Full dmesg
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.201-tegra (wong@wong-ThinkPad-T430s) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #3 SMP PREEMPT Tue Mar 2 20:02:16 CST 2021
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 3f800000
[ 0.000000] OF: fdt: - bfa00000 , 3fe00000
[ 0.000000] OF: fdt: - ffa00000 , 600000
[ 0.000000] Found tegra_fbmem: 00800000@92ca9000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000070006000 (options '')
[ 0.000000] bootconsole [uart8250] enabled
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb0_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node iram-carveout, compatible id nvidia,iram-carveout
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fb800000
[ 0.000000] On node 0 totalpages: 522752
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 522752 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 24 pages/cpu s57560 r8192 d32552 u98304
[ 0.000000] pcpu-alloc: s57560 r8192 d32552 u98304 alloc=24*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] CPU features: enabling workaround for ARM erratum 832075
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 514560
[ 0.000000] Kernel command line: tegraid=21.1.2.0.0 ddr_die=2048M@2048M section=256M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 core_edp_mv=1075 core_edp_ma=4000 gpt tegra_fbmem=0x800000@0x92ca9000 is_hdmi_initialised=1 earlycon=uart8250,mmio32,0x70006000 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 98304 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 131072 bytes
[ 0.000000] early log buf free: 29472(89%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.000000] Memory: 1527684K/2091008K available (15294K kernel code, 2942K rwdata, 6740K rodata, 8576K init, 609K bss, 88188K reserved, 475136K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f70000 ( 15296 KB)
[ 0.000000] .rodata : 0xffffff8008f70000 - 0xffffff8009610000 ( 6784 KB)
[ 0.000000] .init : 0xffffff8009610000 - 0xffffff8009e70000 ( 8576 KB)
[ 0.000000] .data : 0xffffff8009e70000 - 0xffffff800a14f808 ( 2943 KB)
[ 0.000000] .bss : 0xffffff800a14f808 - 0xffffff800a1e7cbc ( 610 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf02000000 ( 32 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc080000000 ( 2048 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /interrupt-controller
[ 0.000000] t210 clock and reset probe
[ 0.000000] tegra-pmc: get_secure_pmc_setting: done secure_pmc=1
[ 0.000000] clk_cbus_recalc_rate: no gbus parent
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000006] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.010016] Console: colour dummy device 80x25
[ 0.014675] console [tty0] enabled
[ 0.018187] bootconsole [uart8250] disabled
[ 0.022514] kmemleak: Kernel memory leak detector disabled
[ 0.022540] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=76800)
[ 0.022565] pid_max: default: 32768 minimum: 301
[ 0.023026] Security Framework initialized
[ 0.023252] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.023263] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.024399] ftrace: allocating 47233 entries in 185 pages
[ 0.194260] sched-energy: CPU device node has no sched-energy-costs
[ 0.194295] ASID allocator initialised with 65536 entries
[ 0.232444] tegra-id: chipid=22117.
[ 0.232504] tegra-id: opt_subrevision=0.
[ 0.232527] Tegra Speedo/IDDQ fuse revision 4
[ 0.232536] Tegra: CPU Speedo ID 9, SoC Speedo ID 0, GPU Speedo ID 2
[ 0.232546] Tegra: CPU Process ID 0, SoC Process ID 1, GPU Process ID 0
[ 0.232557] Tegra: CPU Speedo Value 2063, SoC Speedo Value 1976, GPU Speedo Value 2071
[ 0.232568] Tegra: CPU IDDQ Value 2012, SoC IDDQ Value 2264, GPU IDDQ Value 2665
[ 0.232594] Tegra Revision: A02 SKU: 0x8f CPU Process: 0 SoC Process: 1
[ 0.232616] DTS File Name: /home/wong/Jetson/l4t-32.5.1/Linux_for_Tegra/source/public/kernel_src/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-b00-arducam.dts
[ 0.232645] DTB Build time: Mar 2 2021 18:19:46
[ 0.281351] CPU1: Booted secondary processor [411fd071]
[ 0.313225] CPU2: Booted secondary processor [411fd071]
[ 0.345195] CPU3: Booted secondary processor [411fd071]
[ 0.345288] Brought up 4 CPUs
[ 0.345344] SMP: Total of 4 processors activated.
[ 0.345361] CPU features: detected feature: 32-bit EL0 Support
[ 0.345652] CPU: All CPU(s) started at EL2
[ 0.345683] alternatives: patching kernel code
[ 0.353470] devtmpfs: initialized
[ 0.391887] Initilizing CustomIPI irq domain
[ 0.392311] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.392360] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.403494] pinctrl core: initialized pinctrl subsystem
[ 0.404133] OS set in device tree is not L4T.
[ 0.404680] regulator-dummy: no parameters
[ 0.404970] Initializing plugin-manager
[ 0.405145] Plugin module not found
[ 0.405507] node /plugin-manager/fragment@1 match with board >=3448-0003-400
[ 0.406824] node /plugin-manager/fragement@7 match with odm-data enable-pmic-wdt
[ 0.407062] node /plugin-manager/fragement@8 match with odm-data enable-pmic-wdt
[ 0.407539] node /plugin-manager/fragement@9 match with board >=3448-0003-000
[ 0.408944] node /plugin-manager/fragment@12 match with board >=3448-0003-400
[ 0.409215] node /plugin-manager/fragement@13 match with board >=3448-0003-400
[ 0.412805] NET: Registered protocol family 16
[ 0.414126] pstore: using zlib compression
[ 0.414663] console [pstore-1] enabled
[ 0.414680] pstore: Registered ramoops as persistent store backend
[ 0.414698] ramoops: attached 0x200000@0xb0000000, ecc: 0/0
[ 0.433372] cpuidle: using governor menu
[ 0.436813] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[ 0.438689] vdso: 2 pages (1 code @ ffffff8008f77000, 1 data @ ffffff8009e74000)
[ 0.438737] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.441916] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.444511] Serial: AMBA PL011 UART driver
[ 0.445072] tegra_powergate_init: DONE
[ 0.445103] DTS File Name: /home/wong/Jetson/l4t-32.5.1/Linux_for_Tegra/source/public/kernel_src/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-b00-arducam.dts
[ 0.445146] DTB Build time: Mar 2 2021 18:19:46
[ 0.447226] Tegra reboot handler registered.
[ 0.451916] iommu: Adding device tegra-carveouts to group 0
[ 0.452052] platform tegra-carveouts: domain=ffffffc078b07258 allocates as[0]=ffffffc078be40a8
[ 0.452417] iommu: Adding device smmu_test to group 1
[ 0.452482] platform smmu_test: domain=ffffffc078b07498 allocates as[0]=ffffffc078be4110
[ 0.453336] mc: mapped MMIO address: 0xffffff800802e000 -> 0x70019000
[ 0.453449] mc: mapped MMIO address: 0xffffff8008065000 -> 0x7001c000
[ 0.453524] mc: mapped MMIO address: 0xffffff8008079000 -> 0x7001d000
[ 0.453548] nv-tegra-mc 70019000.mc: No mssnvlink node
[ 0.453598] mc-err: mcerr ops are set to t21x
[ 0.464011] iommu: Adding device 70090000.xusb to group 2
[ 0.464343] iommu: Adding device 70006000.serial to group 3
[ 0.464418] platform 70006000.serial: domain=ffffffc078b58b58 allocates as[0]=ffffffc078be4178
[ 0.464873] iommu: Adding device 70006040.serial to group 4
[ 0.465143] iommu: Adding device 70006200.serial to group 5
[ 0.465384] iommu: Adding device sound to group 6
[ 0.465452] platform sound: domain=ffffffc0784b10d8 allocates as[0]=ffffffc078be41e0
[ 0.466048] iommu: Adding device 7000d400.spi to group 7
[ 0.466325] iommu: Adding device 7000d600.spi to group 8
[ 0.466639] iommu: Adding device 70410000.spi to group 9
[ 0.466955] iommu: Adding device 50000000.host1x to group 10
[ 0.467240] iommu: Adding device 54080000.vi to group 11
[ 0.467663] iommu: Adding device 54600000.isp to group 12
[ 0.467939] iommu: Adding device 54680000.isp to group 13
[ 0.468222] iommu: Adding device tegradc.0 to group 14
[ 0.468287] platform tegradc.0: domain=ffffffc078511018 allocates as[0]=ffffffc078be4248
[ 0.472479] platform tegradc.0: IOVA linear map 0x0000000092ca9000(800000)
[ 0.472888] platform tegradc.0: IOVA linear map 0x00000000d7000000(19000000)
[ 0.473241] iommu: Adding device tegradc.1 to group 15
[ 0.473300] platform tegradc.1: domain=ffffffc078511258 allocates as[0]=ffffffc078be42b0
[ 0.477481] platform tegradc.1: IOVA linear map 0x0000000092ca9000(800000)
[ 0.477889] platform tegradc.1: IOVA linear map 0x00000000d7000000(19000000)
[ 0.478178] iommu: Adding device 54340000.vic to group 16
[ 0.478400] iommu: Adding device 544c0000.nvenc to group 17
[ 0.478608] iommu: Adding device 54500000.tsec to group 18
[ 0.478812] iommu: Adding device 54100000.tsecb to group 19
[ 0.479030] iommu: Adding device 54480000.nvdec to group 20
[ 0.479230] iommu: Adding device 54380000.nvjpg to group 21
[ 0.480273] iommu: Adding device 546c0000.i2c to group 22
[ 0.480625] iommu: Adding device 57000000.gpu to group 23
[ 0.480694] platform 57000000.gpu: domain=ffffffc078525258 allocates as[0]=ffffffc078be4318
[ 0.480770] platform 57000000.gpu: domain=ffffffc078525258 allocates as[1]=ffffffc078be4380
[ 0.480827] platform 57000000.gpu: domain=ffffffc078525258 allocates as[2]=ffffffc078be43e8
[ 0.480880] platform 57000000.gpu: domain=ffffffc078525258 allocates as[3]=ffffffc078be4450
[ 0.481820] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency thermal reset disabled.
[ 0.481857] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
[ 0.481884] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ 0.481902] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_WARM
[ 0.481919] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.533537] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.533569] tegra-pmc: Clear bootloader IO dpd settings
[ 0.533601] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
[ 0.533681] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset commands
[ 0.534001] iommu: Adding device 70012000.se to group 24
[ 0.534805] iommu: Adding device 7000c000.i2c to group 25
[ 0.535072] iommu: Adding device 7000c400.i2c to group 26
[ 0.535334] iommu: Adding device 7000c500.i2c to group 27
[ 0.535603] iommu: Adding device 7000c700.i2c to group 28
[ 0.535889] iommu: Adding device 7000d000.i2c to group 29
[ 0.536156] iommu: Adding device 7000d100.i2c to group 30
[ 0.536462] iommu: Adding device sdhci-tegra.0 to group 31
[ 0.536530] platform sdhci-tegra.0: domain=ffffffc07859f3d8 allocates as[0]=ffffffc078be44b8
[ 0.537430] iommu: Adding device 700d0000.xudc to group 32
[ 0.540596] vdd-ac-bat: 5000 mV
[ 0.540978] vdd-5v0-sys: 5000 mV
[ 0.542011] vdd-5v0-hdmi: supplied by vdd-5v0-sys
[ 0.542081] vdd-5v0-hdmi: 5000 mV
[ 0.542519] vdd-1v8-sys: 1800 mV
[ 0.542982] vdd-fan: supplied by vdd-5v0-sys
[ 0.543038] vdd-fan: 5000 mV
[ 0.543428] vdd-usb-vbus: supplied by vdd-5v0-sys
[ 0.543470] vdd-usb-vbus: 5000 mV
[ 0.544018] vdd-usb-vbus2: 5000 mV
[ 0.574473] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.577018] gpio gpiochip0: gpio-line-names specifies 240 line names but there are 256 lines on the chip
[ 0.578183] GPIO line 151 (camera-control-output-low) hogged as output/low
[ 0.578219] GPIO line 152 (camera-control-output-low) hogged as output/low
[ 0.578267] GPIO line 6 (system-suspend-gpio) hogged as output/high
[ 0.578681] gpiochip_setup_dev: registered GPIOs 0 to 255 on device: gpiochip0 (tegra-gpio)
[ 0.586831] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.587241] SCSI subsystem initialized
[ 0.587499] libata version 3.00 loaded.
[ 0.587747] usbcore: registered new interface driver usbfs
[ 0.587817] usbcore: registered new interface driver hub
[ 0.587909] usbcore: registered new device driver usb
[ 0.591910] max77620 4-003c: PMIC Version OTP:0x35 and ES:0x8
[ 0.594339] random: fast init done
[ 0.597578] vdd-core: 600 <--> 1162 mV at 1075 mV
[ 0.598640] vdd-ddr-1v1: Bringing 1125000uV into 1150000-1150000uV
[ 0.601363] vdd-ddr-1v1: 1150 mV
[ 0.605263] vdd-pre-reg-1v35: 1350 mV
[ 0.609218] vdd-1v8: 1800 mV
[ 0.613210] avdd-sys-1v2: 1200 mV
[ 0.617219] vdd-pex-1v0: 1050 mV
[ 0.617873] vddio-sdmmc-ap: 1800 <--> 3300 mV at 3300 mV
[ 0.618459] max77620-ldo3: at 3100 mV
[ 0.621216] vdd-rtc: 850 <--> 1100 mV at 1000 mV
[ 0.621765] max77620-ldo5: at 3100 mV
[ 0.622315] max77620-ldo6: at 2800 mV
[ 0.625215] avdd-1v05-pll: 1050 mV
[ 0.629211] avdd-io-hdmi-dp: 1050 mV
[ 0.631921] GPIO line 505 (spmic-default-output-high) hogged as output/high
[ 0.632224] gpiochip_setup_dev: registered GPIOs 504 to 511 on device: gpiochip1 (max77620-gpio)
[ 0.632537] max77620 4-003c: max77620 probe successful
[ 0.635449] media: Linux media interface: v0.10
[ 0.635524] Linux video capture interface: v2.00
[ 0.636469] pps_core: LinuxPPS API ver. 1 registered
[ 0.636497] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.636541] PTP clock support registered
[ 0.639799] tegra210-emc 7001b000.external-memory-controller: validated EMC DFS table
[ 0.640733] Advanced Linux Sound Architecture Driver Initialized.
[ 0.641447] Bluetooth: Core ver 2.22
[ 0.641518] NET: Registered protocol family 31
[ 0.641536] Bluetooth: HCI device and connection manager initialized
[ 0.641562] Bluetooth: HCI socket layer initialized
[ 0.641583] Bluetooth: L2CAP socket layer initialized
[ 0.641646] Bluetooth: SCO socket layer initialized
[ 0.643445] tegra210_dvfs: no clock found for sdmmc2_ddr
[ 0.643484] tegra210_dvfs: no clock found for sdmmc4_ddr
[ 0.643544] tegra210_dvfs: no clock found for sdmmc1_ddr
[ 0.643572] tegra210_dvfs: no clock found for sdmmc3_ddr
[ 0.647286] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering probe
[ 0.648604] vdd-3v3-sys: supplied by vdd-5v0-sys
[ 0.648693] vdd-3v3-sys: 3300 mV
[ 0.649000] vdd-1v8-sys: supplied by vdd-3v3-sys
[ 0.653426] vdd-usb-vbus2: supplied by vdd-3v3-sys
[ 0.653962] vdd-3v3-sd: supplied by vdd-3v3-sys
[ 0.654020] vdd-3v3-sd: 3300 mV
[ 0.655177] avdd-io-edp-1v05: supplied by avdd-1v05-pll
[ 0.655233] avdd-io-edp-1v05: 1050 mV
[ 0.655673] vdd-usb-hub-en: supplied by vdd-1v8-sys
[ 0.655727] vdd-usb-hub-en: 5000 mV
[ 0.657121] camchar: rtcpu character device driver loaded
[ 0.658016] extcon-gpio-states extcon:extcon@1: Cable state:0, cable id:0
[ 0.659301] clocksource: Switched to clocksource arch_sys_counter
[ 0.700345] VFS: Disk quotas dquot_6.6.0
[ 0.700541] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.701052] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.701480] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000d7000000, size=0x19000000
[ 0.701525] dma-vpr: heap size is not multiple of cma_chunk_size heap_info->num_chunks (13) rem_chunk_size(0x1000000)
[ 0.701794] cma: enabled page replacement for spfn=d7000, epfn=f0000
[ 0.701816] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[ 0.701844] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 0.701899] tegra-carveouts tegra-carveouts: iram :dma coherent mem declare 0x0000000040001000,258048
[ 0.701924] tegra-carveouts tegra-carveouts: assigned reserved memory node iram-carveout
[ 0.701953] nvmap: nvmap_select_cache_ops() nvmap cache ops set to set/ways
[ 0.701974] nvmap_page_pool_init: Total RAM pages: 500705
[ 0.701990] nvmap_page_pool_init: nvmap page pool size: 62588 pages (244 MB)
[ 0.702084] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.702573] misc nvmap: created heap iram base 0x0000000040001000 size (252KiB)
[ 0.703506] misc nvmap: created heap vpr base 0x00000000d7000000 size (409600KiB)
[ 0.712497] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[ 0.712998] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[ 0.713395] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.713698] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.713901] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 0.714209] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[ 0.714227] pre_t19x_iso_plat_init(): max_iso_bw=11520000KB
[ 0.714674] NET: Registered protocol family 2
[ 0.715693] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.715827] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[ 0.716099] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.716266] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[ 0.716324] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[ 0.716688] NET: Registered protocol family 1
[ 0.717420] RPC: Registered named UNIX socket transport module.
[ 0.717444] RPC: Registered udp transport module.
[ 0.717460] RPC: Registered tcp transport module.
[ 0.717476] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.717501] PCI: CLS 0 bytes, default 64
[ 0.717740] Trying to unpack rootfs image as initramfs...
[ 1.021763] Freeing initrd memory: 6992K
[ 1.031812] host1x 50000000.host1x: initialized
[ 1.033600] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.036953] audit: initializing netlink subsys (disabled)
[ 1.037073] audit: type=2000 audit(0.875:1): initialized
[ 1.037894] workingset: timestamp_bits=46 max_order=19 bucket_order=0
[ 1.047845] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.049356] ntfs: driver 2.1.32 [Flags: R/W].
[ 1.050162] 9p: Installing v9fs 9p2000 file system support
[ 1.053755] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 1.053927] io scheduler noop registered
[ 1.054238] io scheduler cfq registered (default)
[ 1.057002] gic 702f9000.agic: GIC IRQ controller registered
[ 1.060035] iommu: Adding device 702ef000.adsp to group 33
[ 1.069245] iommu: Adding device aconnect@702c0000:adsp_audio to group 34
[ 1.069429] tegra-aconnect aconnect@702c0000: Tegra ACONNECT bus registered
[ 1.070028] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_SKU_CALIB_0 = 0x8a49410
[ 1.070059] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_USB_CALIB_EXT_0 = 0x4
[ 1.071876] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.0, lane = usb2-0, function = xusb
[ 1.072015] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.1, lane = usb2-1, function = xusb
[ 1.072134] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane = usb2-2, function = xusb
[ 1.072345] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane = pcie-0, function = pcie-x1
[ 1.072453] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane = pcie-1, function = pcie-x4
[ 1.072565] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane = pcie-2, function = pcie-x4
[ 1.072674] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane = pcie-3, function = pcie-x4
[ 1.072782] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane = pcie-4, function = pcie-x4
[ 1.072887] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane = pcie-5, function = xusb
[ 1.072998] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane = pcie-6, function = xusb
[ 1.079120] tegra-pwm 7000a000.pwm: PWM clk cannot sleep in ops
[ 1.081019] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[ 1.082954] tegra-pcie 1003000.pcie: 4x1, 1x1 configuration
[ 1.084290] tegra-pcie 1003000.pcie: PCIE: Enable power rails
[ 1.084666] tegra-pcie 1003000.pcie: probing port 0, using 4 lanes
[ 1.085862] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 1.086113] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=750000, max_bw=1500000
[ 1.086386] Adding domain tsec-pd to PM domain host1x-pd
[ 1.088753] tegra-pcie 1003000.pcie: probing port 1, using 1 lanes
[ 1.089683] tsec 54500000.tsec: initialized
[ 1.091333] tsec 54100000.tsecb: initialized
[ 1.092097] Adding domain nvdec-pd to PM domain host1x-pd
[ 1.095750] nvdec 54480000.nvdec: initialized
[ 1.096864] Adding domain vic03-pd to PM domain host1x-pd
[ 1.097070] Adding domain msenc-pd to PM domain host1x-pd
[ 1.097243] Adding domain nvjpg-pd to PM domain host1x-pd
[ 1.101543] falcon 54340000.vic: initialized
[ 1.102863] falcon 544c0000.nvenc: initialized
[ 1.104257] falcon 54380000.nvjpg: initialized
[ 1.108582] tegra_cec 70015000.tegra_cec: dt=1 start=0x70015000 end=0x70015FFF irq=97
[ 1.108669] tegra_cec 70015000.tegra_cec: Enable clock result: 0.
[ 1.108701] tegradc tegradc.0: disp0 connected to head0->/host1x/sor1
[ 1.108715] tegra_cec 70015000.tegra_cec: tegra_cec_init started
[ 1.108824] display board info: id 0x0, fab 0x0
[ 1.108899] generic_infoframe_type: 0x87
[ 1.109008] tegra_cec 70015000.tegra_cec: cec_add_sysfs ret=0
[ 1.109031] tegra_cec 70015000.tegra_cec: probed
[ 1.109047] tegradc tegradc.0: DT parsed successfully
[ 1.109113] tegradc tegradc.0: Display dc.ffffff800ab80000 registered with id=0
[ 1.109681] tegradc tegradc.0: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350781
[ 1.117031] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
[ 1.117594] tegradc tegradc.0: probed
[ 1.123697] tegra-adma 702e2000.adma: Tegra210 ADMA driver registered 22 channels
[ 1.125186] tegra-fuse-burn 7000f800.efuse:efuse-burn: shutdown limit check disabled
[ 1.125227] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initialized
[ 1.125701] kfuse 7000fc00.kfuse: initialized
[ 1.127494] tegra-pmc-iopower pmc-iopower: Regulator supply iopower-dbg-supply not available
[ 1.128522] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 1.130021] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[ 1.130061] vdd-cpu: 708 <--> 1322 mV at 708 mV
[ 1.130598] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator registration passed
[ 1.132371] vdd-gpu: applied init 1000000uV constraint
[ 1.132408] vdd-gpu: 708 <--> 1323 mV at 997 mV
[ 1.132868] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator registration passed
[ 1.137790] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.137989] No Device Node present for smmu client: serial8250 !!
[ 1.138016] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 1.138100] iommu: Adding device serial8250 to group 35
[ 1.142011] console [ttyS0] disabled
[ 1.142244] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 63, base_baud = 25500000) is a Tegra
[ 1.594692] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 1.999140] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 2.119329] tegra_cec 70015000.tegra_cec: Can't find physical addresse.
[ 2.119334] tegra_cec 70015000.tegra_cec: tegra_cec_init Done.
[ 2.402973] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 2.404990] tegra-pcie 1003000.pcie: link 0 down, ignoring
[ 2.511143] tegra-pcie 1003000.pcie: PCI host bridge to bus 0000:00
[ 2.511155] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 2.511160] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
[ 2.511165] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pref]
[ 2.511171] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 2.511215] pci 0000:00:02.0: [10de:0faf] type 01 class 0x060400
[ 2.511358] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2.511603] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 2.511753] pci 0000:01:00.0: [10ec:8168] type 00 class 0x020000
[ 2.511782] pci 0000:01:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 2.511814] pci 0000:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[ 2.511837] pci 0000:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[ 2.511987] pci 0000:01:00.0: supports D1 D2
[ 2.511991] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2.523403] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 2.523452] pci 0000:00:02.0: BAR 14: assigned [mem 0x13000000-0x130fffff]
[ 2.523459] pci 0000:00:02.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 2.523468] pci 0000:01:00.0: BAR 4: assigned [mem 0x13000000-0x13003fff 64bit]
[ 2.523489] pci 0000:01:00.0: BAR 2: assigned [mem 0x13004000-0x13004fff 64bit]
[ 2.523508] pci 0000:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 2.523518] pci 0000:00:02.0: PCI bridge to [bus 01]
[ 2.523524] pci 0000:00:02.0: bridge window [io 0x1000-0x1fff]
[ 2.523530] pci 0000:00:02.0: bridge window [mem 0x13000000-0x130fffff]
[ 2.523923] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
[ 2.523928] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 2.523934] pcie_pme 0000:00:02.0:pcie001: service driver pcie_pme loaded
[ 2.524066] aer 0000:00:02.0:pcie002: service driver aer loaded
[ 3.612021] console [ttyS0] enabled
[ 3.612629] Console: switching to colour frame buffer device 240x67
[ 3.613408] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 64, base_baud = 0) is a TEGRA_UART
[ 3.613764] serial-tegra 70006200.serial: RX in PIO mode
[ 3.613850] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 65, base_baud = 0) is a TEGRA_UART
[ 3.614746] [drm] Initialized
[ 3.648713] tegradc tegradc.0: fb registered
[ 3.652472] brd: module loaded
[ 3.661278] loop: module loaded
[ 3.663215] tegradc tegradc.0: DC initialized, skipping tegra_dc_program_mode.
[ 3.663259] tegradc tegradc.0: hdmi: tmds rate:148351K prod-setting:prod_c_hdmi_75m_150m
[ 3.663798] tegradc tegradc.0: hdmi: get RGB quant from REG programmed by BL.
[ 3.663810] tegradc tegradc.0: hdmi: get YCC quant from REG programmed by BL.
[ 3.689947] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 3.689952] Extcon AUX1(HDMI) enable
[ 3.690934] tegradc tegradc.1: disp1 connected to head1->/host1x/sor
[ 3.691005] tegradc tegradc.1: No lt-data, using default setting
[ 3.691033] tegradc tegradc.1: No hpd-gpio in DT
[ 3.691063] tegradc tegradc.1: DT parsed successfully
[ 3.691120] tegradc tegradc.1: Display dc.ffffff800d500000 registered with id=1
[ 3.692632] tegradc tegradc.1: dpd enable lookup fail:-19
[ 3.696937] tegradc tegradc.1: probed
[ 3.727391] tegradc tegradc.0: nominal-pclk:148351648 parent:148350781 div:1.0 pclk:148350781 146868084~161703244
[ 3.752533] tegradc tegradc.1: fb registered
[ 3.752604] tegra_profiler: version: 1.143, samples/io: 48/28
[ 3.752709] tegra_profiler: auth: init
[ 3.753294] THERMAL EST: found 2 subdevs
[ 3.753298] THERMAL EST num_resources: 0
[ 3.753302] [THERMAL EST subdev 0]
[ 3.753306] [THERMAL EST subdev 1]
[ 3.753614] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[ 3.753616] THERMAL EST: thz register success.
[ 3.753722] THERMAL EST: end of probe, return err: 0
[ 3.754338] sd: No Scsi addr parsed to reserve index
[ 3.754359] hisi_sas: driver version v1.6
[ 3.758086] tegra-qspi 70410000.spi: Prod settings list not found
[ 3.758928] qspi_mtd spi32766.0: MX25U3235F (4096 Kbytes)
[ 3.758935] qspi_mtd spi32766.0: mtd .name = spi32766.0, .size = 0x400000 (4MiB) .erasesize = 0x00001000 (4KiB) .numeraseregions = 0
[ 3.771210] libphy: Fixed MDIO Bus: probed
[ 3.771768] tun: Universal TUN/TAP device driver, 1.6
[ 3.771770] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 3.773046] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 3.773048] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 3.773092] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 3.773094] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 3.773140] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 3.773142] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 3.773185] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 3.773187] Copyright(c) 1999 - 2017 Intel Corporation.
[ 3.773840] r8168 0000:01:00.0: enabling device (0000 -> 0003)
[ 3.773859] r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded
[ 3.788431] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Invalid ethernet address 00:00:00:00:00:00, trying device tree node
[ 3.788493] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Found valid ethernet address 48:b0:2d:2e:c0:56 from device tree
[ 3.788913] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[ 3.788945] r8168 Copyright (C) 2017 Realtek NIC software team <nicfae@realtek.com>
This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
[ 3.789351] PPP generic driver version 2.4.2
[ 3.789488] PPP BSD Compression module registered
[ 3.789491] PPP Deflate Compression module registered
[ 3.789504] PPP MPPE Compression module registered
[ 3.789508] NET: Registered protocol family 24
[ 3.789559] usbcore: registered new interface driver r8152
[ 3.789599] usbcore: registered new interface driver asix
[ 3.789642] usbcore: registered new interface driver ax88179_178a
[ 3.789675] usbcore: registered new interface driver cdc_ether
[ 3.789708] usbcore: registered new interface driver net1080
[ 3.789739] usbcore: registered new interface driver cdc_subset
[ 3.789773] usbcore: registered new interface driver zaurus
[ 3.789818] usbcore: registered new interface driver cdc_ncm
[ 3.789954] VFIO - User Level meta-driver version: 0.3
[ 3.790898] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 3.790909] ehci-pci: EHCI PCI platform driver
[ 3.790948] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 3.790956] ohci-pci: OHCI PCI platform driver
[ 3.790991] ohci-platform: OHCI generic platform driver
[ 3.793014] tegra-xusb 70090000.xusb: USB2 port 0 has OTG_CAP
[ 3.793563] tegra-xusb-padctl 7009f000.xusb_padctl: enabled OTG on UTMI pad 0
[ 3.794618] tegra-xusb 70090000.xusb: extcon 0: ffffffc078029000 id
[ 3.796096] usbcore: registered new interface driver uas
[ 3.796141] usbcore: registered new interface driver usb-storage
[ 3.796207] usbcore: registered new interface driver usbserial
[ 3.797056] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-10-17 15:58:59 UTC, Version: 50.25 release
[ 3.797086] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 3.797102] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 1
[ 3.797818] tegra-xusb 70090000.xusb: hcc params 0x0184f525 hci version 0x100 quirks 0x00050010
[ 3.797855] tegra-xusb 70090000.xusb: irq 61, io mem 0x70090000
[ 3.798004] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.798010] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.798014] usb usb1: Product: xHCI Host Controller
[ 3.798017] usb usb1: Manufacturer: Linux 4.9.201-tegra xhci-hcd
[ 3.798021] usb usb1: SerialNumber: 70090000.xusb
[ 3.798428] hub 1-0:1.0: USB hub found
[ 3.798461] hub 1-0:1.0: 5 ports detected
[ 3.799004] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 3.799013] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 2
[ 3.799083] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 3.799176] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 3.799181] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.799184] usb usb2: Product: xHCI Host Controller
[ 3.799188] usb usb2: Manufacturer: Linux 4.9.201-tegra xhci-hcd
[ 3.799192] usb usb2: SerialNumber: 70090000.xusb
[ 3.799661] hub 2-0:1.0: USB hub found
[ 3.799692] hub 2-0:1.0: 4 ports detected
[ 3.800404] tegra-xusb 70090000.xusb: Upgrade port 0 to USB3.0
[ 3.800409] tegra-xusb 70090000.xusb: Upgrade port 1 to USB3.0
[ 3.800727] tegra-xudc-new 700d0000.xudc: device count: 1
[ 3.801687] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[ 3.801696] tegra-xudc-new 700d0000.xudc: vbus state: 0
[ 3.801717] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 3.801950] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 3.802407] mousedev: PS/2 mouse device common for all mice
[ 3.802471] usbcore: registered new interface driver xpad
[ 3.895373] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 3.895432] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 2
[ 3.903534] usb usb2: usb_suspend_both: status 0
[ 3.928110] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 3.930245] rtc rtc1: alarm rtc device
[ 3.930257] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc1
[ 3.930274] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[ 3.930615] i2c /dev entries driver
[ 3.955693] tegra-vii2c 546c0000.i2c: no acknowledge from address 0xc
[ 3.955884] tegra-vii2c 546c0000.i2c: no acknowledge from address 0xc
[ 3.956067] tegra-vii2c 546c0000.i2c: no acknowledge from address 0xc
[ 3.956127] arducam-csi2: arducam_read: Reading register 0x103 failed
[ 3.956131] arducam-csi2 6-000c: probe failed
[ 3.956158] arducam-csi2 6-000c: Failed to setup board.
[ 3.956703] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 3.958553] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[ 3.958558] tegra_soctherm 700e2000.soctherm: pllx_offset tz:2 max:8, min:4
[ 3.958858] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.958870] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[ 3.958876] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
[ 3.959003] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.959012] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[ 3.959019] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
[ 3.959162] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.959171] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[ 3.959175] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
[ 3.959368] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[ 3.959884] tegra_aotag tegra-aotag: Registering sensor 0
[ 3.959930] tegra_aotag tegra-aotag: Invalid temp readout
[ 3.959949] tegra_aotag tegra-aotag: Invalid temp readout
[ 3.959965] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[ 3.959973] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[ 3.960734] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.960748] tegra_dfll_action dfll-cdev-cap: Tegra DFLL 'cap cooling device' registered
[ 3.960897] tegra_aotag tegra-aotag: Invalid temp readout
[ 3.960919] tegra_dfll_action dfll-cdev-floor: Tegra DFLL 'floor cooling device' registered
[ 3.961257] parse_throttle_dt_data: Num cap clks = 6
[ 3.961262] parse_throttle_dt_data: clk=cclk_g type=2
[ 3.961269] parse_throttle_dt_data: clk=gpu type=4
[ 3.961288] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[ 3.961308] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[ 3.961329] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[ 3.961332] parse_throttle_dt_data: clk=emc type=3
[ 3.961624] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.961713] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.961830] tegra_throttle_probe: probe successful. #cdevs=4
[ 3.962390] FAN dev name: pwm-fan
[ 3.962435] FAN:gpio request success.
[ 3.962485] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 3.962718] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 3.962832] pwm_fan_driver pwm-fan: fan tach request irq success
[ 3.962839] pwm_fan_driver pwm-fan: tach period: 1000
[ 3.962918] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 3.962923] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 3.962927] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 3.962931] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 3.962935] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 3.962938] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 3.962942] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 3.962946] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 3.962950] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 3.962954] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 3.965034] device-mapper: uevent: version 1.0.3
[ 3.965518] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 3.968182] tegra210-cpufreq cpufreq: probe()...completed
[ 3.968843] sdhci: Secure Digital Host Controller Interface driver
[ 3.968844] sdhci: Copyright(c) Pierre Ossman
[ 3.968845] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.969309] sdhci-tegra sdhci-tegra.0: Got CD GPIO
[ 3.969654] sdhci-tegra sdhci-tegra.0: Client registration for eMC Successful
[ 3.969774] sdhci-tegra sdhci-tegra.0: wakeup init done, cdirq 300
[ 3.974630] tegra-se 70012000.se: tegra_se_probe: complete
[ 3.975118] hidraw: raw HID events driver (C) Jiri Kosina
[ 3.976176] usbcore: registered new interface driver usbhid
[ 3.976178] usbhid: USB HID core driver
[ 3.977056] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x40
[ 3.977115] ina3221x 6-0040: ina3221 reset failure status: 0xffffff87
[ 3.977262] ina3221x: probe of 6-0040 failed with error -121
[ 3.978238] tegra21x_actmon 6000c800.actmon: in actmon_register()...
[ 3.978412] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
[ 3.980257] nvpmodel: initialized successfully
[ 3.981371] usbcore: registered new interface driver snd-usb-audio
[ 3.981428] No Device Node present for smmu client: snd-soc-dummy !!
[ 3.981432] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 3.981450] iommu: Adding device snd-soc-dummy to group 36
[ 3.998549] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/card0/input0
[ 4.007931] OPE platform probe
[ 4.008016] OPE platform probe successful
[ 4.008296] OPE platform probe
[ 4.008374] OPE platform probe successful
[ 4.019681] mmc0: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADMA 64-bit with 64 bit addr
[ 4.031921] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 4.032049] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 4.032174] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 4.032296] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 4.032416] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 4.032547] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 4.032666] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 4.032785] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 4.032908] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 4.033027] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 4.045166] u32 classifier
[ 4.045168] Actions configured
[ 4.045239] Initializing XFRM netlink socket
[ 4.045939] NET: Registered protocol family 10
[ 4.046680] NET: Registered protocol family 17
[ 4.046691] NET: Registered protocol family 15
[ 4.046763] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 4.046808] Bluetooth: RFCOMM socket layer initialized
[ 4.046816] Bluetooth: RFCOMM ver 1.11
[ 4.046820] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 4.046824] Bluetooth: HIDP socket layer initialized
[ 4.046842] 9pnet: Installing 9P2000 support
[ 4.046879] Key type dns_resolver registered
[ 4.050100] Registered cp15_barrier emulation handler
[ 4.050157] Registered setend emulation handler
[ 4.051204] registered taskstats version 1
[ 4.051855] Adding domain ve2-pd to PM domain host1x-pd
[ 4.052111] Adding domain ve-pd to PM domain host1x-pd
[ 4.132148] usb 1-2: new low-speed USB device number 2 using tegra-xusb
[ 4.162900] usb 1-2: New USB device found, idVendor=1c4f, idProduct=0002
[ 4.162904] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.162907] usb 1-2: Product: USB Keyboard
[ 4.162909] usb 1-2: Manufacturer: SIGMACHIP
[ 4.170289] input: SIGMACHIP USB Keyboard as /devices/70090000.xusb/usb1/1-2/1-2:1.0/0003:1C4F:0002.0001/input/input1
[ 4.226940] mmc0: Applying tuning correction
[ 4.226953] mmc0: Tap value after applying correction 57
[ 4.226969] mmc0: hw tuning done ...
[ 4.227000] mmc0: new ultra high speed SDR104 SDXC card at address aaaa
[ 4.227396] mmcblk0: mmc0:aaaa SN64G 59.5 GiB
[ 4.231668] hid-generic 0003:1C4F:0002.0001: input,hidraw0: USB HID v1.10 Keyboard [SIGMACHIP USB Keyboard] on usb-70090000.xusb-2/input0
[ 4.231860] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14
[ 4.234849] input: SIGMACHIP USB Keyboard as /devices/70090000.xusb/usb1/1-2/1-2:1.1/0003:1C4F:0002.0002/input/input2
[ 4.291589] hid-generic 0003:1C4F:0002.0002: input,hidraw1: USB HID v1.10 Device [SIGMACHIP USB Keyboard] on usb-70090000.xusb-2/input1
[ 4.415307] usb 1-3: new high-speed USB device number 3 using tegra-xusb
[ 4.435679] usb 1-3: New USB device found, idVendor=1a40, idProduct=0801
[ 4.435683] usb 1-3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 4.435685] usb 1-3: Product: USB 2.0 Hub
[ 4.436448] hub 1-3:1.0: USB hub found
[ 4.436516] hub 1-3:1.0: 4 ports detected
[ 4.723309] usb 1-3.1: new high-speed USB device number 4 using tegra-xusb
[ 4.743922] usb 1-3.1: New USB device found, idVendor=0bda, idProduct=c811
[ 4.743925] usb 1-3.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 4.743928] usb 1-3.1: Product: 802.11ac NIC
[ 4.743931] usb 1-3.1: Manufacturer: Realtek
[ 4.743933] usb 1-3.1: SerialNumber: 123456
[ 4.843310] usb 1-3.2: new full-speed USB device number 5 using tegra-xusb
[ 4.866112] usb 1-3.2: New USB device found, idVendor=1d57, idProduct=fa60
[ 4.866115] usb 1-3.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.866118] usb 1-3.2: Product: 2.4G Receiver
[ 4.866120] usb 1-3.2: Manufacturer: Compx
[ 4.868672] input: Compx 2.4G Receiver as /devices/70090000.xusb/usb1/1-3/1-3.2/1-3.2:1.0/0003:1D57:FA60.0003/input/input3
[ 4.927640] hid-generic 0003:1D57:FA60.0003: input,hidraw2: USB HID v1.00 Keyboard [Compx 2.4G Receiver] on usb-70090000.xusb-3.2/input0
[ 4.929191] input: Compx 2.4G Receiver as /devices/70090000.xusb/usb1/1-3/1-3.2/1-3.2:1.1/0003:1D57:FA60.0004/input/input4
[ 4.929492] hid-generic 0003:1D57:FA60.0004: input,hidraw3: USB HID v1.00 Mouse [Compx 2.4G Receiver] on usb-70090000.xusb-3.2/input1
[ 4.931381] input: Compx 2.4G Receiver as /devices/70090000.xusb/usb1/1-3/1-3.2/1-3.2:1.2/0003:1D57:FA60.0005/input/input5
[ 4.987572] hid-generic 0003:1D57:FA60.0005: input,hidraw4: USB HID v1.00 Device [Compx 2.4G Receiver] on usb-70090000.xusb-3.2/input2
[ 5.300421] tegradc tegradc.0: blank - powerdown
[ 5.303471] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 5.303474] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 5.303479] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 5.304599] isp 54600000.isp: initialized
[ 5.305405] isp 54680000.isp: initialized
[ 5.315799] last reset is due to power on reset
[ 5.315802] KERNEL: PMC reset status reg: 0x0
[ 5.315860] BL: PMC reset status reg: 0x0
[ 5.315862] BL: PMIC poweroff Event Recorder: 0x40
[ 5.317332] clk_cbus_recalc_rate: no gbus parent
[ 5.317336] clk_cbus_round_rate: no gbus parent
[ 5.317338] clk_cbus_round_rate: no gbus parent
[ 5.317345] clk_cbus_recalc_rate: no gbus parent
[ 5.317443] clk_cbus_recalc_rate: no gbus parent
[ 5.317446] clk_cbus_round_rate: no gbus parent
[ 5.317447] clk_cbus_round_rate: no gbus parent
[ 5.317451] clk_cbus_recalc_rate: no gbus parent
[ 5.317464] tegra_dvfs: GPU-cap: registered
[ 5.317522] tegra dvfs: vdd-cpu: nominal 1168mV, offset 708000uV, step 19200uV, scaling enabled
[ 5.317524] tegra dvfs: vdd-core: nominal 1075mV, offset 600000uV, step 12500uV, scaling enabled
[ 5.317526] tegra dvfs: vdd-gpu: nominal 1058mV, offset 708000uV, step 10000uV, scaling enabled
[ 5.318910] tegra_dvfs: vdd-gpu-vts: registered
[ 5.319597] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS 'floor cooling device' registered
[ 5.320212] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS 'cap cooling device' registered
[ 5.320762] input: gpio-keys as /devices/gpio-keys/input/input6
[ 5.350654] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 5.350656] Extcon AUX1(HDMI) disable
[ 5.351954] tegra_rtc 7000e000.rtc: setting system clock to 2000-01-01 01:00:16 UTC (946688416)
[ 5.352980] vi 54080000.vi: vi_probe: ++
[ 5.355643] vi 54080000.vi: initialized
[ 5.357630] vi 54080000.vi: subdev nvcsi--1 bound
[ 5.357883] mmcblk mmc0:aaaa: Card claimed for testing.
[ 5.358483] Disable partitions left on by BL
[ 5.358486] disb
[ 5.358525] bwmgr: missing cdev-type property
[ 5.358651] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 5.358657] DRAM derating cdev registered.
[ 5.359635] ALSA device list:
[ 5.359638] #0: tegra-hda at 0x70038000 irq 83
[ 5.359640] #1: tegra-snd-t210ref-mobile-rt565x
[ 5.378522] tegradc tegradc.0: unblank
[ 5.414431] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 5.414478] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[ 5.415466] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 5.450265] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 5.450267] Extcon AUX1(HDMI) enable
[ 5.465709] tegradc tegradc.0: sync windows ret = 246
[ 5.841323] tegradc tegradc.1: blank - powerdown
[ 5.847753] extcon-disp-state extcon:disp-state: cable 44 state 0 already set.
[ 5.847757] Extcon DP: HPD disabled
[ 5.847759] hpd: hpd_switch 0
[ 5.847761] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 5.847769] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 5.847774] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 5.891741] extcon-disp-state extcon:disp-state: cable 51 state 1
[ 5.891743] Extcon HDMI: HPD enabled
[ 5.891758] tegradc tegradc.0: hdmi: plugged
[ 5.914192] Freeing unused kernel memory: 8576K
[ 5.944959] Root device found: mmcblk0p1
[ 5.952194] Found dev node: /dev/mmcblk0p1
[ 5.995304] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 6.007094] Rootfs mounted over mmcblk0p1
[ 6.042665] Switching from initrd to actual rootfs
[ 6.243014] systemd[1]: System time before build time, advancing clock.
[ 6.273984] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 6.293412] cgroup: cgroup2: unknown option "nsdelegate"
[ 6.316030] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 6.342075] systemd[1]: Detected architecture arm64.
[ 6.383355] systemd[1]: Set hostname to <creep-pc>.
[ 6.539351] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 6.558463] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 6.769115] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.779613] systemd[1]: Created slice System Slice.
[ 6.789318] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.798302] systemd[1]: Listening on Journal Audit Socket.
[ 6.808432] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.817469] systemd[1]: Listening on udev Control Socket.
[ 6.827673] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 6.839855] systemd[1]: Created slice User and Session Slice.
[ 6.984574] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 7.110467] systemd-journald[2002]: Received request to flush runtime journal from PID 1
[ 7.135342] nvgpu: 57000000.gpu gm20b_init_clk_setup_sw:1268 [INFO] GPCPLL initial settings: NA mode, M=1, N=34, P=3 (id = 1)
[ 7.140218] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 7.140240] cpu-throttle-alert cooling device registered.
[ 7.140451] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 7.140464] gpu-throttle-alert cooling device registered.
[ 7.140624] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 7.140635] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 7.140647] hot-surface-alert cooling device registered.
[ 7.395224] Adding 4194300k swap on /swapfile. Priority:-1 extents:5 across:4481020k SS
[ 8.149295] using random self ethernet address
[ 8.155297] using random host ethernet address
[ 8.299568] random: crng init done
[ 8.304441] random: 7 urandom warning(s) missed due to ratelimiting
[ 9.242405] Mass Storage Function, version: 2009/09/11
[ 9.242411] LUN: removable file: (no medium)
[ 9.248911] using random self ethernet address
[ 9.254944] using random host ethernet address
[ 9.342256] rndis0: HOST MAC 02:36:54:6f:70:f4
[ 9.342491] rndis0: MAC 02:36:54:6f:70:f5
[ 9.343890] usb0: HOST MAC 02:36:54:6f:70:f6
[ 9.343920] usb0: MAC 02:36:54:6f:70:f7
[ 9.343943] tegra-xudc-new 700d0000.xudc: exiting ELPG
[ 9.344690] tegra-xudc-new 700d0000.xudc: exiting ELPG done
[ 9.344710] tegra-xudc-new 700d0000.xudc: ep 0 (type: 0, dir: out) enabled
[ 9.347597] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 9.347859] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 9.347887] tegra-xudc-new 700d0000.xudc: exiting ELPG
[ 9.348384] tegra-xudc-new 700d0000.xudc: exiting ELPG done
[ 9.348397] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 9.348621] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 9.352916] l4tbr0: port 1(rndis0) entered blocking state
[ 9.352921] l4tbr0: port 1(rndis0) entered disabled state
[ 9.353091] device rndis0 entered promiscuous mode
[ 9.363208] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 9.370524] l4tbr0: port 2(usb0) entered blocking state
[ 9.370529] l4tbr0: port 2(usb0) entered disabled state
[ 9.371448] device usb0 entered promiscuous mode
[ 9.379706] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 10.523598] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 10.524697] eth0: 0xffffff800a42c000, 48:b0:2d:2e:c0:56, IRQ 406
[ 10.608208] zram: Added device: zram0
[ 10.608722] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 10.612509] zram: Added device: zram1
[ 10.617658] zram: Added device: zram2
[ 10.620778] zram: Added device: zram3
[ 10.647762] zram0: detected capacity change from 0 to 258355200
[ 10.719398] Adding 252296k swap on /dev/zram0. Priority:5 extents:1 across:252296k SS
[ 10.727788] zram1: detected capacity change from 0 to 258355200
[ 10.741095] Adding 252296k swap on /dev/zram1. Priority:5 extents:1 across:252296k SS
[ 10.752654] zram2: detected capacity change from 0 to 258355200
[ 10.774987] Adding 252296k swap on /dev/zram2. Priority:5 extents:1 across:252296k SS
[ 10.778130] zram3: detected capacity change from 0 to 258355200
[ 10.810521] Adding 252296k swap on /dev/zram3. Priority:5 extents:1 across:252296k SS
[ 11.038032] usbcore: registered new interface driver rtl8821cu
[ 11.092932] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 11.865155] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 11.879701] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 11.961839] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 11.972363] tegradc tegradc.0: unblank
[ 11.972743] tegradc tegradc.1: blank - powerdown
[ 13.196459] fuse init (API version 7.26)
[ 16.268409] start_addr=(0x8000), end_addr=(0x10000), buffer_size=(0x8000), smp_number_max=(4096)
[ 16.385735] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 30.908952] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 30.908963] Bluetooth: BNEP socket layer initialized
[ 35.971463] vdd-fan: disabling
[ 35.971467] vdd-usb-vbus: disabling
[ 35.971470] vdd-usb-vbus2: disabling
[ 35.971479] avdd-io-edp-1v05: disabling
[ 35.971481] vdd-usb-hub-en: disabling
