All,
I’m trying to build Open MPI 1.6.5 with Free PGI (14.3 as I downloaded it). I first tried configuring with:
./configure CC=pgcc CXX=g++ F77=pgfortran FC=pgfortran CFLAGS='-m64' CXXFLAGS='-m64' FCFLAGS='-m64' FFLAGS='-m64' --prefix=/Users/fortran/MPI/openmpi_1.6.5-pgi_14.3-pgcc | & tee configure.pgi14.3.pgcc.log
but that led to:
checking if C and C++ are link compatible... no
* It appears that your C++ compiler is unable to link against object
* files created by your C compiler. This generally indicates either
* a conflict between the options specified in CFLAGS and CXXFLAGS
* or a problem with the local compiler installation. More
* information (including exactly what command was given to the
* compilers and what error resulted when the commands were executed) is
* available in the config.log file in this directory.
configure: error: C and C++ compilers are not link compatible. Can not continue.
Now, as the code I’m ultimately targeting is mainly Fortran, I figured let’s try using just gcc, g++, and pgfortran:
./configure CC=gcc CXX=g++ F77=pgfortran FC=pgfortran CFLAGS='-m64' CXXFLAGS='-m64' FCFLAGS='-m64' FFLAGS='-m64' --prefix=/Users/fortran/MPI/openmpi_1.6.5-pgi_14.3-gcc | & tee configure.pgi14.3.gcc.log
and that works. So, I issue a “make” which runs without Error and then do the always important “make check” and it fails after checking some atomic bits (which pass):
Making check in class
/Applications/Xcode.app/Contents/Developer/usr/bin/make ompi_rb_tree opal_bitmap opal_hash_table opal_list opal_value_array opal_pointer_array
CC ompi_rb_tree.o
ompi_rb_tree.c:347:70: warning: cast to 'void *' from smaller integer type 'int' [-Wint-to-void-pointer-cast]
((ompi_test_rb_value_t *) new_value)->registered_mpools[0] = (void *) i;
1 warning generated.
CCLD ompi_rb_tree
Undefined symbols for architecture x86_64:
"_opal_cache_line_size", referenced from:
_test2 in ompi_rb_tree.o
_ompi_rb_tree_construct in libmpi.a(ompi_rb_tree.o)
ld: symbol(s) not found for architecture x86_64
clang: error: linker command failed with exit code 1 (use -v to see invocation)
make[3]: *** [ompi_rb_tree] Error 1
make[2]: *** [check-am] Error 2
make[1]: *** [check-recursive] Error 1
make: *** [check-recursive] Error 1
I have no doubt there are flags I probably need to pass to configure to make this “hybrid” work, but does anyone know what they are? The classic “-DpgiFortran” perhaps?
Thanks for any help,
Matt
