Disabling PTP causes WiFi to shutdown
We are using PTP to synchronize the clocks between multiple devices. We observed that PTP causes the Linux clock to drift by 3 minutes per hour. I understand this is a configuration issue in PTP. But to avoid this we disabled PTP and set Linux time from the remote device. One thing we observed is whenever PTP is disabled, WiFi is not working after reboot. I am not sure of the reason. Please help on how to resolve this.
Could you share
  1. Which jetpack release are you using?
  2. Which wifi module are you using?
  3. Any log from uart console to share?
  4. The steps to hit this issue.
Hi, Please find the answers,
  1. JetPack 4.4 Production Release, R32.4.3
  2. Ampak 4356a2
  3. No error logs are there
  4. Steps are simple.
    1. booting the system
    2. Load ptp-gen kernel module
    3. Checked ptp4l and phc2sys are not running.
    4. Enabling wifi interface
    5. running hostapd and dnsmasq
Could you give detailed command here?
Did this ptp-gen come from default BSP or you built this one?
Hi, ptp-gen we compiled from open source pps-gen-gpio/pps_gen_gpio.c at master · jsln/pps-gen-gpio · GitHub
We are starting WiFi using below commands
killall dhclient
killall udhcpc
ip link add name br0 type bridge
ip link set br0 up
ip link set eth0 master br0
ip link set wlan1 master br0
udhcpc -n -i br0 -F $host_name
killall dnsmasq
dnsmasq -C dnsmasq_br0.conf -z
We are starting PTP using below commands
killall ptp4l
killall phc2sys
ptp4l -A -H -i eth0 -2 -m >> ptp4l.log &
phc2sys -w -s eth0 -O 0 -m >> phc.log &
One more thing to add here is we are bridging both eth0 and wlan1 using virtual interface br0
  1. Any log to share?
  2. What if the bridging is not set? Will this issue also happem?
journalctl_log.txt (254.8 KB)
Attached journal ctl logs.
  1. Bridging always works if both eth0 and wlan1 are up
  1. Please dump the log from serial console if this is NX devkit. I need the log before board suddenly shutdown.
  1. I didn’t ask “bridging is working or not”. I am asking if the bridging is related to the shutdown issue or not.
  1. Sorry I am not using developer Kit. But I can share the serial logs,
    Serial_logs.txt (95.8 KB)
  2. I think it is interpreted wrongly, System is not shutting down. WiFi is not showing up at all.
Could you also share a log when wifi is running? From dmesg, looks like even wifi is not up.
What interface is your wifi card using?
This is the log for working caseworking_logs.txt (304.1 KB)
I am using wlan1 for wifi ap.
No, my question is not wlan0 1 2 3 …100. My question is what kind of interaface is that? USB? PCIe?
PCIe
0004:00:00.0 PCI bridge: NVIDIA Corporation Device 1ad1 (rev a1)
0004:01:00.0 Ethernet controller: Intel Corporation Device 1531 (rev 03)
0005:00:00.0 PCI bridge: NVIDIA Corporation Device 1ad0 (rev a1)
0005:01:00.0 Network controller: Broadcom Inc. and subsidiaries BCM4356 802.11ac Wireless Network Adapter (rev 02)
Could you share the result of “lspci -vv” when wifi are working and not working?
When WiFi is working
0004:00:00.0 PCI bridge: NVIDIA Corporation Device 1ad1 (rev a1) (prog-if 00 [Normal decode])
        Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
        Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
        Latency: 0
        Interrupt: pin A routed to IRQ 33
        Bus: primary=00, secondary=01, subordinate=ff, sec-latency=0
        I/O behind bridge: 00001000-00001fff
        Memory behind bridge: 40000000-40bfffff
        Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
        BridgeCtl: Parity- SERR- NoISA- VGA- MAbort- >Reset- FastB2B-
                PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
        Capabilities: [40] Power Management version 3
                Flags: PMEClk- DSI- D1- D2- AuxCurrent=375mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
                Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
        Capabilities: [50] MSI: Enable- Count=1/1 Maskable+ 64bit+
                Address: 0000000000000000  Data: 0000
                Masking: 00000000  Pending: 00000000
        Capabilities: [70] Express (v2) Root Port (Slot-), MSI 00
                DevCap: MaxPayload 256 bytes, PhantFunc 0
                        ExtTag- RBE+
                DevCtl: Report errors: Correctable+ Non-Fatal+ Fatal+ Unsupported+
                        RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+
                        MaxPayload 256 bytes, MaxReadReq 512 bytes
                DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr+ TransPend-
                LnkCap: Port #0, Speed 8GT/s, Width x1, ASPM not supported, Exit Latency L0s <1us, L1 <64us
                        ClockPM- Surprise+ LLActRep+ BwNot+ ASPMOptComp+
                LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk+
                        ExtSynch- ClockPM- AutWidDis- BWInt+ AutBWInt-
                LnkSta: Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive+ BWMgmt+ ABWMgmt-
                RootCtl: ErrCorrectable- ErrNon-Fatal- ErrFatal- PMEIntEna+ CRSVisible+
                RootCap: CRSVisible+
                RootSta: PME ReqID 0000, PMEStatus- PMEPending-
                DevCap2: Completion Timeout: Range ABCD, TimeoutDis+, LTR+, OBFF Not Supported ARIFwd-
                DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR+, OBFF Disabled ARIFwd-
                LnkCtl2: Target Link Speed: 8GT/s, EnterCompliance- SpeedDis-
                         Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
                         Compliance De-emphasis: -6dB
                LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete-, EqualizationPhase1-
                         EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
        Capabilities: [b0] MSI-X: Enable- Count=8 Masked-
                Vector table: BAR=2 offset=00000000
                PBA: BAR=2 offset=00010000
        Capabilities: [100 v2] Advanced Error Reporting
                UESta:  DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
                UEMsk:  DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
                UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
                CESta:  RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
                CEMsk:  RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
                AERCap: First Error Pointer: 00, GenCap+ CGenEn- ChkCap+ ChkEn-
        Capabilities: [148 v1] #19
        Capabilities: [168 v1] #26
        Capabilities: [18c v1] #27
        Capabilities: [1ac v1] L1 PM Substates
                L1SubCap: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2- ASPM_L1.1- L1_PM_Substates+
                          PortCommonModeRestoreTime=60us PortTPowerOnTime=40us
                L1SubCtl1: PCI-PM_L1.2- PCI-PM_L1.1- ASPM_L1.2- ASPM_L1.1-
                           T_CommonMode=60us
                L1SubCtl2: T_PwrOn=40us
        Capabilities: [1bc v1] Vendor Specific Information: ID=0002 Rev=4 Len=100 <?>
        Capabilities: [2bc v1] Vendor Specific Information: ID=0001 Rev=1 Len=038 <?>
        Capabilities: [2f4 v1] #25
        Capabilities: [300 v1] Precision Time Measurement
                PTMCap: Requester:+ Responder:+ Root:+
                PTMClockGranularity: 16ns
                PTMControl: Enabled:- RootSelected:-
                PTMEffectiveGranularity: Unknown
        Capabilities: [30c v1] Vendor Specific Information: ID=0004 Rev=1 Len=054 <?>
        Kernel driver in use: pcieport
        Subsystem: Intel Corporation Device 0000
        Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
        Interrupt: pin A routed to IRQ 0
        Region 0: Memory at 1740000000 (32-bit, non-prefetchable) [disabled] [size=8M]
        Region 2: I/O ports at 1000 [disabled] [size=32]
        Region 3: Memory at 1740800000 (32-bit, non-prefetchable) [disabled] [size=16K]
                Flags: PMEClk- DSI+ D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
                Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=1 PME-
        Capabilities: [70] MSI-X: Enable- Count=5 Masked-
                Vector table: BAR=3 offset=00000000
                PBA: BAR=3 offset=00002000
        Capabilities: [a0] Express (v2) Endpoint, MSI 00
                DevCap: MaxPayload 512 bytes, PhantFunc 0, Latency L0s <512ns, L1 <64us
                        ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset+ SlotPowerLimit 0.000W
                DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
                        RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+ FLReset-
                LnkCap: Port #4, Speed 2.5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <2us, L1 <16us
                        ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp+
                        ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
                LnkSta: Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
                DevCap2: Completion Timeout: Range ABCD, TimeoutDis+, LTR+, OBFF Via WAKE#
                DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled
                LnkCtl2: Target Link Speed: 2.5GT/s, EnterCompliance- SpeedDis-
                LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete-, EqualizationPhase1-
        Capabilities: [140 v1] Device Serial Number 00-a0-c9-ff-ff-00-00-00
        Capabilities: [1a0 v1] Transaction Processing Hints
                Device specific mode supported
                Steering table in TPH capability structure
        Capabilities: [1c0 v1] Latency Tolerance Reporting
                Max snoop latency: 0ns
                Max no snoop latency: 0ns
0005:00:00.0 PCI bridge: NVIDIA Corporation Device 1ad0 (rev a1) (prog-if 00 [Normal decode])
        Latency: 0
        Interrupt: pin A routed to IRQ 35
        Memory behind bridge: 40000000-405fffff
                        ExtTag- RBE+
                LnkCap: Port #0, Speed 16GT/s, Width x8, ASPM not supported, Exit Latency L0s <1us, L1 <64us
                LnkCtl2: Target Link Speed: 16GT/s, EnterCompliance- SpeedDis-
                CEMsk:  RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
        Capabilities: [190 v1] #27
        Capabilities: [1c0 v1] L1 PM Substates
                           T_CommonMode=60us
                L1SubCtl2: T_PwrOn=50us
        Capabilities: [1d0 v1] Vendor Specific Information: ID=0002 Rev=4 Len=100 <?>
        Capabilities: [2d0 v1] Vendor Specific Information: ID=0001 Rev=1 Len=038 <?>
        Capabilities: [308 v1] #25
        Capabilities: [314 v1] Precision Time Measurement
        Capabilities: [320 v1] Vendor Specific Information: ID=0004 Rev=1 Len=054 <?>
        Subsystem: Gemtek Technology Co., Ltd BCM4356 802.11ac Wireless Network Adapter
        Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
        Latency: 0
        Region 0: Memory at 1f40400000 (64-bit, non-prefetchable) [size=32K]
        Region 2: Memory at 1f40000000 (64-bit, non-prefetchable) [size=4M]
        Capabilities: [48] Power Management version 3
                Flags: PMEClk- DSI- D1+ D2+ AuxCurrent=0mA PME(D0+,D1+,D2+,D3hot+,D3cold+)
                Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=2 PME-
        Capabilities: [58] MSI: Enable- Count=1/16 Maskable- 64bit+
        Capabilities: [68] Vendor Specific Information: Len=44 <?>
        Capabilities: [ac] Express (v2) Endpoint, MSI 00
                DevCap: MaxPayload 256 bytes, PhantFunc 0, Latency L0s <4us, L1 unlimited
                        ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset- SlotPowerLimit 0.000W
                        RlxdOrd+ ExtTag- PhantFunc- AuxPwr+ NoSnoop+
                LnkCap: Port #0, Speed 2.5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <2us, L1 <32us
                        ClockPM+ Surprise- LLActRep- BwNot- ASPMOptComp+
        Capabilities: [100 v1] Advanced Error Reporting
        Capabilities: [13c v1] Device Serial Number 00-00-38-ff-ff-00-38-0f
        Capabilities: [150 v1] Power Budgeting <?>
        Capabilities: [160 v1] Virtual Channel
                Caps:   LPEVC=0 RefClk=100ns PATEntryBits=1
                Arb:    Fixed- WRR32- WRR64- WRR128-
                Ctrl:   ArbSelect=Fixed
                Status: InProgress-
                VC0:    Caps:   PATOffset=00 MaxTimeSlots=1 RejSnoopTrans-
                        Arb:    Fixed- WRR32- WRR64- WRR128- TWRR128- WRR256-
                        Ctrl:   Enable+ ID=0 ArbSelect=Fixed TC/VC=ff
                        Status: NegoPending- InProgress-
        Capabilities: [1b0 v1] Latency Tolerance Reporting
        Capabilities: [220 v1] #15
        Capabilities: [240 v1] L1 PM Substates
                L1SubCap: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2+ ASPM_L1.1+ L1_PM_Substates+
                          PortCommonModeRestoreTime=0us PortTPowerOnTime=50us
                           T_CommonMode=0us LTR1.2_Threshold=0ns
        Kernel driver in use: pcieh
        Kernel modules: bcmdhd_pcie
When WiFi is not working
        Latency: 0
                        ExtTag- RBE+
                           T_CommonMode=60us
        Latency: 0
                        ExtTag- RBE+
                           T_CommonMode=60us
        Latency: 0
                Status: InProgress-
Looks like PCIe part has no problem. And “dhd_module_init” is not starting when wifi failed case.
You can check the dmesg right after running hostapd and see if any new error log gets printed.
