I found a device driver for the DVP-7641E PCIe device on internet.
and i build a driver without any problem.
but, the device driver does not works correctly.
please, let me know. what shall i do first for debugging.
Many thanks,
Namsu
------ dmesg ------
[ 353.366410] [LINUXV4L2] : FAF86DD63BEE049469391C62866E9E0BB(), 1.1.0.120.879, 2020.07.15 PAL
[ 353.366736] [LINUXV4L2] : [00] F0251D2D952114606BEF15BFE3B8A3F85( 01:000000:12AB:0381:23CA:12AB (12AB:0381:23CA:12AB) )
[ 353.366740] [LINUXV4L2] : [00] F0251D2D952114606BEF15BFE3B8A3F85() primary(0x0)
[ 353.366743] [LINUXV4L2] : [00] F0251D2D952114606BEF15BFE3B8A3F85() pm_cap(0x40)
[ 353.366745] [LINUXV4L2] : [00] F0251D2D952114606BEF15BFE3B8A3F85() current_state(0x5)
[ 353.366766] [LINUXV4L2] : [00] F0251D2D952114606BEF15BFE3B8A3F85() - w_bar0(0x0)
[ 353.366768] [LINUXV4L2] : m_nAnalogCrossbarVideoInputProperty(0d5)
[ 353.366770] [LINUXV4L2] : m_nCustomCompanyMedicalProperty(0d1)
[ 353.366789] LINUXV4L20380 0000:01:00.0: can’t enable device: BAR 0 [mem 0x00000000-0x00ffffff] not claimed
[ 353.376500] [LINUXV4L2] : [00] F0251D2D952114606BEF15BFE3B8A3F85() - pci_enable_device() - [FAIL]
[ 353.385483] Trying to free nonexistent resource <0000000000000000-0000000000ffffff>
[ 353.393177] Trying to free nonexistent resource <0000000000000000-0000000000000fff>
[ 353.400879] LINUXV4L20380 0000:01:00.0: disabling already-disabled device
[ 353.400912] ------------[ cut here ]------------
[ 353.405534] WARNING: CPU: 5 PID: 9292 at drivers/pci/pci.c:1700 pci_disable_device+0xd4/0xe8
[ 353.413959] Modules linked in: LXV4L2D_MZ0380(O) bnep fuse bcmdhd zram cfg80211 ov5693 spidev overlay nvgpu bluedroid_pm ip_tables x_tables
[ 353.414027] CPU: 5 PID: 9292 Comm: Init_pci_driver Tainted: G O 4.9.140-tegra #8
[ 353.414033] Hardware name: quill (DT)
[ 353.414040] task: ffffffc1ebbfd400 task.stack: ffffffc1646f0000
[ 353.414050] PC is at pci_disable_device+0xd4/0xe8
[ 353.414058] LR is at pci_disable_device+0xd4/0xe8
[ 353.414066] pc : [] lr : [] pstate: 60400045
[ 353.414071] sp : ffffffc1646f3a60
[ 353.414076] x29: ffffffc1646f3a60 x28: ffffffc131800320
[ 353.414091] x27: ffffffc131800000 x26: ffffffc1318138e0
[ 353.414104] x25: 00000000000d8000 x24: 0000000000000000
[ 353.414117] x23: ffffffc1e94540a0 x22: ffffffc1e94540a0
[ 353.414129] x21: ffffffc1318138e0 x20: ffffffc1e94540a0
[ 353.414142] x19: ffffffc1e9454000 x18: 0000000000000010
[ 353.414154] x17: 0000000000000000 x16: 0000000000000000
[ 353.414166] x15: ffffffffffffffff x14: 3030302d30303030
[ 353.414179] x13: 3030303030303030 x12: 303030303c206563
[ 353.414191] x11: 72756f7365722074 x10: 00000000000003fe
[ 353.414204] x9 : 6f6e206565726620 x8 : 69642d7964616572
[ 353.414216] x7 : 6c6120676e696c62 x6 : ffffff800a1780dd
[ 353.414228] x5 : 0000000000000000 x4 : 0000000000000000
[ 353.414240] x3 : ffffffffffffffff x2 : 00000041ecf91000
[ 353.414253] x1 : ffffffc1ebbfd400 x0 : 000000000000003d
[ 353.414271] —[ end trace 5edf8d048c2155da ]—
[ 353.418892] Call trace:
[ 353.418899] [] pci_disable_device+0xd4/0xe8
[ 353.418953] [] F0251D2D952114606BEF15BFE3B8A3F85+0x28a8/0x2b90 [LXV4L2D_MZ0380]
[ 353.418960] [] pci_device_probe+0xa4/0x140
[ 353.418970] [] driver_probe_device+0xd8/0x408
[ 353.418974] [] __driver_attach+0xdc/0x128
[ 353.418979] [] bus_for_each_dev+0x5c/0xa8
[ 353.418982] [] driver_attach+0x30/0x40
[ 353.418986] [] bus_add_driver+0x20c/0x2a8
[ 353.418989] [] driver_register+0x6c/0x110
[ 353.418994] [] __pci_register_driver+0x50/0x60
[ 353.419031] [] Init_pci_driver+0x28/0x68 [LXV4L2D_MZ0380]
[ 353.419039] [] kthread+0xec/0xf0
[ 353.419044] [] ret_from_fork+0x10/0x30
[ 353.419181] LINUXV4L20380: probe of 0000:01:00.0 failed with error -22
lspci -v
00:01.0 PCI bridge: NVIDIA Corporation Device 10e5 (rev a1) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 381
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
Memory behind bridge: 40800000-41ffffff
Capabilities:
Kernel driver in use: pcieport
01:00.0 Non-VGA unclassified device: YUAN High-Tech Development Co., Ltd. Device 0381
Subsystem: Device 23ca:12ab
Flags: fast devsel, IRQ 381
Memory at (32-bit, non-prefetchable) [disabled] [size=16M]
I/O ports at [disabled]
Memory at (32-bit, non-prefetchable) [disabled] [size=4K]
Capabilities:
Kernel modules: LXV4L2D_MZ0380
