Hello! Sry I haven’t replied since then. I’ve been away. Next time the crash happens I’ll make sure to capture the output of the console in which I ran the kwin command.
Also when I first run the command these are the lines that I get:
kwin_x11 --replace
QPainter::begin: Paint device returned engine == 0, type: 3
QPainter::setRenderHint: Painter must be active to set rendering hints
QPainter::setWindow: Painter not active
QPainter::setClipRect: Painter not active
QPainter::save: Painter not active
QPainter::setPen: Painter not active
QPainter::setBrush: Painter not active
QPainter::drawRects: Painter not active
QPainter::restore: Unbalanced save/restore
OpenGL vendor string: NVIDIA Corporation
OpenGL renderer string: GeForce GTX 770/PCIe/SSE2
OpenGL version string: 3.1.0 NVIDIA 396.51
OpenGL shading language version string: 1.40 NVIDIA via Cg compiler
Driver: NVIDIA
Driver version: 396.51
GPU class: Unknown
OpenGL version: 3.1
GLSL version: 1.40
X server version: 1.19.6
Linux kernel version: 4.15
Requires strict binding: no
GLSL shaders: yes
Texture NPOT support: yes
Virtual Machine: no
kf5.kcoreaddons.desktopparser: Property type "Url" is not a known QVariant type. Found while parsing property definition for "X-KWin-Video-Url" in "/usr/share/kservicetypes5/kwineffect.desktop"
qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 5428, resource id: 0, major code: 14 (GetGeometry), minor code: 0
qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 5438, resource id: 0, major code: 14 (GetGeometry), minor code: 0
qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 5440, resource id: 0, major code: 14 (GetGeometry), minor code: 0
qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 5441, resource id: 0, major code: 14 (GetGeometry), minor code: 0
qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 5442, resource id: 0, major code: 14 (GetGeometry), minor code: 0
qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 5443, resource id: 0, major code: 14 (GetGeometry), minor code: 0
qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 5444, resource id: 0, major code: 14 (GetGeometry), minor code: 0
qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 5574, resource id: 123732073, major code: 3 (GetWindowAttributes), minor code: 0
