Hi, all:
I attempted to port RT5616 to Orin Nano and modified the following files:
tegra234-soc-i2c.dtsi.txt (8.5 KB)
tegra234-p3767-common-audio.dtsi.log (7.9 KB)
tegra234-soc-audio.dtsi.log (27.6 KB)
rt5616.c.log (41.1 KB)
But there is currently no sound output, the following is the debugging information:
dmesg.log (66.4 KB)
root@ubuntu:/home/via# cat /proc/asound/cards
0 [SafetyI2Ssoun ]: -1 [HDA ]: tegra-hda - NVIDIA Jetson Orin NX HDA
NVIDIA Jetson Orin NX HDA at 0x3518000 irq 112
2 [APE ]: tegra-ape - NVIDIA Jetson Orin nano APE
root@ubuntu:/home/via# amixer -c2 cset name=“I2S2 Mux” “ADMAIF2”
numid=1288,iface=MIXER,name=‘I2S2 Mux’
; type=ENUMERATED,access=rw------,values=1,items=81
; Item #0 ‘None’
; Item #1 ‘ADMAIF1’
; Item #2 ‘ADMAIF2’
; Item #3 ‘ADMAIF3’
; Item #4 ‘ADMAIF4’
; Item #5 ‘ADMAIF5’
; Item #6 ‘ADMAIF6’
; Item #7 ‘ADMAIF7’
; Item #8 ‘ADMAIF8’
; Item #9 ‘ADMAIF9’
; Item #10 ‘ADMAIF10’
; Item #11 ‘ADMAIF11’
; Item #12 ‘ADMAIF12’
; Item #13 ‘ADMAIF13’
; Item #14 ‘ADMAIF14’
; Item #15 ‘ADMAIF15’
; Item #16 ‘ADMAIF16’
; Item #17 ‘I2S1’
; Item #18 ‘I2S2’
; Item #19 ‘I2S3’
; Item #20 ‘I2S4’
; Item #21 ‘I2S5’
; Item #22 ‘I2S6’
; Item #23 ‘SFC1’
; Item #24 ‘SFC2’
; Item #25 ‘SFC3’
; Item #26 ‘SFC4’
; Item #27 ‘MIXER1 TX1’
; Item #28 ‘MIXER1 TX2’
; Item #29 ‘MIXER1 TX3’
; Item #30 ‘MIXER1 TX4’
; Item #31 ‘MIXER1 TX5’
; Item #32 ‘AMX1’
; Item #33 ‘AMX2’
; Item #34 ‘AMX3’
; Item #35 ‘AMX4’
; Item #36 ‘ARAD1’
; Item #37 ‘AFC1’
; Item #38 ‘AFC2’
; Item #39 ‘AFC3’
; Item #40 ‘AFC4’
; Item #41 ‘AFC5’
; Item #42 ‘AFC6’
; Item #43 ‘OPE1’
; Item #44 ‘SPKPROT1’
; Item #45 ‘MVC1’
; Item #46 ‘MVC2’
; Item #47 ‘IQC1-1’
; Item #48 ‘IQC1-2’
; Item #49 ‘IQC2-1’
; Item #50 ‘IQC2-2’
; Item #51 ‘DMIC1’
; Item #52 ‘DMIC2’
; Item #53 ‘DMIC3’
; Item #54 ‘DMIC4’
; Item #55 ‘ADX1 TX1’
; Item #56 ‘ADX1 TX2’
; Item #57 ‘ADX1 TX3’
; Item #58 ‘ADX1 TX4’
; Item #59 ‘ADX2 TX1’
; Item #60 ‘ADX2 TX2’
; Item #61 ‘ADX2 TX3’
; Item #62 ‘ADX2 TX4’
; Item #63 ‘ADX3 TX1’
; Item #64 ‘ADX3 TX2’
; Item #65 ‘ADX3 TX3’
; Item #66 ‘ADX3 TX4’
; Item #67 ‘ADX4 TX1’
; Item #68 ‘ADX4 TX2’
; Item #69 ‘ADX4 TX3’
; Item #70 ‘ADX4 TX4’
; Item #71 ‘ADMAIF17’
; Item #72 ‘ADMAIF18’
; Item #73 ‘ADMAIF19’
; Item #74 ‘ADMAIF20’
; Item #75 ‘ASRC1 TX1’
; Item #76 ‘ASRC1 TX2’
; Item #77 ‘ASRC1 TX3’
; Item #78 ‘ASRC1 TX4’
; Item #79 ‘ASRC1 TX5’
; Item #80 ‘ASRC1 TX6’
: values=2
root@ubuntu:/home/via# amixer -c2 cset name=‘DAC MIXL INF1 Switch’ 1
numid=1496,iface=MIXER,name=‘DAC MIXL INF1 Switch’
; type=BOOLEAN,access=rw------,values=1
: values=on
root@ubuntu:/home/via# amixer -c2 cset name=‘DAC MIXR INF1 Switch’ 1
numid=1498,iface=MIXER,name=‘DAC MIXR INF1 Switch’
: values=on
root@ubuntu:/home/via# amixer -c2 cset name=‘Stereo DAC MIXL DAC L1 Switch’ 1
numid=1499,iface=MIXER,name=‘Stereo DAC MIXL DAC L1 Switch’
: values=on
root@ubuntu:/home/via# amixer -c2 cset name=‘Stereo DAC MIXR DAC R1 Switch’ 1
numid=1501,iface=MIXER,name=‘Stereo DAC MIXR DAC R1 Switch’
: values=on
root@ubuntu:/home/via# amixer -c2 cset name=‘HPO MIX DAC1 Switch’ 1
numid=1513,iface=MIXER,name=‘HPO MIX DAC1 Switch’
: values=on
root@ubuntu:/home/via# amixer -c2 cset name=‘HP Playback Volume’ 39
numid=439,iface=MIXER,name=‘HP Playback Volume’
; type=INTEGER,access=rw—R–,values=2,min=0,max=39,step=0
: values=39,39
| dBscale-min=-46.50dB,step=1.50dB,mute=0
root@ubuntu:/home/via# for i infind /sys/kernel/debug/tracing/events -name "enable" | grep snd_soc_
; do echo 1 > $i; done
root@ubuntu:/home/via# speaker-test -D hw:APE,0 -r 48000 -c 1 -F S32_LE -t sine -f 1000speaker-test 1.2.2
Playback device is hw:APE,0
Stream parameters are 48000Hz, S32_LE, 1 channels
Sine wave rate is 1000.0000Hz
Rate set to 48000Hz (requested 48000Hz)
Buffer size range from 32 to 8192
Period size range from 32 to 4096
Using max buffer size 8192
Periods = 4
was set period_size = 2048
was set buffer_size = 8192
0 - Front Left
Time per period = 0.053792
0 - Front Left
Time per period = 0.056115
0 - Front Left
Time per period = 0.056112
0 - Front Left
Time per period = 0.055949
0 - Front Left
Time per period = 0.056139
0 - Front Left
Time per period = 0.056126
0 - Front Left
Time per period = 0.056145
0 - Front Left
Time per period = 0.056322
0 - Front Left
Time per period = 0.056137
0 - Front Left
0 - Front Left
Time per period = 0.056142
0 - Front Left
0 - Front Left
Time per period = 0.056143
0 - Front Left
Time per period = 0.056147
0 - Front Left
0 - Front Left
Time per period = 0.056122
0 - Front Left
0 - Front Left
Time per period = 0.056141
0 - Front Left
Time per period = 0.056133
0 - Front Left
0 - Front Left
^CTime per period = 0.055437
root@ubuntu:/home/via# cat /sys/kernel/debug/tracing/trace_pipe | grep *
speaker-test-2452 [001] … 237.292432: snd_soc_dapm_path: *ADMAIF1 XBAR-Playback ← (direct) ← tegra-dlink-44-playback
speaker-test-2452 [001] … 237.292434: snd_soc_dapm_path: *ADMAIF1 XBAR-Playback ← (direct) ← ADMAIF1 Playback
