We have custom Carrier Board for TX2.
We use Configuration #4 from the Platform adaption guide.
PCIe#1_0 and all USB Ports are working
PCIe#0_0 where we connect a Rennesas USB Host controller for additional USB3.0 does not work.
tegra186-quill-p3310-1000-c03-00-base.dts
pcie-controller@10003000 {
status = "okay";
// PCIe#0_0
pci@1,0 {
nvidia,num-lanes = <1>;
status = "okay";
// PCIe#1_0
pci@2,0 {
status = "okay";
pci@3,0 {
status = "disabled";
xudc@3550000 {
status = "okay";
phys = <&tegra_xusb_padctl TEGRA_PADCTL_PHY_UTMI_P(0)>,
<&tegra_xusb_padctl TEGRA_PADCTL_PHY_UTMI_P(1)>,
<&tegra_xusb_padctl TEGRA_PADCTL_PHY_UTMI_P(2)>,
<&tegra_xusb_padctl TEGRA_PADCTL_PHY_USB3_P(0)>,
<&tegra_xusb_padctl TEGRA_PADCTL_PHY_USB3_P(1)>,
<&tegra_xusb_padctl TEGRA_PADCTL_PHY_USB3_P(2)>;
phy-names = "usb2", "usb2", "usb2", "usb3", "usb3", "usb3";
xhci@3530000 {
phy-names = "utmi-0", "utmi-1", "utmi-2", "usb3-0", "usb3-1", "usb3-2";
pinctrl@3520000 {
pinmux {
usb2-0-debug {
nvidia,lanes = "otg-0";
nvidia,function = "xusb";
nvidia,port-cap = <TEGRA_PADCTL_PORT_OTG_CAP>;
nvidia,oc-pin = <0>;
status = "okay";
usb2-2-front {
nvidia,lanes = "otg-1";
nvidia,port-cap = <TEGRA_PADCTL_PORT_HOST_ONLY>;
nvidia,oc-pin = <1>;
status = "okay";
usb2-5-aux {
nvidia,lanes = "otg-2";
status = "okay";
usb3-2-front {
nvidia,lanes = "usb3-0";
status = "okay";
usb3-1-front {
nvidia,lanes = "usb3-1";
/* nvidia,oc-pin = <?>; */ // USB#1.OC# | B22 | GPIO3_PB.05 | 1 | TEGRA_MAIN_GPIO(1, 5)
status = "okay";
usb3-5-aux {
nvidia,lanes = "usb3-2";
status = "okay";
I updated power tree in tegra186-quill-power-tree-p3310-1000-a00-00.dtsi
pinctrl@3520000 {
vbus-0-supply = <&vdd_usb0_5v>;
vbus-1-supply = <&vdd_usb1_5v>;
/* vbus-2-supply = <&vdd_usb2_5v>; */
vbus-2-supply = <&battery_reg>;
vbus-3-supply = <&battery_reg>;
vddio-hsic-supply = <&battery_reg>;
avdd_usb-supply = <&spmic_sd3>;
vclamp_usb-supply = <&spmic_sd2>;
avdd_pll_erefeut-supply = <&spmic_sd2>;
I disabled the some fragments in the plugin-manager.
/* fragment-500-pcie-config {
/* fragment-500-xusb-config {
The device tree in /proc/device-tree looks like it’s finally taking my settings and not overwriting anything anymore.
With dev2mem I get following values. The PCI/USB Muxing seams to be configured correctly.
Value at address 0x2520284 (0x7f9a4e9284): 0x0 > USB_SS0 OK
Value at address 0x2530284 (0x7f78a87284): 0x0 > USB_SS1 OK
Value at address 0x2540284 (0x7f839d5284): 0x0 > USB_SS2 OK
Value at address 0x2550284 (0x7fb22c6284): 0x1 > PCIe1_0 OK
Value at address 0x2560284 (0x7f7813b284): 0x1 > PCIe0_0 OK
Value at address 0x2570284 (0x7f9a3e9284): 0x2 > SATA OK
I updated the pmic cfg for c00, c01, c02, c03 and c04 according to https://devtalk.nvidia.com/default/topic/1001443/jetson-tx2/extlinux-conf-fdt-no-longer-used-for-dtb-file-specification-/post/5130849/#5130849
I set ODM=0x7090000 at flash and I rewrote the board config:
process_board_version()
local board_id="${1}";
local board_version="${2}";
local bdv=${board_version^^};
local bid=${board_id^^};
local uboot_build=000;
local fromfab="-a00";
local tofab="-c03"; # default = C03
local pmicfab="-c00"; # default = C00
local bpfdtbfab="-c00"; # default = C00
local tbcdtbfab="-c03"; # default = C03
local kerndtbfab="-c03"; # default = C03
# Board version is Alpah-Numeric value.
echo "Board ID(${board_id}) version(${board_version}) " >/dev/stderr;
if ! [[ "${bdv}" =~ ^[A-Z0-9][0-9][0-9]$ ]]; then
bdv="${DEFAULT_FAB:-Z99}";
fi;
ODMDATA=0x7090000;
pmicfab="-c04";
bpfdtbfab="-c04";
sub_var_token "BPFDTB_FILE" "${fromfab}" "${bpfdtbfab}";
sub_var_token "PINMUX_CONFIG" "${fromfab}" "${tofab}";
sub_var_token "PMIC_CONFIG" "${fromfab}" "${pmicfab}";
sub_var_token "PMC_CONFIG" "${fromfab}" "${tofab}";
sub_var_token "PROD_CONFIG" "${fromfab}" "${tofab}";
sub_var_token "BOOTROM_CONFIG" "${fromfab}" "${tofab}";
sub_var_token "TBCDTB_FILE" "${fromfab}" "${tbcdtbfab}";
sub_var_token "DTB_FILE" "${fromfab}" "${kerndtbfab}";
if [ "${USE_UBOOT}" -eq 1 ]; then
DFLT_KERNEL_IMAGE="bootloader/t186ref/myboard/"; # refering to my u-boot build
DFLT_KERNEL_IMAGE+="${uboot_build}/u-boot.bin";
fi;
BCT="--sdram_config";
BINSARGS="--bins \"";
DEV_PARAMS="emmc.cfg";
SCR_CONFIG="minimal_scr.cfg";
SCR_COLD_BOOT_CONFIG="mobile_scr.cfg";
MISC_CONFIG="tegra186-mb1-bct-misc-si-l4t.cfg";
# PINMUX_CONFIG="tegra186-mb1-bct-pinmux-quill-p3310-1000-a00.cfg";
PINMUX_CONFIG="tegra186-mb1-bct-pinmux-myboard.cfg"; # my pinmux config generated from pinmux.xlsm
PMIC_CONFIG="tegra186-mb1-bct-pmic-quill-p3310-1000-a00.cfg";
# PMC_CONFIG="tegra186-mb1-bct-pad-quill-p3310-1000-a00.cfg";
PMC_CONFIG="tegra186-mb1-bct-pad-myboard.cfg";
PROD_CONFIG="tegra186-mb1-bct-prod-quill-p3310-1000-a00.cfg";
BOOTROM_CONFIG="tegra186-mb1-bct-bootrom-quill-p3310-1000-a00.cfg";
BPFDTB_FILE=tegra186-a02-bpmp-quill-p3310-1000-a00-00-te770d-ucm2.dtb;
In dmesg I see that the pcie is configuring and probing port 0 and 1 while only port 1 goes active.
nvidia@tegra-ubuntu:~$ dmesg | grep -i pci
[ 6.106695] tegra-pcie 10003000.pcie-controller: PCIE: Enable power rails
[ 6.117566] tegra-pcie 10003000.pcie-controller: probing port 0, using 1 lanes
[ 6.134706] tegra-pcie 10003000.pcie-controller: probing port 1, using 1 lanes
[ 6.558783] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 7.084215] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 7.524768] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 7.534483] tegra-pcie 10003000.pcie-controller: link 0 down, ignoring
[ 7.542222] tegra-pcie 10003000.pcie-controller: PCI host bridge to bus 0000:00
[ 7.551361] pci_bus 0000:00: root bus resource [mem 0x50100000-0x57ffffff]
[ 7.559179] pci_bus 0000:00: root bus resource [mem 0x58000000-0x7fffffff pref]
[ 7.568111] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 7.574484] pci_bus 0000:00: root bus resource [io 0x1000-0xffff]
[ 7.581571] pci 0000:00:02.0: [10de:10e6] type 01 class 0x060400
[ 7.588651] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 7.596670] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 7.596838] pci 0000:01:00.0: [1912:0015] type 00 class 0x0c0330
[ 7.596916] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00001fff 64bit]
[ 7.597154] pci 0000:01:00.0: PME# supported from D0 D3hot D3cold
[ 7.597461] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 7.597495] pci 0000:00:02.0: BAR 8: assigned [mem 0x50100000-0x501fffff]
[ 7.597500] pci 0000:01:00.0: BAR 0: assigned [mem 0x50100000-0x50101fff 64bit]
[ 7.597521] pci 0000:00:02.0: PCI bridge to [bus 01]
[ 7.597528] pci 0000:00:02.0: bridge window [mem 0x50100000-0x501fffff]
[ 7.597596] pcieport 0000:00:02.0: enabling device (0000 -> 0002)
[ 7.597731] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
[ 7.597733] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 7.597738] pcie_pme 0000:00:02.0:pcie01: service driver pcie_pme loaded
[ 7.597812] aer 0000:00:02.0:pcie02: service driver aer loaded
[ 7.597872] pci 0000:01:00.0: enabling device (0000 -> 0002)
[ 7.607405] tegra-pcie 10003000.pcie-controller: speed change : Gen-1 -> Gen-2
boot2.log (102 KB)
