That won’t work either… the host cannot write to test_ptr. You’ll need a combination of cudatGetSymbolAddress and cudaMemcpyToSymbol in order to truly initialize that pointer. But ask yourself if you truly want to do this… There is almost never a good reason to want to do an uncoalesced read from global mem just to get a pointer to perform yet another read from global mem.
I am just reporting a compiler defect. Please don’t read my code literally.
As for workarounds, I guess the simplest one would be to call a host function to init the pointers. But in my real code the tables are supposed to reside constant memory, I haven’t found an acceptable workaround, so suggestions welcome.
Well, I do. I need starting addresses of some variable length tables. I don’t see why not if this happens outside any performance critical loop. Alternative would be a huge case statement.
well, I agree with MisterAnderson42 - this is indeed not implemented in nvcc but I guess this is not a compiler bug - global memory is just not supposed to be initialized in this way.
So you can either use constant memory properly initialized or, if your tables are too large, put them to texture memory and pass starting indices as parameters to your kernel
Actually, you don’t agree MisterAnderson42. He never said that this compiler behaviour was not a compiler bug. If a failed assertion is not a compiler defect for you then I am grateful that you don’t write compilers I am used to use.
MisterAnderson42 only warned me about the adverse performance effect of such statement, and I replied that in my code it is used so marginally, that there would not be any.
Yes, daddy. I will never take constant pointer to a constant again. This is sooooo improper. :">
Seriously, I don’t find your void patronizing statements appropriate.
You can’t tell a legal C statement from an illegal C statement. You can’t tell a failed assertion from a compile time warning. And you even can’t even tell upload form download. It is therefore impossible for you to offend me. By calling me a fool, or in any other way.
You claim that nvcc is full of bugs. So why don’t you disclose the list of bugs you found?
Prior to answering me, ask yourself a question if you really have something to say.
