I am building a CUDA program which has some use cases of Opencv in it. I decided to use cmake for building my program.
The following is my cmake file :-
cmake_minimum_required(VERSION 3.8)
project(rgb_to_gray LANGUAGES CXX CUDA)
find_package(OpenCV 4 REQUIRED)
find_package(CUDA)
include_directories(${OpenCV_INCLUDE_DIRS})
add_library(cpu.cpp utils.cpp cpu.h utils.h)
add_executable(convert.o rgb_to_gray.cu)
target_link_libraries(convert.o ${OpenCV_LIBS})
But when I try to run it using this command :-
cmake -DCMAKE_CUDA_FLAGS="-arch=sm_60"
It throws this error :-
ERROR: No supported gcc/g++ host compiler found, but clang-8 is available.
Use 'nvcc -ccbin clang-8' to use that instead.
My CUDA version 11.2
My GPU architecture is Pascal
Compute capability 6.1
