We have a custom carrier board which has Xilinx Artix 7 and Jetson TX2. We want Jetson to communicate with this FPGA via PCIe. When I type lspci, I can see that Linux can detect FPGA.
nvidia@tegra-ubuntu:~$ lspci
00:01.0 PCI bridge: NVIDIA Corporation Device 10e5 (rev a1)
01:00.0 Serial controller: Xilinx Corporation Device 7024
However when I try to load Xilinx reference driver, it says “Error: The Kernel module installed correctly, but no devices were recognized.”
dmesg output is:
[ 2997.348703] tegradc 15210000.nvdisplay: hdmi: pclk:74250K, set prod-setting:prod_c_75M
[ 2997.408907] tegradc 15210000.nvdisplay: unblank
[ 3460.512839] xdma:xdma_mod_init: Xilinx XDMA Reference Driver xdma v2017.1.47
[ 3460.520260] xdma:xdma_mod_init: desc_blen_max: 0xfffffff/268435455, sgdma_timeout: 10 sec.
[ 3460.528930] xdma:xdma_device_open: xxx 0xffffffc0683ff700.
[ 3460.534521] xdma:xdma_device_open: xxx 0xffffffc0683ff700.
[ 3460.540096] xdma:xdma_device_open: xdma device 0000:01:00.0, 0xffffffc1deba6800.
[ 3460.547556] xdma:pci_check_extended_tag: 0xffffffc1deba6800 EXT_TAG disabled.
[ 3460.554807] xdma:pci_check_extended_tag: pdev 0xffffffc1deba6800, xdev 0xffffffc1a92ee000, config bar UNKNOWN.
[ 3460.567029] xdma:map_single_bar: BAR0 at 0x51000000 mapped at 0xffffff8011d80000, length=16777216(/16777216)
[ 3460.586990] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0020
[ 3460.597209] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 3460.597289] xdma:map_single_bar: BAR1 at 0x50800000 mapped at 0xffffff80020c0000, length=65536(/65536)
[ 3460.617396] xdma:map_bars: Failed to detect XDMA config BAR
[ 3460.632305] pcieport 0000:00:01.0: device [10de:10e5] error status/mask=00004000/00000000
[ 3460.640694] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 3460.647535] pcieport 0000:00:01.0: broadcast error_detected message
[ 3460.650568] xdma: probe of 0000:01:00.0 failed with error -22
[ 3460.659699] pcieport 0000:00:01.0: AER: Device recovery failed
[ 3460.665577] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0020
[ 3460.673653] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 3460.685432] pcieport 0000:00:01.0: device [10de:10e5] error status/mask=00004000/00000000
[ 3460.693807] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 3460.700637] pcieport 0000:00:01.0: broadcast error_detected message
[ 3460.706947] pcieport 0000:00:01.0: AER: Device recovery failed
[ 3460.712791] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
[ 3460.721598] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
[ 3460.733338] pcieport 0000:00:01.0: device [10de:10e5] error status/mask=00004000/00000000
[ 3460.741694] pcieport 0000:00:01.0: [14] Completion Timeout (First)
[ 3460.748492] pcieport 0000:00:01.0: broadcast error_detected message
[ 3460.755099] pcieport 0000:00:01.0: AER: Device recovery failed
Linux can detect pci device address and create BAR0 and BAR1 memory registers but then it fails.
Is there any suggestions?
Thank you in advance.
