I didn’t receive a certification after completing the course.
Is there anything I could do in DLI to make it issue?
Hello. To which course are you referring? Of all the courses you have unlocked, only Building RAG Agents with LLMs and Rapid Application Development with LLMs offer certificates of completion. And in both of those case you have not yet opened the lab environment that contains the assessment. If you are seeking the certificate of completion for those two courses, be sure to work through the labs and complete the coding challenge in the assessment. Then the certificate will automatically generate.
Hello. I am very sorry, but what is written there is a mistake. This course does not generate a certificate of competency, even after answering those questions. We will remove the incorrect wording. I truly apologize for the inconvenience.
It’s completely fine. I only made this post because I saw another post who had the same issue. I thought it was an issue with the course itself.
the course I am talking about: Evaluation and Light Customization of Large Language Models - do not see the Certificate
