demo log:
./camera_jpeg_capture
[INFO] (NvEglRenderer.cpp:110) Setting Screen width 640 height 480
Error generated. main.cpp, execute:329 No cameras available
kernel log:
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.140 (liyi@ubuntu) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #74 SMP PREEMPT Tue Mar 2 11:00:04 CST 2021
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 32,
[ 0.000000] OF: fdt: - 80000000 , 7ee00000
[ 0.000000] OF: fdt: - 100000000 , 7f200000
[ 0.000000] Found tegra_fbmem: 00800000@92cb4000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000070006000 (options '')
[ 0.000000] bootconsole [uart8250] enabled
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb0_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node iram-carveout, compatible id nvidia,iram-carveout
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fac00000
[ 0.000000] On node 0 totalpages: 1039872
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 519168 pages, LIFO batch:31
[ 0.000000] Normal zone: 8136 pages used for memmap
[ 0.000000] Normal zone: 520704 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 25 pages/cpu @ffffffc0fefb5000 s61656 r8192 d32552 u102400
[ 0.000000] pcpu-alloc: s61656 r8192 d32552 u102400 alloc=25*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] CPU features: enabling workaround for ARM erratum 832075
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1023544
[ 0.000000] Kernel command line: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,2 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1125 core_edp_ma=4000 tegra_fbmem=0x800000@0x92cb4000 is_hdmi_initialised=1 earlycon=uart8250,mmio32,0x70006000 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 98304 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 131072 bytes
[ 0.000000] early log buf free: 29324(89%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Memory: 3562656K/4159488K available (15102K kernel code, 2878K rwdata, 6552K rodata, 8512K init, 609K bss, 121696K reserved, 475136K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f40000 ( 15104 KB)
[ 0.000000] .rodata : 0xffffff8008f40000 - 0xffffff80095b0000 ( 6592 KB)
[ 0.000000] .init : 0xffffff80095b0000 - 0xffffff8009e00000 ( 8512 KB)
[ 0.000000] .data : 0xffffff8009e00000 - 0xffffff800a0cf808 ( 2879 KB)
[ 0.000000] .bss : 0xffffff800a0cf808 - 0xffffff800a167ebc ( 610 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf03fc8000 ( 63 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc0ff200000 ( 4082 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /interrupt-controller
[ 0.000000] t210 clock and reset probe
[ 0.000000] tegra-pmc: get_secure_pmc_setting: done secure_pmc=1
[ 0.000000] clk_cbus_recalc_rate: no gbus parent
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000005] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.001629] Console: colour dummy device 80x25
[ 0.001638] console [tty0] enabled
[ 0.001644] bootconsole [uart8250] disabled
[ 0.001663] kmemleak: Kernel memory leak detector disabled
[ 0.001680] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=76800)
[ 0.001693] pid_max: default: 32768 minimum: 301
[ 0.002148] Security Framework initialized
[ 0.002364] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.002373] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.003533] ftrace: allocating 46947 entries in 184 pages
[ 0.173033] sched-energy: CPU device node has no sched-energy-costs
[ 0.173068] ASID allocator initialised with 65536 entries
[ 0.211779] tegra-id: chipid=22117.
[ 0.211793] tegra-id: opt_subrevision=0.
[ 0.211811] Tegra Speedo/IDDQ fuse revision 4
[ 0.211817] Tegra: CPU Speedo ID 9, SoC Speedo ID 0, GPU Speedo ID 2
[ 0.211822] Tegra: CPU Process ID 0, SoC Process ID 0, GPU Process ID 0
[ 0.211827] Tegra: CPU Speedo Value 2046, SoC Speedo Value 1941, GPU Speedo Value 2050
[ 0.211831] Tegra: CPU IDDQ Value 1924, SoC IDDQ Value 2192, GPU IDDQ Value 2630
[ 0.211851] Tegra Revision: A02 SKU: 0x8f CPU Process: 0 SoC Process: 0
[ 0.211867] DTS File Name: arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-b00.dts
[ 0.211874] DTB Build time: Mar 2 2021 11:50:20
[ 0.261100] CPU1: Booted secondary processor [411fd071]
[ 0.293009] CPU2: Booted secondary processor [411fd071]
[ 0.324954] CPU3: Booted secondary processor [411fd071]
[ 0.325051] Brought up 4 CPUs
[ 0.325058] SMP: Total of 4 processors activated.
[ 0.325066] CPU features: detected feature: 32-bit EL0 Support
[ 0.325331] CPU: All CPU(s) started at EL2
[ 0.325349] alternatives: patching kernel code
[ 0.333571] devtmpfs: initialized
[ 0.371532] Initilizing CustomIPI irq domain
[ 0.371917] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.371935] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.384769] pinctrl core: initialized pinctrl subsystem
[ 0.385427] OS set in device tree is not L4T.
[ 0.385863] regulator-dummy: no parameters
[ 0.386151] Initializing plugin-manager
[ 0.386305] Plugin module not found
[ 0.386496] node /plugin-manager/fragement@0 match with board >=3448-0000-100
[ 0.387020] node /plugin-manager/fragment@1 match with board >=3448-0000-101
[ 0.387876] node /plugin-manager/fragement@6 match with odm-data enable-tegra-wdt
[ 0.388268] node /plugin-manager/fragement@8 match with odm-data enable-tegra-wdt
[ 0.388654] node /plugin-manager/fragement@10 match with board >=3448-0000-300
[ 0.390460] node /plugin-manager/fragement@13 match with board >=3448-0000-300
[ 0.394125] NET: Registered protocol family 16
[ 0.397033] pstore: using zlib compression
[ 0.397080] console [pstore-1] enabled
[ 0.397085] pstore: Registered ramoops as persistent store backend
[ 0.397091] ramoops: attached 0x200000@0xb0000000, ecc: 0/0
[ 0.413118] cpuidle: using governor menu
[ 0.416271] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[ 0.418188] vdso: 2 pages (1 code @ ffffff8008f47000, 1 data @ ffffff8009e04000)
[ 0.418211] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.421641] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.423912] Serial: AMBA PL011 UART driver
[ 0.424424] tegra_powergate_init: DONE
[ 0.424439] DTS File Name: arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-b00.dts
[ 0.424445] DTB Build time: Mar 2 2021 11:50:20
[ 0.426359] Tegra reboot handler registered.
[ 0.430941] iommu: Adding device tegra-carveouts to group 0
[ 0.431083] platform tegra-carveouts: domain=ffffffc0f9bba3d8 allocates as[0]=ffffffc0f9bd40a8
[ 0.431455] iommu: Adding device smmu_test to group 1
[ 0.431507] platform smmu_test: domain=ffffffc0f9bba618 allocates as[0]=ffffffc0f9bd4110
[ 0.432333] mc: mapped MMIO address: 0xffffff800802e000 -> 0x70019000
[ 0.432408] mc: mapped MMIO address: 0xffffff8008065000 -> 0x7001c000
[ 0.432461] mc: mapped MMIO address: 0xffffff8008079000 -> 0x7001d000
[ 0.432470] nv-tegra-mc 70019000.mc: No mssnvlink node
[ 0.432492] mc-err: mcerr ops are set to t21x
[ 0.442787] iommu: Adding device 70090000.xusb to group 2
[ 0.443064] iommu: Adding device 70006000.serial to group 3
[ 0.443133] platform 70006000.serial: domain=ffffffc0f94cd618 allocates as[0]=ffffffc0f9bd4178
[ 0.443574] iommu: Adding device 70006040.serial to group 4
[ 0.443856] iommu: Adding device 70006200.serial to group 5
[ 0.444075] iommu: Adding device sound to group 6
[ 0.444124] platform sound: domain=ffffffc0f94cdb58 allocates as[0]=ffffffc0f9bd41e0
[ 0.444683] iommu: Adding device 7000d400.spi to group 7
[ 0.444937] iommu: Adding device 7000d600.spi to group 8
[ 0.445249] iommu: Adding device 70410000.spi to group 9
[ 0.445563] iommu: Adding device 50000000.host1x to group 10
[ 0.445844] iommu: Adding device 54080000.vi to group 11
[ 0.446241] iommu: Adding device 54600000.isp to group 12
[ 0.446501] iommu: Adding device 54680000.isp to group 13
[ 0.446811] iommu: Adding device tegradc.0 to group 14
[ 0.446869] platform tegradc.0: domain=ffffffc0f94dba98 allocates as[0]=ffffffc0f9bd4248
[ 0.451172] platform tegradc.0: IOVA linear map 0x0000000092cb4000(800000)
[ 0.451566] platform tegradc.0: IOVA linear map 0x00000000d7000000(19000000)
[ 0.451901] iommu: Adding device tegradc.1 to group 15
[ 0.451948] platform tegradc.1: domain=ffffffc0f94dbcd8 allocates as[0]=ffffffc0f9bd42b0
[ 0.456139] platform tegradc.1: IOVA linear map 0x0000000092cb4000(800000)
[ 0.456530] platform tegradc.1: IOVA linear map 0x00000000d7000000(19000000)
[ 0.456786] iommu: Adding device 54340000.vic to group 16
[ 0.456998] iommu: Adding device 544c0000.nvenc to group 17
[ 0.457234] iommu: Adding device 54500000.tsec to group 18
[ 0.457444] iommu: Adding device 54100000.tsecb to group 19
[ 0.457642] iommu: Adding device 54480000.nvdec to group 20
[ 0.457869] iommu: Adding device 54380000.nvjpg to group 21
[ 0.458939] iommu: Adding device 546c0000.i2c to group 22
[ 0.459277] iommu: Adding device 57000000.gpu to group 23
[ 0.459334] platform 57000000.gpu: domain=ffffffc0f94eacd8 allocates as[0]=ffffffc0f9bd4318
[ 0.459371] platform 57000000.gpu: domain=ffffffc0f94eacd8 allocates as[1]=ffffffc0f9bd4380
[ 0.459411] platform 57000000.gpu: domain=ffffffc0f94eacd8 allocates as[2]=ffffffc0f9bd43e8
[ 0.459446] platform 57000000.gpu: domain=ffffffc0f94eacd8 allocates as[3]=ffffffc0f9bd4450
[ 0.460353] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency thermal reset disabled.
[ 0.460365] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
[ 0.460377] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ 0.460381] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_WARM
[ 0.460384] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.513192] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.513204] tegra-pmc: Clear bootloader IO dpd settings
[ 0.513224] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
[ 0.513289] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset commands
[ 0.513574] iommu: Adding device 70012000.se to group 24
[ 0.514356] iommu: Adding device 7000c000.i2c to group 25
[ 0.514619] iommu: Adding device 7000c400.i2c to group 26
[ 0.514885] iommu: Adding device 7000c500.i2c to group 27
[ 0.515137] iommu: Adding device 7000c700.i2c to group 28
[ 0.515423] iommu: Adding device 7000d000.i2c to group 29
[ 0.515674] iommu: Adding device 7000d100.i2c to group 30
[ 0.515963] iommu: Adding device sdhci-tegra.0 to group 31
[ 0.516018] platform sdhci-tegra.0: domain=ffffffc0f957de58 allocates as[0]=ffffffc0f9bd44b8
[ 0.516858] iommu: Adding device 700d0000.xudc to group 32
[ 0.520288] vdd-ac-bat: 5000 mV
[ 0.520650] vdd-5v0-sys: 5000 mV
[ 0.521637] vdd-5v0-hdmi: supplied by vdd-5v0-sys
[ 0.521707] vdd-5v0-hdmi: 5000 mV
[ 0.522110] vdd-1v8-sys: 1800 mV
[ 0.522499] vdd-fan: supplied by vdd-5v0-sys
[ 0.522529] vdd-fan: 5000 mV
[ 0.522928] vdd-usb-vbus: supplied by vdd-5v0-sys
[ 0.522983] vdd-usb-vbus: 5000 mV
[ 0.523521] vdd-usb-vbus2: 5000 mV
[ 0.553869] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.556349] gpio gpiochip0: gpio-line-names specifies 240 line names but there are 256 lines on the chip
[ 0.557992] GPIO line 151 (camera-control-output-low) hogged as output/low
[ 0.558014] GPIO line 152 (camera-control-output-low) hogged as output/low
[ 0.558051] GPIO line 6 (system-suspend-gpio) hogged as output/high
[ 0.558414] gpiochip_setup_dev: registered GPIOs 0 to 255 on device: gpiochip0 (tegra-gpio)
[ 0.566464] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.566805] SCSI subsystem initialized
[ 0.567040] libata version 3.00 loaded.
[ 0.567348] usbcore: registered new interface driver usbfs
[ 0.567399] usbcore: registered new interface driver hub
[ 0.567474] usbcore: registered new device driver usb
[ 0.571711] max77620 4-003c: PMIC Version OTP:0x35 and ES:0x8
[ 0.576356] random: fast init done
[ 0.576372] vdd-core: 600 <--> 1162 mV at 1125 mV
[ 0.577425] vdd-ddr-1v1: Bringing 1125000uV into 1150000-1150000uV
[ 0.580313] vdd-ddr-1v1: 1150 mV
[ 0.584974] vdd-pre-reg-1v35: 1350 mV
[ 0.588975] vdd-1v8: 1800 mV
[ 0.592973] avdd-sys-1v2: 1200 mV
[ 0.596979] vdd-pex-1v0: 1050 mV
[ 0.597626] vddio-sdmmc-ap: 1800 <--> 3300 mV at 3300 mV
[ 0.598166] max77620-ldo3: at 3100 mV
[ 0.600978] vdd-rtc: 850 <--> 1100 mV at 1000 mV
[ 0.601533] max77620-ldo5: at 3100 mV
[ 0.604983] vddio-sdmmc3-ap: 1800 <--> 3300 mV at 2800 mV
[ 0.608972] avdd-1v05-pll: 1050 mV
[ 0.612976] avdd-io-hdmi-dp: 1050 mV
[ 0.615601] GPIO line 505 (spmic-default-output-high) hogged as output/high
[ 0.615890] gpiochip_setup_dev: registered GPIOs 504 to 511 on device: gpiochip1 (max77620-gpio)
[ 0.616166] max77620 4-003c: max77620 probe successful
[ 0.619015] media: Linux media interface: v0.10
[ 0.619073] Linux video capture interface: v2.00
[ 0.620023] pps_core: LinuxPPS API ver. 1 registered
[ 0.620030] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.620050] PTP clock support registered
[ 0.623492] tegra210-emc 7001b000.external-memory-controller: validated EMC DFS table
[ 0.624437] Advanced Linux Sound Architecture Driver Initialized.
[ 0.625157] Bluetooth: Core ver 2.22
[ 0.625206] NET: Registered protocol family 31
[ 0.625210] Bluetooth: HCI device and connection manager initialized
[ 0.625228] Bluetooth: HCI socket layer initialized
[ 0.625237] Bluetooth: L2CAP socket layer initialized
[ 0.625262] Bluetooth: SCO socket layer initialized
[ 0.627049] tegra210_dvfs: no clock found for sdmmc2_ddr
[ 0.627065] tegra210_dvfs: no clock found for sdmmc4_ddr
[ 0.627115] tegra210_dvfs: no clock found for sdmmc1_ddr
[ 0.627130] tegra210_dvfs: no clock found for sdmmc3_ddr
[ 0.630575] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering probe
[ 0.631892] vdd-3v3-sys: supplied by vdd-5v0-sys
[ 0.631958] vdd-3v3-sys: 3300 mV
[ 0.632243] vdd-1v8-sys: supplied by vdd-3v3-sys
[ 0.637108] vdd-usb-vbus2: supplied by vdd-3v3-sys
[ 0.637605] vdd-3v3-sd: supplied by vdd-3v3-sys
[ 0.637653] vdd-3v3-sd: 3300 mV
[ 0.638783] avdd-io-edp-1v05: supplied by avdd-1v05-pll
[ 0.638836] avdd-io-edp-1v05: 1050 mV
[ 0.639297] vdd-usb-hub-en: supplied by vdd-1v8-sys
[ 0.639341] vdd-usb-hub-en: 5000 mV
[ 0.640867] camchar: rtcpu character device driver loaded
[ 0.641590] extcon-gpio-states extcon:extcon@1: Cable state:1, cable id:1
[ 0.643111] clocksource: Switched to clocksource arch_sys_counter
[ 0.681734] VFS: Disk quotas dquot_6.6.0
[ 0.681872] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.682365] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.682805] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000d7000000, size=0x19000000
[ 0.682822] dma-vpr: heap size is not multiple of cma_chunk_size heap_info->num_chunks (13) rem_chunk_size(0x1000000)
[ 0.683026] cma: enabled page replacement for spfn=d7000, epfn=f0000
[ 0.683031] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[ 0.683043] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 0.683070] tegra-carveouts tegra-carveouts: iram :dma coherent mem declare 0x0000000040001000,258048
[ 0.683076] tegra-carveouts tegra-carveouts: assigned reserved memory node iram-carveout
[ 0.683139] nvmap: nvmap_select_cache_ops() nvmap cache ops set to set/ways
[ 0.683149] nvmap_page_pool_init: Total RAM pages: 1009448
[ 0.683154] nvmap_page_pool_init: nvmap page pool size: 126181 pages (492 MB)
[ 0.683259] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.683743] misc nvmap: created heap iram base 0x0000000040001000 size (252KiB)
[ 0.684788] misc nvmap: created heap vpr base 0x00000000d7000000 size (409600KiB)
[ 0.693473] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[ 0.693940] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[ 0.694326] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.694614] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.694793] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 0.695076] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[ 0.695081] pre_t19x_iso_plat_init(): max_iso_bw=11520000KB
[ 0.695563] NET: Registered protocol family 2
[ 0.696529] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.696742] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.697287] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.697448] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.697534] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.697946] NET: Registered protocol family 1
[ 0.698732] RPC: Registered named UNIX socket transport module.
[ 0.698739] RPC: Registered udp transport module.
[ 0.698743] RPC: Registered tcp transport module.
[ 0.698747] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.698761] PCI: CLS 0 bytes, default 64
[ 0.699000] Trying to unpack rootfs image as initramfs...
[ 0.931063] Freeing initrd memory: 5356K
[ 0.941123] host1x 50000000.host1x: initialized
[ 0.943052] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.946343] audit: initializing netlink subsys (disabled)
[ 0.946414] audit: type=2000 audit(0.791:1): initialized
[ 0.947266] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 0.957279] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.958796] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.959639] 9p: Installing v9fs 9p2000 file system support
[ 0.962973] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 0.963166] io scheduler noop registered
[ 0.963453] io scheduler cfq registered (default)
[ 0.966198] gic 702f9000.agic: GIC IRQ controller registered
[ 0.969223] iommu: Adding device 702ef000.adsp to group 33
[ 0.978490] iommu: Adding device aconnect@702c0000:adsp_audio to group 34
[ 0.978649] tegra-aconnect aconnect@702c0000: Tegra ACONNECT bus registered
[ 0.979506] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_SKU_CALIB_0 = 0x8a28410
[ 0.979516] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_USB_CALIB_EXT_0 = 0x4
[ 0.981212] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.0, lane = usb2-0, function = xusb
[ 0.981306] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.1, lane = usb2-1, function = xusb
[ 0.981406] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane = usb2-2, function = xusb
[ 0.981605] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane = pcie-0, function = pcie-x1
[ 0.981689] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane = pcie-1, function = pcie-x4
[ 0.981778] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane = pcie-2, function = pcie-x4
[ 0.981865] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane = pcie-3, function = pcie-x4
[ 0.981953] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane = pcie-4, function = pcie-x4
[ 0.982037] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane = pcie-5, function = xusb
[ 0.982123] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane = pcie-6, function = xusb
[ 0.982207] li===> usb2 mode:otg
[ 0.982511] li===> usb2 mode:host
[ 0.982657] li===> usb2 mode:host
[ 0.988383] tegra-pwm 7000a000.pwm: PWM clk cannot sleep in ops
[ 0.990092] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[ 0.992029] tegra-pcie 1003000.pcie: 4x1, 1x1 configuration
[ 0.993323] tegra-pcie 1003000.pcie: PCIE: Enable power rails
[ 0.993678] tegra-pcie 1003000.pcie: probing port 0, using 4 lanes
[ 0.994917] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.995278] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=3000000, max_bw=3000000
[ 0.995308] tegra-pcie 1003000.pcie: probing port 1, using 1 lanes
[ 0.995581] Adding domain tsec-pd to PM domain host1x-pd
[ 0.998528] tsec 54500000.tsec: initialized
[ 1.000002] tsec 54100000.tsecb: initialized
[ 1.000738] Adding domain nvdec-pd to PM domain host1x-pd
[ 1.004102] nvdec 54480000.nvdec: initialized
[ 1.005168] Adding domain vic03-pd to PM domain host1x-pd
[ 1.005357] Adding domain msenc-pd to PM domain host1x-pd
[ 1.005524] Adding domain nvjpg-pd to PM domain host1x-pd
[ 1.009266] falcon 54340000.vic: initialized
[ 1.010529] falcon 544c0000.nvenc: initialized
[ 1.011929] falcon 54380000.nvjpg: initialized
[ 1.016164] tegra_cec 70015000.tegra_cec: dt=1 start=0x70015000 end=0x70015FFF irq=97
[ 1.016216] tegra_cec 70015000.tegra_cec: Enable clock result: 0.
[ 1.016250] tegra_cec 70015000.tegra_cec: tegra_cec_init started
[ 1.016516] tegradc tegradc.0: disp0 connected to head0->/host1x/sor1
[ 1.016519] tegra_cec 70015000.tegra_cec: cec_add_sysfs ret=0
[ 1.016524] tegra_cec 70015000.tegra_cec: probed
[ 1.016614] display board info: id 0x0, fab 0x0
[ 1.016680] generic_infoframe_type: 0x87
[ 1.016829] tegradc tegradc.0: DT parsed successfully
[ 1.016880] tegradc tegradc.0: Display dc.ffffff800ab00000 registered with id=0
[ 1.017406] tegradc tegradc.0: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350781
[ 1.024768] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
[ 1.025717] tegradc tegradc.0: probed
[ 1.026455] tegra-pcie 1003000.pcie: PCI host bridge to bus 0000:00
[ 1.026464] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 1.026475] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
[ 1.026481] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pref]
[ 1.026487] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.026513] pci 0000:00:01.0: [10de:0fae] type 01 class 0x060400
[ 1.026602] pci 0000:00:01.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 1.026817] pci 0000:00:02.0: [10de:0faf] type 01 class 0x060400
[ 1.026876] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 1.027068] pci 0000:00:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 1.027077] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 1.027273] pci 0000:01:00.0: [144d:a808] type 00 class 0x010802
[ 1.027300] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[ 1.030067] tegra-adma 702e2000.adma: Tegra210 ADMA driver registered 22 channels
[ 1.030564] tegra-fuse-burn 7000f800.efuse:efuse-burn: shutdown limit check disabled
[ 1.030570] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initialized
[ 1.030796] kfuse 7000fc00.kfuse: initialized
[ 1.031435] tegra-pmc-iopower pmc-iopower: Regulator supply iopower-dbg-supply not available
[ 1.032122] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 1.032803] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[ 1.032810] vdd-cpu: 708 <--> 1322 mV at 708 mV
[ 1.033119] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator registration passed
[ 1.034170] vdd-gpu: applied init 1000000uV constraint
[ 1.034176] vdd-gpu: 708 <--> 1323 mV at 997 mV
[ 1.034494] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator registration passed
[ 1.037489] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.037552] No Device Node present for smmu client: serial8250 !!
[ 1.037560] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 1.037587] iommu: Adding device serial8250 to group 35
[ 1.039120] console [ttyS0] disabled
[ 1.039158] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 63, base_baud = 25500000) is a Tegra
[ 1.039198] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 1.039213] console [ttyS0] enabled
[ 1.039361] pci 0000:02:00.0: [10ec:8168] type 00 class 0x020000
[ 1.039384] pci 0000:02:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 1.039410] pci 0000:02:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[ 1.039428] pci 0000:02:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[ 1.039570] pci 0000:02:00.0: supports D1 D2
[ 1.039574] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 1.039616] Console: switching to colour frame buffer device 240x67
[ 1.039691] tegradc tegradc.0: fb registered
[ 1.040023] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 64, base_baud = 0) is a TEGRA_UART
[ 1.040266] serial-tegra 70006200.serial: RX in PIO mode
[ 1.040357] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 65, base_baud = 0) is a TEGRA_UART
[ 1.041285] [drm] Initialized
[ 1.046929] tegradc tegradc.0: DC initialized, skipping tegra_dc_program_mode.
[ 1.046956] tegradc tegradc.0: hdmi: tmds rate:148351K prod-setting:prod_c_hdmi_75m_150m
[ 1.047343] tegradc tegradc.0: hdmi: get RGB quant from REG programmed by BL.
[ 1.047352] tegradc tegradc.0: hdmi: get YCC quant from REG programmed by BL.
[ 1.049266] brd: module loaded
[ 1.051185] pci_bus 0000:02: busn_res: [bus 02-ff] end is updated to 02
[ 1.051233] pci 0000:00:01.0: BAR 14: assigned [mem 0x13000000-0x130fffff]
[ 1.051239] pci 0000:00:02.0: BAR 14: assigned [mem 0x13100000-0x131fffff]
[ 1.051245] pci 0000:00:02.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 1.051254] pci 0000:01:00.0: BAR 0: assigned [mem 0x13000000-0x13003fff 64bit]
[ 1.051269] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 1.051276] pci 0000:00:01.0: bridge window [mem 0x13000000-0x130fffff]
[ 1.051287] pci 0000:02:00.0: BAR 4: assigned [mem 0x13100000-0x13103fff 64bit]
[ 1.051304] pci 0000:02:00.0: BAR 2: assigned [mem 0x13104000-0x13104fff 64bit]
[ 1.051320] pci 0000:02:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 1.051328] pci 0000:00:02.0: PCI bridge to [bus 02]
[ 1.051333] pci 0000:00:02.0: bridge window [io 0x1000-0x1fff]
[ 1.051339] pci 0000:00:02.0: bridge window [mem 0x13100000-0x131fffff]
[ 1.051613] pcieport 0000:00:01.0: Signaling PME through PCIe PME interrupt
[ 1.051618] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 1.051625] pcie_pme 0000:00:01.0:pcie001: service driver pcie_pme loaded
[ 1.051744] aer 0000:00:01.0:pcie002: service driver aer loaded
[ 1.051961] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
[ 1.051966] pci 0000:02:00.0: Signaling PME through PCIe PME interrupt
[ 1.051972] pcie_pme 0000:00:02.0:pcie001: service driver pcie_pme loaded
[ 1.052083] aer 0000:00:02.0:pcie002: service driver aer loaded
[ 1.053581] loop: module loaded
[ 1.053650] tegra_profiler: version: 1.141, samples/io: 48/28
[ 1.053742] tegra_profiler: auth: init
[ 1.054302] THERMAL EST: found 2 subdevs
[ 1.054307] THERMAL EST num_resources: 0
[ 1.054312] [THERMAL EST subdev 0]
[ 1.054317] [THERMAL EST subdev 1]
[ 1.054636] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[ 1.054639] THERMAL EST: thz register success.
[ 1.054732] THERMAL EST: end of probe, return err: 0
[ 1.055467] sd: No Scsi addr parsed to reserve index
[ 1.055495] hisi_sas: driver version v1.6
[ 1.056125] nvme nvme0: pci function 0000:01:00.0
[ 1.056166] nvme 0000:01:00.0: enabling device (0000 -> 0002)
[ 1.059236] tegra-qspi 70410000.spi: Prod settings list not found
[ 1.060058] qspi_mtd spi32766.0: MX25U3235F (4096 Kbytes)
[ 1.060067] qspi_mtd spi32766.0: mtd .name = spi32766.0, .size = 0x400000 (4MiB) .erasesize = 0x00001000 (4KiB) .numeraseregions = 0
[ 1.062298] libphy: Fixed MDIO Bus: probed
[ 1.062981] tun: Universal TUN/TAP device driver, 1.6
[ 1.062984] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.063664] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 1.063667] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.063714] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 1.063717] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 1.063760] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 1.063763] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 1.063808] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 1.063811] Copyright(c) 1999 - 2017 Intel Corporation.
[ 1.064468] r8168 0000:02:00.0: enabling device (0000 -> 0003)
[ 1.064486] r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded
[ 1.073148] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 1.073159] Extcon AUX1(HDMI) enable
[ 1.073689] tegradc tegradc.0: nominal-pclk:148351648 parent:148350781 div:1.0 pclk:148350781 146868084~161703244
[ 1.075764] tegradc tegradc.1: disp1 connected to head1->/host1x/sor
[ 1.075836] tegradc tegradc.1: No lt-data, using default setting
[ 1.075859] tegradc tegradc.1: No hpd-gpio in DT
[ 1.075897] tegradc tegradc.1: DT parsed successfully
[ 1.075933] tegradc tegradc.1: Display dc.ffffff800d480000 registered with id=1
[ 1.076904] tegradc tegradc.1: dpd enable lookup fail:-19
[ 1.078535] r8168 0000:02:00.0 (unnamed net_device) (uninitialized): Invalid ethernet address 00:00:00:00:00:00, trying device tree node
[ 1.078587] r8168 0000:02:00.0 (unnamed net_device) (uninitialized): Found valid ethernet address 00:04:4b:ec:aa:8b from device tree
[ 1.079019] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[ 1.079053] r8168 Copyright (C) 2017 Realtek NIC software team <nicfae@realtek.com>
This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
[ 1.079581] PPP generic driver version 2.4.2
[ 1.079720] PPP BSD Compression module registered
[ 1.079723] PPP Deflate Compression module registered
[ 1.079738] PPP MPPE Compression module registered
[ 1.079742] NET: Registered protocol family 24
[ 1.079793] usbcore: registered new interface driver r8152
[ 1.079841] usbcore: registered new interface driver asix
[ 1.079883] usbcore: registered new interface driver ax88179_178a
[ 1.079917] usbcore: registered new interface driver cdc_ether
[ 1.079952] usbcore: registered new interface driver net1080
[ 1.079985] usbcore: registered new interface driver cdc_subset
[ 1.080016] usbcore: registered new interface driver zaurus
[ 1.080068] usbcore: registered new interface driver cdc_ncm
[ 1.080215] VFIO - User Level meta-driver version: 0.3
[ 1.081247] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.081257] ehci-pci: EHCI PCI platform driver
[ 1.081297] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.081304] ohci-pci: OHCI PCI platform driver
[ 1.081343] ohci-platform: OHCI generic platform driver
[ 1.083275] li===> usb2.0 ports idx:0 mode:3
[ 1.083319] li===> usb2.0 ports idx:1 mode:1
[ 1.083376] li===> usb2.0 ports idx:2 mode:1
[ 1.083394] tegra-xusb 70090000.xusb: USB2 port 0 has OTG_CAP
[ 1.084007] tegra-xusb-padctl 7009f000.xusb_padctl: enabled OTG on UTMI pad 0
[ 1.085038] tegra-xusb 70090000.xusb: extcon 0: ffffffc0fa5d3c00 id
[ 1.086490] usbcore: registered new interface driver uas
[ 1.086545] usbcore: registered new interface driver usb-storage
[ 1.086628] usbcore: registered new interface driver usbserial
[ 1.086837] tegradc tegradc.1: probed
[ 1.087083] tegradc tegradc.1: fb registered
[ 1.087122] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-10-17 15:58:59 UTC, Version: 50.25 release
[ 1.087151] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 1.087168] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 1
[ 1.087887] tegra-xusb 70090000.xusb: hcc params 0x0184f525 hci version 0x100 quirks 0x00050010
[ 1.087923] tegra-xusb 70090000.xusb: irq 61, io mem 0x70090000
[ 1.088078] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.088085] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.088089] usb usb1: Product: xHCI Host Controller
[ 1.088094] usb usb1: Manufacturer: Linux 4.9.140 xhci-hcd
[ 1.088098] usb usb1: SerialNumber: 70090000.xusb
[ 1.088501] hub 1-0:1.0: USB hub found
[ 1.088535] hub 1-0:1.0: 5 ports detected
[ 1.089009] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 1.089019] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 2
[ 1.089088] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.089186] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.089192] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.089197] usb usb2: Product: xHCI Host Controller
[ 1.089201] usb usb2: Manufacturer: Linux 4.9.140 xhci-hcd
[ 1.089206] usb usb2: SerialNumber: 70090000.xusb
[ 1.090892] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 2
[ 1.091431] hub 2-0:1.0: USB hub found
[ 1.091464] hub 2-0:1.0: 4 ports detected
[ 1.091515] tegra-xudc-new 700d0000.xudc: device count: 1
[ 1.092351] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 1
[ 1.092444] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[ 1.092453] tegra-xudc-new 700d0000.xudc: vbus state: 1
[ 1.092464] tegra-xudc-new 700d0000.xudc: device mode on: 0
[ 1.092483] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 0
[ 1.092500] tegra-xudc-new 700d0000.xudc: active: 0 => 1
[ 1.092981] mousedev: PS/2 mouse device common for all mice
[ 1.093045] usbcore: registered new interface driver xpad
[ 1.093807] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 0
[ 1.095259] tegradc tegradc.1: dp: aux write got error (0x10000100)
[ 1.101568] tegradc tegradc.1: dp: Failed for I2C write addr:80, size:1, stat:0x10000100
[ 1.115775] tegradc tegradc.1: nominal-pclk:25200000 parent:25200000 div:1.0 pclk:25200000 24948000~27468000
[ 1.116478] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 2
[ 1.117929] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 1
[ 1.119325] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 0
[ 1.120775] tegradc tegradc.1: dp: aux write got error (0x10000100)
[ 1.127075] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[ 1.136046] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 2
[ 1.137495] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 1
[ 1.138944] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 0
[ 1.140394] tegradc tegradc.1: dp: aux write got error (0x10000100)
[ 1.146676] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[ 1.155533] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 2
[ 1.156982] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 1
[ 1.158430] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 0
[ 1.159749] tegradc tegradc.1: dp: aux write got error (0x10000100)
[ 1.166025] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[ 1.174985] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 2
[ 1.176464] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 1
[ 1.177924] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 0
[ 1.179397] tegradc tegradc.1: dp: aux write got error (0x10000100)
[ 1.185695] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[ 1.194090] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 1.194176] tegradc tegradc.1: dp: failed to exit panel power save mode (0xfffffff2)
[ 1.202044] hpd: state 7 (Takeover from bootloader), hpd 1, pending_hpd_evt 1
[ 1.202049] hpd: switching from state 7 (Takeover from bootloader) to state 1 (Check Plug)
[ 1.204212] nvme0n1: p1
[ 1.209818] tegradc tegradc.0: blank - powerdown
[ 1.223405] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 1.225540] rtc rtc1: alarm rtc device
[ 1.225553] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc1
[ 1.225570] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[ 1.225937] i2c /dev entries driver
[ 1.227217] ar0521 2-0036: probing v4l2 sensor at addr 0x36
[ 1.227329] li===> camera_common_parse_ports: port 2 num of lanes 4
[ 1.227445] ar0521 2-0036: tegracam sensor driver:ar0521_v2.0.6
[ 1.227450] ar0521 2-0036: camera_common_mclk_enable: enable MCLK with 24000000 Hz
[ 1.227477] ar0521 2-0036: ar0521_power_on: power on
[ 1.250599] li===> regmap_i2c_read: addr:0x36 reg_size:2 value_size:2
[ 1.250602] li===> reg:0x30 0x1a
[ 1.250793] tegra-i2c 7000c500.i2c: no acknowledge from address 0x36
[ 1.250822] ar0521 2-0036: ar0521_board_setup: error during i2c read probe (-121)
[ 1.250826] ar0521 2-0036: ar0521_power_off: power off
[ 1.250853] ar0521 2-0036: camera_common_mclk_disable: disable MCLK
[ 1.250868] ar0521 2-0036: board setup failed
[ 1.250933] ar0521: probe of 2-0036 failed with error -121
[ 1.250997] ar0521 6-0036: probing v4l2 sensor at addr 0x36
[ 1.251109] li===> camera_common_parse_ports: port 4 num of lanes 4
[ 1.251218] ar0521 6-0036: tegracam sensor driver:ar0521_v2.0.6
[ 1.251222] ar0521 6-0036: camera_common_mclk_enable: enable MCLK with 24000000 Hz
[ 1.251238] ar0521 6-0036: ar0521_power_on: power on
[ 1.257022] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 1.257024] Extcon AUX1(HDMI) disable
[ 1.274358] li===> regmap_i2c_read: addr:0x36 reg_size:2 value_size:2
[ 1.274360] li===> reg:0x30 0x1a
[ 1.274659] ar0521 6-0036: ar0521_power_off: power off
[ 1.274684] ar0521 6-0036: camera_common_mclk_disable: disable MCLK
[ 1.274733] ar0521 6-0036: li===> tegracam_init_ctrl_ranges_by_mode: modeidx:0 num_modes:2
[ 1.275238] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 1.277094] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[ 1.277099] tegra_soctherm 700e2000.soctherm: pllx_offset tz:2 max:8, min:4
[ 1.277397] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.277409] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[ 1.277417] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
[ 1.277554] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.277563] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[ 1.277569] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
[ 1.277719] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.277727] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[ 1.277731] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
[ 1.277920] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[ 1.278567] tegra_aotag tegra-aotag: Registering sensor 0
[ 1.278616] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.278636] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.278652] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[ 1.278660] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[ 1.279453] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.279467] tegra_dfll_action dfll-cdev-cap: Tegra DFLL 'cap cooling device' registered
[ 1.279620] tegra_aotag tegra-aotag: Invalid temp readout
[ 1.279641] tegra_dfll_action dfll-cdev-floor: Tegra DFLL 'floor cooling device' registered
[ 1.279974] parse_throttle_dt_data: Num cap clks = 6
[ 1.279978] parse_throttle_dt_data: clk=cclk_g type=2
[ 1.279985] parse_throttle_dt_data: clk=gpu type=4
[ 1.280004] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[ 1.280021] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[ 1.280041] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[ 1.280044] parse_throttle_dt_data: clk=emc type=3
[ 1.280335] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.280435] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.280543] tegra_throttle_probe: probe successful. #cdevs=4
[ 1.281142] FAN dev name: pwm-fan
[ 1.281190] FAN:gpio request success.
[ 1.281239] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 1.281476] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 1.281592] pwm_fan_driver pwm-fan: fan tach request irq success
[ 1.281598] pwm_fan_driver pwm-fan: tach period: 1000
[ 1.281670] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 1.281674] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 1.281678] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 1.281682] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 1.281685] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 1.281689] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 1.281692] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 1.281696] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 1.281700] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 1.281704] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 1.282266] tegra-wdt 60005100.watchdog: Tegra WDT enabled on probe. Timeout = 120 seconds.
[ 1.282586] tegra-wdt 60005100.watchdog: initialized (timeout = 120 sec, nowayout = 1)
[ 1.283397] device-mapper: uevent: version 1.0.3
[ 1.283793] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 1.286375] tegra210-cpufreq cpufreq: probe()...completed
[ 1.287080] sdhci: Secure Digital Host Controller Interface driver
[ 1.287081] sdhci: Copyright(c) Pierre Ossman
[ 1.287083] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.287278] tegradc tegradc.0: unblank
[ 1.287593] sdhci-tegra sdhci-tegra.0: Got CD GPIO
[ 1.288022] sdhci-tegra sdhci-tegra.0: Client registration for eMC Successful
[ 1.288142] sdhci-tegra sdhci-tegra.0: wakeup init done, cdirq 300
[ 1.293323] tegra-se 70012000.se: tegra_se_probe: complete
[ 1.294003] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.295820] usbcore: registered new interface driver usbhid
[ 1.295821] usbhid: USB HID core driver
[ 1.298050] tegra21x_actmon 6000c800.actmon: in actmon_register()...
[ 1.298213] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
[ 1.300081] nvpmodel: initialized successfully
[ 1.301024] usbcore: registered new interface driver snd-usb-audio
[ 1.301080] No Device Node present for smmu client: snd-soc-dummy !!
[ 1.301084] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 1.301101] iommu: Adding device snd-soc-dummy to group 36
[ 1.307361] hpd: state 1 (Check Plug), hpd 1, pending_hpd_evt 0
[ 1.307366] hpd: switching from state 1 (Check Plug) to state 2 (Check EDID)
[ 1.312887] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/card0/input0
[ 1.315328] hpd: state 2 (Check EDID), hpd 1, pending_hpd_evt 0
[ 1.315978] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 2
[ 1.317344] OPE platform probe
[ 1.317429] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 1
[ 1.317450] OPE platform probe successful
[ 1.317477] OPE platform probe
[ 1.317555] OPE platform probe successful
[ 1.318927] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 0
[ 1.320377] tegradc tegradc.1: dp: aux write got error (0x10000100)
[ 1.320381] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[ 1.321018] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 2
[ 1.322457] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 1
[ 1.323629] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 1.323681] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[ 1.323732] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 0
[ 1.324643] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 1.324650] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 1.325172] tegradc tegradc.1: dp: aux write got error (0x10000100)
[ 1.325175] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[ 1.325810] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 2
[ 1.327251] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 1
[ 1.328692] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 0
[ 1.330187] tegradc tegradc.1: dp: aux write got error (0x10000100)
[ 1.330190] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[ 1.330822] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 2
[ 1.332188] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 1
[ 1.333626] tegradc tegradc.1: dp: aux write retry (0x10000100) -- 0
[ 1.335062] tegradc tegradc.1: dp: aux write got error (0x10000100)
[ 1.335065] tegradc tegradc.1: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[ 1.335067] tegradc tegradc.1: dp: failed to exit panel power save mode (0xfffffff2)
[ 1.335072] hpd: edid read prepare failed
[ 1.335072] hpd: DC from connected to disconnected
[ 1.335360] mmc0: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADMA 64-bit with 64 bit addr
[ 1.340847] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 1.340961] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 1.341076] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 1.341190] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 1.341330] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 1.341444] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 1.341552] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 1.341663] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 1.341776] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 1.341886] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 1.353630] u32 classifier
[ 1.353631] Actions configured
[ 1.353699] Initializing XFRM netlink socket
[ 1.354404] NET: Registered protocol family 10
[ 1.355072] NET: Registered protocol family 17
[ 1.355082] NET: Registered protocol family 15
[ 1.355181] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 1.355227] Bluetooth: RFCOMM socket layer initialized
[ 1.355236] Bluetooth: RFCOMM ver 1.11
[ 1.355240] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.355244] Bluetooth: HIDP socket layer initialized
[ 1.355263] 9pnet: Installing 9P2000 support
[ 1.355296] Key type dns_resolver registered
[ 1.355732] Registered cp15_barrier emulation handler
[ 1.355737] Registered setend emulation handler
[ 1.359258] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 1.359260] Extcon AUX1(HDMI) enable
[ 1.359599] registered taskstats version 1
[ 1.360209] Adding domain ve2-pd to PM domain host1x-pd
[ 1.360455] Adding domain ve-pd to PM domain host1x-pd
[ 1.362373] isp 54600000.isp: initialized
[ 1.363314] isp 54680000.isp: initialized
[ 1.373298] last reset is due to power on reset
[ 1.373301] KERNEL: PMC reset status reg: 0x0
[ 1.373362] BL: PMC reset status reg: 0x0
[ 1.373364] BL: PMIC poweroff Event Recorder: 0x40
[ 1.374820] clk_cbus_recalc_rate: no gbus parent
[ 1.374825] clk_cbus_round_rate: no gbus parent
[ 1.374827] clk_cbus_round_rate: no gbus parent
[ 1.374833] clk_cbus_recalc_rate: no gbus parent
[ 1.374910] tegradc tegradc.0: sync windows ret = 247
[ 1.374936] clk_cbus_recalc_rate: no gbus parent
[ 1.374939] clk_cbus_round_rate: no gbus parent
[ 1.374941] clk_cbus_round_rate: no gbus parent
[ 1.374944] clk_cbus_recalc_rate: no gbus parent
[ 1.375658] tegra_dvfs: GPU-cap: registered
[ 1.375714] tegra dvfs: vdd-cpu: nominal 1168mV, offset 708000uV, step 19200uV, scaling enabled
[ 1.375716] tegra dvfs: vdd-core: nominal 1125mV, offset 600000uV, step 12500uV, scaling enabled
[ 1.375718] tegra dvfs: vdd-gpu: nominal 1068mV, offset 708000uV, step 10000uV, scaling enabled
[ 1.377006] tegra_dvfs: vdd-gpu-vts: registered
[ 1.377695] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS 'floor cooling device' registered
[ 1.378253] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS 'cap cooling device' registered
[ 1.378802] input: gpio-keys as /devices/gpio-keys/input/input1
[ 1.415110] usb 1-2: new full-speed USB device number 2 using tegra-xusb
[ 1.417382] tegra_rtc 7000e000.rtc: setting system clock to 2000-01-01 01:00:13 UTC (946688413)
[ 1.418353] vi 54080000.vi: vi_probe: ++
[ 1.421330] vi 54080000.vi: initialized
[ 1.421361] li===> csi->iomem: 0xffffff800d700838 0xffffff800d701038 0xffffff800d701838
[ 1.421363] li===> csi_port:4 pixel_parser:0xffffff800d701838 cil:0xffffff800d70192c tpg:0xffffff800d7019c4
[ 1.421365] li===> csi_port:2 pixel_parser:0xffffff800d701038 cil:0xffffff800d70112c tpg:0xffffff800d7011c4
[ 1.421367] li===> vi->num_channels:2
[ 1.424084] li===> vi init port:4 numlanes: 4
[ 1.424089] li===> tegra_channel_fmt_align width:1920 height:1080 denominator:1 numerator:2 fmt_align:2 align:2 bpl:3840
[ 1.424091] li===> tegra_channel_fmt_align bytesperline:3840 bpl:3840
[ 1.424094] li===> tegra_channel_fmt_align bpl :3840 32768 3840 stride_align:1 bytesperline:3840
[ 1.424100] li===> vi init port:2 numlanes: 4
[ 1.424103] li===> tegra_channel_fmt_align width:1920 height:1080 denominator:1 numerator:2 fmt_align:2 align:2 bpl:3840
[ 1.424105] li===> tegra_channel_fmt_align bytesperline:3840 bpl:3840
[ 1.424107] li===> tegra_channel_fmt_align bpl :3840 32768 3840 stride_align:1 bytesperline:3840
[ 1.424211] vi 54080000.vi: subdev nvcsi--2 bound
[ 1.424223] vi 54080000.vi: subdev ar0521 6-0036 bound
[ 1.424476] li===> tegra_channel_fmt_align width:2592 height:1944 denominator:1 numerator:2 fmt_align:2 align:2 bpl:5184
[ 1.424478] li===> tegra_channel_fmt_align bytesperline:5184 bpl:5184
[ 1.424480] li===> tegra_channel_fmt_align bpl :5184 32768 5184 stride_align:1 bytesperline:5184
[ 1.424553] li===> tegra_channel_fmt_align width:2592 height:1944 denominator:1 numerator:2 fmt_align:2 align:2 bpl:5184
[ 1.424554] li===> tegra_channel_fmt_align bytesperline:5184 bpl:5184
[ 1.424556] li===> tegra_channel_fmt_align bpl :5184 32768 5184 stride_align:1 bytesperline:5184
[ 1.424561] li===> tegra_channel_fmt_align width:2592 height:1944 denominator:1 numerator:2 fmt_align:2 align:2 bpl:5184
[ 1.424562] li===> tegra_channel_fmt_align bytesperline:5184 bpl:5184
[ 1.424564] li===> tegra_channel_fmt_align bpl :5184 32768 5184 stride_align:1 bytesperline:5184
[ 1.424569] li===> tegra_channel_fmt_align width:2592 height:1944 denominator:1 numerator:2 fmt_align:2 align:2 bpl:5184
[ 1.424571] li===> tegra_channel_fmt_align bytesperline:5184 bpl:5184
[ 1.424573] li===> tegra_channel_fmt_align bpl :5184 32768 5184 stride_align:1 bytesperline:5184
[ 1.426672] vi 54080000.vi: subdev nvcsi--1 bound
[ 1.427485] Disable partitions left on by BL
[ 1.427488] disb
[ 1.427527] bwmgr: missing cdev-type property
[ 1.427623] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 1.427628] DRAM derating cdev registered.
[ 1.428740] vdd-fan: disabling
[ 1.428742] vdd-usb-vbus: disabling
[ 1.428744] vdd-usb-vbus2: disabling
[ 1.428753] vddio-sdmmc3-ap: disabling
[ 1.428836] vdd-usb-hub-en: disabling
[ 1.428914] ALSA device list:
[ 1.428916] #0: tegra-hda at 0x70038000 irq 83
[ 1.428918] #1: tegra-snd-t210ref-mobile-rt565x
[ 1.441092] usb 1-2: New USB device found, idVendor=062a, idProduct=4101
[ 1.441096] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.441098] usb 1-2: Product: 2.4G Keyboard Mouse
[ 1.441100] usb 1-2: Manufacturer: MOSART Semi.
[ 1.443206] input: MOSART Semi. 2.4G Keyboard Mouse as /devices/70090000.xusb/usb1/1-2/1-2:1.0/0003:062A:4101.0001/input/input2
[ 1.481397] extcon-disp-state extcon:disp-state: cable 51 state 1
[ 1.481400] Extcon HDMI: HPD enabled
[ 1.481421] tegradc tegradc.0: hdmi: plugged
[ 1.484401] Freeing unused kernel memory: 8512K
[ 1.503575] hid-generic 0003:062A:4101.0001: input,hidraw0: USB HID v1.10 Keyboard [MOSART Semi. 2.4G Keyboard Mouse] on usb-70090000.xusb-2/input0
[ 1.505983] input: MOSART Semi. 2.4G Keyboard Mouse as /devices/70090000.xusb/usb1/1-2/1-2:1.1/0003:062A:4101.0002/input/input3
[ 1.510516] Root device found: mmcblk0p1
[ 1.534145] mmc0: hw tuning done ...
[ 1.534179] mmc0: new ultra high speed SDR104 SDXC card at address 5048
[ 1.534500] mmcblk0: mmc0:5048 SD128 119 GiB
[ 1.538883] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14
[ 1.567583] hid-generic 0003:062A:4101.0002: input,hidraw1: USB HID v1.10 Mouse [MOSART Semi. 2.4G Keyboard Mouse] on usb-70090000.xusb-2/input1
[ 1.715158] Found dev node: /dev/mmcblk0p1
[ 2.039129] tegra_cec 70015000.tegra_cec: physical address: 10:00.
[ 2.103699] tegra_cec 70015000.tegra_cec: Sent <Text View On> res: -113.
[ 2.103702] tegra_cec 70015000.tegra_cec: tegra_cec_init Done.
[ 2.211670] EXT4-fs (mmcblk0p1): 14 orphan inodes deleted
[ 2.211673] EXT4-fs (mmcblk0p1): recovery complete
[ 2.228757] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 2.229475] Rootfs mounted over mmcblk0p1
[ 2.245899] Switching from initrd to actual rootfs
[ 2.363571] tegradc tegradc.1: blank - powerdown
[ 2.363582] extcon-disp-state extcon:disp-state: cable 44 state 0 already set.
[ 2.363584] Extcon DP: HPD disabled
[ 2.363587] hpd: hpd_switch 0
[ 2.363590] hpd: switching from state 2 (Check EDID) to state 3 (Disabled)
[ 2.467466] systemd[1]: System time before build time, advancing clock.
[ 2.518326] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 2.530739] cgroup: cgroup2: unknown option "nsdelegate"
[ 2.554336] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 2.555150] systemd[1]: Detected architecture arm64.
[ 2.578963] systemd[1]: Set hostname to <nano-desktop>.
[ 2.705371] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 2.705381] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 2.841496] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.841725] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 2.841808] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.841827] systemd[1]: Reached target Swap.
[ 2.841864] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.843464] systemd[1]: Created slice System Slice.
[ 2.843781] systemd[1]: Listening on Journal Socket.
[ 2.845862] systemd[1]: Mounting RPC Pipe File System...
[ 2.890512] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 3.197095] systemd-journald[1998]: Received request to flush runtime journal from PID 1
[ 4.337241] ar0521 6-0036: ar0521_open:
[ 4.343702] ar0521 6-0036: camera_common_mclk_enable: enable MCLK with 24000000 Hz
[ 4.344299] ar0521 6-0036: ar0521_power_on: power on
[ 4.375006] li===> regmap_i2c_read: addr:0x36 reg_size:2 value_size:2
[ 4.375011] li===> reg:0x31 0xfe
[ 4.501833] ===ar0521_reg_30fps_init OK!===
[ 4.501844] ar0521 6-0036: li===> tegracam_init_ctrl_ranges_by_mode: modeidx:0 num_modes:2
[ 4.502204] ar0521 6-0036: ar0521_power_off: power off
[ 4.502291] ar0521 6-0036: camera_common_mclk_disable: disable MCLK
[ 4.502316] li===> tegra_vi2_power_on: ret:0
[ 4.502326] ar0521 6-0036: camera_common_mclk_enable: enable MCLK with 24000000 Hz
[ 4.502396] ar0521 6-0036: ar0521_power_on: power on
[ 4.525987] li===> vi2_power_on: ret:0
[ 4.526193] ar0521 6-0036: ar0521_power_off: power off
[ 4.526905] ar0521 6-0036: camera_common_mclk_disable: disable MCLK
[ 4.639435] random: crng init done
[ 4.639440] random: 7 urandom warning(s) missed due to ratelimiting
[ 4.759518] nvgpu: 57000000.gpu gm20b_init_clk_setup_sw:1268 [INFO] GPCPLL initial settings: NA mode, M=1, N=34, P=3 (id = 1)
[ 4.803828] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 4.803852] cpu-throttle-alert cooling device registered.
[ 4.803987] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 4.804002] gpu-throttle-alert cooling device registered.
[ 4.804155] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 4.804167] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 4.804180] hot-surface-alert cooling device registered.
[ 5.251570] tegra-xusb 70090000.xusb: Upgrade port 0 to USB3.0
[ 5.251577] tegra-xusb 70090000.xusb: Upgrade port 1 to USB3.0
[ 5.359525] usb usb2: usb_suspend_both: status 0
[ 5.556976] using random self ethernet address
[ 5.561696] using random host ethernet address
[ 6.185740] Mass Storage Function, version: 2009/09/11
[ 6.185747] LUN: removable file: (no medium)
[ 6.193493] using random self ethernet address
[ 6.198055] using random host ethernet address
[ 6.261297] rndis0: HOST MAC ba:49:56:2a:d5:a8
[ 6.261814] rndis0: MAC ba:49:56:2a:d5:a9
[ 6.263792] usb0: HOST MAC ba:49:56:2a:d5:aa
[ 6.263829] usb0: MAC ba:49:56:2a:d5:ab
[ 6.263861] tegra-xudc-new 700d0000.xudc: ep 0 (type: 0, dir: out) enabled
[ 6.269096] l4tbr0: port 1(rndis0) entered blocking state
[ 6.269101] l4tbr0: port 1(rndis0) entered disabled state
[ 6.269928] device rndis0 entered promiscuous mode
[ 6.295150] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 6.308410] l4tbr0: port 2(usb0) entered blocking state
[ 6.308416] l4tbr0: port 2(usb0) entered disabled state
[ 6.309011] device usb0 entered promiscuous mode
[ 6.333345] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 7.219537] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 7.220635] eth0: 0xffffff800a36e000, 00:04:4b:ec:aa:8b, IRQ 407
[ 7.258621] zram: Added device: zram0
[ 7.263671] zram: Added device: zram1
[ 7.270255] zram: Added device: zram2
[ 7.275512] zram: Added device: zram3
[ 7.292649] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 7.314756] zram0: detected capacity change from 0 to 518615040
[ 7.388629] Adding 506456k swap on /dev/zram0. Priority:5 extents:1 across:506456k SS
[ 7.401816] zram1: detected capacity change from 0 to 518615040
[ 7.425448] Adding 506456k swap on /dev/zram1. Priority:5 extents:1 across:506456k SS
[ 7.429172] zram2: detected capacity change from 0 to 518615040
[ 7.449002] Adding 506456k swap on /dev/zram2. Priority:5 extents:1 across:506456k SS
[ 7.457525] zram3: detected capacity change from 0 to 518615040
[ 7.474664] Adding 506456k swap on /dev/zram3. Priority:5 extents:1 across:506456k SS
[ 9.073020] tegradc tegradc.0: blank - powerdown
[ 9.124962] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 9.124970] Extcon AUX1(HDMI) disable
[ 9.145305] tegradc tegradc.0: unblank
[ 9.155036] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 9.155133] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[ 9.156138] tegradc tegradc.0: hdmi: get RGB quant from EDID.
[ 9.156144] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 9.194242] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 9.194246] Extcon AUX1(HDMI) enable
[ 9.199338] tegradc tegradc.0: unblank
[ 9.199347] tegradc tegradc.1: blank - powerdown
[ 10.461447] fuse init (API version 7.26)
[ 11.383170] r8168: eth0: link up
[ 11.383211] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 12.878732] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 12.878743] Bluetooth: BNEP socket layer initialized
[ 14.543596] tegradc tegradc.0: unblank
[ 14.543606] tegradc tegradc.1: blank - powerdown
[ 117.278571] ar0521 6-0036: camera_common_mclk_enable: enable MCLK with 24000000 Hz
[ 117.278652] ar0521 6-0036: ar0521_power_on: power on
[ 117.383240] ===ar0521_reg_30fps_init OK!===
[ 117.383252] ar0521 6-0036: li===> tegracam_init_ctrl_ranges_by_mode: modeidx:0 num_modes:2
[ 117.383634] ar0521 6-0036: ar0521_power_off: power off
[ 117.383728] ar0521 6-0036: camera_common_mclk_disable: disable MCLK
[ 117.383753] li===> tegra_vi2_power_on: ret:0
[ 117.383766] ar0521 6-0036: camera_common_mclk_enable: enable MCLK with 24000000 Hz
[ 117.383843] ar0521 6-0036: ar0521_power_on: power on
[ 117.407033] li===> vi2_power_on: ret:0
[ 117.407508] ar0521 6-0036: ar0521_power_off: power off
[ 117.407638] ar0521 6-0036: camera_common_mclk_disable: disable MCLK
[ 117.413483] li===> tegra_vi2_power_on: ret:0
[ 117.413508] ar0521 6-0036: camera_common_mclk_enable: enable MCLK with 24000000 Hz
[ 117.413789] ar0521 6-0036: ar0521_power_on: power on
[ 117.437122] li===> vi2_power_on: ret:0
[ 117.437605] ar0521 6-0036: ar0521_power_off: power off
[ 117.437979] ar0521 6-0036: camera_common_mclk_disable: disable MCLK
[ 117.470129] li===> tegra_vi2_power_on: ret:0
[ 117.470155] ar0521 6-0036: camera_common_mclk_enable: enable MCLK with 24000000 Hz
[ 117.470275] ar0521 6-0036: ar0521_power_on: power on
[ 117.493514] li===> vi2_power_on: ret:0
[ 117.493598] ar0521 6-0036: ar0521_power_off: power off
[ 117.493875] ar0521 6-0036: camera_common_mclk_disable: disable MCLK
