Cmake compile ". cpp" as "cu"
Is it possible compile “.cpp” as “.cu” in modern cmake(3.10~)
my project structure
  • non cuda code that uses kernel code(.cpp) with runtime api
  • cuda code library(.cpp)
and cmake script
enable_language(CUDA)
set(CMAKE_CUDA_FLAGS_DEBUG "-g -G")
add_library(CUDA_KERNELS OBJECT ${GPU_KERNELS})
set_property(TARGET CUDA_KERNELS PROPERTY CUDA_PTX_COMPILATION ON)
The cmake script was originally like above, and the things I tried to compile .cpp as .cu are as follows.
 set_source_files_properties(CUDA_KERNELS LANGUAGE CUDA)
 set(CMAKE_CUDA_FLAGS  "-x cu")
set(CMAKE_CXX_EXTENSIONS OFF)
none of them works, it is not handled as cuda code.
If I change .cpp to .cu, it works well obviously
what is the correct way to compile .cpp as .cu files ?
Try this?
set_source_files_properties(test.cpp PROPERTIES LANGUAGE CUDA)
