I am using a p3448-b01 nano on a custom carrier board. I completely copied the mipi dual cam schematic from the developer kit schematic. I have attached the relevant schematic files below as well as the commands issued and the dmesg log.
I have made no changes to the b00 dtb file in regards to the cameras. I would assume it was a hardware issue, but I find it unlikely since:
a) both cameras are recognized
b) video0 is able to record to a file
c) both mipi connections are identical
I have tried swapping cameras, it appears that video0 works regardless of which camera is connected. Both cameras are sony IMX219.
Any assistance is greatly appreciated,
Ben
Terminal Window
Welcome to Ubuntu 18.04.4 LTS (GNU/Linux 4.9.140-tegra aarch64)
* Documentation: https://help.ubuntu.com
* Management: https://landscape.canonical.com
* Support: https://ubuntu.com/advantage
This system has been minimized by removing packages and content that are
not required on a system that users do not log into.
To restore this content, you can run the 'unminimize' command.
269 packages can be updated.
199 updates are security updates.
Last login: Fri Oct 16 18:02:04 2020
nvidia@nn-024:~$ gst-launch-1.0 -e nvarguscamerasrc sensor-id=0 ! nvvidconv ! omxh264enc ! h264parse ! matroskamux ! filesink location=test0.mkv
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
Framerate set to : 30 at NvxVideoEncoderSetParameterNvMMLiteOpen : Block : BlockType = 4
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
H264: Profile = 66, Level = 40
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 3264 x 2464 FR = 21.000000 fps Duration = 47619048 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 3264 x 1848 FR = 28.000001 fps Duration = 35714284 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1920 x 1080 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 120.000005 fps Duration = 8333333 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: Running with following settings:
Camera index = 0
Camera mode = 2
Output Stream W = 1920 H = 1080
seconds to Run = 0
Frame Rate = 29.999999
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
^Chandling interrupt.
Interrupt: Stopping pipeline ...
EOS on shutdown enabled -- Forcing EOS on the pipeline
Waiting for EOS...
Got EOS from element "pipeline0".
EOS received - stopping pipeline...
Execution ended after 0:00:08.813899528
Setting pipeline to READY ...
GST_ARGUS: Cleaning up
CONSUMER: Done Success
GST_ARGUS: Done Success
Setting pipeline to NULL ...
Freeing pipeline ...
nvidia@nn-024:~$ gst-launch-1.0 -e nvarguscamerasrc sensor-id=1 ! nvvidconv ! omxh264enc ! h264parse ! matroskamux ! filesink location=test1.mkv
Camera index = 1
Camera mode = 2
seconds to Run = 0
^C
nvidia@nn-024:~$ ls -l
total 2192
drwxr-xr-x 2 nvidia nvidia 4096 Jan 28 2018 Desktop
-rw-r--r-- 1 nvidia nvidia 8980 Jan 28 2018 examples.desktop
-rw-rw-r-- 1 nvidia nvidia 2226408 Oct 16 18:02 test0.mkv
-rw-rw-r-- 1 nvidia nvidia 0 Oct 16 18:03 test1.mkv
dmesg output
dmesg.txt (106.6 KB)
debug uart output
debug-msg.txt (22.4 KB)
Schematic files
