I successfully compiled max9295, max9296 and imx390 from builtin module to loadable module( They do not exist in modules.builtin)
I used to replace Image and tegra194-p2888-0001-p2822-0000.dtb according to Leopard imaging. But if I change them into loadable modules, which file should I replace before I flash kernel-dtb and kernel?
Have a check the flash log to find the dtb file name for your Xavier. Like below.
And for the kernel Image you can copy it to Xavier and modify the /boot/extlinux/extlinux.conf to load your Image.
[ 96.0785 ] Writing partition DTB-1 with tegra210-jetson-tx1-p2597-2180-a01-devkit.dtb.encrypt
[ 96.1089 ] [................................................] 100%
[ 96.1378 ] Writing partition TOS-1 with tos-mon-only.img.encrypt
[ 96.1801 ] [................................................] 100%
[ 96.1936 ] Writing partition EKS-1 with eks.img
[ 96.2302 ] [................................................] 100%
[ 96.2419 ] Writing partition LNX-1 with boot.img.encrypt
[ 96.2783 ] [................................................] 100%
[ 96.3077 ] Writing partition BMP with bmp.blob
[ 96.3389 ] [................................................] 100%
[ 96.3674 ] Writing partition RP4 with rp4.blob
[ 96.4048 ] [................................................] 100%
[ 96.4651 ]
[ 96.4660 ] tegradevflash --write BCT P2180_A00_LP4_DSC_204Mhz.bct
[ 96.4672 ] Cboot version 00.01.0000
[ 96.5374 ] Writing partition BCT with P2180_A00_LP4_DSC_204Mhz.bct
[ 96.5380 ] [................................................] 100%
[ 96.9676 ]
[ 96.9677 ] Flashing completed
[ 96.9678 ] Coldbooting the device
[ 96.9690 ] tegradevflash --reboot coldboot
[ 96.9702 ] Cboot version 00.01.0000
*** The target t210ref has been flashed successfully. ***
Reset the board to boot from internal eMMC.
After I finished compiling kernel. I replaced Image and tegra194-p2888-0001-p2822-0000.dtb just like before. Then I flashed the kernel-dtb and kernel.
I replaced Image file in /boot according to /boot/extlinux/exlinux.conf and reboot. But in my Xavier, modules.builtin still has imx390.ko, max9295.ko and max9296.ko
Does loadable module need to add some code in dts or dtb file?
