[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x4e0f0040]
[ 0.000000] Linux version 5.10.216-tegra (buildbrain@mobile-u64-6429-d8000) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2020.08) 9.3.0, GNU ld (GNU Binutils) 2.33.1) #1 SMP PREEMPT Wed Aug 28 01:46:00 PDT 2024
[ 0.000000] Machine model: Jetson-AGX
[ 0.000000] efi: EFI v2.70 by EDK II
[ 0.000000] efi: RTPROP=0x875e96a98 SMBIOS=0xc7bb0000 SMBIOS 3.0=0x87aee0000 MEMATTR=0x8759f2018 ESRT=0x874dffe98 RNG=0x869c90018 MEMRESERVE=0x86a605f18
[ 0.000000] random: crng init done
[ 0.000000] esrt: Reserving ESRT space from 0x0000000874dffe98 to 0x0000000874dffed0.
[ 0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'fb2_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'fb3_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x000000087fffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x00000000a0a6afff]
[ 0.000000] node 0: [mem 0x00000000a0a6b000-0x00000000a0a6cfff]
[ 0.000000] node 0: [mem 0x00000000a0a6e000-0x00000000aeffffff]
[ 0.000000] node 0: [mem 0x00000000af010000-0x00000000c79fffff]
[ 0.000000] node 0: [mem 0x00000000c7b00000-0x00000000c7b9ffff]
[ 0.000000] node 0: [mem 0x00000000c7ba0000-0x00000000c7bbffff]
[ 0.000000] node 0: [mem 0x00000000ca000000-0x00000000ca7fffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x000000086c7c5fff]
[ 0.000000] node 0: [mem 0x000000086c7c6000-0x000000086c9cbfff]
[ 0.000000] node 0: [mem 0x000000086c9cc000-0x0000000879eaffff]
[ 0.000000] node 0: [mem 0x0000000879eb0000-0x000000087bdeffff]
[ 0.000000] node 0: [mem 0x000000087bdf0000-0x000000087fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000087fffffff]
[ 0.000000] On node 0 totalpages: 8159919
[ 0.000000] DMA zone: 4619 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 295599 pages, LIFO batch:63
[ 0.000000] Normal zone: 122880 pages used for memmap
[ 0.000000] Normal zone: 7864320 pages, LIFO batch:63
[ 0.000000] On node 0, zone DMA: 1 pages in unavailable ranges
[ 0.000000] cma: Reserved 64 MiB at 0x00000000c3800000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 32 pages/cpu s90392 r8192 d32488 u131072
[ 0.000000] pcpu-alloc: s90392 r8192 d32488 u131072 alloc=32*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [0] 6 [0] 7
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: Virtualization Host Extensions
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] CPU features: detected: Spectre-v2
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] CPU features: detected: NVIDIA Carmel CNP erratum
[ 0.000000] alternatives: patching kernel code
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 8032420
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 rootfstype=ext4 video=efifb:off nospectre_bhb nv-auto-config
[ 0.000000] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x00000000b3800000-0x00000000c3800000] (256MB)
[ 0.000000] Memory: 31655376K/32639676K available (18560K kernel code, 3170K rwdata, 7240K rodata, 3968K init, 1415K bss, 918764K reserved, 65536K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=8.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000004] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000751] Console: colour dummy device 80x25
[ 0.001749] printk: console [tty0] enabled
[ 0.001811] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.001843] pid_max: default: 32768 minimum: 301
[ 0.002029] LSM: Security Framework initializing
[ 0.002093] Yama: becoming mindful.
[ 0.002132] SELinux: Initializing.
[ 0.002334] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.002415] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.005873] rcu: Hierarchical SRCU implementation.
[ 0.006121] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[ 0.006858] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-5.10/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t19x/galen/kernel-dts/common/tegra194-p2888-0001-p2822-0000-common.dtsi
[ 0.006909] DTB Build time: Aug 28 2024 01:58:20
[ 0.009785] Tegra Revision: A02 SKU: 0xd0 CPU Process: 0 SoC Process: 0
[ 0.010063] Remapping and enabling EFI services.
[ 0.012307] smp: Bringing up secondary CPUs ...
[ 0.041537] Detected PIPT I-cache on CPU1
[ 0.041595] CPU1: Booted secondary processor 0x0000000001 [0x4e0f0040]
[ 0.071183] Detected PIPT I-cache on CPU2
[ 0.071287] CPU2: Booted secondary processor 0x0000000100 [0x4e0f0040]
[ 0.100929] Detected PIPT I-cache on CPU3
[ 0.101026] CPU3: Booted secondary processor 0x0000000101 [0x4e0f0040]
[ 0.130684] Detected PIPT I-cache on CPU4
[ 0.130790] CPU4: Booted secondary processor 0x0000000200 [0x4e0f0040]
[ 0.160532] Detected PIPT I-cache on CPU5
[ 0.160661] CPU5: Booted secondary processor 0x0000000201 [0x4e0f0040]
[ 0.190355] Detected PIPT I-cache on CPU6
[ 0.190465] CPU6: Booted secondary processor 0x0000000300 [0x4e0f0040]
[ 0.220236] Detected PIPT I-cache on CPU7
[ 0.220343] CPU7: Booted secondary processor 0x0000000301 [0x4e0f0040]
[ 0.220785] smp: Brought up 1 node, 8 CPUs
[ 0.221134] SMP: Total of 8 processors activated.
[ 0.221195] CPU features: detected: Privileged Access Never
[ 0.221231] CPU features: detected: LSE atomic instructions
[ 0.221250] CPU features: detected: User Access Override
[ 0.221282] CPU features: detected: 32-bit EL0 Support
[ 0.221300] CPU features: detected: RAS Extension Support
[ 0.221332] CPU features: detected: CRC32 instructions
[ 0.221349] CPU features: detected: 32-bit EL1 Support
[ 0.254714] spectre-bhb mitigation disabled by command line option
[ 0.284645] CPU: All CPU(s) started at EL2
[ 0.294106] devtmpfs: initialized
[ 0.346744] KASLR enabled
[ 0.347090] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.347164] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 0.348243] pinctrl core: initialized pinctrl subsystem
[ 0.349196] SMBIOS 3.0.0 present.
[ 0.349223] DMI: NVIDIA Jetson-AGX/Jetson, BIOS 6.0-37391689 08/28/2024
[ 0.349805] NET: Registered protocol family 16
[ 0.352315] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[ 0.353839] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.355392] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.355465] audit: initializing netlink subsys (disabled)
[ 0.355809] audit: type=2000 audit(0.352:1): state=initialized audit_enabled=0 res=1
[ 0.356234] thermal_sys: Registered thermal governor 'step_wise'
[ 0.356241] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.356265] thermal_sys: Registered thermal governor 'pid_thermal_gov'
[ 0.358750] cpuidle: using governor menu
[ 0.359060] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.359709] ASID allocator initialised with 32768 entries
[ 0.359894] Serial: AMBA PL011 UART driver
[ 0.363766] Tegra reboot handler registered.
[ 0.430436] mc: mapped MMIO address: 0xffff800010ee0000 -> 0x2c10000
[ 0.430495] mc: mapped MMIO address: 0xffff800010f00000 -> 0x2c20000
[ 0.430528] mc: mapped MMIO address: 0xffff800010f20000 -> 0x2c30000
[ 0.430566] mc: mapped MMIO address: 0xffff800010f40000 -> 0x2c40000
[ 0.430606] mc: mapped MMIO address: 0xffff800010f60000 -> 0x2c50000
[ 0.430639] mc: mapped MMIO address: 0xffff800010f80000 -> 0x2b80000
[ 0.430671] mc: mapped MMIO address: 0xffff800010fa0000 -> 0x2b90000
[ 0.430707] mc: mapped MMIO address: 0xffff800010fc0000 -> 0x2ba0000
[ 0.430743] mc: mapped MMIO address: 0xffff800010fe0000 -> 0x2bb0000
[ 0.430775] mc: mapped MMIO address: 0xffff800011000000 -> 0x1700000
[ 0.430806] mc: mapped MMIO address: 0xffff800011020000 -> 0x1710000
[ 0.430837] mc: mapped MMIO address: 0xffff800011040000 -> 0x1720000
[ 0.430889] mc: mapped MMIO address: 0xffff800011060000 -> 0x1730000
[ 0.430920] mc: mapped MMIO address: 0xffff800011080000 -> 0x1740000
[ 0.430951] mc: mapped MMIO address: 0xffff8000110a0000 -> 0x1750000
[ 0.430984] mc: mapped MMIO address: 0xffff8000110c0000 -> 0x1760000
[ 0.431015] mc: mapped MMIO address: 0xffff8000110e0000 -> 0x1770000
[ 0.431101] mc-err: mcerr ops are set to t19x
[ 0.442487] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.442531] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.442552] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.442572] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.448734] ACPI: Interpreter disabled.
[ 0.449437] vdd-epb-1v0: supplied by vdd-3v3-cvb
[ 0.451080] iommu: Default domain type: Translated
[ 0.451175] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.451577] SCSI subsystem initialized
[ 0.451727] usbcore: registered new interface driver usbfs
[ 0.451775] usbcore: registered new interface driver hub
[ 0.451813] usbcore: registered new device driver usb
[ 0.452195] mc: Linux media interface: v0.10
[ 0.452225] videodev: Linux video capture interface: v2.00
[ 0.452504] pps_core: LinuxPPS API ver. 1 registered
[ 0.452522] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.452561] PTP clock support registered
[ 0.452756] tegra_wdt_t18x 30c0000.watchdog: Expiry count is deprecated
[ 0.453079] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.453135] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.453706] Registered efivars operations
[ 0.460969] FPGA manager framework
[ 0.461084] Advanced Linux Sound Architecture Driver Initialized.
[ 0.461642] Bluetooth: Core ver 2.22
[ 0.461684] NET: Registered protocol family 31
[ 0.461703] Bluetooth: HCI device and connection manager initialized
[ 0.461733] Bluetooth: HCI socket layer initialized
[ 0.461757] Bluetooth: L2CAP socket layer initialized
[ 0.461786] Bluetooth: SCO socket layer initialized
[ 0.463358] camchar: rtcpu character device driver loaded
[ 0.464092] clocksource: Switched to clocksource arch_sys_counter
[ 0.740248] VFS: Disk quotas dquot_6.6.0
[ 0.740324] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.741005] pnp: PnP ACPI: disabled
[ 0.752771] la/ptsa driver initialized.
[ 0.752897] NET: Registered protocol family 2
[ 0.753133] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.761288] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear)
[ 0.761532] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.762324] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.762709] TCP: Hash tables configured (established 262144 bind 65536)
[ 0.762875] UDP hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 0.763158] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 0.763571] NET: Registered protocol family 1
[ 0.764324] RPC: Registered named UNIX socket transport module.
[ 0.764346] RPC: Registered udp transport module.
[ 0.764381] RPC: Registered tcp transport module.
[ 0.764395] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.764433] PCI: CLS 0 bytes, default 64
[ 0.764646] Trying to unpack rootfs image as initramfs...
[ 0.956230] Freeing initrd memory: 9560K
[ 0.961387] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.961955] kvm [1]: IPA Size Limit: 40 bits
[ 0.962642] kvm [1]: vgic interrupt IRQ9
[ 0.963389] kvm [1]: VHE mode initialized successfully
[ 0.965327] Initialise system trusted keyrings
[ 0.965646] workingset: timestamp_bits=46 max_order=23 bucket_order=0
[ 0.972925] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.974018] NFS: Registering the id_resolver key type
[ 0.974083] Key type id_resolver registered
[ 0.974113] Key type id_legacy registered
[ 0.974245] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.974292] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.974392] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.986266] NET: Registered protocol family 38
[ 0.986319] Key type asymmetric registered
[ 0.986337] Asymmetric key parser 'x509' registered
[ 0.986405] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 239)
[ 0.986725] io scheduler mq-deadline registered
[ 0.986747] io scheduler kyber registered
[ 0.996779] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 0.996875] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 0.996954] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 0.997030] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 1.003372] scrncapt: init (heads:4 wins:6 planes:4)
[ 1.003647] tegradccommon 15200000.display-hub: Nvhost Channel map failed
[ 1.004765] EINJ: ACPI disabled.
[ 1.008644] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 1.008675] tegra-pmc: ### PMC reset source: SYS_RESET_N
[ 1.008691] tegra-pmc: ### PMC reset level: L0
[ 1.008705] tegra-pmc: ### PMC reset status reg: 0x0
[ 1.008826] tegra-pmc: PMC Prod config success
[ 1.014525] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 2.326989] printk: console [ttyTCU0] enabled
[ 2.333732] arm-smmu 10000000.iommu: probing hardware configuration...
[ 2.337885] arm-smmu 10000000.iommu: SMMUv2 with:
[ 2.342434] arm-smmu 10000000.iommu: stage 1 translation
[ 2.347578] arm-smmu 10000000.iommu: stage 2 translation
[ 2.353021] arm-smmu 10000000.iommu: nested translation
[ 2.358809] arm-smmu 10000000.iommu: stream matching with 128 register groups
[ 2.365975] arm-smmu 10000000.iommu: 64 context banks (0 stage-2 only)
[ 2.377683] arm-smmu 10000000.iommu: Supported page sizes: 0x00001000
[ 2.378724] arm-smmu 10000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 2.385566] arm-smmu 10000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 2.393289] arm-smmu 12000000.iommu: probing hardware configuration...
[ 2.398602] arm-smmu 12000000.iommu: SMMUv2 with:
[ 2.403326] arm-smmu 12000000.iommu: stage 1 translation
[ 2.408588] arm-smmu 12000000.iommu: stage 2 translation
[ 2.414260] arm-smmu 12000000.iommu: nested translation
[ 2.419432] arm-smmu 12000000.iommu: stream matching with 128 register groups
[ 2.426628] arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 2.438537] arm-smmu 12000000.iommu: Supported page sizes: 0x00001000
[ 2.439708] arm-smmu 12000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 2.446565] arm-smmu 12000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 2.453751] arm-smmu-suspend 12000000.smmu_suspend: arm_smmu_suspend probe successful
[ 2.464800] tegra_profiler: version: 1.151, samples/io: 51/30
[ 2.466707] tegra_profiler: auth: init
[ 2.471286] THERMAL EST: found 3 subdevs
[ 2.474398] THERMAL EST num_resources: 0
[ 2.478490] [THERMAL EST subdev 0]
[ 2.481555] [THERMAL EST subdev 1]
[ 2.485225] [THERMAL EST subdev 2]
[ 2.488237] THERMAL EST: Found 2 profiles, default profile is quiet
[ 2.494706] THERMAL EST: thz register success.
[ 2.499220] THERMAL EST: end of probe, return err: 0
[ 2.504230] nvsciipc: loaded module
[ 2.508482] ufs_tegra 2450000.ufshci: Adding to iommu group 0
[ 2.513977] ufs_tegra 2450000.ufshci: freq-table-hz property not specified
[ 2.520256] ufs_tegra 2450000.ufshci: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
[ 2.531042] ufs_tegra 2450000.ufshci: ufshcd_get_vreg: vcc get failed, err=-517
[ 2.547965] tun: Universal TUN/TAP device driver, 1.6
[ 2.549627] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 2.550747] hns3: Copyright (c) 2017 Huawei Corporation.
[ 2.556625] e1000e: Intel(R) PRO/1000 Network Driver
[ 2.561275] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 2.567605] igb: Intel(R) Gigabit Ethernet Network Driver
[ 2.572817] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 2.578960] PPP generic driver version 2.4.2
[ 2.583329] PPP BSD Compression module registered
[ 2.587447] PPP Deflate Compression module registered
[ 2.592700] PPP MPPE Compression module registered
[ 2.597880] usbcore: registered new interface driver r8152
[ 2.603132] usbcore: registered new interface driver asix
[ 2.608900] usbcore: registered new interface driver ax88179_178a
[ 2.615012] usbcore: registered new interface driver cdc_ether
[ 2.620712] usbcore: registered new interface driver net1080
[ 2.626309] usbcore: registered new interface driver cdc_subset
[ 2.632351] usbcore: registered new interface driver zaurus
[ 2.638300] usbcore: registered new interface driver cdc_ncm
[ 2.643976] usbcore: registered new interface driver aqc111
[ 2.649651] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 2.655451] ohci-pci: OHCI PCI platform driver
[ 2.659990] ohci-platform: OHCI generic platform driver
[ 2.665866] tegra-xusb 3610000.xhci: Adding to iommu group 1
[ 2.671898] usbcore: registered new interface driver uas
[ 2.676301] usbcore: registered new interface driver usb-storage
[ 2.682482] tegra-xudc 3550000.xudc: Adding to iommu group 2
[ 2.688651] mousedev: PS/2 mouse device common for all mice
[ 2.693445] usbcore: registered new interface driver xpad
[ 2.701386] tegra_rtc c2a0000.rtc: registered as rtc1
[ 2.704158] tegra_rtc c2a0000.rtc: setting system clock to 1970-01-01T00:00:27 UTC (27)
[ 2.711992] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 2.718525] i2c /dev entries driver
[ 2.721642] tegra-i2c 3160000.i2c: Adding to iommu group 3
[ 2.727889] tegra-i2c c240000.i2c: Adding to iommu group 3
[ 2.733276] tegra-i2c 3180000.i2c: Adding to iommu group 3
[ 2.738296] tegra-i2c 3190000.i2c: Adding to iommu group 3
[ 2.743742] tegra-i2c 31b0000.i2c: Adding to iommu group 3
[ 2.749237] tegra-i2c 31c0000.i2c: Adding to iommu group 3
[ 2.754671] tegra-i2c c250000.i2c: Adding to iommu group 3
[ 2.765979] tegra-camrtc-capture-vi tegra-capture-vi: ep of_device is not enabled endpoint.
[ 2.767754] tegra-camrtc-capture-vi tegra-capture-vi: ep of_device is not enabled endpoint.
[ 2.776018] tegra-camrtc-capture-vi tegra-capture-vi: ep of_device is not enabled endpoint.
[ 2.784832] pps pps0: new PPS source ktimer
[ 2.788439] pps pps0: ktimer PPS source registered
[ 2.793146] pps_ldisc: PPS line discipline registered
[ 2.800465] tegra-oc-event d280000.soctherm-oc-event: OC driver initialized
[ 2.806540] device-mapper: uevent: version 1.0.3
[ 2.810561] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
[ 2.821627] cpuidle: Initializing cpuidle driver
[ 2.825770] sdhci: Secure Digital Host Controller Interface driver
[ 2.829902] sdhci: Copyright(c) Pierre Ossman
[ 2.834354] Synopsys Designware Multimedia Card Interface Driver
[ 2.840848] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.846993] sdhci-tegra 3460000.sdhci: Adding to iommu group 4
[ 2.847170] sdhci-tegra 3400000.sdhci: Adding to iommu group 5
[ 2.847929] SMCCC: SOC_ID: ID = jep106:036b:0019 Revision = 0x00000102
[ 2.849008] tegra-bpmp bpmp: firmware: 128431eec76692047e1ac1ebc0392266
[ 2.873942] max77620 4-003c: PMIC Version OTP:0x51 and ES:0x1
[ 2.887088] vdd-1v0: supplied by regulator-dummy
[ 2.892790] vdd-1v8-hs: supplied by regulator-dummy
[ 2.897740] vdd-1v8-ls: supplied by regulator-dummy
[ 2.902669] vdd-1v8-ao: supplied by regulator-dummy
[ 2.906732] vddio-ddr-1v1: supplied by regulator-dummy
[ 2.911581] vdd-rtc: supplied by regulator-dummy
[ 2.913740] spmic-ldo1: supplied by regulator-dummy
[ 2.915309] vdd-ao-3v3: supplied by regulator-dummy
[ 2.922469] vddio-emmc-3v3: supplied by regulator-dummy
[ 2.929127] spmic-ldo4: supplied by regulator-dummy
[ 2.930760] vdd-usb-3v3: supplied by regulator-dummy
[ 2.937325] vddio-sdmmc1-3v3: supplied by regulator-dummy
[ 2.944021] vdd-csi-1v2: supplied by vdd-1v8-ls
[ 2.950247] spmic-ldo8: supplied by vdd-1v8-ls
[ 2.952385] gpio-510 (gpio_default): hogged as output/high
[ 2.954309] gpio-511 (gpio_default): hogged as output/high
[ 2.959349] gpiochip0: registered GPIOs 504 to 511 on max77620-gpio
[ 3.097952] max77686-rtc max77620-rtc: registered as rtc0
[ 3.099337] max77620-power max20024-power: Event recorder REG_NVERC : 0x40
[ 3.099794] max77620 4-003c: max77620 probe successful
[ 4.102568] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 4.104062] hid: raw HID events driver (C) Jiri Kosina
[ 4.105229] usbcore: registered new interface driver usbhid
[ 4.105395] usbhid: USB HID core driver
[ 4.108595] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 6
[ 4.110015] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 4.193630] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee01ff size=131584
[ 4.194254] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 4.195430] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x448]=0x1900-0x1b40 TX[1x448]=0x1b40-0x1d80
[ 4.196385] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d80-0x3e00 TX[1x8192]=0x3e00-0x5e80
[ 4.198359] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e80-0xaf00 TX[64x320]=0xaf00-0xff80
[ 4.199125] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff80-0x18000 TX[512x64]=0x18000-0x20080
[ 4.199901] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20080-0x20140 TX[1x64]=0x20140-0x20200
[ 4.201706] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (55)
[ 4.201992] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 4.204773] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=9e9c1f2855a3c5345da28a29c2b705ed44dd5253
[ 4.208616] tegra_aon c1a0000.aon: Adding to iommu group 7
[ 4.215121] tegra_aon c1a0000.aon: tegra aon driver probe OK
[ 4.220824] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 4.227579] denver_knobs_init:MTS_VERSION:72064061
[ 4.245985] t19x_cache tegra-cache: probed
[ 4.249642] optee: probing for conduit method.
[ 4.250513] optee: revision 3.22 (eb8130c7)
[ 4.361759] optee: dynamic shared memory is enabled
[ 4.362929] optee: initialized driver
[ 4.367546] nvpmodel: initialized successfully
[ 4.368433] tegra_hv: get_hvd: not initialized yet
[ 4.368616] user_ivc_mempool: hypervisor not present
[ 4.370031] usbcore: registered new interface driver snd-usb-audio
[ 4.371806] u32 classifier
[ 4.371919] input device check on
[ 4.372026] Actions configured
[ 4.372545] Initializing XFRM netlink socket
[ 4.373645] NET: Registered protocol family 10
[ 4.378175] Segment Routing with IPv6
[ 4.378569] NET: Registered protocol family 17
[ 4.378768] NET: Registered protocol family 15
[ 4.379120] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 4.380569] Bluetooth: RFCOMM socket layer initialized
[ 4.380822] Bluetooth: RFCOMM ver 1.11
[ 4.380980] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 4.381230] Bluetooth: HIDP socket layer initialized
[ 4.382324] 9pnet: Installing 9P2000 support
[ 4.382606] Key type dns_resolver registered
[ 4.384489] registered taskstats version 1
[ 4.384699] Loading compiled-in X.509 certificates
[ 4.423795] Loaded X.509 cert 'Build time autogenerated kernel key: 8bf422cbdacfe43c83374f4270ed8f21e8dceb0f'
[ 4.425756] tegra194-pcie 14180000.pcie: Adding to iommu group 8
[ 4.433640] tegra194-pcie 14180000.pcie: host bridge /pcie@14180000 ranges:
[ 4.434049] tegra194-pcie 14180000.pcie: IO 0x0038100000..0x00381fffff -> 0x0038100000
[ 4.434363] tegra194-pcie 14180000.pcie: MEM 0x1800000000..0x1b3fffffff -> 0x1800000000
[ 4.434768] tegra194-pcie 14180000.pcie: MEM 0x1b40000000..0x1bffffffff -> 0x0040000000
[ 5.536817] tegra194-pcie 14180000.pcie: Phy link never came up
[ 5.537325] tegra194-pcie 14180000.pcie: PCI host bridge to bus 0000:00
[ 5.537536] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 5.537823] pci_bus 0000:00: root bus resource [io 0x0000-0xfffff] (bus address [0x38100000-0x381fffff])
[ 5.538132] pci_bus 0000:00: root bus resource [mem 0x1800000000-0x1b3fffffff pref]
[ 5.538355] pci_bus 0000:00: root bus resource [mem 0x1b40000000-0x1bffffffff] (bus address [0x40000000-0xffffffff])
[ 5.538859] pci 0000:00:00.0: [10de:1ad0] type 01 class 0x060400
[ 5.539322] pci 0000:00:00.0: PME# supported from D0 D3hot D3cold
[ 5.572022] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[ 5.572574] pci 0000:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 5.575206] pcieport 0000:00:00.0: Adding to iommu group 8
[ 5.577155] pcieport 0000:00:00.0: PME: Signaling with IRQ 24
[ 5.579197] pcieport 0000:00:00.0: AER: enabled with IRQ 24
[ 5.581153] pci_bus 0000:01: busn_res: [bus 01-ff] is released
[ 5.582238] pci 0000:00:00.0: Removing from iommu group 8
[ 5.582665] pci_bus 0000:00: busn_res: [bus 00-ff] is released
[ 5.587422] tegra194-pcie 14100000.pcie: Adding to iommu group 9
[ 5.593137] tegra194-pcie 14100000.pcie: host bridge /pcie@14100000 ranges:
[ 5.593579] tegra194-pcie 14100000.pcie: IO 0x0030100000..0x00301fffff -> 0x0030100000
[ 5.593958] tegra194-pcie 14100000.pcie: MEM 0x1200000000..0x122fffffff -> 0x1200000000
[ 5.594276] tegra194-pcie 14100000.pcie: MEM 0x1230000000..0x123fffffff -> 0x0040000000
[ 5.700204] tegra194-pcie 14100000.pcie: Link up
[ 5.711671] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[ 5.711898] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 5.712127] pci_bus 0001:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x30100000-0x301fffff])
[ 5.712386] pci_bus 0001:00: root bus resource [mem 0x1200000000-0x122fffffff pref]
[ 5.712673] pci_bus 0001:00: root bus resource [mem 0x1230000000-0x123fffffff] (bus address [0x40000000-0x4fffffff])
[ 5.713066] pci 0001:00:00.0: [10de:1ad2] type 01 class 0x060400
[ 5.713498] pci 0001:00:00.0: PME# supported from D0 D3hot D3cold
[ 5.727350] pci 0001:01:00.0: [1b4b:9171] type 00 class 0x010601
[ 5.727821] pci 0001:01:00.0: reg 0x10: [io 0x8000-0x8007]
[ 5.728235] pci 0001:01:00.0: reg 0x14: [io 0x8040-0x8043]
[ 5.728576] pci 0001:01:00.0: reg 0x18: [io 0x8100-0x8107]
[ 5.728903] pci 0001:01:00.0: reg 0x1c: [io 0x8140-0x8143]
[ 5.729187] pci 0001:01:00.0: reg 0x20: [io 0x800000-0x80000f]
[ 5.729499] pci 0001:01:00.0: reg 0x24: [mem 0x00900000-0x009001ff]
[ 5.729851] pci 0001:01:00.0: reg 0x30: [mem 0xd0000000-0xd000ffff pref]
[ 5.730598] pci 0001:01:00.0: PME# supported from D3hot
[ 5.754935] pci 0001:00:00.0: BAR 14: assigned [mem 0x1230000000-0x12300fffff]
[ 5.755316] pci 0001:00:00.0: BAR 13: assigned [io 0x100000-0x100fff]
[ 5.755541] pci 0001:01:00.0: BAR 6: assigned [mem 0x1230000000-0x123000ffff pref]
[ 5.755857] pci 0001:01:00.0: BAR 5: assigned [mem 0x1230010000-0x12300101ff]
[ 5.756226] pci 0001:01:00.0: BAR 4: assigned [io 0x100000-0x10000f]
[ 5.760943] pci 0001:01:00.0: BAR 0: assigned [io 0x100010-0x100017]
[ 5.767313] pci 0001:01:00.0: BAR 2: assigned [io 0x100018-0x10001f]
[ 5.773460] pci 0001:01:00.0: BAR 1: assigned [io 0x100020-0x100023]
[ 5.780184] pci 0001:01:00.0: BAR 3: assigned [io 0x100024-0x100027]
[ 5.786650] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[ 5.791895] pci 0001:00:00.0: bridge window [io 0x100000-0x100fff]
[ 5.798329] pci 0001:00:00.0: bridge window [mem 0x1230000000-0x12300fffff]
[ 5.805494] pci 0001:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 5.814447] pci 0001:01:00.0: Max Payload Size set to 256/ 512 (was 128), Max Read Rq 512
[ 5.823935] pcieport 0001:00:00.0: Adding to iommu group 9
[ 5.828829] pcieport 0001:00:00.0: PME: Signaling with IRQ 26
[ 5.834780] pcieport 0001:00:00.0: AER: enabled with IRQ 26
[ 5.841501] tegra194-pcie 14140000.pcie: Adding to iommu group 10
[ 5.848790] tegra194-pcie 14140000.pcie: host bridge /pcie@14140000 ranges:
[ 5.852906] tegra194-pcie 14140000.pcie: IO 0x0034100000..0x00341fffff -> 0x0034100000
[ 5.861545] tegra194-pcie 14140000.pcie: MEM 0x1280000000..0x12afffffff -> 0x1280000000
[ 5.869868] tegra194-pcie 14140000.pcie: MEM 0x12b0000000..0x12bfffffff -> 0x0040000000
[ 6.984871] tegra194-pcie 14140000.pcie: Phy link never came up
[ 6.985344] tegra194-pcie 14140000.pcie: PCI host bridge to bus 0003:00
[ 6.985550] pci_bus 0003:00: root bus resource [bus 00-ff]
[ 6.985714] pci_bus 0003:00: root bus resource [io 0x200000-0x2fffff] (bus address [0x34100000-0x341fffff])
[ 6.986050] pci_bus 0003:00: root bus resource [mem 0x1280000000-0x12afffffff pref]
[ 6.986346] pci_bus 0003:00: root bus resource [mem 0x12b0000000-0x12bfffffff] (bus address [0x40000000-0x4fffffff])
[ 6.986734] pci 0003:00:00.0: [10de:1ad2] type 01 class 0x060400
[ 6.987218] pci 0003:00:00.0: PME# supported from D0 D3hot D3cold
[ 7.011358] pci 0003:00:00.0: PCI bridge to [bus 01-ff]
[ 7.011678] pci 0003:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 7.013194] pcieport 0003:00:00.0: Adding to iommu group 10
[ 7.014232] pcieport 0003:00:00.0: PME: Signaling with IRQ 28
[ 7.015418] pcieport 0003:00:00.0: AER: enabled with IRQ 28
[ 7.016812] pci_bus 0003:01: busn_res: [bus 01-ff] is released
[ 7.017655] pci 0003:00:00.0: Removing from iommu group 10
[ 7.017926] pci_bus 0003:00: busn_res: [bus 00-ff] is released
[ 7.020527] tegra194-pcie 141a0000.pcie: Adding to iommu group 11
[ 7.021991] tegra194-pcie 141a0000.pcie: Failed to get slot regulators: -517
[ 7.045004] host1x 13e10000.host1x: Adding to iommu group 12
[ 7.064506] host1x 13e10000.host1x: initialized
[ 7.065695] iommu_context_dev 13e10000.host1x:ctx0: Adding to iommu group 13
[ 7.066440] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56, iommu=smmu.0x0000000012000000)
[ 7.067067] iommu_context_dev 13e10000.host1x:ctx1: Adding to iommu group 14
[ 7.067762] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57, iommu=smmu.0x0000000012000000)
[ 7.068452] iommu_context_dev 13e10000.host1x:ctx2: Adding to iommu group 15
[ 7.069145] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58, iommu=smmu.0x0000000012000000)
[ 7.069700] iommu_context_dev 13e10000.host1x:ctx3: Adding to iommu group 16
[ 7.074650] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59, iommu=smmu.0x0000000012000000)
[ 7.084001] iommu_context_dev 13e10000.host1x:ctx4: Adding to iommu group 17
[ 7.091410] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60, iommu=smmu.0x0000000012000000)
[ 7.100944] iommu_context_dev 13e10000.host1x:ctx5: Adding to iommu group 18
[ 7.108451] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61, iommu=smmu.0x0000000012000000)
[ 7.118157] iommu_context_dev 13e10000.host1x:ctx6: Adding to iommu group 19
[ 7.125174] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62, iommu=smmu.0x0000000012000000)
[ 7.135168] iommu_context_dev 13e10000.host1x:ctx7: Adding to iommu group 20
[ 7.142457] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63, iommu=smmu.0x0000000012000000)
[ 7.152225] falcon 15340000.vic: Adding to iommu group 21
[ 7.164023] falcon 15340000.vic: initialized
[ 7.164850] falcon 15380000.nvjpg: Adding to iommu group 21
[ 7.171542] falcon 15380000.nvjpg: initialized
[ 7.172368] falcon 154c0000.nvenc: Adding to iommu group 21
[ 7.183088] falcon 154c0000.nvenc: initialized
[ 7.183588] falcon 15a80000.nvenc1: Adding to iommu group 21
[ 7.194090] falcon 15a80000.nvenc1: initialized
[ 7.194568] nvdec 15480000.nvdec: Adding to iommu group 21
[ 7.206315] nvdec 15480000.nvdec: initialized
[ 7.206862] nvdec 15140000.nvdec1: Adding to iommu group 21
[ 7.215211] nvdec 15140000.nvdec1: initialized
[ 7.215690] tsec 15500000.tsec: Adding to iommu group 22
[ 7.222270] tsec 15500000.tsec: initialized
[ 7.222768] tsec 15100000.tsecb: Adding to iommu group 23
[ 7.231545] tsec 15100000.tsecb: initialized
[ 7.234865] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 7.261236] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 7.268413] tegra-xusb-padctl 3520000.xusb_padctl: failed to setup XUSB ports: -517
[ 7.272706] gpio-374 (wifi-enable): hogged as output/high
[ 7.272941] gpio-382 (camera-control-output-low): hogged as output/low
[ 7.273262] gpio-385 (camera-control-output-low): hogged as output/low
[ 7.273544] gpio-463 (camera-control-output-low): hogged as output/low
[ 7.273867] gpio-462 (camera-control-output-low): hogged as output/low
[ 7.276732] gpio-485 (camera-control-output-low): hogged as output/low
[ 7.284226] gpiochip1: registered GPIOs 335 to 503 on tegra194-gpio
[ 7.291190] gpiochip2: registered GPIOs 305 to 334 on tegra194-gpio-aon
[ 7.296481] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 7.302394] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 7.308927] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 7.313810] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 7.321187] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 7.327171] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=4687500, vi_iso_bw=6262500, max_bw=6262500
[ 7.337931] tegra194-isp5 13e10000.host1x:isp@14800000: Adding to iommu group 24
[ 7.348356] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: context isolation disabled due to no IOMMU
[ 7.354575] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: initialized
[ 7.361123] tegra194-vi5 15c10000.vi: Adding to iommu group 25
[ 7.367947] scare-pigeon 13e10000.host1x:vi-thi@15f00000: context isolation disabled due to no IOMMU
[ 7.375663] scare-pigeon 13e10000.host1x:vi-thi@15f00000: initialized
[ 7.382044] scare-pigeon 13e10000.host1x:isp-thi@14b00000: context isolation disabled due to no IOMMU
[ 7.391159] scare-pigeon 13e10000.host1x:isp-thi@14b00000: initialized
[ 7.397473] pva 16000000.pva0: Adding to iommu group 26
[ 7.424565] pva 16000000.pva0: initialized
[ 7.427745] pva 16800000.pva1: Adding to iommu group 27
[ 7.438233] pva 16800000.pva1: initialized
[ 7.441232] nvdla 15880000.nvdla0: Adding to iommu group 28
[ 7.452698] nvdla 15880000.nvdla0: initialized
[ 7.453651] nvdla 158c0000.nvdla1: Adding to iommu group 29
[ 7.461594] nvdla 158c0000.nvdla1: initialized
[ 7.465998] tegra-slvs-ec 15ac0000.slvs-ec: context isolation disabled due to no IOMMU
[ 7.466581] tegra-slvs-ec 15ac0000.slvs-ec: initialized
[ 7.466949] tegra-slvs-ec 15ac0000.slvs-ec: No streams defined - setting to zero
[ 7.467282] tegra-slvs-ec 15ac0000.slvs-ec: slvs has 0 available streams
[ 7.467518] tegra-slvs-ec 15ac0000.slvs-ec: probed
[ 7.471084] tegradccommon 15200000.display-hub: host1x channel mapped
[ 7.472403] tegradc 15200000.display: Adding to iommu group 30
[ 7.472475] tegra_cec 3960000.tegra_cec: dt=1 start=0x03960000 end=0x03960FFF irq=72
[ 7.472490] tegra_cec 3960000.tegra_cec: Unpowergated DISP
[ 7.472909] tegra_cec 3960000.tegra_cec: Enable clock result: 0.
[ 7.473260] tegra_cec 3960000.tegra_cec: tegra_cec_init started
[ 7.473616] tegradc 15210000.display: Adding to iommu group 30
[ 7.475501] tegradccommon 15200000.display-hub: dc_common syncpt # 1 allocated
[ 7.475850] tegra_cec 3960000.tegra_cec: cec_add_sysfs ret=0
[ 7.475857] tegra_cec 3960000.tegra_cec: probed
[ 7.476366] tegra-gpcdma 2600000.dma: Adding to iommu group 3
[ 7.478037] tegra-gpcdma 2600000.dma: GPC DMA driver register 31 channels
[ 7.478333] kfuse 3830000.kfuse: initialized
[ 7.478741] tegra-fuse-burn efuse-burn: shutdown limit check disabled
[ 7.479462] tegra-fuse-burn efuse-burn: Fuse burn driver initialized
[ 7.479936] serial-tegra 3100000.serial: Adding to iommu group 3
[ 7.480382] tegradc 15220000.display: Adding to iommu group 30
[ 7.480800] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 35, base_baud = 0) is a TEGRA_UART
[ 7.481897] serial-tegra 3110000.serial: Adding to iommu group 3
[ 7.488987] tegradccommon 15200000.display-hub: dma mapping done
[ 7.494987] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 36, base_baud = 0) is a TEGRA_UART
[ 7.601814] serial-tegra 3140000.serial: Adding to iommu group 3
[ 7.607601] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 37, base_baud = 0) is a TEGRA_UART
[ 7.617636] ufs_tegra 2450000.ufshci: freq-table-hz property not specified
[ 7.622850] ufs_tegra 2450000.ufshci: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
[ 7.633224] ufs_tegra 2450000.ufshci: ufshcd_get_vreg: vcc get failed, err=-517
[ 7.667756] tegra-i2c 31e0000.i2c: Adding to iommu group 3
[ 7.680581] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 2264000 KHz, changing to: 2265600 KHz
[ 7.681548] tegra194-cpufreq ccplex: probed with BWMGR, cl:4
[ 7.683077] sdhci-tegra 3460000.sdhci: BWMGR client registration for eMC Successful
[ 7.684120] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 7.684208] tegra194-pcie 141a0000.pcie: Failed to get slot regulators: -517
[ 7.684358] sdhci-tegra 3400000.sdhci: BWMGR client registration for eMC Successful
[ 7.684621] reg-fixed-voltage fixed-regulators:regulator@106: nonexclusive access to GPIO for fixed-regulators:regulator@106
[ 7.692166] irq: IRQ276: trimming hierarchy from :interrupt-controller@3881000
[ 7.694658] mmc0: CQHCI version 5.10
[ 7.694731] vdd-5v-sata: supplied by vdd-ac-bat
[ 7.701310] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 276
[ 7.703029] tegra194-isp5 13e10000.host1x:isp@14800000: initialized
[ 7.708225] tegra194-vi5 15c10000.vi: initialized
[ 7.728850] tegradc 15210000.display: disp0 connected to head1->sor
[ 7.732417] ufs_tegra 2450000.ufshci: freq-table-hz property not specified
[ 7.733003] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit
[ 7.733139] tegradc 15210000.display: parse_dp_settings: No dp-lt-settings node
[ 7.733291] tegradc 15210000.display: DT parsed successfully
[ 7.733296] tegradc 15210000.display: dc.1 probe not in device tree order, deferring
[ 7.733463] tegradc 15220000.display: disp0 connected to head2->sor1
[ 7.733521] tegradc 15220000.display: parse_dp_settings: No dp-lt-settings node
[ 7.733598] tegradc 15220000.display: DT parsed successfully
[ 7.733602] tegradc 15220000.display: dc.2 probe not in device tree order, deferring
[ 7.740134] ufs_tegra 2450000.ufshci: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
[ 7.740321] tegradc 15200000.display: disp0 connected to head0->sor2
[ 7.740386] generic_infoframe_type: 0x87
[ 7.740441] tegradc 15200000.display: DT parsed successfully
[ 7.740476] tegradc 15200000.display: Display dc.000000004db68ab9 registered with id=0
[ 7.741836] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 15681600 KB/s
[ 7.741840] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 1066500000 Hz
[ 7.741843] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 358400000 Hz
[ 7.742157] tegradc 15200000.display: vblank syncpt # 8 for dc 0
[ 7.742163] tegradc 15200000.display: vpulse3 syncpt # 9 for dc 0
[ 7.743488] tegradc 15200000.display: hdmi: invalid prod list prod_list_hdmi_board
[ 7.743492] tegradc 15200000.display: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[ 7.746859] mmc1: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit
[ 7.779212] tegradc 15200000.display: probed
[ 7.788194] irq: IRQ277: trimming hierarchy from :pmc@c360000
[ 7.874659] mmc0: Command Queue Engine enabled
[ 7.875156] ufs_tegra 2450000.ufshci: wakeup init done, cdirq 277
[ 7.882751] mmc0: periodic cache flush enabled
[ 7.882762] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 7.900405] ufs_tegra 2450000.ufshci: ufs card not detected.
[ 7.901070] mmcblk0: mmc0:0001 HBG4a2 29.1 GiB
[ 7.932752] mmcblk0rpmb: mmc0:0001 HBG4a2 partition 3 4.00 MiB, chardev (509:0)
[ 7.932903] Console: switching to colour frame buffer device 320x90
[ 7.946032] tegradc 15200000.display: fb registered
[ 7.951120] irq: IRQ278: trimming hierarchy from :pmc@c360000
[ 7.958778] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 7.963054] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 7.964139] tegra-xusb 3610000.xhci: Firmware timestamp: 2024-04-10 14:55:13 UTC, Version: 60.14 release
[ 7.977875] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 7.980421] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 p26 p27 p28 p29 p30 p31 p32 p33 p34 p35 p36 p37 p38 p39 p40 p41 p42 p43 p44
[ 7.983406] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 8.008550] tegra-xusb 3610000.xhci: hcc params 0x0184ff25 hci version 0x110 quirks 0x0000000000050810
[ 8.017303] tegra-xusb 3610000.xhci: irq 202, io mem 0x03610000
[ 8.023173] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 8.028802] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 8.029913] tegradc 15200000.display: hdmi: tmds rate:241699K prod-setting:prod_c_hdmi_223m_300m
[ 8.036173] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 8.046825] tegradc 15200000.display: hdmi: get YCC quant from EDID.
[ 8.052618] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 8.062791] extcon-disp-state external-connection:disp-state: cable 48 state 1
[ 8.066948] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.074297] Extcon AUX2(HDMI) enable
[ 8.081907] usb usb1: Product: xHCI Host Controller
[ 8.081914] usb usb1: Manufacturer: Linux 5.10.216-tegra xhci-hcd
[ 8.096344] usb usb1: SerialNumber: 3610000.xhci
[ 8.101453] hub 1-0:1.0: USB hub found
[ 8.105304] hub 1-0:1.0: 4 ports detected
[ 8.110010] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 8.117780] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.124779] usb usb2: Product: xHCI Host Controller
[ 8.129592] usb usb2: Manufacturer: Linux 5.10.216-tegra xhci-hcd
[ 8.135837] usb usb2: SerialNumber: 3610000.xhci
[ 8.140861] hub 2-0:1.0: USB hub found
[ 8.144679] hub 2-0:1.0: 4 ports detected
[ 8.219386] tegradc 15200000.display: blank - powerdown
[ 8.260503] tegra194-pcie 141a0000.pcie: host bridge /pcie@141a0000 ranges:
[ 8.260542] tegra194-pcie 141a0000.pcie: IO 0x003a100000..0x003a1fffff -> 0x003a100000
[ 8.260561] tegra194-pcie 141a0000.pcie: MEM 0x1c00000000..0x1f3fffffff -> 0x1c00000000
[ 8.260570] tegra194-pcie 141a0000.pcie: MEM 0x1f40000000..0x1fffffffff -> 0x0040000000
[ 8.262018] extcon-disp-state external-connection:disp-state: cable 48 state 0
[ 8.262023] Extcon AUX2(HDMI) disable
[ 8.285255] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 8.286157] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 8.299731] tegradc 15200000.display: unblank
[ 8.300958] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 8.301140] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 8.306940] tegradc 15200000.display: hdmi: tmds rate:241500K prod-setting:prod_c_hdmi_223m_300m
[ 8.308700] tegradc 15200000.display: hdmi: get YCC quant from EDID.
[ 8.312590] extcon-disp-state external-connection:disp-state: cable 48 state 1
[ 8.312593] Extcon AUX2(HDMI) enable
[ 8.325459] tegradc 15200000.display: sync windows ret = 247
[ 8.343430] extcon-disp-state external-connection:disp-state: cable 53 state 1
[ 8.350372] Extcon HDMI: HPD enabled
[ 8.354044] tegradc 15200000.display: hdmi: plugged
[ 8.364110] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 8.480145] tegra_cec 3960000.tegra_cec: physical address: 10:00.
[ 8.515244] usb 1-2: New USB device found, idVendor=2109, idProduct=2817, bcdDevice= 3.84
[ 8.515467] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 8.515650] usb 1-2: Product: USB2.0 Hub
[ 8.515747] usb 1-2: Manufacturer: VIA Labs, Inc.
[ 8.517159] hub 1-2:1.0: USB hub found
[ 8.517599] hub 1-2:1.0: 5 ports detected
[ 8.544687] tegra_cec 3960000.tegra_cec: Sent <Text View On> res: -113.
[ 8.544864] tegra_cec 3960000.tegra_cec: tegra_cec_init Done.
[ 8.641493] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using tegra-xusb
[ 8.663212] usb 2-1: New USB device found, idVendor=2109, idProduct=0817, bcdDevice= 3.84
[ 8.663448] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 8.666654] usb 2-1: Product: USB3.0 Hub
[ 8.669017] usb 2-1: Manufacturer: VIA Labs, Inc.
[ 8.674919] hub 2-1:1.0: USB hub found
[ 8.677660] hub 2-1:1.0: 4 ports detected
[ 9.256121] usb 1-2.2: new low-speed USB device number 3 using tegra-xusb
[ 9.368393] tegra194-pcie 141a0000.pcie: Phy link never came up
[ 9.370461] tegra194-pcie 141a0000.pcie: PCI host bridge to bus 0005:00
[ 9.372386] pci_bus 0005:00: root bus resource [bus 00-ff]
[ 9.374267] pci_bus 0005:00: root bus resource [io 0x300000-0x3fffff] (bus address [0x3a100000-0x3a1fffff])
[ 9.376200] pci_bus 0005:00: root bus resource [mem 0x1c00000000-0x1f3fffffff pref]
[ 9.377961] pci_bus 0005:00: root bus resource [mem 0x1f40000000-0x1fffffffff] (bus address [0x40000000-0xffffffff])
[ 9.379837] pci 0005:00:00.0: [10de:1ad0] type 01 class 0x060400
[ 9.381712] pci 0005:00:00.0: PME# supported from D0 D3hot D3cold
[ 9.395985] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[ 9.399367] pci 0005:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 9.403234] pcieport 0005:00:00.0: Adding to iommu group 11
[ 9.406969] pcieport 0005:00:00.0: PME: Signaling with IRQ 30
[ 9.410716] pcieport 0005:00:00.0: AER: enabled with IRQ 30
[ 9.413071] usb 1-2.2: New USB device found, idVendor=046d, idProduct=c404, bcdDevice= 2.20
[ 9.414591] pci_bus 0005:01: busn_res: [bus 01-ff] is released
[ 9.417623] usb 1-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 9.421278] pci 0005:00:00.0: Removing from iommu group 11
[ 9.425748] usb 1-2.2: Product: Trackball
[ 9.425756] usb 1-2.2: Manufacturer: Logitech
[ 9.427496] pci_bus 0005:00: busn_res: [bus 00-ff] is released
[ 9.434669] tegradc 15210000.display: disp1 connected to head1->sor
[ 9.435708] nvethernet 2490000.ethernet: Adding to iommu group 31
[ 9.436464] tegradc 15210000.display: parse_dp_settings: No dp-lt-settings node
[ 9.438522] nvethernet 2490000.ethernet: failed to read skip mac reset flag, default 0
[ 9.440205] tegradc 15210000.display: DT parsed successfully
[ 9.441775] nvethernet 2490000.ethernet: failed to read MDIO address
[ 9.443434] tegradc 15210000.display: Display dc.000000009ea5f7dd registered with id=1
[ 9.449773] nvethernet 2490000.ethernet: setting to default DMA bit mask
[ 9.457996] tegradc 15210000.display: vblank syncpt # 11 for dc 1
[ 9.458346] input: Logitech Trackball as /devices/platform/3610000.xhci/usb1/1-2/1-2.2/1-2.2:1.0/0003:046D:C404.0001/input/input0
[ 9.458577] hid-generic 0003:046D:C404.0001: input,hidraw0: USB HID v1.10 Mouse [Logitech Trackball] on usb-3610000.xhci-2.2/input0
[ 9.464459] nvethernet 2490000.ethernet: set default TXQ to TC mapping
[ 9.464467] nvethernet 2490000.ethernet: Setting default PTP RX queue
[ 9.470806] tegradc 15210000.display: vpulse3 syncpt # 12 for dc 1
[ 9.482113] nvethernet 2490000.ethernet: Failed to read DMA Tx ring size, using default [1024]
[ 9.482119] nvethernet 2490000.ethernet: Failed to read DMA Rx ring size, using default [1024]
[ 9.482145] nvethernet 2490000.ethernet: missing nvidia,pad_auto_cal_pu_offset, setting default 0
[ 9.500875] tegradc 15210000.display: probed
[ 9.507212] nvethernet 2490000.ethernet: missing nvidia,pad_auto_cal_pd_offset, setting default 0
[ 9.512152] nvethernet 2490000.ethernet: failed to get eqos_rx_m clk
[ 9.558945] tegradc 15210000.display: fb registered
[ 9.558973] nvethernet 2490000.ethernet: failed to get eqos_rx_input clk
[ 9.566920] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 9.570568] nvethernet 2490000.ethernet: failed to get eqos_tx_divider clk
[ 9.570700] tegradc 15220000.display: disp2 connected to head2->sor1
[ 9.577865] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 9.584652] tegradc 15220000.display: parse_dp_settings: No dp-lt-settings node
[ 9.591408] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 9.599339] tegradc 15220000.display: DT parsed successfully
[ 9.607064] nvethernet 2490000.ethernet: Ethernet MAC address: 48:b0:2d:05:ac:ab
[ 9.611976] tegradc 15220000.display: Display dc.0000000032c36359 registered with id=2
[ 9.618178] -->macsec_probe()
[ 9.625169] usb 1-2.3: new low-speed USB device number 4 using tegra-xusb
[ 9.633260] <--macsec_probe()
[ 9.633405] tegradc 15220000.display: vblank syncpt # 13 for dc 2
[ 9.633430] tegradc 15220000.display: vpulse3 syncpt # 14 for dc 2
[ 9.652334] tegradc 15210000.display: blank - powerdown
[ 9.654362] nvethernet 2490000.ethernet: Macsec not supported/Not enabled in DT
[ 9.657201] extcon-disp-state external-connection:disp-state: cable 44 state 0 already set.
[ 9.672801] Extcon DP: HPD disabled
[ 9.676716] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 9.683308] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 9.689522] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 9.696672] nvethernet 2490000.ethernet: eth0 (HW ver: 50) created with 1 DMA channels
[ 9.697955] tegradc 15220000.display: probed
[ 9.705633] irq: IRQ280: trimming hierarchy from :pmc@c360000
[ 9.714424] tegradc 15220000.display: fb registered
[ 9.714568] irq: IRQ281: trimming hierarchy from :interrupt-controller@3881000
[ 9.722659] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 9.726765] input: gpio-keys as /devices/platform/gpio-keys/input/input1
[ 9.733789] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 9.741878] tegra-se-nvhost 15810000.se: Adding to iommu group 32
[ 9.748298] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 9.755841] tegra-se-nvhost 15810000.se: initialized
[ 9.764928] tegradc 15220000.display: blank - powerdown
[ 9.766188] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 9.770143] extcon-disp-state external-connection:disp-state: cable 44 state 0 already set.
[ 9.770146] Extcon DP: HPD disabled
[ 9.770168] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 9.770177] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 9.776590] tegra-se-nvhost 15820000.se: Adding to iommu group 33
[ 9.784230] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 9.788464] tegra-se-nvhost 15820000.se: initialized
[ 9.820508] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 9.825531] tegra-se-nvhost 15830000.se: Adding to iommu group 34
[ 9.832025] tegra-se-nvhost 15830000.se: initialized
[ 9.837277] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 9.841906] usb 1-2.3: New USB device found, idVendor=03f0, idProduct=0d4a, bcdDevice= 2.07
[ 9.842715] tegra-se-nvhost 15840000.se: Adding to iommu group 35
[ 9.850907] usb 1-2.3: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 9.857426] tegra-se-nvhost 15840000.se: initialized
[ 9.863938] usb 1-2.3: Product: HP USB Keyboard
[ 9.869576] input: HP USB Keyboard as /devices/platform/3610000.xhci/usb1/1-2/1-2.3/1-2.3:1.0/0003:03F0:0D4A.0002/input/input2
[ 9.874990] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 9.892567] tegra_actmon d230000.actmon: in actmon_register()...
[ 9.897177] tegra_actmon d230000.actmon: bwmgr_disable = 0
[ 9.902777] tegra_actmon d230000.actmon: initialization Completed for the device mc_all
[ 9.910806] hvc_sysfs: hypervisor is not present
[ 9.915000] clk: Disabling unused clocks
[ 9.940265] ALSA device list:
[ 9.941901] No soundcards found.
[ 9.944406] Freeing unused kernel memory: 3968K
[ 9.944454] hid-generic 0003:03F0:0D4A.0002: input,hidraw1: USB HID v1.10 Keyboard [HP USB Keyboard] on usb-3610000.xhci-2.3/input0
[ 9.946254] Run /init as init process
[ 9.949738] with arguments:
[ 9.949761] /init
[ 9.949766] nv-auto-config
[ 9.949770] with environment:
[ 9.949773] HOME=/
[ 9.949777] TERM=linux
[ 9.949781] mminit_loglevel=4
[ 9.952429] input: HP USB Keyboard System Control as /devices/platform/3610000.xhci/usb1/1-2/1-2.3/1-2.3:1.1/0003:03F0:0D4A.0003/input/input3
[ 10.003843] Root device found: mmcblk0p1
[ 10.016401] input: HP USB Keyboard Consumer Control as /devices/platform/3610000.xhci/usb1/1-2/1-2.3/1-2.3:1.1/0003:03F0:0D4A.0003/input/input4
[ 10.018602] hid-generic 0003:03F0:0D4A.0003: input,hidraw2: USB HID v1.10 Device [HP USB Keyboard] on usb-3610000.xhci-2.3/input1
[ 10.029044] Found dev node: /dev/mmcblk0p1
[ 10.067385] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 10.076126] Rootfs mounted over mmcblk0p1
[ 10.103556] Switching from initrd to actual rootfs
[ 10.104176] usb 1-2.5: new high-speed USB device number 5 using tegra-xusb
[ 10.205772] usb 1-2.5: New USB device found, idVendor=2109, idProduct=8888, bcdDevice= 0.01
[ 10.207718] usb 1-2.5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 10.209594] usb 1-2.5: Product: USB Billboard Device
[ 10.211375] usb 1-2.5: Manufacturer: VIA Labs, Inc.
[ 10.213171] usb 1-2.5: SerialNumber: 0000000000000001
[ 10.246881] systemd[1]: System time before build time, advancing clock.
[ 10.306481] systemd[1]: systemd 245.4-4ubuntu3.24 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[ 10.310518] systemd[1]: Detected architecture arm64.
[ 10.330850] systemd[1]: Set hostname to <ubuntu>.
[ 10.643379] systemd[1]: /lib/systemd/system/snapd.service:23: Unknown key name 'RestartMode' in section 'Service', ignoring.
[ 10.799968] systemd[1]: system-modprobe.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[ 10.802209] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[ 10.808477] systemd[1]: Created slice system-modprobe.slice.
[ 10.814434] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 10.819867] systemd[1]: Created slice User and Session Slice.
[ 10.824330] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 10.829086] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 10.833198] systemd[1]: Reached target User and Group Name Lookups.
[ 10.837170] systemd[1]: Reached target Slices.
[ 10.841025] systemd[1]: Reached target Mounting snaps.
[ 10.844852] systemd[1]: Reached target Mounted snaps.
[ 10.848623] systemd[1]: Reached target Swap.
[ 10.854642] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 10.858917] systemd[1]: Listening on Syslog Socket.
[ 10.863065] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 10.867107] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 10.871889] systemd[1]: Listening on Journal Audit Socket.
[ 10.876055] systemd[1]: Listening on Journal Socket (/dev/log).
[ 10.880404] systemd[1]: Listening on Journal Socket.
[ 10.884671] systemd[1]: Listening on udev Control Socket.
[ 10.888756] systemd[1]: Listening on udev Kernel Socket.
[ 10.897533] systemd[1]: Mounting Huge Pages File System...
[ 10.906168] systemd[1]: Mounting POSIX Message Queue File System...
[ 10.914322] systemd[1]: Mounting RPC Pipe File System...
[ 10.923355] systemd[1]: Mounting Kernel Debug File System...
[ 10.932410] systemd[1]: Mounting Kernel Trace File System...
[ 10.942293] systemd[1]: Starting Journal Service...
[ 10.951473] systemd[1]: Starting Set the console keyboard layout...
[ 10.960079] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ 10.968498] systemd[1]: Starting Load Kernel Module chromeos_pstore...
[ 10.973277] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[ 10.979370] systemd[1]: Starting Load Kernel Module efi_pstore...
[ 10.988311] systemd[1]: Starting Load Kernel Module pstore_blk...
[ 10.996585] systemd[1]: Starting Load Kernel Module pstore_zone...
[ 11.004513] systemd[1]: Starting Load Kernel Module ramoops...
[ 11.012561] systemd[1]: Starting NVIDIA specific first-boot udev script...
[ 11.020785] systemd[1]: Started Nameserver information manager.
[ 11.025310] systemd[1]: Reached target Network (Pre).
[ 11.031635] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 11.033870] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 11.041579] systemd[1]: Starting Load Kernel Modules...
[ 11.049696] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 11.057873] systemd[1]: Starting udev Coldplug all Devices...
[ 11.068333] systemd[1]: Mounted Huge Pages File System.
[ 11.071649] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 11.076236] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 11.076642] systemd[1]: Mounted POSIX Message Queue File System.
[ 11.078784] tegra-carveouts tegra-carveouts: vpr :dma coherent mem declare 0x00000000ce000000,704643072
[ 11.081531] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 11.081543] nvmap_page_pool_init: Total RAM pages: 7933610
[ 11.081546] nvmap_page_pool_init: nvmap page pool size: 991701 pages (3873 MB)
[ 11.081746] nvmap_background_zero_thread: PP zeroing thread starting.
[ 11.081978] misc nvmap: created heap vpr base 0x00000000ce000000 size (688128KiB)
[ 11.082116] misc nvmap: cvsram :dma coherent mem declare 0x0000000050000000,4194304
[ 11.082122] misc nvmap: created heap cvsram base 0x0000000050000000 size (4096KiB)
[ 11.097012] systemd[1]: Mounted RPC Pipe File System.
[ 11.101034] systemd[1]: Mounted Kernel Debug File System.
[ 11.105137] systemd[1]: Mounted Kernel Trace File System.
[ 11.112021] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 11.117069] systemd[1]: modprobe@chromeos_pstore.service: Succeeded.
[ 11.120613] systemd[1]: Finished Load Kernel Module chromeos_pstore.
[ 11.125409] systemd[1]: modprobe@efi_pstore.service: Succeeded.
[ 11.129658] systemd[1]: Finished Load Kernel Module efi_pstore.
[ 11.137777] systemd[1]: modprobe@pstore_blk.service: Succeeded.
[ 11.143185] systemd[1]: Finished Load Kernel Module pstore_blk.
[ 11.153546] systemd[1]: Finished Set the console keyboard layout.
[ 11.159178] systemd[1]: modprobe@pstore_zone.service: Succeeded.
[ 11.163081] systemd[1]: Finished Load Kernel Module pstore_zone.
[ 11.168191] systemd[1]: modprobe@ramoops.service: Succeeded.
[ 11.171808] systemd[1]: Finished Load Kernel Module ramoops.
[ 11.173638] nvgpu: 17000000.gv11b nvgpu_nvhost_syncpt_init:135 [INFO] syncpt_unit_base 60000000 syncpt_unit_size 400000 size 1000
[ 11.180400] systemd[1]: nvfb-udev.service: Succeeded.
[ 11.185124] systemd[1]: Finished NVIDIA specific first-boot udev script.
[ 11.195788] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 11.210536] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[ 11.213370] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[ 11.219650] systemd[1]: Starting Load/Save Random Seed...
[ 11.229268] systemd[1]: Starting Create System Users...
[ 11.240349] systemd[1]: Finished Load Kernel Modules.
[ 11.249977] systemd[1]: Finished Load/Save Random Seed.
[ 11.255636] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[ 11.262051] systemd[1]: Mounting Kernel Configuration File System...
[ 11.270812] systemd[1]: Started OP-TEE Client Supplicant.
[ 11.279087] systemd[1]: Starting Apply Kernel Variables...
[ 11.286327] systemd[1]: Mounted Kernel Configuration File System.
[ 11.299289] systemd[1]: Finished Create System Users.
[ 11.307524] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 11.315973] systemd[1]: Finished Apply Kernel Variables.
[ 11.337615] systemd[1]: Started Journal Service.
[ 11.359933] systemd-journald[300]: Received client request to flush runtime journal.
[ 12.271870] spi-tegra114 3210000.spi: Adding to iommu group 3
[ 12.276610] spi-tegra114 c260000.spi: Adding to iommu group 3
[ 12.350776] libata version 3.00 loaded.
[ 12.360962] ahci 0001:01:00.0: Adding to iommu group 9
[ 12.363474] ahci 0001:01:00.0: version 3.0
[ 12.365642] ahci 0001:01:00.0: AHCI 0001.0000 32 slots 1 ports 6 Gbps 0x1 impl SATA mode
[ 12.365660] ahci 0001:01:00.0: flags: 64bit ncq sntf led only pmp fbs pio slum part sxs
[ 12.375583] tegra-hda 3510000.hda: Adding to iommu group 36
[ 12.376221] tegra-hda 3510000.hda: Override SDO lines to 4
[ 12.380516] scsi host1: ahci
[ 12.381301] ata1: SATA max UDMA/133 abar m512@0x1230010000 port 0x1230010100 irq 282
[ 12.405388] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 16 channels
[ 12.437185] irq: IRQ283: trimming hierarchy from :pmc@c360000
[ 12.448498] cpu-throttle-alert cooling device registered.
[ 12.449395] gpu-throttle-alert cooling device registered.
[ 12.450166] aux-throttle-alert cooling device registered.
[ 12.450617] hot-surface-alert cooling device registered.
[ 12.516672] nvadsp 2993000.adsp: Adding to iommu group 37
[ 12.516921] nvadsp 2993000.adsp: in probe()...
[ 12.526415] nvadsp 2993000.adsp: nvadsp_app_module_probe
[ 12.552288] using random self ethernet address
[ 12.553703] using random host ethernet address
[ 12.631543] irq: IRQ284: trimming hierarchy from :pmc@c360000
[ 12.631566] nct1008_nct72 4-004c: starting parse dt
[ 12.631634] nct1008_nct72 4-004c: !!!Found deprecated property!!!
[ 12.631640] nct1008_nct72 4-004c: success parsing dt
[ 12.631863] nct1008_nct72 4-004c: success in enabling tmp451 VDD rail
[ 12.665595] loop: module loaded
[ 12.667515] nct1008_nct72 4-004c: LOC shutdown limit 107
[ 12.668420] nct1008_nct72 4-004c: EXT shutdown limit 109
[ 12.700030] ata1: SATA link down (SStatus 0 SControl 300)
[ 12.704736] nct1008_nct72 4-004c: initial LOC temp: 26000
[ 12.705332] nct1008_nct72 4-004c: initial EXT temp: 40750
[ 12.706604] nct1008_nct72 4-004c: hi_b:-10, lo_b:128
[ 12.707647] nct1008_nct72 4-004c: nct1008_probe: initialized
[ 12.731658] input: NVIDIA Jetson AGX Xavier HDA HDMI/DP,pcm=3 as /devices/platform/3510000.hda/sound/card0/input5
[ 12.731848] input: NVIDIA Jetson AGX Xavier HDA HDMI/DP,pcm=7 as /devices/platform/3510000.hda/sound/card0/input6
[ 12.732010] input: NVIDIA Jetson AGX Xavier HDA HDMI/DP,pcm=8 as /devices/platform/3510000.hda/sound/card0/input7
[ 12.732256] input: NVIDIA Jetson AGX Xavier HDA HDMI/DP,pcm=9 as /devices/platform/3510000.hda/sound/card0/input8
[ 12.748657] irq: IRQ286: trimming hierarchy from :pmc@c360000
[ 12.777354] irq: IRQ287: trimming hierarchy from :pmc@c360000
[ 12.933587] tegra210-adsp aconnect@2a41000:adsp_audio: Adding to iommu group 37
[ 12.933629] tegra210_adsp_audio_probe: platform probe started
[ 12.934711] tegra210-adsp tegra210-adsp: Default param-type to BYTE for mp3-dec1
[ 12.992305] tegra210-adsp tegra210-adsp: Default param-type to BYTE for spkprot
[ 12.993239] tegra210-adsp tegra210-adsp: Default param-type to BYTE for src
[ 12.994126] tegra210-adsp tegra210-adsp: Default param-type to BYTE for aac-dec1
[ 12.994963] tegra210-adsp tegra210-adsp: Default param-type to BYTE for aec
[ 12.995792] tegra210-adsp tegra210-adsp: Default param-type to BYTE for wire
[ 12.995805] tegra210-adsp tegra210-adsp: adma channel page address dt entry not found
[ 12.995810] tegra210-adsp tegra210-adsp: using adma channel page 0
[ 12.995958] nvadsp 2993000.adsp: ADSP OS firmware already loaded
[ 13.291420] Mass Storage Function, version: 2009/09/11
[ 13.291434] LUN: removable file: (no medium)
[ 13.299188] using random self ethernet address
[ 13.301459] using random host ethernet address
[ 13.342341] irq: IRQ288: trimming hierarchy from :interrupt-controller@3881000
[ 13.343316] hwmon hwmon8: temp1_input not attached to any thermal zone
[ 13.470676] rndis0: HOST MAC 32:ce:42:39:38:1c
[ 13.470685] rndis0: MAC 32:ce:42:39:38:1d
[ 13.473108] usb0: HOST MAC 32:ce:42:39:38:1e
[ 13.473116] usb0: MAC 32:ce:42:39:38:1f
[ 13.473961] tegra-xudc 3550000.xudc: EP 0 (type: ctrl, dir: out) enabled
[ 13.482760] l4tbr0: port 1(rndis0) entered blocking state
[ 13.486062] l4tbr0: port 1(rndis0) entered disabled state
[ 13.486271] device rndis0 entered promiscuous mode
[ 13.503709] l4tbr0: port 2(usb0) entered blocking state
[ 13.503736] l4tbr0: port 2(usb0) entered disabled state
[ 13.504301] device usb0 entered promiscuous mode
[ 13.520438] tegra210-adsp tegra210-adsp: Loaded app wire
[ 13.520449] tegra210-adsp tegra210-adsp: Loaded app apm
[ 13.520454] tegra210-adsp tegra210-adsp: Loaded app adma
[ 13.520458] tegra210-adsp tegra210-adsp: Loaded app adma_tx
[ 13.520466] nvadsp_set_adma_dump_reg: callback for adma reg dump is sent to 00000000b9acf46b
[ 13.538646] tegra210-adsp tegra210-adsp: Tegra210 ADSP driver successfully registered
[ 13.709793] tegra-asoc: sound: Adding to iommu group 37
[ 13.854626] pstore: Using crash dump compression: deflate
[ 13.854727] printk: console [ramoops-1] enabled
[ 13.854732] pstore: Registered ramoops as persistent store backend
[ 13.854739] ramoops: using 0x200000@0xc8200000, ecc: 0
[ 13.933617] IRQ282: set affinity failed(-22).
[ 13.934907] CPU4: shutdown
[ 13.936281] psci: CPU4 killed (polled 0 ms)
[ 13.989382] IRQ282: set affinity failed(-22).
[ 13.989648] CPU5: shutdown
[ 13.990948] psci: CPU5 killed (polled 0 ms)
[ 14.037236] IRQ282: set affinity failed(-22).
[ 14.037452] CPU6: shutdown
[ 14.038786] psci: CPU6 killed (polled 0 ms)
[ 14.085240] IRQ282: set affinity failed(-22).
[ 14.085791] CPU7: shutdown
[ 14.087102] psci: CPU7 killed (polled 0 ms)
[ 14.089386] nvgpu: 17000000.gv11b tpc_pg_mask_store:1070 [INFO] no value change, same mask already set
[ 14.152193] cryptd: max_cpu_qlen set to 1000
[ 14.177791] nvgpu: 17000000.gv11b gk20a_scale_init:541 [INFO] enabled scaling for GPU
[ 17.353687] input: NVIDIA Jetson AGX Xavier APE Headset Jack as /devices/platform/sound/sound/card1/input9
[ 23.035083] zram: Added device: zram0
[ 23.038327] zram: Added device: zram1
[ 23.038674] zram: Added device: zram2
[ 23.038993] zram: Added device: zram3
[ 23.142395] zram0: detected capacity change from 0 to 4062011392
[ 23.200543] Adding 3966804k swap on /dev/zram0. Priority:5 extents:1 across:3966804k SS
[ 23.208683] zram1: detected capacity change from 0 to 4062011392
[ 23.252257] Adding 3966804k swap on /dev/zram1. Priority:5 extents:1 across:3966804k SS
[ 23.255976] zram2: detected capacity change from 0 to 4062011392
[ 23.296495] Adding 3966804k swap on /dev/zram2. Priority:5 extents:1 across:3966804k SS
[ 23.300317] zram3: detected capacity change from 0 to 4062011392
[ 23.344339] Adding 3966804k swap on /dev/zram3. Priority:5 extents:1 across:3966804k SS
[ 24.047706] Bridge firewalling registered
[ 24.767363] tegradc 15200000.display: unblank
[ 24.767399] tegradc 15210000.display: blank - powerdown
[ 24.767411] tegradc 15220000.display: blank - powerdown
[ 24.902759] nvidia: loading out-of-tree module taints kernel.
[ 24.916617] NVRM: No NVIDIA GPU found.
[ 41.751121] tegradc 15200000.display: blank - powerdown
[ 41.803178] extcon-disp-state external-connection:disp-state: cable 48 state 0
[ 41.803184] Extcon AUX2(HDMI) disable
[ 41.827308] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 41.828344] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 41.828448] tegradc 15210000.display: blank - powerdown
[ 41.828462] tegradc 15220000.display: blank - powerdown
[ 41.952281] vdd-3v3-cvb: disabling
[ 41.952294] vdd-epb-1v0: disabling
[ 41.952300] vdd-sata-1v5: disabling
[ 41.952304] vdd-1v8-slt: disabling
[ 41.952308] vdd-3v3-slt: disabling
[ 42.034908] tegradc 15200000.display: blank - powerdown
[ 42.034938] tegradc 15200000.display: unblank
[ 42.038017] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 42.038237] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 42.044484] tegradc 15200000.display: hdmi: tmds rate:241500K prod-setting:prod_c_hdmi_223m_300m
[ 42.046152] tegradc 15200000.display: hdmi: get YCC quant from EDID.
[ 42.050420] extcon-disp-state external-connection:disp-state: cable 48 state 1
[ 42.050425] Extcon AUX2(HDMI) enable
[ 42.050468] tegradc 15200000.display: unblank
[ 42.050497] tegradc 15210000.display: blank - powerdown
[ 42.050509] tegradc 15220000.display: blank - powerdown
[ 42.162365] NVRM: No NVIDIA GPU found.
[ 44.791710] fuse: init (API version 7.32)
$ sudo ./spidev_test -D /dev/spidev0.0 -v -p “HelloWorld123456789abcdef”
spi mode: 0x0
bits per word: 8
max speed: 500000 Hz (500 kHz)
TX | 48 65 6C 6C 6F 57 6F 72 6C 64 31 32 33 34 35 36 37 38 39 61 62 63 64 65 66 __ __ __ __ __ __ __ |HelloWorld123456789abcdef|
RX | 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 __ __ __ __ __ __ __ |…|
$ sudo ./spidev_test -D /dev/spidev0.1 -v -p “HelloWorld123456789abcdef”
spi mode: 0x0
bits per word: 8
