PCIe Mini card driver issue in Jetson Tx2
We are working on the ARM64 PCIe loadable driver for a custom PCIe mini card.
We are creating a driver for this card. On module initialization, pci_enable_device() fails with error no -22(-EINVAL) and the error message is “pci 0000:01:00:0: can’t enable device: BAR 0 [0xffffff00 - 0xffffffff] not claimed”.
On debugging, we noticed that the device resource doesn’t have a parent resource. (r->parent == NULL in pci_enable_devices() in drivers/pci/setup-res.c).
My code is as follows:
dev = pci_get_device(vendor_id, device_id, NULL);
if (dev != NULL) {
ret = pci_enable_device(dev);
if (ret) {
printk(KERN_ALERT “pci_enable_device failed with err no %d\n”, rc);
goto err;
“lspci” command shows:
00:01.0 PCI bridge: NVIDIA Corporation Device 10e5 (rev a1)
01:00.0 Non-VGA unclassified device: Device 4453:0b00
on reading /proc/ioports(“cat /proc/ioports”), I get
00001000-0000ffff : PCI0 I/O
00001000-00001fff : PCI Bus 0000:01
dmesg_log(dmesg | grep pci) is below,
[    0.134608] node /plugin-manager/fragment-500-pcie-config match with board >=3310-1000-500
[    0.135291] node /plugin-manager/fragment-500-e3325-pcie match with board >=3310-1000-500
[    0.240883] iommu: Adding device 10003000.pcie-controller to group 50
[   10.148254] tegra-pcie 10003000.pcie-controller: 4x1, 1x1 configuration
[   10.150304] Modules linked in: pci_tegra(+) bluedroid_pm
[   10.151341] Modules linked in: pci_tegra(+) bluedroid_pm
[   10.151537] tegra-pcie 10003000.pcie-controller: PCIE: Enable power rails
[   10.151940] tegra-pcie 10003000.pcie-controller: probing port 0, using 4 lanes
[   10.153818] tegra-pcie 10003000.pcie-controller: probing port 2, using 1 lanes
[   10.158311] Modules linked in: pci_tegra bluedroid_pm
[   10.584417] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[   10.986393] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[   11.388426] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[   11.397829] tegra-pcie 10003000.pcie-controller: link 2 down, ignoring
[   11.405460] tegra-pcie 10003000.pcie-controller: PCI host bridge to bus 0000:00
[   11.414567] pci_bus 0000:00: root bus resource [mem 0x50100000-0x57ffffff]
[   11.422278] pci_bus 0000:00: root bus resource [mem 0x58000000-0x7fffffff pref]
[   11.431206] pci_bus 0000:00: root bus resource [bus 00-ff]
[   11.437543] pci_bus 0000:00: root bus resource [io  0x1000-0xffff]
[   11.452108] pci 0000:00:01.0: [10de:10e5] type 01 class 0x060400
[   11.459094] pci 0000:00:01.0: PME# supported from D0 D1 D2 D3hot D3cold
[   11.459350] pci 0000:00:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[   11.459473] pci 0000:01:00.0: [4453:0b00] type 00 class 0x000000
[   11.459519] pci 0000:01:00.0: reg 0x10: [io  0xffffff00-0xffffffff]
[   11.459789] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[   11.459820] pci 0000:00:01.0: BAR 7: assigned [io  0x1000-0x1fff]
[   11.459824] pci 0000:00:01.0: PCI bridge to [bus 01]
[   11.459827] pci 0000:00:01.0:   bridge window [io  0x1000-0x1fff]
[   11.459894] pcieport 0000:00:01.0: enabling device (0000 -> 0001)
[   11.459967] pcieport 0000:00:01.0: Signaling PME through PCIe PME interrupt
[   11.459969] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[   11.459974] pcie_pme 0000:00:01.0:pcie01: service driver pcie_pme loaded
[   11.460047] aer 0000:00:01.0:pcie02: service driver aer loaded
It would be helpful if you provide your inputs on this issue.
What kind of PCIe endpoint is this?
Can you please connect it to an x86 system and provide ‘sudo lspci -vv’ output?
Hi Vidyas,
Below is lspci log for my device in Ubuntu 32-bit OS x86 platform.
03:00.0 Non-VGA unclassified device: Device 4453:0b00
	Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
	Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Latency: 0, Cache Line Size: 64 bytes
	Interrupt: pin A routed to IRQ 11
	Region 0: I/O ports at c000
	Capabilities: [50] Power Management version 3
		Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
		Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME-
	Capabilities: [70] MSI: Enable- Count=1/1 Maskable- 64bit+
		Address: 0000000000000000  Data: 0000
	Capabilities: [90] Express (v2) Endpoint, MSI 00
		DevCap:	MaxPayload 128 bytes, PhantFunc 0, Latency L0s <64ns, L1 <1us
			ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset-
		DevCtl:	Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
			RlxdOrd- ExtTag- PhantFunc- AuxPwr- NoSnoop-
			MaxPayload 128 bytes, MaxReadReq 512 bytes
		DevSta:	CorrErr+ UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend-
		LnkCap:	Port #0, Speed 2.5GT/s, Width x1, ASPM L0s, Exit Latency L0s unlimited, L1 <1us
			ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp-
		LnkCtl:	ASPM Disabled; RCB 64 bytes Disabled- CommClk+
			ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
		LnkSta:	Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
		DevCap2: Completion Timeout: Range A, TimeoutDis+, LTR-, OBFF Not Supported
		DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis+, LTR-, OBFF Disabled
		LnkCtl2: Target Link Speed: 2.5GT/s, EnterCompliance- SpeedDis-
			 Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
			 Compliance De-emphasis: -6dB
		LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete-, EqualizationPhase1-
			 EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
	Capabilities: [100 v1] Device Serial Number 00-00-00-00-00-00-00-00
Below is complete log for “lspci -vv”
00:00.0 Host bridge: Intel Corporation Atom Processor Z36xxx/Z37xxx Series SoC Transaction Register (rev 11)
	Subsystem: Intel Corporation Atom Processor Z36xxx/Z37xxx Series SoC Transaction Register
	Status: Cap- 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Latency: 0
	Kernel driver in use: iosf_mbi_pci
00:02.0 VGA compatible controller: Intel Corporation Atom Processor Z36xxx/Z37xxx Series Graphics & Display (rev 11) (prog-if 00 [VGA controller])
	DeviceName:  Onboard IGD
	Subsystem: Intel Corporation Atom Processor Z36xxx/Z37xxx Series Graphics & Display
	Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
	Latency: 0
	Interrupt: pin A routed to IRQ 89
	Region 0: Memory at 90000000 (32-bit, non-prefetchable)
	Region 2: Memory at 80000000 (32-bit, prefetchable)
	Region 4: I/O ports at e080
	[virtual] Expansion ROM at 000c0000 [disabled]
	Capabilities: [d0] Power Management version 2
		Flags: PMEClk- DSI+ D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
	Capabilities: [90] MSI: Enable+ Count=1/1 Maskable- 64bit-
		Address: fee02004  Data: 4023
	Capabilities: [b0] Vendor Specific Information: Len=07 <?>
	Kernel driver in use: i915
	Kernel modules: i915
00:13.0 SATA controller: Intel Corporation Atom Processor E3800 Series SATA AHCI Controller (rev 11) (prog-if 01 [AHCI 1.0])
	Subsystem: Intel Corporation Atom Processor E3800 Series SATA AHCI Controller
	Status: Cap+ 66MHz+ UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Latency: 0
	Interrupt: pin A routed to IRQ 88
	Region 0: I/O ports at e070
	Region 1: I/O ports at e060
	Region 2: I/O ports at e050
	Region 3: I/O ports at e040
	Region 4: I/O ports at e020
	Region 5: Memory at 90a28000 (32-bit, non-prefetchable)
	Capabilities: [80] MSI: Enable+ Count=1/1 Maskable- 64bit-
		Address: fee02004  Data: 4030
	Capabilities: [70] Power Management version 3
		Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot+,D3cold-)
		Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
	Capabilities: [a8] SATA HBA v1.0 BAR4 Offset=00000004
	Kernel driver in use: ahci
	Kernel modules: ahci
00:14.0 USB controller: Intel Corporation Atom Processor Z36xxx/Z37xxx, Celeron N2000 Series USB xHCI (rev 11) (prog-if 30 [XHCI])
	Subsystem: Intel Corporation Atom Processor Z36xxx/Z37xxx, Celeron N2000 Series USB xHCI
	Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
	Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Latency: 0
	Interrupt: pin A routed to IRQ 87
	Region 0: Memory at 90a00000 (64-bit, non-prefetchable)
	Capabilities: [70] Power Management version 2
		Flags: PMEClk- DSI- D1- D2- AuxCurrent=375mA PME(D0-,D1-,D2-,D3hot+,D3cold+)
	Capabilities: [80] MSI: Enable+ Count=1/8 Maskable- 64bit+
		Address: 00000000fee02004  Data: 4031
	Kernel driver in use: xhci_hcd
00:18.0 DMA controller: Intel Corporation Atom Processor Z36xxx/Z37xxx Series LPIO2 DMA Controller (rev 11) (prog-if 02 [EISA DMA])
	Subsystem: Intel Corporation Atom Processor Z36xxx/Z37xxx Series LPIO2 DMA Controller
	Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
	Interrupt: pin A routed to IRQ 17
	Region 0: Memory at 90a18000 (32-bit, non-prefetchable)
	Region 1: Memory at 90a27000 (32-bit, non-prefetchable)
	Capabilities: [80] Power Management version 3
	Kernel driver in use: dw_dmac_pci
	Kernel modules: dw_dmac_pci
00:18.1 Serial bus controller [0c80]: Intel Corporation Atom Processor Z36xxx/Z37xxx Series LPIO2 I2C Controller #1 (rev 11)
	Subsystem: Intel Corporation Atom Processor Z36xxx/Z37xxx Series LPIO2 I2C Controller
	Interrupt: pin C routed to IRQ 19
	Region 0: Memory at 90a26000 (32-bit, non-prefetchable)
	Region 1: Memory at 90a25000 (32-bit, non-prefetchable)
		Status: D3 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
	Kernel driver in use: i2c-designware-pci
	Kernel modules: i2c_designware_pci
00:18.7 Serial bus controller [0c80]: Intel Corporation Atom Processor Z36xxx/Z37xxx Series LPIO2 I2C Controller #7 (rev 11)
	Interrupt: pin B routed to IRQ 16
	Region 0: Memory at 90a24000 (32-bit, non-prefetchable)
	Region 1: Memory at 90a23000 (32-bit, non-prefetchable)
00:1a.0 Encryption controller: Intel Corporation Atom Processor Z36xxx/Z37xxx Series Trusted Execution Engine (rev 11)
	Subsystem: Intel Corporation Atom Processor Z36xxx/Z37xxx Series Trusted Execution Engine
	Interrupt: pin A routed to IRQ 100
	Region 0: Memory at 90500000 (32-bit, non-prefetchable)
	Region 1: Memory at 90400000 (32-bit, non-prefetchable)
		Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold-)
	Capabilities: [a0] MSI: Enable+ Count=1/1 Maskable- 64bit-
		Address: fee02004  Data: 4025
	Kernel driver in use: mei_txe
	Kernel modules: mei_txe
00:1b.0 Audio device: Intel Corporation Atom Processor Z36xxx/Z37xxx Series High Definition Audio Controller (rev 11)
	Subsystem: Intel Corporation Atom Processor Z36xxx/Z37xxx Series High Definition Audio Controller
	Interrupt: pin A routed to IRQ 101
	Region 0: Memory at 90a14000 (64-bit, non-prefetchable)
	Capabilities: [50] Power Management version 2
		Flags: PMEClk- DSI- D1- D2- AuxCurrent=55mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
	Capabilities: [60] MSI: Enable+ Count=1/1 Maskable- 64bit+
		Address: 00000000fee02004  Data: 4026
	Kernel driver in use: snd_hda_intel
	Kernel modules: snd_hda_intel
00:1c.0 PCI bridge: Intel Corporation Atom Processor E3800 Series PCI Express Root Port 1 (rev 11) (prog-if 00 [Normal decode])
	Interrupt: pin A routed to IRQ 16
	Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
	I/O behind bridge: 0000d000-0000dfff
	Memory behind bridge: 90800000-909fffff
	Prefetchable memory behind bridge: 00000000fff00000-00000000000fffff
	Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort+ <SERR- <PERR-
	BridgeCtl: Parity- SERR- NoISA- VGA- MAbort- >Reset- FastB2B-
		PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
	Capabilities: [40] Express (v2) Root Port (Slot+), MSI 00
			ExtTag- RBE+
			MaxPayload 128 bytes, MaxReadReq 128 bytes
		DevSta:	CorrErr+ UncorrErr- FatalErr- UnsuppReq- AuxPwr+ TransPend-
		LnkCap:	Port #1, Speed 5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <512ns, L1 <4us
			ClockPM- Surprise- LLActRep+ BwNot+ ASPMOptComp-
		LnkCtl:	ASPM L1 Enabled; RCB 64 bytes Disabled- CommClk+
		LnkSta:	Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive+ BWMgmt+ ABWMgmt-
		SltCap:	AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+
			Slot #0, PowerLimit 10.000W; Interlock- NoCompl+
		SltCtl:	Enable: AttnBtn- PwrFlt- MRL- PresDet- CmdCplt- HPIrq- LinkChg-
			Control: AttnInd Unknown, PwrInd Unknown, Power- Interlock-
		SltSta:	Status: AttnBtn- PowerFlt- MRL- CmdCplt- PresDet+ Interlock-
			Changed: MRL- PresDet- LinkState-
		RootCtl: ErrCorrectable- ErrNon-Fatal- ErrFatal- PMEIntEna- CRSVisible-
		RootCap: CRSVisible-
		RootSta: PME ReqID 0000, PMEStatus- PMEPending-
		DevCap2: Completion Timeout: Range BC, TimeoutDis+, LTR-, OBFF Not Supported ARIFwd-
		DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis+, LTR-, OBFF Disabled ARIFwd-
		LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete-, EqualizationPhase1-
	Capabilities: [80] MSI: Enable- Count=1/1 Maskable- 64bit-
		Address: 00000000  Data: 0000
	Capabilities: [90] Subsystem: Intel Corporation Atom Processor E3800 Series PCI Express Root Port 1
	Capabilities: [a0] Power Management version 3
		Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
	Kernel driver in use: pcieport
	Kernel modules: shpchp
00:1c.1 PCI bridge: Intel Corporation Atom Processor E3800 Series PCI Express Root Port 2 (rev 11) (prog-if 00 [Normal decode])
	Interrupt: pin B routed to IRQ 17
	Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
	I/O behind bridge: 0000c000-0000cfff
	Memory behind bridge: 90600000-907fffff
			ExtTag- RBE+
		LnkCap:	Port #2, Speed 5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <512ns, L1 <4us
			Slot #1, PowerLimit 10.000W; Interlock- NoCompl+
	Capabilities: [90] Subsystem: Intel Corporation Atom Processor E3800 Series PCI Express Root Port 2
00:1c.2 PCI bridge: Intel Corporation Atom Processor E3800 Series PCI Express Root Port 3 (rev 11) (prog-if 00 [Normal decode])
	Interrupt: pin C routed to IRQ 18
	Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
	I/O behind bridge: 0000b000-0000bfff
	Memory behind bridge: fff00000-000fffff
			ExtTag- RBE+
		LnkCap:	Port #3, Speed 5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <512ns, L1 <4us
			Slot #2, PowerLimit 10.000W; Interlock- NoCompl+
	Capabilities: [90] Subsystem: Intel Corporation Atom Processor E3800 Series PCI Express Root Port 3
00:1c.3 PCI bridge: Intel Corporation Atom Processor E3800 Series PCI Express Root Port 4 (rev 11) (prog-if 00 [Normal decode])
	Interrupt: pin D routed to IRQ 19
	Bus: primary=00, secondary=04, subordinate=04, sec-latency=0
	I/O behind bridge: 00001000-00001fff
			ExtTag- RBE+
		DevSta:	CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr+ TransPend-
		LnkCap:	Port #4, Speed 5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <512ns, L1 <4us
		LnkCtl:	ASPM L0s L1 Enabled; RCB 64 bytes Disabled- CommClk+
		LnkSta:	Speed 2.5GT/s, Width x0, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
			Slot #3, PowerLimit 10.000W; Interlock- NoCompl+
		SltSta:	Status: AttnBtn- PowerFlt- MRL- CmdCplt- PresDet- Interlock-
		DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled ARIFwd-
		LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis-
	Capabilities: [90] Subsystem: Intel Corporation Atom Processor E3800 Series PCI Express Root Port 4
00:1d.0 USB controller: Intel Corporation Atom Processor Z36xxx/Z37xxx Series USB EHCI (rev 11) (prog-if 20 [EHCI])
	Subsystem: Intel Corporation Atom Processor Z36xxx/Z37xxx Series USB EHCI
	Control: I/O- Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
	Interrupt: pin A routed to IRQ 23
	Region 0: Memory at 90a22000 (32-bit, non-prefetchable)
		Flags: PMEClk- DSI- D1- D2- AuxCurrent=375mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
	Capabilities: [58] Debug port: BAR=1 offset=00a0
	Capabilities: [98] PCI Advanced Features
		AFCap: TP+ FLR+
		AFCtrl: FLR-
		AFStatus: TP-
00:1e.0 DMA controller: Intel Corporation Atom Processor Z36xxx/Z37xxx Series LPIO1 DMA Controller (rev 11) (prog-if 02 [EISA DMA])
	Subsystem: Intel Corporation Atom Processor Z36xxx/Z37xxx Series LPIO1 DMA Controller
	Interrupt: pin A routed to IRQ 19
	Region 0: Memory at 90a10000 (32-bit, non-prefetchable)
	Region 1: Memory at 90a21000 (32-bit, non-prefetchable)
00:1e.1 Serial bus controller [0c80]: Intel Corporation Atom Processor Z36xxx/Z37xxx Series LPIO1 PWM Controller (rev 11)
	Subsystem: Intel Corporation Atom Processor Z36xxx/Z37xxx Series LPIO1 PWM Controller
	Interrupt: pin D routed to IRQ 16
	Region 0: Memory at 90a20000 (32-bit, non-prefetchable)
	Region 1: Memory at 90a1f000 (32-bit, non-prefetchable)
	Kernel driver in use: pwm-lpss
	Kernel modules: pwm_lpss_pci
00:1e.2 Serial bus controller [0c80]: Intel Corporation Atom Processor Z36xxx/Z37xxx Series LPIO1 PWM Controller (rev 11)
	Region 0: Memory at 90a1e000 (32-bit, non-prefetchable)
	Region 1: Memory at 90a1d000 (32-bit, non-prefetchable)
00:1f.0 ISA bridge: Intel Corporation Atom Processor Z36xxx/Z37xxx Series Power Control Unit (rev 11)
	Subsystem: Intel Corporation Atom Processor Z36xxx/Z37xxx Series Power Control Unit
	Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Latency: 0
	Capabilities: [e0] Vendor Specific Information: Len=0c <?>
	Kernel driver in use: lpc_ich
	Kernel modules: lpc_ich
00:1f.3 SMBus: Intel Corporation Atom Processor E3800 Series SMBus Controller (rev 11)
	Subsystem: Intel Corporation Atom Processor E3800 Series SMBus Controller
	Control: I/O+ Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
	Interrupt: pin B routed to IRQ 18
	Region 0: Memory at 90a1c000 (32-bit, non-prefetchable)
	Region 4: I/O ports at e000
	Kernel driver in use: i801_smbus
	Kernel modules: i2c_i801
01:00.0 Ethernet controller: Intel Corporation I210 Gigabit Network Connection (rev 03)
	Region 0: Memory at 90800000 (32-bit, non-prefetchable)
	Region 2: I/O ports at d000
	Region 3: Memory at 90900000 (32-bit, non-prefetchable)
	Capabilities: [40] Power Management version 3
		Flags: PMEClk- DSI+ D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
		Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=1 PME-
	Capabilities: [50] MSI: Enable- Count=1/1 Maskable+ 64bit+
		Masking: 00000000  Pending: 00000000
	Capabilities: [70] MSI-X: Enable+ Count=5 Masked-
		Vector table: BAR=3 offset=00000000
		PBA: BAR=3 offset=00002000
	Capabilities: [a0] Express (v2) Endpoint, MSI 00
		DevCap:	MaxPayload 512 bytes, PhantFunc 0, Latency L0s <512ns, L1 <64us
			ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset+
		DevCtl:	Report errors: Correctable+ Non-Fatal+ Fatal+ Unsupported+
			RlxdOrd- ExtTag- PhantFunc- AuxPwr- NoSnoop+ FLReset-
		DevSta:	CorrErr+ UncorrErr- FatalErr- UnsuppReq+ AuxPwr+ TransPend-
		LnkCap:	Port #0, Speed 2.5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <2us, L1 <16us
			ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp+
		DevCap2: Completion Timeout: Range ABCD, TimeoutDis+, LTR-, OBFF Not Supported
	Capabilities: [100 v2] Advanced Error Reporting
		UESta:	DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
		UEMsk:	DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
		UESvrt:	DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
		CESta:	RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
		CEMsk:	RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
		AERCap:	First Error Pointer: 00, GenCap+ CGenEn- ChkCap+ ChkEn-
	Capabilities: [140 v1] Device Serial Number 00-06-d5-ff-ff-30-f1-ce
	Capabilities: [1a0 v1] Transaction Processing Hints
		Device specific mode supported
		Steering table in TPH capability structure
	Kernel driver in use: igb
	Kernel modules: igb
02:00.0 Ethernet controller: Intel Corporation I210 Gigabit Network Connection (rev 03)
	Region 0: Memory at 90600000 (32-bit, non-prefetchable)
	Region 2: I/O ports at c000
	Region 3: Memory at 90700000 (32-bit, non-prefetchable)
	Capabilities: [140 v1] Device Serial Number 00-06-d5-ff-ff-30-f1-cf
	Kernel modules: igb
	Region 0: I/O ports at b000
		DevSta:	CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend-
We fixed the bug by assigning resource from OS itself by calling pci_assign_resource() before pci_enable_device().
Now driver is successfully loaded. After that I tried writing in the port by calling “writeb(PCI_IOBASE + dev_io_base + OFFSET_LED)” from the driver itself. But it fails showing the error below. Did I miss anything here such as mapping? any help is greatly appreciated.
PCI_IOBASE: ffffffbffae00000, BASE: 1000
CPU3: SError detected, daif=140, spsr=0x80000045, mpidr= 80000101, esr= bf000000
CPU3: SError detected, daif=140, spsr=0x80000045, mpidr= 40000101, esr= bf40c000
ROC:CCE Machine Check Error:
#Address Type = Secure DRAM
#Address = 0x0 (Unknown Device)
ROC: IOB Machine Check Error:
#Address = 0x0 (Unknown Device).
Any input for above issue?
Getting ‘struct pci_dev *’ pointer through the following method is not correct.
Instead, when your probe function gets called with a ‘struct pci_dev *’ passed to it as the first argument by PCIe sub-system. Please use that for any subsequent PCIe sub-system calls like ‘pci_enable_device()’ Etc…
