Hi vidyas,
I’ll try to provide some additional information to answer your questions.
lspci Output
This is the full output of sudo lspci -vvv
0005:00:00.0 PCI bridge: NVIDIA Corporation Device 1ad0 (rev a1) (prog-if 00 [Normal decode])
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
Interrupt: pin A routed to IRQ 35
Bus: primary=00, secondary=01, subordinate=ff, sec-latency=0
I/O behind bridge: 00000000-00003fff
Memory behind bridge: 40000000-407fffff
Prefetchable memory behind bridge: 0000001c00000000-0000001c007fffff
Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort+ <SERR- <PERR-
BridgeCtl: Parity- SERR- NoISA- VGA- MAbort- >Reset- FastB2B-
PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
Capabilities: [40] Power Management version 3
Flags: PMEClk- DSI- D1- D2- AuxCurrent=375mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [50] MSI: Enable- Count=1/1 Maskable+ 64bit+
Address: 0000000000000000 Data: 0000
Masking: 00000000 Pending: 00000000
Capabilities: [70] Express (v2) Root Port (Slot-), MSI 00
DevCap: MaxPayload 256 bytes, PhantFunc 0
ExtTag- RBE+
DevCtl: Report errors: Correctable+ Non-Fatal+ Fatal+ Unsupported+
RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+
MaxPayload 128 bytes, MaxReadReq 512 bytes
DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr+ TransPend-
LnkCap: Port #0, Speed 16GT/s, Width x8, ASPM not supported, Exit Latency L0s <1us, L1 <64us
ClockPM- Surprise+ LLActRep+ BwNot+ ASPMOptComp+
LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk-
ExtSynch- ClockPM- AutWidDis- BWInt+ AutBWInt-
LnkSta: Speed 5GT/s, Width x4, TrErr- Train- SlotClk+ DLActive+ BWMgmt- ABWMgmt+
RootCtl: ErrCorrectable- ErrNon-Fatal- ErrFatal- PMEIntEna+ CRSVisible+
RootCap: CRSVisible+
RootSta: PME ReqID 0000, PMEStatus- PMEPending-
DevCap2: Completion Timeout: Range ABCD, TimeoutDis+, LTR+, OBFF Not Supported ARIFwd-
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR+, OBFF Disabled ARIFwd-
LnkCtl2: Target Link Speed: 16GT/s, EnterCompliance- SpeedDis-
Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
Compliance De-emphasis: -6dB
LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete-, EqualizationPhase1-
EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
Capabilities: [b0] MSI-X: Enable- Count=8 Masked-
Vector table: BAR=2 offset=00000000
PBA: BAR=2 offset=00010000
Capabilities: [100 v2] Advanced Error Reporting
UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
AERCap: First Error Pointer: 00, GenCap+ CGenEn- ChkCap+ ChkEn-
Capabilities: [148 v1] #19
Capabilities: [168 v1] #26
Capabilities: [190 v1] #27
Capabilities: [1c0 v1] L1 PM Substates
L1SubCap: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2- ASPM_L1.1- L1_PM_Substates+
PortCommonModeRestoreTime=60us PortTPowerOnTime=40us
L1SubCtl1: PCI-PM_L1.2- PCI-PM_L1.1- ASPM_L1.2- ASPM_L1.1-
T_CommonMode=10us
L1SubCtl2: T_PwrOn=10us
Capabilities: [1d0 v1] Vendor Specific Information: ID=0002 Rev=4 Len=100 <?>
Capabilities: [2d0 v1] Vendor Specific Information: ID=0001 Rev=1 Len=038 <?>
Capabilities: [308 v1] #25
Capabilities: [314 v1] Precision Time Measurement
PTMCap: Requester:+ Responder:+ Root:+
PTMClockGranularity: 16ns
PTMControl: Enabled:- RootSelected:-
PTMEffectiveGranularity: Unknown
Capabilities: [320 v1] Vendor Specific Information: ID=0004 Rev=1 Len=054 <?>
Kernel driver in use: pcieport
0005:01:00.0 PCI bridge: Pericom Semiconductor PI7C9X2G608GP PCIe2 6-Port/8-Lane Packet Switch (prog-if 00 [Normal decode])
Latency: 0
Bus: primary=01, secondary=02, subordinate=06, sec-latency=0
I/O behind bridge: 3a100000-3a103fff
Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
Flags: PMEClk- DSI- D1+ D2+ AuxCurrent=375mA PME(D0+,D1+,D2+,D3hot+,D3cold+)
Capabilities: [5c] Vital Product Data
pcilib: sysfs_read_vpd: read failed: Input/output error
Not readable
Capabilities: [64] Vendor Specific Information: Len=34 <?>
Capabilities: [b0] Subsystem: Device 0000:0000
Capabilities: [c0] Express (v2) Upstream Port, MSI 00
ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ SlotPowerLimit 0.000W
DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
RlxdOrd- ExtTag- PhantFunc- AuxPwr- NoSnoop-
MaxPayload 128 bytes, MaxReadReq 128 bytes
DevSta: CorrErr+ UncorrErr- FatalErr- UnsuppReq+ AuxPwr+ TransPend-
LnkCap: Port #0, Speed 5GT/s, Width x4, ASPM not supported, Exit Latency L0s <512ns, L1 <1us
ClockPM+ Surprise- LLActRep- BwNot- ASPMOptComp-
LnkCtl: ASPM Disabled; Disabled- CommClk-
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 5GT/s, Width x4, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Not Supported, TimeoutDis-, LTR+, OBFF Not Supported
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled
LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis-
Capabilities: [100 v1] Advanced Error Reporting
UESvrt: DLP+ SDES- TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
Capabilities: [140 v1] Virtual Channel
Caps: LPEVC=0 RefClk=100ns PATEntryBits=4
Arb: Fixed- WRR32- WRR64- WRR128-
Ctrl: ArbSelect=Fixed
Status: InProgress-
VC0: Caps: PATOffset=04 MaxTimeSlots=64 RejSnoopTrans-
Arb: Fixed+ WRR32- WRR64- WRR128+ TWRR128- WRR256-
Ctrl: Enable+ ID=0 ArbSelect=Fixed TC/VC=ff
Status: NegoPending- InProgress-
Port Arbitration Table <?>
Capabilities: [20c v1] Power Budgeting <?>
Capabilities: [230 v1] Latency Tolerance Reporting
Max snoop latency: 0ns
Max no snoop latency: 0ns
Capabilities: [240 v1] L1 PM Substates
L1SubCap: PCI-PM_L1.2- PCI-PM_L1.1+ ASPM_L1.2- ASPM_L1.1- L1_PM_Substates+
L1SubCtl2:
0005:02:01.0 PCI bridge: Pericom Semiconductor PI7C9X2G608GP PCIe2 6-Port/8-Lane Packet Switch (prog-if 00 [Normal decode])
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx+
Latency: 0
Interrupt: pin A routed to IRQ 555
Bus: primary=02, secondary=03, subordinate=03, sec-latency=0
I/O behind bridge: 3a100000-3a100fff
Memory behind bridge: 40000000-401fffff
Prefetchable memory behind bridge: 0000001c00000000-0000001c001fffff
Capabilities: [4c] MSI: Enable+ Count=1/1 Maskable- 64bit+
Address: 00000000fffff000 Data: 0000
Capabilities: [c0] Express (v2) Downstream Port (Slot+), MSI 00
ExtTag- RBE+
LnkCap: Port #1, Speed 5GT/s, Width x1, ASPM not supported, Exit Latency L0s <512ns, L1 <1us
ClockPM- Surprise- LLActRep+ BwNot+ ASPMOptComp-
LnkSta: Speed 5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive+ BWMgmt- ABWMgmt-
SltCap: AttnBtn+ PwrCtrl+ MRL+ AttnInd+ PwrInd+ HotPlug+ Surprise-
Slot #0, PowerLimit 25.000W; Interlock- NoCompl-
SltCtl: Enable: AttnBtn- PwrFlt- MRL- PresDet- CmdCplt- HPIrq- LinkChg-
Control: AttnInd Off, PwrInd On, Power- Interlock-
SltSta: Status: AttnBtn- PowerFlt- MRL- CmdCplt+ PresDet+ Interlock-
Changed: MRL- PresDet- LinkState+
DevCap2: Completion Timeout: Not Supported, TimeoutDis-, LTR+, OBFF Not Supported ARIFwd-
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled ARIFwd-
LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis-, Selectable De-emphasis: -3.5dB
LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete-, EqualizationPhase1-
Status: InProgress-
Capabilities: [220 v1] Access Control Services
ACSCap: SrcValid+ TransBlk+ ReqRedir+ CmpltRedir+ UpstreamFwd+ EgressCtrl+ DirectTrans+
ACSCtl: SrcValid- TransBlk- ReqRedir- CmpltRedir- UpstreamFwd- EgressCtrl- DirectTrans-
L1SubCtl2:
0005:02:02.0 PCI bridge: Pericom Semiconductor PI7C9X2G608GP PCIe2 6-Port/8-Lane Packet Switch (prog-if 00 [Normal decode])
Latency: 0
Interrupt: pin A routed to IRQ 556
Bus: primary=02, secondary=04, subordinate=04, sec-latency=0
I/O behind bridge: 3a101000-3a101fff
Memory behind bridge: 40200000-403fffff
Prefetchable memory behind bridge: 0000001c00200000-0000001c003fffff
Address: 00000000fffff000 Data: 0001
ExtTag- RBE+
LnkCap: Port #2, Speed 5GT/s, Width x1, ASPM not supported, Exit Latency L0s <512ns, L1 <1us
Status: InProgress-
L1SubCtl2:
0005:02:03.0 PCI bridge: Pericom Semiconductor PI7C9X2G608GP PCIe2 6-Port/8-Lane Packet Switch (prog-if 00 [Normal decode])
Latency: 0
Interrupt: pin A routed to IRQ 557
Bus: primary=02, secondary=05, subordinate=05, sec-latency=0
I/O behind bridge: 3a102000-3a102fff
Memory behind bridge: 40400000-405fffff
Prefetchable memory behind bridge: 0000001c00400000-0000001c005fffff
Address: 00000000fffff000 Data: 0002
ExtTag- RBE+
LnkCap: Port #3, Speed 5GT/s, Width x1, ASPM not supported, Exit Latency L0s <512ns, L1 <1us
Status: InProgress-
L1SubCtl2:
0005:02:04.0 PCI bridge: Pericom Semiconductor PI7C9X2G608GP PCIe2 6-Port/8-Lane Packet Switch (prog-if 00 [Normal decode])
Latency: 0
Interrupt: pin A routed to IRQ 558
Bus: primary=02, secondary=06, subordinate=06, sec-latency=0
I/O behind bridge: 3a103000-3a103fff
Memory behind bridge: 40600000-407fffff
Prefetchable memory behind bridge: 0000001c00600000-0000001c007fffff
Address: 00000000fffff000 Data: 0003
ExtTag- RBE+
LnkCap: Port #4, Speed 5GT/s, Width x1, ASPM not supported, Exit Latency L0s <512ns, L1 <1us
Status: InProgress-
L1SubCtl2:
0005:03:00.0 System peripheral: Device 1ac1:089a (prog-if ff)
Subsystem: Device 1ac1:089a
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Latency: 0
Region 0: Memory at 1c00100000 (64-bit, prefetchable) [size=16K]
Region 2: Memory at 1c00000000 (64-bit, prefetchable) [size=1M]
Capabilities: [80] Express (v2) Endpoint, MSI 00
DevCap: MaxPayload 256 bytes, PhantFunc 0, Latency L0s <64ns, L1 <1us
ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset- SlotPowerLimit 25.000W
RlxdOrd+ ExtTag+ PhantFunc- AuxPwr- NoSnoop+
DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend-
LnkCap: Port #1, Speed 5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <64ns, L1 <1us
ClockPM+ Surprise- LLActRep- BwNot- ASPMOptComp+
LnkSta: Speed 5GT/s, Width x1, TrErr- Train- SlotClk- DLActive- BWMgmt- ABWMgmt-
Capabilities: [d0] MSI-X: Enable+ Count=128 Masked-
Vector table: BAR=2 offset=00046800
PBA: BAR=2 offset=00046068
Capabilities: [e0] MSI: Enable- Count=1/32 Maskable- 64bit+
Capabilities: [f8] Power Management version 3
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
Capabilities: [100 v1] Vendor Specific Information: ID=1556 Rev=1 Len=008 <?>
Capabilities: [108 v1] Latency Tolerance Reporting
Capabilities: [110 v1] L1 PM Substates
L1SubCap: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2+ ASPM_L1.1+ L1_PM_Substates+
PortCommonModeRestoreTime=10us PortTPowerOnTime=10us
T_CommonMode=0us LTR1.2_Threshold=0ns
Capabilities: [200 v2] Advanced Error Reporting
UESvrt: DLP+ SDES- TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP+ ECRC- UnsupReq- ACSViol-
Kernel driver in use: apex
Kernel modules: apex
0005:04:00.0 System peripheral: Device 1ac1:089a (prog-if ff)
Latency: 0
Region 0: Memory at 1c00300000 (64-bit, prefetchable) [size=16K]
Region 2: Memory at 1c00200000 (64-bit, prefetchable) [size=1M]
0005:05:00.0 System peripheral: Device 1ac1:089a (prog-if ff)
Latency: 0
Region 0: Memory at 1c00500000 (64-bit, prefetchable) [size=16K]
Region 2: Memory at 1c00400000 (64-bit, prefetchable) [size=1M]
0005:06:00.0 Non-Volatile memory controller: Device 1987:5013 (rev 01) (prog-if 02 [NVM Express])
Subsystem: Device 1987:5013
Latency: 0
Region 0: Memory at 1f40600000 (64-bit, non-prefetchable) [size=16K]
DevCap: MaxPayload 256 bytes, PhantFunc 0, Latency L0s unlimited, L1 unlimited
ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset+ SlotPowerLimit 25.000W
RlxdOrd+ ExtTag+ PhantFunc- AuxPwr- NoSnoop+ FLReset-
LnkCap: Port #1, Speed 8GT/s, Width x4, ASPM not supported, Exit Latency L0s unlimited, L1 unlimited
ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp+
LnkSta: Speed 5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
LnkCtl2: Target Link Speed: 8GT/s, EnterCompliance- SpeedDis-
Capabilities: [d0] MSI-X: Enable+ Count=9 Masked-
Vector table: BAR=0 offset=00002000
PBA: BAR=0 offset=00003000
Capabilities: [e0] MSI: Enable- Count=1/8 Maskable- 64bit+
Capabilities: [100 v1] Latency Tolerance Reporting
AERCap: First Error Pointer: 00, GenCap- CGenEn- ChkCap+ ChkEn-
Capabilities: [300 v1] #19
Kernel driver in use: nvme
We also enabled extended error reporting including correctable errors, so there is now some more information in the kernel log:
[ 60.495458] nvgpu: 17000000.gv11b railgate_enable_store:297 [INFO] railgate is disabled.
[35694.062504] pcieport 0005:01:00.0: invalid large VPD tag 7f at offset 0
[38906.635124] pcieport 0005:00:00.0: AER: Corrected error received: id=0000
[38906.635144] pcieport 0005:00:00.0: PCIe Bus Error: severity=Corrected, type=Transaction Layer, id=0000(Receiver ID)
[38906.635586] pcieport 0005:00:00.0: device [10de:1ad0] error status/mask=0000a000/00000000
[38906.635891] pcieport 0005:00:00.0: [13] Advisory Non-Fatal
[38906.636141] pcieport 0005:00:00.0: [15] Header Log Overflow
[38906.636356] pcieport 0005:00:00.0: AER: Uncorrected (Non-Fatal) error received: id=0000
[38906.636377] pcieport 0005:00:00.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0000(Requester ID)
[38906.636650] pcieport 0005:00:00.0: device [10de:1ad0] error status/mask=00014000/00400000
[38906.636962] pcieport 0005:00:00.0: [14] Completion Timeout (First)
[38906.637136] pcieport 0005:00:00.0: [16] Unexpected Completion
[38906.637288] pcieport 0005:00:00.0: TLP Header: 00000000 00000000 00000000 00000000
[38906.637714] pcieport 0005:00:00.0: broadcast error_detected message
[38906.637739] pcieport 0005:00:00.0: AER: Device recovery failed
[38906.718021] pcieport 0005:00:00.0: AER: Multiple Corrected error received: id=0000
[38906.807267] pcieport 0005:00:00.0: PCIe Bus Error: severity=Corrected, type=Transaction Layer, id=0000(Receiver ID)
[38906.807716] pcieport 0005:00:00.0: device [10de:1ad0] error status/mask=0000a000/00000000
[38906.808234] pcieport 0005:00:00.0: [13] Advisory Non-Fatal
[38906.808432] pcieport 0005:00:00.0: [15] Header Log Overflow
[38906.808664] pcieport 0005:00:00.0: AER: Uncorrected (Non-Fatal) error received: id=0000
[38906.808684] pcieport 0005:00:00.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0000(Requester ID)
[38906.809008] pcieport 0005:00:00.0: device [10de:1ad0] error status/mask=00014000/00400000
[38906.809208] pcieport 0005:00:00.0: [14] Completion Timeout (First)
[38906.809376] pcieport 0005:00:00.0: [16] Unexpected Completion
[38906.809679] pcieport 0005:00:00.0: TLP Header: 00000000 00000000 00000000 00000000
[38906.809917] pcieport 0005:00:00.0: broadcast error_detected message
[38906.809943] pcieport 0005:00:00.0: AER: Device recovery failed
[38906.809950] pcieport 0005:00:00.0: AER: Multiple Corrected error received: id=0000
[38906.810195] pcieport 0005:00:00.0: can't find device of ID0000
[38906.810201] pcieport 0005:00:00.0: AER: Uncorrected (Non-Fatal) error received: id=0000
[38906.810219] pcieport 0005:00:00.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0000(Requester ID)
[38906.810515] pcieport 0005:00:00.0: device [10de:1ad0] error status/mask=00014000/00400000
[38906.810752] pcieport 0005:00:00.0: [14] Completion Timeout (First)
[38906.815221] pcieport 0005:00:00.0: [16] Unexpected Completion
[38906.821711] pcieport 0005:00:00.0: TLP Header: 00000000 00000000 00000000 00000000
[38906.829777] pcieport 0005:00:00.0: broadcast error_detected message
[38906.829831] pcieport 0005:00:00.0: AER: Device recovery failed
[39124.746257] pcieport 0005:00:00.0: AER: Multiple Corrected error received: id=0000
[39124.746505] pcieport 0005:00:00.0: PCIe Bus Error: severity=Corrected, type=Transaction Layer, id=0000(Receiver ID)
[39124.746965] pcieport 0005:00:00.0: device [10de:1ad0] error status/mask=0000a000/00000000
[39124.747250] pcieport 0005:00:00.0: [13] Advisory Non-Fatal
[39124.747427] pcieport 0005:00:00.0: [15] Header Log Overflow
[39124.747660] pcieport 0005:00:00.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0000
[39124.747772] pcieport 0005:00:00.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0000(Requester ID)
[39124.748069] pcieport 0005:00:00.0: device [10de:1ad0] error status/mask=00014000/00400000
[39124.748263] pcieport 0005:00:00.0: [14] Completion Timeout (First)
[39124.748451] pcieport 0005:00:00.0: [16] Unexpected Completion
[39124.748668] pcieport 0005:00:00.0: TLP Header: 00000000 00000000 00000000 00000000
[39124.748870] pcieport 0005:00:00.0: broadcast error_detected message
[39124.748888] pcieport 0005:00:00.0: AER: Device recovery failed
[39124.748893] pcieport 0005:00:00.0: AER: Multiple Corrected error received: id=0000
[39124.749000] pcieport 0005:00:00.0: can't find device of ID0000
[39130.112813] apex 0005:05:00.0: Apex performance not throttled due to temperature
[39130.115003] pcieport 0005:00:00.0: AER: Multiple Corrected error received: id=0000
[39130.131757] pcieport 0005:00:00.0: PCIe Bus Error: severity=Corrected, type=Transaction Layer, id=0000(Receiver ID)
[39130.132122] pcieport 0005:00:00.0: device [10de:1ad0] error status/mask=0000a000/00000000
[39130.132327] pcieport 0005:00:00.0: [13] Advisory Non-Fatal
[39130.132497] pcieport 0005:00:00.0: [15] Header Log Overflow
[39130.132672] pcieport 0005:00:00.0: AER: Uncorrected (Non-Fatal) error received: id=0000
[39130.132694] pcieport 0005:00:00.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0000(Requester ID)
[39130.133048] pcieport 0005:00:00.0: device [10de:1ad0] error status/mask=00014000/00400000
[39130.133344] pcieport 0005:00:00.0: [14] Completion Timeout (First)
[39130.133518] pcieport 0005:00:00.0: [16] Unexpected Completion
[39130.133664] pcieport 0005:00:00.0: TLP Header: 00000000 00000000 00000000 00000000
[39130.133880] pcieport 0005:00:00.0: broadcast error_detected message
[39130.133903] pcieport 0005:00:00.0: AER: Device recovery failed
Clocking Architecture
All devices including the PCIe Switch ar receiveing the REFCLK from Tegra.
In detail the clocking architecture in hardware is implemented as follows:
- The source of PCIe REFCLK is PCIE0_CLK* from Tegra module pins 160+162.
- The PCIE0_CLKREQ pin is confiured via 10R to GND for standard enabled.
- Decoupled via 100nF the PCIECLK is fed into the PCIe switch (PERICOM PI7C9X2G608GP) clock distribution buffer input REFCLKI*.
- The used buffered 6 clk outputs of the switch are distributed to the relevant PCIe CLKREFs
- 2x PHY of the Switch itself (standard enabled)
- 4x M.2 Cards (enabled via each M.2’s CLKREQ)
- The REFCLKOP/N[6] of the PCIe-switch is unused (refer to datasheet)
- each clk output 100nF decoupled and HCSL terminated
- The SWG_LVL can be high or low → no difference in the generated errors, CLKBUF_PD is configured low by resistor.
- The clkbuf is enabled and the clocks are correctly distributed to the M.2 cards.
This is the corresponding section of the schematic:
Using Gen-1
We have also forced the link speed down to PCIe Gen-1 on all devices, but this had no effect on the error itself.
Thank you for addressing this issue, we look forward to hearing from you.
