Trouble getting raspberry pi camera to work
i am learning about my new jetson nano. i am using jetpack 4.4, and a raspberry pi V2 camera. i cannot get the camera to display any images when i test it. any assistance is greatly appreciated. i am not sure how to start troubleshooting. here ishow i am testing it:
trauts14@jetson-desktop:~$ gst-launch-1.0 nvarguscamerasrc ! nvoverlaysink
Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
Setting pipeline to PLAYING …
New clock: GstSystemClock
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:568 Failed to create CaptureSession
Got EOS from element “pipeline0”.
Execution ended after 0:00:00.002917942
Setting pipeline to READY …
Setting pipeline to NULL …
Freeing pipeline …
You would first check if imx219 driver succesfully probed your camera;
dmesg | grep imx219
[    4.653076] imx219 9-0010: tegracam sensor driver:imx219_v2.0.6
[    4.677978] imx219 10-0010: tegracam sensor driver:imx219_v2.0.6
[    4.701284] imx219 10-0010: imx219_board_setup: error during i2c read probe (-121)
[    4.701324] imx219 10-0010: board setup failed
[    4.701450] imx219: probe of 10-0010 failed with error -121
[    5.295628] tegra194-vi5 15c10000.vi: subdev imx219 9-0010 bound
First line and last line show that first camera was detected, other say than no second camera was probed.
So I have video0 node only (with no USB cam connected):
ls /dev/video*
/dev/video0
So it should be possible to use first camera.
Note it some cases you may have fooled nvargus-daemon.service, so you may restart it:
sudo systemctl restart nvargus-daemon.service
Then you should be able to run:
thank you for your assistance. this is what was returned:
trauts14@jetson-desktop:~$ ls /dev/video*
/dev/video0
trauts14@jetson-desktop:~$ /dev/video0
bash: /dev/video0: Permission denied
trauts14@jetson-desktop:~$ sudo systemctl restart nvargus-daemon.service
[sudo] password for trauts14:
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected…
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 3264 x 2464 FR = 21.000000 fps Duration = 47619048 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 3264 x 1848 FR = 28.000001 fps Duration = 35714284 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1920 x 1080 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1640 x 1232 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 120.000005 fps Duration = 8333333 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: Running with following settings:
Camera index = 0
Camera mode = 2
Output Stream W = 1920 H = 1080
seconds to Run = 0
Frame Rate = 29.999999
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
NvxBaseWorkerFunction[2575] comp OMX.Nvidia.std.iv_renderer.overlay.yuv420 Error -2147479552
ERROR: from element /GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc0: Internal data stream error.
Additional debug info:
gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc0:
streaming stopped, reason error (-5)
Execution ended after 0:00:00.927192621
GST_ARGUS: Cleaning up
CONSUMER: Done Success
GST_ARGUS: Done Success
Freeing pipeline …
hello trauts14,
it’s my curiosity why there’s permission denied failure by checking the video nodes.
these errors should related to display rendering.
are you running at command mode, had you install X window for ubuntu desktop.
please check developer guide, you may refer to Applications Using V4L2 IOCTL Directly session.
please enable V4L2 IOCTL to verify basic functionality during sensor bring-up.
thanks
thank you. i have no idea it say permission denied, but i would think it is something i did incorrectly when setting things up. here is what i get when i visited the link you provided:
trauts14@jetson-desktop:~$ v4l2-ctl --set-fmt-video=width=1920,height=1080,pixelformat=RG10 --stream-mmap --stream-count=1 -d /dev/video0 --stream-to=ov5693.raw
bash: v4l2-ctl: command not found
i forgot to mention, i am running from the terminal. i do not recall installing X windows for ubuntu.
This is probably because you issued that command (which is not correct):
/dev/video0
v4l2-ctl command is provided by apt packeage v4l-utils. You would install it with:
sudo apt update
sudo apt install v4l-utils
and retry v4l2-ctl.
thank you. i followed your instructions. this is what is showing after running the commands in terminal:
trauts14@jetson-desktop:~$ sudo apt update
Get:1 file:/var/cuda-repo-10-2-local-10.2.89 InRelease
Ign:1 file:/var/cuda-repo-10-2-local-10.2.89 InRelease
Get:2 file:/var/visionworks-repo InRelease
Ign:2 file:/var/visionworks-repo InRelease
Get:3 file:/var/visionworks-sfm-repo InRelease
Ign:3 file:/var/visionworks-sfm-repo InRelease
Get:4 file:/var/visionworks-tracking-repo InRelease
Ign:4 file:/var/visionworks-tracking-repo InRelease
Get:5 file:/var/cuda-repo-10-2-local-10.2.89 Release [574 B]
Get:6 file:/var/visionworks-repo Release [2,001 B]
Get:7 file:/var/visionworks-sfm-repo Release [2,005 B]
Get:8 file:/var/visionworks-tracking-repo Release [2,010 B]
Hit:10 Index of /ubuntu-ports bionic InRelease
Hit:11 https://repo.download.nvidia.com/jetson/common r32.4 InRelease
Get:12 Index of /ubuntu-ports bionic-updates InRelease [88.7 kB]
Hit:13 https://repo.download.nvidia.com/jetson/t210 r32.4 InRelease
Get:15 Index of /ubuntu-ports bionic-backports InRelease [74.6 kB]
Get:17 Index of /ubuntu-ports bionic-security InRelease [88.7 kB]
Get:19 Index of /ubuntu-ports bionic-updates/main arm64 Packages [1,145 kB]
Get:20 Index of /ubuntu-ports bionic-updates/main Translation-en [376 kB]
Get:21 Index of /ubuntu-ports bionic-updates/main arm64 DEP-11 Metadata [290 kB]
Get:22 Index of /ubuntu-ports bionic-updates/universe arm64 Packages [1,486 kB]
Get:23 Index of /ubuntu-ports bionic-updates/universe Translation-en [357 kB]
Get:24 Index of /ubuntu-ports bionic-updates/universe arm64 DEP-11 Metadata [283 kB]
Get:25 Index of /ubuntu-ports bionic-backports/universe arm64 DEP-11 Metadata [9,288 B]
Get:26 Index of /ubuntu-ports bionic-security/main arm64 DEP-11 Metadata [42.7 kB]
Get:27 Index of /ubuntu-ports bionic-security/universe arm64 DEP-11 Metadata [54.5 kB]
Fetched 4,295 kB in 4s (1,046 kB/s)
Reading package lists… Done
Building dependency tree
Reading state information… Done
10 packages can be upgraded. Run ‘apt list --upgradable’ to see them.
trauts14@jetson-desktop:~$ sudo apt install v4l-utils
The following packages were automatically installed and are no longer required:
apt-clone archdetect-deb bogl-bterm busybox-static
cryptsetup-bin dpkg-repack gir1.2-timezonemap-1.0
gir1.2-xkl-1.0 grub-common kde-window-manager kinit kio
kpackagetool5 kwayland-data kwin-common kwin-data kwin-x11
libdebian-installer4 libkdecorations2-5v5
libkdecorations2private5v5 libkf5activities5 libkf5attica5
libkf5completion-data libkf5completion5
libkf5declarative-data libkf5declarative5 libkf5doctools5
libkf5globalaccel-data libkf5globalaccel5
libkf5globalaccelprivate5 libkf5idletime5
libkf5jobwidgets-data libkf5jobwidgets5
libkf5kcmutils-data libkf5kcmutils5 libkf5kiocore5
libkf5kiontlm5 libkf5kiowidgets5 libkf5newstuff-data
libkf5newstuff5 libkf5newstuffcore5 libkf5package-data
libkf5package5 libkf5plasma5 libkf5quickaddons5
libkf5solid5 libkf5solid5-data libkf5sonnet5-data
libkf5sonnetcore5 libkf5sonnetui5 libkf5textwidgets-data
libkf5textwidgets5 libkf5waylandclient5
libkf5waylandserver5 libkf5xmlgui-bin libkf5xmlgui-data
libkf5xmlgui5 libkscreenlocker5 libkwin4-effect-builtins1
libkwineffects11 libkwinglutils11 libkwinxrenderutils11
libllvm9 libqgsttools-p1 libqt5designer5 libqt5help5
libqt5multimedia5 libqt5multimedia5-plugins
libqt5multimediaquick-p5 libqt5multimediawidgets5
libqt5quickwidgets5 libxcb-composite0 libxcb-cursor0
libxcb-damage0 os-prober python3-dbus.mainloop.pyqt5
python3-icu python3-pam python3-pyqt5 python3-pyqt5.qtsvg
python3-pyqt5.qtwebkit python3-sip
qml-module-org-kde-kquickcontrolsaddons
qml-module-qtmultimedia qml-module-qtquick2 rdate tasksel
tasksel-data
Use ‘sudo apt autoremove’ to remove them.
The following additional packages will be installed:
libv4l2rds0
The following NEW packages will be installed:
libv4l2rds0 v4l-utils
0 upgraded, 2 newly installed, 0 to remove and 10 not upgraded.
Need to get 399 kB of archives.
After this operation, 1,553 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 Index of /ubuntu-ports bionic/main arm64 libv4l2rds0 arm64 1.14.2-1 [14.8 kB]
Get:2 Index of /ubuntu-ports bionic/universe arm64 v4l-utils arm64 1.14.2-1 [384 kB]
Fetched 399 kB in 1s (548 kB/s)
debconf: delaying package configuration, since apt-utils is not installed
Selecting previously unselected package libv4l2rds0:arm64.
(Reading database … 163772 files and directories currently installed.)
Preparing to unpack …/libv4l2rds0_1.14.2-1_arm64.deb …
Unpacking libv4l2rds0:arm64 (1.14.2-1) …
Selecting previously unselected package v4l-utils.
Preparing to unpack …/v4l-utils_1.14.2-1_arm64.deb …
Unpacking v4l-utils (1.14.2-1) …
Setting up libv4l2rds0:arm64 (1.14.2-1) …
Setting up v4l-utils (1.14.2-1) …
Processing triggers for man-db (2.8.3-2ubuntu0.1) …
Processing triggers for libc-bin (2.27-3ubuntu1.3) …
hello trauts14,
did you have software modifications? did you install JetPack-4.4 release via SDKManager?
i do not think i used SDK manager. i believe i simply installed jetpack 4.4. if i start from scratch, should i install jetpack 4.4 via sdk manager?
It is unclear what is your problem now you have v4l2-ctl.
This should produce a file ov5693.raw (note you are probably using another sensor than ov5693 with Nano) with a single frame in bayer RG10 format (file may be 2 bytes (16 bits) per 10bits value) .
Also note that you should add bypass=0 so that it doesn’t interferes with argus that may use the same camera.
In case argus daemon is broken:
And capture with:
v4l2-ctl --set-fmt-video=width=1920,height=1080,pixelformat=RG10 --set-ctrl bypass_mode=0 --stream-mmap --stream-count=1 -d /dev/video0 --stream-to=imx219.RG10
thank you. i entered the commands you mentioned into terminal.
can you suggest a command to test the camera to make sure all is well?
I can’t tell any viewer for Bayer RG10 format.
For checking framerate, you may try to run acquisition for more than one frame (here 10s, so 3000 frames):
v4l2-ctl --set-fmt-video=width=1920,height=1080,pixelformat=RG10 --set-ctrl bypass_mode=0 --stream-mmap --stream-count=3000 -d /dev/video0 --stream-to=imx219.RG10
For seeing image, you may try debayering with nvarguscamera in gstreamer.
As you don’t have X running, not sure but you may try :
# This may display as ascii art in terminal:
gst-launch-1.0 -v nvarguscamerasrc ! nvvidconv ! videoconvert ! cacasink
# Or try to make a H264 video (here 10s so 3000 frames)
# You would transfer it to another computing able to display
gst-launch-1.0 -ev  nvarguscamerasrc num-buffers=3000 ! nvv4l2h264enc ! h264parse ! qtmux ! filesink location=test.mov
hello trauts14,
FYI, nvarguscamerasrc to render camera frames with X window,
you may have a try to execute $ xinit & to initialize the service before running gst commands to display the frame.
thanks
thank you much, the camera is functional now. do you happen to have a link for a tutorial on making, and running python scripts with the jetson nano? when i read HELLO AI WORLD, i am stuck at this part:
Coding Your Own Image Recognition Program (Python)
In the previous step, we ran a sample application that came with the jetson-inference repo.
Now, we’re going to walk through creating a new program from scratch in Python for image recognition called my-recognition.py . This script will load an arbitrary image from disk and classify it using the imageNet object. The completed source at python/examples/my-recognition.py
#!/usr/bin/python3 import jetson.inference import jetson.utils import argparse # parse the command line parser = argparse.ArgumentParser() parser.add_argument(“filename”, type=str, help=“filename of the image to process”) parser.add_argument(“–network”, type=str, default=“googlenet”, help=“model to use, can be: googlenet, resnet-18, ect.”) args = parser.parse_args() # load an image (into shared CPU/GPU memory) img = jetson.utils.loadImage(args.filename) # load the recognition network net = jetson.inference.imageNet(args.network) # classify the image class_idx, confidence = net.Classify(img) # find the object description class_desc = net.GetClassDesc(class_idx) # print out the result print(“image is recognized as ‘{:s}’ (class #{:d}) with {:f}% confidence”.format(class_desc, class_idx, confidence * 100))
hello trauts14,
here’s GitHub - dusty-nv/jetson-inference: Hello AI World guide to deploying deep-learning inference networks and deep vision primitives with TensorRT and NVIDIA Jetson., which contain instructional guide and Video Walkthroughs for your reference,
please also refer to Tutorials page for several training videos for reference,
thanks
