The web camera does not work on jetson nano
Hello.
I am writing motion detection code in jetson nano. The motion detection process is written in cuda.
I have confirmed that we can run the sample video. However, live streaming using the camera cannot be performed with the following warning.
[ WARN:0] global /home/jetson/workspace/opencv-4.5.0/modules/videoio/src/cap_gstreamer.cpp (935) open OpenCV | GStreamer warning: Cannot query video position: status=0, value=-1, duration=-1
I looked into it and found #332 , changed the options and rebuilt OpenCV. However, the result did not change.
How do I get my webcam to work? The source code and OpenCV build information, Camera Information are included below.
Thank you.
MotionGPU.cpp
#include <opencv2/opencv.hpp>
#include <opencv2/cudaimgproc.hpp>
#include <vector>
#include "Kernel.h"
int main() {
    std::string src = "v4l2src device=/dev/video0 ! video/x-raw,framerate=30/1,width=640,height=480, format=YUY2 ! videoconvert ! appsink";
    cv::VideoCapture cap(src);
    //cap.open("vtest.avi");
    cv::Mat frame;
    cv::Mat mono;
    if(cap.isOpened()){return -1;}
    while(cap.read(frame)){
        frame.convertTo(frame, CV_32FC3, 1/255.0);
        cv::Mat mono  = cv::Mat::zeros(frame.size(), CV_32FC1);
        cudaKernel(frame, mono);
        cv::imshow("gpu", mono);
        const int key = cv::waitKey(1);
        if(key == 'q'){
            break;
    cv::destroyAllWindows();
    return 0;
Kernel.h
#pragma once
#include <opencv2/core.hpp>
#include <opencv2/core/cuda.hpp>
void cudaKernel(cv::Mat &src, cv::Mat &dst);
Kernel.cu
#include <opencv2/cudev.hpp>
#include <iostream>
#include <cuda_runtime.h>
#include <helper_cuda.h>
#include <device_launch_parameters.h>
#include <cmath>
#define CEIL(a, b) (a + (b - 1)) / b
enum thresh_type{
    thresh_binary
//average
float* p_avg = NULL;
__global__ void invertNP(float* src, float* dst, int cols, int rows, int channels) {
    int x = blockDim.x * blockIdx.x + threadIdx.x;
    int y = blockDim.y * blockIdx.y + threadIdx.y;
    if (x < cols  && y < rows){
        for(int i = 0; i < channels; i++){
            dst[y * cols * channels + x * channels + i] = 1.0 -  src[y * cols * channels + x * channels + i];
__global__ void convertMono(float* src, float* dst, int cols, int rows, int channels){
        float Y = 0.0;
        //Y = 0.299R + 0.587G + 0.114B
        //B
            Y += 0.114 * src[y * cols * channels + x * channels + 0];
        //G
            Y += 0.587 * src[y * cols * channels + x * channels + 1];
        //R
            Y += 0.299 * src[y * cols * channels + x * channels + 2];
        dst[y * cols + x] = Y;
__global__ void accumulateWeighted(float* src, float* dst, int cols, int rows, double alpha){
        dst[y * cols + x] = (1.0 - alpha) * dst[y * cols + x] + alpha * src[y * cols + x];
__global__ void convertScaleAbs(float* src, float* dst, int cols, int rows, double alpha, double beta){
        dst[y * cols + x] = abs((float)(alpha * src[y * cols + x] + beta));
__global__ void absDiff(float* src1, float* src2, float* dst, int cols, int rows){
        dst[y * cols + x] =  abs(src1[y * cols + x] - src2[y * cols + x]);
__global__ void threshold(float* src, float* dst, int cols, int rows ,float thresh, float maxval, int type){
        if(type == thresh_binary){
            dst[y * cols + x] = (src[y * cols + x] > thresh) ? maxval : 0;
    float* p_src;
    float* p_mono;
    float* p_temp;
    float* p_framedata;
    float* p_thresh;
    float* p_cpudst;
    cudaMalloc((void **)&p_src, sizeof(float) * src.cols * src.rows * src.channels());
    cudaMalloc((void **)&p_mono, sizeof(float) * dst.cols * dst.rows * dst.channels());
    cudaMalloc((void **)&p_temp, sizeof(float) * dst.cols * dst.rows * dst.channels());
    cudaMalloc((void **)&p_framedata, sizeof(float) * dst.cols * dst.rows * dst.channels());
    cudaMalloc((void **)&p_thresh, sizeof(float) * dst.cols * dst.rows * dst.channels());
    cudaMallocHost((void **)&p_cpudst,sizeof(float) * dst.cols * dst.rows * dst.channels());
    cudaMemcpy(p_src, src.data, sizeof(float) * src.cols * src.rows * src.channels(), cudaMemcpyHostToDevice);
    cudaMemcpy(p_mono, dst.data, sizeof(float) * dst.cols * dst.rows * dst.channels(), cudaMemcpyHostToDevice);
    dim3 dimBlock(32, 32);
    dim3 dimGrid(CEIL(src.cols, 32), CEIL(src.rows, 32));
    //Convert mono
    convertMono<<<dimGrid, dimBlock>>>(p_src, p_mono, src.cols, src.rows, src.channels());
    if(!p_avg){
        cudaMalloc((void **)&p_avg, sizeof(float) * src.cols * src.rows * 1);
        //initial value
        cudaMemcpy(p_avg, p_mono, sizeof(float) * src.cols * src.rows * 1, cudaMemcpyDeviceToDevice);
        return;
    //AccumulateWeighted
    accumulateWeighted<<<dimGrid, dimBlock>>>(p_mono, p_avg, src.cols, src.rows, 0.6);
    convertScaleAbs<<<dimGrid, dimBlock>>>(p_avg, p_temp, src.cols, src.rows, 1.0, 0.0);
    absDiff<<<dimGrid, dimBlock>>>(p_mono, p_temp, p_framedata, src.cols, src.rows);
    //threshold
    threshold<<<dimGrid, dimBlock>>>(p_framedata, p_thresh, src.cols, src.rows, 3.0/255.0, 1.0, thresh_binary);
    cudaMemcpy(p_cpudst, p_thresh, sizeof(float) * dst.cols * dst.rows * dst.channels(), cudaMemcpyDeviceToHost);
    dst = cv::Mat(dst.rows, dst.cols, CV_32FC1, p_cpudst);
    cudaFree(p_src);
    cudaFree(p_mono);
    cudaFree(p_temp);
    cudaFree(p_framedata);
    checkCudaErrors(cudaGetLastError());
    checkCudaErrors(cudaDeviceSynchronize());
OpenCV Build Information
General configuration for OpenCV 4.5.0 =====================================
  Version control:               unknown
  Extra modules:
    Location (extra):            /home/jetson/workspace/opencv_contrib-4.5.0/modules
    Version control (extra):     unknown
  Platform:
    Timestamp:                   2021-07-09T05:18:31Z
    Host:                        Linux 4.9.201-tegra aarch64
    CMake:                       3.10.2
    CMake generator:             Unix Makefiles
    CMake build tool:            /usr/bin/make
    Configuration:               RELEASE
  CPU/HW features:
    Baseline:                    NEON FP16
      required:                  NEON
      disabled:                  VFPV3
  C/C++:
    Built as dynamic libs?:      YES
    C++ standard:                11
    C++ Compiler:                /usr/bin/c++  (ver 7.5.0)
    C++ flags (Release):         -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wundef -Winit-self -Wpointer-arith -Wshadow -Wsign-promo -Wuninitialized -Winit-self -Wsuggest-override -Wno-delete-non-virtual-dtor -Wno-comment -Wimplicit-fallthrough=3 -Wno-strict-overflow -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections    -fvisibility=hidden -fvisibility-inlines-hidden -O3 -DNDEBUG  -DNDEBUG
    C++ flags (Debug):           -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wundef -Winit-self -Wpointer-arith -Wshadow -Wsign-promo -Wuninitialized -Winit-self -Wsuggest-override -Wno-delete-non-virtual-dtor -Wno-comment -Wimplicit-fallthrough=3 -Wno-strict-overflow -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections    -fvisibility=hidden -fvisibility-inlines-hidden -g  -O0 -DDEBUG -D_DEBUG
    C Compiler:                  /usr/bin/cc
    C flags (Release):           -fsigned-char -W -Wall -Werror=return-type -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wmissing-prototypes -Wstrict-prototypes -Wundef -Winit-self -Wpointer-arith -Wshadow -Wuninitialized -Winit-self -Wno-comment -Wimplicit-fallthrough=3 -Wno-strict-overflow -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections    -fvisibility=hidden -O3 -DNDEBUG  -DNDEBUG
    C flags (Debug):             -fsigned-char -W -Wall -Werror=return-type -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wmissing-prototypes -Wstrict-prototypes -Wundef -Winit-self -Wpointer-arith -Wshadow -Wuninitialized -Winit-self -Wno-comment -Wimplicit-fallthrough=3 -Wno-strict-overflow -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections    -fvisibility=hidden -g  -O0 -DDEBUG -D_DEBUG
    Linker flags (Release):      -Wl,--gc-sections -Wl,--as-needed
    Linker flags (Debug):        -Wl,--gc-sections -Wl,--as-needed
    ccache:                      NO
    Precompiled headers:         NO
    Extra dependencies:          m pthread cudart_static dl rt nppc nppial nppicc nppicom nppidei nppif nppig nppim nppist nppisu nppitc npps cublas cudnn cufft -L/usr/local/cuda/lib64 -L/usr/lib/aarch64-linux-gnu
    3rdparty dependencies:
  OpenCV modules:
    To be built:                 alphamat aruco bgsegm bioinspired calib3d ccalib core cudaarithm cudabgsegm cudacodec cudafeatures2d cudafilters cudaimgproc cudalegacy cudaobjdetect cudaoptflow cudastereo cudawarping cudev datasets dnn dnn_objdetect dnn_superres dpm face features2d flann freetype fuzzy gapi hfs highgui img_hash imgcodecs imgproc intensity_transform line_descriptor mcc ml objdetect optflow phase_unwrapping photo plot python2 python3 quality rapid reg rgbd saliency shape stereo stitching structured_light superres surface_matching text tracking video videoio videostab xfeatures2d ximgproc xobjdetect xphoto
    Disabled:                    world
    Disabled by dependency:      -
    Unavailable:                 cnn_3dobj cvv hdf java js julia matlab ovis sfm ts viz
    Applications:                apps
    Documentation:               NO
    Non-free algorithms:         NO
  GUI:
    GTK+:                        YES (ver 3.22.30)
      GThread :                  YES (ver 2.56.4)
      GtkGlExt:                  NO
    VTK support:                 NO
  Media I/O:
    ZLib:                        /usr/lib/aarch64-linux-gnu/libz.so (ver 1.2.11)
    JPEG:                        /usr/lib/aarch64-linux-gnu/libjpeg.so (ver 80)
    WEBP:                        build (ver encoder: 0x020f)
    PNG:                         /usr/lib/aarch64-linux-gnu/libpng.so (ver 1.6.34)
    TIFF:                        /usr/lib/aarch64-linux-gnu/libtiff.so (ver 42 / 4.0.9)
    JPEG 2000:                   build (ver 2.3.1)
    OpenEXR:                     build (ver 2.3.0)
    HDR:                         YES
    SUNRASTER:                   YES
    PXM:                         YES
    PFM:                         YES
  Video I/O:
    GStreamer:                   YES (1.14.5)
    v4l/v4l2:                    YES (linux/videodev2.h)
  Parallel framework:            pthreads
  Trace:                         YES (with Intel ITT)
  Other third-party libraries:
    Lapack:                      NO
    Eigen:                       YES (ver 3.3.4)
    Custom HAL:                  YES (carotene (ver 0.0.1))
    Protobuf:                    build (3.5.1)
  NVIDIA CUDA:                   YES (ver 10.2, CUFFT CUBLAS)
    NVIDIA GPU arch:             53 62 72
    NVIDIA PTX archs:
  cuDNN:                         YES (ver 8.0.0)
  OpenCL:                        YES (no extra features)
    Include path:                /home/jetson/workspace/opencv-4.5.0/3rdparty/include/opencl/1.2
    Link libraries:              Dynamic load
  Python 2:
    Interpreter:                 /usr/bin/python2.7 (ver 2.7.17)
    Libraries:                   /usr/lib/aarch64-linux-gnu/libpython2.7.so (ver 2.7.17)
    numpy:                       /usr/lib/python2.7/dist-packages/numpy/core/include (ver 1.13.3)
    install path:                lib/python2.7/dist-packages/cv2/python-2.7
  Python 3:
    Interpreter:                 /usr/bin/python3 (ver 3.6.9)
    Libraries:                   /usr/lib/aarch64-linux-gnu/libpython3.6m.so (ver 3.6.9)
    numpy:                       /usr/lib/python3/dist-packages/numpy/core/include (ver 1.13.3)
    install path:                lib/python3.6/dist-packages/cv2/python-3.6
  Python (for build):            /usr/bin/python2.7
  Java:
    ant:                         NO
    JNI:                         NO
    Java wrappers:               NO
    Java tests:                  NO
  Install to:                    /usr/local
Camera Information
Driver Info (not using libv4l2):
        Driver name   : uvcvideo
        Card type     : HD Pro Webcam C920
        Bus info      : usb-70090000.xusb-2.1
        Driver version: 4.9.201
        Capabilities  : 0x84200001
                Video Capture
                Streaming
                Extended Pix Format
                Device Capabilities
        Device Caps   : 0x04200001
                Video Capture
                Streaming
                Extended Pix Format
ioctl: VIDIOC_ENUM_FMT
        Index       : 0
        Type        : Video Capture
        Pixel Format: 'YUYV'
        Index       : 1
        Pixel Format: 'H264' (compressed)
        Index       : 2
        Pixel Format: 'MJPG' (compressed)
v4l2-ctl --list-formats-ext shows 640x480 at 30fps?
How about try this webcam with jetcam first.
According to the supported format, you may modify usb_camera.py.
You run a gstreamer pipelein in cv2.VideoCapture() to get the the buffer in cv::Mat. Not sure if the buffer is GPU-accessible. This would need other users to share experience.
Please refer to this page:
https://www.e-consystems.com/blog/camera/how-to-access-cameras-using-opencv-with-python/
And see if you can disable gstreamer and use OpenCV framework to capture frames in cv::Mat. In this case the buffer should be GPU-accessible.
Hello.
Sorry for the delay in replying. I haven’t been able to touch jetson nano for a few days.
Here is the result of running v4l2-ctl --list-formats-ext.
I think this camera will work at 640x480, 30fps.
        Index       : 0
                        Interval: Discrete 0.033s (30.000 fps)
                        Interval: Discrete 0.042s (24.000 fps)
                        Interval: Discrete 0.050s (20.000 fps)
                        Interval: Discrete 0.067s (15.000 fps)
                        Interval: Discrete 0.100s (10.000 fps)
                        Interval: Discrete 0.133s (7.500 fps)
                        Interval: Discrete 0.200s (5.000 fps)
                Size: Discrete 1920x1080
                Size: Discrete 2304x1296
                        Interval: Discrete 0.500s (2.000 fps)
                Size: Discrete 2304x1536
        Index       : 1
        Index       : 2
Hello.
I disabled gstreamer and rebuilt. Here is the build information.
  Extra modules:
  Platform:
    CMake:                       3.10.2
  CPU/HW features:
    Baseline:                    NEON FP16
      required:                  NEON
      disabled:                  VFPV3
  C/C++:
    C++ standard:                11
    ccache:                      NO
  OpenCV modules:
    Disabled:                    world
    Applications:                apps
    Documentation:               NO
  GUI:
      GtkGlExt:                  NO
    VTK support:                 NO
  Media I/O:
    HDR:                         YES
    SUNRASTER:                   YES
    PXM:                         YES
    PFM:                         YES
  Video I/O:
    Lapack:                      NO
    NVIDIA PTX archs:
  Python 2:
  Python 3:
  Java:
    ant:                         NO
    JNI:                         NO
    Java wrappers:               NO
    Java tests:                  NO
Next, I ran a simple camera capture program and it worked fine.
int main (void){
    cv::Mat frame;
    //std::string src = "v4l2src device=/dev/video0 ! video/x-raw,framerate=30/1,width=640,height=480,format=YUY2 ! videoconvert ! appsink";
    cv::VideoCapture cap(0);
    if(!cap.isOpened()){return -1;}
        cv::imshow("win", frame);
        if(key == 'q'){
            break;
    return 0;
However, when I changed MotionGPU.cpp to cv::VideoCapture cap(0);, I was able to run it, but no window or anything was displayed. cuda-memcheck did not detect any errors.
MotionGPU.cpp
#include <vector>
#include "Kernel.h"
int main() {
    cv::Mat frame;
    cv::Mat mono;
        if(key == 'q'){
            break;
    return 0;
Since we don’t have the experience and are not sure if applying cuda kernel to cv::Mat is supported, please go to OpenCV forum to get further suggestion:
https://forum.opencv.org/
You would have to upload your capture frame from cv::Mat into a cv:GpuMat for CUDA kernel.
You may display your GpuMat with imshow into an opencv window created with cv::WINDOW_OPENGL flag, but it would require some GTK2 or QT4 backend (see GTK2 backend or QT4 backend).
Hi.
I did find out one thing. In MotionGPU.cpp, cap.isOpened() returned false, so the camera was not open.
However, in the simple program below, the camera works fine.
The compile-time options are the same. What should I do?
int main (void){
    cv::Mat frame;
    cv::VideoCapture cap(0,cv::CAP_V4L);
        if(key == 'q'){
            break;
    return 0;
Hello.
I was able to get the results I was expecting by rebuilding opencv several times.
The following warning is still displayed, but I am able to run the program. Finally, here is the current buildinformation of opencv.
Thanks for your help.
  Extra modules:
  Platform:
    CMake:                       3.10.2
  CPU/HW features:
    Baseline:                    NEON FP16
      required:                  NEON
      disabled:                  VFPV3
  C/C++:
    C++ standard:                11
    ccache:                      NO
  OpenCV modules:
    Disabled:                    world
    Applications:                apps
    Documentation:               NO
  GUI:
      GtkGlExt:                  NO
    OpenGL support:              NO
    VTK support:                 NO
  Media I/O:
    HDR:                         YES
    SUNRASTER:                   YES
    PXM:                         YES
    PFM:                         YES
  Video I/O:
    FFMPEG:                      YES
      avcodec:                   YES (57.107.100)
      avformat:                  YES (57.83.100)
      avutil:                    YES (55.78.100)
      swscale:                   YES (4.8.100)
      avresample:                NO
    Lapack:                      NO
    NVIDIA PTX archs:
  Python 2:
  Python 3:
  Java:
    ant:                         NO
    JNI:                         NO
    Java wrappers:               NO
    Java tests:                  NO
