@carolyuu so we got further, and are now seeing that the files are being found on the server. The jetson.dtb is able to be successfully retrieved, but the boot.img is failing to be retrieved mid-download (see console output below). Any idea as to what could be causing this?
[0001.301] I> Welcome to Cbootÿâmrq initialized
fmon_post initialized
ÿá
[0001.301] I> Cboot Version: t194-38d30025
[0001.302] I> CPU-BL Params @ 0xf2820000
[0001.302] I> 0) Base:0x00000000 Size:0x00000000
[0001.305] I> 1) Base:0xf1100000 Size:0x00100000
[0001.310] I> 2) Base:0xf2000000 Size:0x00200000
[0001.314] I> 3) Base:0xf1200000 Size:0x00200000
[0001.319] I> 4) Base:0xf1000000 Size:0x00100000
ÿâclk_set_parent failed for clk i2c2, parent pll_aon (-22)
clk_set_parent failed for clk i2c8, parent pll_aon (-22)
clk_dt_late initialized
machine_check initialized
pm_post initialized
dbells initialized
avfs_clk_platform_post initialized
dmce initialized
cvc initialized
ccplex_avfs_hw_init: nafll_cluster0: not monitored
ccplex_avfs_hw_init: nafll_cluster1: not monitored
ccplex_avfs_hw_init: nafll_cluster2: not monitored
ccplex_avfs_hw_init: nafll_cluster3: not monitored
avfs_clk_mach_post initialized
regulator_post initialized
rm initialized
sc7_diag initialized
thermal_test initialized
serial_late initialized
clk_post initialized
clk_dt_post initialized
mc_reg initialized
pg_post initialized
dyn_modules initialized
sku_debugfs initialized
speedo_debugfs initialized
adc_debugfs initialized
clk_debugfs initialized
ÿá[0001.323] I> 5) Base:0xf0f00000 Size:0x00100000
[0001.403] I> 6) Base:0xf3800000 Size:0x00400000
[0001.407] I> 7) Base:0xf1c00000 Size:0x00400000
[0001.412] I> 8) Base:0xf0e00000 Size:0x00100000
[0001.416] I> 9) Base:0xf0d00000 Size:0x00100000
[0001.421] I> 10) Base:0xf3000000 Size:0x00800000
[0001.425] I> 11) Base:0x40000000 Size:0x00040000
[0001.429] I> 12) Base:0xf0c00000 Size:0x00100000
[0001.434] I> 13) Base:0x40046000 Size:0x00002000
[0001.438] I> 14) Base:0x40048000 Size:0x00002000
[0001.443] I> 15) Base:0xac000000 Size:0x00004000
ÿâemc_debugfs initialized
dvs_debugfs initialized
fmon_debugfs initialized
vmon_debugfs initialized
pg_debugfs initialized
profile_fs initialized
debugfs_cons initialized
mail_fs initialized
profile initialized
cvc_debugfs initialized
dmce_debugfs initialized
ec_debugfs initialized
rm_debugfs initialized
soctherm_debug initialized
gr_reader initialized
mods initialized
dt_fs initialized
debugfs_mrq initialized
debug_mrq initialized
debug_safereg initialized
initializing target
calling apps_init()
starting app shell
entering main console loop
] ÿá[0001.447] I> 16) Base:0x4004a000 Size:0x00002000
[0001.502] I> 17) Base:0xf0b00000 Size:0x00100000
[0001.507] I> 18) Base:0x4004c000 Size:0x00002000
[0001.511] I> 19) Base:0xf2200000 Size:0x00600000
[0001.516] I> 20) Base:0x4004e000 Size:0x00002000
[0001.520] I> 21) Base:0xf0ad0000 Size:0x0000c000
[0001.524] I> 22) Base:0x00000000 Size:0x00000000
[0001.529] I> 23) Base:0xf0ae0000 Size:0x00020000
[0001.533] I> 24) Base:0xf6000000 Size:0x02000000
[0001.538] I> 25) Base:0x40050000 Size:0x00002000
[0001.542] I> 26) Base:0x40040000 Size:0x00006000
[0001.547] I> 27) Base:0xf1800000 Size:0x00400000
[0001.551] I> 28) Base:0xf4c00000 Size:0x01400000
[0001.556] I> 29) Base:0xf1400000 Size:0x00400000
[0001.560] I> 30) Base:0x00000000 Size:0x00000000
[0001.565] I> 31) Base:0x00000000 Size:0x00000000
[0001.569] I> 32) Base:0xf8000000 Size:0x08000000
[0001.574] I> 33) Base:0x00000000 Size:0x00000000
[0001.578] I> 34) Base:0xf3c00000 Size:0x01000000
[0001.582] I> 35) Base:0xab000000 Size:0x01000000
[0001.587] I> 36) Base:0xa0000000 Size:0x0b000000
[0001.591] I> 37) Base:0xf2800000 Size:0x00800000
[0001.596] I> 38) Base:0x80000000 Size:0x20000000
[0001.600] I> 39) Base:0xb0000000 Size:0x08000000
[0001.605] I> 40) Base:0x00000000 Size:0x00000000
[0001.609] I> 41) Base:0x00000000 Size:0x00000000
[0001.614] I> 42) Base:0x00000000 Size:0x00000000
[0001.618] I> 43) Base:0x00000000 Size:0x00000000
[0001.623] I> 44) Base:0x00000000 Size:0x00000000
[0001.627] I> 45) Base:0x00000000 Size:0x00000000
[0001.632] GIC-SPI Target CPU: 0
[0001.635] Interrupts Init done
[0001.637] calling constructors
[0001.640] initializing heap
[0001.643] I> Heap: [0xa069ab80 ... 0xab000000]
[0001.647] initializing threads
[0001.650] initializing timers
[0001.653] creating bootstrap completion thread
[0001.657] top of bootstrap2()
[0001.660] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0001.665] initializing platform
[0001.668] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0001.673] W> device prod register failed
[0001.677] I> Bl_dtb @0xaaf00000
[0001.683] W> "plugin-manager" doesn't exist, creating
[0001.685] W> "ids" doesn't exist, creating
[0001.689] W> "connection" doesn't exist, creating
[0001.693] W> "configs" doesn't exist, creating
[0001.706] E> failed to read label property for node 227404: 13
[0001.710] E> failed to read reg property for node 227492: 13
[0001.713] E> failed to read label property for node 227544: 13
[0001.716] E> failed to read label property for node 227612: 13
[0001.721] E> failed to read label property for node 227648: 13
[0001.727] E> failed to read label property for node 227684: 13
[0001.733] E> failed to read reg property for node 227752: 13
[0001.738] E> failed to read label property for node 227804: 13
[0001.744] I> Find /i2c@3160000's alias i2c0
[0001.747] I> Reading eeprom i2c=0 address=0x50
[0001.776] I> Device at /i2c@3160000:0x50
[0001.777] I> Reading eeprom i2c=0 address=0x56
[0001.801] I> Device at /i2c@3160000:0x56
[0001.802] I> Find /i2c@3180000's alias i2c2
[0001.802] I> Reading eeprom i2c=2 address=0x54
[0001.804] E> I2C: slave not found in slaves.
[0001.804] E> I2C: Could not write 0 bytes to slave: 0x00a8 with repeat start true.
[0001.805] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.806] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa8 at 0x00000000 via instance 2.
[0001.815] E> eeprom: Failed to read I2C slave device
[0001.820] I> Eeprom read failed 0x3526070d
[0001.824] I> Reading eeprom i2c=2 address=0x57
[0001.828] E> I2C: slave not found in slaves.
[0001.832] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
[0001.840] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.846] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 2.
[0001.855] E> eeprom: Failed to read I2C slave device
[0001.860] I> Eeprom read failed 0x3526070d
[0001.864] I> Reading eeprom i2c=2 address=0x52
[0001.868] E> I2C: slave not found in slaves.
[0001.872] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0001.880] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.886] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 2.
[0001.895] E> eeprom: Failed to read I2C slave device
[0001.900] I> Eeprom read failed 0x3526070d
[0001.905] I> Find /i2c@c240000's alias i2c1
[0001.908] I> Reading eeprom i2c=1 address=0x52
[0001.914] E> I2C: slave not found in slaves.
[0001.916] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0001.924] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.930] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 1.
[0001.939] E> eeprom: Retry to read I2C slave device.
[0001.944] E> I2C: slave not found in slaves.
[0001.948] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0001.956] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.962] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 1.
[0001.971] E> eeprom: Failed to read I2C slave device
[0001.976] I> Eeprom read failed 0x3526070d
[0001.980] I> Reading eeprom i2c=1 address=0x50
[0001.984] E> I2C: slave not found in slaves.
[0001.988] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.996] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.002] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0002.011] E> eeprom: Retry to read I2C slave device.
[0002.016] E> I2C: slave not found in slaves.
[0002.020] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0002.028] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.034] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0002.043] E> eeprom: Failed to read I2C slave device
[0002.048] I> Eeprom read failed 0x3526070d
[0002.052] I> create_pm_ids: id: 2888-0004-400-L, len: 15
[0002.057] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0002.068] I> create_pm_ids: id: 2822-0000-700-K, len: 15
[0002.073] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0002.084] I> Adding plugin-manager/ids/2888-0004-400=/i2c@3160000:module@0x50
[0002.092] W> "i2c@3160000" doesn't exist, creating
[0002.096] W> "module@0x50" doesn't exist, creating
[0002.101] I> Adding plugin-manager/ids/2822-0000-700=/i2c@3160000:module@0x56
[0002.108] W> "module@0x56" doesn't exist, creating
[0002.114] I> Adding plugin-manager/cvm
[0002.116] W> "chip-id" doesn't exist, creating
[0002.120] I> Adding plugin-manager/chip-id/A02P
[0002.125] I> Plugin-manager override starting
[0002.129] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0002.137] I> node /plugin-manager/fragement-soft-wdt matches
[0002.146] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0002.150] I> node /plugin-manager/fragment-tegra-ufs-lane10 matches
[0002.164] I> Disable plugin-manager status in FDT
[0002.164] I> Plugin-manager override finished successfully
[0002.165] I> gpio framework initialized
[0002.166] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0002.174] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0002.180] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0002.188] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0002.196] W> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0002.202] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.208] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0002.216] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0002.223] W> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0002.230] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.237] I> fixed regulator driver initialized
[0002.251] I> register 'maxim' power off handle
[0002.252] I> virtual i2c enabled
[0002.253] I> registered 'maxim,max20024' pmic
[0002.253] I> tegrabl_gpio_driver_register: register 'max20024-gpio' driver
[0002.259] I> Boot-device: eMMC
[0002.261] I> Boot_device: SDMMC_BOOT instance: 3
[0002.270] I> sdmmc-3 params source = boot args
[0002.270] I> create_pm_ids: id: 2888-0004-400-L, len: 15
[0002.275] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0002.286] I> create_pm_ids: id: 2822-0000-700-K, len: 15
[0002.292] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0002.303] I> sdmmc bdev is already initialized
[0002.307] I> sdmmc-3 params source = boot args
[0002.338] I> Found 17 partitions in SDMMC_BOOT (instance 3)
[0002.350] I> Found 42 partitions in SDMMC_USER (instance 3)
[0002.359] I> enabling 'vdd-hdmi-5v0' regulator
[0002.364] I> regulator 'vdd-hdmi-5v0' already enabled
[0002.364] E> tegrabl_display_init_regulator: hdmi cable is not connected
[0002.365] E> tegrabl_display_get_pdata, failed to parse dtb settings
[0002.368] E> invalid display type
[0002.372] E> invalid display type
[0002.373] E> cannot find any other nvdisp nodes
[0002.373] E> no valid display unit config found in dtb
[0002.375] W> display init failed
[0002.375] I> Load in CBoot Boot Options partition and parse it
[0002.387] I> boot-order :-
[0002.387] I> 1.net
[0002.387] I> tftp-server-ip: 192.168.1.1
[0002.389] W> parse_ip_info: static-ip info is not required, only tftp-server-ip is required.
[0002.397] W> Failed to parse GUID
[0002.400] I> boot-dev-order :-
[0002.403] I> 1.net
[0002.405] I> Hit any key to stop autoboot: 4 3 2 1
[0004.413] initializing target
[0004.413] calling apps_init()
[0004.414] starting app kernel_boot_app
[0004.433] I> found decompressor handler: lz4-legacy
[0004.434] I> decompressing BMP blob ...
[0004.445] I> Kernel type = Normal
[0004.445] I> ########## Net boot ##########
[0004.445] I> EQoS: Init
[0006.448] I> Wait till auto-calibration completes...
[0006.449] I> Configuring PHY
[0006.509] I> Start auto-negotiation
[0006.510] I> Wait till it completes...
[0009.511] I> MAC addr 48:b0:2d:2b:76:63
[0009.511] I> DHCP: Init: Requesting IP ...
[0009.511] I> netif status changed 0.0.0.0
[0009.516] I> netif status changed 192.168.1.2
[0010.012] I> Our IP: 192.168.1.2
[0010.012] TFTP Client: Init
[0010.012] TFTP Client: Server IP: 192.168.1.1
[0010.012] TFTP Client: Send RRQ, file: jetson.dtb
[0010.224] TFTP Client: Last packet received
[0010.225] TFTP Client: Send RRQ, file: boot.img
######[0061.553] E> Failed to get boot.img
[0061.554] I> netif status changed 192.168.1.2
[0061.554] E> Net boot failed, err: 724239618
