Chronological AI Memory: Same Data, Different Order, Different Decision
Most AI memory systems retrieve information by similarity.
But similarity is not the same as sequence.
The same facts presented in a different order can produce a different interpretation, a different risk assessment, and a different decision.
That matters in:
  • autonomous systems
  • legal and investigative reasoning
  • cybersecurity
  • financial markets
  • robotics
  • long-running AI agents
I have been developing the Analog Recall Engine, or ARE, as an external chronological memory layer for AI systems.
The core principle is simple:
Preserve what happened, in the order it happened, before reducing events to semantic categories.
ARE keeps the historical record outside the language model. The model may reason through that record, but it does not own or silently rewrite it.
A recent Termux benchmark of the deterministic SQLite/HMAC branch produced:
  • 50,000 capsules: recall p99 0.160 ms
  • 200,000 capsules: recall p99 0.234 ms
  • 1,000,000 capsules: recall p99 0.182 ms
  • end-to-end recall plus integrity verification remained below 0.7 ms p99 across all three scale tests
  • mutated payload verification failed as intended: TAMPER DETECTED
The broader architectural question is this:
What changes when AI memory is treated not as a bag of semantically similar facts, but as a navigable path through time?
My current working thesis is:
ARE preserves where the system has been.
A directional orientation layer can determine where the system is now.
A recognition layer can detect when the current trajectory resembles a prior one.
A forward evaluation layer can test where the trajectory may lead.
I would value serious technical criticism from NVIDIA engineers working in NeMo, agentic systems, edge AI, robotics, and governed inference.
The original ARE implementation is deliberately small. Every attempt to “improve” it by pushing semantic interpretation into the memory core has weakened the behavior that makes it useful.
The question is not whether the code is large.
The question is whether chronology itself should be treated as a first-class computational structure for AI cognition.
Hi @Steve — this is a genuinely interesting framing. I think the key distinction is that similarity-based retrieval is a **compression** of history, and compression always loses information. Chronology is one of the things that gets lost first.
A few thoughts on where this fits in the NVIDIA ecosystem:
**1. NeMo Retriever is similarity-first today**
Current NeMo Retriever / NIM embedding models are built around semantic similarity. They’re great for “find me docs like this” but not naturally good at “what happened right before this event.” Your chronological layer would sit *under* or *beside* the retriever, not replace it.
**2. A practical architecture**
Something like this is feasible:
Chronological store (your ARE) → time-ordered event log with HMAC integrity
NeMo Retriever / embedding NIM → semantic index over the same events
Reasoning layer (Nemotron / LLM NIM) → consumes both temporal context and semantic matches
The LLM prompt would then contain two context blocks: “here are the semantically relevant facts” and “here is the timeline around those facts.” That addresses ordering without forcing the memory core to become semantic.
**3. Where it matters most for NVIDIA users**
- **Robotics / autonomous systems:** temporal coherence is safety-critical.
- **Cybersecurity / SOC:** attack chains are sequences, not bags of indicators.
- **Financial compliance:** transactions and decisions have strict ordering.
- **Long-running agents:** without a timeline, an agent can reason itself into contradictions.
**4. The hard part you didn’t mention**
Compression vs. navigation is the real tradeoff. A pure timeline with a million capsules is expensive to feed into an LLM context window. You’ll eventually need some form of summarization or hierarchical timeline, and *that* is where chronology can get corrupted. Keeping the raw timeline immutable and building derived views on top is probably the right separation.
Your p99 recall numbers are impressive for SQLite/HMAC. Have you benchmarked retrieval when the query is temporal rather than semantic — e.g., “what happened between event X and event Y”? That’s the query pattern I’d want to see before declaring chronology a first-class structure.
