We used the Jetson AGX Xavier industrial connected to PCIe 10G NIC(PCIe #0) and PCIe Switch(PCIe #5), the connection is like the figure below:
PCIe Switch : Microchip PM43028
The PCIe 10G NIC is working fine. But when the system is try to link to PCIe switch, it will lead the system to hand!
[ 0.072447] CPU2: Booted secondary processor 0x0000000100 [0x4e0f0040]
[ 0.101752] Detected PIPT I-cache on CPU3
[ 0.101841] CPU3: Booted secondary processor 0x0000000101 [0x4e0f0040]
[ 0.131229] Detected PIPT I-cache on CPU4
[ 0.131370] CPU4: Booted secondary processor 0x0000000200 [0x4e0f0040]
[ 0.160925] Detected PIPT I-cache on CPU5
[ 0.161096] CPU5: Booted secondary processor 0x0000000201 [0x4e0f0040]
[ 0.190661] Detected PIPT I-cache on CPU6
[ 0.190843] CPU6: Booted secondary processor 0x0000000300 [0x4e0f0040]
[ 0.220560] Detected PIPT I-cache on CPU7
[ 0.220750] CPU7: Booted secondary processor 0x0000000301 [0x4e0f0040]
[ 0.221241] smp: Brought up 1 node, 8 CPUs
[ 0.221430] SMP: Total of 8 processors activated.
[ 0.221517] CPU features: detected: Privileged Access Never
[ 0.221540] CPU features: detected: LSE atomic instructions
[ 0.221552] CPU features: detected: User Access Override
[ 0.221564] CPU features: detected: 32-bit EL0 Support
[ 0.221575] CPU features: detected: RAS Extension Support
[ 0.221585] CPU features: detected: CRC32 instructions
[ 0.221597] CPU features: detected: 32-bit EL1 Support
[ 0.288501] CPU: All CPU(s) started at EL2
[ 0.300601] devtmpfs: initialized
[ 0.359931] Registered cp15_barrier emulation handler
[ 0.360050] Registered setend emulation handler
[ 0.360074] KASLR enabled
[ 0.360328] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.360372] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 0.361652] pinctrl core: initialized pinctrl subsystem
[ 0.362574] SMBIOS 3.0.0 present.
[ 0.362595] DMI: Unknown Jetson-AGXi/Jetson-AGXi, BIOS 2.1-32413640 01/24/2023
[ 0.363226] NET: Registered protocol family 16
[ 0.366171] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[ 0.367910] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.370084] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.370143] audit: initializing netlink subsys (disabled)
[ 0.370459] audit: type=2000 audit(0.364:1): state=initialized audit_enabled=0 res=1
[ 0.370922] thermal_sys: Registered thermal governor 'step_wise'
[ 0.370927] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.370940] thermal_sys: Registered thermal governor 'pid_thermal_gov'
[ 0.373732] cpuidle: using governor menu
[ 0.374053] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.374621] ASID allocator initialised with 32768 entries
[ 0.374870] Serial: AMBA PL011 UART driver
[ 0.378332] Tegra reboot handler registered.
[ 0.448436] mc: mapped MMIO address: 0xffff800010ee0000 -> 0x2c10000
[ 0.448474] mc: mapped MMIO address: 0xffff800010f00000 -> 0x2c20000
[ 0.448519] mc: mapped MMIO address: 0xffff800010f20000 -> 0x2c30000
[ 0.448546] mc: mapped MMIO address: 0xffff800010f40000 -> 0x2c40000
[ 0.448569] mc: mapped MMIO address: 0xffff800010f60000 -> 0x2c50000
[ 0.448592] mc: mapped MMIO address: 0xffff800010f80000 -> 0x2b80000
[ 0.448616] mc: mapped MMIO address: 0xffff800010fa0000 -> 0x2b90000
[ 0.448638] mc: mapped MMIO address: 0xffff800010fc0000 -> 0x2ba0000
[ 0.448663] mc: mapped MMIO address: 0xffff800010fe0000 -> 0x2bb0000
[ 0.448688] mc: mapped MMIO address: 0xffff800011000000 -> 0x1700000
[ 0.448709] mc: mapped MMIO address: 0xffff800011020000 -> 0x1710000
[ 0.448731] mc: mapped MMIO address: 0xffff800011040000 -> 0x1720000
[ 0.448758] mc: mapped MMIO address: 0xffff800011060000 -> 0x1730000
[ 0.448783] mc: mapped MMIO address: 0xffff800011080000 -> 0x1740000
[ 0.448806] mc: mapped MMIO address: 0xffff8000110a0000 -> 0x1750000
[ 0.448827] mc: mapped MMIO address: 0xffff8000110c0000 -> 0x1760000
[ 0.448849] mc: mapped MMIO address: 0xffff8000110e0000 -> 0x1770000
[ 0.448931] mc-err: mcerr ops are set to t19x
[ 0.461052] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.461094] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.461106] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.461117] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.467929] ACPI: Interpreter disabled.
[ 0.468789] vdd-epb-1v0: supplied by vdd-3v3-cvb
[ 0.470885] iommu: Default domain type: Translated
[ 0.470951] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.471314] SCSI subsystem initialized
[ 0.471454] usbcore: registered new interface driver usbfs
[ 0.471487] usbcore: registered new interface driver hub
[ 0.471520] usbcore: registered new device driver usb
[ 0.471908] mc: Linux media interface: v0.10
[ 0.471935] videodev: Linux video capture interface: v2.00
[ 0.472217] pps_core: LinuxPPS API ver. 1 registered
[ 0.472227] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.472246] PTP clock support registered
[ 0.472442] tegra_wdt_t18x 30c0000.watchdog: Expiry count is deprecated
[ 0.472789] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.472889] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.473465] Registered efivars operations
[ 0.473785] FPGA manager framework
[ 0.473845] Advanced Linux Sound Architecture Driver Initialized.
[ 0.474340] Bluetooth: Core ver 2.22
[ 0.474374] NET: Registered protocol family 31
[ 0.474385] Bluetooth: HCI device and connection manager initialized
[ 0.474399] Bluetooth: HCI socket layer initialized
[ 0.474412] Bluetooth: L2CAP socket layer initialized
[ 0.474432] Bluetooth: SCO socket layer initialized
[ 0.476676] camchar: rtcpu character device driver loaded
[ 0.477711] clocksource: Switched to clocksource arch_sys_counter
[ 0.899404] VFS: Disk quotas dquot_6.6.0
[ 0.899561] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.900008] pnp: PnP ACPI: disabled
[ 0.914408] la/ptsa driver initialized.
[ 0.914627] NET: Registered protocol family 2
[ 0.914976] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.928748] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear)
[ 0.929102] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.930447] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.931033] TCP: Hash tables configured (established 262144 bind 65536)
[ 0.931224] UDP hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 0.931668] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 0.932311] NET: Registered protocol family 1
[ 0.933177] RPC: Registered named UNIX socket transport module.
[ 0.933204] RPC: Registered udp transport module.
[ 0.933218] RPC: Registered tcp transport module.
[ 0.933232] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.933265] PCI: CLS 0 bytes, default 64
[ 0.933679] Trying to unpack rootfs image as initramfs...
[ 1.204506] Freeing initrd memory: 8208K
[ 1.211094] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.211723] kvm [1]: IPA Size Limit: 40 bits
[ 1.212392] kvm [1]: vgic interrupt IRQ9
[ 1.213088] kvm [1]: VHE mode initialized successfully
[ 1.215101] Initialise system trusted keyrings
[ 1.215500] workingset: timestamp_bits=46 max_order=23 bucket_order=0
[ 1.222329] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.223218] NFS: Registering the id_resolver key type
[ 1.223258] Key type id_resolver registered
[ 1.223272] Key type id_legacy registered
[ 1.223362] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.223389] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 1.223423] ntfs: driver 2.1.32 [Flags: R/W].
[ 1.233902] NET: Registered protocol family 38
[ 1.233924] Key type asymmetric registered
[ 1.233939] Asymmetric key parser 'x509' registered
[ 1.233986] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 1.234262] io scheduler mq-deadline registered
[ 1.234280] io scheduler kyber registered
[ 1.244464] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 1.244547] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 1.244619] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 1.244688] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 1.251061] scrncapt: init (heads:4 wins:6 planes:4)
[ 1.251176] tegradccommon 15200000.display-hub: Nvhost Channel map failed
[ 1.252289] EINJ: ACPI disabled.
[ 1.256085] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 1.256110] tegra-pmc: ### PMC reset source: BCCPLEXWDT
[ 1.256124] tegra-pmc: ### PMC reset level: L1
[ 1.256137] tegra-pmc: ### PMC reset status reg: 0x9
[ 1.256183] tegra-pmc: PMC Prod config success
[ 1.262056] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.267455] random: fast init done
[ 1.267624] printk: console [ttyTCU0] enabled
[ 2.768497] arm-smmu 10000000.iommu: probing hardware configuration...
[ 2.772652] arm-smmu 10000000.iommu: SMMUv2 with:
[ 2.777344] arm-smmu 10000000.iommu: stage 1 translation
[ 2.783019] arm-smmu 10000000.iommu: stage 2 translation
[ 2.788261] arm-smmu 10000000.iommu: nested translation
[ 2.793863] arm-smmu 10000000.iommu: stream matching with 128 register groups
[ 2.800706] arm-smmu 10000000.iommu: 64 context banks (0 stage-2 only)
[ 2.811468] arm-smmu 10000000.iommu: Supported page sizes: 0x00001000
[ 2.814356] arm-smmu 10000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 2.820647] arm-smmu 10000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 2.828690] arm-smmu 12000000.iommu: probing hardware configuration...
[ 2.833688] arm-smmu 12000000.iommu: SMMUv2 with:
[ 2.838413] arm-smmu 12000000.iommu: stage 1 translation
[ 2.844180] arm-smmu 12000000.iommu: stage 2 translation
[ 2.849346] arm-smmu 12000000.iommu: nested translation
[ 2.855032] arm-smmu 12000000.iommu: stream matching with 128 register groups
[ 2.862213] arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 2.872766] arm-smmu 12000000.iommu: Supported page sizes: 0x00001000
[ 2.875343] arm-smmu 12000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 2.881635] arm-smmu 12000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 2.889321] arm-smmu-suspend 12000000.smmu_suspend: arm_smmu_suspend probe successful
[ 2.900166] tegra_profiler: version: 1.150, samples/io: 50/29
[ 2.902144] tegra_profiler: auth: init
[ 2.906375] THERMAL EST: found 3 subdevs
[ 2.909991] THERMAL EST num_resources: 0
[ 2.913555] [THERMAL EST subdev 0]
[ 2.917157] [THERMAL EST subdev 1]
[ 2.920310] [THERMAL EST subdev 2]
[ 2.923810] THERMAL EST: Found 2 profiles, default profile is quiet
[ 2.930244] THERMAL EST: thz register success.
[ 2.934554] THERMAL EST: end of probe, return err: 0
[ 2.939592] nvsciipc: loaded module
[ 2.946757] tun: Universal TUN/TAP device driver, 1.6
[ 2.949496] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 2.955369] hns3: Copyright (c) 2017 Huawei Corporation.
[ 2.961157] e1000e: Intel(R) PRO/1000 Network Driver
[ 2.965816] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 2.972164] igb: Intel(R) Gigabit Ethernet Network Driver
[ 2.977441] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 2.983675] PPP generic driver version 2.4.2
[ 2.987775] PPP BSD Compression module registered
[ 2.992424] PPP Deflate Compression module registered
[ 2.997664] PPP MPPE Compression module registered
[ 3.002470] usbcore: registered new interface driver r8152
[ 3.008192] usbcore: registered new interface driver asix
[ 3.013275] usbcore: registered new interface driver ax88179_178a
[ 3.019386] usbcore: registered new interface driver cdc_ether
[ 3.025593] usbcore: registered new interface driver net1080
[ 3.031202] usbcore: registered new interface driver cdc_subset
[ 3.036978] usbcore: registered new interface driver zaurus
[ 3.042677] usbcore: registered new interface driver cdc_ncm
[ 3.048620] usbcore: registered new interface driver aqc111
[ 3.054468] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 3.060069] ohci-pci: OHCI PCI platform driver
[ 3.064625] ohci-platform: OHCI generic platform driver
[ 3.070389] tegra-xusb 3610000.xhci: Adding to iommu group 0
[ 3.076544] usbcore: registered new interface driver uas
[ 3.080678] usbcore: registered new interface driver usb-storage
[ 3.087082] tegra-xudc 3550000.xudc: Adding to iommu group 1
[ 3.092887] mousedev: PS/2 mouse device common for all mice
[ 3.098076] usbcore: registered new interface driver xpad
[ 3.106000] tegra_rtc c2a0000.rtc: registered as rtc1
[ 3.108825] tegra_rtc c2a0000.rtc: setting system clock to 1970-01-01T00:00:34 UTC (34)
[ 3.116641] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 3.123217] i2c /dev entries driver
[ 3.126517] tegra-i2c 3160000.i2c: Adding to iommu group 2
[ 3.132319] tegra-i2c c240000.i2c: Adding to iommu group 2
[ 3.137532] tegra-i2c 3180000.i2c: Adding to iommu group 2
[ 3.142983] tegra-i2c 3190000.i2c: Adding to iommu group 2
[ 3.148044] tegra-i2c 31b0000.i2c: Adding to iommu group 2
[ 3.153896] tegra-i2c 31c0000.i2c: Adding to iommu group 2
[ 3.159033] tegra-i2c c250000.i2c: Adding to iommu group 2
[ 3.170128] tegra-camrtc-capture-vi tegra-capture-vi: ep of_device is not enabled endpoint.
[ 3.172382] tegra-camrtc-capture-vi tegra-capture-vi: ep of_device is not enabled endpoint.
[ 3.180642] tegra-camrtc-capture-vi tegra-capture-vi: ep of_device is not enabled endpoint.
[ 3.190794] tegra-oc-event d280000.soctherm-oc-event: OC driver initialized
[ 3.196517] device-mapper: uevent: version 1.0.3
[ 3.200961] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
[ 3.211473] cpuidle: Initializing cpuidle driver
[ 3.215954] sdhci: Secure Digital Host Controller Interface driver
[ 3.220093] sdhci: Copyright(c) Pierre Ossman
[ 3.224820] Synopsys Designware Multimedia Card Interface Driver
[ 3.231032] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.236979] sdhci-tegra 3460000.sdhci: Adding to iommu group 3
[ 3.237339] sdhci-tegra 3400000.sdhci: Adding to iommu group 4
[ 3.238130] SMCCC: SOC_ID: ID = jep106:036b:0019 Revision = 0x00000102
[ 3.239185] tegra-bpmp bpmp: firmware: 128431eec76692047e1ac1ebc0392266
[ 3.259567] max77620 4-003c: PMIC Version OTP:0x51 and ES:0x2
[ 3.276685] vdd-1v0: supplied by regulator-dummy
[ 3.282145] vdd-1v8-hs: supplied by regulator-dummy
[ 3.287078] vdd-1v8-ls: supplied by regulator-dummy
[ 3.291840] vdd-1v8-ao: supplied by regulator-dummy
[ 3.295743] vddio-ddr-1v1: supplied by regulator-dummy
[ 3.300234] vdd-rtc: supplied by regulator-dummy
[ 3.301941] spmic-ldo1: supplied by regulator-dummy
[ 3.303174] vdd-ao-3v3: supplied by regulator-dummy
[ 3.312876] vddio-emmc-3v3: supplied by regulator-dummy
[ 3.319115] spmic-ldo4: supplied by regulator-dummy
[ 3.320347] vdd-usb-3v3: supplied by regulator-dummy
[ 3.327482] vddio-sdmmc1-3v3: supplied by regulator-dummy
[ 3.333662] vdd-csi-1v2: supplied by vdd-1v8-ls
[ 3.339253] spmic-ldo8: supplied by vdd-1v8-ls
[ 3.340802] gpio-510 (gpio_default): hogged as output/high
[ 3.342518] gpio-511 (gpio_default): hogged as output/high
[ 3.349858] gpiochip0: registered GPIOs 504 to 511 on max77620-gpio
[ 3.488390] max77686-rtc max77620-rtc: registered as rtc0
[ 3.489471] max77620-power max20024-power: Event recorder REG_NVERC : 0x0
[ 3.489885] max77620 4-003c: max77620 probe successful
[ 4.273407] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 4.274586] hid: raw HID events driver (C) Jiri Kosina
[ 4.275411] usbcore: registered new interface driver usbhid
[ 4.275565] usbhid: USB HID core driver
[ 4.278217] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 5
[ 4.279597] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 4.361318] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee01ff size=131584
[ 4.361907] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 4.362907] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x448]=0x1900-0x1b40 TX[1x448]=0x1b40-0x1d80
[ 4.363823] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d80-0x3e00 TX[1x8192]=0x3e00-0x5e80
[ 4.365395] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e80-0xaf00 TX[64x320]=0xaf00-0xff80
[ 4.366165] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff80-0x18000 TX[512x64]=0x18000-0x20080
[ 4.366754] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20080-0x20140 TX[1x64]=0x20140-0x20200
[ 4.367922] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (55)
[ 4.368181] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 4.370883] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=01b72e3c1b59ab02ad8c842bed3160278b410129
[ 4.376527] tegra_aon c1a0000.aon: Adding to iommu group 6
[ 4.384765] tegra_aon c1a0000.aon: tegra aon driver probe OK
[ 4.388357] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 4.396178] denver_knobs_init:MTS_VERSION:55637613
[ 4.410378] t19x_cache tegra-cache: probed
[ 4.413823] optee: probing for conduit method.
[ 4.414744] optee: revision 3.19 (18d0f61b)
[ 4.416247] optee: dynamic shared memory is enabled
[ 4.417960] optee: initialized driver
[ 4.422527] nvpmodel: initialized successfully
[ 4.423164] tegra_hv: get_hvd: not initialized yet
[ 4.428021] user_ivc_mempool: hypervisor not present
[ 4.434529] usbcore: registered new interface driver snd-usb-audio
[ 4.440675] u32 classifier
[ 4.441423] input device check on
[ 4.445176] Actions configured
[ 4.449215] Initializing XFRM netlink socket
[ 4.454213] NET: Registered protocol family 10
[ 4.459900] Segment Routing with IPv6
[ 4.461022] NET: Registered protocol family 17
[ 4.465570] NET: Registered protocol family 15
[ 4.469744] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 4.483382] Bluetooth: RFCOMM socket layer initialized
[ 4.488234] Bluetooth: RFCOMM ver 1.11
[ 4.491868] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 4.497982] Bluetooth: HIDP socket layer initialized
[ 4.503459] 9pnet: Installing 9P2000 support
[ 4.507175] Key type dns_resolver registered
[ 4.512862] registered taskstats version 1
[ 4.515653] Loading compiled-in X.509 certificates
[ 4.530080] Loaded X.509 cert 'Build time autogenerated kernel key: d25818a2a0374bd220e34de93c3a3d81e2d1591c'
[ 4.531403] tegra194-pcie 14180000.pcie: Adding to iommu group 7
[ 4.542154] tegra194-pcie 14180000.pcie: host bridge /pcie@14180000 ranges:
[ 4.543551] tegra194-pcie 14180000.pcie: IO 0x0038100000..0x00381fffff -> 0x0038100000
[ 4.552381] tegra194-pcie 14180000.pcie: MEM 0x1800000000..0x1b3fffffff -> 0x1800000000
[ 4.560467] tegra194-pcie 14180000.pcie: MEM 0x1b40000000..0x1bffffffff -> 0x0040000000
[ 5.678375] tegra194-pcie 14180000.pcie: Phy link never came up
[ 5.678892] tegra194-pcie 14180000.pcie: PCI host bridge to bus 0000:00
[ 5.679186] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 5.679340] pci_bus 0000:00: root bus resource [io 0x0000-0xfffff] (bus address [0x38100000-0x381fffff])
[ 5.679557] pci_bus 0000:00: root bus resource [mem 0x1800000000-0x1b3fffffff pref]
[ 5.679797] pci_bus 0000:00: root bus resource [mem 0x1b40000000-0x1bffffffff] (bus address [0x40000000-0xffffffff])
[ 5.680234] pci 0000:00:00.0: [10de:1ad0] type 01 class 0x060400
[ 5.680697] pci 0000:00:00.0: PME# supported from D0 D3hot D3cold
[ 5.711483] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[ 5.711781] pci 0000:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 5.714127] pcieport 0000:00:00.0: Adding to iommu group 7
[ 5.715763] pcieport 0000:00:00.0: PME: Signaling with IRQ 24
[ 5.717523] pcieport 0000:00:00.0: AER: enabled with IRQ 24
[ 5.719556] pci_bus 0000:01: busn_res: [bus 01-ff] is released
[ 5.720652] pci 0000:00:00.0: Removing from iommu group 7
[ 5.721372] pci_bus 0000:00: busn_res: [bus 00-ff] is released
[ 5.725507] tegra194-pcie 14100000.pcie: Adding to iommu group 8
[ 5.731714] tegra194-pcie 14100000.pcie: host bridge /pcie@14100000 ranges:
[ 5.732210] tegra194-pcie 14100000.pcie: IO 0x0030100000..0x00301fffff -> 0x0030100000
[ 5.732610] tegra194-pcie 14100000.pcie: MEM 0x1200000000..0x122fffffff -> 0x1200000000
[ 5.732999] tegra194-pcie 14100000.pcie: MEM 0x1230000000..0x123fffffff -> 0x0040000000
[ 6.842962] tegra194-pcie 14100000.pcie: Phy link never came up
[ 6.843933] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[ 6.844238] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 6.844375] pci_bus 0001:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x30100000-0x301fffff])
[ 6.844694] pci_bus 0001:00: root bus resource [mem 0x1200000000-0x122fffffff pref]
[ 6.844935] pci_bus 0001:00: root bus resource [mem 0x1230000000-0x123fffffff] (bus address [0x40000000-0x4fffffff])
[ 6.845688] pci 0001:00:00.0: [10de:1ad2] type 01 class 0x060400
[ 6.846452] pci 0001:00:00.0: PME# supported from D0 D3hot D3cold
[ 6.875540] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[ 6.875952] pci 0001:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 6.878157] pcieport 0001:00:00.0: Adding to iommu group 8
[ 6.879559] pcieport 0001:00:00.0: PME: Signaling with IRQ 26
[ 6.881183] pcieport 0001:00:00.0: AER: enabled with IRQ 26
[ 6.883179] pci_bus 0001:01: busn_res: [bus 01-ff] is released
[ 6.884201] pci 0001:00:00.0: Removing from iommu group 8
[ 6.884678] pci_bus 0001:00: busn_res: [bus 00-ff] is released
[ 6.887560] tegra194-pcie 14140000.pcie: Adding to iommu group 9
[ 6.892397] tegra194-pcie 14140000.pcie: host bridge /pcie@14140000 ranges:
[ 6.892699] tegra194-pcie 14140000.pcie: IO 0x0034100000..0x00341fffff -> 0x0034100000
[ 6.892969] tegra194-pcie 14140000.pcie: MEM 0x1280000000..0x12afffffff -> 0x1280000000
[ 6.893349] tegra194-pcie 14140000.pcie: MEM 0x12b0000000..0x12bfffffff -> 0x0040000000
[ 8.006683] tegra194-pcie 14140000.pcie: Phy link never came up
[ 8.007291] tegra194-pcie 14140000.pcie: PCI host bridge to bus 0003:00
[ 8.007564] pci_bus 0003:00: root bus resource [bus 00-ff]
[ 8.007756] pci_bus 0003:00: root bus resource [io 0x200000-0x2fffff] (bus address [0x34100000-0x341fffff])
[ 8.008033] pci_bus 0003:00: root bus resource [mem 0x1280000000-0x12afffffff pref]
[ 8.008202] pci_bus 0003:00: root bus resource [mem 0x12b0000000-0x12bfffffff] (bus address [0x40000000-0x4fffffff])
[ 8.008612] pci 0003:00:00.0: [10de:1ad2] type 01 class 0x060400
[ 8.009076] pci 0003:00:00.0: PME# supported from D0 D3hot D3cold
[ 8.036332] pci 0003:00:00.0: PCI bridge to [bus 01-ff]
[ 8.036769] pci 0003:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 8.039187] pcieport 0003:00:00.0: Adding to iommu group 9
[ 8.040705] pcieport 0003:00:00.0: PME: Signaling with IRQ 28
[ 8.042225] pcieport 0003:00:00.0: AER: enabled with IRQ 28
[ 8.043966] pci_bus 0003:01: busn_res: [bus 01-ff] is released
[ 8.045090] pci 0003:00:00.0: Removing from iommu group 9
[ 8.045344] pci_bus 0003:00: busn_res: [bus 00-ff] is released
[ 8.048582] tegra194-pcie 141a0000.pcie: Adding to iommu group 10
[ 8.054011] tegra194-pcie 141a0000.pcie: host bridge /pcie@141a0000 ranges:
[ 8.054426] tegra194-pcie 141a0000.pcie: IO 0x003a100000..0x003a1fffff -> 0x003a100000
[ 8.054779] tegra194-pcie 141a0000.pcie: MEM 0x1c00000000..0x1f3fffffff -> 0x1c00000000
[ 8.055116] tegra194-pcie 141a0000.pcie: MEM 0x1f40000000..0x1fffffffff -> 0x0040000000
[ 9.170484] tegra194-pcie 141a0000.pcie: Phy link never came up
[ 9.171322] tegra194-pcie 141a0000.pcie: PCI host bridge to bus 0005:00
[ 9.171533] pci_bus 0005:00: root bus resource [bus 00-ff]
[ 9.171680] pci_bus 0005:00: root bus resource [io 0x300000-0x3fffff] (bus address [0x3a100000-0x3a1fffff])
[ 9.172004] pci_bus 0005:00: root bus resource [mem 0x1c00000000-0x1f3fffffff pref]
[ 9.172192] pci_bus 0005:00: root bus resource [mem 0x1f40000000-0x1fffffffff] (bus address [0x40000000-0xffffffff])
[ 9.172592] pci 0005:00:00.0: [10de:1ad0] type 01 class 0x060400
[ 9.173000] pci 0005:00:00.0: PME# supported from D0 D3hot D3cold
[ 9.198249] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[ 9.198656] pci 0005:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 9.200824] pcieport 0005:00:00.0: Adding to iommu group 10
[ 9.202610] pcieport 0005:00:00.0: PME: Signaling with IRQ 30
[ 9.204066] pcieport 0005:00:00.0: AER: enabled with IRQ 30
[ 9.205499] pci_bus 0005:01: busn_res: [bus 01-ff] is released
[ 9.206452] pci 0005:00:00.0: Removing from iommu group 10
[ 9.206914] pci_bus 0005:00: busn_res: [bus 00-ff] is released
[ 9.245544] host1x 13e10000.host1x: Adding to iommu group 11
[ 9.268421] host1x 13e10000.host1x: initialized
[ 9.268733] random: crng init done
[ 9.270233] iommu_context_dev 13e10000.host1x:ctx0: Adding to iommu group 12
[ 9.271166] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56, iommu=smmu.0x0000000012000000)
[ 9.272194] iommu_context_dev 13e10000.host1x:ctx1: Adding to iommu group 13
[ 9.272817] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57, iommu=smmu.0x0000000012000000)
[ 9.273829] iommu_context_dev 13e10000.host1x:ctx2: Adding to iommu group 14
[ 9.274466] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58, iommu=smmu.0x0000000012000000)
[ 9.275415] iommu_context_dev 13e10000.host1x:ctx3: Adding to iommu group 15
[ 9.276068] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59, iommu=smmu.0x0000000012000000)
[ 9.276997] iommu_context_dev 13e10000.host1x:ctx4: Adding to iommu group 16
[ 9.277683] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60, iommu=smmu.0x0000000012000000)
[ 9.284447] iommu_context_dev 13e10000.host1x:ctx5: Adding to iommu group 17
[ 9.291732] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61, iommu=smmu.0x0000000012000000)
[ 9.301378] iommu_context_dev 13e10000.host1x:ctx6: Adding to iommu group 18
[ 9.308630] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62, iommu=smmu.0x0000000012000000)
[ 9.318551] iommu_context_dev 13e10000.host1x:ctx7: Adding to iommu group 19
[ 9.325426] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63, iommu=smmu.0x0000000012000000)
[ 9.335451] falcon 15340000.vic: Adding to iommu group 20
[ 9.348577] falcon 15340000.vic: initialized
[ 9.349646] falcon 15380000.nvjpg: Adding to iommu group 20
[ 9.354984] falcon 15380000.nvjpg: initialized
[ 9.355808] falcon 154c0000.nvenc: Adding to iommu group 20
[ 9.368254] falcon 154c0000.nvenc: initialized
[ 9.368939] falcon 15a80000.nvenc1: Adding to iommu group 20
[ 9.377858] falcon 15a80000.nvenc1: initialized
[ 9.378562] nvdec 15480000.nvdec: Adding to iommu group 20
[ 9.390075] nvdec 15480000.nvdec: initialized
[ 9.390596] nvdec 15140000.nvdec1: Adding to iommu group 20
[ 9.399123] nvdec 15140000.nvdec1: initialized
[ 9.399689] tsec 15500000.tsec: Adding to iommu group 21
[ 9.406483] tsec 15500000.tsec: initialized
[ 9.407221] tsec 15100000.tsecb: Adding to iommu group 22
[ 9.415577] tsec 15100000.tsecb: initialized
[ 9.419401] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 9.446453] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 9.455008] tegra-xusb-padctl 3520000.xusb_padctl: failed to setup XUSB ports: -517
[ 9.462286] gpio-374 (wifi-enable): hogged as output/high
[ 9.462617] gpio-382 (camera-control-output-low): hogged as output/low
[ 9.462921] gpio-385 (camera-control-output-low): hogged as output/low
[ 9.463163] gpio-463 (camera-control-output-low): hogged as output/low
[ 9.463403] gpio-462 (camera-control-output-low): hogged as output/low
[ 9.463682] gpio-485 (camera-control-output-low): hogged as output/low
[ 9.467084] gpiochip1: registered GPIOs 335 to 503 on tegra194-gpio
[ 9.474055] gpiochip2: registered GPIOs 305 to 334 on tegra194-gpio-aon
[ 9.479107] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 9.485992] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 9.492578] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 9.496843] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 9.504748] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 9.510107] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=4687500, vi_iso_bw=6262500, max_bw=6262500
[ 9.520959] tegra194-isp5 13e10000.host1x:isp@14800000: Adding to iommu group 23
[ 9.533181] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: context isolation disabled due to no IOMMU
[ 9.538122] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: initialized
[ 9.543963] tegra194-vi5 15c10000.vi: Adding to iommu group 24
[ 9.551432] scare-pigeon 13e10000.host1x:vi-thi@15f00000: context isolation disabled due to no IOMMU
[ 9.558992] scare-pigeon 13e10000.host1x:vi-thi@15f00000: initialized
[ 9.565253] scare-pigeon 13e10000.host1x:isp-thi@14b00000: context isolation disabled due to no IOMMU
[ 9.574762] scare-pigeon 13e10000.host1x:isp-thi@14b00000: initialized
[ 9.580604] pva 16000000.pva0: Adding to iommu group 25
[ 9.610947] pva 16000000.pva0: initialized
[ 9.616015] pva 16800000.pva1: Adding to iommu group 26
[ 9.660586] pva 16800000.pva1: initialized
[ 9.664495] nvdla 15880000.nvdla0: Adding to iommu group 27
[ 9.677184] nvdla 15880000.nvdla0: initialized
[ 9.678399] nvdla 158c0000.nvdla1: Adding to iommu group 28
[ 9.687229] nvdla 158c0000.nvdla1: initialized
[ 9.696318] tegra-slvs-ec 15ac0000.slvs-ec: context isolation disabled due to no IOMMU
[ 9.696933] tegra-slvs-ec 15ac0000.slvs-ec: initialized
[ 9.697379] tegra-slvs-ec 15ac0000.slvs-ec: No streams defined - setting to zero
[ 9.697599] tegra-slvs-ec 15ac0000.slvs-ec: slvs has 0 available streams
[ 9.697870] tegra-slvs-ec 15ac0000.slvs-ec: probed
[ 9.701496] tegradccommon 15200000.display-hub: host1x channel mapped
[ 9.701849] tegradccommon 15200000.display-hub: dc_common syncpt # 1 allocated
[ 9.702186] tegradccommon 15200000.display-hub: dma mapping done
[ 9.703404] tegradc 15210000.display: Adding to iommu group 29
[ 9.703511] tegradc 15200000.display: Adding to iommu group 29
[ 9.705415] tegradc 15210000.display: disp0 connected to head1->sor
[ 9.705892] tegradc 15210000.display: tegra_dc_parse_panel_ops: panel: dp-display is not active
[ 9.706239] tegradc 15210000.display: err:-19 parsing panel_ops
[ 9.707565] tegradc 15200000.display: disp0 connected to head0->sor2
[ 9.709477] tegradc 15220000.display: Adding to iommu group 29
[ 9.710903] tegradc 15200000.display: tegra_dc_parse_panel_ops: panel: hdmi-display is not active
[ 9.717150] tegra_cec 3960000.tegra_cec: dt=1 start=0x03960000 end=0x03960FFF irq=66
[ 9.725255] tegradc 15200000.display: err:-19 parsing panel_ops
[ 9.725547] tegradc 15220000.display: disp0 connected to head2->sor1
[ 9.733077] tegra_cec 3960000.tegra_cec: Unpowergated DISP
[ 9.739423] tegradc 15220000.display: tegra_dc_parse_panel_ops: panel: dp-display is not active
[ 9.746259] tegra_cec 3960000.tegra_cec: Enable clock result: 0.
[ 9.751032] tegradc 15220000.display: err:-19 parsing panel_ops
[ 9.772183] tegra_cec 3960000.tegra_cec: tegra_cec_init started
[ 9.777872] tegra_cec 3960000.tegra_cec: cec_add_sysfs ret=0
[ 9.782954] tegra_cec 3960000.tegra_cec: probed
[ 9.788619] tegra-gpcdma 2600000.dma: Adding to iommu group 2
[ 9.796040] tegra-gpcdma 2600000.dma: GPC DMA driver register 31 channels
[ 9.800857] kfuse 3830000.kfuse: initialized
[ 9.805882] tegra-fuse-burn efuse-burn: shutdown limit check disabled
[ 9.811903] tegra-fuse-burn efuse-burn: Fuse burn driver initialized
[ 9.818568] serial-tegra 3100000.serial: Adding to iommu group 2
[ 9.824404] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 35, base_baud = 0) is a TEGRA_UART
[ 9.833613] serial-tegra 3110000.serial: Adding to iommu group 2
[ 9.839307] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 36, base_baud = 0) is a TEGRA_UART
[ 9.849006] serial-tegra 3140000.serial: Adding to iommu group 2
[ 9.854160] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 37, base_baud = 0) is a TEGRA_UART
[ 9.898122] tegra-i2c 31e0000.i2c: Adding to iommu group 2
[ 9.902662] mpq7920 8-0069: valid gpio for HPC PMIC_PWRON
[ 9.902980] mpq7920 8-0069: request gpio for PMIC_PWRON [OK]
[ 9.903189] mpq7920 8-0069: corrct regulator gpio for HPC PMIC_PWRON, on!
[ 10.053909] mpq7920 8-0069: valid gpio for HPC ENET3v_3_EN
[ 10.054267] mpq7920 8-0069: request gpio for PCIE Switch RSTB [OK]
[ 10.054448] mpq7920 8-0069: corrct regulator gpio for HPC ENET3v_3_EN, on!
[ 10.204788] mpq7920 8-0069: valid gpio for PCIE Switch RSTB
[ 10.205001] mpq7920 8-0069: request gpio for PCIE Switch RSTB [OK]
[ 10.205256] mpq7920 8-0069: --> pull high PCIE Switch RSTB
[ 10.555655] mpq7920 8-0069: --> pull low PCIE Switch RSTB
[ 10.567995] mpq7920 8-0069: --> pull high PCIE Switch RSTB
[ 10.568502] irq: IRQ270: trimming hierarchy from :pmc@c360000
[ 10.589480] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 2047000 KHz, changing to: 2035200 KHz
[ 10.590584] tegra194-cpufreq ccplex: probed with BWMGR
[ 10.592048] sdhci-tegra 3460000.sdhci: BWMGR client registration for eMC Successful
[ 10.592192] reg-fixed-voltage fixed-regulators:regulator@106: nonexclusive access to GPIO for fixed-regulators:regulator@106
[ 10.592821] reg-fixed-voltage fixed-regulators:regulator@112: nonexclusive access to GPIO for fixed-regulators:regulator@112
[ 10.593144] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 10.593357] sdhci-tegra 3400000.sdhci: BWMGR client registration for eMC Successful
[ 10.593549] vdd-5v-sata: supplied by vdd-ac-bat
[ 10.599602] tegra194-isp5 13e10000.host1x:isp@14800000: initialized
[ 10.602587] irq: IRQ271: trimming hierarchy from :interrupt-controller@3881000
[ 10.602884] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 271
[ 10.603693] mmc0: CQHCI version 5.10
[ 10.608919] tegra194-vi5 15c10000.vi: initialized
[ 10.616035] tegra-xusb 3610000.xhci: Firmware timestamp: 2022-03-16 11:07:43 UTC, Version: 60.13 release
[ 10.616317] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 10.616493] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 10.617335] tegra-xusb 3610000.xhci: hcc params 0x0184ff25 hci version 0x110 quirks 0x0000000000050810
[ 10.621754] tegra-xusb 3610000.xhci: irq 196, io mem 0x03610000
[ 10.628200] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 10.632634] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit
[ 10.636033] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 10.651129] usb usb1: Product: xHCI Host Controller
[ 10.655795] usb usb1: Manufacturer: Linux 5.10.104-tegra xhci-hcd
[ 10.662034] usb usb1: SerialNumber: 3610000.xhci
[ 10.667280] hub 1-0:1.0: USB hub found
[ 10.670801] hub 1-0:1.0: 4 ports detected
[ 10.675223] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 10.680154] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 10.687967] mmc1: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit
[ 10.695765] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 10.702937] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 10.711335] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 10.718597] usb usb2: Product: xHCI Host Controller
[ 10.723497] usb usb2: Manufacturer: Linux 5.10.104-tegra xhci-hcd
[ 10.729622] usb usb2: SerialNumber: 3610000.xhci
[ 10.734474] hub 2-0:1.0: USB hub found
[ 10.738107] hub 2-0:1.0: 4 ports detected
[ 10.745319] nvethernet 2490000.ethernet: Adding to iommu group 30
[ 10.748539] nvethernet 2490000.ethernet: failed to read skip mac reset flag, default 0
[ 10.751606] mmc0: Command Queue Engine enabled
[ 10.756439] nvethernet 2490000.ethernet: failed to read MDIO address
[ 10.760864] mmc0: periodic cache flush enabled
[ 10.760878] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 10.767631] nvethernet 2490000.ethernet: setting to default DMA bit mask
[ 10.772105] mmcblk0: mmc0:0001 G1J38E 59.3 GiB
[ 10.778422] nvethernet 2490000.ethernet: set default TXQ to TC mapping
[ 10.785741] tegra_cec 3960000.tegra_cec: Can't find physical address.
[ 10.789765] nvethernet 2490000.ethernet: Setting default PTP RX queue
[ 10.789789] mmcblk0rpmb: mmc0:0001 G1J38E partition 3 4.00 MiB, chardev (510:0)
[ 10.796095] tegra_cec 3960000.tegra_cec: tegra_cec_init Done.
[ 10.802297] nvethernet 2490000.ethernet: Failed to read DMA Tx ring size, using default [1024]
[ 10.829919] nvethernet 2490000.ethernet: Failed to read DMA Tx ring size, using default [1024]
[ 10.845855] nvethernet 2490000.ethernet: failed to get eqos_rx_m clk
[ 10.846039] nvethernet 2490000.ethernet: failed to get eqos_rx_input clk
[ 10.848440] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15
[ 10.851529] nvethernet 2490000.ethernet: failed to get eqos_tx_divider clk
[ 10.853142] nvethernet 2490000.ethernet: Ethernet MAC address: 48:b0:2d:55:cb:38
[ 10.872827] -->macsec_probe()
[ 10.872833] <--macsec_probe()
[ 10.872856] nvethernet 2490000.ethernet: Macsec not supported
[ 10.880189] nvethernet 2490000.ethernet: eth0 (HW ver: 50) created with 1 DMA channels
[ 10.888289] irq: IRQ273: trimming hierarchy from :pmc@c360000
[ 10.892759] irq: IRQ274: trimming hierarchy from :interrupt-controller@3881000
[ 10.899797] gpio-keys gpio-keys: failed to get gpio: -16
[ 10.905571] gpio-keys: probe of gpio-keys failed with error -16
[ 10.911842] tegra-se-nvhost 15810000.se: Adding to iommu group 31
[ 10.919402] tegra-se-nvhost 15810000.se: initialized
[ 10.928815] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 10.929446] tegra-se-nvhost 15820000.se: Adding to iommu group 32
[ 10.935641] tegra-se-nvhost 15820000.se: initialized
[ 10.941807] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 10.946237] tegra-se-nvhost 15830000.se: Adding to iommu group 33
[ 10.953024] tegra-se-nvhost 15830000.se: initialized
[ 10.958256] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 10.963611] tegra-se-nvhost 15840000.se: Adding to iommu group 34
[ 10.970328] tegra-se-nvhost 15840000.se: initialized
[ 10.975995] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 10.982319] tegra_actmon d230000.actmon: in actmon_register()...
[ 10.986468] tegra_actmon d230000.actmon: bwmgr_disable = 0
[ 10.992503] tegra_actmon d230000.actmon: initialization Completed for the device mc_all
[ 11.000355] hvc_sysfs: hypervisor is not present
[ 11.057270] ALSA device list:
[ 11.057371] No soundcards found.
[ 11.058537] Freeing unused kernel memory: 3968K
[ 11.058806] Run /init as init process
[ 11.058912] with arguments:
[ 11.058916] /init
[ 11.058919] with environment:
[ 11.058922] HOME=/
[ 11.058926] TERM=linux
[ 11.058929] mminit_loglevel=4
[ 11.112107] Root device found: PARTUUID=89f4ed76-7243-40e7-943a-4b02060d69bf
[ 11.703480] EXT4-fs (mmcblk0p1): 16 orphan inodes deleted
[ 11.703626] EXT4-fs (mmcblk0p1): recovery complete
[ 11.709589] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 11.719836] Rootfs mounted over PARTUUID=89f4ed76-7243-40e7-943a-4b02060d69bf
[ 11.751529] Switching from initrd to actual rootfs
[ 11.884081] systemd[1]: System time before build time, advancing clock.
[ 11.910048] x_tables: module verification failed: signature and/or required key missing - tainting kernel
[ 12.181582] systemd[1]: systemd 245.4-4ubuntu3.19 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[ 12.184165] systemd[1]: Detected architecture arm64.
[ 12.223386] systemd[1]: Set hostname to <tegra-ubuntu>.
[ 12.879955] systemd[1]: system-modprobe.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[ 12.880383] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[ 12.885400] systemd[1]: Created slice system-modprobe.slice.
[ 12.887158] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 12.888471] systemd[1]: Created slice User and Session Slice.
[ 12.889126] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 12.890889] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 12.891473] systemd[1]: Reached target User and Group Name Lookups.
[ 12.891891] systemd[1]: Reached target Slices.
[ 12.892224] systemd[1]: Reached target Swap.
[ 12.893445] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 12.894334] systemd[1]: Listening on Syslog Socket.
[ 12.895115] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 12.895694] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 12.905247] systemd[1]: Listening on Journal Audit Socket.
[ 12.906070] systemd[1]: Listening on Journal Socket (/dev/log).
[ 12.906976] systemd[1]: Listening on Journal Socket.
[ 12.907842] systemd[1]: Listening on udev Control Socket.
[ 12.908515] systemd[1]: Listening on udev Kernel Socket.
[ 12.916594] systemd[1]: Mounting Huge Pages File System...
[ 12.922655] systemd[1]: Mounting POSIX Message Queue File System...
[ 12.928365] systemd[1]: Mounting RPC Pipe File System...
[ 12.934314] systemd[1]: Mounting Kernel Debug File System...
[ 12.939858] systemd[1]: Mounting Kernel Trace File System...
[ 12.946948] systemd[1]: Starting Journal Service...
[ 12.953043] systemd[1]: Starting Set the console keyboard layout...
[ 12.958401] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ 12.964896] systemd[1]: Starting Load Kernel Module chromeos_pstore...
[ 12.967556] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[ 12.979606] systemd[1]: Starting Load Kernel Module efi_pstore...
[ 12.986052] systemd[1]: Starting Load Kernel Module pstore_blk...
[ 12.991883] systemd[1]: Starting Load Kernel Module pstore_zone...
[ 12.998478] systemd[1]: Starting Load Kernel Module ramoops...
[ 13.004096] systemd[1]: Starting NVIDIA specific first-boot udev script...
[ 13.011307] systemd[1]: Started Nameserver information manager.
[ 13.013464] systemd[1]: Reached target Network (Pre).
[ 13.019668] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 13.031870] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 13.059494] systemd[1]: Starting Load Kernel Modules...
[ 13.064812] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 13.069737] systemd[1]: Starting udev Coldplug all Devices...
[ 13.092090] systemd[1]: Mounted Huge Pages File System.
[ 13.097325] systemd[1]: Mounted POSIX Message Queue File System.
[ 13.108042] systemd[1]: Mounted RPC Pipe File System.
[ 13.117215] systemd[1]: Mounted Kernel Debug File System.
[ 13.122397] systemd[1]: Mounted Kernel Trace File System.
[ 13.142893] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 13.145998] systemd[1]: modprobe@chromeos_pstore.service: Succeeded.
[ 13.147280] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 13.148410] systemd[1]: Finished Load Kernel Module chromeos_pstore.
[ 13.153268] systemd[1]: modprobe@efi_pstore.service: Succeeded.
[ 13.156152] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 13.156760] systemd[1]: Finished Load Kernel Module efi_pstore.
[ 13.157756] tegra-carveouts tegra-carveouts: vpr :dma coherent mem declare 0x000000074e000000,704643072
[ 13.158040] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 13.158299] nvmap_page_pool_init: Total RAM pages: 6907044
[ 13.158464] nvmap_page_pool_init: nvmap page pool size: 863380 pages (3372 MB)
[ 13.158823] systemd[1]: modprobe@pstore_blk.service: Succeeded.
[ 13.159006] nvmap_background_zero_thread: PP zeroing thread starting.
[ 13.163773] systemd[1]: Finished Load Kernel Module pstore_blk.
[ 13.164077] misc nvmap: created heap vpr base 0x000000074e000000 size (688128KiB)
[ 13.164233] misc nvmap: cvsram :dma coherent mem declare 0x0000000050000000,4194304
[ 13.164245] misc nvmap: created heap cvsram base 0x0000000050000000 size (4096KiB)
[ 13.198903] systemd[1]: modprobe@pstore_zone.service: Succeeded.
[ 13.205320] systemd[1]: Finished Load Kernel Module pstore_zone.
[ 13.210510] systemd[1]: modprobe@ramoops.service: Succeeded.
[ 13.216715] systemd[1]: Finished Load Kernel Module ramoops.
[ 13.222367] systemd[1]: nvfb-udev.service: Succeeded.
[ 13.227725] systemd[1]: Finished NVIDIA specific first-boot udev script.
[ 13.238936] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 13.243480] systemd[1]: Finished Set the console keyboard layout.
[ 13.248163] tegra-xusb 3610000.xhci: entering ELPG done
[ 13.254102] nvgpu: 17000000.gv11b nvgpu_nvhost_syncpt_init:135 [INFO] syncpt_unit_base 60000000 syncpt_unit_size 400000 size 1000
[ 13.257186] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[ 13.273110] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[ 13.287471] systemd[1]: Starting Load/Save Random Seed...
[ 13.292292] systemd[1]: Starting Create System Users...
[ 13.339319] systemd[1]: Finished Load Kernel Modules.
[ 13.344629] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[ 13.351047] systemd[1]: Mounting Kernel Configuration File System...
[ 13.356667] systemd[1]: Started OP-TEE Client Supplicant.
[ 13.362034] systemd[1]: Starting Apply Kernel Variables...
[ 13.370200] systemd[1]: Mounted Kernel Configuration File System.
[ 13.392872] systemd[1]: Finished Load/Save Random Seed.
[ 13.414529] systemd[1]: Finished Create System Users.
[ 13.420698] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 13.456155] systemd[1]: Started Journal Service.
[ 13.495202] systemd-journald[271]: Received client request to flush runtime journal.
[ 14.640729] spi-tegra114 3210000.spi: Adding to iommu group 2
[ 14.678092] tegra-qspi 3300000.spi: Adding to iommu group 2
[ 14.701880] spi-tegra114 c260000.spi: Adding to iommu group 2
[ 14.702047] tegra-hda 3510000.hda: Adding to iommu group 35
[ 14.705587] tegra-hda 3510000.hda: Override SDO lines to 4
[ 14.735450] irq: IRQ275: trimming hierarchy from :pmc@c360000
[ 14.765659] cpu-throttle-alert cooling device registered.
[ 14.765872] nvadsp 2993000.adsp: Adding to iommu group 36
[ 14.766136] nvadsp 2993000.adsp: in probe()...
[ 14.767115] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 16 channels
[ 14.768363] gpu-throttle-alert cooling device registered.
[ 14.770243] aux-throttle-alert cooling device registered.
[ 14.770407] nvadsp 2993000.adsp: nvadsp_app_module_probe
[ 14.770733] hot-surface-alert cooling device registered.
[ 14.828508] input: NVIDIA Jetson AGX Xavier HDA HDMI/DP,pcm=3 as /devices/platform/3510000.hda/sound/card0/input1
[ 14.828832] input: NVIDIA Jetson AGX Xavier HDA HDMI/DP,pcm=7 as /devices/platform/3510000.hda/sound/card0/input2
[ 14.829105] input: NVIDIA Jetson AGX Xavier HDA HDMI/DP,pcm=8 as /devices/platform/3510000.hda/sound/card0/input3
[ 14.829329] input: NVIDIA Jetson AGX Xavier HDA HDMI/DP,pcm=9 as /devices/platform/3510000.hda/sound/card0/input4
[ 14.896313] tegra210-adsp aconnect@2a41000:adsp_audio: Adding to iommu group 36
[ 14.896366] tegra210_adsp_audio_probe: platform probe started
[ 14.897464] tegra210-adsp tegra210-adsp: Default param-type to BYTE for mp3-dec1
[ 14.905418] tegra210-adsp tegra210-adsp: Default param-type to BYTE for spkprot
[ 14.907212] tegra210-adsp tegra210-adsp: Default param-type to BYTE for src
[ 14.908076] tegra210-adsp tegra210-adsp: Default param-type to BYTE for aac-dec1
[ 14.908937] tegra210-adsp tegra210-adsp: Default param-type to BYTE for aec
[ 14.909811] tegra210-adsp tegra210-adsp: Default param-type to BYTE for wire
[ 14.909823] tegra210-adsp tegra210-adsp: adma channel page address dt entry not found
[ 14.909828] tegra210-adsp tegra210-adsp: using adma channel page 0
[ 14.909959] nvadsp 2993000.adsp: ADSP OS firmware already loaded
[ 14.935682] irq: IRQ277: trimming hierarchy from :pmc@c360000
[ 14.950537] irq: IRQ278: trimming hierarchy from :pmc@c360000
[ 14.950559] nct1008_nct72 4-004c: starting parse dt
[ 14.950644] nct1008_nct72 4-004c: !!!Found deprecated property!!!
[ 14.950651] nct1008_nct72 4-004c: success parsing dt
[ 14.950831] nct1008_nct72 4-004c: success in enabling tmp451 VDD rail
[ 14.987047] nct1008_nct72 4-004c: LOC shutdown limit 107
[ 14.987854] nct1008_nct72 4-004c: EXT shutdown limit 109
[ 15.031164] nct1008_nct72 4-004c: initial LOC temp: 29000
[ 15.037117] nct1008_nct72 4-004c: initial EXT temp: 32500
[ 15.038659] nct1008_nct72 4-004c: hi_b:-10, lo_b:128
[ 15.040281] nct1008_nct72 4-004c: nct1008_probe: initialized
[ 15.051913] irq: IRQ279: trimming hierarchy from :pmc@c360000
[ 15.130592] tegra-asoc: sound: Adding to iommu group 36
[ 15.270260] rt5659 7-001a: Device with ID register 55ebc20 is not rt5659
[ 15.274162] tegra210-adsp tegra210-adsp: Loaded app wire
[ 15.274173] tegra210-adsp tegra210-adsp: Loaded app apm
[ 15.274178] tegra210-adsp tegra210-adsp: Loaded app adma
[ 15.274183] tegra210-adsp tegra210-adsp: Loaded app adma_tx
[ 15.274193] nvadsp_set_adma_dump_reg: callback for adma reg dump is sent to 00000000c1a92141
[ 15.295708] tegra210-adsp tegra210-adsp: Tegra210 ADSP driver successfully registered
[ 15.484014] using random self ethernet address
[ 15.484156] using random host ethernet address
[ 15.636258] cryptd: max_cpu_qlen set to 1000
[ 16.079723] loop: module loaded
[ 16.555166] Mass Storage Function, version: 2009/09/11
[ 16.555180] LUN: removable file: (no medium)
[ 16.563810] using random self ethernet address
[ 16.564025] using random host ethernet address
[ 16.609393] rndis0: HOST MAC 06:f7:c0:25:49:f0
[ 16.609403] rndis0: MAC 06:f7:c0:25:49:f1
[ 16.613174] usb0: HOST MAC 06:f7:c0:25:49:f2
[ 16.613183] usb0: MAC 06:f7:c0:25:49:f3
[ 16.613248] tegra-xudc 3550000.xudc: EP 0 (type: ctrl, dir: out) enabled
[ 16.655202] l4tbr0: port 1(rndis0) entered blocking state
[ 16.655233] l4tbr0: port 1(rndis0) entered disabled state
[ 16.655847] device rndis0 entered promiscuous mode
[ 16.694535] l4tbr0: port 2(usb0) entered blocking state
[ 16.694912] l4tbr0: port 2(usb0) entered disabled state
[ 16.695565] device usb0 entered promiscuous mode
[ 17.136612] tegra-xudc 3550000.xudc: EP 5 (type: intr, dir: in) enabled
[ 17.136650] tegra-xudc 3550000.xudc: EP 3 (type: bulk, dir: in) enabled
[ 17.136663] tegra-xudc 3550000.xudc: EP 2 (type: bulk, dir: out) enabled
[ 17.136783] tegra-xudc 3550000.xudc: EP 9 (type: intr, dir: in) enabled
[ 17.136800] tegra-xudc 3550000.xudc: EP 7 (type: bulk, dir: in) enabled
[ 17.136812] tegra-xudc 3550000.xudc: EP 4 (type: bulk, dir: out) enabled
[ 17.136856] tegra-xudc 3550000.xudc: EP 15 (type: intr, dir: in) enabled
[ 17.136889] tegra-xudc 3550000.xudc: EP 11 (type: bulk, dir: in) enabled
[ 17.136904] tegra-xudc 3550000.xudc: EP 6 (type: bulk, dir: out) enabled
[ 17.136966] IPv6: ADDRCONF(NETDEV_CHANGE): rndis0: link becomes ready
[ 17.155706] tegra-xudc 3550000.xudc: EP 13 (type: bulk, dir: in) enabled
[ 17.155725] tegra-xudc 3550000.xudc: EP 8 (type: bulk, dir: out) enabled
[ 17.156305] IPv6: ADDRCONF(NETDEV_CHANGE): usb0: link becomes ready
[ 17.157456] tegra-xudc 3550000.xudc: ep 13 disabled
[ 17.157538] tegra-xudc 3550000.xudc: ep 8 disabled
[ 17.175208] tegra-xudc 3550000.xudc: EP 13 (type: bulk, dir: in) enabled
[ 17.175224] tegra-xudc 3550000.xudc: EP 8 (type: bulk, dir: out) enabled
[ 23.158590] l4tbr0: port 2(usb0) entered blocking state
[ 23.158605] l4tbr0: port 2(usb0) entered forwarding state
[ 23.158732] l4tbr0: port 1(rndis0) entered blocking state
[ 23.158742] l4tbr0: port 1(rndis0) entered forwarding state
[ 23.158976] IPv6: ADDRCONF(NETDEV_CHANGE): l4tbr0: link becomes ready
[ 23.603931] irq: IRQ280: trimming hierarchy from :interrupt-controller@3881000
[ 28.993040] nvgpu: 17000000.gv11b tpc_pg_mask_store:1067 [INFO] no value change, same mask already set
[ 29.084473] nvgpu: 17000000.gv11b gk20a_scale_init:539 [INFO] enabled scaling for GPU
[ 32.181245] zram: Added device: zram0
[ 32.182701] zram: Added device: zram1
[ 32.184704] zram: Added device: zram2
[ 32.186791] zram: Added device: zram3
[ 32.203955] zram: Added device: zram4
[ 32.211379] zram: Added device: zram5
[ 32.213553] zram: Added device: zram6
[ 32.215361] zram: Added device: zram7
[ 32.405889] zram0: detected capacity change from 0 to 1768206336
[ 32.577959] Adding 1726760k swap on /dev/zram0. Priority:5 extents:1 across:1726760k SS
[ 32.591256] zram1: detected capacity change from 0 to 1768206336
[ 32.657936] Adding 1726760k swap on /dev/zram1. Priority:5 extents:1 across:1726760k SS
[ 32.663207] zram2: detected capacity change from 0 to 1768206336
[ 32.726373] Adding 1726760k swap on /dev/zram2. Priority:5 extents:1 across:1726760k SS
[ 32.732463] zram3: detected capacity change from 0 to 1768206336
[ 32.797970] Adding 1726760k swap on /dev/zram3. Priority:5 extents:1 across:1726760k SS
[ 32.802873] zram4: detected capacity change from 0 to 1768206336
[ 32.865982] Adding 1726760k swap on /dev/zram4. Priority:5 extents:1 across:1726760k SS
[ 32.871865] zram5: detected capacity change from 0 to 1768206336
[ 32.934110] Adding 1726760k swap on /dev/zram5. Priority:5 extents:1 across:1726760k SS
[ 32.939013] zram6: detected capacity change from 0 to 1768206336
[ 32.997929] Adding 1726760k swap on /dev/zram6. Priority:5 extents:1 across:1726760k SS
[ 33.002650] zram7: detected capacity change from 0 to 1768206336
[ 33.109965] Adding 1726760k swap on /dev/zram7. Priority:5 extents:1 across:1726760k SS
[ 34.783088] fuse: init (API version 7.32)
[ 35.248405] nvidia: loading out-of-tree module taints kernel.
[ 35.271156] NVRM: No NVIDIA GPU found.
[ 41.954475] vdd-3v3-cvb: disabling
[ 41.954545] vdd-epb-1v0: disabling
[ 41.954560] vdd-sata-1v5: disabling
[ 41.954573] vdd-1v8-slt: disabling
[ 41.954585] vdd-3v3-slt: disabling
[ 2371.044947] tegra194-pcie 141a0000.pcie: host bridge /pcie@141a0000 ranges:
[ 2371.045100] tegra194-pcie 141a0000.pcie: IO 0x003a100000..0x003a1fffff -> 0x003a100000
[ 2371.045340] tegra194-pcie 141a0000.pcie: MEM 0x1c00000000..0x1f3fffffff -> 0x1c00000000
[ 2371.045366] tegra194-pcie 141a0000.pcie: MEM 0x1f40000000..0x1fffffffff -> 0x0040000000
[ 2371.153901] tegra194-pcie 141a0000.pcie: Link up
SSH 192.168.55.1: session closed
Press any key to reconnect
