CSI-Camera Raspberry Pi v2 not work on Jetson Nano
I have a Jetson Nano Board, with a Raspberry CAM v2 correctly connected to MIPI Port.
My camera work perfectly with the following command:
$ gst-launch-1.0 nvarguscamerasrc ! 'video/x-raw(memory:NVMM),width=3820, height=2464, framerate=21/1, format=NV12' ! nvvidconv flip-method=0 ! 'video/x-raw,width=960, height=616' ! nvvidconv ! nvegltransform ! nveglglessink -e
but, when i try run:
import cv2
def gstreamer_pipeline (capture_width=1280, capture_height=720, display_width=1280,
     display_height=720, framerate=60, flip_method=0) :
     return ('nvarguscamerasrc ! '
    'video/x-raw(memory:NVMM), '
    'width=(int)%d, height=(int)%d, '
    'format=(string)NV12, framerate=(fraction)%d/1 ! '
    'nvvidconv flip-method=%d ! '
    'video/x-raw, width=(int)%d, height=(int)%d, format=(string)BGRx ! '
    'videoconvert ! '
    'video/x-raw, format=(string)BGR ! appsink'  % (capture_width,capture_height,framerate,flip_method,display_width,display_height))
def show_camera():
    # To flip the image, modify the flip_method parameter (0 and 2 are the most common)
    print gstreamer_pipeline(flip_method=0)
    cap = cv2.VideoCapture(gstreamer_pipeline(flip_method=0), cv2.CAP_GSTREAMER)
    if cap.isOpened():
        window_handle = cv2.namedWindow('CSI Camera', cv2.WINDOW_AUTOSIZE)
        # Window
        while cv2.getWindowProperty('CSI Camera',0) >= 0:
            ret_val, img = cap.read();
            cv2.imshow('CSI Camera',img)
	    # This also acts as
            keyCode = cv2.waitKey(30) & 0xff
            # Stop the program on the ESC key
            if keyCode == 27:
               break
        cap.release()
        cv2.destroyAllWindows()
    else:
        print 'Unable to open camera'
if __name__ == '__main__':
    show_camera()
i get:
'Unable to open camera'.
when i put:
$ v4l2-ctl -d /dev/video0 --list-formats-ext
i get:
ioctl: VIDIOC_ENUM_FMT
	Index       : 0
	Type        : Video Capture
	Pixel Format: 'RG10'
	Name        : 10-bit Bayer RGRG/GBGB
		Size: Discrete 3280x2464
			Interval: Discrete 0.048s (21.000 fps)
		Size: Discrete 3280x1848
			Interval: Discrete 0.036s (28.000 fps)
		Size: Discrete 1920x1080
			Interval: Discrete 0.033s (30.000 fps)
			Interval: Discrete 0.017s (60.000 fps)
Why i can’t open my camera with “cv2.VideoCapture(gstreamer_pipeline)” ?
One difference I can see is the resolution. In launching pipeline, it is 3820x2464p21 and then being converted to 960x616. In the cv code, it is 720p60. You may try to run identical resolution.
Some posts about OpenCV:
[url]https://devtalk.nvidia.com/default/topic/987537/videocapture-fails-to-open-onboard-camera-l4t-24-2-1-opencv-3-1/[/url]
[url]https://devtalk.nvidia.com/default/topic/1024245/jetson-tx2/opencv-3-3-and-integrated-camera-problems-/post/5210735/#5210735[/url]
Hi @tho7o,
The GStreamer pipelines you are using aren´t exactly the same, they differ in the caps and elements used. For example, framerate and resolution are different.
You may try the following GStreamer pipeline (based on your opencv snippet) with gst-launch-1.0 to check if it runs:
$ gst-launch-1.0 -v nvarguscamerasrc ! 'video/x-raw(memory:NVMM),width=1280, height=720, framerate=60/1, format=NV12' ! nvvidconv flip-method=0 ! 'video/x-raw, width=1280, height=720, format=BGRx' ! videoconvert ! 'video/x-raw, format=BGR' ! identity silent=false ! fakesink -e
The identity element will prompt info about each frame that is flowing in the pipeline, so this will be helpful to determine if the pipeline is running as expected. The fakesink element will act similar to an appsink element, but it will consume and discard each frame that arrives at it.
If the above pipeline works fine, the problem may be directly related with opencv. I will suggest to verify if your opencv build has support for GStreamer1-0 enabled. You can check it by adding the following line to your code:
print cv2.getBuildInformation()
Also, you may try to run a simpler pipeline with your opencv code by using a videotestsrc element instead the camera capture element to confirm that GStreamer is working as expected with your opencv build. The suggested pipeline should be something like this:
def gstreamer_pipeline (capture_width=640, capture_height=480, framerate=15) :
     return ('videotestsrc ! '
    'video/x-raw, width=(int)%d, height=(int)%d, '
    'videoconvert ! '
    'video/x-raw, format=(string)BGR ! appsink'  % (capture_width,capture_height,framerate))
I hope the above information helps you.
Hi guys,
Thanks for your help. Im trying remove OpenCV 3.3, and install OpenCV 4.
I’ll tell you something tomorrow.
Regards
Hi Guys,
I installed Opencv 4 with this script, including “-D WITH_GSTREAMER=ON” on the statement:
#!/bin/bash
# Copyright (c) 2018, NVIDIA CORPORATION.  All rights reserved.
# NVIDIA Corporation and its licensors retain all intellectual property
# and proprietary rights in and to this software, related documentation
# and any modifications thereto.  Any use, reproduction, disclosure or
# distribution of this software and related documentation without an express
# license agreement from NVIDIA Corporation is strictly prohibited.
if [ "$#" -ne 1 ]; then
    echo "Usage: $0 <Install Folder>"
    exit
fi
folder="$1"
user="nvidia"
passwd="nvidia"
echo "** Remove OpenCV3.3 first"
sudo sudo apt-get purge *libopencv*
echo "** Install requirement"
sudo apt-get update
sudo apt-get install -y build-essential cmake git libgtk2.0-dev pkg-config libavcodec-dev libavformat-dev libswscale-dev
sudo apt-get install -y libgstreamer1.0-dev libgstreamer-plugins-base1.0-dev
sudo apt-get install -y python2.7-dev python3.6-dev python-dev python-numpy python3-numpy
sudo apt-get install -y libtbb2 libtbb-dev libjpeg-dev libpng-dev libtiff-dev libjasper-dev libdc1394-22-dev
sudo apt-get install -y libv4l-dev v4l-utils qv4l2 v4l2ucp
sudo apt-get install -y curl
sudo apt-get update
echo "** Download opencv-4.0.0"
cd $folder
curl -L https://github.com/opencv/opencv/archive/4.0.0.zip -o opencv-4.0.0.zip
curl -L https://github.com/opencv/opencv_contrib/archive/4.0.0.zip -o opencv_contrib-4.0.0.zip
unzip opencv-4.0.0.zip
unzip opencv_contrib-4.0.0.zip
cd opencv-4.0.0/
echo "** Building..."
mkdir release
cd release/
cmake -D WITH_CUDA=ON -D CUDA_ARCH_BIN="5.3" -D CUDA_ARCH_PTX="" -D OPENCV_EXTRA_MODULES_PATH=../../opencv_contrib-4.0.0/modules -D WITH_GSTREAMER=ON -D WITH_LIBV4L=ON -D BUILD_opencv_python2=ON -D BUILD_opencv_python3=ON -D BUILD_TESTS=OFF -D BUILD_PERF_TESTS=OFF -D BUILD_EXAMPLES=OFF -D CMAKE_BUILD_TYPE=RELEASE -D CMAKE_INSTALL_PREFIX=/usr/local ..
make -j3
sudo make install
sudo apt-get install -y python-opencv python3-opencv
echo "** Install opencv-4.0.0 successfully"
echo "** Bye :)"
now, i have GSTREAMER = ON. Take a look when i run “getBuildInformation()”
import cv2
print (cv2.getBuildInformation())
General configuration for OpenCV 4.0.0 =====================================
  Version control:               unknown
  Extra modules:
    Location (extra):            /home/toni/OpenCV/opencv_contrib-4.0.0/modules
    Version control (extra):     unknown
  Platform:
    Timestamp:                   2019-06-06T02:33:02Z
    Host:                        Linux 4.9.140-tegra aarch64
    CMake:                       3.10.2
    CMake generator:             Unix Makefiles
    CMake build tool:            /usr/bin/make
    Configuration:               RELEASE
  CPU/HW features:
    Baseline:                    NEON FP16
      required:                  NEON
      disabled:                  VFPV3
  C/C++:
    Built as dynamic libs?:      YES
    C++ Compiler:                /usr/bin/c++  (ver 7.4.0)
    C++ flags (Release):         -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wundef -Winit-self -Wpointer-arith -Wshadow -Wsign-promo -Wuninitialized -Winit-self -Wno-narrowing -Wno-delete-non-virtual-dtor -Wno-comment -Wimplicit-fallthrough=3 -Wno-strict-overflow -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections    -fvisibility=hidden -fvisibility-inlines-hidden -O3 -DNDEBUG  -DNDEBUG
    C++ flags (Debug):           -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wundef -Winit-self -Wpointer-arith -Wshadow -Wsign-promo -Wuninitialized -Winit-self -Wno-narrowing -Wno-delete-non-virtual-dtor -Wno-comment -Wimplicit-fallthrough=3 -Wno-strict-overflow -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections    -fvisibility=hidden -fvisibility-inlines-hidden -g  -O0 -DDEBUG -D_DEBUG
    C Compiler:                  /usr/bin/cc
    C flags (Release):           -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wmissing-prototypes -Wstrict-prototypes -Wundef -Winit-self -Wpointer-arith -Wshadow -Wuninitialized -Winit-self -Wno-narrowing -Wno-comment -Wimplicit-fallthrough=3 -Wno-strict-overflow -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections    -fvisibility=hidden -O3 -DNDEBUG  -DNDEBUG
    C flags (Debug):             -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wmissing-prototypes -Wstrict-prototypes -Wundef -Winit-self -Wpointer-arith -Wshadow -Wuninitialized -Winit-self -Wno-narrowing -Wno-comment -Wimplicit-fallthrough=3 -Wno-strict-overflow -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections    -fvisibility=hidden -g  -O0 -DDEBUG -D_DEBUG
    Linker flags (Release):
    Linker flags (Debug):
    ccache:                      NO
    Precompiled headers:         YES
    Extra dependencies:          m pthread cudart_static -lpthread dl rt nppc nppial nppicc nppicom nppidei nppif nppig nppim nppist nppisu nppitc npps cublas cufft -L/usr/local/cuda/lib64 -L/usr/lib/aarch64-linux-gnu
    3rdparty dependencies:
  OpenCV modules:
    To be built:                 aruco bgsegm bioinspired calib3d ccalib core cudaarithm cudabgsegm cudacodec cudafeatures2d cudafilters cudaimgproc cudalegacy cudaobjdetect cudaoptflow cudastereo cudawarping cudev datasets dnn dnn_objdetect dpm face features2d flann freetype fuzzy gapi hdf hfs highgui img_hash imgcodecs imgproc java_bindings_generator line_descriptor ml objdetect optflow phase_unwrapping photo plot python2 python3 python_bindings_generator reg rgbd saliency shape stereo stitching structured_light superres surface_matching text tracking video videoio videostab xfeatures2d ximgproc xobjdetect xphoto
    Disabled:                    world
    Disabled by dependency:      -
    Unavailable:                 cnn_3dobj cvv java js matlab ovis sfm ts viz
    Applications:                apps
    Documentation:               NO
    Non-free algorithms:         NO
  GUI:
    GTK+:                        YES (ver 3.22.30)
      GThread :                  YES (ver 2.56.4)
      GtkGlExt:                  NO
    VTK support:                 NO
  Media I/O:
    ZLib:                        /usr/lib/aarch64-linux-gnu/libz.so (ver 1.2.11)
    JPEG:                        /usr/lib/aarch64-linux-gnu/libjpeg.so (ver 80)
    WEBP:                        build (ver encoder: 0x020e)
    PNG:                         /usr/lib/aarch64-linux-gnu/libpng.so (ver 1.6.34)
    TIFF:                        /usr/lib/aarch64-linux-gnu/libtiff.so (ver 42 / 4.0.9)
    JPEG 2000:                   build (ver 1.900.1)
    OpenEXR:                     build (ver 1.7.1)
    HDR:                         YES
    SUNRASTER:                   YES
    PXM:                         YES
    PFM:                         YES
  Video I/O:
    DC1394:                      YES (ver 2.2.5)
    FFMPEG:                      YES
      avcodec:                   YES (ver 57.107.100)
      avformat:                  YES (ver 57.83.100)
      avutil:                    YES (ver 55.78.100)
      swscale:                   YES (ver 4.8.100)
      avresample:                NO
    GStreamer:
      base:                      YES (ver 1.14.1)
      video:                     YES (ver 1.14.1)
      app:                       YES (ver 1.14.1)
      riff:                      YES (ver 1.14.1)
      pbutils:                   YES (ver 1.14.1)
    v4l/v4l2:                    linux/videodev2.h
  Parallel framework:            pthreads
  Trace:                         YES (built-in)
  Other third-party libraries:
    Lapack:                      YES (/usr/lib/aarch64-linux-gnu/liblapack.so /usr/lib/aarch64-linux-gnu/libcblas.so /usr/lib/aarch64-linux-gnu/libatlas.so)
    Eigen:                       YES (ver 3.3.4)
    Custom HAL:                  YES (carotene (ver 0.0.1))
    Protobuf:                    build (3.5.1)
  NVIDIA CUDA:                   YES (ver 10.0, CUFFT CUBLAS)
    NVIDIA GPU arch:             53
    NVIDIA PTX archs:
  OpenCL:                        YES (no extra features)
    Include path:                /home/toni/OpenCV/opencv-4.0.0/3rdparty/include/opencl/1.2
    Link libraries:              Dynamic load
  Python 2:
    Interpreter:                 /usr/bin/python2.7 (ver 2.7.15)
    Libraries:                   /usr/lib/aarch64-linux-gnu/libpython2.7.so (ver 2.7.15rc1)
    numpy:                       /usr/lib/python2.7/dist-packages/numpy/core/include (ver 1.13.3)
    packages path:               lib/python2.7/dist-packages
  Python 3:
    Interpreter:                 /usr/bin/python3 (ver 3.6.7)
    Libraries:                   /usr/lib/aarch64-linux-gnu/libpython3.6m.so (ver 3.6.7)
    numpy:                       /usr/local/lib/python3.6/dist-packages/numpy/core/include (ver 1.16.3)
    packages path:               lib/python3.6/dist-packages
  Python (for build):            /usr/bin/python2.7
  Java:
    ant:                         NO
    JNI:                         NO
    Java wrappers:               NO
    Java tests:                  NO
  Install to:                    /usr/local
i add PYTHONPATH on the .bashrc file:
# virtualenv and virtualenvwrapper
export PYTHONPATH=/home/toni/OpenCV/opencv-4.0.0/release/lib/python3
and now, i can import cv2 on python3 correctly.
toni@jetson:~$ python3
Python 3.6.7 (default, Oct 22 2018, 11:32:17)
[GCC 8.2.0] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import cv2
>>> print(cv2.__version__)
4.0.0
but, when i run sudo python3, and try import cv2, python can’t import it.
toni@jetson:~$ sudo python3
>>> import cv2
  File "<stdin>", line 1, in <module>
ModuleNotFoundError: No module named 'cv2'
How can i fix this issue? i wouldn’t use a enviroment variable. Is it possible?
First things first, the IMX219 kernel module should be loaded, inode /dev/video0 should be appeare.
with a raspi V2 video sensor which chips is imx219 connect through CSI, the default drivers in jetson-l4t image already build in the kernel
[s]I couldn’t find my IMX219.ko kernel module,
jetson# find /lib/modules/`uname -r` -name "imx*" | wc -l
0
[/s]
default build in the SDK kernel
Your script works well under python2 on my board. But it not working under python3. I have to use python3 for some reasons. Anything I can do to fix it?
I’m using the code posted here to initialize the camera. I’m using different resolutions for capture (3280x2464) and for display(640x480) as is shown. The camera works but the frame is captured in the resolution of display:
ret_val, frame = cap.read()    #---> frame get shape 640 x 480
Code used to initialize the cam:
import cv2
def gstreamer_pipeline (capture_width=3280, capture_height=2464, display_width=640,
     display_height=480, framerate=21, flip_method=0) :
    'videoconvert ! '
My question is:
How could I capture the frame at 3280x2464 while keeping the display 640x480?. I tried putting both resolutions as 3280x2464 and then resizing the frame to 640x480 for displaying. It works but is very slow FPS=15. Is there a more efficient way?
ret_val, frame = cap.read()   # ---> frame get shape 3280x2464
img = cv2.resize(frame, (640,480))
cv2.imshow("display",img)
Please check if your source can achieve 21fps through fpsdisplaysink. Below is a sample pipeline of using fpsdisplaysink.
[url]https://devtalk.nvidia.com/default/topic/1027772/jetson-tx2/two-csi-cameras-on-tx2/post/5227935/#5227935[/url]
Everything worked fine with me!
Thank you bro.!
I rebuilt it the way you said (like this “-D WITH_GSTREAMER=ON” ) and the result is good.
