In my system, I have two nodes CPU1 and CPU2 and each
node has two GPU cards.
CPU1 has GPU_A1 and GPU_B1
CPU2 has GPU_A2 and GPU_B2
I know that GPU_A1 and GPU_B1 can direct access each other
via CudaMemCpyPeer function. I want to know that if it is
possible that GPU_A1 can direct access GPU_A2 or GPU_B2
or not ?
I use PGI community edition 16.10 with its built-in OpenMPI 1.10
I refer to the following slides (In page 13)
http://twin.iac.rm.cnr.it/Multi_GPU_Programming_with_MPI.pdf
It uses MPI_Send and MPI_Recv function to send the array in GPU
to other GPU. But it does not work. Is there anyone can tell me how to do it ?
Thank you very much.
Neo
