is it possible to clone (make a backup image) a Xavier with the latest Jetpack?
The flash.sh wasn´t working in the older version.
If it is still not possible, are there plans to be available in future?
Thank you very much
Thank you very much
Hi jonny21,
A workaround is to modify the flash script as below patch.
diff --git a/flash.sh b/flash.sh
index 5242a68..d21d7ca 100755
--- a/flash.sh
+++ b/flash.sh
@@ -2049,7 +2049,7 @@ if [ "${target_partname}" != "" ]; then
else
FLASHARGS+="$BCT ${bctfilename} ";
fi
- FLASHARGS+="${BCTARGS} ";
+ FLASHARGS+="${BCTARGS}${NV_ARGS} ";
FLASHARGS+="--cfg ${localcfgfile} ${BINSARGS} ";
FLASHARGS+=" --cmd \"";
FLASHARGS+="${pre_cmds}";
Were both Xaviers flashed with the same release prior to putting the clone from one into the other? FYI, release versions have to match.
