[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.140-tegra (wong@wong-HP-Z420-Workstation) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #6 SMP PREEMPT Wed Jul 29 13:23:38 CST 2020
[ 0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[ 0.000000] OF: fdt:memory scan node memory, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 2c000000
[ 0.000000] OF: fdt: - ac200000 , 44800000
[ 0.000000] OF: fdt: - 100000000 , 180000000
[ 0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options '')
[ 0.000000] bootconsole [tegra_comb_uart0] enabled
[ 0.000000] Found tegra_fbmem: 00800000@a06aa000
[ 0.000000] Found lut_mem: 00002008@a06a4000
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb2_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb3_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node grid-of-semaphores, compatible id nvidia,gosmem
[ 0.000000] cma: Reserved 64 MiB at 0x00000000c2000000
[ 0.000000] On node 0 totalpages: 2031101
[ 0.000000] DMA zone: 7160 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 458237 pages, LIFO batch:31
[ 0.000000] Normal zone: 24576 pages used for memmap
[ 0.000000] Normal zone: 1572864 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 25 pages/cpu @ffffffc1ffd09000 s61656 r8192 d32552 u102400
[ 0.000000] pcpu-alloc: s61656 r8192 d32552 u102400 alloc=25*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1999365
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 video=tegrafb earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt rootfs.slot_suffix= tegra_fbmem=0x800000@0xa06aa000 lut_mem=0x2008@0xa06a4000 usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1 quiet
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 163840 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 262144 bytes
[ 0.000000] early log buf free: 29200(89%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Memory: 7184188K/8124404K available (15294K kernel code, 2938K rwdata, 6736K rodata, 8576K init, 609K bss, 186552K reserved, 753664K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f70000 ( 15296 KB)
[ 0.000000] .rodata : 0xffffff8008f70000 - 0xffffff8009610000 ( 6784 KB)
[ 0.000000] .init : 0xffffff8009610000 - 0xffffff8009e70000 ( 8576 KB)
[ 0.000000] .data : 0xffffff8009e70000 - 0xffffff800a14e808 ( 2939 KB)
[ 0.000000] .bss : 0xffffff800a14e808 - 0xffffff800a1e6f7c ( 610 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf08000000 ( 128 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc200000000 ( 8192 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000005] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000727] Console: colour dummy device 80x25
[ 0.000739] console [tty0] enabled
[ 0.000747] bootconsole [tegra_comb_uart0] disabled
[ 0.000761] kmemleak: Kernel memory leak detector disabled
[ 0.000780] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.000797] pid_max: default: 32768 minimum: 301
[ 0.001881] Security Framework initialized
[ 0.002450] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.002462] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.004069] ftrace: allocating 47143 entries in 185 pages
[ 0.401891] sched-energy: Sched-energy-costs installed from DT
[ 0.401911] ASID allocator initialised with 65536 entries
[ 0.436556] tegra-id: chipid=21917.
[ 0.436568] tegra-id: opt_subrevision=1.
[ 0.436594] Tegra Revision: A02 SKU: 0xde CPU Process: 0 SoC Process: 0
[ 0.436617] DTS File Name: /home/wang/Arducam/Jetson/l4t-32.4.3-NX/Linux_for_Tegra/source/public/kernel_src/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t19x/jakku/kernel-dts/tegra194-p3668-all-p3509-0000.dts
[ 0.436628] DTB Build time: Sep 24 2020 17:09:45
[ 0.484769] CPU1: Booted secondary processor [4e0f0040]
[ 0.516843] CPU2: Booted secondary processor [4e0f0040]
[ 0.548957] CPU3: Booted secondary processor [4e0f0040]
[ 0.581189] CPU4: Booted secondary processor [4e0f0040]
[ 0.613338] CPU5: Booted secondary processor [4e0f0040]
[ 0.613612] Brought up 6 CPUs
[ 0.613622] SMP: Total of 6 processors activated.
[ 0.613630] CPU features: detected feature: Privileged Access Never
[ 0.613637] CPU features: detected feature: LSE atomic instructions
[ 0.613643] CPU features: detected feature: User Access Override
[ 0.613649] CPU features: detected feature: 32-bit EL0 Support
[ 0.615290] CPU: All CPU(s) started at EL2
[ 0.615362] alternatives: patching kernel code
[ 0.621677] devtmpfs: initialized
[ 0.655064] Initilizing CustomIPI irq domain
[ 0.655296] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.655316] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.667649] pinctrl core: initialized pinctrl subsystem
[ 0.667917] OS set in device tree is not L4T.
[ 0.668185] regulator-dummy: no parameters
[ 0.668414] Initializing plugin-manager
[ 0.668526] Plugin module not found
[ 0.668597] Plugin-manager status disabled
[ 0.669843] NET: Registered protocol family 16
[ 0.671159] pstore: using zlib compression
[ 0.671184] console [pstore-1] enabled
[ 0.671192] pstore: Registered ramoops as persistent store backend
[ 0.671201] ramoops: attached 0x200000@0xf0800000, ecc: 0/0
[ 0.684156] cpuidle: using governor menu
[ 0.685188] bpmp: waiting for handshake
[ 0.685200] bpmp: handshake completed
[ 0.685232] bpmp: synchronizing channels
[ 0.685246] bpmp: channels synchronized
[ 0.685253] bpmp: mail init ok
[ 0.687653] t19x-arm-smmu 12000000.iommu: found 3 SMMUs and ISO SMMU id is 2
[ 0.687871] t19x-arm-smmu 12000000.iommu: probing hardware configuration...
[ 0.687877] t19x-arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.687884] t19x-arm-smmu 12000000.iommu: stage 1 translation
[ 0.687890] t19x-arm-smmu 12000000.iommu: stage 2 translation
[ 0.687896] t19x-arm-smmu 12000000.iommu: nested translation
[ 0.687905] t19x-arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.687913] t19x-arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.687919] t19x-arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.687927] t19x-arm-smmu 12000000.iommu: Stage-1: 39-bit VA -> 48-bit IPA
[ 0.687933] t19x-arm-smmu 12000000.iommu: Stage-2: 39-bit IPA -> 48-bit PA
[ 0.691039] vdso: 2 pages (1 code @ ffffff8008f77000, 1 data @ ffffff8009e74000)
[ 0.691070] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.693638] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.694747] tegra_aon_clk_init: ok
[ 0.694759] Registering BPMP clocks...
[ 0.694860] tegra_bpmp_clk_init: clock init ok (400 clks)
[ 0.695381] Serial: AMBA PL011 UART driver
[ 0.695549] tegra_powergate_init: DONE
[ 0.695624] DTS File Name: /home/wang/Arducam/Jetson/l4t-32.4.3-NX/Linux_for_Tegra/source/public/kernel_src/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t19x/jakku/kernel-dts/tegra194-p3668-all-p3509-0000.dts
[ 0.695640] DTB Build time: Sep 24 2020 17:09:45
[ 0.698246] Tegra reboot handler registered.
[ 0.704971] iommu: Adding device 14160000.pcie to group 0
[ 0.705571] iommu: Adding device 141a0000.pcie to group 1
[ 0.706733] iommu: Adding device 2490000.ether_qos to group 2
[ 0.707155] iommu: Adding device 3100000.serial to group 3
[ 0.707577] iommu: Adding device 3110000.serial to group 4
[ 0.707897] iommu: Adding device 3140000.serial to group 5
[ 0.708442] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.708675] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[ 0.708701] tegra-pmc: ### PMC reset source: TEGRA_SOFTWARE_RESET
[ 0.708711] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L1
[ 0.708717] tegra-pmc: ### PMC reset status reg: 0x2d
[ 0.708756] tegra-pmc: PMC Prod config success
[ 0.708950] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.708965] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.709231] iommu: Adding device 3400000.sdhci to group 6
[ 0.709653] iommu: Adding device 3210000.spi to group 7
[ 0.710009] iommu: Adding device 3230000.spi to group 8
[ 0.710365] iommu: Adding device 3270000.spi to group 9
[ 0.711225] iommu: Adding device 3160000.i2c to group 10
[ 0.711590] iommu: Adding device c240000.i2c to group 11
[ 0.711933] iommu: Adding device 3180000.i2c to group 12
[ 0.712271] iommu: Adding device 3190000.i2c to group 13
[ 0.712751] iommu: Adding device 31b0000.i2c to group 14
[ 0.713096] iommu: Adding device 31c0000.i2c to group 15
[ 0.713424] iommu: Adding device c250000.i2c to group 16
[ 0.713774] iommu: Adding device 31e0000.i2c to group 17
[ 0.714266] iommu: Adding device sound to group 18
[ 0.714698] iommu: Adding device 3510000.hda to group 19
[ 0.715178] iommu: Adding device bc00000.rtcpu to group 20
[ 0.717193] iommu: Adding device 13e10000.host1x to group 21
[ 0.717641] iommu: Adding device 13e10000.host1x:ctx0 to group 22
[ 0.717967] iommu: Adding device 13e10000.host1x:ctx1 to group 23
[ 0.718264] iommu: Adding device 13e10000.host1x:ctx2 to group 24
[ 0.718649] iommu: Adding device 13e10000.host1x:ctx3 to group 25
[ 0.719022] iommu: Adding device 13e10000.host1x:ctx4 to group 26
[ 0.719348] iommu: Adding device 13e10000.host1x:ctx5 to group 27
[ 0.719635] iommu: Adding device 13e10000.host1x:ctx6 to group 28
[ 0.720013] iommu: Adding device 13e10000.host1x:ctx7 to group 29
[ 0.720436] iommu: Adding device 15340000.vic to group 30
[ 0.720804] iommu: Adding device 15380000.nvjpg to group 31
[ 0.721044] iommu: Adding device 15500000.tsec to group 32
[ 0.721299] iommu: Adding device 15100000.tsecb to group 33
[ 0.721541] iommu: Adding device 15480000.nvdec to group 34
[ 0.721770] iommu: Adding device 15140000.nvdec1 to group 35
[ 0.722006] iommu: Adding device 154c0000.nvenc to group 36
[ 0.722265] iommu: Adding device 15a80000.nvenc1 to group 37
[ 0.722600] iommu: Adding device 15880000.nvdla0 to group 38
[ 0.723080] iommu: Adding device 158c0000.nvdla1 to group 39
[ 0.723567] iommu: Adding device 15200000.nvdisplay to group 40
[ 0.723743] platform 15200000.nvdisplay: IOVA linear map 0x00000000a06aa000(800000)
[ 0.723754] platform 15200000.nvdisplay: IOVA linear map 0x00000000a06a4000(3000)
[ 0.727710] platform 15200000.nvdisplay: IOVA linear map 0x00000000c6000000(2a000000)
[ 0.727788] t19x-arm-smmu: Adding 15200000.nvdisplay to ISO SMMU client
[ 0.728470] iommu: Adding device 15210000.nvdisplay to group 41
[ 0.728521] t19x-arm-smmu: Adding 15210000.nvdisplay to ISO SMMU client
[ 0.729956] iommu: Adding device 15c10000.vi to group 42
[ 0.730095] t19x-arm-smmu: Adding 15c10000.vi to ISO SMMU client
[ 0.730444] iommu: Adding device 14800000.isp to group 43
[ 0.731216] iommu: Adding device 16000000.pva0 to group 44
[ 0.731662] iommu: Adding device 16800000.pva1 to group 45
[ 0.731984] iommu: Adding device 15810000.se to group 46
[ 0.732382] iommu: Adding device 15820000.se to group 47
[ 0.732631] iommu: Adding device 15830000.se to group 48
[ 0.732857] iommu: Adding device 15840000.se to group 49
[ 0.733064] iommu: Adding device c1a0000.aon to group 50
[ 0.734610] iommu: Adding device d000000.bpmp to group 51
[ 0.734990] bpmp: ping status is 0
[ 0.735142] bpmp d000000.bpmp: firmware tag is e73a758761f0c6d24a1e69a2ac6b5035
[ 0.738042] bpmp d000000.bpmp: probe ok
[ 0.739181] tegra-reset 0.bpmp_reset: registered 190 resets.
[ 0.739579] iommu: Adding device smmu_test to group 52
[ 0.740458] mc: mapped MMIO address: 0xffffff800a5c0000 -> 0x2c10000
[ 0.740484] mc: mapped MMIO address: 0xffffff800a5e0000 -> 0x2c20000
[ 0.740506] mc: mapped MMIO address: 0xffffff800a7b0000 -> 0x2c30000
[ 0.740528] mc: mapped MMIO address: 0xffffff800a7d0000 -> 0x2c40000
[ 0.740551] mc: mapped MMIO address: 0xffffff800b010000 -> 0x2c50000
[ 0.740571] mc: mapped MMIO address: 0xffffff800b030000 -> 0x2b80000
[ 0.740590] mc: mapped MMIO address: 0xffffff800b050000 -> 0x2b90000
[ 0.740610] mc: mapped MMIO address: 0xffffff800b070000 -> 0x2ba0000
[ 0.740629] mc: mapped MMIO address: 0xffffff800b090000 -> 0x2bb0000
[ 0.740649] mc: mapped MMIO address: 0xffffff800b0b0000 -> 0x1700000
[ 0.740668] mc: mapped MMIO address: 0xffffff800b0d0000 -> 0x1710000
[ 0.740687] mc: mapped MMIO address: 0xffffff800b0f0000 -> 0x1720000
[ 0.740707] mc: mapped MMIO address: 0xffffff800b110000 -> 0x1730000
[ 0.740726] mc: mapped MMIO address: 0xffffff800b130000 -> 0x1740000
[ 0.740775] mc: mapped MMIO address: 0xffffff800b150000 -> 0x1750000
[ 0.740803] mc: mapped MMIO address: 0xffffff800b170000 -> 0x1760000
[ 0.740820] mc: mapped MMIO address: 0xffffff800b190000 -> 0x1770000
[ 0.740891] mc-err: mcerr ops are set to t19x
[ 0.745724] iommu: Adding device 2600000.dma to group 53
[ 0.750557] gpio gpiochip0: gpio-line-names specifies 240 line names but there are 224 lines on the chip
[ 0.751718] GPIO line 339 (wifi-enable) hogged as output/high
[ 0.751755] GPIO line 412 (camera-control-output-low) hogged as output/low
[ 0.751787] GPIO line 413 (camera-control-output-low) hogged as output/low
[ 0.752064] gpiochip_setup_dev: registered GPIOs 288 to 511 on device: gpiochip0 (tegra-gpio)
[ 0.757618] gpio gpiochip1: gpio-line-names specifies 21 line names but there are 40 lines on the chip
[ 0.757675] GPIO line 253 (pex-refclk-sel-low) hogged as output/low
[ 0.757709] GPIO line 266 (w-disable1) hogged as output/high
[ 0.757737] GPIO line 264 (w-disable2) hogged as output/high
[ 0.757990] gpiochip_setup_dev: registered GPIOs 248 to 287 on device: gpiochip1 (tegra-gpio-aon)
[ 0.759730] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.759741] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[ 0.760330] iommu: Adding device 3550000.xudc to group 54
[ 0.760894] iommu: Adding device 3610000.xhci to group 55
[ 0.762617] arm64_ras arm64_ras: probed
[ 0.762901] ras_fhi_enable: FHI 468 enabled on CPU0
[ 0.762936] ras_fhi_enable: FHI 469 enabled on CPU1
[ 0.763023] ras_fhi_enable: FHI 470 enabled on CPU2
[ 0.763101] ras_fhi_enable: FHI 471 enabled on CPU3
[ 0.763178] ras_fhi_enable: FHI 472 enabled on CPU4
[ 0.763242] ras_fhi_enable: FHI 473 enabled on CPU5
[ 0.763417] carmel_ras_enable: RAS enabled on cpu0
[ 0.763580] carmel_ras_enable: RAS enabled on cpu1
[ 0.763771] carmel_ras_enable: RAS enabled on cpu2
[ 0.763955] carmel_ras_enable: RAS enabled on cpu3
[ 0.764162] carmel_ras_enable: RAS enabled on cpu4
[ 0.764346] carmel_ras_enable: RAS enabled on cpu5
[ 0.764401] carmel_ras carmel_ras: probed
[ 0.765292] tegra-cbb 2300000.cbb-noc: noc_secure_irq = 477, noc_nonsecure_irq = 476>
[ 0.765693] tegra-cbb c600000.aon-noc: noc_secure_irq = 479, noc_nonsecure_irq = 478>
[ 0.766423] tegra-cbb d600000.bpmp-noc: noc_secure_irq = 481, noc_nonsecure_irq = 480>
[ 0.767147] tegra-cbb be00000.rce-noc: noc_secure_irq = 483, noc_nonsecure_irq = 482>
[ 0.767839] tegra-cbb b600000.sce-noc: noc_secure_irq = 485, noc_nonsecure_irq = 484>
[ 0.768127] tegra-cbb 14040000.cv-noc: defer probe as CV-NOC not probed yet
[ 0.769035] vdd-ac-bat: 5000 mV
[ 0.769342] vdd-sdmmc1-sw: 3300 mV
[ 0.769592] vdd-1v8-sd: 1800 mV
[ 0.769822] vdd-3v3-cvb: 3300 mV
[ 0.770076] vdd-1v8-cvb: 1800 mV
[ 0.770335] vdd-epb-1v0: supplied by vdd-3v3-cvb
[ 0.770374] vdd-epb-1v0: 1000 mV
[ 0.770651] avdd-cam-2v8: 2800 mV
[ 0.770891] vdd-fan: 5000 mV
[ 0.771215] vdd-hdmi-5v0: 5000 mV
[ 0.771457] vdd_sys_en: 1200 mV
[ 0.800059] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.805361] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.805671] SCSI subsystem initialized
[ 0.805961] libata version 3.00 loaded.
[ 0.806216] usbcore: registered new interface driver usbfs
[ 0.806281] usbcore: registered new interface driver hub
[ 0.806355] usbcore: registered new device driver usb
[ 0.816389] tegra-i2c 31e0000.i2c: could not find pctldev for node /host1x/dpaux@155F0000/pinmux@0, deferring probe
[ 0.819010] max77620 4-003c: PMIC Version OTP:0x51 and ES:0x1
[ 0.823687] vdd-1v0: at 1000 mV
[ 0.827680] vdd-1v8-hs: at 1800 mV
[ 0.831742] vdd-1v8-ls: at 1800 mV
[ 0.835802] vdd-1v8-ao: at 1800 mV
[ 0.841066] vddio-ddr-1v1: at 1100 mV
[ 0.844804] vdd-rtc: at 800 mV
[ 0.845844] spmic-ldo1: at 2375 mV
[ 0.853067] vdd-ao-3v3: at 3300 mV
[ 0.861097] vddio-emmc-3v3: at 3300 mV
[ 0.862117] spmic-ldo4: at 1587 mV
[ 0.867646] vdd-usb-3v3: at 3300 mV
[ 0.875728] vddio-sdmmc1-3v3: at 3300 mV
[ 0.879713] vdd-csi-1v2: at 1200 mV
[ 0.880848] spmic-ldo8: at 1800 mV
[ 0.884815] GPIO line 246 (gpio_default) hogged as output/high
[ 0.885784] GPIO line 247 (gpio_default) hogged as output/high
[ 0.885997] gpiochip_setup_dev: registered GPIOs 240 to 247 on device: gpiochip2 (max77620-gpio)
[ 0.886246] max77620 4-003c: max77620 probe successful
[ 0.886942] media: Linux media interface: v0.10
[ 0.886982] Linux video capture interface: v2.00
[ 0.888202] pps_core: LinuxPPS API ver. 1 registered
[ 0.888209] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.888225] PTP clock support registered
[ 0.888457] tegra_wdt_t18x 30c0000.watchdog: Expiry count is deprecated
[ 0.888701] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.888741] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.891215] trusty trusty: trusty version: Built: 12:20:34 Jul 26 2021
[ 0.891274] trusty trusty: selected api version: 3 (requested 3)
[ 0.892242] Advanced Linux Sound Architecture Driver Initialized.
[ 0.892643] Bluetooth: Core ver 2.22
[ 0.892680] NET: Registered protocol family 31
[ 0.892685] Bluetooth: HCI device and connection manager initialized
[ 0.892695] Bluetooth: HCI socket layer initialized
[ 0.892703] Bluetooth: L2CAP socket layer initialized
[ 0.892724] Bluetooth: SCO socket layer initialized
[ 0.895097] camchar: rtcpu character device driver loaded
[ 0.895476] gpio tegra-gpio wake61 for gpio=201(Z:1)
[ 0.895550] extcon-gpio-states external-connection:extcon@1: Cable state:0, cable id:0
[ 0.896575] clocksource: Switched to clocksource arch_sys_counter
[ 0.937775] VFS: Disk quotas dquot_6.6.0
[ 0.937895] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.938207] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.939663] tegra-carveouts tegra-carveouts: assigned reserved memory node grid-of-semaphores
[ 0.939712] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000c6000000, size=0x2a000000
[ 0.939946] cma: enabled page replacement for spfn=c6000, epfn=f0000
[ 0.939955] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[ 0.939987] nvmap: nvmap_select_cache_ops() nvmap cache ops set to scf
[ 0.939996] nvmap_page_pool_init: Total RAM pages: 1984463
[ 0.940002] nvmap_page_pool_init: nvmap page pool size: 248057 pages (968 MB)
[ 0.940192] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.940686] misc nvmap: created heap vpr base 0x00000000c6000000 size (688128KiB)
[ 0.941835] tegra-gpcdma 2600000.dma: GPC DMA driver register 31 channels
[ 0.954026] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type CPU-therm
[ 0.954206] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type GPU-therm
[ 0.954366] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type AUX-therm
[ 0.954503] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type AO-therm
[ 0.954645] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 0.955817] la/ptsa driver initialized.
[ 0.956183] NET: Registered protocol family 2
[ 0.957086] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.957452] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.958062] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.958106] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.958225] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.958681] NET: Registered protocol family 1
[ 0.959287] RPC: Registered named UNIX socket transport module.
[ 0.959293] RPC: Registered udp transport module.
[ 0.959298] RPC: Registered tcp transport module.
[ 0.959303] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.959326] PCI: CLS 0 bytes, default 64
[ 0.959563] Trying to unpack rootfs image as initramfs...
[ 1.146915] Freeing initrd memory: 5432K
[ 1.164757] host1x 13e10000.host1x: initialized
[ 1.166408] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.170903] audit: initializing netlink subsys (disabled)
[ 1.170949] audit: type=2000 audit(0.792:1): initialized
[ 1.171688] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 1.178424] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.179546] ntfs: driver 2.1.32 [Flags: R/W].
[ 1.180100] 9p: Installing v9fs 9p2000 file system support
[ 1.184362] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 1.184580] io scheduler noop registered
[ 1.184784] io scheduler cfq registered (default)
[ 1.188252] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 1.189625] random: fast init done
[ 1.218746] iommu: Adding device 2993000.adsp to group 56
[ 1.231792] iommu: Adding device aconnect@2a41000:adsp_audio to group 57
[ 1.232733] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 1.242959] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 1.243326] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 1.243804] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 1.244151] tegra-pwm 32d0000.pwm: PWM clk can sleep in ops
[ 1.244509] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 1.247045] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 1.247271] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=1500000, max_bw=1500000
[ 1.250044] tsec 15500000.tsec: initialized
[ 1.251399] tsec 15100000.tsecb: initialized
[ 1.255129] nvdec 15480000.nvdec: initialized
[ 1.257488] nvdec 15140000.nvdec1: initialized
[ 1.262348] falcon 15340000.vic: initialized
[ 1.264229] falcon 15380000.nvjpg: initialized
[ 1.266072] falcon 154c0000.nvenc: initialized
[ 1.267957] falcon 15a80000.nvenc1: initialized
[ 1.271318] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 1.272763] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 1.274125] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 1.275495] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 1.276844] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 1.278245] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 1.279716] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 1.281157] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 1.284595] t194-nvcsi 15a00000.nvcsi: initialized
[ 1.289455] scare-pigeon 13e10000.host1x:vi-thi@15f00000: initialized
[ 1.289799] scare-pigeon 14b00000.isp-thi: initialized
[ 1.295269] pva 16000000.pva0: initialized
[ 1.300955] pva 16800000.pva1: initialized
[ 1.305814] nvdla 15880000.nvdla0: initialized
[ 1.310506] nvdla 158c0000.nvdla1: initialized
[ 1.311826] tegradccommon 15200000.dc_common: host1x channel mapped
[ 1.311839] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[ 1.311872] tegradccommon 15200000.dc_common: dma mapping done
[ 1.312040] tegra_cec 3960000.tegra_cec: dt=1 start=0x03960000 end=0x03960FFF irq=77
[ 1.312050] tegra_cec 3960000.tegra_cec: Unpowergate DISP: 0.
[ 1.312384] tegra_cec 3960000.tegra_cec: Enable clock result: 0.
[ 1.312405] tegra_cec 3960000.tegra_cec: tegra_cec_init started
[ 1.312651] tegra_cec 3960000.tegra_cec: cec_add_sysfs ret=0
[ 1.312659] tegra_cec 3960000.tegra_cec: probed
[ 1.313277] tegradc 15200000.nvdisplay: disp0 connected to head0->/host1x/sor1
[ 1.313342] generic_infoframe_type: 0x87
[ 1.313465] tegradc 15200000.nvdisplay: DT parsed successfully
[ 1.313503] tegradc 15200000.nvdisplay: Display dc.ffffff800bce0000 registered with id=0
[ 1.318086] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 15681600 KB/s
[ 1.318094] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 933000000 Hz
[ 1.318100] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 300000000 Hz
[ 1.318442] tegradc 15200000.nvdisplay: vblank syncpt # 8 for dc 0
[ 1.318451] tegradc 15200000.nvdisplay: vpulse3 syncpt # 9 for dc 0
[ 1.319348] tegradc 15200000.nvdisplay: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350937
[ 1.322630] tegradc 15200000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
[ 1.322638] tegradc 15200000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[ 1.327435] tegradc 15200000.nvdisplay: probed
[ 1.328294] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 32 channels
[ 1.329008] tegra-fuse-burn 3820000.efuse:efuse-burn: shutdown limit check disabled
[ 1.329016] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 1.329348] kfuse 3830000.kfuse: initialized
[ 1.334209] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.336755] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 47, base_baud = 0) is a TEGRA_UART
[ 1.337804] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 48, base_baud = 0) is a TEGRA_UART
[ 1.338553] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 49, base_baud = 0) is a TEGRA_UART
[ 1.339598] console [ttyTCU0] enabled
[ 1.339816] [drm] Initialized
[ 1.350393] brd: module loaded
[ 1.355109] loop: module loaded
[ 1.355222] tegra_profiler: version: 1.141, samples/io: 48/28
[ 1.355340] tegra_profiler: auth: init
[ 1.355933] THERMAL EST: found 3 subdevs
[ 1.355939] THERMAL EST num_resources: 0
[ 1.355945] [THERMAL EST subdev 0]
[ 1.355951] [THERMAL EST subdev 1]
[ 1.355956] [THERMAL EST subdev 2]
[ 1.355965] THERMAL EST: Found 2 profiles, default profile is quiet
[ 1.356191] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[ 1.356197] THERMAL EST: thz register success.
[ 1.356340] THERMAL EST: end of probe, return err: 0
[ 1.356974] sd: No Scsi addr parsed to reserve index
[ 1.357002] hisi_sas: driver version v1.6
[ 1.366294] qspi_mtd spi6.0: s25fs256s SSG 8 0 1000 2000000
[ 1.366305] qspi_mtd spi6.0: s25fs256s (32768 Kbytes)
[ 1.366315] qspi_mtd spi6.0: mtd .name = spi6.0, .size = 0x2000000 (32MiB) .erasesize = 0x00010000 (64KiB) .numeraseregions = 0
[ 1.366595] 1 ofpart partitions found on MTD device spi6.0
[ 1.366601] Creating 1 MTD partitions on "spi6.0":
[ 1.366622] 0x000000000000-0x000002000000 : "Whole_flash0"
[ 1.368826] libphy: Fixed MDIO Bus: probed
[ 1.370479] tun: Universal TUN/TAP device driver, 1.6
[ 1.370486] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.371142] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 1.371147] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.371182] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 1.371187] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 1.371213] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 1.371217] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 1.371262] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 1.371267] Copyright(c) 1999 - 2017 Intel Corporation.
[ 1.380712] Console: switching to colour frame buffer device 240x67
[ 1.380851] tegradc 15200000.nvdisplay: fb registered
[ 1.381074] gpio tegra-gpio wake63 for gpio=97(M:1)
[ 1.381660] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 1.381748] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 1.386558] Parent Clock set for DC plld2
[ 1.452654] tegradc 15200000.nvdisplay: hdmi: tmds rate:148351K prod-setting:prod_c_hdmi_111m_223m
[ 1.453315] tegradc 15200000.nvdisplay: hdmi: get RGB quant from REG programmed by BL.
[ 1.453329] tegradc 15200000.nvdisplay: hdmi: get YCC quant from REG programmed by BL.
[ 1.478713] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 1.478719] Extcon AUX1(HDMI) enable
[ 1.479037] tegradc 15210000.nvdisplay: disp1 connected to head1->/host1x/sor
[ 1.479064] tegradc 15210000.nvdisplay: parse_dp_settings: No dp-lt-settings node
[ 1.479158] tegradc 15210000.nvdisplay: DT parsed successfully
[ 1.479240] tegradc 15210000.nvdisplay: Display dc.ffffff800d1e0000 registered with id=1
[ 1.479447] tegradc 15210000.nvdisplay: vblank syncpt # 11 for dc 1
[ 1.479456] tegradc 15210000.nvdisplay: vpulse3 syncpt # 12 for dc 1
[ 1.487110] tegradc 15210000.nvdisplay: probed
[ 1.487412] tegradc 15210000.nvdisplay: fb registered
[ 1.490741] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 1.490750] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 1.490761] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 1.490774] tegradc 15210000.nvdisplay: blank - powerdown
[ 1.490813] extcon-disp-state external-connection:disp-state: cable 44 state 0 already set.
[ 1.490818] Extcon DP: HPD disabled
[ 1.490823] hpd: hpd_switch 0
[ 1.490828] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 1.490839] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 1.490847] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 1.611503] tegradc 15200000.nvdisplay: blank - powerdown
[ 1.616168] eqos 2490000.ether_qos: Setting local MAC: 48 b0 2d 7 8e a6
[ 1.616255] libphy: dwc_phy: probed
[ 1.618204] PPP generic driver version 2.4.2
[ 1.618559] PPP BSD Compression module registered
[ 1.618563] PPP Deflate Compression module registered
[ 1.618580] PPP MPPE Compression module registered
[ 1.618584] NET: Registered protocol family 24
[ 1.618621] usbcore: registered new interface driver r8152
[ 1.618645] usbcore: registered new interface driver asix
[ 1.618669] usbcore: registered new interface driver ax88179_178a
[ 1.618689] usbcore: registered new interface driver cdc_ether
[ 1.618710] usbcore: registered new interface driver net1080
[ 1.618731] usbcore: registered new interface driver cdc_subset
[ 1.618750] usbcore: registered new interface driver zaurus
[ 1.618781] usbcore: registered new interface driver cdc_ncm
[ 1.619267] VFIO - User Level meta-driver version: 0.3
[ 1.624373] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.624387] ehci-pci: EHCI PCI platform driver
[ 1.624411] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.624418] ohci-pci: OHCI PCI platform driver
[ 1.624444] ohci-platform: OHCI generic platform driver
[ 1.628962] tegra-xusb 3610000.xhci: USB2 port 0 has OTG_CAP
[ 1.631222] tegra-xusb 3610000.xhci: extcon 0: ffffffc1f4c99000 id
[ 1.631448] usbcore: registered new interface driver uas
[ 1.631482] usbcore: registered new interface driver usb-storage
[ 1.631536] usbcore: registered new interface driver usbserial
[ 1.634332] tegra-xudc-new 3550000.xudc: PMQOS CPU boost enabled
[ 1.634441] tegra-xudc-new 3550000.xudc: device count: 1
[ 1.634899] tegra-xusb 3610000.xhci: Firmware timestamp: 2019-07-24 05:47:34 UTC, Version: 60.06 release
[ 1.634927] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 1.634943] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 1.635643] tegra-xusb 3610000.xhci: hcc params 0x0184ff25 hci version 0x110 quirks 0x00050810
[ 1.635678] tegra-xusb 3610000.xhci: irq 463, io mem 0x03610000
[ 1.635914] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.635919] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.635924] usb usb1: Product: xHCI Host Controller
[ 1.635928] usb usb1: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 1.635933] usb usb1: SerialNumber: 3610000.xhci
[ 1.636439] hub 1-0:1.0: USB hub found
[ 1.636584] hub 1-0:1.0: 4 ports detected
[ 1.637199] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 1.637209] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 1.637217] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 1.637362] tegra-xudc-new 3550000.xudc: vbus state: 0
[ 1.637370] tegra-xudc-new 3550000.xudc: Initialize boost_cpufreq work
[ 1.637395] tegra-xudc-new 3550000.xudc: entering ELPG
[ 1.637523] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.637528] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.637533] usb usb2: Product: xHCI Host Controller
[ 1.637537] usb usb2: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 1.637541] usb usb2: SerialNumber: 3610000.xhci
[ 1.637639] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 1.637921] hub 2-0:1.0: USB hub found
[ 1.637960] hub 2-0:1.0: 4 ports detected
[ 1.638165] mousedev: PS/2 mouse device common for all mice
[ 1.638304] usbcore: registered new interface driver xpad
[ 1.653023] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 1.653027] Extcon AUX1(HDMI) disable
[ 1.678736] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 1.679904] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 1.700281] tegradc 15200000.nvdisplay: unblank
[ 1.702089] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 1.702378] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 1.713449] Parent Clock set for DC plld2
[ 1.718209] tegradc 15200000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 1.719574] tegradc 15200000.nvdisplay: hdmi: get RGB quant from EDID.
[ 1.719584] tegradc 15200000.nvdisplay: hdmi: get YCC quant from EDID.
[ 1.754036] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 1.754039] Extcon AUX1(HDMI) enable
[ 1.766002] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 1.767411] Wake73 for irq=42
[ 1.768677] rtc rtc1: alarm rtc device
[ 1.768690] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 1.768714] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 1.768848] i2c /dev entries driver
[ 1.771053] i2c i2c-2: Added multiplexed i2c bus 9
[ 1.771490] i2c i2c-2: Added multiplexed i2c bus 10
[ 1.771497] i2c-mux-gpio cam_i2cmux: 2 port mux on 3180000.i2c adapter
[ 1.771663] arducam-csi2: chip found @ 0x18 (i2c-2-mux (chan_id 0))
[ 1.795538] arducam-csi2: arducam_read: 0x103 0x0030
[ 1.795845] arducam-csi2: arducam_read: 0x101 0x0003
[ 1.795851] arducam-csi2 9-000c: firmware version: 3
[ 1.796126] arducam-csi2: arducam_read: 0x102 0x0000
[ 1.796131] arducam-csi2 9-000c: Sensor ID: 0x0000
[ 1.797183] arducam-csi2: arducam_read: 0x201 0x002a
[ 1.798251] arducam-csi2: arducam_read: 0x201 0x002b
[ 1.799295] arducam-csi2: arducam_read: 0x201 0xfffffffe
[ 1.801086] arducam-csi2: arducam_read: 0x201 0x002a
[ 1.801360] arducam-csi2: arducam_read: 0x203 0x0002
[ 1.801631] arducam-csi2: arducam_read: 0x202 0x0004
[ 1.802648] arducam-csi2: arducam_read: 0x301 0x0a00
[ 1.803684] arducam-csi2: arducam_read: 0x301 0xfffffffe
[ 1.805507] arducam-csi2: arducam_read: 0x301 0x0a00
[ 1.805797] arducam-csi2: arducam_read: 0x302 0x0320
[ 1.806867] arducam-csi2: arducam_read: 0x301 0xfffffffe
[ 1.807155] arducam-csi2: arducam_read: 0x302 0xfffffffe
[ 1.809033] arducam-csi2: arducam_read: 0x201 0x002b
[ 1.809310] arducam-csi2: arducam_read: 0x203 0x0002
[ 1.809585] arducam-csi2: arducam_read: 0x202 0x0004
[ 1.810627] arducam-csi2: arducam_read: 0x301 0x0a00
[ 1.811676] arducam-csi2: arducam_read: 0x301 0xfffffffe
[ 1.813531] arducam-csi2: arducam_read: 0x301 0x0a00
[ 1.813807] arducam-csi2: arducam_read: 0x302 0x0320
[ 1.814853] arducam-csi2: arducam_read: 0x301 0xfffffffe
[ 1.815147] arducam-csi2: arducam_read: 0x302 0xfffffffe
[ 1.816926] arducam-csi2: arducam_read: 0x201 0xfffffffe
[ 1.818708] arducam-csi2: arducam_read: 0x401 0x980911
[ 1.819744] arducam-csi2: arducam_read: 0x401 0x980913
[ 1.820824] arducam-csi2: arducam_read: 0x401 0x981901
[ 1.821863] arducam-csi2: arducam_read: 0x401 0x981906
[ 1.822922] arducam-csi2: arducam_read: 0x401 0xfffffffe
[ 1.824715] arducam-csi2: arducam_read: 0x401 0x980911
[ 1.824987] arducam-csi2: arducam_read: 0x403 0x0058
[ 1.825260] arducam-csi2: arducam_read: 0x402 0x0005
[ 1.825534] arducam-csi2: arducam_read: 0x405 0x003c
[ 1.825807] arducam-csi2: arducam_read: 0x404 0x0001
[ 1.826844] arducam-csi2: arducam_read: 0x401 0x980913
[ 1.827116] arducam-csi2: arducam_read: 0x403 0x000f
[ 1.827390] arducam-csi2: arducam_read: 0x402 0x0000
[ 1.827662] arducam-csi2: arducam_read: 0x405 0x0001
[ 1.827936] arducam-csi2: arducam_read: 0x404 0x0001
[ 1.828993] arducam-csi2: arducam_read: 0x401 0x981901
[ 1.829268] arducam-csi2: arducam_read: 0x403 0x0001
[ 1.829566] arducam-csi2: arducam_read: 0x402 0x0000
[ 1.829846] arducam-csi2: arducam_read: 0x405 0x0000
[ 1.830144] arducam-csi2: arducam_read: 0x404 0x0001
[ 1.830152] arducam-csi2: arducam_enum_controls: new custom ctrl, ctrl: ffffffc1f2d00a00.
[ 1.831208] arducam-csi2: arducam_read: 0x401 0x981906
[ 1.831483] arducam-csi2: arducam_read: 0x403 0x0050
[ 1.831780] arducam-csi2: arducam_read: 0x402 0x0005
[ 1.832056] arducam-csi2: arducam_read: 0x405 0x003c
[ 1.832364] arducam-csi2: arducam_read: 0x404 0x0001
[ 1.832371] arducam-csi2: arducam_enum_controls: new custom ctrl, ctrl: ffffffc1f2d00b00.
[ 1.833408] arducam-csi2: arducam_read: 0x401 0xfffffffe
[ 1.833681] arducam-csi2: arducam_read: 0x403 0x0000
[ 1.833953] arducam-csi2: arducam_read: 0x402 0x0000
[ 1.834225] arducam-csi2: arducam_read: 0x405 0x0000
[ 1.834497] arducam-csi2: arducam_read: 0x404 0x0000
[ 1.834506] arducam-csi2: arducam_s_ctrl: cid = (0x980911), value = (60).
[ 1.836018] arducam-csi2: arducam_s_ctrl: cid = (0x980913), value = (1).
[ 1.837584] arducam-csi2: arducam_s_ctrl: cid = (0x981901), value = (0).
[ 1.839107] arducam-csi2: arducam_s_ctrl: cid = (0x981906), value = (60).
[ 1.840656] arducam-csi2: arducam_s_ctrl: cid = (0x981902), value = (0).
[ 1.840661] arducam-csi2: arducam_s_ctrl: cid = (0x981903), value = (2000).
[ 1.841451] arducam-csi2 9-000c: sensor arducam-csi2 9-000c registered
[ 1.841511] arducam-csi2: chip found @ 0x18 (i2c-2-mux (chan_id 1))
[ 1.864987] tegra-i2c 3180000.i2c: no acknowledge from address 0xc
[ 1.865154] tegra-i2c 3180000.i2c: no acknowledge from address 0xc
[ 1.865313] tegra-i2c 3180000.i2c: no acknowledge from address 0xc
[ 1.865363] arducam-csi2: arducam_read: Reading register 0x103 failed
[ 1.865367] arducam-csi2 10-000c: probe failed
[ 1.865406] arducam-csi2 10-000c: Failed to setup board.
[ 1.866822] max77620-power max20024-power: Event recorder REG_NVERC : 0x0
[ 1.873810] tegra-thermal-throttle bthrot_cdev: clk:cpu max:1907200000, min:115200000 steps:24
[ 1.878079] tegra-thermal-throttle bthrot_cdev: clk:gpu max:1109250000, min:114750000 steps:10
[ 1.878122] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:0:cpu off:0 slope-adj:200
[ 1.878126] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:1:gpu off:0 slope-adj:400
[ 1.878196] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced max_state:48 cutoff:0
[ 1.878254] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:0:cpu off:0 slope-adj:400
[ 1.878259] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:1:gpu off:0 slope-adj:400
[ 1.878510] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced max_state:40 cutoff:1
[ 1.878556] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:0:cpu off:0 slope-adj:200
[ 1.878561] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:1:gpu off:365500000 slope-adj:300
[ 1.878816] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced max_state:48 cutoff:0
[ 1.878888] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:0:cpu off:38400000 slope-adj:10
[ 1.878893] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:1:gpu off:25500000 slope-adj:10
[ 1.879223] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced max_state:2 cutoff:0
[ 1.879280] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:0:cpu off:0 slope-adj:400
[ 1.879285] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:1:gpu off:0 slope-adj:400
[ 1.879567] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced max_state:40 cutoff:1
[ 1.880074] FAN dev name: pwm-fan
[ 1.880169] FAN:gpio request success.
[ 1.880176] FAN: can't find tach_gpio
[ 1.880184] pwm_fan_driver pwm-fan: Found 2 profiles, default profile is quiet
[ 1.880215] pwm_fan_driver pwm-fan: cap state:4, cap pwm:255
[ 1.880374] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 1.880382] pwm_fan_driver pwm-fan: tach period: 1000
[ 1.881038] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 1.881044] pwm_fan_driver pwm-fan: index 1: pwm=130, rpm=1000, rru=2, rrd=2, state:2
[ 1.881070] pwm_fan_driver pwm-fan: index 2: pwm=160, rpm=2000, rru=1, rrd=1, state:2
[ 1.881075] pwm_fan_driver pwm-fan: index 3: pwm=200, rpm=3000, rru=1, rrd=1, state:2
[ 1.881080] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 1.881084] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 1.881088] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 1.881092] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 1.881096] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 1.881101] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 1.881955] device-mapper: uevent: version 1.0.3
[ 1.882363] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 1.885804] tegra194_cpufreq_probe: platform driver Initialization: pass
[ 1.886687] cpuidle: Initializing cpuidle driver
[ 1.887569] sdhci: Secure Digital Host Controller Interface driver
[ 1.887571] sdhci: Copyright(c) Pierre Ossman
[ 1.887574] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.887876] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 1.889128] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 1.891928] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 245
[ 1.896035] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 1.897373] tegra-se-nvhost 15810000.se: initialized
[ 1.898834] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 1.899462] tegra-se-nvhost 15820000.se: initialized
[ 1.900491] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 1.901489] tegra-se-nvhost 15830000.se: initialized
[ 1.902124] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 1.902681] tegra-se-nvhost 15840000.se: initialized
[ 1.903630] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 1.903814] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.904921] usbcore: registered new interface driver usbhid
[ 1.904924] usbhid: USB HID core driver
[ 1.908811] tegra186-cam-rtcpu bc00000.rtcpu: deferring, 14800000.isp is not probed
[ 1.909842] tegra_aon c1a0000.aon: tegra aon driver probe OK
[ 1.910249] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 1.910869] denver_knobs_init:MTS_VERSION:53250041
[ 1.911032] tegra19x_actmon d230000.actmon: in actmon_register()...
[ 1.911615] tegra19x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 1.911920] t19x_cache tegra-cache: probed
[ 1.913845] misc nvmap: cvsram :dma coherent mem declare 0x0000000050000000,4194304
[ 1.913851] misc nvmap: created heap cvsram base 0x0000000050000000 size (4096KiB)
[ 1.914300] carmel-pmu-drv carmel-pmu: Registered Carmel PMU
[ 1.914715] PLL_AON clock registered
[ 1.916925] Clocks initialized successfully
[ 1.918165] nvpmodel: initialized successfully
[ 1.919223] trusty-virtio trusty:virtio: initializing
[ 1.919425] trusty_ipc virtio0: vring0: va(pa) ffffffc1e2ab6000(0) qsz 32 notifyid 1
[ 1.919433] trusty_ipc virtio0: vring1: va(pa) ffffffc1e2b24000(0) qsz 32 notifyid 2
[ 1.919580] trusty-virtio trusty:virtio: initializing done
[ 1.920153] usbcore: registered new interface driver snd-usb-audio
[ 1.920341] trusty_ipc virtio0: is online
[ 1.921426] tegra-hda 3510000.hda: Override SDO lines to 4
[ 1.941445] input: tegra-hda-xnx HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[ 1.941603] input: tegra-hda-xnx HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[ 1.941756] input: tegra-hda-xnx HDMI/DP,pcm=8 as /devices/3510000.hda/sound/card0/input2
[ 1.941950] input: tegra-hda-xnx HDMI/DP,pcm=9 as /devices/3510000.hda/sound/card0/input3
[ 1.944639] gpio tegra-gpio wake8 for gpio=55(G:7)
[ 1.944689] mmc0: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 1.949717] OPE platform probe
[ 1.949808] OPE platform probe successful
[ 1.964590] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 2.003623] usb 1-2: New USB device found, idVendor=0bda, idProduct=5489
[ 2.003629] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.003632] usb 1-2: Product: 4-Port USB 2.0 Hub
[ 2.003635] usb 1-2: Manufacturer: Generic
[ 2.004906] hub 1-2:1.0: USB hub found
[ 2.006119] hub 1-2:1.0: 4 ports detected
[ 2.018209] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 2.018336] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 2.018450] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 2.018549] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 2.018659] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 2.018764] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 2.018862] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 2.018956] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 2.019065] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 2.019170] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 2.019276] tegra-asoc: sound: ADMAIF11 <-> ADMAIF11 mapping ok
[ 2.019386] tegra-asoc: sound: ADMAIF12 <-> ADMAIF12 mapping ok
[ 2.019476] tegra-asoc: sound: ADMAIF13 <-> ADMAIF13 mapping ok
[ 2.019565] tegra-asoc: sound: ADMAIF14 <-> ADMAIF14 mapping ok
[ 2.019652] tegra-asoc: sound: ADMAIF15 <-> ADMAIF15 mapping ok
[ 2.019725] tegra-asoc: sound: ADMAIF16 <-> ADMAIF16 mapping ok
[ 2.019805] tegra-asoc: sound: ADMAIF17 <-> ADMAIF17 mapping ok
[ 2.019881] tegra-asoc: sound: ADMAIF18 <-> ADMAIF18 mapping ok
[ 2.019950] tegra-asoc: sound: ADMAIF19 <-> ADMAIF19 mapping ok
[ 2.020020] tegra-asoc: sound: ADMAIF20 <-> ADMAIF20 mapping ok
[ 2.047002] u32 classifier
[ 2.047005] Actions configured
[ 2.047132] Initializing XFRM netlink socket
[ 2.047696] NET: Registered protocol family 10
[ 2.048436] NET: Registered protocol family 17
[ 2.048449] NET: Registered protocol family 15
[ 2.048498] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 2.048599] Bluetooth: RFCOMM socket layer initialized
[ 2.048612] Bluetooth: RFCOMM ver 1.11
[ 2.048616] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 2.048624] Bluetooth: HIDP socket layer initialized
[ 2.048641] 9pnet: Installing 9P2000 support
[ 2.048677] Key type dns_resolver registered
[ 2.048942] Registered cp15_barrier emulation handler
[ 2.048960] Registered setend emulation handler
[ 2.050470] registered taskstats version 1
[ 2.050912] tegra-pcie-dw 14160000.pcie: Setting init speed to max speed
[ 2.051915] OF: PCI: host bridge /pcie@14160000 ranges:
[ 2.051929] OF: PCI: IO 0x36100000..0x361fffff -> 0x36100000
[ 2.051935] OF: PCI: MEM 0x1740000000..0x17ffffffff -> 0x40000000
[ 2.051940] OF: PCI: MEM 0x1400000000..0x173fffffff -> 0x1400000000
[ 2.060212] mmc0: host does not support reading read-only switch, assuming write-enable
[ 2.128550] usb 1-3: new full-speed USB device number 3 using tegra-xusb
[ 2.149668] usb 1-3: New USB device found, idVendor=13d3, idProduct=3549
[ 2.149673] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.149676] usb 1-3: Product: Bluetooth Radio
[ 2.149679] usb 1-3: Manufacturer: Realtek
[ 2.149682] usb 1-3: SerialNumber: 00e04c000001
[ 2.160557] tegra-pcie-dw 14160000.pcie: link is up
[ 2.160754] tegra-pcie-dw 14160000.pcie: PCI host bridge to bus 0004:00
[ 2.160760] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 2.160767] pci_bus 0004:00: root bus resource [io 0x0000-0xfffff] (bus address [0x36100000-0x361fffff])
[ 2.160772] pci_bus 0004:00: root bus resource [mem 0x1740000000-0x17ffffffff] (bus address [0x40000000-0xffffffff])
[ 2.160776] pci_bus 0004:00: root bus resource [mem 0x1400000000-0x173fffffff pref]
[ 2.160802] pci 0004:00:00.0: [10de:1ad1] type 01 class 0x060400
[ 2.160951] pci 0004:00:00.0: PME# supported from D0 D3hot D3cold
[ 2.161199] iommu: Adding device 0004:00:00.0 to group 58
[ 2.161585] pci 0004:01:00.0: [10ec:c822] type 00 class 0x028000
[ 2.161723] pci 0004:01:00.0: reg 0x10: [io 0x1000-0x10ff]
[ 2.161927] pci 0004:01:00.0: reg 0x18: [mem 0x1740000000-0x174000ffff 64bit]
[ 2.162720] pci 0004:01:00.0: supports D1 D2
[ 2.162723] pci 0004:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2.163061] iommu: Adding device 0004:01:00.0 to group 59
[ 2.173460] pci 0004:00:00.0: BAR 14: assigned [mem 0x1740000000-0x17400fffff]
[ 2.173467] pci 0004:00:00.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 2.173474] pci 0004:01:00.0: BAR 2: assigned [mem 0x1740000000-0x174000ffff 64bit]
[ 2.173555] pci 0004:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 2.173582] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 2.173599] pci 0004:00:00.0: bridge window [io 0x1000-0x1fff]
[ 2.173606] pci 0004:00:00.0: bridge window [mem 0x1740000000-0x17400fffff]
[ 2.173623] pci 0004:00:00.0: Max Payload Size set to 128/ 256 (was 256), Max Read Rq 512
[ 2.173681] pci 0004:01:00.0: Max Payload Size set to 128/ 128 (was 128), Max Read Rq 512
[ 2.173971] pcieport 0004:00:00.0: Signaling PME through PCIe PME interrupt
[ 2.173975] pci 0004:01:00.0: Signaling PME through PCIe PME interrupt
[ 2.173980] pcie_pme 0004:00:00.0:pcie001: service driver pcie_pme loaded
[ 2.174068] aer 0004:00:00.0:pcie002: service driver aer loaded
[ 2.174675] tegra-pcie-dw 141a0000.pcie: Setting init speed to max speed
[ 2.175536] OF: PCI: host bridge /pcie@141a0000 ranges:
[ 2.175554] OF: PCI: IO 0x3a100000..0x3a1fffff -> 0x3a100000
[ 2.175577] OF: PCI: MEM 0x1f40000000..0x1fffffffff -> 0x40000000
[ 2.175582] OF: PCI: MEM 0x1c00000000..0x1f3fffffff -> 0x1c00000000
[ 2.197616] mmc0: hw tuning done ...
[ 2.197655] mmc0: new ultra high speed SDR104 SDXC card at address 59b4
[ 2.198090] mmcblk0: mmc0:59b4 EC1S5 59.7 GiB
[ 2.201631] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11
[ 2.324571] tegra_cec 3960000.tegra_cec: physical address: 10:00.
[ 2.389111] tegra_cec 3960000.tegra_cec: Sent <Text View On> res: -113.
[ 2.389115] tegra_cec 3960000.tegra_cec: tegra_cec_init Done.
[ 2.688549] tegra-pcie-dw 141a0000.pcie: link is down
[ 2.688650] tegra-pcie-dw 141a0000.pcie: PCI host bridge to bus 0005:00
[ 2.688656] pci_bus 0005:00: root bus resource [bus 00-ff]
[ 2.688664] pci_bus 0005:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x3a100000-0x3a1fffff])
[ 2.688668] pci_bus 0005:00: root bus resource [mem 0x1f40000000-0x1fffffffff] (bus address [0x40000000-0xffffffff])
[ 2.688672] pci_bus 0005:00: root bus resource [mem 0x1c00000000-0x1f3fffffff pref]
[ 2.688718] pci 0005:00:00.0: [10de:1ad0] type 01 class 0x060400
[ 2.688869] pci 0005:00:00.0: PME# supported from D0 D3hot D3cold
[ 2.689045] iommu: Adding device 0005:00:00.0 to group 60
[ 2.689262] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[ 2.689281] pci 0005:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 2.689456] pcieport 0005:00:00.0: Signaling PME through PCIe PME interrupt
[ 2.689462] pcie_pme 0005:00:00.0:pcie001: service driver pcie_pme loaded
[ 2.689545] aer 0005:00:00.0:pcie002: service driver aer loaded
[ 2.689679] pcie_pme 0005:00:00.0:pcie001: unloading service driver pcie_pme
[ 2.689719] aer 0005:00:00.0:pcie002: unloading service driver aer
[ 2.689790] pci_bus 0005:01: busn_res: [bus 01-ff] is released
[ 2.689863] iommu: Removing device 0005:00:00.0 from group 60
[ 2.689886] pci_bus 0005:00: busn_res: [bus 00-ff] is released
[ 2.691736] tegra-pcie-dw 141a0000.pcie: PCIe link is not up...!
[ 2.700561] usb 1-2.4: new full-speed USB device number 4 using tegra-xusb
[ 2.701069] tegra-cbb 14040000.cv-noc: noc_secure_irq = 89, noc_nonsecure_irq = 88>
[ 2.705615] tegra194-isp5 14800000.isp: initialized
[ 2.712038] tegra194-vi5 15c10000.vi: using default number of vi channels, 36
[ 2.715228] tegra194-vi5 15c10000.vi: initialized
[ 2.719382] tegra194-vi5 15c10000.vi: subdev arducam-csi2 9-000c bound
[ 2.719405] arducam-csi2 9-000c: subdev_registered: v4l2 subde registered.
[ 2.719409] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi--2 bound
[ 2.719545] arducam-csi2 9-000c: arducam_csi2_enum_mbus_code: index = (0)
[ 2.719548] arducam-csi2 9-000c: arducam_csi2_enum_mbus_code: index = (1)
[ 2.719550] arducam-csi2 9-000c: arducam_csi2_enum_mbus_code: index = (2)
[ 2.719552] arducam-csi2 9-000c: arducam_csi2_enum_mbus_code: index = (3)
[ 2.719557] arducam-csi2 9-000c: arducam_csi2_get_fmt: width: (2560) height: (800) code: (0x2001)
[ 2.719955] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi--1 bound
[ 2.720697] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 2.724878] usb 1-2.4: New USB device found, idVendor=046d, idProduct=c52b
[ 2.724883] usb 1-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.724895] usb 1-2.4: Product: USB Receiver
[ 2.724898] usb 1-2.4: Manufacturer: Logitech
[ 2.798919] tegra-ivc ivc-bc00000.rtcpu: region 0: iova=0xbfee0000-0xbfefffff size=131072
[ 2.799207] tegra-ivc ivc-bc00000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 2.799373] tegra-ivc ivc-bc00000.rtcpu:dbg@1: dbg: ver=0 grp=1 RX[1x384]=0x1900-0x1b00 TX[1x384]=0x1b00-0x1d00
[ 2.799493] tegra-ivc ivc-bc00000.rtcpu:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d00-0x3d80 TX[1x8192]=0x3d80-0x5e00
[ 2.799806] tegra-ivc ivc-bc00000.rtcpu:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e00-0xae80 TX[64x320]=0xae80-0xff00
[ 2.799856] tegra-ivc ivc-bc00000.rtcpu:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff00-0x17f80 TX[512x64]=0x17f80-0x20000
[ 2.800093] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (65)
[ 2.800097] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 2.801204] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=5 sha1=06bdc710c3c9a48de2881774602bbcf4d0114a58
[ 2.801584] gpio tegra-gpio wake67 for gpio=48(G:0)
[ 2.801654] gpio tegra-gpio-aon wake29 for gpio=36(EE:4)
[ 2.801804] input: gpio-keys as /devices/gpio-keys/input/input4
[ 2.833522] tegra_rtc c2a0000.rtc: setting system clock to 2021-08-24 09:27:57 UTC (1629797277)
[ 2.833952] mmcblk mmc0:59b4: Card claimed for testing.
[ 2.869386] bpmp: mounted debugfs mirror
[ 2.875361] vdd-1v8-sd: disabling
[ 2.875366] vdd-1v8-cvb: disabling
[ 2.875368] vdd-epb-1v0: disabling
[ 2.875371] avdd-cam-2v8: disabling
[ 2.875373] vdd-fan: disabling
[ 2.875375] vdd_sys_en: disabling
[ 2.875381] ALSA device list:
[ 2.875383] #0: tegra-hda-xnx at 0x3518000 irq 64
[ 2.875385] #1: jetson-xaviernx-ape
[ 3.779238] extcon-disp-state external-connection:disp-state: cable 51 state 1
[ 3.779242] Extcon HDMI: HPD enabled
[ 3.779269] tegradc 15200000.nvdisplay: hdmi: plugged
[ 3.781327] Freeing unused kernel memory: 8576K
[ 3.819392] Root device found: mmcblk0p1
[ 3.820862] Found dev node: /dev/mmcblk0p1
[ 3.860008] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 3.861033] Rootfs mounted over mmcblk0p1
[ 3.886967] Switching from initrd to actual rootfs
[ 4.084708] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 4.088974] cgroup: cgroup2: unknown option "nsdelegate"
[ 4.101605] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 4.102283] systemd[1]: Detected architecture arm64.
[ 4.107531] systemd[1]: Set hostname to <namiki>.
[ 4.209912] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 4.209924] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 4.345554] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.348311] systemd[1]: Created slice User and Session Slice.
[ 4.348501] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.349483] systemd[1]: Created slice System Slice.
[ 4.349544] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.349750] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 4.349961] systemd[1]: Listening on udev Control Socket.
[ 4.350122] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 4.408897] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 4.494057] nvgpu: 17000000.gv11b nvgpu_nvhost_syncpt_init:291 [INFO] syncpt_unit_base 60000000 syncpt_unit_size 400000 size 1000
[ 4.662606] systemd-journald[2248]: Received request to flush runtime journal from PID 1
[ 4.724816] FAN rising trip_level:1 cur_temp:47300 trip_temps[2]:60000
[ 5.547870] random: crng init done
[ 5.548001] random: 7 urandom warning(s) missed due to ratelimiting
[ 5.798196] Wake76 for irq=199
[ 5.798203] Wake77 for irq=199
[ 5.798206] Wake78 for irq=199
[ 5.798209] Wake79 for irq=199
[ 5.798212] Wake80 for irq=199
[ 5.798215] Wake81 for irq=199
[ 5.798218] Wake82 for irq=199
[ 5.798263] tegra-xusb 3610000.xhci: Upgrade port 0 to USB3.0
[ 5.798269] tegra-xusb 3610000.xhci: Upgrade port 1 to USB3.0
[ 6.120745] using random self ethernet address
[ 6.120929] using random host ethernet address
[ 6.125523] usb 2-3: new SuperSpeedPlus USB device number 2 using tegra-xusb
[ 6.162169] usb 2-3: New USB device found, idVendor=0bda, idProduct=0489
[ 6.162176] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 6.162181] usb 2-3: Product: 4-Port USB 3.0 Hub
[ 6.162184] usb 2-3: Manufacturer: Generic
[ 6.174029] hub 2-3:1.0: USB hub found
[ 6.175905] hub 2-3:1.0: 4 ports detected
[ 6.292411] usbcore: registered new interface driver btusb
[ 6.303083] rtk_btusb: Realtek Bluetooth USB driver ver 3.1
[ 6.303087] rtk_btcoex: rtk_btcoex_init: version: 1.2
[ 6.303089] rtk_btcoex: create workqueue
[ 6.312770] rtk_btcoex: alloc buffers 1792, 2432 for ev and l2
[ 6.312833] rtk_btusb: btusb_probe intf->cur_altsetting->desc.bInterfaceNumber 0
[ 6.312836] rtk_btusb: btusb_probe can_wakeup 1, may wakeup 0
[ 6.312838] rtk_btusb: patch_add
[ 6.312840] rtk_btusb: auto suspend is disabled
[ 6.312843] rtk_btusb: pid = 0x3549
[ 6.312846] rtk_btusb: patch_add: Reset gEVersion to 0xff
[ 6.312857] rtk_btusb: set_bit(HCI_QUIRK_RESET_ON_CLOSE, &hdev->quirks);
[ 6.319911] rtk_btusb: btusb_probe: done
[ 6.319938] rtk_btusb: btusb_open start
[ 6.319942] rtk_btusb: btusb_open hdev->promisc ==0
[ 6.319944] rtk_btusb: download_patch start
[ 6.319949] rtk_btusb: chip type value: 0x73
[ 6.319953] rtk_btusb: HCI reset.
[ 6.322451] usbcore: registered new interface driver rtk_btusb
[ 6.331318] rtk_btusb: read_ver_rsp->lmp_subver = 0x8822
[ 6.331321] rtk_btusb: read_ver_rsp->hci_rev = 0xc
[ 6.331323] rtk_btusb: patch_entry->lmp_sub = 0x8822
[ 6.331325] rtk_btusb: load_firmware start
[ 6.331327] rtk_btusb: lmp_version = 0x8822
[ 6.331330] rtk_btusb: config filename rtl8822cu_config
[ 6.432246] logitech-djreceiver 0003:046D:C52B.0003: hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-3610000.xhci-2.4/input2
[ 6.575204] input: Logitech K400 Plus as /devices/3610000.xhci/usb1/1-2/1-2.4/1-2.4:1.2/0003:046D:C52B.0003/0003:046D:404D.0004/input/input5
[ 6.576014] logitech-hidpp-device 0003:046D:404D.0004: input,hidraw1: USB HID v1.11 Keyboard [Logitech K400 Plus] on usb-3610000.xhci-2.4:1
[ 6.600715] rtk_btusb: no bdaddr file /opt/bdaddr
[ 6.600721] rtk_btusb: 55 ab 23 87 00 00
[ 6.600734] rtk_btusb: Config file length 6, new length 6
[ 6.600736] rtk_btusb: fw name is rtl8822cu_fw
[ 6.614341] rtk_btusb: This is not 8723a, use new patch style!
[ 6.614347] rtk_btusb: rtk_get_eversion: gEVersion 255
[ 6.615315] rtk_btusb: eversion->status = 0x0, eversion->version = 0x3
[ 6.615320] rtk_btusb: load_firmware: New gEVersion 3
[ 6.615324] rtk_btusb: rtk_get_fw_project_id: opcode 0, len 1, data 13
[ 6.615327] rtk_btusb: lmp_version is 8822, project_id is 8822, match!
[ 6.615329] rtk_btusb: fw_version = 0x98a42f7
[ 6.615331] rtk_btusb: number_of_total_patch = 3
[ 6.615333] rtk_btusb: chipID 4
[ 6.615335] rtk_btusb: patch_length 0x55f0
[ 6.615337] rtk_btusb: start_offset 0x00005d00
[ 6.615339] rtk_btusb: Svn version: 21761
[ 6.615342] rtk_btusb: Coexistence: BTCOEX_20190509-0d0d
[ 6.615344] rtk_btusb: buf_len = 0x55f6
[ 6.615356] rtk_btusb: fw: exists, config file: exists
[ 6.615357] rtk_btusb: load_firmware done
[ 6.615378] rtk_btusb: download_data start
[ 6.729309] rtk_btusb: download_data done
[ 6.729313] rtk_btusb: HCI reset.
[ 6.740308] rtk_btusb: read_ver_rsp->lmp_subver = 0x42f7
[ 6.740311] rtk_btusb: read_ver_rsp->hci_rev = 0x98a
[ 6.740313] rtk_btusb: patch_entry->lmp_sub = 0x8822
[ 6.740322] rtk_btusb: Rtk patch end 0
[ 6.740324] rtk_btusb: btusb_open set HCI_RUNNING
[ 6.740347] rtk_btcoex: Open BTCOEX
[ 6.740350] rtk_btusb: btusb_open end
[ 6.743314] rtk_btcoex: BTCOEX hci_rev 0x098a
[ 6.743317] rtk_btcoex: BTCOEX lmp_subver 0x42f7
[ 6.764330] rtk_btusb: btusb_notify: hci0 evt 3
[ 6.772571] usb 2-3: usb_suspend_both: status 0
[ 6.772795] usb usb2: usb_suspend_both: status 0
[ 6.881041] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 6.881055] Bluetooth: BNEP socket layer initialized
[ 7.198693] Mass Storage Function, version: 2009/09/11
[ 7.198698] LUN: removable file: (no medium)
[ 7.203582] using random self ethernet address
[ 7.203586] using random host ethernet address
[ 7.356730] rndis0: HOST MAC 6e:77:42:bf:45:b4
[ 7.357534] rndis0: MAC 6e:77:42:bf:45:b5
[ 7.359323] usb0: HOST MAC 6e:77:42:bf:45:b6
[ 7.359355] usb0: MAC 6e:77:42:bf:45:b7
[ 7.359374] tegra-xudc-new 3550000.xudc: exiting ELPG
[ 7.362566] tegra-xudc-new 3550000.xudc: exiting ELPG done
[ 7.362588] tegra-xudc-new 3550000.xudc: ep 0 (type: 0, dir: out) enabled
[ 7.362633] tegra-xudc-new 3550000.xudc: entering ELPG
[ 7.362847] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 7.362909] tegra-xudc-new 3550000.xudc: exiting ELPG
[ 7.363413] tegra-xudc-new 3550000.xudc: exiting ELPG done
[ 7.363440] tegra-xudc-new 3550000.xudc: entering ELPG
[ 7.363643] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 7.369829] l4tbr0: port 1(rndis0) entered blocking state
[ 7.369834] l4tbr0: port 1(rndis0) entered disabled state
[ 7.370345] device rndis0 entered promiscuous mode
[ 7.378202] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 7.383290] l4tbr0: port 2(usb0) entered blocking state
[ 7.383294] l4tbr0: port 2(usb0) entered disabled state
[ 7.383468] device usb0 entered promiscuous mode
[ 7.389338] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 7.630756] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 7.945884] gpio tegra-gpio wake20 for gpio=52(G:4)
[ 7.958628] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 7.971028] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 8.274833] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 8.345570] ras_fhi_disable: FHI 470 disabled
[ 8.346653] CPU2: shutdown
[ 8.364579] psci: Retrying again to check for CPU kill
[ 8.364598] psci: CPU2 killed.
[ 8.412990] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 8.414020] ras_fhi_disable: FHI 471 disabled
[ 8.424616] CPU3: shutdown
[ 8.424633] psci: CPU3 killed.
[ 8.469134] ras_fhi_disable: FHI 472 disabled
[ 8.470569] CPU4: shutdown
[ 8.470654] psci: CPU4 killed.
[ 8.518556] ras_fhi_disable: FHI 473 disabled
[ 8.528402] CPU5: shutdown
[ 8.544616] psci: Retrying again to check for CPU kill
[ 8.544644] psci: CPU5 killed.
[ 8.550370] nvgpu: 17000000.gv11b tpc_pg_mask_store:843 [INFO] no value change, same mask already set
[ 8.837452] zram: Added device: zram0
[ 8.841676] zram: Added device: zram1
[ 8.920784] zram0: detected capacity change from 0 to 2035679232
[ 9.071264] Adding 1987964k swap on /dev/zram0. Priority:5 extents:1 across:1987964k SS
[ 9.090929] zram1: detected capacity change from 0 to 2035679232
[ 9.133496] Adding 1987964k swap on /dev/zram1. Priority:5 extents:1 across:1987964k SS
[ 10.910469] tegradc 15200000.nvdisplay: blank - powerdown
[ 10.970600] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 10.970604] Extcon AUX1(HDMI) disable
[ 10.992105] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 10.992664] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 10.992888] tegradc 15200000.nvdisplay: unblank
[ 11.000080] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 11.007210] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 11.010332] Parent Clock set for DC plld2
[ 11.016907] tegradc 15200000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 11.018424] tegradc 15200000.nvdisplay: hdmi: get RGB quant from EDID.
[ 11.018436] tegradc 15200000.nvdisplay: hdmi: get YCC quant from EDID.
[ 11.054468] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 11.054472] Extcon AUX1(HDMI) enable
[ 11.055043] tegradc 15200000.nvdisplay: unblank
[ 11.055057] tegradc 15210000.nvdisplay: blank - powerdown
[ 13.767426] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 15.102006] fuse init (API version 7.26)
[ 17.630958] tegradc 15200000.nvdisplay: unblank
[ 17.630972] tegradc 15210000.nvdisplay: blank - powerdown
[ 68.928219] arducam-csi2 9-000c: arducam_csi2_set_fmt: code: 0x2001, width: 2560, height: 800
[ 68.928229] arducam-csi2 9-000c: arducam_csi2_set_fmt: format match.
[ 68.928261] arducam-csi2 9-000c: arducam_csi2_set_fmt: set format to device: 0 0.
[ 68.929804] arducam-csi2 9-000c: arducam_csi2_set_fmt: code: 0x2001, width: 2560, height: 800
[ 68.929811] arducam-csi2 9-000c: arducam_csi2_set_fmt: format match.
[ 68.929816] arducam-csi2 9-000c: arducam_csi2_set_fmt: set format to device: 0 0.
[ 69.937378] tegra194-vi5 15c10000.vi: vi_capture_setup: control failed, errno 1
[ 69.937585] tegra194-vi5 15c10000.vi: vi capture setup failed
