I can’t seem to install Cuda successfully on Ubuntu on my laptop. I need it in order to properly use Dax for “data analysis at the extreme”. I’ve tried a lot of different things and done a lot of google searches on this, and nothing seems to really be working. I’ve included a summary below.
It now looks like an issue building nvidia-331-uvm, but I’ve included all relevant info below. I’ve bolded the error.
Ubuntu Version #:
chris@chris-G750JW:~$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 14.04 LTS
Release: 14.04
Codename: trusty
–From what I’ve read, this version of Ubuntu is not “officially supported” by NVidia because it’s too new, but I’ve found a posting by someone saying they got it to work. If it’s really needed, I’ll downgrade Ubuntu, but I’d have to think that leads to other problems (ie security).
Graphics Card:
GeForce GTX 765M
I tried following the instructions at How to install Nvidia drivers in Ubuntu 13.04 – method 4
…when I was advised that it may be a graphics driver issue. Seeing the Noveau card seemed to be causing issues, I followed the instructions on this web page to disable it. When these didn’t work, I allowed the installer to create nvidia-installer-disable-nouveau.conf in directory /etc/modprobe.d and then rebooted. This got the graphics driver to install finally, but it did not resolve the cuda installation issues.
chris@chris-G750JW:/etc/modprobe.d$ sudo apt-get install cuda
Reading package lists… Done
Building dependency tree
Reading state information… Done
Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
cuda : Depends: cuda-6-0 (= 6.0-37) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
chris@chris-G750JW:/etc/modprobe.d$ sudo apt-get install cuda-drivers
cuda-drivers : Depends: nvidia-331 (>= 331.62) but it is not going to be installed
Depends: nvidia-331-uvm (>= 331.62) but it is not going to be installed
Depends: nvidia-331-dev (>= 331.62) but it is not going to be installed
chris@chris-G750JW:/etc/modprobe.d$ sudo apt-get install nvidia-331-uvm
The following NEW packages will be installed:
nvidia-331-uvm
0 upgraded, 1 newly installed, 0 to remove and 157 not upgraded.
Need to get 0 B/67.2 kB of archives.
After this operation, 432 kB of additional disk space will be used.
Selecting previously unselected package nvidia-331-uvm.
(Reading database … 189570 files and directories currently installed.)
Preparing to unpack …/nvidia-331-uvm_331.67-0ubuntu1~xedgers14.04.2_amd64.deb …
Unpacking nvidia-331-uvm (331.67-0ubuntu1~xedgers14.04.2) …
Setting up nvidia-331-uvm (331.67-0ubuntu1~xedgers14.04.2) …
Loading new nvidia-331-uvm-331.67 DKMS files…
First Installation: checking all kernels…
Building only for 3.13.0-24-generic
Building for architecture x86_64
Building initial module for 3.13.0-24-generic
Error! Application of patch buildfix_kernel_3.12.patch failed. Check /var/lib/dkms/nvidia-331-uvm/331.67/build/ for more information.
I checked out that directly cited in the error above but don’t see any logs:
chris@chris-G750JW:/var/lib/dkms/nvidia-331-uvm/331.67/build$ ll -rt
total 472
-rw-r–r-- 1 root root 1566 May 16 02:23 ctrl2080mc.h
drwxr-xr-x 3 root root 4096 May 16 02:23 …/
-rw-r–r-- 1 root root 6339 May 16 02:23 uvmtypes.h
-rw-r–r-- 1 root root 1568 May 16 02:23 uvm_linux_ioctl.h
-rw-r–r-- 1 root root 7798 May 16 02:23 uvm_ioctl.h
-rw-r–r-- 1 root root 12539 May 16 02:23 uvm.h
-rw-r–r-- 1 root root 1752 May 16 02:23 uvm_gpu_ops_tests.h
-rw-r–r-- 1 root root 8829 May 16 02:23 uvm_gpu_ops_tests.c
-rw-r–r-- 1 root root 10759 May 16 02:23 uvm-debug.h
drwxr-xr-x 2 root root 4096 May 16 02:23 patches/
-rw-r–r-- 1 root root 21707 May 16 02:23 nvmisc.h
-rw-r–r-- 1 root root 5808 May 16 02:23 nvkernel.h
-rw-r–r-- 1 root root 1942 May 16 02:23 nvidia_uvm_utils.h
-rw-r–r-- 1 root root 3140 May 16 02:23 nvidia_uvm_utils.c
-rw-r–r-- 1 root root 4628 May 16 02:23 nvidia_uvm_page_cache.c
-rw-r–r-- 1 root root 12752 May 16 02:23 nvidia_uvm_lite.h
-rw-r–r-- 1 root root 2470 May 16 02:23 nvidia_uvm_lite_events.c
-rw-r–r-- 1 root root 3627 May 16 02:23 nvidia_uvm_lite_counters.h
-rw-r–r-- 1 root root 11205 May 16 02:23 nvidia_uvm_lite_counters.c
-rw-r–r-- 1 root root 83268 May 16 02:23 nvidia_uvm_lite.c
-rw-r–r-- 1 root root 14970 May 16 02:23 nvidia_uvm_lite_api.c
-rw-r–r-- 1 root root 14670 May 16 02:23 nvidia_uvm_linux.h
-rw-r–r-- 1 root root 2293 May 16 02:23 nvidia_uvm_linux.c
-rw-r–r-- 1 root root 4576 May 16 02:23 nvidia_uvm_common.h
-rw-r–r-- 1 root root 7855 May 16 02:23 nvidia_uvm_common.c
-rw-r–r-- 1 root root 2419 May 16 02:23 nvidia_page_migration_kepler.h
-rw-r–r-- 1 root root 11254 May 16 02:23 nvidia_page_migration_kepler.c
-rw-r–r-- 1 root root 9585 May 16 02:23 nvidia_page_migration.h
-rw-r–r-- 1 root root 2896 May 16 02:23 nvidia_page_migration.c
-rw-r–r-- 1 root root 6867 May 16 02:23 Makefile
-rw-r–r-- 1 root root 282 May 16 02:23 dkms.conf.fragment
-rw-r–r-- 1 root root 551 May 16 02:23 dkms.conf
-rwxr-xr-x 1 root root 78186 May 16 02:23 conftest.sh*
-rw-r–r-- 1 root root 10386 May 16 02:23 cla0b5.h
-rw-r–r-- 1 root root 1440 May 16 02:23 cla06fsubch.h
-rw-r–r-- 1 root root 4534 May 16 02:23 cla06f.h
-rw-r–r-- 1 root root 651 May 16 02:23 nvidia_uvm_linux.h.rej
-rw-r–r-- 1 root root 14670 May 16 02:23 nvidia_uvm_linux.h.orig
drwxr-xr-x 3 root root 4096 May 16 02:23 ./
