good day, I have set up cloud xr using the unity plugin and im able to stream. But the meta quest 2 controller buttons are not mapped correctly. Can I get some guidance on this?
This is how the controllers are behaving right now:
Right controller: Press Trigger → “A” button detected
Analog joystick → Trigger (select)
Left controller: Joystick touch → Trigger (select)
Joystick movement → Trigger (Press)
Interestingly, the sample app from “Windows Mixed Reality OpenXR runtime” seems to be working much better. But any other app (unity or usd composer) is showing above behaviour
Attaching the latest log files if that is useful for you
CloudXR Server - SteamVR Log 2024-12-05 16.49.44.txt (2.0 MB)
CloudXR Server - SteamVR Log 2024-12-05 16.49.40.txt (981 Bytes)
Streamer Server Log 2024-12-05 16.49.48.txt (465.2 KB)
