The Tx1’s wifi module works properly after system boots and connected to my AP, I also can see all of the AP routes on the Ubuntu → system Settings → Network → Wireless.
But if try to turn off and turn on the wireless switch immediately for several times. The wireless network failure and those AP routes do not show up on the “Wirless” windows.
Here is the kernel log when I try to switch the Wireless switch. Is there any suggestions on this issue?
[ 107.904087] WLC_E_IF: NO_IF set, event Ignored
[ 107.904106] CFG80211-ERROR) wl_cfg80211_disconnect : Reason 3
[ 107.914733] CFG80211-ERROR) wl_is_linkdown : Link down Reason : WLC_E_LINK
[ 107.904087] WLC_E_IF: NO_IF set, even[ 107.921837] CFG80211-ERROR) wl_notify_connect_status : t Ignored
[ 107.904106] CFG80link down if wlan0 may call cfg80211_disconnected. event : 16, reason=2 from ac:37:43:a1:12:bd
[ 107.921837] CFG80211-ERROR) wl_notify_connect_status : link down if wlan0 may call cfg80211_disconnected. event : 16, reason=2 from ac:37:43:a1:12:bd
[ 108.222253] CFG80211-ERROR) wl_cfg80211_disconnect : Link down event is not received
[ 108.259672] wl_android_wifi_off in
[ 108.263294] tegra_sysfs_off
[ 108.266130] tegra_sysfs_rf_test_disable
[ 108.263294] tegra_sysf[ 108.273761] dhd_wlfc_deinit():3438, maintain HOST RXRERODER flag in tvl
s_off
[ 108.273761] dhd_wlfc_deinit()[ 108.287509] sdhci-tegra sdhci-tegra.1: Tuning already done, restoring the best tap value : 107
[ 108.300424] wifi_platform_set_power = 0
[ 108.639780] CFGP2P-ERROR) wl_cfgp2p_del_p2p_disc_if : P2P interface unregistered
[ 108.656015] cfg80211: World regulatory domain updated:
[ 108.661295] cfg80211: DFS Master region: unset[ 108.656015] cfg80211: World regulator
y domain updated:
[ 108.665902] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 108.680610] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 108.661295] cfg80211: DFS Master reg[ 108.689066] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
ion: unset
[ 108.665902] cfg80211: (start_freq - end_freq @ bandwidth), (max[ 108.704140] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
_antenna_gain, max_eirp), (dfs_c[ 108.715077] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
ac_time)
[ 108.680610] cfg8021[ 108.727299] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
1: (2402000 KHz - 2472000 KHz [ 108.739533] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
@ 40000 KHz), (N/A, 2000 mBm), ([ 108.750366] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
N/A)
[ 108.689066] cfg80211: [ 108.761120] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 109.750093]
[ 109.750093] Dongle Host Driver, version 1.201.82 (r)
[ 109.750093] Compiled in drivers/net/wireless/bcmdhd on Mar 1 2018 at 20:43:08
[ 109.764024] wl_android_wifi_on in
[ 109.767338] wifi_platform_set_power = 1
[ 109.750093]
[ 110.042533] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[ 110.139428] sdhci-tegra sdhci-tegra.1: Tuning already done, restoring the best tap value : 107
[ 110.139428] sdhci-tegra sdhci-tegra.1[ 110.148657] F1 signature read @0x18000000=0x17214354
[ 110.148657] F1 signature read @0x1[ 110.161644] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
8000000=0x17214354
[ 110.171960] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 110.242111] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
[ 110.291390] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
[ 110.291390] dhd_bus_init: enable 0x06, ready [ 110.298405] wifi_platform_get_mac_addr
0x06 (waited 0us)
[ 110.298405] wifi_platform_get_mac_add[ 110.307323] Firmware up: op_mode=0x0005, MAC=00:04:4b:a1:2c:b6
r
[ 110.323110] dhd_preinit_ioctls pspretend_threshold for HostAPD failed -23
[ 110.323110] dhd_preinit_ioctls pspretend_threshold for HostAP[ 110.336243] Firmware version = wl0: Dec 12 2017 15:09:35 version 7.35.221.34 (r679642) FWID 01-8f1f4763
D failed -23
[ 110.336243] Firmware version = wl0: Dec 12 2017 15:09[ 110.351765] dhd_interworking_enable: failed to set WNM info, ret=-23
:35 version 7.35.221.34 (r679642) FWID 0[ 110.361362] tegra_sysfs_on
1-8f1f4763
[ 110.518954] CFGP2P-ERROR) wl_cfgp2p_add_p2p_disc_if : P2P interface registered
[ 110.545678] WLC_E_IF: NO_IF set, event Ignored
[ 111.437635] WLC_E_IF: NO_IF set, event Ignored
[ 111.447202] CFG80211-ERROR) wl_escan_handler : escan is not ready ndev ffffffc07a30c000 drv_status 0x0 e_type 69 e_states 4
[ 111.447202] CFG80211-ERROR) w[ 111.460896] wl_android_wifi_off in
l_escan_handler : escan is not r[ 111.467050] tegra_sysfs_off
eady ndev ffffffc07a30c000 drv_s[ 111.472676] tegra_sysfs_rf_test_disable
[ 111.4[ 111.480006] dhd_wlfc_deinit():3438, maintain HOST RXRERODER flag in tvl
[ 111.46[ 111.489949] sdhci-tegra sdhci-tegra.1: Tuning already done, restoring the best tap value : 107
[ 111.472676] tegra_sysf[ 111.502403] wifi_platform_set_power = 0
s_rf_test_disable
[ 111.781746] CFGP2P-ERROR) wl_cfgp2p_del_p2p_disc_if : P2P interface unregistered
[ 113.083474]
[ 113.083474] Dongle Host Driver, version 1.201.82 (r)
[ 113.083474] Compiled in drivers/net/wireless/bcmdhd on Mar 1 2018 at 20:43:08
[ 113.097258] wl_android_wifi_on in
[ 113.100635] wifi_platform_set_power = 1
[ 113.083474]
[ 113.399272] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[ 113.513239] sdhci-tegra sdhci-tegra.1: Tuning already done, restoring the best tap value : 107
[ 113.529186] F1 signature read @0x18000000=0x17214354
[ 113.545388] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 113.552475] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 113.605737] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
[ 113.654834] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
[ 113.661770] wifi_platform_get_mac_addr
[ 113.654834] dhd_bus_init: enable 0x06, ready 0x06 (wa[ 113.667752] Firmware up: op_mode=0x0005, MAC=00:04:4b:a1:2c:b6
ited 0us)
[ 113.667752] Firmware up: op_mode=0x0005, MAC=00:04:4b[ 113.682940] dhd_preinit_ioctls pspretend_threshold for HostAPD failed -23
:a1:2c:b6
[ 113.698861] Firmware version = wl0: Dec 12 2017 15:09:35 version 7.35.221.34 (r679642) FWID 01-8f1f4763
[ 113.713589] dhd_interworking_enable: failed to set WNM info, ret=-23
[ 113.698861] Firmware version [ 113.720123] tegra_sysfs_on
[ 113.832443] CFGP2P-ERROR) wl_cfgp2p_add_p2p_disc_if : P2P interface registered
[ 113.853524] WLC_E_IF: NO_IF set, event Ignored
[ 114.763194] WLC_E_IF: NO_IF set, event Ignored
[ 114.784145] wl_android_wifi_off in
[ 114.787547] tegra_sysfs_off
[ 114.790349] tegra_sysfs_rf_test_disable
[[ 114.794927] dhd_wlfc_deinit():3438, maintain HOST RXRERODER flag in tvl
[ 114.79[ 114.805091] sdhci-tegra sdhci-tegra.1: Tuning already done, restoring the best tap value : 107
[ 114.794927[ 114.817495] wifi_platform_set_power = 0
[ 115.104558] CFGP2P-ERROR) wl_cfgp2p_del_p2p_disc_if : P2P interface unregistered
[ 120.598971] CFG80211-ERROR) wl_scan_timeout : timer expired but no scan request
[ 231.141605]
[ 231.141605] Dongle Host Driver, version 1.201.82 (r)
[ 231.141605] Compiled in drivers/net/wireless/bcmdhd on Mar 1 2018 at 20:43:08
[ 231.141605]
Dongle Host Driver, vers[ 231.158540] wl_android_wifi_on in
ion 1.201.82 (r)
Compiled in drivers/net/wireles[ 231.167817] wifi_platform_set_power = 1
[ 231.468998] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[ 231.584034] sdhci-tegra sdhci-tegra.1: Tuning already done, restoring the best tap value : 107
[ 231.584034] sdhci-tegra sdhci-tegra.1: Tuning already done, restoring the best tap va[ 231.598462] F1 signature read @0x18000000=0x17214354
lue : 107
[ 231.621012] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 231.621012] F1 signature OK, socitype[ 231.629476] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 231.726453] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
[ 231.775971] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
[ 231.783035] wifi_platform_get_mac_addr
[ 231.775971] dhd_bus_init: enable 0x06, ready 0x06 (wa[ 231.788757] Firmware up: op_mode=0x0005, MAC=00:04:4b:a1:2c:b6
ited 0us)
[ 231.804732] dhd_preinit_ioctls pspretend_threshold for HostAPD failed -23
[ 231.820811] Firmware version = wl0: Dec 12 2017 15:09:35 version 7.35.221.34 (r679642) FWID 01-8f1f4763
[ 231.837077] dhd_interworking_enable: failed to set WNM info, ret=-23
[ 231.820811] Firmware version [ 231.843605] tegra_sysfs_on
[ 231.971446] CFGP2P-ERROR) wl_cfgp2p_add_p2p_disc_if : P2P interface registered
[ 231.992716] WLC_E_IF: NO_IF set, event Ignored
