So I just played around with it, and I believe if you have explicit OpenACC in your code, “-stdpar=gpu” and “-acc=gpu” will lead to that being parsed. However, do concurrent clauses appear to only get parsed by “-stdpar=gpu” - though your example would lead one to believe that if you mix the two “-stdpar=gpu -acc=gpu”, then some things that are only allowed in openacc clauses can get handled in do concurrent structures. Something odd is definitely going on. If you can carve out a more clean example where it occurs, that’d be helpful.
With regards to the procedure - I think it’s complicated. It doesn’t want to handle generic procedures, for example - this fails with that compilation error:
module profile_def
implicit none
type :: profile
logical :: active = .false.
real :: f(3) = 1.0
real :: x(2) = (/ -1.0e20, 1.0e20 /)
real :: w(2) = 1.0
end type profile
type :: heat_source
real :: h0 = 0.0
type(profile) :: r_profile
end type heat_source
end module profile_def
module profile_value_interface
use profile_def, only : profile
implicit none
interface
pure function profile_value(prof, x) result(v)
import :: profile
type(profile), intent(in) :: prof
real, intent(in) :: x
real :: v
end function profile_value
end interface
end module profile_value_interface
module heating_mod
use profile_def, only : heat_source
use profile_value_interface,only : profile_value
implicit none
private
public :: heating
contains
subroutine heating
integer, parameter :: n = 16
type(heat_source) :: heatsource(1)
real :: rh_true(n)
real :: rprof(n)
integer :: i
rh_true = [(real(i), i=1,n)]
! The call below is the trigger: procedure call inside DO CONCURRENT
do concurrent (i = 1:n)
rprof(i) = profile_value(heatsource(1)%r_profile, rh_true(i))
end do
end subroutine heating
end module heating_mod
I think because the profile_value is in a different compilation unit (module), whereas this is handled okay since they’re all together and presumably the function can be inlined:
module repro_do_concurrent_proc_call
implicit none
private
public :: heating
! Minimal "profile" type
type :: profile
real :: f(3) = 1.0
real :: w(2) = 1.0
end type profile
! Minimal heat_source type, with a profile component
type :: heat_source
real :: h0 = 0.0
integer, parameter :: max_heat_sources = 2
contains
! PURE procedure being called inside DO CONCURRENT
pure function profile_value(prof, x) result(val)
real :: val
if (.not. prof%active) then
val = 1.0
else
! Any simple expression is fine; keep it trivial.
val = prof%f(1) + x*0.0
end if
! Subroutine that triggers the diagnostic at compile time
subroutine heating
type(heat_source) :: heatsource(max_heat_sources)
real :: rh_true(4)
real :: rprof
integer :: i, n
rh_true = (/ 1.0, 2.0, 3.0, 4.0 /)
! Key pattern: procedure call inside DO CONCURRENT
do concurrent (i = 1:4)
n = 1
rprof = profile_value(heatsource(n)%r_profile, rh_true(i))
end do
end module repro_do_concurrent_proc_call
Compiling:
[scamp]$ nvfortran compiles.F90 -c -stdpar=gpu
[scamp]$ nvfortran crashes.F90 -c -stdpar=gpu
NVFORTRAN-S-1074-Procedure call in Do Concurrent is not supported yet (crashes.F90: 63)
0 inform, 0 warnings, 1 severes, 0 fatal for heating
[scamp]$
Note that in this case, adding “-acc=gpu” doesn’t appear to resolve the issue, so that highlights we may need a better example for that particular case. If you can carve it out, we can analyze it and try to help.
