L4T R24.2 PCIe IOMMU not working when switches (bridges) are present
Hi.
Latest L4T release enabled IOMMU for PCIe which broke PCIe DMA transfers on some systems. Specifically when PCIe device is connected through PCIe bridge/switch (so not directly into Tegra itself) no IOVA mappings are created for its driver. Simple workaround is to disable IOMMU for PCIe controller by removing iommus line from pcie-controller block in DTS. To create a real fix I’ve tracked down the issue to this commit:
http://nv-tegra.nvidia.com/gitweb/?p=linux-3.10.git;a=blobdiff;f=drivers/iommu/of_tegra-smmu.c;h=af6c752d31f1375f201ef2660d61ded9fb1b0034;hp=d71e89cd61350ca59babd3630398aa60bdf494a5;hb=518f4f35043435f1f32c9d5eae8f2a2b027b6a77;hpb=907c35d9d62d5fc03e509bf5a011ac00e5d30a5a
And created the following patch:
From 801177535081e1b8bf286cbc2c2cf0c06c93f9b9 Mon Sep 17 00:00:00 2001
Date: Fri, 23 Sep 2016 11:29:00 +0200
Subject: [PATCH] iommu/tegra: of: use root bus node to find stream id for PCIe
If there are bridges in PCIe tolopology then parent node isn't
necessarily a root bus, so loop all the way to the top instead of doing
just one step.
Fixes creation of IOMMU mappings for such PCIe configurations.
 drivers/iommu/of_tegra-smmu.c | 4 +++-
 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/drivers/iommu/of_tegra-smmu.c b/drivers/iommu/of_tegra-smmu.c
index af6c752..72bea5b 100644
--- a/drivers/iommu/of_tegra-smmu.c
+++ b/drivers/iommu/of_tegra-smmu.c
@@ -168,8 +168,10 @@ u64 tegra_smmu_of_get_swgids(struct device *dev,
        if (dev_is_pci(dev)) {
                struct pci_bus *bus = to_pci_dev(dev)->bus;
-               if (!pci_is_root_bus(bus))
+               while (!pci_is_root_bus(bus)) {
                        dev = bus->bridge;
+                       bus = to_pci_dev(dev)->bus;
                np = of_get_parent(dev->of_node);
2.0.4
Please consider including it into next release. This change helps for described cases and doesn’t break directly connected devices.
FYI, here’s lspci -vvv output for such PCIe configuration:
00:01.0 PCI bridge: NVIDIA Corporation Device 0fae (rev a1) (prog-if 00 [Normal decode])
	Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx-
	Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Latency: 0, Cache Line Size: 64 bytes
	Interrupt: pin A routed to IRQ 130
	Bus: primary=00, secondary=01, subordinate=05, sec-latency=0
	I/O behind bridge: 00001000-00001fff
	Memory behind bridge: 13000000-132fffff
	Prefetchable memory behind bridge: 0000000020000000-00000000203fffff
	Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
	BridgeCtl: Parity+ SERR- NoISA- VGA- MAbort- >Reset- FastB2B-
		PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
	Capabilities: [40] Subsystem: NVIDIA Corporation Device 0000
	Capabilities: [48] Power Management version 3
		Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1+,D2+,D3hot+,D3cold+)
		Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME-
	Capabilities: [50] MSI: Enable- Count=1/2 Maskable- 64bit+
		Address: 0000000000000000  Data: 0000
	Capabilities: [60] HyperTransport: MSI Mapping Enable- Fixed-
		Mapping Address Base: 00000000fee00000
	Capabilities: [80] Express (v2) Root Port (Slot+), MSI 00
		DevCap:	MaxPayload 128 bytes, PhantFunc 0
			ExtTag+ RBE+
		DevCtl:	Report errors: Correctable+ Non-Fatal+ Fatal+ Unsupported+
			RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+
			MaxPayload 128 bytes, MaxReadReq 512 bytes
		DevSta:	CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend-
		LnkCap:	Port #0, Speed 5GT/s, Width x4, ASPM L0s L1, Exit Latency L0s <512ns, L1 <4us
			ClockPM- Surprise- LLActRep+ BwNot+ ASPMOptComp-
		LnkCtl:	ASPM L1 Enabled; RCB 64 bytes Disabled- CommClk-
			ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
		LnkSta:	Speed 5GT/s, Width x4, TrErr- Train- SlotClk+ DLActive+ BWMgmt- ABWMgmt-
		SltCap:	AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug- Surprise-
			Slot #0, PowerLimit 0.000W; Interlock- NoCompl-
		SltCtl:	Enable: AttnBtn- PwrFlt- MRL- PresDet- CmdCplt- HPIrq- LinkChg-
			Control: AttnInd Off, PwrInd On, Power- Interlock-
		SltSta:	Status: AttnBtn- PowerFlt- MRL- CmdCplt- PresDet+ Interlock-
			Changed: MRL- PresDet+ LinkState+
		RootCtl: ErrCorrectable- ErrNon-Fatal- ErrFatal- PMEIntEna+ CRSVisible-
		RootCap: CRSVisible-
		RootSta: PME ReqID 0000, PMEStatus- PMEPending-
		DevCap2: Completion Timeout: Range AB, TimeoutDis+, LTR+, OBFF Not Supported ARIFwd-
		DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR+, OBFF Disabled ARIFwd-
		LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis-
			 Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
			 Compliance De-emphasis: -6dB
		LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete-, EqualizationPhase1-
			 EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
	Capabilities: [100 v1] Advanced Error Reporting
		UESta:	DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
		UEMsk:	DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
		UESvrt:	DLP+ SDES- TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
		CESta:	RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
		CEMsk:	RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
		AERCap:	First Error Pointer: 00, GenCap+ CGenEn- ChkCap+ ChkEn-
	Capabilities: [140 v1] L1 PM Substates
		L1SubCap: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2+ ASPM_L1.1+ L1_PM_Substates+
			  PortCommonModeRestoreTime=30us PortTPowerOnTime=70us
	Kernel driver in use: pcieport
01:00.0 PCI bridge: PLX Technology, Inc. PEX 8612 12-lane, 4-Port PCI Express Gen 2 (5.0 GT/s) Switch (rev bb) (prog-if 00 [Normal decode])
	Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx+
	Interrupt: pin A routed to IRQ 547
	Region 0: Memory at 13200000 (32-bit, non-prefetchable)
	Bus: primary=01, secondary=02, subordinate=05, sec-latency=0
	Memory behind bridge: 13000000-131fffff
	Capabilities: [40] Power Management version 3
		Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
		Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
	Capabilities: [48] MSI: Enable+ Count=1/4 Maskable+ 64bit+
		Address: 000000017c4f0000  Data: 0000
		Masking: 0000000f  Pending: 00000000
	Capabilities: [68] Express (v2) Upstream Port, MSI 00
		DevCap:	MaxPayload 2048 bytes, PhantFunc 0
			ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ SlotPowerLimit 0.000W
		DevCtl:	Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
			RlxdOrd- ExtTag- PhantFunc- AuxPwr- NoSnoop-
			MaxPayload 128 bytes, MaxReadReq 128 bytes
		LnkCap:	Port #5, Speed 5GT/s, Width x4, ASPM L0s L1, Exit Latency L0s <1us, L1 <2us
			ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp-
		LnkCtl:	ASPM L1 Enabled; Disabled- CommClk-
		LnkSta:	Speed 5GT/s, Width x4, TrErr- Train- SlotClk- DLActive- BWMgmt- ABWMgmt-
		DevCap2: Completion Timeout: Not Supported, TimeoutDis-, LTR-, OBFF Not Supported
		DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled
	Capabilities: [a4] Subsystem: PLX Technology, Inc. PEX 8612 12-lane, 4-Port PCI Express Gen 2 (5.0 GT/s) Switch
	Capabilities: [100 v1] Device Serial Number aa-86-00-10-b5-df-0e-00
	Capabilities: [fb4 v1] Advanced Error Reporting
		UESvrt:	DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
		CESta:	RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
		AERCap:	First Error Pointer: 1f, GenCap+ CGenEn- ChkCap+ ChkEn-
	Capabilities: [138 v1] Power Budgeting <?>
	Capabilities: [148 v1] Virtual Channel
		Caps:	LPEVC=0 RefClk=100ns PATEntryBits=1
		Arb:	Fixed- WRR32- WRR64- WRR128-
		Ctrl:	ArbSelect=Fixed
		Status:	InProgress-
		VC0:	Caps:	PATOffset=00 MaxTimeSlots=1 RejSnoopTrans-
			Arb:	Fixed+ WRR32- WRR64- WRR128- TWRR128- WRR256-
			Ctrl:	Enable+ ID=0 ArbSelect=Fixed TC/VC=ff
			Status:	NegoPending- InProgress-
	Capabilities: [950 v1] Vendor Specific Information: ID=0001 Rev=0 Len=010 <?>
02:00.0 PCI bridge: PLX Technology, Inc. PEX 8612 12-lane, 4-Port PCI Express Gen 2 (5.0 GT/s) Switch (rev bb) (prog-if 00 [Normal decode])
	Interrupt: pin A routed to IRQ 548
	Bus: primary=02, secondary=03, subordinate=03, sec-latency=0
	I/O behind bridge: 0000f000-00000fff
	Memory behind bridge: fff00000-000fffff
	Prefetchable memory behind bridge: 0000000020000000-00000000200fffff
		Address: 000000017c4f0000  Data: 0001
	Capabilities: [68] Express (v2) Downstream Port (Slot+), MSI 00
			ExtTag- RBE+
		LnkCap:	Port #0, Speed 5GT/s, Width x4, ASPM L0s L1, Exit Latency L0s <1us, L1 <2us
			ClockPM- Surprise+ LLActRep+ BwNot+ ASPMOptComp-
		LnkCtl:	ASPM Disabled; Disabled- CommClk-
		LnkSta:	Speed 5GT/s, Width x2, TrErr- Train- SlotClk- DLActive+ BWMgmt+ ABWMgmt-
			Slot #112, PowerLimit 25.000W; Interlock- NoCompl-
			Control: AttnInd Unknown, PwrInd Unknown, Power- Interlock-
		DevCap2: Completion Timeout: Not Supported, TimeoutDis-, LTR-, OBFF Not Supported ARIFwd+
		DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled ARIFwd-
		LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis-, Selectable De-emphasis: -6dB
		Caps:	LPEVC=0 RefClk=100ns PATEntryBits=4
		Status:	InProgress-
		VC0:	Caps:	PATOffset=06 MaxTimeSlots=1 RejSnoopTrans-
			Arb:	Fixed- WRR32+ WRR64- WRR128- TWRR128- WRR256-
			Ctrl:	Enable+ ID=0 ArbSelect=WRR32 TC/VC=ff
			Port Arbitration Table <?>
	Capabilities: [448 v1] Vendor Specific Information: ID=0000 Rev=0 Len=0cc <?>
	Capabilities: [520 v1] Access Control Services
		ACSCap:	SrcValid+ TransBlk+ ReqRedir+ CmpltRedir+ UpstreamFwd+ EgressCtrl+ DirectTrans+
		ACSCtl:	SrcValid- TransBlk- ReqRedir- CmpltRedir- UpstreamFwd- EgressCtrl- DirectTrans-
02:01.0 PCI bridge: PLX Technology, Inc. PEX 8612 12-lane, 4-Port PCI Express Gen 2 (5.0 GT/s) Switch (rev bb) (prog-if 00 [Normal decode])
	Interrupt: pin A routed to IRQ 549
	Bus: primary=02, secondary=04, subordinate=04, sec-latency=0
	Prefetchable memory behind bridge: 0000000020100000-00000000203fffff
		Address: 000000017c4f0000  Data: 0002
			ExtTag- RBE+
		LnkCap:	Port #1, Speed 5GT/s, Width x4, ASPM L0s L1, Exit Latency L0s <1us, L1 <2us
		SltCap:	AttnBtn+ PwrCtrl+ MRL+ AttnInd+ PwrInd+ HotPlug+ Surprise-
			Slot #113, PowerLimit 25.000W; Interlock- NoCompl-
			Control: AttnInd Unknown, PwrInd Unknown, Power+ Interlock-
		SltSta:	Status: AttnBtn- PowerFlt- MRL+ CmdCplt+ PresDet+ Interlock-
			Changed: MRL- PresDet- LinkState-
		Status:	InProgress-
02:04.0 PCI bridge: PLX Technology, Inc. PEX 8612 12-lane, 4-Port PCI Express Gen 2 (5.0 GT/s) Switch (rev bb) (prog-if 00 [Normal decode])
	Interrupt: pin A routed to IRQ 550
	Bus: primary=02, secondary=05, subordinate=05, sec-latency=0
	Prefetchable memory behind bridge: 00000000fff00000-00000000000fffff
		Address: 000000017c4f0000  Data: 0003
			ExtTag- RBE+
		LnkCap:	Port #4, Speed 5GT/s, Width x8, ASPM L0s L1, Exit Latency L0s <2us, L1 <4us
		LnkSta:	Speed 2.5GT/s, Width x0, TrErr- Train- SlotClk- DLActive- BWMgmt- ABWMgmt-
			Slot #116, PowerLimit 25.000W; Interlock- NoCompl-
		SltSta:	Status: AttnBtn- PowerFlt- MRL- CmdCplt- PresDet- Interlock-
		Status:	InProgress-
			Status:	NegoPending+ InProgress-
03:00.0 Memory controller: XIMEA Camera MT (rev 70)
	Subsystem: XIMEA Camera MT
	Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx+
	Interrupt: pin A routed to IRQ 553
	Region 0: Memory at 20000000 (64-bit, prefetchable)
	Region 2: Memory at 20001000 (64-bit, prefetchable)
		Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1+,D2+,D3hot+,D3cold-)
	Capabilities: [48] MSI: Enable+ Count=1/1 Maskable- 64bit+
		Address: 000000017c4f0000  Data: 0004
	Capabilities: [60] Express (v2) Endpoint, MSI 00
		DevCap:	MaxPayload 512 bytes, PhantFunc 0, Latency L0s <64ns, L1 unlimited
			ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset-
		LnkCap:	Port #0, Speed 5GT/s, Width x2, ASPM L0s, Exit Latency L0s unlimited, L1 unlimited
		LnkCtl:	ASPM Disabled; RCB 64 bytes Disabled- CommClk-
		LnkSta:	Speed 5GT/s, Width x2, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
		DevCap2: Completion Timeout: Range B, TimeoutDis-, LTR-, OBFF Not Supported
	Capabilities: [100 v1] Device Serial Number 00-00-00-00-00-00-00-00
	Kernel driver in use: ximea_cam_pcie
04:00.0 Memory controller: XIMEA Camera CB (rev 70)
	Subsystem: XIMEA Camera CB
	Interrupt: pin A routed to IRQ 554
	Region 0: Memory at 20100000 (64-bit, prefetchable)
	Region 2: Memory at 20101000 (64-bit, prefetchable)
		Address: 000000017c4f0000  Data: 0005
P.S.
Also in this L4T release wget seems to have broken SSL support, it only works with --no-check-certificate option (curl works fine).
0001-iommu-tegra-of-use-root-bus-node-to-find-stream-id-f.patch.txt (1.01 KB)
lspci.log (23.7 KB)
Hi parafin,
Thanks for your finding, we will merge this patch into the coming release.
Hi
we are using a PCIe video frame grabber and we have the ame problem.
This patch is critical for us.
Is this patch is merged into version 24.2.1?
If not, how soon is the coming release?
Yossi
No, it’s not in 24.2.1 release: nv-tegra.nvidia Code Review - linux-3.10.git/shortlog
L4T R24.2.1 was released before the comment by kayccc was posted.
Thank you Parafin for sharing.
