Hi, I tested to sensor bring-up in Xavier.
At first, For the convenience of development, I separated a few drivers into modules.
For example,
max9295 / max9296 / 2g1 sensor(our testing sensor)
So, I modified to makefile for building the modules from these.
Like this,
#obj-$(CONFIG_I2C_IOEXPANDER_DESER_MAX9296) += max9296.o
obj-m += max9296.o
#obj-$(CONFIG_I2C_IOEXPANDER_SER_MAX9295) += max9295.o
obj-m += max9295.o
After building, I did it like that in xavier.
$ sudo insmod max9296.ko
$ sudo insmod max9295.ko
$ lsmod
Module Size Used by
max9295 9593 0
max9296 14671 0
$ sudo rmmod max9296
rmmod: ERROR: Module max9296 is builtin.
So, Why is it registered as Builtin?
And, Secondly
When I register a sensor as module, which is using it used? Can I turn off this?
$sudo insmod 2g1.ko
$lsmod
Module Size Used by
2g1 19294 1
$ sudo rmmod s5k2g1
rmmod: ERROR: Module s5k2g1 is in use
I think, in the tegracam_v4l2subdev_register function, uses a sensor, is it correct?
if it correct, How should I proceed if I want to do rmod?
Thank you.
