I’m having an issue where cicc is generating a flood of warnings I neither want nor need, and I can’t seem to be able to disable them. I do not want to disable warnings across the board, but I really would like a way to make this particular one be silent.
In my real code I’m getting pages of a particular warning so it’s not something I can easily ignore, but I trimmed things down to a minimal working example to demonstrate my issue:
namespace {
template <int N>
struct Foo {
__device__ __host__ void A() {}
__device__ __host__ void B() {}
__device__ __host__ void C() {}
__global__ void dummy()
Foo<1> one;
one.A();
one.B();
one.C();
Foo<2> two;
two.A();
int main()
Foo<1> one;
one.A();
one.B();
one.C();
Foo<2> two;
two.B();
dummy<<<1,1>>>();
If I compile this code I get the warning: function “::Foo::C [with N=2]” was declared but never referenced.
The class Foo has three functions all marked both host and device so that I could show that using the function either on the host or on the device (but not necessarily both) is enough to avoid the warning on a function.
From what I can tell these are the important bits:
I know that you can pass arguments to the backend compiler directly, but using “-Xcompiler -Wno-unused-function” does not fix the issue. If I run nvcc with verbose output it seems that cicc itself is issuing this warning.
nvcc tmp.cu -Xcompiler -Wno-unused-function --verbose
#$ _SPACE_=
#$ _CUDART_=cudart
#$ _HERE_=/usr/local/cuda/bin
#$ _THERE_=/usr/local/cuda/bin
#$ _TARGET_SIZE_=
#$ _TARGET_DIR_=
#$ _TARGET_SIZE_=64
#$ TOP=/usr/local/cuda/bin/..
#$ NVVMIR_LIBRARY_DIR=/usr/local/cuda/bin/../nvvm/libdevice
#$ LD_LIBRARY_PATH=/usr/local/cuda/bin/../lib:/opt/rh/llvm-toolset-7/root/usr/lib64:/opt/rh/devtoolset-6/root/usr/lib64:/opt/rh/devtoolset-6/root/usr/lib
#$ PATH=/usr/local/cuda/bin/../nvvm/bin:/usr/local/cuda/bin:/home/UNIXHOME/bbyington/.local/bin:/home/UNIXHOME/bbyington/bin:/home/UNIXHOME/bbyington/bin/bin:/home/UNIXHOME/bbyington/rtags/bin:/home/UNIXHOME/bbyington/emacs/bin/:/home/UNIXHOME/bbyington/rtags/bin:/home/UNIXHOME/bbyington/emacs/bin/:/home/UNIXHOME/bbyington/.local/bin:/home/UNIXHOME/bbyington/bin:/home/UNIXHOME/bbyington/bin/bin:/home/UNIXHOME/bbyington/rtags/bin:/home/UNIXHOME/bbyington/emacs/bin/:/opt/rh/llvm-toolset-7/root/usr/bin:/opt/rh/llvm-toolset-7/root/usr/sbin:/opt/rh/devtoolset-6/root/usr/bin:/usr/lib64/qt-3.3/bin:/usr/local/bin:/usr/local/sbin:/usr/bin:/usr/sbin:/bin:/sbin:/usr/local/cuda/bin:/usr/local/cuda/bin:/usr/local/cuda/bin:/usr/local/cuda/bin:/usr/local/cuda/bin
#$ INCLUDES="-I/usr/local/cuda/bin/..//include"
#$ LIBRARIES= "-L/usr/local/cuda/bin/..//lib64/stubs" "-L/usr/local/cuda/bin/..//lib64"
#$ CUDAFE_FLAGS=
#$ PTXAS_FLAGS=
#$ gcc -std=c++14 -D__CUDA_ARCH__=300 -E -x c++ -DCUDA_DOUBLE_MATH_FUNCTIONS -D__CUDACC__ -D__NVCC__ -Wno-unused-function "-I/usr/local/cuda/bin/..//include" -D__CUDACC_VER_MAJOR__=10 -D__CUDACC_VER_MINOR__=0 -D__CUDACC_VER_BUILD__=130 -include "cuda_runtime.h" -m64 "tmp.cu" > "/tmp/tmpxft_00007b20_00000000-8_tmp.cpp1.ii"
#$ cicc --c++14 --gnu_version=60301 --allow_managed -arch compute_30 -m64 -ftz=0 -prec_div=1 -prec_sqrt=1 -fmad=1 --include_file_name "tmpxft_00007b20_00000000-2_tmp.fatbin.c" -tused -nvvmir-library "/usr/local/cuda/bin/../nvvm/libdevice/libdevice.10.bc" --gen_module_id_file --module_id_file_name "/tmp/tmpxft_00007b20_00000000-3_tmp.module_id" --orig_src_file_name "tmp.cu" --gen_c_file_name "/tmp/tmpxft_00007b20_00000000-5_tmp.cudafe1.c" --stub_file_name "/tmp/tmpxft_00007b20_00000000-5_tmp.cudafe1.stub.c" --gen_device_file_name "/tmp/tmpxft_00007b20_00000000-5_tmp.cudafe1.gpu" "/tmp/tmpxft_00007b20_00000000-8_tmp.cpp1.ii" -o "/tmp/tmpxft_00007b20_00000000-5_tmp.ptx"
tmp.cu(7): warning: function "<unnamed>::Foo<N>::C [with N=2]" was declared but never referenced
#$ ptxas -arch=sm_30 -m64 "/tmp/tmpxft_00007b20_00000000-5_tmp.ptx" -o "/tmp/tmpxft_00007b20_00000000-9_tmp.sm_30.cubin"
#$ fatbinary --create="/tmp/tmpxft_00007b20_00000000-2_tmp.fatbin" -64 "--image=profile=sm_30,file=/tmp/tmpxft_00007b20_00000000-9_tmp.sm_30.cubin" "--image=profile=compute_30,file=/tmp/tmpxft_00007b20_00000000-5_tmp.ptx" --embedded-fatbin="/tmp/tmpxft_00007b20_00000000-2_tmp.fatbin.c" --cuda
#$ rm /tmp/tmpxft_00007b20_00000000-2_tmp.fatbin
#$ gcc -std=c++14 -E -x c++ -D__CUDACC__ -D__NVCC__ -Wno-unused-function "-I/usr/local/cuda/bin/..//include" -D__CUDACC_VER_MAJOR__=10 -D__CUDACC_VER_MINOR__=0 -D__CUDACC_VER_BUILD__=130 -include "cuda_runtime.h" -m64 "tmp.cu" > "/tmp/tmpxft_00007b20_00000000-4_tmp.cpp4.ii"
#$ cudafe++ --c++14 --gnu_version=60301 --allow_managed --m64 --parse_templates --gen_c_file_name "/tmp/tmpxft_00007b20_00000000-5_tmp.cudafe1.cpp" --stub_file_name "tmpxft_00007b20_00000000-5_tmp.cudafe1.stub.c" --module_id_file_name "/tmp/tmpxft_00007b20_00000000-3_tmp.module_id" "/tmp/tmpxft_00007b20_00000000-4_tmp.cpp4.ii"
#$ gcc -std=c++14 -D__CUDA_ARCH__=300 -c -x c++ -DCUDA_DOUBLE_MATH_FUNCTIONS -Wno-unused-function "-I/usr/local/cuda/bin/..//include" -m64 -o "/tmp/tmpxft_00007b20_00000000-10_tmp.o" "/tmp/tmpxft_00007b20_00000000-5_tmp.cudafe1.cpp"
#$ nvlink --arch=sm_30 --register-link-binaries="/tmp/tmpxft_00007b20_00000000-6_a_dlink.reg.c" -m64 "-L/usr/local/cuda/bin/..//lib64/stubs" "-L/usr/local/cuda/bin/..//lib64" -cpu-arch=X86_64 "/tmp/tmpxft_00007b20_00000000-10_tmp.o" -o "/tmp/tmpxft_00007b20_00000000-11_a_dlink.sm_30.cubin"
#$ fatbinary --create="/tmp/tmpxft_00007b20_00000000-7_a_dlink.fatbin" -64 -link "--image=profile=sm_30,file=/tmp/tmpxft_00007b20_00000000-11_a_dlink.sm_30.cubin" --embedded-fatbin="/tmp/tmpxft_00007b20_00000000-7_a_dlink.fatbin.c"
#$ rm /tmp/tmpxft_00007b20_00000000-7_a_dlink.fatbin
#$ gcc -std=c++14 -c -x c++ -DFATBINFILE="\"/tmp/tmpxft_00007b20_00000000-7_a_dlink.fatbin.c\"" -DREGISTERLINKBINARYFILE="\"/tmp/tmpxft_00007b20_00000000-6_a_dlink.reg.c\"" -I. -D__NV_EXTRA_INITIALIZATION= -D__NV_EXTRA_FINALIZATION= -D__CUDA_INCLUDE_COMPILER_INTERNAL_HEADERS__ -Wno-unused-function "-I/usr/local/cuda/bin/..//include" -D__CUDACC_VER_MAJOR__=10 -D__CUDACC_VER_MINOR__=0 -D__CUDACC_VER_BUILD__=130 -m64 -o "/tmp/tmpxft_00007b20_00000000-12_a_dlink.o" "/usr/local/cuda/bin/crt/link.stub"
#$ g++ -Wno-unused-function -m64 -o "a.out" -std=c++14 -Wl,--start-group "/tmp/tmpxft_00007b20_00000000-12_a_dlink.o" "/tmp/tmpxft_00007b20_00000000-10_tmp.o" "-L/usr/local/cuda/bin/..//lib64/stubs" "-L/usr/local/cuda/bin/..//lib64" -lcudadevrt -lcudart_static -lrt -lpthread -ldl -Wl,--end-group
