PGF90-F-0155-Compiler failed to translate accelerator region (see -Minfo messages): Unexpected runtime function call (rhs.cuf: 1)
Everything was running fine until I made some changes (the BIN variable was change from a one dimensional array to a three dimensional array is the major change). I emailed the code to the support address.
Line 5 corresponds to the “size” intrinsic, but “size” should be fine to use within an OpenACC compute region. Hence, I’m not sure what the problem is here.
Can you please provide a reproducing example? If it’s too large to post, please send a note to PGI Customer Service (support@pgroup.com) and ask them to forward it to me.
This was Cuda fortran code not Openacc. I emailed all of the code to the support email address several days ago. I have gotten around the problem by pulling the if statements out of the loop and creating explicit statements for each i:
if (i_bin_index(1) == 1) l_bound(1) = 0
if (i_bin_index(1) == size(bin,1)) u_bound(1) = 0
if (i_bin_index(2) == 1) l_bound(2) = 0
if (i_bin_index(2) == size(bin,2)) u_bound(2) = 0
if (i_bin_index(3) == 1) l_bound(3) = 0
if (i_bin_index(3) == size(bin,3)) u_bound(3) = 0
