USB hub doesn't work with L4T R24.2.1
I am using TX1 with a PCIe USB 3 hub, but after flashing to Linux For Tegra R24.2.1 devices connected to the hub are no longer recognized.
Output of lsusb
Bus 009 Device 003: ID 046d:c31d Logitech, Inc. Media Keyboard K200
Bus 009 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 010 Device 002: ID 0955:09ff NVidia Corp.
Bus 010 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 008 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 007 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
lspci -v
00:01.0 PCI bridge: NVIDIA Corporation Device 0fae (rev a1) (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 130
	Bus: primary=00, secondary=01, subordinate=06, sec-latency=0
	I/O behind bridge: 00001000-00004fff
	Memory behind bridge: 13000000-137fffff
	Prefetchable memory behind bridge: 0000000020000000-00000000207fffff
	Capabilities: <access denied>
	Kernel driver in use: pcieport
01:00.0 PCI bridge: Pericom Semiconductor Device 2608 (prog-if 00 [Normal decode])
	Bus: primary=01, secondary=02, subordinate=06, sec-latency=0
02:01.0 PCI bridge: Pericom Semiconductor Device 2608 (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 547
	Bus: primary=02, secondary=03, subordinate=03, sec-latency=0
	I/O behind bridge: 00001000-00001fff
	Memory behind bridge: 13000000-131fffff
	Prefetchable memory behind bridge: 0000000020000000-00000000201fffff
02:02.0 PCI bridge: Pericom Semiconductor Device 2608 (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 548
	Bus: primary=02, secondary=04, subordinate=04, sec-latency=0
	I/O behind bridge: 00002000-00002fff
	Memory behind bridge: 13200000-133fffff
	Prefetchable memory behind bridge: 0000000020200000-00000000203fffff
02:03.0 PCI bridge: Pericom Semiconductor Device 2608 (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 549
	Bus: primary=02, secondary=05, subordinate=05, sec-latency=0
	I/O behind bridge: 00003000-00003fff
	Memory behind bridge: 13400000-135fffff
	Prefetchable memory behind bridge: 0000000020400000-00000000205fffff
02:04.0 PCI bridge: Pericom Semiconductor Device 2608 (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 550
	Bus: primary=02, secondary=06, subordinate=06, sec-latency=0
	I/O behind bridge: 00004000-00004fff
	Memory behind bridge: 13600000-137fffff
	Prefetchable memory behind bridge: 0000000020600000-00000000207fffff
03:00.0 USB controller: Renesas Technology Corp. uPD720202 USB 3.0 Host Controller (rev 02) (prog-if 30 [XHCI])
	Subsystem: Renesas Technology Corp. uPD720202 USB 3.0 Host Controller
	Memory at 13000000 (64-bit, non-prefetchable)
	Kernel driver in use: xhci_hcd
04:00.0 USB controller: Renesas Technology Corp. uPD720202 USB 3.0 Host Controller (rev 02) (prog-if 30 [XHCI])
	Memory at 13200000 (64-bit, non-prefetchable)
05:00.0 USB controller: Renesas Technology Corp. uPD720202 USB 3.0 Host Controller (rev 02) (prog-if 30 [XHCI])
	Memory at 13400000 (64-bit, non-prefetchable)
06:00.0 USB controller: Renesas Technology Corp. uPD720202 USB 3.0 Host Controller (rev 02) (prog-if 30 [XHCI])
	Memory at 13600000 (64-bit, non-prefetchable)
dmesg | grep -i xhci
[    4.300860] xhci_hcd 0000:03:00.0: xHCI Host Controller
[    4.308992] xhci_hcd 0000:03:00.0: new USB bus registered, assigned bus number 1
[    4.389596] usb usb1: Product: xHCI Host Controller
[    4.397855] usb usb1: Manufacturer: Linux 3.10.96-tegra xhci_hcd
[    4.415629] xHCI xhci_add_endpoint called for root hub
[    4.415636] xHCI xhci_check_bandwidth called for root hub
[    4.430521] xhci_hcd 0000:03:00.0: xHCI Host Controller
[    4.439291] xhci_hcd 0000:03:00.0: new USB bus registered, assigned bus number 2
[    4.471741] usb usb2: Product: xHCI Host Controller
[    4.480292] usb usb2: Manufacturer: Linux 3.10.96-tegra xhci_hcd
[    4.498544] xHCI xhci_add_endpoint called for root hub
[    4.498551] xHCI xhci_check_bandwidth called for root hub
[    4.580786] xhci_hcd 0000:04:00.0: xHCI Host Controller
[    4.589625] xhci_hcd 0000:04:00.0: new USB bus registered, assigned bus number 3
[    4.618551] usb usb3: Product: xHCI Host Controller
[    4.618555] usb usb3: Manufacturer: Linux 3.10.96-tegra xhci_hcd
[    4.680956] xHCI xhci_add_endpoint called for root hub
[    4.680958] xHCI xhci_check_bandwidth called for root hub
[    4.681289] xhci_hcd 0000:04:00.0: xHCI Host Controller
[    4.681313] xhci_hcd 0000:04:00.0: new USB bus registered, assigned bus number 4
[    4.681435] usb usb4: Product: xHCI Host Controller
[    4.681439] usb usb4: Manufacturer: Linux 3.10.96-tegra xhci_hcd
[    4.681691] xHCI xhci_add_endpoint called for root hub
[    4.681693] xHCI xhci_check_bandwidth called for root hub
[    4.800774] xhci_hcd 0000:05:00.0: xHCI Host Controller
[    4.800790] xhci_hcd 0000:05:00.0: new USB bus registered, assigned bus number 5
[    4.990457] usb usb5: Product: xHCI Host Controller
[    4.999540] usb usb5: Manufacturer: Linux 3.10.96-tegra xhci_hcd
[    5.018897] xHCI xhci_add_endpoint called for root hub
[    5.018904] xHCI xhci_check_bandwidth called for root hub
[    5.035281] xhci_hcd 0000:05:00.0: xHCI Host Controller
[    5.044751] xhci_hcd 0000:05:00.0: new USB bus registered, assigned bus number 6
[    5.078978] usb usb6: Product: xHCI Host Controller
[    5.088031] usb usb6: Manufacturer: Linux 3.10.96-tegra xhci_hcd
[    5.107053] xHCI xhci_add_endpoint called for root hub
[    5.107060] xHCI xhci_check_bandwidth called for root hub
[    5.220779] xhci_hcd 0000:06:00.0: xHCI Host Controller
[    5.230042] xhci_hcd 0000:06:00.0: new USB bus registered, assigned bus number 7
[    5.270668] usb usb7: Product: xHCI Host Controller
[    5.279651] usb usb7: Manufacturer: Linux 3.10.96-tegra xhci_hcd
[    5.298690] xHCI xhci_add_endpoint called for root hub
[    5.298697] xHCI xhci_check_bandwidth called for root hub
[    5.314742] xhci_hcd 0000:06:00.0: xHCI Host Controller
[    5.324028] xhci_hcd 0000:06:00.0: new USB bus registered, assigned bus number 8
[    5.357819] usb usb8: Product: xHCI Host Controller
[    5.366829] usb usb8: Manufacturer: Linux 3.10.96-tegra xhci_hcd
[    5.385845] xHCI xhci_add_endpoint called for root hub
[    5.385852] xHCI xhci_check_bandwidth called for root hub
[    5.532219] tegra-xhci tegra-xhci: XUSB device id = 0xfac (T210)
[    5.542788] tegra-xhci tegra-xhci: Firmware File: tegra21x_xusb_firmware (124416 Bytes)
[    5.555009] tegra-xhci tegra-xhci: Firmware DMA Memory: dma 0x0000000080040000 mapped 0xffffff8000359000 (124416 Bytes)
[    5.854703] tegra-xhci tegra-xhci: num_hsic_port 0
[    5.864933] tegra-xhci tegra-xhci: Firmware timestamp: 2016-06-16 13:21:43 UTC, Version: 50.16 release, Falcon state 0x20
[    5.879379] tegra-xhci tegra-xhci: Nvidia xHCI Host Controller
[    5.888635] tegra-xhci tegra-xhci: new USB bus registered, assigned bus number 9
[    5.900226] tegra-xhci tegra-xhci: irq 71, io mem 0x70090000
[    5.930341] usb usb9: Product: Nvidia xHCI Host Controller
[    5.950308] usb usb9: Manufacturer: Linux 3.10.96-tegra tegra-xhci
[    5.959976] usb usb9: SerialNumber: tegra-xhci
[    5.968155] xHCI xhci_add_endpoint called for root hub
[    5.968162] xHCI xhci_check_bandwidth called for root hub
[    6.560705] tegra-xhci tegra-xhci: Nvidia xHCI Host Controller
[    6.560719] tegra-xhci tegra-xhci: new USB bus registered, assigned bus number 10
[    6.560831] usb usb10: Product: Nvidia xHCI Host Controller
[    6.560835] usb usb10: Manufacturer: Linux 3.10.96-tegra tegra-xhci
[    6.560838] usb usb10: SerialNumber: tegra-xhci
[    6.563396] xHCI xhci_add_endpoint called for root hub
[    6.563399] xHCI xhci_check_bandwidth called for root hub
[    7.697769] tegra_xhci_process_mbox_message: ignore SSPI clock request.
[    9.674951] xhci_hcd 0000:03:00.0: Timeout while waiting for a slot
[    9.694357] tegra_xhci_process_mbox_message: ignore SSPI clock request.
[    9.870790] usb 9-3: new low-speed USB device number 3 using tegra-xhci
[    9.957185] input: Logitech USB Keyboard as /devices/platform/tegra-xhci/usb9/9-3/9-3:1.0/input/input2
[    9.969039] hid-generic 0003:046D:C31D.0001: input,hidraw0: USB HID v1.10 Keyboard [Logitech USB Keyboard] on usb-tegra-xhci-3/input0
[    9.992767] input: Logitech USB Keyboard as /devices/platform/tegra-xhci/usb9/9-3/9-3:1.1/input/input3
[   10.021999] hid-generic 0003:046D:C31D.0002: input,hidraw1: USB HID v1.10 Device [Logitech USB Keyboard] on usb-tegra-xhci-3/input1
[   10.311078] usb 10-1: new SuperSpeed USB device number 2 using tegra-xhci
[   10.501351] usb 10-1: reset SuperSpeed USB device number 2 using tegra-xhci
[  141.201344] xhci_hcd 0000:03:00.0: Timeout while waiting for a slot
No new message appears in dmesg upon connecting devices to the hub.
Any help appreciated.
That’s a lot of root HUBs listed. What’s the layout of the add-on, e.g., number of ports, speed, or anything to describe the PCIe card?
Also note that lspci will not show all verbose details without using sudo.
For PCIe USB 3.0 card we have verified Renesas(NEC) uPD720200 working fine. FYI. Thanks.
I think it’s this one https://en.ids-imaging.com/store/usb-3-0-pci-express-card-4-ports-89325.html.
Actually, a two-ports card with uPD720202 chipset works fine here too, but not 4-ports one. Possibly some power management issues?
Capabilities from “sudo lspci -v”
Capabilities: [50] Power Management version 3
Capabilities: [70] MSI: Enable- Count=1/8 Maskable- 64bit+
Capabilities: [90] MSI-X: Enable- Count=8 Masked-
Capabilities: [a0] Express Endpoint, MSI 00
Capabilities: [100] Advanced Error Reporting
Capabilities: [140] Device Serial Number 13-00-00-00-92-43-14-08
Capabilities: [150] Latency Tolerance Reporting
The specs on that card do say it needs external supply. Are you using the SATA power connector on the Jetson to meet that power requirement? If so, try with an external source other than the Jetson supplying the power.
We have hit the case that uPD720202 is NG if AUX power is not connected.
Could you please try with external supply connected as linuxdev suggested?
I did connect external power, it doesn’t help. Also note this same card works well with another TX1 that’s still running trusty-based (R23) image.
Hi Aldrog,
Please connect the card and share the boot log of OK and NG images for reference. Thanks.
Ubuntu 16.04 (non-working)
Feb 11 19:28:00 tegra-ubuntu kernel: Initializing cgroup subsys cpuset
Feb 11 19:28:00 tegra-ubuntu kernel: Initializing cgroup subsys cpuacct
Feb 11 19:28:00 tegra-ubuntu kernel: Linux version 3.10.96-tegra (buildbrain@mobile-u64-1072) (gcc version 4.8.2 (GCC) ) #1 SMP PREEMPT Wed Nov 9 19:42:57 PST 2016
Feb 11 19:28:00 tegra-ubuntu kernel: CPU: Cortex A57 Processor [411fd071] revision 1
Feb 11 19:28:00 tegra-ubuntu kernel: alternative: enabling workaround for ARM erratum 832075
Feb 11 19:28:00 tegra-ubuntu kernel: Machine: jetson_tx1
Feb 11 19:28:00 tegra-ubuntu kernel: bootconsole [earlycon0] enabled
Feb 11 19:28:00 tegra-ubuntu kernel: Reserved memory: initialized node iram-carveout, compatible id nvidia,iram-carveout
Feb 11 19:28:00 tegra-ubuntu kernel: Tegra reserved memory:
                                     LP0:                    ff2bf000 - ff2bffff
                                     Bootloader framebuffer: 00000000 - 00000000
                                     Bootloader framebuffer2: 00000000 - 00000000
                                     Framebuffer:            00000000 - 00000000
                                     2nd Framebuffer:        00000000 - 00000000
                                     Carveout:               00000000 - 00000000
                                     Vpr:                    00000000 - 00000000
                                     Tsec:                   00000000 - 00000000
                                     Bootloader Debug Data:  00000000 - 00000000
Feb 11 19:28:00 tegra-ubuntu kernel: Nvdumper:               ff23f000 - ff23ffff
Feb 11 19:28:00 tegra-ubuntu kernel: cma: CMA: reserved 16 MiB at fdc00000
Feb 11 19:28:00 tegra-ubuntu kernel: On node 0 totalpages: 1043968
Feb 11 19:28:00 tegra-ubuntu kernel:   DMA32 zone: 7168 pages used for memmap
Feb 11 19:28:00 tegra-ubuntu kernel:   DMA32 zone: 0 pages reserved
Feb 11 19:28:00 tegra-ubuntu kernel:   DMA32 zone: 519680 pages, LIFO batch:31
Feb 11 19:28:00 tegra-ubuntu kernel:   Normal zone: 7168 pages used for memmap
Feb 11 19:28:00 tegra-ubuntu kernel:   Normal zone: 524288 pages, LIFO batch:31
Feb 11 19:28:00 tegra-ubuntu kernel: psci: probing for conduit method from DT.
Feb 11 19:28:00 tegra-ubuntu kernel: psci: PSCIv0.2 detected in firmware.
Feb 11 19:28:00 tegra-ubuntu kernel: psci: Using standard PSCI v0.2 function IDs
Feb 11 19:28:00 tegra-ubuntu kernel: DTS File Name: /dvs/git/dirty/git-master_linux/kernel/arch/arm64/boot/dts/tegra210-jetson-tx1-p2597-2180-a01-devkit.dts
Feb 11 19:28:00 tegra-ubuntu kernel: DTB Build time: Nov  9 2016 19:40:03
Feb 11 19:28:00 tegra-ubuntu kernel: Tegra21: Speedo/IDDQ fuse revision 4
Feb 11 19:28:00 tegra-ubuntu kernel: Tegra21: CPU Speedo ID 7, Soc Speedo ID 0, Gpu Speedo ID 2
Feb 11 19:28:00 tegra-ubuntu kernel: Tegra21: CPU Process ID 0, Soc Process ID 0, Gpu Process ID 0
Feb 11 19:28:00 tegra-ubuntu kernel: Tegra21: CPU Speedo value 2029, Soc Speedo value 1913, Gpu Speedo value 2025
Feb 11 19:28:00 tegra-ubuntu kernel: Tegra21: CPU IDDQ 1884, Soc IDDQ 1940, Gpu IDDQ 2430
Feb 11 19:28:00 tegra-ubuntu kernel: Tegra Revision: A02 SKU: 0x17 CPU Process: 0 Core Process: 0 Bootrom patch v0x3f
Feb 11 19:28:00 tegra-ubuntu kernel: tegra: PLLP fixed rate: 408000000
Feb 11 19:28:00 tegra-ubuntu kernel: pll_u: boot with h/w control already set
Feb 11 19:28:00 tegra-ubuntu kernel: pll_x boot misc1 0x0 : expected 0x20
Feb 11 19:28:00 tegra-ubuntu kernel:  (comparison mask = 0xffffff)
Feb 11 19:28:00 tegra-ubuntu kernel: pll_c4 rates match 204000000 max sdmmc: vco=998400000 out0=998400000 out3=998400000
Feb 11 19:28:00 tegra-ubuntu kernel: Lowering vic03 maximum rate from 1000000000 to 627200000
Feb 11 19:28:00 tegra-ubuntu kernel: Lowering nvjpg maximum rate from 1000000000 to 627200000
Feb 11 19:28:00 tegra-ubuntu kernel: Lowering se maximum rate from 1000000000 to 627200000
Feb 11 19:28:00 tegra-ubuntu kernel: Lowering tsecb maximum rate from 1000000000 to 627200000
Feb 11 19:28:00 tegra-ubuntu kernel: Lowering msenc maximum rate from 1000000000 to 716800000
Feb 11 19:28:00 tegra-ubuntu kernel: Lowering nvdec maximum rate from 1000000000 to 716800000
Feb 11 19:28:00 tegra-ubuntu kernel: Lowering vi maximum rate from 1000000000 to 793600000
Feb 11 19:28:00 tegra-ubuntu kernel: Lowering isp maximum rate from 1000000000 to 793600000
Feb 11 19:28:00 tegra-ubuntu kernel: Lowering adsp_bus maximum rate from 1200000000 to 844800000
Feb 11 19:28:00 tegra-ubuntu kernel: Lowering sbus maximum rate from 600000000 to 408000000
Feb 11 19:28:00 tegra-ubuntu kernel: Lowering host1x maximum rate from 600000000 to 408000000
Feb 11 19:28:00 tegra-ubuntu kernel: Lowering pll_c maximum rate from 1200000000 to 1130000000
Feb 11 19:28:00 tegra-ubuntu kernel: Lowering pll_c2 maximum rate from 1200000000 to 1130000000
Feb 11 19:28:00 tegra-ubuntu kernel: Lowering pll_c3 maximum rate from 1200000000 to 1130000000
Feb 11 19:28:00 tegra-ubuntu kernel: Lowering pll_d2 maximum rate from 1500000000 to 1130000000
Feb 11 19:28:00 tegra-ubuntu kernel: Lowering pll_dp maximum rate from 1500000000 to 1130000000
Feb 11 19:28:00 tegra-ubuntu kernel: Lowering sor0 maximum rate from 600000000 to 540000000
Feb 11 19:28:00 tegra-ubuntu kernel: Lowering sor1 maximum rate from 600000000 to 594000000
Feb 11 19:28:00 tegra-ubuntu kernel: Lowering dmic1 maximum rate from 12288000 to 12190000
Feb 11 19:28:00 tegra-ubuntu kernel: Lowering dmic2 maximum rate from 12288000 to 12190000
Feb 11 19:28:00 tegra-ubuntu kernel: Lowering dmic3 maximum rate from 12288000 to 12190000
Feb 11 19:28:00 tegra-ubuntu kernel: Lowering hda maximum rate from 102000000 to 51000000
Feb 11 19:28:00 tegra-ubuntu kernel: Lowering sdmmc2 maximum rate from 266000000 to 204000000
Feb 11 19:28:00 tegra-ubuntu kernel: Lowering qspi maximum rate from 163200000 to 116600000
Feb 11 19:28:00 tegra-ubuntu kernel: Lowering gbus maximum rate from 1300000000 to 998400000
Feb 11 19:28:00 tegra-ubuntu kernel: Lowering cpu_g maximum rate from 3000000000 to 1734000000
Feb 11 19:28:00 tegra-ubuntu kernel: Lowering cpu_lp maximum rate from 1350000000 to 1132800000
Feb 11 19:28:00 tegra-ubuntu kernel: tegra dvfs: vdd_cpu: nominal 1226mV, offset 708000uV, step 19200uV, scaling enabled
Feb 11 19:28:00 tegra-ubuntu kernel: tegra dvfs: vdd_core: nominal 1125mV, offset 0uV, step 12500uV, scaling enabled
Feb 11 19:28:00 tegra-ubuntu kernel: tegra dvfs: vdd_gpu: nominal 1120mV, offset 710000uV, step 10000uV, scaling enabled
Feb 11 19:28:00 tegra-ubuntu kernel: Tegra reset control registration success
Feb 11 19:28:00 tegra-ubuntu kernel: tegra_powergate_init: DONE
Feb 11 19:28:00 tegra-ubuntu kernel: PERCPU: Embedded 13 pages/cpu @ffffffc01fecf000 s20800 r8192 d24256 u53248
Feb 11 19:28:00 tegra-ubuntu kernel: pcpu-alloc: s20800 r8192 d24256 u53248 alloc=13*4096
Feb 11 19:28:00 tegra-ubuntu kernel: pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
Feb 11 19:28:00 tegra-ubuntu kernel: Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 1029632
Feb 11 19:28:00 tegra-ubuntu kernel: Kernel command line: fbcon=map:0 console=tty0 console=ttyS0,115200n8 androidboot.modem=none androidboot.serialno=P2180A00P00940c003fd androidboot.security=non-secure tegraid=21.1.2.0.0 ddr_die=2048M@2048M ddr_die=2048M@4096M section=256M memtype=0 usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 debug_uartport=lsport,0 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff2bf000 nvdumper_reserved=0xff23f000 core_edp_mv=1125 core_edp_ma=4000 gpt android.kerneltype=normal androidboot.touch_vendor_id=0 androidboot.touch_panel_id=63 androidboot.touch_feature=0 androidboot.bootreason=pmc:software_reset,pmic:0x0 net.ifnames=0 root=/dev/mmcblk0p1 rw rootwait usbcore.usbfs_memory_mb=1000
Feb 11 19:28:00 tegra-ubuntu kernel: PID hash table entries: 4096 (order: 3, 32768 bytes)
Feb 11 19:28:00 tegra-ubuntu kernel: Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
Feb 11 19:28:00 tegra-ubuntu kernel: Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
Feb 11 19:28:00 tegra-ubuntu kernel: Memory: 2030MB 2048MB = 4078MB total
Feb 11 19:28:00 tegra-ubuntu kernel: Memory: 4067000k/4067000k available, 108872k reserved
Feb 11 19:28:00 tegra-ubuntu kernel: Virtual kernel memory layout:
                                         vmalloc : 0xffffff8000000000 - 0xffffffbbffff0000   (245759 MB)
                                         vmemmap : 0xffffffbc01c00000 - 0xffffffbc05400000   (    56 MB)
                                         modules : 0xffffffbffc000000 - 0xffffffc000000000   (    64 MB)
                                         memory  : 0xffffffc000000000 - 0xffffffc100000000   (  4096 MB)
                                           .init : 0xffffffc00114f000 - 0xffffffc0011ba140   (   429 kB)
                                           .text : 0xffffffc000080000 - 0xffffffc00114e3a4   ( 17209 kB)
                                           .data : 0xffffffc0011ce000 - 0xffffffc00139e7f0   (  1858 kB)
Feb 11 19:28:00 tegra-ubuntu kernel: Preemptible hierarchical RCU implementation.
Feb 11 19:28:00 tegra-ubuntu kernel:         RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
Feb 11 19:28:00 tegra-ubuntu kernel: NR_IRQS:704 nr_irqs:704 0
Feb 11 19:28:00 tegra-ubuntu kernel: the number of interrupt controllers found is 6
Feb 11 19:28:00 tegra-ubuntu kernel: Architected local timer running at 19.20MHz (phys).
Feb 11 19:28:00 tegra-ubuntu kernel: sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 3579139424256ns
Feb 11 19:28:00 tegra-ubuntu kernel: Console: colour dummy device 80x25
Feb 11 19:28:00 tegra-ubuntu kernel: console [tty0] enabled
Feb 11 19:28:00 tegra-ubuntu kernel: allocated 16777216 bytes of page_cgroup
Feb 11 19:28:00 tegra-ubuntu kernel: please try 'cgroup_disable=memory' option if you don't want memory cgroups
Feb 11 19:28:00 tegra-ubuntu kernel: Calibrating delay loop (skipped), value calculated using timer frequency.. lpj=192000
Feb 11 19:28:00 tegra-ubuntu kernel: pid_max: default: 32768 minimum: 301
Feb 11 19:28:00 tegra-ubuntu kernel: Security Framework initialized
Feb 11 19:28:00 tegra-ubuntu kernel: Mount-cache hash table entries: 256
Feb 11 19:28:00 tegra-ubuntu kernel: Initializing cgroup subsys debug
Feb 11 19:28:00 tegra-ubuntu kernel: Initializing cgroup subsys memory
Feb 11 19:28:00 tegra-ubuntu kernel: Initializing cgroup subsys devices
Feb 11 19:28:00 tegra-ubuntu kernel: Initializing cgroup subsys freezer
Feb 11 19:28:00 tegra-ubuntu kernel: Initializing cgroup subsys net_cls
Feb 11 19:28:00 tegra-ubuntu kernel: Initializing cgroup subsys blkio
Feb 11 19:28:00 tegra-ubuntu kernel: Initializing cgroup subsys perf_event
Feb 11 19:28:00 tegra-ubuntu kernel: hw perfevents: enabled with arm/armv8-pmuv3 PMU driver, 7 counters available
Feb 11 19:28:00 tegra-ubuntu kernel: ftrace: Allocated trace_printk buffers
Feb 11 19:28:00 tegra-ubuntu kernel: Brought up 4 CPUs
Feb 11 19:28:00 tegra-ubuntu kernel: SMP: Total of 4 processors activated.
Feb 11 19:28:00 tegra-ubuntu kernel: alternatives: patching kernel code
Feb 11 19:28:00 tegra-ubuntu kernel: devtmpfs: initialized
Feb 11 19:28:00 tegra-ubuntu kernel: pinctrl core: initialized pinctrl subsystem
Feb 11 19:28:00 tegra-ubuntu kernel: regulator-dummy: ; Rail ON
Feb 11 19:28:00 tegra-ubuntu kernel: Initializing plugin-manager
Feb 11 19:28:00 tegra-ubuntu kernel: node /plugin-manager/fragement@0 match with board >=2180-1000-300
Feb 11 19:28:00 tegra-ubuntu kernel: NET: Registered protocol family 16
Feb 11 19:28:00 tegra-ubuntu kernel: DMA: preallocated 1024 KiB pool for atomic coherent allocations
Feb 11 19:28:00 tegra-ubuntu kernel: console [pstore-1] enabled
Feb 11 19:28:00 tegra-ubuntu kernel: ramoops: attached 0x200000@0xff03f000, ecc: 0/0
Feb 11 19:28:00 tegra-ubuntu kernel: I2C first dynamic bus number based on alias = 7
Feb 11 19:28:00 tegra-ubuntu kernel: cpuidle: using governor ladder
Feb 11 19:28:00 tegra-ubuntu kernel: cpuidle: using governor menu
Feb 11 19:28:00 tegra-ubuntu kernel: PMC: Setting PMIC interrupt active-low
Feb 11 19:28:00 tegra-ubuntu kernel: tegra-pmc device create success
Feb 11 19:28:00 tegra-ubuntu kernel: padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
Feb 11 19:28:00 tegra-ubuntu kernel: Clear bootloader IO dpd settings
Feb 11 19:28:00 tegra-ubuntu kernel: PMC: configuring io pad defaults
Feb 11 19:28:00 tegra-ubuntu kernel: PMC: IO pad audio voltage is 1800000
Feb 11 19:28:00 tegra-ubuntu kernel: PMC: IO pad cam voltage is 1800000
Feb 11 19:28:00 tegra-ubuntu kernel: PMC: IO pad dbg voltage is 1800000
Feb 11 19:28:00 tegra-ubuntu kernel: PMC: IO pad dmic voltage is 1800000
Feb 11 19:28:00 tegra-ubuntu kernel: PMC: IO pad pex-ctrl voltage is 1800000
Feb 11 19:28:00 tegra-ubuntu kernel: PMC: IO pad spi voltage is 1800000
Feb 11 19:28:00 tegra-ubuntu kernel: PMC: IO pad uart voltage is 1800000
Feb 11 19:28:00 tegra-ubuntu kernel: PMC: IO pad bb voltage is 1800000
Feb 11 19:28:00 tegra-ubuntu kernel: PMC: IO pad audio-hv voltage is 1800000
Feb 11 19:28:00 tegra-ubuntu kernel: PMC: IO pad spi-hv voltage is 1800000
Feb 11 19:28:00 tegra-ubuntu kernel: PMC: IO pad gpio voltage is 1800000
Feb 11 19:28:00 tegra-ubuntu kernel: PMC: IO pad sdmmc3 voltage is 1800000
Feb 11 19:28:00 tegra-ubuntu kernel: PMC: IO pad pex-bias power is disable
Feb 11 19:28:00 tegra-ubuntu kernel: PMC: IO pad pex-clk1 power is disable
Feb 11 19:28:00 tegra-ubuntu kernel: PMC: IO pad pex-clk2 power is disable
Feb 11 19:28:00 tegra-ubuntu kernel: T210 pmc padctrl driver initialized
Feb 11 19:28:00 tegra-ubuntu kernel: T210 pmc config for bootrom command passed
Feb 11 19:28:00 tegra-ubuntu kernel: INFO: pinmux CLAMP_INPUTS_WHEN_TRISTATED: disabled
Feb 11 19:28:00 tegra-ubuntu kernel: clk_init_from_dt_table: clocks are set from t210-clk-init-table:clkinit-0
Feb 11 19:28:00 tegra-ubuntu kernel: platform tegra-carveouts.23: SMMU isn't ready yet
Feb 11 19:28:00 tegra-ubuntu kernel: platform tegra-carveouts.23: domain=ffffffc0fe238ed8 allocates as[0]=ffffffc0fe23c0a8
Feb 11 19:28:00 tegra-ubuntu kernel: tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
Feb 11 19:28:00 tegra-ubuntu kernel: bpmp: connect returned 0
Feb 11 19:28:00 tegra-ubuntu kernel: mapped MMIO address: 0xffffff8000038000 -> 0x70019000
Feb 11 19:28:00 tegra-ubuntu kernel: mapped MMIO address: 0xffffff800005e000 -> 0x7001c000
Feb 11 19:28:00 tegra-ubuntu kernel: mapped MMIO address: 0xffffff8000096000 -> 0x7001d000
Feb 11 19:28:00 tegra-ubuntu kernel: Wake16 for irq=34
Feb 11 19:28:00 tegra-ubuntu kernel: tegra210-pinctrl 700008d4.pinmux: lookup the user state drive not found
Feb 11 19:28:00 tegra-ubuntu kernel: tegra210-pinctrl 700008d4.pinmux: lookup the user state unused not found
Feb 11 19:28:00 tegra-ubuntu kernel: tegra210-pinctrl 700008d4.pinmux: Probed Tegra pinctrl driver
Feb 11 19:28:00 tegra-ubuntu kernel: GPIO chip tegra-gpio: created GPIO range 0->245 ==> 700008d4.pinmux PIN 0->245
Feb 11 19:28:00 tegra-ubuntu kernel: tegra-gpio 6000d000.gpio: Initialising GPIO state 0: name wlan-default
Feb 11 19:28:00 tegra-ubuntu kernel: tegra-gpio 6000d000.gpio: Initialising GPIO state 1: name camera_control
Feb 11 19:28:00 tegra-ubuntu kernel: tegra-gpio 6000d000.gpio: Initialising GPIO state 2: name camera-control
Feb 11 19:28:00 tegra-ubuntu kernel: gpiochip_add: registered GPIOs 0 to 255 on device: tegra-gpio
Feb 11 19:28:00 tegra-ubuntu kernel: Wake44 for irq=81
Feb 11 19:28:00 tegra-ubuntu kernel: Wake40 for irq=53
Feb 11 19:28:00 tegra-ubuntu kernel: Wake41 for irq=53
Feb 11 19:28:00 tegra-ubuntu kernel: Wake42 for irq=53
Feb 11 19:28:00 tegra-ubuntu kernel: Wake43 for irq=53
Feb 11 19:28:00 tegra-ubuntu kernel: platform 70006000.serial: domain=ffffffc0fe20a1d8 allocates as[0]=ffffffc0fe23c110
Feb 11 19:28:00 tegra-ubuntu kernel: platform sound.27: domain=ffffffc0fe26ce58 allocates as[0]=ffffffc0fe23c178
Feb 11 19:28:00 tegra-ubuntu kernel: platform tegradc.1: domain=ffffffc0fe26ca58 allocates as[0]=ffffffc0fe23c1e0
Feb 11 19:28:00 tegra-ubuntu kernel: platform gpu.0: domain=ffffffc0fe26c7d8 allocates as[0]=ffffffc0fe23c248
Feb 11 19:28:00 tegra-ubuntu kernel: platform gpu.0: domain=ffffffc0fe26c7d8 allocates as[1]=ffffffc0fe23c2b0
Feb 11 19:28:00 tegra-ubuntu kernel: platform gpu.0: domain=ffffffc0fe26c7d8 allocates as[2]=ffffffc0fe23c318
Feb 11 19:28:00 tegra-ubuntu kernel: platform gpu.0: domain=ffffffc0fe26c7d8 allocates as[3]=ffffffc0fe23c380
Feb 11 19:28:00 tegra-ubuntu kernel: platform 1003000.pcie-controller: domain=ffffffc0fe26c5d8 allocates as[0]=ffffffc0fe23c3e8
Feb 11 19:28:00 tegra-ubuntu kernel: platform sdhci-tegra.3: domain=ffffffc0fe26c158 allocates as[0]=ffffffc0fe23c450
Feb 11 19:28:00 tegra-ubuntu kernel: platform sdhci-tegra.0: domain=ffffffc0fe2d9e58 allocates as[0]=ffffffc0fe23c4b8
Feb 11 19:28:00 tegra-ubuntu kernel: Wake39 for irq=52
Feb 11 19:28:00 tegra-ubuntu kernel: gpio wake52 for gpio=61
Feb 11 19:28:00 tegra-ubuntu kernel: gpio wake8 for gpio=58
Feb 11 19:28:00 tegra-ubuntu kernel: irq: no irq domain found for /soctherm@0x700E2000 !
Feb 11 19:28:00 tegra-ubuntu kernel: board_info: id:sku:fab:major:minor = 0x0884:0x03e8:0x00:0x00:0x00
Feb 11 19:28:00 tegra-ubuntu kernel: PMC dt information non-NULL tegra_init_suspend
Feb 11 19:28:00 tegra-ubuntu kernel: Loading EMC tables...
Feb 11 19:28:00 tegra-ubuntu kernel: tegra: Using EMC sequence '21021' for Rev. 7 tables
Feb 11 19:28:00 tegra-ubuntu kernel: tegra: emc: Derated table is valid.
Feb 11 19:28:00 tegra-ubuntu kernel: Lowering emc maximum rate from 1800000000 to 1600000000
Feb 11 19:28:00 tegra-ubuntu kernel: tegra: validated EMC DFS table
Feb 11 19:28:00 tegra-ubuntu kernel: swapper/0 isomgr_init(): iso emc max clk=1600000KHz
Feb 11 19:28:00 tegra-ubuntu kernel: swapper/0 isomgr_init(): max_iso_bw=11520000KB
Feb 11 19:28:00 tegra-ubuntu kernel: vdso: 2 pages (1 code, 1 data) at base ffffffc0011d6000
Feb 11 19:28:00 tegra-ubuntu kernel: vdso32: 2 pages (1 code, 1 data) at base ffffffc0011d5000
Feb 11 19:28:00 tegra-ubuntu kernel: hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
Feb 11 19:28:00 tegra-ubuntu kernel: nvdumper: last reboot was unknown
Feb 11 19:28:00 tegra-ubuntu kernel: nvdumper: set_dirty_state 0x2badface
Feb 11 19:28:00 tegra-ubuntu kernel: Tegra restart notifier registered.
Feb 11 19:28:00 tegra-ubuntu kernel: bio: create slab <bio-0> at 0
Feb 11 19:28:00 tegra-ubuntu kernel: vdd-ac-bat: 5000 mV ; Rail ON
Feb 11 19:28:00 tegra-ubuntu kernel: vdd-cpu-fixed: 1000 mV ; Rail ON
Feb 11 19:28:00 tegra-ubuntu kernel: vgaarb: loaded
Feb 11 19:28:00 tegra-ubuntu kernel: SCSI subsystem initialized
Feb 11 19:28:00 tegra-ubuntu kernel: libata version 3.00 loaded.
Feb 11 19:28:00 tegra-ubuntu kernel: usbcore: registered new interface driver usbfs
Feb 11 19:28:00 tegra-ubuntu kernel: usbcore: registered new interface driver hub
Feb 11 19:28:00 tegra-ubuntu kernel: usbcore: registered new device driver usb
Feb 11 19:28:00 tegra-ubuntu kernel: gpio wake33 for gpio=188
Feb 11 19:28:00 tegra-ubuntu kernel: regulator_get() failed for (1-0074,vcc), -19
Feb 11 19:28:00 tegra-ubuntu kernel: pca953x 1-0074: no regulator found for vcc. Assuming vcc is always powered
Feb 11 19:28:00 tegra-ubuntu kernel: gpio wake21 for gpio=89
Feb 11 19:28:00 tegra-ubuntu kernel: gpiochip_add: registered GPIOs 1008 to 1023 on device: tca9539
Feb 11 19:28:00 tegra-ubuntu kernel: regulator_get() failed for (1-0077,vcc), -19
Feb 11 19:28:00 tegra-ubuntu kernel: pca953x 1-0077: no regulator found for vcc. Assuming vcc is always powered
Feb 11 19:28:00 tegra-ubuntu kernel: gpio wake36 for gpio=202
Feb 11 19:28:00 tegra-ubuntu kernel: gpiochip_add: registered GPIOs 992 to 1007 on device: tca9539
Feb 11 19:28:00 tegra-ubuntu kernel: i2c i2c-3: of_i2c: modalias failure on /i2c@7000c700/prod-settings
Feb 11 19:28:00 tegra-ubuntu kernel: max77620 4-003c: CID0: 0xb3
Feb 11 19:28:00 tegra-ubuntu kernel: max77620 4-003c: CID1: 0x08
Feb 11 19:28:00 tegra-ubuntu kernel: max77620 4-003c: CID2: 0x0e
Feb 11 19:28:00 tegra-ubuntu kernel: max77620 4-003c: CID3: 0x59
Feb 11 19:28:00 tegra-ubuntu kernel: max77620 4-003c: CID4: 0x3c
Feb 11 19:28:00 tegra-ubuntu kernel: max77620 4-003c: CID5: 0x80
Feb 11 19:28:00 tegra-ubuntu kernel: max77620 4-003c: MAX77620 PMIC OTP Version is 0x3C
Feb 11 19:28:00 tegra-ubuntu kernel: max77620-pmic max77620-pmic: Consumer c2 does not have device name
Feb 11 19:28:00 tegra-ubuntu kernel: vdd_core: 600 <--> 1400 mV at 1000 mV with ramp delay 27500 uV/us ; Rail ON
Feb 11 19:28:00 tegra-ubuntu kernel: vddio-ddr: at 1125 mV with ramp delay 27500 uV/us ; Rail ON
Feb 11 19:28:00 tegra-ubuntu kernel: vdd-pre-reg: 1350 mV with ramp delay 27500 uV/us ; Rail ON
Feb 11 19:28:00 tegra-ubuntu kernel: vdd-1v8: 1800 mV with ramp delay 27500 uV/us ; Rail ON
Feb 11 19:28:00 tegra-ubuntu kernel: avdd-sys: 1200 mV with ramp delay 100000 uV/us ; Rail ON
Feb 11 19:28:00 tegra-ubuntu kernel: avdd-sys: supplied by vdd-pre-reg
Feb 11 19:28:00 tegra-ubuntu kernel: vdd-pex: 1050 mV with ramp delay 100000 uV/us ; Rail ON
Feb 11 19:28:00 tegra-ubuntu kernel: vdd-pex: supplied by vdd-pre-reg
Feb 11 19:28:00 tegra-ubuntu kernel: vddio-sdmmc1: 1800 <--> 3300 mV at 3300 mV with ramp delay 100000 uV/us ; Rail ON
Feb 11 19:28:00 tegra-ubuntu kernel: vdd-cam-hv: 2800 mV with ramp delay 100000 uV/us ; Rail OFF
Feb 11 19:28:00 tegra-ubuntu kernel: vdd-rtc: 850 mV with ramp delay 100000 uV/us ; Rail ON
Feb 11 19:28:00 tegra-ubuntu kernel: avdd-ts-hv: 3300 mV with ramp delay 100000 uV/us ; Rail OFF
Feb 11 19:28:00 tegra-ubuntu kernel: vdd-ts: 1800 mV with ramp delay 100000 uV/us ; Rail OFF
Feb 11 19:28:00 tegra-ubuntu kernel: vdd-gen-pll-edp: 1050 mV with ramp delay 100000 uV/us ; Rail ON
Feb 11 19:28:00 tegra-ubuntu kernel: vdd-gen-pll-edp: supplied by vdd-pre-reg
Feb 11 19:28:00 tegra-ubuntu kernel: vdd-hdmi-dp: 1050 mV with ramp delay 100000 uV/us ; Rail ON
Feb 11 19:28:00 tegra-ubuntu kernel: vdd-hdmi-dp: supplied by vdd-pre-reg
Feb 11 19:28:00 tegra-ubuntu kernel: max77620-gpio max77620-gpio.0: Initialising GPIO state 1: name gpio_default
Feb 11 19:28:00 tegra-ubuntu kernel: gpiochip_add: registered GPIOs 984 to 991 on device: max77620-gpio
Feb 11 19:28:00 tegra-ubuntu kernel: max77620-gpio max77620-gpio.0: max77620 gpio successfully initialized
Feb 11 19:28:00 tegra-ubuntu kernel: max77620 4-003c: max77620 probe successfully
Feb 11 19:28:00 tegra-ubuntu kernel: media: Linux media interface: v0.10
Feb 11 19:28:00 tegra-ubuntu kernel: Linux video capture interface: v2.00
Feb 11 19:28:00 tegra-ubuntu kernel: pps_core: LinuxPPS API ver. 1 registered
Feb 11 19:28:00 tegra-ubuntu kernel: pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
Feb 11 19:28:00 tegra-ubuntu kernel: PTP clock support registered
Feb 11 19:28:00 tegra-ubuntu kernel: Tegra WDT enabled on probe. Timeout = 120 seconds.
Feb 11 19:28:00 tegra-ubuntu kernel: tegra_wdt 60005100.watchdog: tegra_wdt_probe done
Feb 11 19:28:00 tegra-ubuntu kernel: Advanced Linux Sound Architecture Driver Initialized.
Feb 11 19:28:00 tegra-ubuntu kernel: Bluetooth: Core ver 2.16
Feb 11 19:28:00 tegra-ubuntu kernel: NET: Registered protocol family 31
Feb 11 19:28:00 tegra-ubuntu kernel: Bluetooth: HCI device and connection manager initialized
Feb 11 19:28:00 tegra-ubuntu kernel: Bluetooth: HCI socket layer initialized
Feb 11 19:28:00 tegra-ubuntu kernel: Bluetooth: L2CAP socket layer initialized
Feb 11 19:28:00 tegra-ubuntu kernel: Bluetooth: SCO socket layer initialized
Feb 11 19:28:00 tegra-ubuntu kernel: vdd-3v3: 3300 mV ; Rail ON
Feb 11 19:28:00 tegra-ubuntu kernel: max77620-gpio7: 1050 mV ; Rail ON
Feb 11 19:28:00 tegra-ubuntu kernel: max77620-gpio7: supplied by vdd-gen-pll-edp
Feb 11 19:28:00 tegra-ubuntu kernel: lcd-bl-en: 1800 mV ; Rail ON
Feb 11 19:28:00 tegra-ubuntu kernel: en-vdd-sd: 3300 mV ; Rail OFF
Feb 11 19:28:00 tegra-ubuntu kernel: en-vdd-sd: supplied by vdd-3v3
Feb 11 19:28:00 tegra-ubuntu kernel: reg-fixed-sync-voltage 5.regulator: Consumer c1 does not have device name
Feb 11 19:28:00 tegra-ubuntu kernel: en-vdd-cam: 1800 mV ; Rail OFF
Feb 11 19:28:00 tegra-ubuntu kernel: vdd-sys-boost: 5000 mV ; Rail ON
Feb 11 19:28:00 tegra-ubuntu kernel: vdd-hdmi: 5000 mV ; Rail OFF
Feb 11 19:28:00 tegra-ubuntu kernel: vdd-hdmi: supplied by vdd-3v3
Feb 11 19:28:00 tegra-ubuntu kernel: aux-3v3: 3300 mV ; Rail ON
Feb 11 19:28:00 tegra-ubuntu kernel: snsr_pm: 3300 mV ; Rail ON
Feb 11 19:28:00 tegra-ubuntu kernel: vdd-disp-3v0: 3000 mV ; Rail ON
Feb 11 19:28:00 tegra-ubuntu kernel: vdd-fan: 5000 mV ; Rail OFF
Feb 11 19:28:00 tegra-ubuntu kernel: usb-vbus1: 5000 mV ; Rail OFF
Feb 11 19:28:00 tegra-ubuntu kernel: usb-vbus1: supplied by vdd-3v3
Feb 11 19:28:00 tegra-ubuntu kernel: usb-vbus3: 5000 mV ; Rail OFF
Feb 11 19:28:00 tegra-ubuntu kernel: usb-vbus3: supplied by vdd-3v3
Feb 11 19:28:00 tegra-ubuntu kernel: en-vdd-ts-1v8: 1800 mV ; Rail OFF
Feb 11 19:28:00 tegra-ubuntu kernel: en-vdd-ts-hv-3v3: 3300 mV ; Rail OFF
Feb 11 19:28:00 tegra-ubuntu kernel: en-vdd-disp-3v3: 3300 mV ; Rail ON
Feb 11 19:28:00 tegra-ubuntu kernel: en-mdm-pwr-3v7: ; Rail OFF
Feb 11 19:28:00 tegra-ubuntu kernel: en-vdd-disp-1v8: 1800 mV ; Rail ON
Feb 11 19:28:00 tegra-ubuntu kernel: reg-fixed-sync-voltage ce.regulator: Consumer c0 does not have device name
Feb 11 19:28:00 tegra-ubuntu kernel: en-vdd-cam-hv-2v8: ; Rail OFF
Feb 11 19:28:00 tegra-ubuntu kernel: rtl-5v0: ; Rail OFF
Feb 11 19:28:00 tegra-ubuntu kernel: en-usb-vbus2: ; Rail OFF
Feb 11 19:28:00 tegra-ubuntu kernel: en-vdd-cam-1v2: ; Rail OFF
Feb 11 19:28:00 tegra-ubuntu kernel: en-vdd-cam-1v2: supplied by vdd-3v3
Feb 11 19:28:00 tegra-ubuntu kernel: en-vdd-vcm-2v8: ; Rail ON
Feb 11 19:28:00 tegra-ubuntu kernel: en-vdd-vcm-2v8: supplied by vdd-3v3
Feb 11 19:28:00 tegra-ubuntu kernel: en-vdd-cam-1v2-alt: ; Rail OFF
Feb 11 19:28:00 tegra-ubuntu kernel: regulator-pwm 0.pwm-regulator: PWM request deferred
Feb 11 19:28:00 tegra-ubuntu kernel: platform 0.pwm-regulator: Driver regulator-pwm requests probe deferral
Feb 11 19:28:00 tegra-ubuntu kernel: vdd_gpu: applied init 1000000uV constraint
Feb 11 19:28:00 tegra-ubuntu kernel: vdd_gpu: 710 <--> 1320 mV at 1000 mV ; Rail OFF
Feb 11 19:28:00 tegra-ubuntu kernel: vdd_cpu: applied init 1000000uV constraint
Feb 11 19:28:00 tegra-ubuntu kernel: vdd_cpu: 708 <--> 1322 mV at 1000 mV normal ; Rail ON
Feb 11 19:28:00 tegra-ubuntu kernel: gpio wake34 for gpio=200
Feb 11 19:28:00 tegra-ubuntu kernel: extcon-gpio-states 1.extcon: Cable state 0
Feb 11 19:28:00 tegra-ubuntu kernel: Switching to clocksource arch_sys_counter
Feb 11 19:28:00 tegra-ubuntu kernel: nvmap_heap_init: nvmap_heap_init: created heap block cache
Feb 11 19:28:00 tegra-ubuntu kernel: tegra-carveouts tegra-carveouts.23: iram :dma coherent mem declare 0x0000000040001000,258048
Feb 11 19:28:00 tegra-ubuntu kernel: tegra-carveouts tegra-carveouts.23: assigned reserved memory node iram-carveout
Feb 11 19:28:00 tegra-ubuntu kernel: nvmap_page_pool_init: Total RAM pages: 1020846
Feb 11 19:28:00 tegra-ubuntu kernel: nvmap_page_pool_init: nvmap page pool size: 127605 pages (498 MB)
Feb 11 19:28:00 tegra-ubuntu kernel: nvmap_background_zero_thread: PP zeroing thread starting.
Feb 11 19:28:00 tegra-ubuntu kernel: misc nvmap: created heap iram base 0x0000000040001000 size (252KiB)
Feb 11 19:28:00 tegra-ubuntu kernel: nvmap:inner cache maint threshold=2097152
Feb 11 19:28:00 tegra-ubuntu kernel: Could not add tegra-otg to power domain using device tree
Feb 11 19:28:00 tegra-ubuntu kernel: tegra-otg tegra-otg: otg transceiver registered
Feb 11 19:28:00 tegra-ubuntu kernel: thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
Feb 11 19:28:00 tegra-ubuntu kernel: thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
Feb 11 19:28:00 tegra-ubuntu kernel: thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
Feb 11 19:28:00 tegra-ubuntu kernel: thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
Feb 11 19:28:00 tegra-ubuntu kernel: thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
Feb 11 19:28:00 tegra-ubuntu kernel: thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tdiode_tegra
Feb 11 19:28:00 tegra-ubuntu kernel: thermal thermal_zone6: Registering thermal zone thermal_zone6 for type Tboard_tegra
Feb 11 19:28:00 tegra-ubuntu kernel: tegra21_plle_clk_enable: pll_e is already enabled
Feb 11 19:28:00 tegra-ubuntu kernel: t210_sata_uphy_pll_init: init sata uphy pll
Feb 11 19:28:00 tegra-ubuntu kernel: t210_sata_uphy_pll_init SATA uses SATA Lane
Feb 11 19:28:00 tegra-ubuntu kernel: tegra_xusb_padctl_phy_enable: init pex uphy pll
Feb 11 19:28:00 tegra-ubuntu kernel: tegra210-pmc-iopower pmc-iopower.29: Rail iopower-sys is having fixed voltage 1800000
Feb 11 19:28:00 tegra-ubuntu kernel: tegra210-pmc-iopower pmc-iopower.29: Rail iopower-uart is having fixed voltage 1800000
Feb 11 19:28:00 tegra-ubuntu kernel: tegra210-pmc-iopower pmc-iopower.29: Rail iopower-audio is having fixed voltage 1800000
Feb 11 19:28:00 tegra-ubuntu kernel: tegra210-pmc-iopower pmc-iopower.29: Rail iopower-cam is having fixed voltage 1800000
Feb 11 19:28:00 tegra-ubuntu kernel: tegra210-pmc-iopower pmc-iopower.29: Rail iopower-pex-ctrl is having fixed voltage 1800000
Feb 11 19:28:00 tegra-ubuntu kernel: tegra210-pmc-iopower pmc-iopower.29: Rail iopower-sdmmc1 is having voltages: 1800000:3300000
Feb 11 19:28:00 tegra-ubuntu kernel: tegra210-pmc-iopower pmc-iopower.29: Rail iopower-sdmmc3 is having fixed voltage 1800000
Feb 11 19:28:00 tegra-ubuntu kernel: tegra210-pmc-iopower pmc-iopower.29: Rail iopower-sdmmc4 is having fixed voltage 1800000
Feb 11 19:28:00 tegra-ubuntu kernel: tegra210-pmc-iopower pmc-iopower.29: Rail iopower-audio-hv is having fixed voltage 1800000
Feb 11 19:28:00 tegra-ubuntu kernel: tegra210-pmc-iopower pmc-iopower.29: Rail iopower-debug is having fixed voltage 1800000
Feb 11 19:28:00 tegra-ubuntu kernel: tegra210-pmc-iopower pmc-iopower.29: Rail iopower-dmic is having fixed voltage 1800000
Feb 11 19:28:00 tegra-ubuntu kernel: tegra210-pmc-iopower pmc-iopower.29: Rail iopower-gpio is having fixed voltage 1800000
Feb 11 19:28:00 tegra-ubuntu kernel: tegra210-pmc-iopower pmc-iopower.29: Rail iopower-spi is having fixed voltage 1800000
Feb 11 19:28:00 tegra-ubuntu kernel: tegra210-pmc-iopower pmc-iopower.29: Rail iopower-spi-hv is having fixed voltage 1800000
Feb 11 19:28:00 tegra-ubuntu kernel: tegra210-pmc-iopower pmc-iopower.29: Rail iopower-sdmmc2 is having fixed voltage 1800000
Feb 11 19:28:00 tegra-ubuntu kernel: tegra210-pmc-iopower pmc-iopower.29: Rail iopower-dp is having fixed voltage 1800000
Feb 11 19:28:00 tegra-ubuntu kernel: tegra210-pmc-iopower pmc-iopower.29: NO_IO_POWER setting 0x0
Feb 11 19:28:00 tegra-ubuntu kernel: NET: Registered protocol family 2
Feb 11 19:28:00 tegra-ubuntu kernel: TCP established hash table entries: 32768 (order: 7, 524288 bytes)
Feb 11 19:28:00 tegra-ubuntu kernel: TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
Feb 11 19:28:00 tegra-ubuntu kernel: TCP: Hash tables configured (established 32768 bind 32768)
Feb 11 19:28:00 tegra-ubuntu kernel: TCP: reno registered
Feb 11 19:28:00 tegra-ubuntu kernel: UDP hash table entries: 2048 (order: 4, 65536 bytes)
Feb 11 19:28:00 tegra-ubuntu kernel: UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
Feb 11 19:28:00 tegra-ubuntu kernel: RPC: Registered named UNIX socket transport module.
Feb 11 19:28:00 tegra-ubuntu kernel: RPC: Registered udp transport module.
Feb 11 19:28:00 tegra-ubuntu kernel: RPC: Registered tcp transport module.
Feb 11 19:28:00 tegra-ubuntu kernel: RPC: Registered tcp NFSv4.1 backchannel transport module.
Feb 11 19:28:00 tegra-ubuntu kernel: PCI: CLS 0 bytes, default 64
Feb 11 19:28:00 tegra-ubuntu kernel: tegra-fuse tegra-fuse: Fuse driver initialized succesfully
Feb 11 19:28:00 tegra-ubuntu kernel: Trying to unpack rootfs image as initramfs...
Feb 11 19:28:00 tegra-ubuntu kernel: Freeing initrd memory: 6740K (ffffffc003100000 - ffffffc003795000)
Feb 11 19:28:00 tegra-ubuntu kernel: host1x host1x: initialized
Feb 11 19:28:00 tegra-ubuntu kernel: NTFS driver 2.1.30 [Flags: R/O].
Feb 11 19:28:00 tegra-ubuntu kernel: fuse init (API version 7.22)
Feb 11 19:28:00 tegra-ubuntu kernel: msgmni has been set to 7988
Feb 11 19:28:00 tegra-ubuntu kernel: io scheduler noop registered (default)
Feb 11 19:28:00 tegra-ubuntu kernel: Tegra cpuquiet initialized: disabled
Feb 11 19:28:00 tegra-ubuntu kernel: tegra-pcie 1003000.pcie-controller: PCIE: Enable power rails
Feb 11 19:28:00 tegra-ubuntu kernel: tegra-pcie 1003000.pcie-controller: probing port 0, using 4 lanes and lane map as 0x14
Feb 11 19:28:00 tegra-ubuntu kernel: tegra-pcie 1003000.pcie-controller: probing port 1, using 1 lanes and lane map as 0x14
Feb 11 19:28:00 tegra-ubuntu kernel: tegra-pcie 1003000.pcie-controller: link 1 down, ignoring
Feb 11 19:28:00 tegra-ubuntu kernel: tegra-pcie 1003000.pcie-controller: PCI host bridge to bus 0000:00
Feb 11 19:28:00 tegra-ubuntu kernel: pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
Feb 11 19:28:00 tegra-ubuntu kernel: pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pref]
Feb 11 19:28:00 tegra-ubuntu kernel: pci_bus 0000:00: root bus resource [bus 00-ff]
Feb 11 19:28:00 tegra-ubuntu kernel: pci_bus 0000:00: root bus resource [io  0x1000-0xffff]
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:00:01.0: [10de:0fae] type 01 class 0x060400
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:00:01.0: PME# supported from D0 D1 D2 D3hot D3cold
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:00:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:01:00.0: [12d8:2608] type 01 class 0x060400
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:01:00.0: supports D1 D2
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:01:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:02:01.0: [12d8:2608] type 01 class 0x060400
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:02:01.0: supports D1 D2
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:02:01.0: PME# supported from D0 D1 D2 D3hot D3cold
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:02:02.0: [12d8:2608] type 01 class 0x060400
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:02:02.0: supports D1 D2
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:02:02.0: PME# supported from D0 D1 D2 D3hot D3cold
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:02:03.0: [12d8:2608] type 01 class 0x060400
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:02:03.0: supports D1 D2
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:02:03.0: PME# supported from D0 D1 D2 D3hot D3cold
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:02:04.0: [12d8:2608] type 01 class 0x060400
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:02:04.0: supports D1 D2
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:02:04.0: PME# supported from D0 D1 D2 D3hot D3cold
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:02:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:02:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:02:03.0: bridge configuration invalid ([bus 00-00]), reconfiguring
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:02:04.0: bridge configuration invalid ([bus 00-00]), reconfiguring
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:03:00.0: [1912:0015] type 00 class 0x0c0330
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:03:00.0: reg 10: [mem 0x00000000-0x00001fff 64bit]
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:03:00.0: PME# supported from D0 D3hot
Feb 11 19:28:00 tegra-ubuntu kernel: pci_bus 0000:03: busn_res: [bus 03-ff] end is updated to 03
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:04:00.0: [1912:0015] type 00 class 0x0c0330
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:04:00.0: reg 10: [mem 0x00000000-0x00001fff 64bit]
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:04:00.0: PME# supported from D0 D3hot
Feb 11 19:28:00 tegra-ubuntu kernel: pci_bus 0000:04: busn_res: [bus 04-ff] end is updated to 04
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:05:00.0: [1912:0015] type 00 class 0x0c0330
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:05:00.0: reg 10: [mem 0x00000000-0x00001fff 64bit]
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:05:00.0: PME# supported from D0 D3hot
Feb 11 19:28:00 tegra-ubuntu kernel: pci_bus 0000:05: busn_res: [bus 05-ff] end is updated to 05
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:06:00.0: [1912:0015] type 00 class 0x0c0330
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:06:00.0: reg 10: [mem 0x00000000-0x00001fff 64bit]
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:06:00.0: PME# supported from D0 D3hot
Feb 11 19:28:00 tegra-ubuntu kernel: pci_bus 0000:06: busn_res: [bus 06-ff] end is updated to 06
Feb 11 19:28:00 tegra-ubuntu kernel: pci_bus 0000:02: busn_res: [bus 02-ff] end is updated to 06
Feb 11 19:28:00 tegra-ubuntu kernel: pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 06
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:00:01.0: BAR 8: assigned [mem 0x13000000-0x137fffff]
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:00:01.0: BAR 9: assigned [mem 0x20000000-0x207fffff 64bit pref]
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:00:01.0: BAR 7: assigned [io  0x1000-0x4fff]
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:01:00.0: BAR 8: assigned [mem 0x13000000-0x137fffff]
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:01:00.0: BAR 9: assigned [mem 0x20000000-0x207fffff 64bit pref]
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:01:00.0: BAR 7: assigned [io  0x1000-0x4fff]
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:02:01.0: BAR 8: assigned [mem 0x13000000-0x131fffff]
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:02:01.0: BAR 9: assigned [mem 0x20000000-0x201fffff 64bit pref]
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:02:02.0: BAR 8: assigned [mem 0x13200000-0x133fffff]
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:02:02.0: BAR 9: assigned [mem 0x20200000-0x203fffff 64bit pref]
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:02:03.0: BAR 8: assigned [mem 0x13400000-0x135fffff]
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:02:03.0: BAR 9: assigned [mem 0x20400000-0x205fffff 64bit pref]
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:02:04.0: BAR 8: assigned [mem 0x13600000-0x137fffff]
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:02:04.0: BAR 9: assigned [mem 0x20600000-0x207fffff 64bit pref]
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:02:01.0: BAR 7: assigned [io  0x1000-0x1fff]
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:02:02.0: BAR 7: assigned [io  0x2000-0x2fff]
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:02:03.0: BAR 7: assigned [io  0x3000-0x3fff]
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:02:04.0: BAR 7: assigned [io  0x4000-0x4fff]
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:03:00.0: BAR 0: assigned [mem 0x13000000-0x13001fff 64bit]
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:02:01.0: PCI bridge to [bus 03]
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:02:01.0:   bridge window [io  0x1000-0x1fff]
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:02:01.0:   bridge window [mem 0x13000000-0x131fffff]
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:02:01.0:   bridge window [mem 0x20000000-0x201fffff 64bit pref]
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:04:00.0: BAR 0: assigned [mem 0x13200000-0x13201fff 64bit]
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:02:02.0: PCI bridge to [bus 04]
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:02:02.0:   bridge window [io  0x2000-0x2fff]
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:02:02.0:   bridge window [mem 0x13200000-0x133fffff]
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:02:02.0:   bridge window [mem 0x20200000-0x203fffff 64bit pref]
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:05:00.0: BAR 0: assigned [mem 0x13400000-0x13401fff 64bit]
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:02:03.0: PCI bridge to [bus 05]
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:02:03.0:   bridge window [io  0x3000-0x3fff]
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:02:03.0:   bridge window [mem 0x13400000-0x135fffff]
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:02:03.0:   bridge window [mem 0x20400000-0x205fffff 64bit pref]
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:06:00.0: BAR 0: assigned [mem 0x13600000-0x13601fff 64bit]
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:02:04.0: PCI bridge to [bus 06]
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:02:04.0:   bridge window [io  0x4000-0x4fff]
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:02:04.0:   bridge window [mem 0x13600000-0x137fffff]
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:02:04.0:   bridge window [mem 0x20600000-0x207fffff 64bit pref]
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:01:00.0: PCI bridge to [bus 02-06]
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:01:00.0:   bridge window [io  0x1000-0x4fff]
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:01:00.0:   bridge window [mem 0x13000000-0x137fffff]
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:01:00.0:   bridge window [mem 0x20000000-0x207fffff 64bit pref]
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:00:01.0: PCI bridge to [bus 01-06]
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:00:01.0:   bridge window [io  0x1000-0x4fff]
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:00:01.0:   bridge window [mem 0x13000000-0x137fffff]
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:00:01.0:   bridge window [mem 0x20000000-0x207fffff 64bit pref]
Feb 11 19:28:00 tegra-ubuntu kernel: PCI: enabling device 0000:00:01.0 (0140 -> 0143)
Feb 11 19:28:00 tegra-ubuntu kernel: PCI: enabling device 0000:01:00.0 (0140 -> 0143)
Feb 11 19:28:00 tegra-ubuntu kernel: PCI: enabling device 0000:02:01.0 (0140 -> 0143)
Feb 11 19:28:00 tegra-ubuntu kernel: PCI: enabling device 0000:02:02.0 (0140 -> 0143)
Feb 11 19:28:00 tegra-ubuntu kernel: PCI: enabling device 0000:02:03.0 (0140 -> 0143)
Feb 11 19:28:00 tegra-ubuntu kernel: PCI: enabling device 0000:02:04.0 (0140 -> 0143)
Feb 11 19:28:00 tegra-ubuntu kernel: pcieport 0000:00:01.0: Signaling PME through PCIe PME interrupt
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:02:01.0: Signaling PME through PCIe PME interrupt
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:03:00.0: Signaling PME through PCIe PME interrupt
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:02:02.0: Signaling PME through PCIe PME interrupt
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:04:00.0: Signaling PME through PCIe PME interrupt
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:02:03.0: Signaling PME through PCIe PME interrupt
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:05:00.0: Signaling PME through PCIe PME interrupt
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:02:04.0: Signaling PME through PCIe PME interrupt
Feb 11 19:28:00 tegra-ubuntu kernel: pci 0000:06:00.0: Signaling PME through PCIe PME interrupt
Feb 11 19:28:00 tegra-ubuntu kernel: pcie_pme 0000:00:01.0:pcie01: service driver pcie_pme loaded
Feb 11 19:28:00 tegra-ubuntu kernel: aer 0000:00:01.0:pcie02: service driver aer loaded
Feb 11 19:28:00 tegra-ubuntu kernel: PCI: enabling device 0000:03:00.0 (0140 -> 0142)
Feb 11 19:28:00 tegra-ubuntu kernel: PCI: enabling device 0000:04:00.0 (0140 -> 0142)
Feb 11 19:28:00 tegra-ubuntu kernel: PCI: enabling device 0000:05:00.0 (0140 -> 0142)
Feb 11 19:28:00 tegra-ubuntu kernel: PCI: enabling device 0000:06:00.0 (0140 -> 0142)
Feb 11 19:28:00 tegra-ubuntu kernel: tsec tsec: initialized
Feb 11 19:28:00 tegra-ubuntu kernel: tsec tsecb: initialized
Feb 11 19:28:00 tegra-ubuntu kernel: nvdec nvdec: initialized
Feb 11 19:28:00 tegra-ubuntu kernel: falcon vic03: initialized
Feb 11 19:28:00 tegra-ubuntu kernel: falcon msenc: initialized
Feb 11 19:28:00 tegra-ubuntu kernel: falcon nvjpg: initialized
Feb 11 19:28:00 tegra-ubuntu kernel: tegradc tegradc.1: Display dc.54240000 registered with id=0
Feb 11 19:28:00 tegra-ubuntu kernel: of_dc_parse_platform_data: DC OR node is connected to /host1x/sor1
Feb 11 19:28:00 tegra-ubuntu kernel: display board info: id 0x0, fab 0x0
Feb 11 19:28:00 tegra-ubuntu kernel: invalid panel compatible
Feb 11 19:28:00 tegra-ubuntu kernel: parse_tmds_config: No tmds-config node
Feb 11 19:28:00 tegra-ubuntu kernel: of_dc_parse_platform_data: could not find vrr-settings node
Feb 11 19:28:00 tegra-ubuntu kernel: of_dc_parse_platform_data: nvidia,hdmi-vrr-caps not present
Feb 11 19:28:00 tegra-ubuntu kernel: of_dc_parse_platform_data: could not find SD settings node
Feb 11 19:28:00 tegra-ubuntu kernel: of_dc_parse_platform_data: could not find cmu node
Feb 11 19:28:00 tegra-ubuntu kernel: of_dc_parse_platform_data: could not find cmu node for adobeRGB
Feb 11 19:28:00 tegra-ubuntu kernel: tegradc tegradc.1: DT parsed successfully
Feb 11 19:28:00 tegra-ubuntu kernel: gpio wake53 for gpio=225
Feb 11 19:28:00 tegra-ubuntu kernel: tegradc tegradc.1: probed
Feb 11 19:28:00 tegra-ubuntu kernel: Console: switching to colour frame buffer device 80x30
Feb 11 19:28:00 tegra-ubuntu kernel: tegradc tegradc.1: fb registered
Feb 11 19:28:00 tegra-ubuntu kernel: tegra_camera_platform tegra-camera-platform.45: tegra_camera_probe:camera_platform_driver probe
Feb 11 19:28:00 tegra-ubuntu kernel: misc tegra_camera_ctrl: tegra_camera_isomgr_register camera's max_iso_bw 3600000
Feb 11 19:28:00 tegra-ubuntu kernel: tegra-apbdma tegra-apbdma: Tegra20 APB DMA driver register 32 channels
Feb 11 19:28:00 tegra-ubuntu kernel: tegra-adma tegra210-adma: Tegra210 ADMA driver register 10 channels
Feb 11 19:28:00 tegra-ubuntu kernel: Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
Feb 11 19:28:00 tegra-ubuntu kernel: of_serial 70006000.serial: RX periodic polling enabled
Feb 11 19:28:00 tegra-ubuntu kernel: 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 68) is a Tegra
Feb 11 19:28:00 tegra-ubuntu kernel: console [ttyS0] enabled, bootconsole disabled
Feb 11 19:28:00 tegra-ubuntu kernel: 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 69) is a SERIAL_TEGRA
Feb 11 19:28:00 tegra-ubuntu kernel: 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 78) is a SERIAL_TEGRA
Feb 11 19:28:00 tegra-ubuntu kernel: serial-tegra 70006300.serial: RX in PIO mode
Feb 11 19:28:00 tegra-ubuntu kernel: 70006300.serial: ttyTHS3 at MMIO 0x70006300 (irq = 122) is a SERIAL_TEGRA
Feb 11 19:28:00 tegra-ubuntu kernel:  (null): coherent DMA mask is unset
Feb 11 19:28:00 tegra-ubuntu kernel: gk20a gpu.0: failed to allocate secure buffer -12
Feb 11 19:28:00 tegra-ubuntu kernel: brd: module loaded
Feb 11 19:28:00 tegra-ubuntu kernel: loop: module loaded
Feb 11 19:28:00 tegra-ubuntu kernel: zram: Created 1 device(s) ...
Feb 11 19:28:00 tegra-ubuntu kernel: nct1008_nct72 0-004c: find device tree node, parsing dt
Feb 11 19:28:00 tegra-ubuntu kernel: nct1008_nct72 0-004c: starting parse dt
Feb 11 19:28:00 tegra-ubuntu kernel: nct1008_nct72 0-004c: success parsing dt
Feb 11 19:28:00 tegra-ubuntu kernel: nct1008_nct72 0-004c: success in enabling rail vdd_nct72
Feb 11 19:28:00 tegra-ubuntu kernel: NCT72: Enabled overheat logging at 104.00C
Feb 11 19:28:00 tegra-ubuntu kernel: nct1008_nct72 0-004c: nct1008_probe: initialized
Feb 11 19:28:00 tegra-ubuntu kernel: THERMAL EST start of therm_fan_est_probe.
Feb 11 19:28:00 tegra-ubuntu kernel: THERMAL EST: found 2 subdevs
Feb 11 19:28:00 tegra-ubuntu kernel: THERMAL EST name: thermal-fan-est.
Feb 11 19:28:00 tegra-ubuntu kernel: THERMAL EST num_resources: 0
Feb 11 19:28:00 tegra-ubuntu kernel: [THERMAL EST subdev 0]
Feb 11 19:28:00 tegra-ubuntu kernel: THERMAL EST subdev name: CPU-therm
Feb 11 19:28:00 tegra-ubuntu kernel: THERMAL EST index 0 coeffs 50
Feb 11 19:28:00 tegra-ubuntu kernel: THERMAL EST index 1 coeffs 0
Feb 11 19:28:00 tegra-ubuntu kernel: THERMAL EST index 2 coeffs 0
Feb 11 19:28:00 tegra-ubuntu kernel: THERMAL EST index 3 coeffs 0
Feb 11 19:28:00 tegra-ubuntu kernel: THERMAL EST index 4 coeffs 0
Feb 11 19:28:00 tegra-ubuntu kernel: THERMAL EST index 5 coeffs 0
Feb 11 19:28:00 tegra-ubuntu kernel: THERMAL EST index 6 coeffs 0
Feb 11 19:28:00 tegra-ubuntu kernel: THERMAL EST index 7 coeffs 0
Feb 11 19:28:00 tegra-ubuntu kernel: THERMAL EST index 8 coeffs 0
Feb 11 19:28:00 tegra-ubuntu kernel: THERMAL EST index 9 coeffs 0
Feb 11 19:28:00 tegra-ubuntu kernel: [THERMAL EST subdev 1]
Feb 11 19:28:00 tegra-ubuntu kernel: THERMAL EST subdev name: GPU-therm
Feb 11 19:28:00 tegra-ubuntu kernel: THERMAL EST index 0: trip_temp 0, hyst 0
Feb 11 19:28:00 tegra-ubuntu kernel: THERMAL EST index 1: trip_temp 51000, hyst 15000
Feb 11 19:28:00 tegra-ubuntu kernel: THERMAL EST index 2: trip_temp 61000, hyst 9000
Feb 11 19:28:00 tegra-ubuntu kernel: THERMAL EST index 3: trip_temp 71000, hyst 9000
Feb 11 19:28:00 tegra-ubuntu kernel: THERMAL EST index 4: trip_temp 82000, hyst 10000
Feb 11 19:28:00 tegra-ubuntu kernel: THERMAL EST index 5: trip_temp 140000, hyst 0
Feb 11 19:28:00 tegra-ubuntu kernel: THERMAL EST index 6: trip_temp 150000, hyst 0
Feb 11 19:28:00 tegra-ubuntu kernel: THERMAL EST index 7: trip_temp 160000, hyst 0
Feb 11 19:28:00 tegra-ubuntu kernel: THERMAL EST index 8: trip_temp 170000, hyst 0
Feb 11 19:28:00 tegra-ubuntu kernel: THERMAL EST index 9: trip_temp 180000, hyst 0
Feb 11 19:28:00 tegra-ubuntu kernel: THERMAL EST index 0: trip_temps_hyst 0
Feb 11 19:28:00 tegra-ubuntu kernel: THERMAL EST index 1: trip_temps_hyst 36000
Feb 11 19:28:00 tegra-ubuntu kernel: THERMAL EST index 2: trip_temps_hyst 51000
Feb 11 19:28:00 tegra-ubuntu kernel: THERMAL EST index 3: trip_temps_hyst 52000
Feb 11 19:28:00 tegra-ubuntu kernel: THERMAL EST index 4: trip_temps_hyst 61000
Feb 11 19:28:00 tegra-ubuntu kernel: THERMAL EST index 5: trip_temps_hyst 62000
Feb 11 19:28:00 tegra-ubuntu kernel: THERMAL EST index 6: trip_temps_hyst 71000
Feb 11 19:28:00 tegra-ubuntu kernel: THERMAL EST index 7: trip_temps_hyst 72000
Feb 11 19:28:00 tegra-ubuntu kernel: THERMAL EST index 8: trip_temps_hyst 82000
Feb 11 19:28:00 tegra-ubuntu kernel: THERMAL EST index 9: trip_temps_hyst 140000
Feb 11 19:28:00 tegra-ubuntu kernel: THERMAL EST index 10: trip_temps_hyst 140000
Feb 11 19:28:00 tegra-ubuntu kernel: THERMAL EST index 11: trip_temps_hyst 150000
Feb 11 19:28:00 tegra-ubuntu kernel: THERMAL EST index 12: trip_temps_hyst 150000
Feb 11 19:28:00 tegra-ubuntu kernel: THERMAL EST index 13: trip_temps_hyst 160000
Feb 11 19:28:00 tegra-ubuntu kernel: THERMAL EST index 14: trip_temps_hyst 160000
Feb 11 19:28:00 tegra-ubuntu kernel: THERMAL EST index 15: trip_temps_hyst 170000
Feb 11 19:28:00 tegra-ubuntu kernel: THERMAL EST index 16: trip_temps_hyst 170000
Feb 11 19:28:00 tegra-ubuntu kernel: THERMAL EST index 17: trip_temps_hyst 180000
Feb 11 19:28:00 tegra-ubuntu kernel: THERMAL EST index 18: trip_temps_hyst 180000
Feb 11 19:28:00 tegra-ubuntu kernel: THERMAL EST index 19: trip_temps_hyst 0
Feb 11 19:28:00 tegra-ubuntu kernel: THERMAL EST index 20: trip_temps_hyst 0
Feb 11 19:28:00 tegra-ubuntu kernel: THERMAL EST init dev[0] temp hist to 25000
Feb 11 19:28:00 tegra-ubuntu kernel: THERMAL EST init dev[1] temp hist to 25000
Feb 11 19:28:00 tegra-ubuntu kernel: THERMAL EST cdev_type: pwm-fan.
Feb 11 19:28:00 tegra-ubuntu kernel: THERMAL EST governor name: pid_thermal_gov
Feb 11 19:28:00 tegra-ubuntu kernel: thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est.46
Feb 11 19:28:00 tegra-ubuntu kernel: THERMAL EST: thz register success.
Feb 11 19:28:00 tegra-ubuntu kernel: THERMAL EST: end of probe, return err: 0
Feb 11 19:28:00 tegra-ubuntu kernel: tegra_profiler: Branch: Dev
Feb 11 19:28:00 tegra-ubuntu kernel: tegra_profiler: Version: 1.107
Feb 11 19:28:00 tegra-ubuntu kernel: tegra_profiler: Samples version: 36
Feb 11 19:28:00 tegra-ubuntu kernel: tegra_profiler: IO version: 20
Feb 11 19:28:00 tegra-ubuntu kernel: armv8_pmu: imp: 0x41, idcode: 0x1
Feb 11 19:28:00 tegra-ubuntu kernel: armv8_pmu: arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
Feb 11 19:28:00 tegra-ubuntu kernel: tegra_profiler: auth: init
Feb 11 19:28:00 tegra-ubuntu kernel: GPS: mt3332_gps_mod_init: platform_driver_register ret = 0
Feb 11 19:28:00 tegra-ubuntu kernel: tegra-sata tegra-sata.0: version 1.0
Feb 11 19:28:00 tegra-ubuntu kernel: t210_sata_uphy_pll_init: sata uphy already enabled
Feb 11 19:28:00 tegra-ubuntu kernel: tegra-sata tegra-sata.0: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl TEGRA-SATA mode
Feb 11 19:28:00 tegra-ubuntu kernel: tegra-sata tegra-sata.0: flags: 64bit ncq sntf pm led pmp pio slum part sadm apst
Feb 11 19:28:00 tegra-ubuntu kernel: Rounding down aligned max_sectors from 4294967295 to 4294967288
Feb 11 19:28:00 tegra-ubuntu kernel: spi-tegra114 7000d400.spi: /spi@7000d400/prod-settings has no reg property
Feb 11 19:28:00 tegra-ubuntu kernel: spi-tegra114 7000d400.spi: Static pin configuration used
Feb 11 19:28:00 tegra-ubuntu kernel: spi_master spi0: cannot find modalias for /spi@7000d400/prod-settings
Feb 11 19:28:00 tegra-ubuntu kernel: spi-tegra114 7000da00.spi: /spi@7000da00/prod-settings has no reg property
Feb 11 19:28:00 tegra-ubuntu kernel: spi-tegra114 7000da00.spi: Static pin configuration used
Feb 11 19:28:00 tegra-ubuntu kernel: spi_master spi3: cannot find modalias for /spi@7000da00/prod-settings
Feb 11 19:28:00 tegra-ubuntu kernel: tun: Universal TUN/TAP device driver, 1.6
Feb 11 19:28:00 tegra-ubuntu kernel: tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
Feb 11 19:28:00 tegra-ubuntu kernel: e1000e: Intel(R) PRO/1000 Network Driver - 2.3.2-k
Feb 11 19:28:00 tegra-ubuntu kernel: e1000e: Copyright(c) 1999 - 2013 Intel Corporation.
Feb 11 19:28:00 tegra-ubuntu kernel: PPP generic driver version 2.4.2
Feb 11 19:28:00 tegra-ubuntu kernel: PPP BSD Compression module registered
Feb 11 19:28:00 tegra-ubuntu kernel: PPP Deflate Compression module registered
Feb 11 19:28:00 tegra-ubuntu kernel: PPP MPPE Compression module registered
Feb 11 19:28:00 tegra-ubuntu kernel: NET: Registered protocol family 24
Feb 11 19:28:00 tegra-ubuntu kernel: usbcore: registered new interface driver r8152
Feb 11 19:28:00 tegra-ubuntu kernel: usbcore: registered new interface driver asix
Feb 11 19:28:00 tegra-ubuntu kernel: usbcore: registered new interface driver ax88179_178a
Feb 11 19:28:00 tegra-ubuntu kernel: usbcore: registered new interface driver cdc_ether
Feb 11 19:28:00 tegra-ubuntu kernel: usbcore: registered new interface driver smsc95xx
Feb 11 19:28:00 tegra-ubuntu kernel: usbcore: registered new interface driver net1080
Feb 11 19:28:00 tegra-ubuntu kernel: usbcore: registered new interface driver cdc_subset
Feb 11 19:28:00 tegra-ubuntu kernel: usbcore: registered new interface driver zaurus
Feb 11 19:28:00 tegra-ubuntu kernel: usbcore: registered new interface driver cdc_ncm
Feb 11 19:28:00 tegra-ubuntu kernel: ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Feb 11 19:28:00 tegra-ubuntu kernel: ehci-pci: EHCI PCI platform driver
Feb 11 19:28:00 tegra-ubuntu kernel: xhci_hcd 0000:03:00.0: xHCI Host Controller
Feb 11 19:28:00 tegra-ubuntu kernel: xhci_hcd 0000:03:00.0: new USB bus registered, assigned bus number 1
Feb 11 19:28:00 tegra-ubuntu kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
Feb 11 19:28:00 tegra-ubuntu kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Feb 11 19:28:00 tegra-ubuntu kernel: smmu_dump_pagetable(): fault_address=0x00000000fdd04000 pa=0xffffffffffffffff bytes=ffffffffffffffff #pte=0 in L2
Feb 11 19:28:00 tegra-ubuntu kernel: mc-err: (0) csr_afir: EMEM decode error on PDE or PTE entry
Feb 11 19:28:00 tegra-ubuntu kernel: mc-err:   status = 0x6000000e; addr = 0xfdd04000
Feb 11 19:28:00 tegra-ubuntu kernel: mc-err:   secure: no, access-type: read, SMMU fault: nr-nw-s
Feb 11 19:28:00 tegra-ubuntu kernel: usb usb1: Product: xHCI Host Controller
Feb 11 19:28:00 tegra-ubuntu kernel: usb usb1: Manufacturer: Linux 3.10.96-tegra xhci_hcd
Feb 11 19:28:00 tegra-ubuntu kernel: usb usb1: SerialNumber: 0000:03:00.0
Feb 11 19:28:00 tegra-ubuntu kernel: xHCI xhci_add_endpoint called for root hub
Feb 11 19:28:00 tegra-ubuntu kernel: xHCI xhci_check_bandwidth called for root hub
Feb 11 19:28:00 tegra-ubuntu kernel: hub 1-0:1.0: USB hub found
Feb 11 19:28:00 tegra-ubuntu kernel: hub 1-0:1.0: 1 port detected
Feb 11 19:28:00 tegra-ubuntu kernel: xhci_hcd 0000:03:00.0: new USB bus registered, assigned bus number 2
Feb 11 19:28:00 tegra-ubuntu kernel: usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
Feb 11 19:28:00 tegra-ubuntu kernel: usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Feb 11 19:28:00 tegra-ubuntu kernel: usb usb2: Product: xHCI Host Controller
Feb 11 19:28:00 tegra-ubuntu kernel: usb usb2: Manufacturer: Linux 3.10.96-tegra xhci_hcd
Feb 11 19:28:00 tegra-ubuntu kernel: usb usb2: SerialNumber: 0000:03:00.0
Feb 11 19:28:00 tegra-ubuntu kernel: hub 2-0:1.0: USB hub found
Feb 11 19:28:00 tegra-ubuntu kernel: hub 2-0:1.0: 1 port detected
Feb 11 19:28:00 tegra-ubuntu kernel: xhci_hcd 0000:04:00.0: xHCI Host Controller
Feb 11 19:28:00 tegra-ubuntu kernel: xhci_hcd 0000:04:00.0: new USB bus registered, assigned bus number 3
Feb 11 19:28:00 tegra-ubuntu kernel: usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
Feb 11 19:28:00 tegra-ubuntu kernel: smmu_dump_pagetable(): fault_address=0x00000000fdd0e000 pa=0xffffffffffffffff bytes=ffffffffffffffff #pte=0 in L2
Feb 11 19:28:00 tegra-ubuntu kernel: usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Feb 11 19:28:00 tegra-ubuntu kernel: usb usb3: Product: xHCI Host Controller
Feb 11 19:28:00 tegra-ubuntu kernel: usb usb3: Manufacturer: Linux 3.10.96-tegra xhci_hcd
Feb 11 19:28:00 tegra-ubuntu kernel: usb usb3: SerialNumber: 0000:04:00.0
Feb 11 19:28:00 tegra-ubuntu kernel: hub 3-0:1.0: USB hub found
Feb 11 19:28:00 tegra-ubuntu kernel: hub 3-0:1.0: 1 port detected
Feb 11 19:28:00 tegra-ubuntu kernel: xhci_hcd 0000:04:00.0: new USB bus registered, assigned bus number 4
Feb 11 19:28:00 tegra-ubuntu kernel: usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
Feb 11 19:28:00 tegra-ubuntu kernel: usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Feb 11 19:28:00 tegra-ubuntu kernel: usb usb4: Product: xHCI Host Controller
Feb 11 19:28:00 tegra-ubuntu kernel: usb usb4: Manufacturer: Linux 3.10.96-tegra xhci_hcd
Feb 11 19:28:00 tegra-ubuntu kernel: usb usb4: SerialNumber: 0000:04:00.0
Feb 11 19:28:00 tegra-ubuntu kernel: hub 4-0:1.0: USB hub found
Feb 11 19:28:00 tegra-ubuntu kernel: hub 4-0:1.0: 1 port detected
Feb 11 19:28:00 tegra-ubuntu kernel: mc-err:   status = 0x6000000e; addr = 0xfdd0e000
Feb 11 19:28:00 tegra-ubuntu kernel: xhci_hcd 0000:05:00.0: xHCI Host Controller
Feb 11 19:28:00 tegra-ubuntu kernel: xhci_hcd 0000:05:00.0: new USB bus registered, assigned bus number 5
Feb 11 19:28:00 tegra-ubuntu kernel: usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
Feb 11 19:28:00 tegra-ubuntu kernel: smmu_dump_pagetable(): fault_address=0x00000000fdd18000 pa=0xffffffffffffffff bytes=ffffffffffffffff #pte=0 in L2
Feb 11 19:28:00 tegra-ubuntu kernel: mc-err:   status = 0x6000000e; addr = 0xfdd18000
Feb 11 19:28:00 tegra-ubuntu kernel: usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Feb 11 19:28:00 tegra-ubuntu kernel: usb usb5: Product: xHCI Host Controller
Feb 11 19:28:00 tegra-ubuntu kernel: usb usb5: Manufacturer: Linux 3.10.96-tegra xhci_hcd
Feb 11 19:28:00 tegra-ubuntu kernel: usb usb5: SerialNumber: 0000:05:00.0
Feb 11 19:28:00 tegra-ubuntu kernel: hub 5-0:1.0: USB hub found
Feb 11 19:28:00 tegra-ubuntu kernel: hub 5-0:1.0: 1 port detected
Feb 11 19:28:00 tegra-ubuntu kernel: xhci_hcd 0000:05:00.0: new USB bus registered, assigned bus number 6
Feb 11 19:28:00 tegra-ubuntu kernel: usb usb6: New USB device found, idVendor=1d6b, idProduct=0003
Feb 11 19:28:00 tegra-ubuntu kernel: usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Feb 11 19:28:00 tegra-ubuntu kernel: usb usb6: Product: xHCI Host Controller
Feb 11 19:28:00 tegra-ubuntu kernel: usb usb6: Manufacturer: Linux 3.10.96-tegra xhci_hcd
Feb 11 19:28:00 tegra-ubuntu kernel: usb usb6: SerialNumber: 0000:05:00.0
Feb 11 19:28:00 tegra-ubuntu kernel: hub 6-0:1.0: USB hub found
Feb 11 19:28:00 tegra-ubuntu kernel: hub 6-0:1.0: 1 port detected
Feb 11 19:28:00 tegra-ubuntu kernel: xhci_hcd 0000:06:00.0: xHCI Host Controller
Feb 11 19:28:00 tegra-ubuntu kernel: xhci_hcd 0000:06:00.0: new USB bus registered, assigned bus number 7
Feb 11 19:28:00 tegra-ubuntu kernel: usb usb7: New USB device found, idVendor=1d6b, idProduct=0002
Feb 11 19:28:00 tegra-ubuntu kernel: smmu_dump_pagetable(): fault_address=0x00000000fdd22000 pa=0xffffffffffffffff bytes=ffffffffffffffff #pte=0 in L2
/var/log/kern.log from 14.04 (OK)
Apr 25 07:35:29 tegra-ubuntu kernel: [ 1653.304837] serial-tegra 70006200.serial: Got Break
Apr 25 07:46:32 tegra-ubuntu kernel: [ 2316.778626] serial-tegra 70006200.serial: Got Break
Apr 25 07:54:15 tegra-ubuntu kernel: [ 2779.949026] serial-tegra 70006200.serial: Got Break
Apr 25 07:54:15 tegra-ubuntu kernel: [ 2779.949162] serial-tegra 70006200.serial: Got Receive Fifo errors
Apr 25 07:59:27 tegra-ubuntu kernel: [ 3091.306485] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Apr 25 07:59:27 tegra-ubuntu kernel: [ 3091.884166] nf_conntrack: automatic helper assignment is deprecated and it will be removed soon. Use the iptables CT target to attach helpers instead.
Apr 25 08:01:51 tegra-ubuntu kernel: [ 3233.656244] serial-tegra 70006200.serial: Got Break
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.234798] compiz invoked oom-killer: gfp_mask=0x201d2, order=0, oom_score_adj=0
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.234808] CPU: 3 PID: 1974 Comm: compiz Not tainted 3.10.96-tegra #1
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.234813] Call trace:
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.234823] [<ffffffc000089d28>] dump_backtrace+0x0/0xf4
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.234829] [<ffffffc00008a028>] show_stack+0x14/0x1c
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.234836] [<ffffffc0002f76dc>] dump_stack+0x20/0x28
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.234842] [<ffffffc000154714>] dump_header+0x6c/0xa8
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.234848] [<ffffffc000154b34>] oom_kill_process+0xac/0x3ac
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.234853] [<ffffffc000155234>] out_of_memory+0x1b8/0x1f0
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.234859] [<ffffffc000159c30>] __alloc_pages_nodemask+0x6e4/0x968
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.234865] [<ffffffc0001512a8>] page_cache_read+0x5c/0xf0
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.234870] [<ffffffc000153910>] filemap_fault+0x1b4/0x274
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.234875] [<ffffffc0001739d0>] __do_fault+0xc0/0x534
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.234880] [<ffffffc000173e80>] do_linear_fault+0x3c/0x44
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.234885] [<ffffffc0001771f8>] handle_pte_fault+0x60/0x1f4
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.234890] [<ffffffc00017816c>] __handle_mm_fault+0xdc/0x114
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.234895] [<ffffffc00017822c>] handle_mm_fault+0x88/0x98
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.234901] [<ffffffc00009a558>] __do_page_fault+0x60/0xa0
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.234906] [<ffffffc00009aa20>] do_page_fault+0x16c/0x3a8
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.234911] [<ffffffc000081218>] do_mem_abort+0x3c/0x98
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.234916] Exception stack(0xffffffc0df14fe30 to 0xffffffc0df14ff50)
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.234922] fe20:                                     00000000 00000000 03a12820 00000000
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.234928] fe40: ffffffff ffffffff 92c93230 0000007f ffffffff ffffffff 9241d868 0000007f
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.234934] fe60: 80000000 00000000 df14fd20 ffffffc0 df14fe90 ffffffc0 000860fc ffffffc0
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.234939] fe80: dfa5d080 ffffffc0 dfa5d5c0 ffffffc0 df14feb0 ffffffc0 000897f8 ffffffc0
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.234945] fea0: 00000008 00000000 00000000 00000000 ee471c60 0000007f 00085470 ffffffc0
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.234951] fec0: 03a12848 00000000 00000001 00000000 03a12820 00000000 00000000 00000000
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.234957] fee0: 00000001 00000000 00000000 00000000 ee471bf8 0000007f 00000000 00000000
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.234962] ff00: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.234967] ff20: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.234972] ff40: 00000000 00000000 a4c125a0 0000007f
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.234976] Mem-Info:
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.234981] DMA32 per-cpu:
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.234985] CPU    0: hi:  186, btch:  31 usd:   0
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.234990] CPU    1: hi:  186, btch:  31 usd: 174
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.234994] CPU    2: hi:  186, btch:  31 usd:  14
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.234998] CPU    3: hi:  186, btch:  31 usd:  30
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.235002] Normal per-cpu:
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.235006] CPU    0: hi:  186, btch:  31 usd:   6
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.235010] CPU    1: hi:  186, btch:  31 usd: 154
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.235015] CPU    2: hi:  186, btch:  31 usd:  30
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.235019] CPU    3: hi:  186, btch:  31 usd:   2
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.235026] active_anon:98478 inactive_anon:2370 isolated_anon:0
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.235026]  active_file:458 inactive_file:1499 isolated_file:0
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.235026]  unevictable:8 dirty:8 writeback:0 unstable:0
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.235026]  free:78441 slab_reclaimable:4703 slab_unreclaimable:10217
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.235026]  mapped:2758 shmem:2638 pagetables:1854 bounce:0
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.235026]  free_cma:74544
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.235041] DMA32 free:309356kB min:3092kB low:3864kB high:4636kB active_anon:56612kB inactive_anon:12kB active_file:672kB inactive_file:2528kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:1933312kB managed:1458564kB mlocked:0kB dirty:32kB writeback:0kB mapped:700kB shmem:24kB slab_reclaimable:1004kB slab_unreclaimable:2304kB kernel_stack:144kB pagetables:292kB unstable:0kB bounce:0kB free_cma:298176kB writeback_tmp:0kB pages_scanned:4169 all_unreclaimable? yes
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.235045] lowmem_reserve[]: 0 2048 2048
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.235062] Normal free:4408kB min:4444kB low:5552kB high:6664kB active_anon:337300kB inactive_anon:9468kB active_file:1160kB inactive_file:3468kB unevictable:32kB isolated(anon):0kB isolated(file):0kB present:2097152kB managed:2097152kB mlocked:32kB dirty:0kB writeback:0kB mapped:10332kB shmem:10528kB slab_reclaimable:17808kB slab_unreclaimable:38564kB kernel_stack:6112kB pagetables:7124kB unstable:0kB bounce:0kB free_cma:0kB writeback_tmp:0kB pages_scanned:6866 all_unreclaimable? yes
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.235066] lowmem_reserve[]: 0 0 0
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.235076] DMA32: 100*4kB (UEMC) 97*8kB (UEMC) 44*16kB (UEMC) 82*32kB (UEMC) 129*64kB (UEMC) 161*128kB (UEMC) 79*256kB (UC) 32*512kB (C) 10*1024kB (C) 12*2048kB (C) 50*4096kB (RC) = 309592kB
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.235125] Normal: 218*4kB (EMR) 4*8kB (R) 0*16kB 4*32kB (R) 1*64kB (R) 1*128kB (R) 0*256kB 0*512kB 1*1024kB (R) 1*2048kB (R) 0*4096kB = 4296kB
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.235166] 4766 total pagecache pages
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.259749] 1007616 pages RAM
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.259756] 21282 pages reserved
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.259760] 796174 pages shared
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.259764] 896653 pages non-shared
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.259768] [ pid ]   uid  tgid total_vm      rss nr_ptes swapents oom_score_adj name
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.259788] [  282]     0   282      962      289       6        0             0 upstart-udev-br
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.259794] [  296]     0   296     2872      268       7        0         -1000 systemd-udevd
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.259800] [  310]   103   310     1435      397       6        0             0 dbus-daemon
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.259805] [  406]     0   406     1098       74       5        0             0 bluetoothd
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.259810] [  423]     0   423     1266      105       5        0             0 systemd-logind
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.259816] [  463]   101   463    56324      183      10        0             0 rsyslogd
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.259821] [  472]   112   472      932      137       5        0             0 avahi-daemon
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.259827] [  474]   112   474      899       60       5        0             0 avahi-daemon
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.259833] [  590]     0   590     2514      233       8        0             0 cups-browsed
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.259839] [  682]     0   682     8717      463      16        0             0 nvcamera-daemon
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.259844] [  696]     0   696    58365      287      14        0             0 ModemManager
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.259849] [  768]     0   768    62218      426      17        0             0 NetworkManager
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.259854] [  774]     0   774     1316       46       5        0             0 getty
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.259859] [  777]     0   777     1316       45       5        0             0 getty
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.259865] [  782]     0   782     1316       46       5        0             0 getty
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.259869] [  783]     0   783     1316       45       5        0             0 getty
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.259874] [  786]     0   786     1316       45       5        0             0 getty
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.259879] [  815]     0   815     2074      164       7        0         -1000 sshd
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.259885] [  827]     0   827      808       62       5        0             0 cron
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.259890] [  829]     0   829    57265      265      13        0             0 lightdm
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.259895] [  832]   107   832     1549       81       5        0             0 kerneloops
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.259900] [  842]     0   842    57630      552      12        0             0 polkitd
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.259905] [  849]   110   849    62312      351      20        0             0 whoopsie
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.259910] [  927]     0   927   852097     7494      52        0             0 Xorg
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.259915] [  935]     0   935    57769      386      14        0             0 accounts-daemon
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.259921] [  950]     0   950     1316       45       5        0             0 getty
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.259926] [  952]     0   952     1529      143       6        0             0 login
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.259931] [ 1028]  1000  1028     1658      160       5        0             0 bash
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.259936] [ 1059]     0  1059     1712      138       5        0             0 wpa_supplicant
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.259942] [ 1158]     0  1158    20969      265       9        0             0 lightdm
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.259947] [ 1187]     0  1187    58350      281      15        0             0 upowerd
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.259952] [ 1240]   108  1240    37565       57       7        0             0 rtkit-daemon
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.259958] [ 1316]     0  1316      680      106       4        0             0 upstart-socket-
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.259963] [ 1332]     0  1332     1058      475       5        0             0 upstart-file-br
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.259969] [ 1478]   114  1478    58065      383      15        0             0 colord
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.259975] [ 1583]  1000  1583    43965      188      15        0             0 gnome-keyring-d
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.259980] [ 1587]  1000  1587     1839      259       6        0             0 init
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.259985] [ 1654]  1000  1654      924       79       6        0             0 ssh-agent
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.259991] [ 1659]  1000  1659     1627      425       6        0             0 dbus-daemon
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.259996] [ 1667]  1000  1667     1358       58       6        0             0 upstart-event-b
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260001] [ 1670]  1000  1670    10198      155      14        0             0 window-stack-br
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260006] [ 1682]  1000  1682    86106     1363      30        0             0 bamfdaemon
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260011] [ 1686]  1000  1686     1360       50       5        0             0 upstart-dbus-br
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260016] [ 1687]  1000  1687     1485       72       6        0             0 upstart-file-br
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260021] [ 1688]  1000  1688     1360       57       4        0             0 upstart-dbus-br
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260026] [ 1690]  1000  1690    75656      138      15        0             0 at-spi-bus-laun
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260031] [ 1695]  1000  1695    76761      479      14        0             0 ibus-daemon
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260036] [ 1698]  1000  1698     1193      162       5        0             0 dbus-daemon
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260041] [ 1708]  1000  1708    20506      153       7        0             0 at-spi2-registr
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260046] [ 1717]  1000  1717    39382      171      11        0             0 gvfsd
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260051] [ 1724]  1000  1724   119855     2367      35        0             0 unity-settings-
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260056] [ 1725]  1000  1725    57954      165      13        0             0 ibus-dconf
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260062] [ 1727]  1000  1727    75696      155      13        0             0 gvfsd-fuse
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260067] [ 1730]  1000  1730    68278     1183      28        0             0 ibus-ui-gtk3
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260072] [ 1732]  1000  1732   118312     2708      52        0             0 hud-service
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260077] [ 1745]  1000  1745    61546      420      21        0             0 ibus-x11
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260082] [ 1749]  1000  1749   136661      882      32        0             0 gnome-session
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260087] [ 1755]  1000  1755   107991     1970      34        0             0 unity-panel-ser
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260092] [ 1806]  1000  1806    89201     1296      32        0             0 indicator-keybo
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260289] [ 1808]  1000  1808    76012      119      14        0             0 indicator-messa
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260295] [ 1809]  1000  1809    57649      124      13        0             0 indicator-bluet
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260300] [ 1810]  1000  1810    57867      161      14        0             0 indicator-power
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260305] [ 1812]  1000  1812   256561      643      39        0             0 indicator-datet
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260310] [ 1813]  1000  1813    39520      203      11        0             0 ibus-engine-sim
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260316] [ 1817]  1000  1817   113363     1098      24        0             0 indicator-sound
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260320] [ 1823]  1000  1823    63474      908      25        0             0 indicator-print
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260326] [ 1828]  1000  1828   213700      414      27        0             0 indicator-sessi
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260331] [ 1832]  1000  1832    41987      288      15        0             0 indicator-appli
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260336] [ 1867]  1000  1867   220875      723      40        0             0 evolution-sourc
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260341] [ 1877]  1000  1877    58885      808      20        0             0 pulseaudio
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260346] [ 1880]  1000  1880    38366      178       9        0             0 dconf-service
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260351] [ 1940]  1000  1940    50575     1315      28        0             0 notify-osd
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260356] [ 1962]  1000  1962   200491     9057      56        0             0 evolution-calen
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260361] [ 1974]  1000  1974   255091    16104     117        0             0 compiz
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260366] [ 1997]  1000  1997    62125      731      22        0             0 unity-fallback-
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260371] [ 2001]  1000  2001    43773      735      19        0             0 polkit-gnome-au
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260376] [ 2004]  1000  2004    76719     1400      35        0             0 nm-applet
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260382] [ 2007]  1000  2007   295548    21998     100        0             0 nautilus
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260387] [ 2038]  1000  2038    60507      613      15        0             0 gvfs-udisks2-vo
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260392] [ 2045]     0  2045    78289      581      16        0             0 udisksd
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260397] [ 2084]  1000  2084     2727      370       8        0             0 gconfd-2
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260402] [ 2102]  1000  2102    39315      161      11        0             0 gvfs-mtp-volume
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260408] [ 2110]  1000  2110    58568      167      14        0             0 gvfs-afc-volume
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260413] [ 2115]  1000  2115    39782      223      11        0             0 gvfs-gphoto2-vo
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260420] [ 2124]  1000  2124    76573      252      16        0             0 gvfsd-trash
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260425] [ 2134]  1000  2134    57815      146      12        0             0 gvfsd-burn
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260430] [ 2163]  1000  2163    20936      248       9        0             0 gvfsd-metadata
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260435] [ 2241]  1000  2241    69964      791      27        0             0 telepathy-indic
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260441] [ 2250]  1000  2250    59534      388      17        0             0 mission-control
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260446] [ 2298]  1000  2298    69778      556      25        0             0 zeitgeist-datah
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260451] [ 2303]  1000  2303    75999      470      15        0             0 zeitgeist-daemo
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260456] [ 2309]  1000  2309    47183      616      22        0             0 zeitgeist-fts
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260461] [ 2317]  1000  2317     1158       18       6        0             0 cat
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260467] [ 2383]  1000  2383    81294      881      25        0             0 update-notifier
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260472] [ 2409]  1000  2409    91657     8516      64        0             0 update-manager
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260477] [ 2640]  1000  2640    77044      232      17        0             0 deja-dup-monito
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260483] [ 4699]     0  4699     2435      286       8        0             0 cupsd
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260488] [ 4702]     7  4702     1982      134       7        0             0 dbus
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260493] [ 4703]     7  4703     1982      133       7        0             0 dbus
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260499] [ 5535]     0  5535      945       61       5        0             0 dbus-launch
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260504] [ 5536]     0  5536     1163      118       5        0             0 dbus-daemon
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260509] [ 5543]     0  5543    38365      176       8        0             0 dconf-service
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260515] [ 5549]     0  5549    57646      656      13        0             0 zeitgeist-daemo
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260520] [ 5554]     0  5554    69771      521      24        0             0 zeitgeist-datah
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260525] [ 5556]     0  5556    39382      128      11        0             0 gvfsd
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260530] [ 5562]     0  5562    75696      163      14        0             0 gvfsd-fuse
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260537] [ 5827]     0  5827      705       52       4        0             0 systemd-hostnam
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260542] [ 6226]     0  6226     1372      577       6        0             0 dhclient
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260547] [ 6231] 65534  6231     1574       59       5        0             0 dnsmasq
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260552] [ 6361]     0  6361     3281      247       9        0             0 sshd
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260558] [ 6412]  1000  6412     3281      244       8        0             0 sshd
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260563] [ 6417]  1000  6417     1650      169       6        0             0 bash
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260568] [ 6455]   117  6455     1535      151       7        0             0 ntpd
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260578] Out of memory: Kill process 2007 (nautilus) score 22 or sacrifice child
Apr 25 08:17:42 tegra-ubuntu kernel: [ 4185.260589] Killed process 2007 (nautilus) total-vm:1182192kB, anon-rss:79468kB, file-rss:8524kB
Apr 25 08:18:39 tegra-ubuntu kernel: [ 4241.923737] usb 4-1: USB disconnect, device number 2
Apr 25 08:18:41 tegra-ubuntu kernel: [ 4244.210019] Buffer I/O error on device sda1, logical block 30965760
Apr 25 08:18:41 tegra-ubuntu kernel: [ 4244.210030] lost page write due to I/O error on sda1
Apr 25 08:18:41 tegra-ubuntu kernel: [ 4244.210036] JBD2: Error -5 detected when updating journal superblock for sda1-8.
Apr 25 08:18:41 tegra-ubuntu kernel: [ 4244.210043] Aborting journal on device sda1-8.
Apr 25 08:18:41 tegra-ubuntu kernel: [ 4244.210052] Buffer I/O error on device sda1, logical block 30965760
Apr 25 08:18:41 tegra-ubuntu kernel: [ 4244.210057] lost page write due to I/O error on sda1
Apr 25 08:18:41 tegra-ubuntu kernel: [ 4244.210061] JBD2: Error -5 detected when updating journal superblock for sda1-8.
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.266460] net invoked oom-killer: gfp_mask=0x201d2, order=0, oom_score_adj=0
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.266471] CPU: 0 PID: 7696 Comm: net Not tainted 3.10.96-tegra #1
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.266476] Call trace:
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.266485] [<ffffffc000089d28>] dump_backtrace+0x0/0xf4
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.266491] [<ffffffc00008a028>] show_stack+0x14/0x1c
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.266498] [<ffffffc0002f76dc>] dump_stack+0x20/0x28
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.266506] [<ffffffc000154714>] dump_header+0x6c/0xa8
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.266511] [<ffffffc000154b34>] oom_kill_process+0xac/0x3ac
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.266517] [<ffffffc000155234>] out_of_memory+0x1b8/0x1f0
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.266524] [<ffffffc000159c30>] __alloc_pages_nodemask+0x6e4/0x968
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.266529] [<ffffffc0001512a8>] page_cache_read+0x5c/0xf0
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.266535] [<ffffffc000153910>] filemap_fault+0x1b4/0x274
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.266540] [<ffffffc0001739d0>] __do_fault+0xc0/0x534
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.266545] [<ffffffc000173e80>] do_linear_fault+0x3c/0x44
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.266550] [<ffffffc0001771f8>] handle_pte_fault+0x60/0x1f4
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.266555] [<ffffffc00017816c>] __handle_mm_fault+0xdc/0x114
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.266560] [<ffffffc00017822c>] handle_mm_fault+0x88/0x98
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.266567] [<ffffffc00009a558>] __do_page_fault+0x60/0xa0
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.266572] [<ffffffc00009aa20>] do_page_fault+0x16c/0x3a8
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.266577] [<ffffffc000081218>] do_mem_abort+0x3c/0x98
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.266581] Exception stack(0xffffffc0804b3e30 to 0xffffffc0804b3f50)
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.266587] 3e20:                                     b53ae9f8 0000007f b43440bd 0000007f
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.266593] 3e40: ffffffff ffffffff b539fe0c 0000007f ffffffff ffffffff b539fe0c 0000007f
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.266600] 3e60: 00000000 00000000 001b6398 ffffffc0 804b3e90 ffffffc0 000860fc ffffffc0
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.266606] 3e80: 4dd4c800 ffffffc0 4dd4cd40 ffffffc0 804b3eb0 ffffffc0 000897f8 ffffffc0
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.266611] 3ea0: 00000008 00000000 b43440bd 0000007f e743ce70 0000007f 00085470 ffffffc0
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.266617] 3ec0: b53ae500 0000007f 000853c8 ffffffc0 b43440be 0000007f b5171c48 0000007f
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.266623] 3ee0: 0000006c 00000000 00000061 00000000 00000000 00000000 3e071609 07570c1b
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.266628] 3f00: 1b0c5707 0916073e 01235cf5 00000000 7f7f7f7f 7f7f7f7f 7ffff1a0 00000003
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.266634] 3f20: 01010101 01010101 00000004 00000000 000009f0 00000000 000262af 00000000
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.266639] 3f40: b53b2628 0000007f b539d310 0000007f
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.266643] Mem-Info:
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.266647] DMA32 per-cpu:
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.266652] CPU    0: hi:  186, btch:  31 usd:   0
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.266656] CPU    1: hi:  186, btch:  31 usd:   0
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.266661] CPU    2: hi:  186, btch:  31 usd:  32
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.266665] CPU    3: hi:  186, btch:  31 usd:   0
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.266669] Normal per-cpu:
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.266673] CPU    0: hi:  186, btch:  31 usd:  29
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.266678] CPU    1: hi:  186, btch:  31 usd:   0
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.266682] CPU    2: hi:  186, btch:  31 usd: 170
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.266686] CPU    3: hi:  186, btch:  31 usd:  30
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.266694] active_anon:82814 inactive_anon:2370 isolated_anon:0
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.266694]  active_file:144 inactive_file:649 isolated_file:0
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.266694]  unevictable:8 dirty:0 writeback:0 unstable:0
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.266694]  free:87806 slab_reclaimable:4520 slab_unreclaimable:10222
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.266694]  mapped:2408 shmem:2634 pagetables:1824 bounce:0
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.266694]  free_cma:83928
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.266709] DMA32 free:346908kB min:3092kB low:3864kB high:4636kB active_anon:18972kB inactive_anon:2088kB active_file:68kB inactive_file:0kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:1933312kB managed:1458564kB mlocked:0kB dirty:0kB writeback:0kB mapped:2108kB shmem:2100kB slab_reclaimable:812kB slab_unreclaimable:2256kB kernel_stack:144kB pagetables:216kB unstable:0kB bounce:0kB free_cma:335712kB writeback_tmp:0kB pages_scanned:152 all_unreclaimable? yes
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.266714] lowmem_reserve[]: 0 2048 2048
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.266731] Normal free:4316kB min:4444kB low:5552kB high:6664kB active_anon:312284kB inactive_anon:7392kB active_file:508kB inactive_file:2628kB unevictable:32kB isolated(anon):0kB isolated(file):0kB present:2097152kB managed:2097152kB mlocked:32kB dirty:0kB writeback:0kB mapped:7524kB shmem:8436kB slab_reclaimable:17268kB slab_unreclaimable:38632kB kernel_stack:6112kB pagetables:7080kB unstable:0kB bounce:0kB free_cma:0kB writeback_tmp:0kB pages_scanned:4167 all_unreclaimable? yes
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.266735] lowmem_reserve[]: 0 0 0
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.266745] DMA32: 363*4kB (UEMC) 414*8kB (UEMC) 547*16kB (UEMC) 409*32kB (UEMC) 296*64kB (UEMC) 169*128kB (UEMC) 84*256kB (UC) 33*512kB (C) 12*1024kB (C) 12*2048kB (C) 50*4096kB (RC) = 347244kB
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.266795] Normal: 206*4kB (MR) 4*8kB (R) 1*16kB (R) 5*32kB (R) 1*64kB (R) 1*128kB (R) 0*256kB 0*512kB 1*1024kB (R) 1*2048kB (R) 0*4096kB = 4296kB
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.266836] 3452 total pagecache pages
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.291918] 1007616 pages RAM
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.291926] 21282 pages reserved
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.291930] 794787 pages shared
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.291934] 888485 pages non-shared
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.291938] [ pid ]   uid  tgid total_vm      rss nr_ptes swapents oom_score_adj name
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.291959] [  282]     0   282      962      281       6        0             0 upstart-udev-br
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.291965] [  296]     0   296     2847      239       7        0         -1000 systemd-udevd
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.291970] [  310]   103   310     1435      391       6        0             0 dbus-daemon
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.291976] [  406]     0   406     1098       64       5        0             0 bluetoothd
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.291981] [  423]     0   423     1266       99       5        0             0 systemd-logind
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.291988] [  463]   101   463    56324      196      10        0             0 rsyslogd
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.291993] [  472]   112   472      932      106       5        0             0 avahi-daemon
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.291999] [  474]   112   474      899       60       5        0             0 avahi-daemon
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292005] [  590]     0   590     2514      233       8        0             0 cups-browsed
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292011] [  682]     0   682     8717      463      16        0             0 nvcamera-daemon
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292017] [  696]     0   696    58365      289      14        0             0 ModemManager
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292022] [  768]     0   768    62218      413      17        0             0 NetworkManager
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292028] [  774]     0   774     1316       40       5        0             0 getty
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292033] [  777]     0   777     1316       39       5        0             0 getty
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292039] [  782]     0   782     1316       40       5        0             0 getty
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292044] [  783]     0   783     1316       39       5        0             0 getty
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292050] [  786]     0   786     1316       39       5        0             0 getty
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292055] [  815]     0   815     2074      157       7        0         -1000 sshd
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292060] [  827]     0   827      808       60       5        0             0 cron
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292065] [  829]     0   829    57265      265      13        0             0 lightdm
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292071] [  832]   107   832     1549       81       5        0             0 kerneloops
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292076] [  842]     0   842    57630      552      12        0             0 polkitd
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292081] [  849]   110   849    62312      349      20        0             0 whoopsie
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292087] [  927]     0   927   841217     7425      51        0             0 Xorg
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292092] [  935]     0   935    57769      386      14        0             0 accounts-daemon
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292097] [  950]     0   950     1316       39       5        0             0 getty
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292102] [  952]     0   952     1529      136       6        0             0 login
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292107] [ 1028]  1000  1028     1658      160       5        0             0 bash
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292113] [ 1059]     0  1059     1712      138       5        0             0 wpa_supplicant
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292118] [ 1158]     0  1158    20969      265       9        0             0 lightdm
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292123] [ 1187]     0  1187    58350      276      15        0             0 upowerd
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292129] [ 1240]   108  1240    37565       57       7        0             0 rtkit-daemon
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292135] [ 1316]     0  1316      680       98       4        0             0 upstart-socket-
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292140] [ 1332]     0  1332     1058      467       5        0             0 upstart-file-br
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292145] [ 1478]   114  1478    58065      396      15        0             0 colord
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292152] [ 1583]  1000  1583    43965      188      15        0             0 gnome-keyring-d
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292157] [ 1587]  1000  1587     1839      249       6        0             0 init
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292162] [ 1654]  1000  1654      924       73       6        0             0 ssh-agent
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292168] [ 1659]  1000  1659     1627      429       6        0             0 dbus-daemon
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292173] [ 1667]  1000  1667     1358       48       6        0             0 upstart-event-b
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292178] [ 1670]  1000  1670    10198      145      14        0             0 window-stack-br
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292184] [ 1682]  1000  1682    86106     1363      30        0             0 bamfdaemon
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292189] [ 1686]  1000  1686     1360       54       5        0             0 upstart-dbus-br
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292194] [ 1687]  1000  1687     1485       64       6        0             0 upstart-file-br
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292199] [ 1688]  1000  1688     1360       53       4        0             0 upstart-dbus-br
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292205] [ 1690]  1000  1690    75656      138      15        0             0 at-spi-bus-laun
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292210] [ 1695]  1000  1695    76761      488      14        0             0 ibus-daemon
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292215] [ 1698]  1000  1698     1193      152       5        0             0 dbus-daemon
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292220] [ 1708]  1000  1708    20506      153       7        0             0 at-spi2-registr
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292225] [ 1717]  1000  1717    39382      161      11        0             0 gvfsd
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292231] [ 1724]  1000  1724   119855     2356      35        0             0 unity-settings-
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292236] [ 1725]  1000  1725    57954      184      13        0             0 ibus-dconf
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292241] [ 1727]  1000  1727    75696      155      13        0             0 gvfsd-fuse
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292246] [ 1730]  1000  1730    68278     1202      28        0             0 ibus-ui-gtk3
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292252] [ 1732]  1000  1732   118312     2727      52        0             0 hud-service
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292257] [ 1745]  1000  1745    61546      439      21        0             0 ibus-x11
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292263] [ 1749]  1000  1749   136661      882      32        0             0 gnome-session
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292268] [ 1755]  1000  1755   107991     1971      34        0             0 unity-panel-ser
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292273] [ 1806]  1000  1806    89201     1296      32        0             0 indicator-keybo
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292278] [ 1808]  1000  1808    76012      119      14        0             0 indicator-messa
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292284] [ 1809]  1000  1809    57649      124      13        0             0 indicator-bluet
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292289] [ 1810]  1000  1810    57867      161      14        0             0 indicator-power
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292294] [ 1812]  1000  1812   256561      662      39        0             0 indicator-datet
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292300] [ 1813]  1000  1813    39520      222      11        0             0 ibus-engine-sim
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292305] [ 1817]  1000  1817   113363     1098      24        0             0 indicator-sound
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292311] [ 1823]  1000  1823    63474      908      25        0             0 indicator-print
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292316] [ 1828]  1000  1828   213700      414      27        0             0 indicator-sessi
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292322] [ 1832]  1000  1832    41987      284      15        0             0 indicator-appli
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292327] [ 1867]  1000  1867   220875      721      40        0             0 evolution-sourc
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292333] [ 1877]  1000  1877    58885      801      20        0             0 pulseaudio
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292338] [ 1880]  1000  1880    38366      171       9        0             0 dconf-service
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292344] [ 1940]  1000  1940    50575     1310      28        0             0 notify-osd
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292349] [ 1962]  1000  1962   200491     9057      56        0             0 evolution-calen
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292354] [ 1974]  1000  1974   247891    15934     117        0             0 compiz
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292360] [ 1997]  1000  1997    62125      731      22        0             0 unity-fallback-
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292365] [ 2001]  1000  2001    43773      724      19        0             0 polkit-gnome-au
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292370] [ 2004]  1000  2004    76719     1390      35        0             0 nm-applet
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292376] [ 2038]  1000  2038    60507      679      15        0             0 gvfs-udisks2-vo
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292381] [ 2045]     0  2045    94673      599      17        0             0 udisksd
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292386] [ 2084]  1000  2084     2727      364       8        0             0 gconfd-2
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292391] [ 2102]  1000  2102    39315      171      11        0             0 gvfs-mtp-volume
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292396] [ 2110]  1000  2110    58568      180      14        0             0 gvfs-afc-volume
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292402] [ 2115]  1000  2115    39782      227      11        0             0 gvfs-gphoto2-vo
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292407] [ 2124]  1000  2124    76573      254      16        0             0 gvfsd-trash
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292413] [ 2134]  1000  2134    57815      162      12        0             0 gvfsd-burn
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292418] [ 2163]  1000  2163    20936      241       9        0             0 gvfsd-metadata
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292423] [ 2241]  1000  2241    69964      791      27        0             0 telepathy-indic
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292429] [ 2250]  1000  2250    59534      381      17        0             0 mission-control
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292434] [ 2298]  1000  2298    69778      557      25        0             0 zeitgeist-datah
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292439] [ 2303]  1000  2303    75999      466      15        0             0 zeitgeist-daemo
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292445] [ 2309]  1000  2309    47183      614      22        0             0 zeitgeist-fts
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292450] [ 2317]  1000  2317     1158       18       6        0             0 cat
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292456] [ 2383]  1000  2383    81294      874      25        0             0 update-notifier
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292461] [ 2409]  1000  2409    91657     8516      64        0             0 update-manager
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292467] [ 2640]  1000  2640    77044      247      17        0             0 deja-dup-monito
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292472] [ 4699]     0  4699     2435      279       8        0             0 cupsd
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292477] [ 4702]     7  4702     1982      127       7        0             0 dbus
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292483] [ 4703]     7  4703     1982      126       7        0             0 dbus
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292488] [ 5535]     0  5535      945       61       5        0             0 dbus-launch
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292493] [ 5536]     0  5536     1163      117       5        0             0 dbus-daemon
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292499] [ 5543]     0  5543    38365      176       8        0             0 dconf-service
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292504] [ 5549]     0  5549    57646      656      13        0             0 zeitgeist-daemo
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292510] [ 5554]     0  5554    69771      521      24        0             0 zeitgeist-datah
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292515] [ 5556]     0  5556    39382      128      11        0             0 gvfsd
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292520] [ 5562]     0  5562    75696      163      14        0             0 gvfsd-fuse
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292526] [ 5827]     0  5827      705       42       4        0             0 systemd-hostnam
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292532] [ 6226]     0  6226     1372      570       6        0             0 dhclient
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292537] [ 6231] 65534  6231     1574       59       5        0             0 dnsmasq
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292542] [ 6361]     0  6361     3281      240       9        0             0 sshd
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292548] [ 6412]  1000  6412     3281      240       8        0             0 sshd
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292553] [ 6417]  1000  6417     1650      169       6        0             0 bash
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292559] [ 6455]   117  6455     1535      141       7        0             0 ntpd
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292569] [ 7660]  1000  7660   145100     6014      57        0             0 nautilus
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292574] [ 7696]  1000  7696     6740      294      14        0             0 net
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292578] Out of memory: Kill process 1974 (compiz) score 16 or sacrifice child
Apr 25 08:18:50 tegra-ubuntu kernel: [ 4253.292588] Killed process 1974 (compiz) total-vm:991564kB, anon-rss:51732kB, file-rss:12004kB
Apr 25 08:19:19 tegra-ubuntu kernel: [ 4281.921452] usb 6-1.4: reset SuperSpeed USB device number 5 using xhci_hcd
Apr 25 08:19:19 tegra-ubuntu kernel: [ 4281.949165] usb 6-1.4: Parent hub missing LPM exit latency info.  Power management will be impacted.
Hi Aldrog,
Please disable PCIE ASPM and give it a try. It is enabled on r24.2.1:
./arch/arm64/configs/tegra21_defconfig:CONFIG_PCIEASPM_POWERSAVE=y
Doesn’t help.
Just to make sure I got it right, here’re the steps I followed:
  1. Found mentioned file in kernel source tree
  2. Changed CONFIG_PCIEASPM_POWERSAVE to “n”
  3. Built zImage and copied it over to TX1’s /boot/
  4. Rebooted
There’re no observable changes afterwards.
Hi Aldrog,
It should load /boot/Image. Do you see Image get built?
Yes, it is. I’ll try it.
Still no changes.
BTW the boot log from R24 I sent got truncated. Here’s the full log. Boot log (journalctl -b) of L4T R24.2.1 · GitHub
I don’t know if this is actually significant or not, but in that log this caught my attention:
…someone else may know if that matters.
Thank linuxdev for the catch.
Hi Aldrog,
Could you revert the following change and try?
From 83b722328dd9eca847d302c5f32f438375038a7d Mon Sep 17 00:00:00 2001
Date: Thu, 28 Apr 2016 10:17:24 +0530
Subject: [PATCH] ARM64: dts: t210: enable IOMMU for PCIe in Jetson
enables IOMMU for PCIe in Jetson-E and Jetson-CV
 arch/arm64/boot/dts/tegra210-jetson-cv-base-p2597-2180-a00.dts | 2 ++
 arch/arm64/boot/dts/tegra210-jetson-e-base-p2595-0000-a00.dts  | 2 ++
 2 files changed, 4 insertions(+)
diff --git a/arch/arm64/boot/dts/tegra210-jetson-cv-base-p2597-2180-a00.dts b/arch/arm64/boot/dts/tegra210-jetson-cv-base-p2597-2180-a00.dts
index dcd2535..7555b79 100644
--- a/arch/arm64/boot/dts/tegra210-jetson-cv-base-p2597-2180-a00.dts
+++ b/arch/arm64/boot/dts/tegra210-jetson-cv-base-p2597-2180-a00.dts
@@ -231,6 +231,8 @@
 		vddio-pex-ctl-supply = <&max77620_sd3>;
 		status = "okay";
+		iommus = <&smmu TEGRA_SWGROUP_AFI>;
 		pci@1,0 {
 			status = "okay";
diff --git a/arch/arm64/boot/dts/tegra210-jetson-e-base-p2595-0000-a00.dts b/arch/arm64/boot/dts/tegra210-jetson-e-base-p2595-0000-a00.dts
index 68dbc5e..6e0e59d 100644
--- a/arch/arm64/boot/dts/tegra210-jetson-e-base-p2595-0000-a00.dts
+++ b/arch/arm64/boot/dts/tegra210-jetson-e-base-p2595-0000-a00.dts
@@ -306,6 +306,8 @@
 		status = "okay";
 		pci@1,0 {
 			status = "okay";
2.1.4
Hi DaneLLL,
Reverting this patch didn’t help either. The line noticed by linuxdev is still there too.
