I wrote a quite complex kernel, that compiles and runs fine on AMD OpenCL platform, but for some reason crashes NVIDIA’s compiler on my notebook systematically.
My notebook has a GT 330M graphic card and runs under Windows 7 64 bits. I have installed the latest beta version of the driver, version 260.63 (OpenCL 1.0).
I have done my best to simplify the kernel at maximum. The following kernel code does nothing interesting anymore ;) but still crashes when I try to compile it.
Removing any of the instruction make the compiler happy again. I personally do not see any reason for this code to crash.
__kernel void crashes()
short4 y;
while(1)
short4 x = convert_short4(0);
x = x >= x;
convert_char4(x);
x &= (short4)(0xFF0);
y = x + y;
I also tried this code on two other computers with GTX 260 and 280 cards, under Windows XP 32 bits and the same driver version.
The problem does not show there.
I have a similar problem: Simple OpenCL-kernels always crashes in clBuildProgram (with CL_Program_Build_Failure).
First I thought, there is a problem with the SDK examples (as reported here http://forums.nvidia.com/index.php?showtop…=#entry1121775), but I have the same problem with my own kernels.
Could it be, that this is a driver bug?
I use driver version 259.03 for Win 7, 64-bit (TCC).
