I want to change both DP1_AUX_P and DP1_AUX_N form Bidirectional to Open-Drain. But when I compared the output dtsi file, I found that there was no changes from before the modification.
Please help me.
Does this matter to any usecase?
On our custom board, the level shifter circuit is open-drain.
Do you mean HDMI design? Just keep default setting, no need to change to OD.
Thanks, but our custom board have been made some samples. Is there a way to change to OD?
As said, no need to change to OD in pinmux as it default support I2C mode.
