My nano 2GB, can't capture video. when I try the command in official tutorial
It’s weird, my camera is c270
It’s ok using
nvgstcapture-1.0 --camsrc=0 --cap-dev-node=0
but for this command to capture video
nvgstcapture-1.0 --mode=2 --camsrc=0 --cap-dev-node=0
it gave me something “Segmentation fault (core dumped)”
v4l2-ctl --list-devices --list-formats
show
UVC Camera (046d:0825) (usb-70090000.xusb-2):
/dev/video0
ioctl: VIDIOC_ENUM_FMT
Index : 0
Type : Video Capture
Pixel Format: ‘YUYV’
Index       : 1
Pixel Format: 'MJPG' (compressed)
v4l2-ctl --list-formats-ext
show
Index : 0
Interval: Discrete 0.033s (30.000 fps)
Interval: Discrete 0.040s (25.000 fps)
Interval: Discrete 0.050s (20.000 fps)
Interval: Discrete 0.067s (15.000 fps)
Interval: Discrete 0.100s (10.000 fps)
Interval: Discrete 0.200s (5.000 fps)
Interval: Discrete 0.133s (7.500 fps)
Index       : 1
detailed information when I try to capture video
Encoder null, cannot set bitrate!
Encoder Profile = High
Runtime USB Camera Commands:
Help : ‘h’
Quit : ‘q’
Set Capture Mode:
mo:
(1): image
(2): video
Get Capture Mode:
gmo
Capture: enter ‘j’ OR
followed by a timer (e.g., jx5000, capture after 5 seconds) OR
followed by multishot count (e.g., j:6, capture 6 images)
timer/multihot values are optional, capture defaults to single shot with timer=0s
Start Recording : enter ‘1’
Stop Recording : enter ‘0’
Set Preview Resolution:
pcr: e.g., pcr:2
(0) : 176x144
(1) : 320x240
(2) : 640x480
(3) : 1280x720
(4) : 1920x1080
NOTE: Preview/Encode resolution will be same as Capture resolution for USB-Camera
Get Preview Resolution:
gpcr
Get Image Capture Resolution:
gicr
Get Video Capture Resolution:
gvcr
Set Capture Device Node:
cdn: e.g., cdn:0
(0): /dev/video0
(1): /dev/video1
(2): /dev/video2
Get Capture Device Node:
gcdn
Runtime encoder configuration options:
Set Encoding Bit-rate(in bytes):
br: e.g., br:4000000
Get Encoding Bit-rate(in bytes):
gbr
Set Encoding Profile(only for H.264):
ep: e.g., ep:1
(0): Baseline
(1): Main
(2): High
Get Encoding Profile(only for H.264):
gep
Force IDR Frame on video Encoder(only for H.264):
Enter ‘f’
bitrate = 4000000
Encoder control-rate = 1
Encoder EnableTwopassCBR = 0
Opening in BLOCKING MODE
I searched all over the forum , but seems only me who have this issue :(
Can you check the core dumped in dmesg.
Also try add --video-res=3 in command like to try.
Hi CCC
I tried this
nvgstcapture-1.0 --mode=2 --camsrc=0 --cap-dev-node=0   --video-res=3
result is
bitrate = 8000000
below is core dump (I copy part of them, if it is too less to analyze, I will get more later :) )
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.201-tegra (buildbrain@mobile-u64-5486-d4000) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Wed May 5 09:31:36 PDT 2021
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 3f800000
[ 0.000000] OF: fdt: - bfa00000 , 3fe00000
[ 0.000000] OF: fdt: - ffa00000 , 600000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000070006000 (options ‘’)
[ 0.000000] bootconsole [uart8250] enabled
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb0_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb1_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node iram-carveout, compatible id nvidia,iram-carveout
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fb800000
[ 0.000000] On node 0 totalpages: 522752
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 522752 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 24 pages/cpu s57560 r8192 d32552 u98304
[ 0.000000] pcpu-alloc: s57560 r8192 d32552 u98304 alloc=24*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] CPU features: enabling workaround for ARM erratum 832075
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 514560
[ 0.000000] Kernel command line: tegraid=21.1.2.0.0 ddr_die=2048M@2048M section=256M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 core_edp_mv=1075 core_edp_ma=4000 gpt earlycon=uart8250,mmio32,0x70006000 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
Did see the core dump information from the post.
Do you mean this information?
dmesg | more
[    0.000000] earlycon: uart8250 at MMIO32 0x0000000070006000 (options '')
[    0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb0_carveout': base 0x0000000000000000, size 0 MiB
[    0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB
ames=0
[    0.000000] log_buf_len total cpu_extra contributions: 98304 bytes
[    0.000000] log_buf_len min size: 32768 bytes
[    0.000000] log_buf_len: 131072 bytes
[    0.000000] early log buf free: 29556(90%)
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.000000] Memory: 1946276K/2091008K available (15294K kernel code, 2942K rwdata, 6664K rodata, 8576K init, 609K bss, 7919
6K reserved, 65536K cma-reserved)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
[    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000   (   250 GB)
[    0.000000]       .text : 0xffffff8008080000 - 0xffffff8008f70000   ( 15296 KB)
[    0.000000]     .rodata : 0xffffff8008f70000 - 0xffffff8009600000   (  6720 KB)
[    0.000000]       .init : 0xffffff8009600000 - 0xffffff8009e60000   (  8576 KB)
[    0.000000]       .data : 0xffffff8009e60000 - 0xffffff800a13f808   (  2943 KB)
[    0.000000]        .bss : 0xffffff800a13f808 - 0xffffff800a1d7cbc   (   610 KB)
[    0.000000]     fixed   : 0xffffffbefe7fd000 - 0xffffffbefec00000   (  4108 KB)
[    0.000000]     PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000   (    16 MB)
[    0.000000]     vmemmap : 0xffffffbf00000000 - 0xffffffc000000000   (     4 GB maximum)
[    0.000000]               0xffffffbf00000000 - 0xffffffbf02000000   (    32 MB actual)
[    0.000000]     memory  : 0xffffffc000000000 - 0xffffffc080000000   (  2048 MB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] 	Build-time adjustment of leaf fanout to 64.
[    0.000000] 	RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /interrupt-controller
[    0.000000] t210 clock and reset probe
[    0.000000] tegra-pmc: get_secure_pmc_setting: done secure_pmc=1
[    0.000000] clk_cbus_recalc_rate: no gbus parent
[    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[    0.000006] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[    0.001783] Console: colour dummy device 80x25
[    0.001793] console [tty0] enabled
[    0.001799] bootconsole [uart8250] disabled
[    0.001815] kmemleak: Kernel memory leak detector disabled
[    0.001832] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=76800)
[    0.001845] pid_max: default: 32768 minimum: 301
[    0.002297] Security Framework initialized
[    0.002513] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[    0.002519] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[    0.003596] ftrace: allocating 47208 entries in 185 pages
[    0.172297] sched-energy: CPU device node has no sched-energy-costs
[    0.172329] ASID allocator initialised with 65536 entries
[    0.211824] tegra-id: chipid=22117.
[    0.211838] tegra-id: opt_subrevision=0.
[    0.211854] Tegra Speedo/IDDQ fuse revision 4
[    0.211860] Tegra: CPU Speedo ID 9, SoC Speedo ID 0, GPU Speedo ID 2
[    0.211865] Tegra: CPU Process ID 0, SoC Process ID 1, GPU Process ID 0
[    0.211870] Tegra: CPU Speedo Value 2057, SoC Speedo Value 1955, GPU Speedo Value 2069
[    0.211874] Tegra: CPU IDDQ Value 2292, SoC IDDQ Value 2468, GPU IDDQ Value 3075
[    0.211893] Tegra Revision: A02 SKU: 0x8f CPU Process: 0 SoC Process: 1
[    0.211908] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware
/nvidia/platform/t210/batuu/kernel-dts/tegra210-p3448-0003-p3542-0000.dts
[    0.211915] DTB Build time: Jun 14 2021 11:45:04
[    0.261039] CPU1: Booted secondary processor [411fd071]
[    0.292941] CPU2: Booted secondary processor [411fd071]
[    0.324917] CPU3: Booted secondary processor [411fd071]
[    0.325013] Brought up 4 CPUs
[    0.325019] SMP: Total of 4 processors activated.
[    0.325027] CPU features: detected feature: 32-bit EL0 Support
[    0.325290] CPU: All CPU(s) started at EL2
[    0.325307] alternatives: patching kernel code
[    0.332717] devtmpfs: initialized
[    0.373160] Initilizing CustomIPI irq domain
[    0.373545] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.373566] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.375275] pinctrl core: initialized pinctrl subsystem
[    0.375703] OS set in device tree is not L4T.
[    0.376063] regulator-dummy: no parameters
[    0.376314] Initializing plugin-manager
[    0.376450] Plugin module not found
[    0.376780] node /plugin-manager/fragment@1 match with board >=3448-0003-400
[    0.377994] node /plugin-manager/fragement@7 match with odm-data enable-pmic-wdt
[    0.378204] node /plugin-manager/fragement@8 match with odm-data enable-pmic-wdt
[    0.378606] node /plugin-manager/fragement@9 match with board >=3448-0003-000
[    0.379905] node /plugin-manager/fragment@12 match with board >=3448-0003-400
[    0.380164] node /plugin-manager/fragement@13 match with board >=3448-0003-400
[    0.383837] NET: Registered protocol family 16
[    0.385273] pstore: using zlib compression
[    0.385306] console [pstore-1] enabled
[    0.385310] pstore: Registered ramoops as persistent store backend
[    0.385316] ramoops: attached 0x200000@0xb0000000, ecc: 0/0
[    0.401056] cpuidle: using governor menu
[    0.404235] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[    0.406132] vdso: 2 pages (1 code @ ffffff8008f77000, 1 data @ ffffff8009e64000)
[    0.406153] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.409446] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[    0.412006] Serial: AMBA PL011 UART driver
[    0.412510] tegra_powergate_init: DONE
[    0.412526] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware
[    0.412533] DTB Build time: Jun 14 2021 11:45:04
[    0.414549] Tegra reboot handler registered.
[    0.419107] iommu: Adding device tegra-carveouts to group 0
[    0.419217] platform tegra-carveouts: domain=ffffffc078be5258 allocates as[0]=ffffffc0784400a8
[    0.419570] iommu: Adding device smmu_test to group 1
[    0.419615] platform smmu_test: domain=ffffffc078be5498 allocates as[0]=ffffffc078440110
[    0.420425] mc: mapped MMIO address: 0xffffff800802e000 -> 0x70019000
[    0.420478] mc: mapped MMIO address: 0xffffff8008065000 -> 0x7001c000
[    0.420533] mc: mapped MMIO address: 0xffffff8008079000 -> 0x7001d000
[    0.420543] nv-tegra-mc 70019000.mc: No mssnvlink node
[    0.420577] mc-err: mcerr ops are set to t21x
[    0.430975] iommu: Adding device 70090000.xusb to group 2
[    0.431271] iommu: Adding device 70006000.serial to group 3
[    0.431325] platform 70006000.serial: domain=ffffffc078478558 allocates as[0]=ffffffc078440178
[    0.431735] iommu: Adding device 70006040.serial to group 4
[    0.431996] iommu: Adding device 70006200.serial to group 5
[    0.432216] iommu: Adding device sound to group 6
[    0.432266] platform sound: domain=ffffffc078478a98 allocates as[0]=ffffffc0784401e0
[    0.432800] iommu: Adding device 7000d400.spi to group 7
[    0.433071] iommu: Adding device 7000d600.spi to group 8
[    0.433343] iommu: Adding device 70410000.spi to group 9
[    0.433639] iommu: Adding device 50000000.host1x to group 10
[    0.433909] iommu: Adding device 54080000.vi to group 11
[    0.434293] iommu: Adding device 54600000.isp to group 12
[    0.434553] iommu: Adding device 54680000.isp to group 13
[    0.434853] iommu: Adding device tegradc.0 to group 14
[    0.434907] platform tegradc.0: domain=ffffffc0784ec9d8 allocates as[0]=ffffffc078440248
[    0.435260] iommu: Adding device 54340000.vic to group 15
[    0.435452] iommu: Adding device 544c0000.nvenc to group 16
[    0.435639] iommu: Adding device 54500000.tsec to group 17
[    0.435833] iommu: Adding device 54100000.tsecb to group 18
[    0.436042] iommu: Adding device 54480000.nvdec to group 19
[    0.436228] iommu: Adding device 54380000.nvjpg to group 20
[    0.436918] iommu: Adding device 546c0000.i2c to group 21
[    0.437326] iommu: Adding device 57000000.gpu to group 22
[    0.437376] platform 57000000.gpu: domain=ffffffc0784f7858 allocates as[0]=ffffffc0784402b0
[    0.437425] platform 57000000.gpu: domain=ffffffc0784f7858 allocates as[1]=ffffffc078440318
[    0.437463] platform 57000000.gpu: domain=ffffffc0784f7858 allocates as[2]=ffffffc078440380
[    0.437502] platform 57000000.gpu: domain=ffffffc0784f7858 allocates as[3]=ffffffc0784403e8
[    0.438326] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency thermal reset disabled.
[    0.438337] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
[    0.438349] tegra-pmc: ### PMC reset source: TEGRA_SOFTWARE_RESET
[    0.438353] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_WARM
[    0.438356] tegra-pmc: ### PMC reset status reg: 0x3
[    0.489132] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[    0.489140] tegra-pmc: Clear bootloader IO dpd settings
[    0.489160] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
[    0.489225] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset commands
[    0.489526] iommu: Adding device 70012000.se to group 23
[    0.490295] iommu: Adding device 7000c000.i2c to group 24
[    0.490541] iommu: Adding device 7000c400.i2c to group 25
[    0.490792] iommu: Adding device 7000c500.i2c to group 26
[    0.491040] iommu: Adding device 7000c700.i2c to group 27
[    0.491292] iommu: Adding device 7000d000.i2c to group 28
[    0.491539] iommu: Adding device 7000d100.i2c to group 29
[    0.491848] iommu: Adding device sdhci-tegra.0 to group 30
[    0.491902] platform sdhci-tegra.0: domain=ffffffc0785879d8 allocates as[0]=ffffffc078440450
[    0.492701] iommu: Adding device 700d0000.xudc to group 31
[    0.496140] vdd-ac-bat: 5000 mV
[    0.496529] vdd-5v0-sys: 5000 mV
[    0.497475] vdd-5v0-hdmi: supplied by vdd-5v0-sys
[    0.497518] vdd-5v0-hdmi: 5000 mV
[    0.497949] vdd-1v8-sys: 1800 mV
[    0.498335] vdd-fan: supplied by vdd-5v0-sys
[    0.498367] vdd-fan: 5000 mV
[    0.498728] vdd-usb-vbus: supplied by vdd-5v0-sys
[    0.498760] vdd-usb-vbus: 5000 mV
[    0.499303] vdd-usb-vbus2: 5000 mV
[    0.533972] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[    0.536316] gpio gpiochip0: gpio-line-names specifies 240 line names but there are 256 lines on the chip
[    0.537474] GPIO line 151 (camera-control-output-low) hogged as output/low
[    0.537494] GPIO line 152 (camera-control-output-low) hogged as output/low
[    0.537532] GPIO line 6 (system-suspend-gpio) hogged as output/high
[    0.537876] gpiochip_setup_dev: registered GPIOs 0 to 255 on device: gpiochip0 (tegra-gpio)
[    0.545783] eventlib_kernel: keventlib is initialized, test id: 0
[    0.546119] SCSI subsystem initialized
[    0.546339] libata version 3.00 loaded.
[    0.546606] usbcore: registered new interface driver usbfs
[    0.546658] usbcore: registered new interface driver hub
[    0.546736] usbcore: registered new device driver usb
[    0.550635] max77620 4-003c: PMIC Version OTP:0x35 and ES:0x8
[    0.557157] vdd-core: 600 <--> 1162 mV at 1075 mV
[    0.558088] vdd-ddr-1v1: Bringing 1125000uV into 1150000-1150000uV
[    0.558182] random: fast init done
[    0.561057] vdd-ddr-1v1: 1150 mV
[    0.565054] vdd-pre-reg-1v35: 1350 mV
[    0.569056] vdd-1v8: 1800 mV
[    0.573053] avdd-sys-1v2: 1200 mV
[    0.577053] vdd-pex-1v0: 1050 mV
[    0.577715] vddio-sdmmc-ap: 1800 <--> 3300 mV at 3300 mV
[    0.578250] max77620-ldo3: at 3100 mV
[    0.581055] vdd-rtc: 850 <--> 1100 mV at 1000 mV
[    0.581587] max77620-ldo5: at 3100 mV
[    0.582131] max77620-ldo6: at 2800 mV
[    0.585053] avdd-1v05-pll: 1050 mV
[    0.589051] avdd-io-hdmi-dp: 1050 mV
[    0.591505] GPIO line 505 (spmic-default-output-high) hogged as output/high
[    0.591769] gpiochip_setup_dev: registered GPIOs 504 to 511 on device: gpiochip1 (max77620-gpio)
[    0.592048] max77620 4-003c: max77620 probe successful
[    0.594665] media: Linux media interface: v0.10
[    0.594715] Linux video capture interface: v2.00
[    0.595658] pps_core: LinuxPPS API ver. 1 registered
[    0.595664] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.595686] PTP clock support registered
[    0.599101] tegra210-emc 7001b000.external-memory-controller: validated EMC DFS table
[    0.599926] Advanced Linux Sound Architecture Driver Initialized.
[    0.600564] Bluetooth: Core ver 2.22
[    0.600672] NET: Registered protocol family 31
[    0.600678] Bluetooth: HCI device and connection manager initialized
[    0.600690] Bluetooth: HCI socket layer initialized
[    0.600698] Bluetooth: L2CAP socket layer initialized
[    0.600724] Bluetooth: SCO socket layer initialized
[    0.602389] tegra210_dvfs: no clock found for sdmmc2_ddr
[    0.602407] tegra210_dvfs: no clock found for sdmmc4_ddr
[    0.602453] tegra210_dvfs: no clock found for sdmmc1_ddr
[    0.602468] tegra210_dvfs: no clock found for sdmmc3_ddr
[    0.606110] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering probe
[    0.607420] vdd-3v3-sys: supplied by vdd-5v0-sys
[    0.607480] vdd-3v3-sys: 3300 mV
[    0.607757] vdd-1v8-sys: supplied by vdd-3v3-sys
[    0.609039] vdd-usb-vbus2: supplied by vdd-3v3-sys
[    0.609530] vdd-3v3-sd: supplied by vdd-3v3-sys
[    0.609577] vdd-3v3-sd: 3300 mV
[    0.610505] avdd-io-edp-1v05: supplied by avdd-1v05-pll
[    0.610553] avdd-io-edp-1v05: 1050 mV
[    0.611032] vdd-usb-hub-en: supplied by vdd-1v8-sys
[    0.611070] vdd-usb-hub-en: 5000 mV
[    0.612544] camchar: rtcpu character device driver loaded
[    0.613255] extcon-gpio-states extcon:extcon@1: Cable state:0, cable id:0
[    0.614582] clocksource: Switched to clocksource arch_sys_counter
[    0.654349] VFS: Disk quotas dquot_6.6.0
[    0.654486] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.655049] nvmap_heap_init: nvmap_heap_init: created heap block cache
[    0.655460] nvmap: nvmap_select_cache_ops() nvmap cache ops set to set/ways
[    0.655471] nvmap_page_pool_init: Total RAM pages: 502953
[    0.655476] nvmap_page_pool_init: nvmap page pool size: 62869 pages (245 MB)
[    0.655607] nvmap_background_zero_thread: PP zeroing thread starting.
[    0.655873] misc nvmap: iram :dma coherent mem declare 0x0000000040001000,258048
[    0.656042] misc nvmap: created heap iram base 0x0000000040001000 size (252KiB)
[    0.665346] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[    0.665851] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[    0.666236] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[    0.666523] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[    0.666750] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[    0.667037] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[    0.667042] pre_t19x_iso_plat_init(): max_iso_bw=11520000KB
[    0.667487] NET: Registered protocol family 2
[    0.668459] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[    0.668570] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[    0.668820] TCP: Hash tables configured (established 16384 bind 16384)
[    0.668956] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[    0.668998] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[    0.669352] NET: Registered protocol family 1
[    0.670051] RPC: Registered named UNIX socket transport module.
[    0.670057] RPC: Registered udp transport module.
[    0.670060] RPC: Registered tcp transport module.
[    0.670064] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.670078] PCI: CLS 0 bytes, default 64
[    0.670296] Trying to unpack rootfs image as initramfs...
[    0.972462] Freeing initrd memory: 6992K
[    0.982225] host1x 50000000.host1x: initialized
[    0.984007] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    0.987222] audit: initializing netlink subsys (disabled)
[    0.987292] audit: type=2000 audit(0.839:1): initialized
[    0.988025] workingset: timestamp_bits=46 max_order=19 bucket_order=0
[    0.997865] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.999498] ntfs: driver 2.1.32 [Flags: R/W].
[    1.000285] 9p: Installing v9fs 9p2000 file system support
[    1.003549] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[    1.003688] io scheduler noop registered
[    1.003977] io scheduler cfq registered (default)
[    1.006997] gic 702f9000.agic: GIC IRQ controller registered
[    1.009976] iommu: Adding device 702ef000.adsp to group 32
[    1.018829] iommu: Adding device aconnect@702c0000:adsp_audio to group 33
[    1.018982] tegra-aconnect aconnect@702c0000: Tegra ACONNECT bus registered
[    1.019556] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_SKU_CALIB_0 = 0x9289413
[    1.019563] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_USB_CALIB_EXT_0 = 0x4
[    1.021197] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.0, lane = usb2-0, function = xusb
[    1.021301] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.1, lane = usb2-1, function = xusb
[    1.021390] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane = usb2-2, function = xusb
[    1.021579] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane = pcie-0, function = pcie-x1
[    1.021674] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane = pcie-1, function = pcie-x4
[    1.021759] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane = pcie-2, function = pcie-x4
[    1.021848] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane = pcie-3, function = pcie-x4
[    1.021933] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane = pcie-4, function = pcie-x4
[    1.022020] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane = pcie-5, function = xusb
[    1.022113] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane = pcie-6, function = xusb
[    1.022737] tegra-xusb-padctl 7009f000.xusb_padctl: failed to setup XUSB ports: -517
[    1.028875] tegra-pwm 7000a000.pwm: PWM clk cannot sleep in ops
[    1.030526] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[    1.032510] tegra-pcie 1003000.pcie: 4x1, 1x1 configuration
[    1.032553] tegra-pcie 1003000.pcie: PHY get deferred: -517
[    1.032560] tegra-pcie 1003000.pcie: failed to get PHYs: -517
[    1.033904] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[    1.034122] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=750000, max_bw=1500000
[    1.034349] Adding domain tsec-pd to PM domain host1x-pd
[    1.037403] tsec 54500000.tsec: initialized
[    1.038882] tsec 54100000.tsecb: initialized
[    1.039559] Adding domain nvdec-pd to PM domain host1x-pd
[    1.043073] nvdec 54480000.nvdec: initialized
[    1.044095] Adding domain vic03-pd to PM domain host1x-pd
[    1.044279] Adding domain msenc-pd to PM domain host1x-pd
[    1.044437] Adding domain nvjpg-pd to PM domain host1x-pd
[    1.048899] falcon 54340000.vic: initialized
[    1.050182] falcon 544c0000.nvenc: initialized
[    1.051543] falcon 54380000.nvjpg: initialized
[    1.055907] tegra_cec 70015000.tegra_cec: dt=1 start=0x70015000 end=0x70015FFF irq=95
[    1.055960] tegra_cec 70015000.tegra_cec: Enable clock result: 0.
[    1.055999] tegra_cec 70015000.tegra_cec: tegra_cec_init started
[    1.056013] tegradc tegradc.0: disp0 connected to head0->/host1x/sor1
[    1.056110] display board info: id 0x0, fab 0x0
[    1.056164] generic_infoframe_type: 0x87
[    1.056275] tegra_cec 70015000.tegra_cec: cec_add_sysfs ret=0
[    1.056282] tegra_cec 70015000.tegra_cec: probed
[    1.056306] tegradc tegradc.0: DT parsed successfully
[    1.056356] tegradc tegradc.0: Display dc.ffffff800ab80000 registered with id=0
[    1.059973] tegradc tegradc.0: probed
[    1.060678] Console: switching to colour frame buffer device 80x30
[    1.060714] tegradc tegradc.0: fb registered
[    1.064274] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
[    1.069395] tegra-adma 702e2000.adma: Tegra210 ADMA driver registered 22 channels
[    1.069995] tegra-fuse-burn 7000f800.efuse:efuse-burn: shutdown limit check disabled
[    1.070001] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initialized
[    1.070251] kfuse 7000fc00.kfuse: initialized
[    1.071224] tegra-pmc-iopower pmc-iopower: Regulator supply iopower-dbg-supply not available
[    1.072010] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[    1.072970] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[    1.072981] vdd-cpu: 708 <--> 1322 mV at 708 mV
[    1.073352] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator registration passed
[    1.074604] vdd-gpu: applied init 1000000uV constraint
[    1.074613] vdd-gpu: 708 <--> 1323 mV at 997 mV
[    1.074965] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator registration passed
[    1.078516] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    1.078658] No Device Node present for smmu client: serial8250 !!
[    1.078669] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[    1.078711] iommu: Adding device serial8250 to group 34
[    1.081024] console [ttyS0] disabled
[    1.081093] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 63, base_baud = 25500000) is a Tegra
[    1.081180] console [ttyS0] enabled
[    1.082053] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 64, base_baud = 0) is a TEGRA_UART
[    1.082324] serial-tegra 70006200.serial: RX in PIO mode
[    1.082414] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 65, base_baud = 0) is a TEGRA_UART
[    1.083435] [drm] Initialized
[    1.093812] brd: module loaded
[    1.099404] loop: module loaded
[    1.099506] tegra_profiler: version: 1.143, samples/io: 48/28
[    1.099629] tegra_profiler: auth: init
[    1.100977] THERMAL EST: found 2 subdevs
[    1.100988] THERMAL EST num_resources: 0
[    1.100995] [THERMAL EST subdev 0]
[    1.101001] [THERMAL EST subdev 1]
[    1.101442] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[    1.101446] THERMAL EST: thz register success.
[    1.101594] THERMAL EST: end of probe, return err: 0
[    1.102786] sd: No Scsi addr parsed to reserve index
[    1.102832] hisi_sas: driver version v1.6
[    1.107566] tegra-qspi 70410000.spi: Prod settings list not found
[    1.108692] qspi_mtd spi32766.0: MX25U3235F (4096 Kbytes)
[    1.108703] qspi_mtd spi32766.0: mtd .name = spi32766.0, .size = 0x400000 (4MiB) .erasesize = 0x00001000 (4KiB) .numerasere
gions = 0
[    1.111623] libphy: Fixed MDIO Bus: probed
[    1.112516] tun: Universal TUN/TAP device driver, 1.6
[    1.112522] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    1.113492] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[    1.113497] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    1.113546] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[    1.113549] igb: Copyright (c) 2007-2014 Intel Corporation.
[    1.113597] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[    1.113600] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    1.113657] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[    1.113660] Copyright(c) 1999 - 2017 Intel Corporation.
[    1.115180] PPP generic driver version 2.4.2
[    1.115396] PPP BSD Compression module registered
[    1.115402] PPP Deflate Compression module registered
[    1.115443] PPP MPPE Compression module registered
[    1.115450] NET: Registered protocol family 24
[    1.115530] usbcore: registered new interface driver r8152
[    1.115574] usbcore: registered new interface driver asix
[    1.115628] usbcore: registered new interface driver ax88179_178a
[    1.115670] usbcore: registered new interface driver cdc_ether
[    1.115710] usbcore: registered new interface driver net1080
[    1.115749] usbcore: registered new interface driver cdc_subset
[    1.115785] usbcore: registered new interface driver zaurus
[    1.115844] usbcore: registered new interface driver cdc_ncm
[    1.116015] VFIO - User Level meta-driver version: 0.3
[    1.117339] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.117362] ehci-pci: EHCI PCI platform driver
[    1.117410] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.117422] ohci-pci: OHCI PCI platform driver
[    1.117469] ohci-platform: OHCI generic platform driver
[    1.119241] usbcore: registered new interface driver uas
[    1.119307] usbcore: registered new interface driver usb-storage
[    1.119428] usbcore: registered new interface driver usbserial
[    1.123115] mousedev: PS/2 mouse device common for all mice
[    1.123204] usbcore: registered new interface driver xpad
[    1.252176] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[    1.254799] rtc rtc1: alarm rtc device
[    1.254824] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc1
[    1.254853] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[    1.255493] i2c /dev entries driver
[    1.257616] imx219 6-0010: tegracam sensor driver:imx219_v2.0.6
[    1.280947] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[    1.281029] imx219 6-0010: imx219_board_setup: error during i2c read probe (-121)
[    1.288674] imx219 6-0010: board setup failed
[    1.293127] imx219: probe of 6-0010 failed with error -121
[    1.294377] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[    1.297033] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[    1.297040] tegra_soctherm 700e2000.soctherm: pllx_offset tz:2 max:8, min:4
[    1.297523] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    1.297542] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[    1.297553] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
[    1.297698] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    1.297709] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[    1.297716] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
[    1.297870] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    1.297881] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[    1.297887] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
[    1.298083] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[    1.298932] tegra_aotag tegra-aotag: Registering sensor 0
[    1.298989] tegra_aotag tegra-aotag: Invalid temp readout
[    1.299013] tegra_aotag tegra-aotag: Invalid temp readout
[    1.299031] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[    1.299041] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[    1.300023] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    1.300045] tegra_dfll_action dfll-cdev-cap: Tegra DFLL 'cap cooling device' registered
[    1.300278] tegra_aotag tegra-aotag: Invalid temp readout
[    1.300309] tegra_dfll_action dfll-cdev-floor: Tegra DFLL 'floor cooling device' registered
[    1.300767] parse_throttle_dt_data: Num cap clks = 6
[    1.300774] parse_throttle_dt_data: clk=cclk_g type=2
[    1.300789] parse_throttle_dt_data: clk=gpu type=4
[    1.300816] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[    1.300836] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[    1.300859] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[    1.300863] parse_throttle_dt_data: clk=emc type=3
[    1.301301] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    1.301411] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    1.301581] tegra_throttle_probe: probe successful. #cdevs=4
[    1.302405] FAN dev name: pwm-fan
[    1.302475] FAN:gpio request success.
[    1.302547] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[    1.302890] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[    1.303068] pwm_fan_driver pwm-fan: fan tach request irq success
[    1.303079] pwm_fan_driver pwm-fan: tach period: 1000
[    1.303187] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[    1.303193] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[    1.303198] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[    1.303203] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[    1.303208] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[    1.303213] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[    1.303218] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[    1.303222] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[    1.303227] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[    1.303232] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[    1.305989] device-mapper: uevent: version 1.0.3
[    1.306492] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[    1.312190] tegra210-cpufreq cpufreq: probe()...completed
[    1.312896] sdhci: Secure Digital Host Controller Interface driver
[    1.312899] sdhci: Copyright(c) Pierre Ossman
[    1.312901] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.313368] sdhci-tegra sdhci-tegra.0: Got CD GPIO
[    1.313730] sdhci-tegra sdhci-tegra.0: Client registration for eMC Successful
[    1.313856] sdhci-tegra sdhci-tegra.0: wakeup init done, cdirq 298
[    1.318445] tegra-se 70012000.se: tegra_se_probe: complete
[    1.319024] hidraw: raw HID events driver (C) Jiri Kosina
[    1.320233] usbcore: registered new interface driver usbhid
[    1.320235] usbhid: USB HID core driver
[    1.321175] tegra21x_actmon 6000c800.actmon: in actmon_register()...
[    1.321358] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
[    1.323192] nvpmodel: initialized successfully
[    1.324267] usbcore: registered new interface driver snd-usb-audio
[    1.324326] No Device Node present for smmu client: snd-soc-dummy !!
[    1.324332] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[    1.324350] iommu: Adding device snd-soc-dummy to group 35
[    1.329843] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/card0/input0
[    1.348500] OPE platform probe
[    1.348587] OPE platform probe successful
[    1.348843] OPE platform probe
[    1.348922] OPE platform probe successful
[    1.362802] mmc0: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADMA 64-bit with 64 bit addr
[    1.372867] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[    1.373000] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[    1.373133] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[    1.373264] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[    1.373391] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[    1.373518] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[    1.373644] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[    1.373772] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[    1.373901] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[    1.374028] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[    1.385869] u32 classifier
[    1.385872]     Actions configured
[    1.385943] Initializing XFRM netlink socket
[    1.386665] NET: Registered protocol family 10
[    1.387341] NET: Registered protocol family 17
[    1.387352] NET: Registered protocol family 15
[    1.387427] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfil
ter if you need this.
[    1.387477] Bluetooth: RFCOMM socket layer initialized
[    1.387486] Bluetooth: RFCOMM ver 1.11
[    1.387491] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    1.387496] Bluetooth: HIDP socket layer initialized
[    1.387514] 9pnet: Installing 9P2000 support
[    1.387549] Key type dns_resolver registered
[    1.387919] Registered cp15_barrier emulation handler
[    1.387925] Registered setend emulation handler
[    1.388928] registered taskstats version 1
[    1.389444] Adding domain ve2-pd to PM domain host1x-pd
[    1.389692] Adding domain ve-pd to PM domain host1x-pd
[    1.391886] isp 54600000.isp: initialized
[    1.392866] isp 54680000.isp: initialized
[    1.403093] last reset is due to software reset
[    1.403097] KERNEL: PMC reset status reg: 0x3
[    1.403156] BL: PMC reset status reg: 0x3
[    1.403159] BL: PMIC poweroff Event Recorder: 0x0
[    1.403791] vdd-usb-vbus-en: supplied by vdd-5v0-sys
[    1.403817] vdd-usb-vbus-en: 5000 mV
[    1.405087] clk_cbus_recalc_rate: no gbus parent
[    1.405093] clk_cbus_round_rate: no gbus parent
[    1.405095] clk_cbus_round_rate: no gbus parent
[    1.405102] clk_cbus_recalc_rate: no gbus parent
[    1.405199] clk_cbus_recalc_rate: no gbus parent
[    1.405202] clk_cbus_round_rate: no gbus parent
[    1.405204] clk_cbus_round_rate: no gbus parent
[    1.405208] clk_cbus_recalc_rate: no gbus parent
[    1.405889] tegra_dvfs: GPU-cap: registered
[    1.405943] tegra dvfs: vdd-cpu: nominal 1168mV, offset 708000uV, step 19200uV, scaling enabled
[    1.405946] tegra dvfs: vdd-core: nominal 1075mV, offset 600000uV, step 12500uV, scaling enabled
[    1.405949] tegra dvfs: vdd-gpu: nominal 1058mV, offset 708000uV, step 10000uV, scaling enabled
[    1.407555] tegra_dvfs: vdd-gpu-vts: registered
[    1.407686] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_SKU_CALIB_0 = 0x9289413
[    1.407691] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_USB_CALIB_EXT_0 = 0x4
[    1.408374] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.0, lane = usb2-0, function = xusb
[    1.408432] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.1, lane = usb2-1, function = xusb
[    1.408489] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane = usb2-2, function = xusb
[    1.408593] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane = pcie-0, function = pcie-x1
[    1.408646] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane = pcie-1, function = pcie-x4
[    1.408700] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane = pcie-2, function = pcie-x4
[    1.408756] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane = pcie-3, function = pcie-x4
[    1.408812] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane = pcie-4, function = pcie-x4
[    1.408868] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane = pcie-5, function = xusb
[    1.408922] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane = pcie-6, function = xusb
[    1.410213] tegra-pcie 1003000.pcie: 4x1, 1x1 configuration
[    1.412260] tegra-xusb 70090000.xusb: USB2 port 0 has OTG_CAP
[    1.412384] tegra-pcie 1003000.pcie: PCIE: Enable power rails
[    1.412932] tegra-xusb-padctl 7009f000.xusb_padctl: enabled OTG on UTMI pad 0
[    1.413713] tegra-pcie 1003000.pcie: probing port 0, using 4 lanes
[    1.414005] tegra-xusb 70090000.xusb: extcon 0: ffffffc0795d2c00 id
[    1.415471] tegra-xudc-new 700d0000.xudc: device count: 1
[    1.416193] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[    1.416200] tegra-xudc-new 700d0000.xudc: vbus state: 0
[    1.416583] tegra-pcie 1003000.pcie: probing port 1, using 1 lanes
[    1.416706] tegra-xudc-new 700d0000.xudc: entering ELPG
[    1.417084] tegra-xudc-new 700d0000.xudc: entering ELPG done
[    1.417100] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS 'floor cooling device' registered
[    1.417738] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS 'cap cooling device' registered
[    1.417767] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-10-17 15:58:59 UTC, Version: 50.25 release
[    1.417793] tegra-xusb 70090000.xusb: xHCI Host Controller
[    1.417806] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 1
[    1.418307] input: gpio-keys as /devices/gpio-keys/input/input1
[    1.418506] tegra-xusb 70090000.xusb: hcc params 0x0184f525 hci version 0x100 quirks 0x00050010
[    1.418531] tegra-xusb 70090000.xusb: irq 61, io mem 0x70090000
[    1.418856] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.418861] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.418865] usb usb1: Product: xHCI Host Controller
[    1.418868] usb usb1: Manufacturer: Linux 4.9.201-tegra xhci-hcd
[    1.418871] usb usb1: SerialNumber: 70090000.xusb
[    1.419169] hub 1-0:1.0: USB hub found
[    1.419193] hub 1-0:1.0: 5 ports detected
[    1.419515] tegra-xusb 70090000.xusb: xHCI Host Controller
[    1.419523] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 2
[    1.419576] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    1.419630] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[    1.419634] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.419637] usb usb2: Product: xHCI Host Controller
[    1.419640] usb usb2: Manufacturer: Linux 4.9.201-tegra xhci-hcd
[    1.419643] usb usb2: SerialNumber: 70090000.xusb
[    1.419901] hub 2-0:1.0: USB hub found
[    1.419930] hub 2-0:1.0: 4 ports detected
[    1.420556] tegra-xusb 70090000.xusb: Upgrade port 0 to USB3.0
[    1.420561] tegra-xusb 70090000.xusb: Upgrade port 1 to USB3.0
[    1.452070] tegra_rtc 7000e000.rtc: setting system clock to 2021-08-06 03:01:42 UTC (1628218902)
[    1.453171] vi 54080000.vi: vi_probe: ++
[    1.469588] vi 54080000.vi: initialized
[    1.475851] vi 54080000.vi: subdev nvcsi--1 bound
[    1.476807] Disable partitions left on by BL
[    1.476810]   disb
[    1.476851] bwmgr: missing cdev-type property
[    1.476977] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    1.476983] DRAM derating cdev registered.
[    1.477964] ALSA device list:
[    1.477967]   #0: tegra-hda at 0x70038000 irq 81
[    1.477969]   #1: tegra-snd-t210ref-mobile-rt565x
[    1.481099] Freeing unused kernel memory: 8576K
[    1.504929] Root device found: mmcblk0p1
[    1.522757] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[    1.522900] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 2
[    1.523004] usb usb2: usb_suspend_both: status 0
[    1.560498] mmc0: hw tuning done ...
[    1.560542] mmc0: new ultra high speed SDR104 SDHC card at address aaaa
[    1.560918] mmcblk0: mmc0:aaaa SC32G 29.7 GiB
[    1.567523]  mmcblk0: p1
[    1.709731] Found dev node: /dev/mmcblk0p1
[    1.746655] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[    1.759949] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[    1.761751] Rootfs mounted over mmcblk0p1
[    1.796771] Switching from initrd to actual rootfs
[    1.844765] tegra-pcie 1003000.pcie: link 0 down, retrying
[    1.985180] usb 1-2: New USB device found, idVendor=046d, idProduct=0825
[    1.985185] usb 1-2: New USB device strings: Mfr=0, Product=0, SerialNumber=2
[    1.985187] usb 1-2: SerialNumber: E533BDC0
[    2.043360] ip_tables: (C) 2000-2006 Netfilter Core Team
[    2.055619] cgroup: cgroup2: unknown option "nsdelegate"
[    2.066659] tegra_cec 70015000.tegra_cec: Can't find physical addresse.
[    2.066662] tegra_cec 70015000.tegra_cec: tegra_cec_init Done.
[    2.085447] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LI
BCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[    2.086204] systemd[1]: Detected architecture arm64.
[    2.111058] systemd[1]: Set hostname to <fackNvidia>.
[    2.258689] tegra-pcie 1003000.pcie: link 0 down, retrying
[    2.324235] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any),
 but the local system does not support BPF/cgroup based firewalling.
[    2.324244] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit usi
ng IP firewalling.)
[    2.497133] random: systemd: uninitialized urandom read (16 bytes read)
[    2.498993] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    2.499110] random: systemd: uninitialized urandom read (16 bytes read)
[    2.500663] systemd[1]: Created slice User and Session Slice.
[    2.500717] random: systemd: uninitialized urandom read (16 bytes read)
[    2.501477] systemd[1]: Created slice System Slice.
[    2.501687] systemd[1]: Listening on fsck to fsckd communication Socket.
[    2.501856] systemd[1]: Listening on udev Control Socket.
[    2.575831] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[    2.666599] tegra-pcie 1003000.pcie: link 0 down, retrying
[    2.668628] tegra-pcie 1003000.pcie: link 0 down, ignoring
[    2.748040] nvgpu: 57000000.gpu           gm20b_init_clk_setup_sw:1268 [INFO]  GPCPLL initial settings: NA mode, M=1, N=34,
 P=3 (id = 1)
[    2.753618] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    2.753638] cpu-throttle-alert cooling device registered.
[    2.753759] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    2.753774] gpu-throttle-alert cooling device registered.
[    2.753917] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    2.753931] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    2.753948] hot-surface-alert cooling device registered.
[    2.774249] tegra-pcie 1003000.pcie: PCI host bridge to bus 0000:00
[    2.774256] pci_bus 0000:00: root bus resource [io  0x0000-0xffff]
[    2.774260] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
[    2.774264] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pref]
[    2.774268] pci_bus 0000:00: root bus resource [bus 00-ff]
[    2.774289] pci 0000:00:02.0: [10de:0faf] type 01 class 0x060400
[    2.774350] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[    2.774520] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    2.774706] pci 0000:01:00.0: [10ec:8168] type 00 class 0x020000
[    2.774730] pci 0000:01:00.0: reg 0x10: [io  0x0000-0x00ff]
[    2.774761] pci 0000:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[    2.774781] pci 0000:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[    2.774917] pci 0000:01:00.0: supports D1 D2
[    2.774920] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    2.786812] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[    2.786843] pci 0000:00:02.0: BAR 14: assigned [mem 0x13000000-0x130fffff]
[    2.786848] pci 0000:00:02.0: BAR 13: assigned [io  0x1000-0x1fff]
[    2.786855] pci 0000:01:00.0: BAR 4: assigned [mem 0x13000000-0x13003fff 64bit]
[    2.786873] pci 0000:01:00.0: BAR 2: assigned [mem 0x13004000-0x13004fff 64bit]
[    2.786889] pci 0000:01:00.0: BAR 0: assigned [io  0x1000-0x10ff]
[    2.786897] pci 0000:00:02.0: PCI bridge to [bus 01]
[    2.786901] pci 0000:00:02.0:   bridge window [io  0x1000-0x1fff]
[    2.786906] pci 0000:00:02.0:   bridge window [mem 0x13000000-0x130fffff]
[    2.787185] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
[    2.787190] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[    2.787195] pcie_pme 0000:00:02.0:pcie001: service driver pcie_pme loaded
[    2.787281] aer 0000:00:02.0:pcie002: service driver aer loaded
[    2.787461] r8168 0000:01:00.0: enabling device (0000 -> 0003)
[    2.787478] r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded
[    2.803140] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Invalid ethernet address 00:00:00:00:00:00, trying dev
ice tree node
[    2.803210] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Found valid ethernet address 48:b0:2d:2e:5b:ca from de
vice tree
[    2.803679] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,6
25.
[    2.803693] r8168  Copyright (C) 2017  Realtek NIC software team <nicfae@realtek.com>
                This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
                This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.or
g/licenses/>.
[    2.916876] systemd-journald[2007]: Received request to flush runtime journal from PID 1
[    2.989455] Adding 4194300k swap on /swapfile.  Priority:-1 extents:8 across:4530172k SS
[    3.325943] usb 1-2: set resolution quirk: cval->res = 384
[    3.446609] usb 1-3: new high-speed USB device number 3 using tegra-xusb
[    3.467052] usb 1-3: New USB device found, idVendor=1a40, idProduct=0801
[    3.467059] usb 1-3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    3.467063] usb 1-3: Product: USB 2.0 Hub
[    3.467953] hub 1-3:1.0: USB hub found
[    3.468026] hub 1-3:1.0: 4 ports detected
[    3.594622] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 2
[    3.614623] usb 1-3: usb_suspend_both: status 0
[    3.988602] random: crng init done
[    3.992004] random: 7 urandom warning(s) missed due to ratelimiting
[    4.619318] using random self ethernet address
[    4.624121] using random host ethernet address
[    4.665822] uvcvideo: Found UVC 1.00 device <unnamed> (046d:0825)
[    4.681030] uvcvideo 1-2:1.0: Entity type for entity Extension 4 was not initialized!
[    4.688911] uvcvideo 1-2:1.0: Entity type for entity Extension 6 was not initialized!
[    4.696808] uvcvideo 1-2:1.0: Entity type for entity Extension 7 was not initialized!
[    4.704739] uvcvideo 1-2:1.0: Entity type for entity Processing 2 was not initialized!
[    4.713446] uvcvideo 1-2:1.0: Entity type for entity Extension 3 was not initialized!
[    4.722545] uvcvideo 1-2:1.0: Entity type for entity Camera 1 was not initialized!
[    4.730463] input: UVC Camera (046d:0825) as /devices/70090000.xusb/usb1/1-2/1-2:1.0/input/input2
[    4.730755] usbcore: registered new interface driver uvcvideo
[    4.730758] USB Video Class driver (1.1.1)
[    5.581194] Mass Storage Function, version: 2009/09/11
[    5.581201] LUN: removable file: (no medium)
[    5.587188] using random self ethernet address
[    5.591666] using random host ethernet address
[    5.847473] rndis0: HOST MAC 9a:8d:21:dc:41:ec
[    5.848463] rndis0: MAC 9a:8d:21:dc:41:ed
[    5.849161] usb0: HOST MAC 9a:8d:21:dc:41:ee
[    5.849189] usb0: MAC 9a:8d:21:dc:41:ef
[    5.849209] tegra-xudc-new 700d0000.xudc: exiting ELPG
[    5.849809] tegra-xudc-new 700d0000.xudc: exiting ELPG done
[    5.849827] tegra-xudc-new 700d0000.xudc: ep 0 (type: 0, dir: out) enabled
[    5.849856] tegra-xudc-new 700d0000.xudc: entering ELPG
[    5.850060] tegra-xudc-new 700d0000.xudc: entering ELPG done
[    5.850080] tegra-xudc-new 700d0000.xudc: exiting ELPG
[    5.850648] tegra-xudc-new 700d0000.xudc: exiting ELPG done
[    5.850663] tegra-xudc-new 700d0000.xudc: entering ELPG
[    5.850891] tegra-xudc-new 700d0000.xudc: entering ELPG done
[    5.855547] l4tbr0: port 1(rndis0) entered blocking state
[    5.855552] l4tbr0: port 1(rndis0) entered disabled state
[    5.855744] device rndis0 entered promiscuous mode
[    5.865343] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[    5.874350] l4tbr0: port 2(usb0) entered blocking state
[    5.874355] l4tbr0: port 2(usb0) entered disabled state
[    5.874539] device usb0 entered promiscuous mode
[    5.882148] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[    6.136527] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[    6.138296] eth0: 0xffffff800abf0000, 48:b0:2d:2e:5b:ca, IRQ 405
[    6.203144] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[    6.380517] zram: Added device: zram0
[    6.384335] zram: Added device: zram1
[    6.388062] zram: Added device: zram2
[    6.391362] zram: Added device: zram3
[    6.425863] zram0: detected capacity change from 0 to 259506176
[    6.448038] Adding 253420k swap on /dev/zram0.  Priority:5 extents:1 across:253420k SS
[    6.451266] zram1: detected capacity change from 0 to 259506176
[    6.467546] Adding 253420k swap on /dev/zram1.  Priority:5 extents:1 across:253420k SS
[    6.475286] zram2: detected capacity change from 0 to 259506176
[    6.486850] Adding 253420k swap on /dev/zram2.  Priority:5 extents:1 across:253420k SS
[    6.490228] zram3: detected capacity change from 0 to 259506176
[    6.500653] Adding 253420k swap on /dev/zram3.  Priority:5 extents:1 across:253420k SS
[    7.978657] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[    7.998610] usb 1-2: usb_suspend_both: status 0
[    7.998831] usb usb1: usb_suspend_both: status 0
[    7.998874] tegra-xusb 70090000.xusb: entering ELPG
[    8.000047] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 1, speed 3
[    8.000284] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 2, speed 3
[    8.001931] tegra-xusb 70090000.xusb: entering ELPG done
[    8.909128] tegradc tegradc.0: blank - powerdown
[    8.934081] Bridge firewalling registered
[    8.982414] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[    9.251044] Netfilter messages via NETLINK v0.30.
[    9.253590] ctnetlink v0.93: registering with nfnetlink.
[    9.468469] IPv6: ADDRCONF(NETDEV_UP): docker0: link is not ready
[   10.386282] fuse init (API version 7.26)
[   12.927538] tegra-xusb 70090000.xusb: exiting ELPG
[   12.933433] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-10-17 15:58:59 UTC, Version: 50.25 release
[   12.933847] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 0
[   12.933868] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 1
[   12.933887] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 2
[   12.934371] tegra-xusb 70090000.xusb: exiting ELPG done
[   12.934542] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[   13.170899] usb 1-2: reset high-speed USB device number 2 using tegra-xusb
[   15.608188] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   15.608200] Bluetooth: BNEP socket layer initialized
[   19.507041] r8168: eth0: link up
[   19.507593] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   23.174617] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[   23.194654] usb 1-2: usb_suspend_both: status 0
[   23.194751] usb usb1: usb_suspend_both: status 0
[   23.194761] tegra-xusb 70090000.xusb: entering ELPG
[   23.195801] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 1, speed 3
[   23.195990] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 2, speed 3
[   23.197575] tegra-xusb 70090000.xusb: entering ELPG done
[   31.861298] vdd-fan: disabling
[   31.861340] vdd-usb-vbus: disabling
[   31.861374] vdd-usb-vbus2: disabling
[   31.861483] avdd-io-edp-1v05: disabling
[   31.861514] vdd-usb-hub-en: disabling
[  259.817926] tegra-xusb 70090000.xusb: exiting ELPG
[  259.821019] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-10-17 15:58:59 UTC, Version: 50.25 release
[  259.821286] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 0
[  259.821303] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 1
[  259.821319] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 2
[  259.821787] tegra-xusb 70090000.xusb: exiting ELPG done
[  259.821973] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[  260.057133] usb 1-2: reset high-speed USB device number 2 using tegra-xusb
[  299.349381] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[  299.369382] usb 1-2: usb_suspend_both: status 0
[  299.369505] usb usb1: usb_suspend_both: status 0
[  299.369522] tegra-xusb 70090000.xusb: entering ELPG
[  299.370585] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 1, speed 3
[  299.370810] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 2, speed 3
[  299.372474] tegra-xusb 70090000.xusb: entering ELPG done
[ 4167.829256] tegra-xusb 70090000.xusb: exiting ELPG
[ 4167.833011] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-10-17 15:58:59 UTC, Version: 50.25 release
[ 4167.833271] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 0
[ 4167.833292] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 1
[ 4167.833312] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 2
[ 4167.833879] tegra-xusb 70090000.xusb: exiting ELPG done
[ 4167.834027] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 4168.067029] usb 1-2: reset high-speed USB device number 2 using tegra-xusb
[ 4173.290865] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 4173.310683] usb 1-2: usb_suspend_both: status 0
[ 4173.310800] usb usb1: usb_suspend_both: status 0
[ 4173.310815] tegra-xusb 70090000.xusb: entering ELPG
[ 4173.311909] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 1, speed 3
[ 4173.312173] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 2, speed 3
[ 4173.313975] tegra-xusb 70090000.xusb: entering ELPG done
[ 4215.337548] tegra-xusb 70090000.xusb: exiting ELPG
[ 4215.340877] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-10-17 15:58:59 UTC, Version: 50.25 release
[ 4215.341157] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 0
[ 4215.341177] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 1
[ 4215.341195] tegra-pmc: PMC tegra_pmc_utmi_phy_disable_sleepwalk : port 2
[ 4215.341674] tegra-xusb 70090000.xusb: exiting ELPG done
[ 4215.341854] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 4215.578970] usb 1-2: reset high-speed USB device number 2 using tegra-xusb
[ 4219.115314] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
[ 4219.134738] usb 1-2: usb_suspend_both: status 0
[ 4219.134843] usb usb1: usb_suspend_both: status 0
[ 4219.134857] tegra-xusb 70090000.xusb: entering ELPG
[ 4219.135956] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 1, speed 3
[ 4219.136183] tegra-pmc: PMC tegra_pmc_utmi_phy_enable_sleepwalk : port 2, speed 3
[ 4219.137829] tegra-xusb 70090000.xusb: entering ELPG done
Looks like the the dmesg didn’t show that.
What’s the BSP version?
How can I check BSP version?
I used this command uname -a
and show me these
Linux jackoo 4.9.201-tegra #1 SMP PREEMPT Wed May 5 09:31:36 PDT 2021 aarch64 aarch64 aarch64 GNU/Linux
cat /etc/nv_tegra_release to check it.
ok, it shows:
R32 (release), REVISION: 5.1, GCID: 27362550, BOARD: t210ref, EABI: aarch64, DATE: Wed May 19 18:07:59 UTC 2021
Could you download the source code form below link to debug it.
https://developer.nvidia.com/embedded/l4t/r32_release_v5.2/sources/t210/public_sources.tbz2
Ok thanks, seems it isn’t a simple process :(
I will try.
@nuclei2002
Have a try apply the patch from below link for your problem.
much appreciated!
