Kernel Panics with Memory Mapped access on Jetson AGX Orin
I am trying to get a NI PCIe Card PCIe-6363 to work wit h a Jetson AGX Orin in the PCIe slot.
I am using their open source driver MHDDK and was able to get the kernel and user mode driver to compile with the kernel in the R36.4 distribution on the AGX Orin.
What works?
  • Kernel driver loads and recognizes the device.
  • Can read the BAR0 address space successfully.
What doesn’t work?
  • The issue is that when I try to deference/access any mapped memory at the base of the BAR0 I get a memory access violation and kernel panic.
The kicker is that the same driver without any/much modification can run fully well without any issues on a x86_64 linux host that I have.
What should I be doing differently on ARM64 or Jetson AGX Orin to be specific to enable user mode access of the mapped memory?
Sample of the kernel panic:
��ERROR:R E: epin rason=2 syn**oe=x00011
ERROR: RAS Uncorrectable Error in SNOC, base=0xe011000:
ERROR: Status = 0xe400030d
ERROR: SERR = Illegal address (software fault): 0xd
ERROR: IERR = Carveout Uncorrectable Error: 0x3
ERROR: MISC0 = 0x2400
ERROR: MISC1 = 0x15cc842000000000
ERROR: MISC2 = 0x0
ERROR: MISC3 = 0x40000000
ERROR: ADDR = 0xe0a5a5a5a5a5a5a5
ERROR: **************************************
ERRRR:: sddii_dipattch_vvnt rrttunned 11
ERROR: RAS Uncorrectable Error in ACI, base=0xe01a000:
ERROR: Status = 0xe8000904
ERROR: SERR = Assertion failure: 0x4
ERROR: IERR = FillWrite Error: 0x9
ERROR: Overflow (there may be more errors) - Uncorrectable
ERROR: ADDR = 0x8000000040000000
ERROR: sdei_dispatch_event returned -1
ERROR: Powering off core
��[Mar20 17:01] nirlpk: nNIRLP_open(inode (00000000f0250f9e), file (00000000a06aebdb))
[ +0.000038] nirlpk: Allocated nNIRLP_tDriverContext (00000000366e0277)
[ +0.000048] nirlpk: minor 0
[ +0.000021] nirlpk: mmap: vma->vm_start = 0xffff80250000
[ +0.000002] nirlpk: mmap: vma->vm_end = 0xffff80290000
[ +0.000002] nirlpk: mmap: vma->vm_pgoff = 0x40000
[ +0.000001] nirlpk: mmap: Found BAR0 at physical address 0x40000000
[ +0.032074] nirlpk: nNIRLP_release
[ +0.000003] nirlpk: free nNIRLP_tDriverContext (00000000366e0277)
[ +0.000003] nirlpk: exit release
[ +1.270116] tegra-hda 3510000.hda: azx_get_response timeout, switching to polling mode: last cmd=0x004f0900
If the device cannot be flashed/booted, please refer to the page to get uart log from the device:
Jetson/General debug - eLinux.org
And get logs of host PC and Jetson device for reference. If you are using custom board, you can compare uart log of developer kit and custom board to get more information.
Also please check FAQs:
Jetson AGX Orin FAQ
If possible, we would suggest follow quick start in developer guide to re-flash the system:
Quick Start — NVIDIA Jetson Linux Developer Guide 1 documentation
And see if the issue still persists on a clean-flashed system.
Looks like carveout memory is accidentally got accessed by this pcie driver.
Thank you for your replies, I will look more into the carveout memory on Jetson AGX Orin and may be how to avoid it. Here are some more details:
Crash Happens here when de-referencing a memory address from user mode driver at the base of the BAR0 address mapping :
Kernel Crash Dmesg
[ +3.106277] nirlpk: mmap: vma->vm_start = 0xfffff7ab0000
[ +0.000044] nirlpk: mmap: vma->vm_end = 0xfffff7af0000
��ERROE: :x etio**reao*=2 s**dome0x80000011
ERROR: MISC0 = 0x2200
ERROR: MISC1 = 0x2d4c842000000000
ERROR: MISC2 = 0x0
ERROOR: sdee__dipaach_event rettrned -1
ERROR: PoweriAgSERT col31/ehf.c:245
Driver Details
Kernel mode Mapping Call which succeeds:
vma->vm_flags |= (VM_IO | VM_DONTDUMP | VM_DONTEXPAND);
vma->vm_page_prot = pgprot_noncached(vma->vm_page_prot);
if(remap_pfn_range(vma, vma->vm_start, vma->vm_pgoff,
                                       vsize, vma->vm_page_prot))
            nNIRLP_printDebug("could not map device address\n");
            return -EFAULT; // or -EAGAIN
User mode mmap() call which succeeds too:
fd = open (file, O_RDWR);
// bar0Size queried form kernel via IOCTL is set correctly to the BAR0 size of 256KB
// physicalBar0 queried form kernel via IOCTL is set correctly to 0x40000000 which matches the memory
// information shown below
  mem0 = mmap (NULL, bar0Size, PROT_READ|PROT_WRITE, MAP_SHARED, fd, physicalBar0);
  if ( MAP_FAILED == mem0)
      close (fd);
      return NULL;
Kernel Debug information about VMA
+0.000021] nirlpk: Allocated nNIRLP_tDriverContext (0000000045568402)
[ +0.000032] nirlpk: minor 0
> [ +16.042207] nirlpk: mmap: vma->vm_start = 0xfffff7ab0000
[ +0.000011] nirlpk: mmap: vma->vm_end = 0xfffff7af0000
> [ +0.000002] nirlpk: mmap: Found BAR0 at physical address 0x40000000
Memory Mapping of the PCIe Bridge
$ sudo lspci -v -s 0005:00:00.0
0005:00:00.0 PCI bridge: NVIDIA Corporation Device 229a (rev a1) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 204, IOMMU group 48
Bus: primary=00, secondary=01, subordinate=ff, sec-latency=0
I/O behind bridge: [disabled]
Memory behind bridge: 40000000-400fffff [size=1M]
Prefetchable memory behind bridge: [disabled]
Capabilities: [40] Power Management version 3
Capabilities: [50] MSI: Enable- Count=1/1 Maskable+ 64bit+
Capabilities: [70] Express Root Port (Slot-), MSI 00
Capabilities: [b0] MSI-X: Enable- Count=8 Masked-
Capabilities: [100] Advanced Error Reporting
Capabilities: [148] Secondary PCI Express
Capabilities: [168] Physical Layer 16.0 GT/s <?> Capabilities: [190] Lane Margining at the Receiver <?>
Capabilities: [1c0] L1 PM Substates
Capabilities: [1d0] Vendor Specific Information: ID=0002 Rev=4 Len=100 <?> Capabilities: [2d0] Vendor Specific Information: ID=0001 Rev=1 Len=038 <?>
Capabilities: [308] Data Link Feature <?> Capabilities: [314] Precision Time Measurement Capabilities: [320] Vendor Specific Information: ID=0004 Rev=1 Len=054 <?>
Capabilities: [388] Vendor Specific Information: ID=0006 Rev=0 Len=018 <?>
Kernel driver in use: pcieport
Kernel modules: tegra_pcie_dma_test
PCIe Bridge Resource Information
$ cat /sys/bus/pci/devices/0005:00:00.0/resource
0x0000000000000000 0x0000000000000000 0x0000000000000000
0x0000002b28000000 0x0000002b280fffff 0x0000000000000200
Memory Mapping of the PCIE-6363 device Connected in the Jetson PCIE slot
$ sudo lspci -v -s 0005:01:00.0
0005:01:00.0 Signal processing controller: National Instruments PXIe/PCIe Device
Subsystem: National Instruments PCIe-6363
Memory at 2b28000000 (32-bit, non-prefetchable) [size=256K]
Capabilities: [50] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [78] Power Management version 3
Capabilities: [80] Express Endpoint, MSI 00
Capabilities: [100] Virtual Channel
Capabilities: [800] Advanced Error Reporting
Kernel driver in use: nirlpk
Kernel modules: nirlpk
PCIe 6363 Device Resource Information
$ cat /sys/bus/pci/devices/0005:01:00.0/resource
0x0000002b28000000 0x0000002b2803ffff 0x0000000000040200
This issue is sounding similar to this one where they saw the carveout error when trying to access BAR0 address space but on Xavier. @WayneWWW
Do you think this could be a similar issue? How do I change the mapping of my BAR0 address to not use the careveout memory?
Here’s a detailed output of sudo lspci -vvv
$ sudo lspci -vvv
0001:00:00.0 PCI bridge: NVIDIA Corporation Device 229e (rev a1) (prog-if 00 [Normal decode])
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- SERR- <PERR- INTx-
Latency: 0
Interrupt: pin A routed to IRQ 200
IOMMU group: 4
I/O behind bridge: 00001000-00001fff [size=4K]
Prefetchable memory behind bridge: 00000000fff00000-00000000000fffff [disabled]
Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
BridgeCtl: Parity- SERR+ NoISA- VGA- VGA16- MAbort- >Reset- FastB2B-
PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold-)
Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
Address: 0000000000000000 Data: 0000
Capabilities: [70] Express (v2) Root Port (Slot-), MSI 00
DevCap: MaxPayload 256 bytes, PhantFunc 0
ExtTag- RBE+
DevCtl: CorrErr+ NonFatalErr+ FatalErr+ UnsupReq+
RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+
MaxPayload 128 bytes, MaxReadReq 512 bytes
DevSta: CorrErr- NonFatalErr- FatalErr- UnsupReq- AuxPwr+ TransPend-
LnkCap: Port #0, Speed 16GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <1us, L1 <64us
ClockPM- Surprise+ LLActRep+ BwNot+ ASPMOptComp+
LnkCtl: ASPM Disabled; RCB 64 bytes, Disabled- CommClk+
ExtSynch- ClockPM- AutWidDis- BWInt+ AutBWInt-
LnkSta: Speed 2.5GT/s (downgraded), Width x1 (ok)
TrErr- Train- SlotClk+ DLActive+ BWMgmt- ABWMgmt-
RootCap: CRSVisible+
RootCtl: ErrCorrectable- ErrNon-Fatal- ErrFatal- PMEIntEna+ CRSVisible+
RootSta: PME ReqID 0000, PMEStatus- PMEPending-
DevCap2: Completion Timeout: Range ABCD, TimeoutDis+ NROPrPrP+ LTR+
10BitTagComp+ 10BitTagReq- OBFF Not Supported, ExtFmt- EETLPPrefix-
EmergencyPowerReduction Not Supported, EmergencyPowerReductionInit-
FRS- LN System CLS Not Supported, TPHComp- ExtTPHComp- ARIFwd+
AtomicOpsCap: Routing- 32bit- 64bit- 128bitCAS-
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis- LTR+ OBFF Disabled, ARIFwd-
AtomicOpsCtl: ReqEn- EgressBlck-
LnkCap2: Supported Link Speeds: 2.5-16GT/s, Crosslink- Retimer+ 2Retimers+ DRS-
LnkCtl2: Target Link Speed: 16GT/s, EnterCompliance- SpeedDis-
Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
Compliance De-emphasis: -6dB
LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete- EqualizationPhase1-
EqualizationPhase2- EqualizationPhase3- LinkEqualizationRequest-
Retimer- 2Retimers- CrosslinkRes: Downstream Port
Capabilities: [b0] MSI-X: Enable- Count=1 Masked-
Vector table: BAR=0 offset=00000000
PBA: BAR=0 offset=00000000
Capabilities: [100 v2] Advanced Error Reporting
UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr-
CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr+
AERCap: First Error Pointer: 00, ECRCGenCap+ ECRCGenEn- ECRCChkCap+ ECRCChkEn-
MultHdrRecCap+ MultHdrRecEn- TLPPfxPres- HdrLogCap-
HeaderLog: 00000000 00000000 00000000 00000000
RootCmd: CERptEn+ NFERptEn+ FERptEn+
RootSta: CERcvd- MultCERcvd- UERcvd- MultUERcvd-
FirstFatal- NonFatalMsg- FatalMsg- IntMsg 0
ErrorSrc: ERR_COR: 0000 ERR_FATAL/NONFATAL: 0000
Capabilities: [148 v1] Secondary PCI Express
LnkCtl3: LnkEquIntrruptEn- PerformEqu-
LaneErrStat: 0
Capabilities: [158 v1] Physical Layer 16.0 GT/s <?> Capabilities: [17c v1] Lane Margining at the Receiver <?>
Capabilities: [190 v1] L1 PM Substates
L1SubCap: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2- ASPM_L1.1- L1_PM_Substates+
PortCommonModeRestoreTime=60us PortTPowerOnTime=40us
L1SubCtl1: PCI-PM_L1.2- PCI-PM_L1.1- ASPM_L1.2- ASPM_L1.1-
T_CommonMode=60us
L1SubCtl2: T_PwrOn=60us
Capabilities: [1a0 v1] Vendor Specific Information: ID=0002 Rev=4 Len=100 <?> Capabilities: [2a0 v1] Vendor Specific Information: ID=0001 Rev=1 Len=038 <?>
Capabilities: [2d8 v1] Data Link Feature <?> Capabilities: [2e4 v1] Precision Time Measurement PTMCap: Requester:- Responder:+ Root:+ PTMClockGranularity: 16ns PTMControl: Enabled:- RootSelected:- PTMEffectiveGranularity: Unknown Capabilities: [2f0 v1] Vendor Specific Information: ID=0004 Rev=1 Len=054 <?>
Capabilities: [358 v1] Vendor Specific Information: ID=0006 Rev=0 Len=018 <?>
0001:01:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8822CE 802.11ac PCIe Wireless Network Adapter
Subsystem: AzureWave RTL8822CE 802.11ac PCIe Wireless Network Adapter
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Latency: 0, Cache Line Size: 32 bytes
Interrupt: pin A routed to IRQ 254
IOMMU group: 4
Region 0: I/O ports at 1000 [size=256]
Region 2: Memory at 20a8000000 (64-bit, non-prefetchable) [size=64K]
Flags: PMEClk- DSI- D1+ D2+ AuxCurrent=375mA PME(D0+,D1+,D2+,D3hot+,D3cold+)
Capabilities: [50] MSI: Enable+ Count=1/1 Maskable- 64bit+
Address: 00000000fffffd50 Data: 0000
Capabilities: [70] Express (v2) Endpoint, MSI 00
DevCap: MaxPayload 128 bytes, PhantFunc 0, Latency L0s <4us, L1 <64us
ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset- SlotPowerLimit 0.000W
DevCtl: CorrErr- NonFatalErr- FatalErr- UnsupReq-
RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop-
LnkCap: Port #0, Speed 2.5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <4us, L1 <64us
ClockPM+ Surprise- LLActRep- BwNot- ASPMOptComp+
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 2.5GT/s (ok), Width x1 (ok)
TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Not Supported, TimeoutDis+ NROPrPrP- LTR+
10BitTagComp- 10BitTagReq- OBFF Via message/WAKE#, ExtFmt- EETLPPrefix-
FRS- TPHComp- ExtTPHComp-
AtomicOpsCap: 32bit- 64bit- 128bitCAS-
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis+ LTR+ OBFF Disabled,
LnkCap2: Supported Link Speeds: 2.5GT/s, Crosslink- Retimer- 2Retimers- DRS-
LnkCtl2: Target Link Speed: 2.5GT/s, EnterCompliance- SpeedDis-
LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete- EqualizationPhase1-
Retimer- 2Retimers- CrosslinkRes: unsupported
MultHdrRecCap- MultHdrRecEn- TLPPfxPres- HdrLogCap-
Capabilities: [148 v1] Device Serial Number 00-e0-4c-ff-fe-c8-22-01
Capabilities: [158 v1] Latency Tolerance Reporting
Max snoop latency: 0ns
Max no snoop latency: 0ns
Capabilities: [160 v1] L1 PM Substates
L1SubCap: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2+ ASPM_L1.1+ L1_PM_Substates+
PortCommonModeRestoreTime=30us PortTPowerOnTime=60us
T_CommonMode=0us LTR1.2_Threshold=98304ns
Kernel driver in use: rtl88x2ce
Kernel modules: rtl8822ce
Latency: 0
Interrupt: pin A routed to IRQ 204
IOMMU group: 51
I/O behind bridge: 0000f000-00000fff [disabled]
Masking: 00000000 Pending: 00000000
ExtTag- RBE+
LnkCap: Port #0, Speed 16GT/s, Width x8, ASPM L0s L1, Exit Latency L0s <1us, L1 <64us
LnkSta: Speed 2.5GT/s (downgraded), Width x1 (downgraded)
Vector table: BAR=2 offset=00000000
PBA: BAR=2 offset=00010000
LaneErrStat: 0
Capabilities: [168 v1] Physical Layer 16.0 GT/s <?> Capabilities: [190 v1] Lane Margining at the Receiver <?>
Capabilities: [1c0 v1] L1 PM Substates
T_CommonMode=60us
L1SubCtl2: T_PwrOn=10us
Capabilities: [1d0 v1] Vendor Specific Information: ID=0002 Rev=4 Len=100 <?> Capabilities: [2d0 v1] Vendor Specific Information: ID=0001 Rev=1 Len=038 <?>
Capabilities: [308 v1] Data Link Feature <?> Capabilities: [314 v1] Precision Time Measurement PTMCap: Requester:+ Responder:+ Root:+ PTMClockGranularity: 16ns PTMControl: Enabled:- RootSelected:- PTMEffectiveGranularity: Unknown Capabilities: [320 v1] Vendor Specific Information: ID=0004 Rev=1 Len=054 <?>
Capabilities: [388 v1] Vendor Specific Information: ID=0006 Rev=0 Len=018 <?>
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Latency: 0
IOMMU group: 51
Region 0: Memory at 2b28000000 (32-bit, non-prefetchable) [size=256K]
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
Capabilities: [80] Express (v1) Endpoint, MSI 00
DevCap: MaxPayload 512 bytes, PhantFunc 0, Latency L0s <64ns, L1 <1us
DevSta: CorrErr- NonFatalErr- FatalErr- UnsupReq- AuxPwr- TransPend-
LnkCap: Port #1, Speed 2.5GT/s, Width x4, ASPM L0s, Exit Latency L0s <4us
ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp-
LnkSta: Speed 2.5GT/s (ok), Width x1 (downgraded)
Capabilities: [100 v1] Virtual Channel
Caps: LPEVC=0 RefClk=100ns PATEntryBits=1
Arb: Fixed- WRR32- WRR64- WRR128-
Ctrl: ArbSelect=Fixed
Status: InProgress-
VC0: Caps: PATOffset=00 MaxTimeSlots=1 RejSnoopTrans-
Arb: Fixed- WRR32- WRR64- WRR128- TWRR128- WRR256-
Ctrl: Enable+ ID=0 ArbSelect=Fixed TC/VC=ff
Status: NegoPending- InProgress-
Capabilities: [800 v1] Advanced Error Reporting
UEMsk: DLP- SDES- TLP+ FCP+ CmpltTO- CmpltAbrt+ UnxCmplt+ RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UESvrt: DLP+ SDES+ TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr-
AERCap: First Error Pointer: 00, ECRCGenCap- ECRCGenEn- ECRCChkCap- ECRCChkEn-
This issue is more or less resolved for me. I hard-coded the physical address that was being passed into the user mode mmap() call to be the one I saw in lspci (0x2b28000000) instead of that one that kernel driver was stating as the base of the BAR0 address (0x40000000 which was the base of the PCIe bridge looks like).
And simplified the kernel mmap() function to be very simple as shown below:
int nNIRLP_mmap(struct file *filp, struct vm_area_struct *vma)
    unsigned long vsize = vma->vm_end - vma->vm_start;
    pr_info("my_pci_driver: vma->vm_start = 0x%lx\n", vma->vm_start);
    pr_info("my_pci_driver: vma->vm_end = 0x%lx\n", vma->vm_end);
    pr_info("my_pci_driver: vma->vm_pgoff = 0x%lx\n", vma->vm_pgoff);
    if(remap_pfn_range(vma, vma->vm_start, vma->vm_pgoff,vsize, vma->vm_page_prot))
        pr_info("could not map device address\n");
    return 0;
User mode:
    fd = open (file, O_RDWR | O_SYNC);
    if (fd <= 0 )
        printf ("fail to open %s\n", file);
        return NULL;
   physicalBar0 = 0x2b28000000;
   bar0Size = 262144;
