesg | grep igb
[ 2.661988] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.3.0-k
[ 2.661990] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 8.988515] igb 0000:04:00.0: enabling device (0000 -> 0002)
[ 9.021911] igb 0000:04:00.0: added PHC on eth1
[ 9.021914] igb 0000:04:00.0: Intel(R) Gigabit Ethernet Network Connection
[ 9.021918] igb 0000:04:00.0: eth1: (PCIe:2.5Gb/s:Width x1) 00:a0:c9:00:00:00
[ 9.022016] igb 0000:04:00.0: eth1: PBA No: 000300-000
[ 9.022019] igb 0000:04:00.0: Using MSI-X interrupts. 4 rx queue(s), 4 tx queue(s)
[ 9.022220] igb 0000:05:00.0: enabling device (0000 -> 0002)
[ 9.056797] igb 0000:05:00.0: added PHC on eth2
[ 9.056800] igb 0000:05:00.0: Intel(R) Gigabit Ethernet Network Connection
[ 9.056804] igb 0000:05:00.0: eth2: (PCIe:2.5Gb/s:Width x1) 00:a0:c9:00:00:02
[ 9.056895] igb 0000:05:00.0: eth2: PBA No: 000300-000
[ 9.056899] igb 0000:05:00.0: Using MSI-X interrupts. 4 rx queue(s), 4 tx queue(s)
[ 9.057106] igb 0000:06:00.0: enabling device (0000 -> 0002)
[ 9.091316] igb 0000:06:00.0: added PHC on eth3
[ 9.091318] igb 0000:06:00.0: Intel(R) Gigabit Ethernet Network Connection
[ 9.091322] igb 0000:06:00.0: eth3: (PCIe:2.5Gb/s:Width x1) 00:a0:c9:00:00:01
[ 9.091412] igb 0000:06:00.0: eth3: PBA No: 000300-000
[ 9.091415] igb 0000:06:00.0: Using MSI-X interrupts. 4 rx queue(s), 4 tx queue(s)
[ 9.091576] igb 0000:07:00.0: enabling device (0000 -> 0002)
[ 9.132251] igb 0000:07:00.0: added PHC on eth4
[ 9.132254] igb 0000:07:00.0: Intel(R) Gigabit Ethernet Network Connection
[ 9.132258] igb 0000:07:00.0: eth4: (PCIe:2.5Gb/s:Width x1) 00:a0:c9:00:00:06
[ 9.132347] igb 0000:07:00.0: eth4: PBA No: 000300-000
[ 9.132350] igb 0000:07:00.0: Using MSI-X interrupts. 4 rx queue(s), 4 tx queue(s)
[ 9.132550] igb 0000:08:00.0: enabling device (0000 -> 0002)
[ 9.164487] igb 0000:08:00.0: added PHC on eth5
[ 9.164490] igb 0000:08:00.0: Intel(R) Gigabit Ethernet Network Connection
[ 9.164494] igb 0000:08:00.0: eth5: (PCIe:2.5Gb/s:Width x1) 00:a0:c9:00:00:05
[ 9.164598] igb 0000:08:00.0: eth5: PBA No: 000300-000
[ 9.164601] igb 0000:08:00.0: Using MSI-X interrupts. 4 rx queue(s), 4 tx queue(s)
[ 9.164788] igb 0000:09:00.0: enabling device (0000 -> 0002)
[ 9.198576] igb 0000:09:00.0: added PHC on eth6
[ 9.198579] igb 0000:09:00.0: Intel(R) Gigabit Ethernet Network Connection
[ 9.198603] igb 0000:09:00.0: eth6: (PCIe:2.5Gb/s:Width x1) 00:a0:c9:00:00:07
[ 9.198693] igb 0000:09:00.0: eth6: PBA No: 000300-000
[ 9.198696] igb 0000:09:00.0: Using MSI-X interrupts. 4 rx queue(s), 4 tx queue(s)
[ 9.198896] igb 0000:0a:00.0: enabling device (0000 -> 0002)
[ 9.232130] igb 0000:0a:00.0: added PHC on eth7
[ 9.232132] igb 0000:0a:00.0: Intel(R) Gigabit Ethernet Network Connection
[ 9.232136] igb 0000:0a:00.0: eth7: (PCIe:2.5Gb/s:Width x1) 00:a0:c9:00:00:03
[ 9.232225] igb 0000:0a:00.0: eth7: PBA No: 000300-000
[ 9.232228] igb 0000:0a:00.0: Using MSI-X interrupts. 4 rx queue(s), 4 tx queue(s)
[ 9.232390] igb 0000:0b:00.0: enabling device (0000 -> 0002)
[ 9.266234] igb 0000:0b:00.0: added PHC on eth8
[ 9.266236] igb 0000:0b:00.0: Intel(R) Gigabit Ethernet Network Connection
[ 9.266241] igb 0000:0b:00.0: eth8: (PCIe:2.5Gb/s:Width x1) 00:a0:c9:00:00:04
[ 9.266355] igb 0000:0b:00.0: eth8: PBA No: 000300-000
[ 9.266359] igb 0000:0b:00.0: Using MSI-X interrupts. 4 rx queue(s), 4 tx queue(s)
[ 28.766393] igb 0000:04:00.0 eth1: PCIe link lost, device now detached
[ 28.781487] igb 0000:0b:00.0 eth8: PCIe link lost, device now detached
[ 28.826327] igb 0000:05:00.0 eth2: PCIe link lost, device now detached
[ 29.112805] igb 0000:0a:00.0 eth7: PCIe link lost, device now detached
[ 29.158605] igb 0000:06:00.0 eth3: PCIe link lost, device now detached
[ 29.427119] igb 0000:09:00.0 eth6: PCIe link lost, device now detached
[ 29.741281] igb 0000:08:00.0 eth5: PCIe link lost, device now detached
[ 30.055445] igb 0000:07:00.0 eth4: PCIe link lost, device now detached
The complete log is attached as a file.
log_TX2.txt (89.2 KB)
vidyas
September 15, 2019, 9:25am
7
Apologies for not understanding comment #1 correctly. NVMe device is missing in first lspci output clearly.
Is this issue resolved yet?
to me, it looks like there is something wrong with the switch operation as the device that is not getting enumerated (NVMe) is downstream of the switch. Could it be that switch is getting overheated? (Typically it is the case with PCIe switches). Did you try keeping a fan on it?
