jetson nano raspberry pi camera not working
Jetson nano raspberry pi camera not working
tried using opencv to capture image but this is the error im getting
v4l2-ctl -d /dev/video0 --list-formats
ioctl: VIDIOC_ENUM_FMT
Index : 0
Type : Video Capture
Pixel Format: ‘RG10’
Name : 10-bit Bayer RGRG/GBGB
Error “V4L2: Pixel format of incoming image is unsupported by OpenCV”
You may read this topic.
Can you pls show some python example converting it to OpenCV compatible frame
You may try this one.
If your release doesn’t have nvcamerasrc, you would use nvarguscamerasrc instead, and NV12 format instead of I420, as mentioned in the link from my previous post.
Note that your opencv lib should have been built with gstreamer support, but this should be ok.
im getting this error, please help
(python3:26947): GStreamer-CRITICAL **: 19:42:18.884:
Trying to dispose element pipeline0, but it is in READY instead of the NULL state.
You need to explicitly set elements to the NULL state before
dropping the final reference, to allow them to clean up.
This problem may also be caused by a refcounting bug in the
application or some element.
OpenCV Error: Unspecified error (GStreamer: unable to start pipeline
) in cvCaptureFromCAM_GStreamer, file /home/nvidia/build_opencv/opencv/modules/videoio/src/cap_gstreamer.cpp, line 887
VIDEOIO(cvCreateCapture_GStreamer (CV_CAP_GSTREAMER_FILE, filename)): raised OpenCV exception:
/home/nvidia/build_opencv/opencv/modules/videoio/src/cap_gstreamer.cpp:887: error: (-2) GStreamer: unable to start pipeline
 in function cvCaptureFromCAM_GStreamer
  File "testcamera.py", line 19, in <module>
    read_cam()
  File "testcamera.py", line 5, in read_cam
    cap = cv2.VideoCapture("nvcamerasrc ! video/x-raw(memory:NVMM), width=(int)1280, height=(int)720,format=(string)I420, framerate=(fraction)24/1 ! nvvidconv flip-method=2 ! video/x-raw, format=(string)BGRx ! videoconvert ! video/x-raw, format=(string)BGR ! appsink")
Have you tried that ?
Ok, I installed opencv from source with gstreamer support etc
using https://github.com/AastaNV/JEP/blob/master/script/install_opencv4.0.0_Xavier.sh
changed to nvarguscamerasrc instead
but still this is the error im getting
[ WARN:0] VIDEOIO(cvCreateFileCapture_FFMPEG_proxy(filename)): trying ...
[ WARN:0] VIDEOIO(cvCreateFileCapture_FFMPEG_proxy(filename)): result=(nil) isOpened=-1 ...
[ WARN:0] VIDEOIO(createGStreamerCapture(filename)): trying ...
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 3280 x 2464 FR = 21.000000 fps Duration = 47619048 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 3280 x 1848 FR = 28.000001 fps Duration = 35714284 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1920 x 1080 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 120.000005 fps Duration = 8333333 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: Running with following settings:
   Camera index = 0
   Camera mode  = 2
   Output Stream W = 1920 H = 1080
   seconds to Run    = 0
   Frame Rate = 29.999999
GST_ARGUS: PowerService: requested_clock_Hz=13608000
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
GST_ARGUS: Cleaning up
GST_ARGUS:
PowerServiceHwVic::cleanupResources
CONSUMER: Done Success
GST_ARGUS: Done Success
(python3:16800): GStreamer-CRITICAL **: 11:59:00.148: gst_element_get_state: assertion 'GST_IS_ELEMENT (element)' failed
[ WARN:0] VIDEOIO(createGStreamerCapture(filename)): result=(nil) isOpened=-1 ...
[ WARN:0] VIDEOIO(cvCreateCameraCapture_V4L(filename.c_str())): trying ...
[ WARN:0] VIDEOIO(cvCreateCameraCapture_V4L(filename.c_str())): result=(nil) ...
[ WARN:0] VIDEOIO(createFileCapture_Images(filename)): trying ...
[ WARN:0] VIDEOIO(createFileCapture_Images(filename)): result=(nil) isOpened=-1 ...
[ WARN:0] VIDEOIO(createMotionJpegCapture(filename)): trying ...
[ WARN:0] VIDEOIO(createMotionJpegCapture(filename)): result=(nil) isOpened=-1 ...
camera open failed
You should show the failing code you’re trying, it would be easier for finding out what could be the issue.
Here it seems you’re using ffmpeg, but it suspect this can only be used with a video file, not a camera.
You may also enable gstreamer debugging for checking why the pipeline fails to start.
Can you try this code and post the output if it still fails ?
import sys
import cv2
import gi
gi.require_version('Gst', '1.0')
from gi.repository import Gst
def read_cam():
        cap = cv2.VideoCapture("nvarguscamerasrc ! video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080,format=(string)NV12, framerate=(fraction)30/1 ! nvvidconv ! video/x-raw, format=(string)BGRx ! videoconvert ! video/x-raw, format=(string)BGR ! appsink")
        if cap.isOpened():
                cv2.namedWindow("demo", cv2.WINDOW_AUTOSIZE)
                while True:
                        ret_val, img = cap.read();
                        cv2.imshow('demo',img)
                        if cv2.waitKey(1) == ord('q'):
				break
        else:
                print ("camera open failed")
        cv2.destroyAllWindows()
if __name__ == '__main__':
        print(cv2.getBuildInformation())
        Gst.debug_set_active(True)
        Gst.debug_set_default_threshold(3)
        read_cam()
Thanks a lot!, you saved me, This works perfectly fine
also this article will help others
https://www.jetsonhacks.com/2019/04/02/jetson-nano-raspberry-pi-camera/
For some reason its not working within ROS
I am just getting the cap.isOpened() as false
camerao pen failed
no debug message also
Please help, thanks
import sys
import cv2
import gi
class image_converter:
  def __init__(self):
    self.image_pub = rospy.Publisher("image_topic_2",Image,  queue_size=10)
    self.read_cam()
    self.bridge = CvBridge()
  def read_cam(self):
    cap = cv2.VideoCapture("nvarguscamerasrc ! video/x-raw(memory:NVMM), width=(int)1280, height=(int)720,format=(string)NV12, framerate=(fraction)30/1 ! nvvidconv ! video/x-raw, format=(string)BGRx ! videoconvert ! video/x-raw, format=(string)BGR ! appsink")
    print(cap.isOpened())
    if cap.isOpened():
	while True:
	    ret_val, cv_image = cap.read();
	    cv2.imshow('demo',cv_image)
	    try:
	      self.image_pub.publish(self.bridge.cv2_to_imgmsg(cv_image, "bgr8"))
	    except CvBridgeError as e:
	      print(e)
	      break
    else:
def main(args):
  ic = image_converter()
  rospy.init_node('image_converter', anonymous=True)
  try:
    rospy.spin()
  except KeyboardInterrupt:
    print("Shutting down")
    Gst.debug_set_default_threshold(5)
    main(sys.argv)
I have no experience with ROS, but I think it does install its own opencv version, so there may be version mismatch. You may find details about opencv version in the output of print(cv2.getBuildInformation()).
ROS experienced users may better advise.
We bought 20 jetson nanos and 20 Camera Module Automatic IR-Cut (https://www.amazon.com/dp/B07DNSSDGG/ref=psdc_172511_t1_B06XTP23LH)
Because we listened and thing everything RPI can do, Jetson nano can do it and better.
But only below message has been shown:
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:521 No cameras available.
We re-checked by “Cheese” app. Only message “No device found” is displayed.
Please help us :(
We don’t know how to behave in face of such a situation.
Seems that Jetson nano doesn’t have support for OV5647 sensor.
Check this link [url]https://github.com/NVIDIA-AI-IOT/jetbot/issues/29[/url]
Ouch. Camera v1 is unsupported as far as I know. I checked and there is source for a kernel module, however (Actually more than one driver); The one in Linux master is here:
You could try building a new kernel module using this documentation:
But compiling a kernel is very complicated and if you’ve never done it before (and for another architecture), it’s probably best to wait until either Nvidia or the community provides support.
@nvidia: is there anything preventing the Camera module v1 from working over the csi interface provided kernel modules are built for ov5647?
@regivaldojr @mdegans
We’ll try your solution. Thank you so much for your support!
if you ordered from amazon, you could probably return them as a considerably short period of time has passed and you could exchange them to R pi v2 board cameras, in my opinion.
References:
  • Jetson Nano Supported Components List
  • list of resources
    We have been working with OV5647, In case you need help, you can read more about it here:
    Many people visited the link but I’m surprised nobody mentioned that it is not possible to follow instructions in the article - even though it mentions how to download Jetson Nano kernel source code and compile it with the driver for v1.3 camera, at some point there is a step to “apply the patch with OV5647 camera sources” and then the command to unpack file “4.2_nano_ov5647.tar.gz” but no link to download the file. So it is not possible to actually follow steps in the article but the section “Using the OmniVision OV5647 Linux driver” gives an impression like the driver actually exists. Since v1.3 cameras are no longer produced, it would make no sense to sell the driver for it (and the article does not mention selling it), it would be cheaper to just buy v2. Therefore I assume the link to download “4.2_nano_ov5647.tar.gz” is unintentionally missing and I would be grateful if somebody shares it. I decided to reply here to save time to others - there is no point to spend time in an attempt to follow steps in the guide until the missing download link is fixed.
    I know this is old topic but the issue still exists - but unfortunately as far as I can tell nobody published usable instructions how to get v1.3 camera working. Even though it is no longer produced, it is still sold (or its clone) for $4-$5 including shipping but v2 is many times more expensive (within $16-$25 range, in some places even more), not to mention many already have v1 cameras. Of course I understand why NVidia does not support discontinued module, but if somebody knows how to get it working, please share your knowledge.
